path: root/lib
2006-10-29Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 3914/1: [Jornada7xx] - Typo Fix in cpu-sa1110.c (b != B) [ARM] 3913/1: n2100: fix IRQ routing for second ethernet port [ARM] Add KBUILD_IMAGE target support [ARM] Fix suspend oops caused by PXA2xx PCMCIA driver [ARM] Fix i2c-pxa slave mode support [ARM] 3900/1: Fix VFP Division by Zero exception handling. [ARM] 3899/1: Fix the normalization of the denormal double precision number. [ARM] 3909/1: Disable UWIND_INFO for ARM (again) [ARM] Add __must_check to uaccess functions [ARM] Add realview SMP default configuration [ARM] Fix SMP irqflags support
2006-10-28[PATCH] strstrip remove last blank fixMichael Holzheu
strstrip() does not remove the last blank from strings which only consist of blanks. Example: char string[] = " "; strstrip(string); results in " ", but should produce an empty string! The following patch solves this problem: Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Michael Holzheu <holzheu@de.ibm.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by Joern Engel <joern@wh.fh-wedel.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[ARM] 3909/1: Disable UWIND_INFO for ARM (again)Kevin Hilman
According to Daniel Jacobowitz, UNWIND_INFO is not useful on ARM, and in fact doesn't even compile. This patch disables the option for ARM. Signed-off-by: Kevin Hilman <khilman@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-20[PATCH] highest_possible_node_id() linkage fixAndrew Morton
Qooting Adrian: - net/sunrpc/svc.c uses highest_possible_node_id() - include/linux/nodemask.h says highest_possible_node_id() is out-of-line #if MAX_NUMNODES > 1 - the out-of-line highest_possible_node_id() is in lib/cpumask.c - lib/Makefile: lib-$(CONFIG_SMP) += cpumask.o CONFIG_ARCH_DISCONTIGMEM_ENABLE=y, CONFIG_SMP=n, CONFIG_SUNRPC=y -> highest_possible_node_id() is used in net/sunrpc/svc.c CONFIG_NODES_SHIFT defined and > 0 -> include/linux/numa.h: MAX_NUMNODES > 1 -> compile error The bug is not present on architectures where ARCH_DISCONTIGMEM_ENABLE depends on NUMA (but m32r isn't the only affected architecture). So move the function into page_alloc.c Cc: Adrian Bunk <bunk@stusta.de> Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/dtor/inputLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: fm801-gp - handle errors from pci_enable_device() Input: gameport core - handle errors returned by device_bind_driver() Input: serio core - handle errors returned by device_bind_driver() Lockdep: fix compile error in drivers/input/serio/serio.c Input: serio - add lockdep annotations Lockdep: add lockdep_set_class_and_subclass() and lockdep_set_subclass() Input: atkbd - supress "too many keys" error message Input: i8042 - supress ACK/NAKs when blinking during panic Input: add missing exports to fix modular build
2006-10-17[PATCH] remove carta_random32Andrew Morton
This library function should be in obj-y and not in lib-y. But when we do that it clashes unpleasantly with the assembly-language implementation in the ia64 architecture. Instead of trying to fix it all up, just remove the generic carta_random32 in the expectation that the recently-made-generic random32() will suffice. If/when perfmon is migrated to random32, ia64's private carta_random32 implementation can also be removed. Cc: Stephane Eranian <eranian@hpl.hp.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-17[PATCH] rename net_random to random32Stephen Hemminger
Make net_random() more widely available by calling it random32 akpm: hopefully this will permit the removal of carta_random32. That needs confirmation from Stephane - this code looks somewhat more computationally expensive, and has a different (ie: callee-stateful) interface. [akpm@osdl.org: lots of build fixes, cleanups] Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Stephane Eranian <eranian@hpl.hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-13[PATCH] uml shouldn't do HEADERS_CHECKAl Viro
The lack of asm-um/Kbuild is deliberate. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] bitmap: parse input from kernel and user buffersReinette Chatre
