commit 161b6ae0e067e421b20bb35caf66bdb405c929ac upstream.
Order of initialization look like this:
debugobjects
kmemleak
...(lots of other subsystems)...
workqueues (through early initcall)
debugobjects use schedule_work for batch freeing of its data and kmemleak
heavily use debugobjects, so when it comes to freeing and workqueues were
not initialized yet, kernel crashes:
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff810854d1>] __queue_work+0x29/0x41a
[<ffffffff81085910>] queue_work_on+0x16/0x1d
[<ffffffff81085abc>] queue_work+0x29/0x55
[<ffffffff81085afb>] schedule_work+0x13/0x15
[<ffffffff81242de1>] free_object+0x90/0x95
[<ffffffff81242f6d>] debug_check_no_obj_freed+0x187/0x1d3
[<ffffffff814b6504>] ? _raw_spin_unlock_irqrestore+0x30/0x4d
[<ffffffff8110bd14>] ? free_object_rcu+0x68/0x6d
[<ffffffff8110890c>] kmem_cache_free+0x64/0x12c
[<ffffffff8110bd14>] free_object_rcu+0x68/0x6d
[<ffffffff810b58bc>] __rcu_process_callbacks+0x1b6/0x2d9
because system_wq is NULL.
Fix it by checking if workqueues susbystem was initialized before using.
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Dipankar Sarma <dipankar@in.ibm.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/20110528112342.GA3068@joi.lan
commit ba9f207c9f82115aba4ce04b22e0081af0ae300f upstream.
HARDIRQ_ENTER() maps to irq_enter() which calls rcu_irq_enter().
But HARDIRQ_EXIT() maps to __irq_exit() which doesn't call
rcu_irq_exit().
So for every locking selftest that simulates hardirq disabled,
we create an imbalance in the rcu extended quiescent state
internal state.
As a result, after the first missing rcu_irq_exit(), subsequent
irqs won't exit dyntick-idle mode after leaving the interrupt
handler. This means that RCU won't see the affected CPU as being
in an extended quiescent state, resulting in long grace-period
delays (as in grace periods extending for hours).
To fix this, just use __irq_enter() to simulate the hardirq
context. This is sufficient for the locking selftests as we
don't need to exit any extended quiescent state or perform
any check that irqs normally do when they wake up from idle.
As a side effect, this patch makes it possible to restore
"rcu: Decrease memory-barrier usage based on semi-formal proof",
which eventually helped finding this bug.
Reported-and-tested-by: Yinghai Lu <yinghai@kernel.org>
commit 8474b591faf3bb0a1e08a60d21d6baac498f15e4 upstream.
WARNING: at lib/list_debug.c:26 __list_add+0x3f/0x81()
Hardware name: Express5800/B120a [N8400-085]
list_add corruption. next->prev should be prev (ffffffff81a7ea00), but was dead000000200200. (next=ffff88080b872d58).
Modules linked in: aoe ipt_MASQUERADE iptable_nat nf_nat autofs4 sunrpc bridge 8021q garp stp llc ipv6 cpufreq_ondemand acpi_cpufreq freq_table dm_round_robin dm_multipath kvm_intel kvm uinput lpfc scsi_transport_fc igb ioatdma scsi_tgt i2c_i801 i2c_core dca iTCO_wdt iTCO_vendor_support pcspkr shpchp megaraid_sas [last unloaded: aoe]
Pid: 54, comm: events/3 Tainted: G W 2.6.34-vanilla1 #1
Call Trace:
[<ffffffff8104bd77>] warn_slowpath_common+0x7c/0x94
[<ffffffff8104bde6>] warn_slowpath_fmt+0x41/0x43
[<ffffffff8120fd2e>] __list_add+0x3f/0x81
[<ffffffff81212a12>] __percpu_counter_init+0x59/0x6b
[<ffffffff810d8499>] bdi_init+0x118/0x17e
[<ffffffff811f2c50>] blk_alloc_queue_node+0x79/0x143
[<ffffffff811f2d2b>] blk_alloc_queue+0x11/0x13
[<ffffffffa02a931d>] aoeblk_gdalloc+0x8e/0x1c9 [aoe]
[<ffffffffa02aa655>] aoecmd_sleepwork+0x25/0xa8 [aoe]
[<ffffffff8106186c>] worker_thread+0x1a9/0x237
[<ffffffffa02aa630>] ? aoecmd_sleepwork+0x0/0xa8 [aoe]
[<ffffffff81065827>] ? autoremove_wake_function+0x0/0x39
[<ffffffff810616c3>] ? worker_thread+0x0/0x237
[<ffffffff810653ad>] kthread+0x7f/0x87
[<ffffffff8100aa24>] kernel_thread_helper+0x4/0x10
[<ffffffff8106532e>] ? kthread+0x0/0x87
[<ffffffff8100aa20>] ? kernel_thread_helper+0x0/0x10
It's because there is no initialization code for a list_head contained in
the struct backing_dev_info under CONFIG_HOTPLUG_CPU, and the bug comes up
when block device drivers calling blk_alloc_queue() are used. In case of
me, I got them by using aoe.