lib/bitmap.c:bitmap_parse() is a library function that received as input a user buffer. This seemed to have originated from the way the write_proc function of the /proc filesystem operates. This has been reworked to not use kmalloc and eliminates a lot of get_user() overhead by performing one access_ok before using __get_user(). We need to test if we are in kernel or user space (is_user) and access the buffer differently. We cannot use __get_user() to access kernel addresses in all cases, for example in architectures with separate address space for kernel and user. This function will be useful for other uses as well; for example, taking input for /sysfs instead of /proc, so it was changed to accept kernel buffers. We have this use for the Linux UWB project, as part as the upcoming bandwidth allocator code. Only a few routines used this function and they were changed too. Signed-off-by: Reinette Chatre <reinette.chatre@linux.intel.com> Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com> Cc: Paul Jackson <pj@sgi.com> Cc: Joe Korty <joe.korty@ccur.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] Add carta_random32() library routineStephane Eranian
This is a follow-up patch based on the review for perfmon2. This patch adds the carta_random32() library routine + carta_random32.h header file. This is fast, simple, and efficient pseudo number generator algorithm. We use it in perfmon2 to randomize the sampling periods. In this context, we do not need any fancy randomizer. Signed-off-by: stephane eranian <eranian@hpl.hp.com> Cc: David Mosberger <david.mosberger@acm.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] Add CONFIG_HEADERS_CHECK option to automatically run 'make ↵David Woodhouse
headers_check' In order to encourage people to notice when they break the exported headers, add a config option which automatically runs the sanity checks when building vmlinux. That way, those who use allyesconfig will notice failures. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] Disable DETECT_SOFTLOCKUP for s390Heiko Carstens
We got several false bug reports because of enabled CONFIG_DETECT_SOFTLOCKUP. Disable soft lockup detection on s390, since it doesn't work on a virtualized architecture. Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11Lockdep: add lockdep_set_class_and_subclass() and lockdep_set_subclass()Peter Zijlstra
This annotation makes it possible to assign a subclass on lock init. This annotation is meant to reduce the _nested() annotations by assigning a default subclass. One could do without this annotation and rely on lockdep_set_class() exclusively, but that would require a manual stack of struct lock_class_key objects. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-10-11Input: add missing exports to fix modular buildDmitry Torokhov
2006-10-10[PATCH] gfp annotations: radix_tree_rootAl Viro
struct radix_tree_root has unused upper bits of ->gfp_mask reused for tags bitmap. Annotated. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-06[PATCH] irq_reqs: export __irq_regsAndrew Morton
Modules might want this. Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03[PATCH] low performance of lib/sort.ckeios
It is a non-standard heap-sort algorithm implementation because the index of child node is wrong . The sort function still outputs right result, but the performance is O( n * ( log(n) + 1 ) ) , about 10% ~ 20% worse than standard algorithm. Signed-off-by: keios <keios.cn@gmail.com> Acked-by: Matt Mackall <mpm@selenic.com> Acked-by: Zou Nan hai <nanhai.zou@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] remove remaining errno and __KERNEL_SYSCALLS__ referencesArnd Bergmann
The last in-kernel user of errno is gone, so we should remove the definition and everything referring to it. This also removes the now-unused lib/execve.c file that was introduced earlier. Also remove every trace of __KERNEL_SYSCALLS__ that still remained in the kernel. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Andi Kleen <ak@muc.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Hirokazu Takata <takata.hirokazu@renesas.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] introduce kernel_execveArnd Bergmann
The use of execve() in the kernel is dubious, since it relies on the __KERNEL_SYSCALLS__ mechanism that stores the result in a global errno variable. As a first step of getting rid of this, change all users to a global kernel_execve function that returns a proper error code. This function is a terrible hack, and a later patch removes it again after the kernel syscalls are gone. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Andi Kleen <ak@muc.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Hirokazu Takata <takata.hirokazu@renesas.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] cpumask: add highest_possible_node_idGreg Banks
cpumask: add highest_possible_node_id(), analogous to highest_possible_processor_id(). [pj@sgi.com: fix typo] Signed-off-by: Greg Banks <gnb@melbourne.sgi.com> Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] Linux Kernel Dump Test ModuleAnkita Garg
A simple module to test Linux Kernel Dump mechanism. This module uses jprobes to install/activate pre-defined crash points. At different crash points, various types of crashing scenarios are created like a BUG(), panic(), exception, recursive loop and stack overflow. The user can activate a crash point with specific type by providing parameters at the time of module insertion. Please see the file header for usage information. The module is based on the Linux Kernel Dump Test Tool by Fernando <http://lkdtt.sourceforge.net>. This module could be merged with mainline. Jprobes is used here so that the context in which crash point is hit, could be maintained. This implements all the crash points as done by LKDTT except the one in the middle of tasklet_action(). Signed-off-by: Ankita Garg <ankita@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] make genpool allocator adhere to kernel-doc standardsDean Nelson
The exported kernel interfaces of genpool allocator need to adhere to the requirements of kernel-doc. Signed-off-by: Dean Nelson <dcn@sgi.com> Cc: Steve Wise <swise@opengridcomputing.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] LIB: add gen_pool_destroy()Steve Wise
Modules using the genpool allocator need to be able to destroy the data structure when unloading. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Generic ioremap_page_range: flush_cache_vmapHaavard Skinnemoen
The existing implementation of ioremap_page_range(), which was taken from i386, does this: flush_cache_all(); /* modify page tables */ flush_tlb_all(); I think this is a bit defensive, so this patch changes the generic implementation to do: /* modify page tables */ flush_cache_vmap(start, end); instead, which is similar to what vmalloc() does. This should still be correct because we never modify existing PTEs. According to James Bottomley: The problem the flush_tlb_all() is trying to solve is to avoid stale tlb entries in the ioremap area. We're just being conservative by flushing on both map and unmap. Technically what vmalloc/vfree does (only flush the tlb on unmap) is just fine because it means that the only tlb entries in the remap area must belong to in-use mappings. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Mikael Starvik <starvik@axis.com> Cc: Andi Kleen <ak@suse.de> Cc: <linux-m32r@ml.linux-m32r.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@parisc-linux.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Generic ioremap_page_range: implementationHaavard Skinnemoen
This patch adds a generic implementation of ioremap_page_range() in lib/ioremap.c based on the i386 implementation. It differs from the i386 version in the following ways: * The PTE flags are passed as a pgprot_t argument and must be determined up front by the arch-specific code. No additional PTE flags are added. * Uses set_pte_at() instead of set_pte() [bunk@stusta.de: warning fix] ]dhowells@redhat.com: nommu build fix] Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Mikael Starvik <starvik@axis.com> Cc: Andi Kleen <ak@suse.de> Cc: <linux-m32r@ml.linux-m32r.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@parisc-linux.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] list_del-debug fixAndrew Morton
These two BUG_ON()s are redundant and undesired: we're checking for this condition further on in the function, only better. Cc: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-30[PATCH] rbtree: fixed reversed RB_EMPTY_NODE and rb_next/prevJens Axboe
The conditions got reserved. Also make rb_next() and rb_prev() check for the empty condition. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-09-29[PATCH] lib/ts_fsm.c: constify structsAndreas Mohr
Constify two structs. Correct some typos. Compile-tested and run-tested (module inserted) on 2.6.18-rc4-mm3. Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] lib/rwsem.c: un-inline rwsem_down_failed_common()Andreas Mohr
Un-inlining rwsem_down_failed_common() (two callsites) reduced lib/rwsem.o on my Athlon, gcc 4.1.2 from 5935 to 5480 Bytes (455 Bytes saved). I thus guess that reduced icache footprint (and better function caching) is worth more than any function call overhead. Signed-off-by: Andreas Mohr <andi@lisas.de> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] spinlock_debug: don't recompute (jiffies_per_loop * HZ) in spinloopChuck Ebbert
In spinlock_debug.c, the spinloops call __delay() on every iteration. Because that is an external function, (jiffies_per_loop * HZ), the loop's iteration limit, gets recomputed every time. Caching it explicitly prevents that. Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] list_del debug checkManfred Spraul
A list_del() debugging check. Has been in -mm for years. Dave moved list_del() out-of-line in the debug case, so this is now suitable for mainline. Cc: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] Debug variants of linked list macrosDave Jones
Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27sh: Enable verbose BUG() support.Paul Mundt
Add SH to the list of platforms interested in Verbose BUG(). Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-09-27sh: Use generic CONFIG_FRAME_POINTER.Paul Mundt
We had our own version, which serves no purpose. Simply hook SH in to the generic one. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-09-26Merge branch 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6Linus Torvalds
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6: (225 commits) [PATCH] Don't set calgary iommu as default y [PATCH] i386/x86-64: New Intel feature flags [PATCH] x86: Add a cumulative thermal throttle event counter. [PATCH] i386: Make the jiffies compares use the 64bit safe macros. [PATCH] x86: Refactor thermal throttle processing [PATCH] Add 64bit jiffies compares (for use with get_jiffies_64) [PATCH] Fix unwinder warning in traps.c [PATCH] x86: Allow disabling early pci scans with pci=noearly or disallowing conf1 [PATCH] x86: Move direct PCI scanning functions out of line [PATCH] i386/x86-64: Make all early PCI scans dependent on CONFIG_PCI [PATCH] Don't leak NT bit into next task [PATCH] i386/x86-64: Work around gcc bug with noreturn functions in unwinder [PATCH] Fix some broken white space in ia32_signal.c [PATCH] Initialize argument registers for 32bit signal handlers. [PATCH] Remove all traces of signal number conversion [PATCH] Don't synchronize time reading on single core AMD systems [PATCH] Remove outdated comment in x86-64 mmconfig code [PATCH] Use string instructions for Core2 copy/clear [PATCH] x86: - restore i8259A eoi status on resume [PATCH] i386: Split multi-line printk in oops output. ...
2006-09-26Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6: (47 commits) Driver core: Don't call put methods while holding a spinlock Driver core: Remove unneeded routines from driver core Driver core: Fix potential deadlock in driver core PCI: enable driver multi-threaded probe Driver Core: add ability for drivers to do a threaded probe sysfs: add proper sysfs_init() prototype drivers/base: check errors drivers/base: Platform notify needs to occur before drivers attach to the device v4l-dev2: handle __must_check add CONFIG_ENABLE_MUST_CHECK add __must_check to device management code Driver core: fixed add_bind_files() definition Driver core: fix comments in drivers/base/power/resume.c sysfs_remove_bin_file: no return value, dump_stack on error kobject: must_check fixes Driver core: add ability for devices to create and remove bin files Class: add support for class interfaces for devices Driver core: create devices/virtual/ tree Driver core: add device_rename function Driver core: add ability for classes to handle devices properly ...
2006-09-26[PATCH] avr32 architectureHaavard Skinnemoen
This adds support for the Atmel AVR32 architecture as well as the AT32AP7000 CPU and the AT32STK1000 development board. AVR32 is a new high-performance 32-bit RISC microprocessor core, designed for cost-sensitive embedded applications, with particular emphasis on low power consumption and high code density. The AVR32 architecture is not binary compatible with earlier 8-bit AVR architectures. The AVR32 architecture, including the instruction set, is described by the AVR32 Architecture Manual, available from http://www.atmel.com/dyn/resources/prod_documents/doc32000.pdf The Atmel AT32AP7000 is the first CPU implementing the AVR32 architecture. It features a 7-stage pipeline, 16KB instruction and data caches and a full Memory Management Unit. It also comes with a large set of integrated peripherals, many of which are shared with the AT91 ARM-based controllers from Atmel. Full data sheet is available from http://www.atmel.com/dyn/resources/prod_documents/doc32003.pdf while the CPU core implementation including caches and MMU is documented by the AVR32 AP Technical Reference, available from http://www.atmel.com/dyn/resources/prod_documents/doc32001.pdf Information about the AT32STK1000 development board can be found at http://www.atmel.com/dyn/products/tools_card.asp?tool_id=3918 including a BSP CD image with an earlier version of this patch, development tools (binaries and source/patches) and a root filesystem image suitable for booting from SD card. Alternatively, there's a preliminary "getting started" guide available at http://avr32linux.org/twiki/bin/view/Main/GettingStarted which provides links to the sources and patches you will need in order to set up a cross-compiling environment for avr32-linux. This patch, as well as the other patches included with the BSP and the toolchain patches, is actively supported by Atmel Corporation. [dmccr@us.ibm.com: Fix more pxx_page macro locations] [bunk@stusta.de: fix `make defconfig'] Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Dave McCracken <dmccr@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] optimize hweight64 for x86_64Andi Kleen
Based on patch from David Rientjes <rientjes@google.com>, but changed by AK. Optimizes the 64-bit hamming weight for x86_64 processors assuming they have fast multiplication. Uses five fewer bitops than the generic hweight64. Benchmark on one EMT64 showed ~25% speedup with 2^24 consecutive calls. Define a new ARCH_HAS_FAST_MULTIPLIER that can be set by other architectures that can also multiply fast. Signed-off-by: Andi Kleen <ak@suse.de>
2006-09-26[PATCH] Don't force frame pointers for lockdepAndi Kleen
Now that stacktrace supports dwarf2 don't force frame pointers for lockdep anymore Cc: mingo@elte.hu Signed-off-by: Andi Kleen <ak@suse.de>
2006-09-25Driver core: Don't call put methods while holding a spinlockAlan Stern
The klist utility routines currently call _put methods while holding a spinlock. This is of course illegal; a put routine could try to unregister a device and hence need to sleep. No problems have arisen until now because in many cases klist removals were done synchronously, so the _put methods were never actually used. In other cases we may simply have been lucky. This patch (as784) reworks the klist routines so that _put methods are called only _after_ the klist's spinlock has been released. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-25add CONFIG_ENABLE_MUST_CHECKAndrew Morton
Those 1500 warnings can be a bit of a pain. Add a config option to shut them up. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-25kobject: must_check fixesRandy Dunlap
Check all __must_check warnings in lib/kobject.c Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-22[PATCH] fix missing ifdefs in syscall classes hookup for generic targetsAl Viro
several targets have no ....at() family and m32r calls its only chown variant chown32(), with __NR_chown being undefined. creat(2) is also absent in some targets. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-12[PATCH] syscall class hookup for all normal targetsAl Viro
Take default arch/*/kernel/audit.c to lib/, have those with special needs (== biarch) define AUDIT_ARCH in their Kconfig. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-08-22[TEXTSEARCH]: Fix Boyer Moore initialization bugMichael Rash
The pattern is set after trying to compute the prefix table, which tries to use it. Initialize it before calling compute_prefix_tbl, make compute_prefix_tbl consistently use only the data from struct ts_bm and remove the now unnecessary arguments. Signed-off-by: Michael Rash <mbr@cipherdyne.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-06[PATCH] disable debugging version of write_lock()Andrew Morton
We've confirmed that the debug version of write_lock() can get stuck for long enough to cause NMI watchdog timeouts and hence a crash. We don't know why, yet. Disable it for now. Also disable the similar read_lock() code. Just in case. Thanks to Dave Olson <olson@unixfolk.com> for reporting and testing. Acked-by: Ingo Molnar <mingo@elte.hu> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-03PCI: docking station: remove dock ueventsKristen Carlson Accardi
Remove uevent dock notifications. There are no consumers of these events at present, and uevents are likely not the correct way to send this type of event anyway. Until I get some kind of idea if anyone in userspace cares about dock events, I will just not send any. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-31[PATCH] Fix ppc32 zImage inflatePeter Korsgaard
The recent zlib update (commit 4f3865fb57a04db7cca068fed1c15badc064a302) broke ppc32 zImage decompression as it tries to decompress to address zero and the updated zlib_inflate checks that strm->next_out isn't a null pointer. This little patch fixes it. [rpurdie@rpsys.net: add comment] Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: Tom Rini <trini@kernel.crashing.org> Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