Signed-off-by: Masanori Itoh <itoumsn@nttdata.co.jp>
commit e59464c735db19619cde2aa331609adb02005f5b upstream.
memset() is called with the wrong address and the kernel panics.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
Cc: Patrick McHardy <kaber@trash.net>
Acked-by: David Rientjes <rientjes@google.com>
This is retry of reverted 859ddf09743a8cc680af33f7259ccd0fd36bfe9d
("idr: fix a critical misallocation bug") which contained two bugs.
* pa[idp->layers] should be cleared even if it's not used by
sub_alloc() because it's used by mark idr_mark_full().
* The original condition check also assigned pa[l] to p which the new
code didn't do thus leaving p pointing at the wrong layer.
Both problems have been fixed and the idr code has received good amount
testing using userland testing setup where simple bitmap allocator is
run parallel to verify the result of idr allocation.
The bug this patch fixes is caused by sub_alloc() optimization path
bypassing out-of-room condition check and restarting allocation loop
with starting value higher than maximum allowed value. For detailed
description, please read commit message of 859ddf09.
Based-on-patch-from: Eric Paris <eparis@redhat.com>
Reported-by: Eric Paris <eparis@redhat.com>
Tested-by: Stefan Lippers-Hollmann <s.l-h@gmx.de>
Tested-by: Serge Hallyn <serue@us.ibm.com>
Commit 859ddf09743a8cc680af33f7259ccd0fd36bfe9d tried to fix
misallocation bug but broke full bit marking by not clearing
pa[idp->layers] and also is causing X failures due to lookup failure
in drm code. The cause of the latter hasn't been found yet. Revert
the fix for now.
Eric Paris located a bug in idr. With IDR_BITS of 6, it grows to three
layers when id 4096 is first allocated. When that happens, idr wraps
incorrectly and searches the idr array ignoring the high bits. The
following test code from Eric demonstrates the bug nicely.
#include <linux/idr.h>
#include <linux/kernel.h>
#include <linux/module.h>
static DEFINE_IDR(test_idr);
int init_module(void)
int ret, forty95, forty96;
void *addr;
/* add 2 entries both with 4095 as the start address */
again1:
if (!idr_pre_get(&test_idr, GFP_KERNEL))
return -ENOMEM;
ret = idr_get_new_above(&test_idr, (void *)4095, 4095, &forty95);
if (ret) {
if (ret == -EAGAIN)
goto again1;
return ret;
if (forty95 != 4095)
printk(KERN_ERR "hmmm, forty95=%d\n", forty95);
again2:
return -ENOMEM;
ret = idr_get_new_above(&test_idr, (void *)4096, 4095, &forty96);
if (ret) {
if (ret == -EAGAIN)
goto again2;
return ret;
if (forty96 != 4096)
printk(KERN_ERR "hmmm, forty96=%d\n", forty96);
/* try to find the 2 entries, noticing that 4096 broke */
addr = idr_find(&test_idr, forty95);
if ((int)addr != forty95)
printk(KERN_ERR "hmmm, after find forty95=%d addr=%d\n", forty95, (int)addr);
addr = idr_find(&test_idr, forty96);
if ((int)addr != forty96)
printk(KERN_ERR "hmmm, after find forty96=%d addr=%d\n", forty96, (int)addr);
/* really weird, the entry which should be at 4096 is actually at 0!! */
addr = idr_find(&test_idr, 0);
if ((int)addr)
printk(KERN_ERR "found an entry at id=0 for addr=%d\n", (int)addr);
idr_remove(&test_idr, forty95);
idr_remove(&test_idr, forty96);
return 0;
void cleanup_module(void)
MODULE_AUTHOR("Eric Paris <eparis@redhat.com>");
MODULE_DESCRIPTION("Simple idr test");
MODULE_LICENSE("GPL");
This happens because when sub_alloc() back tracks it doesn't always do it
step-by-step while the over-the-limit detection assumes step-by-step
backtracking. The logic in sub_alloc() looks like the following.
restart:
clear pa[top level + 1] for end cond detection
l = top level
while (true) {
search for empty slot at this level
if (not found) {
push id to the next possible value
l++
A: if (pa[l] is clear)
failed, return asking caller to grow the tree
if (going up 1 level gives more slots to search)
continue the while loop above with the incremented l
else
C: goto restart
adjust id accordingly to the found slot
if (l == 0)
return found id;
create lower level if not there yet
record pa[l] and l--
Test A is the fail exit condition but this assumes that failure is
propagated upwared one level at a time but the B optimization path breaks
the assumption and restarts the whole thing with a start value which is
above the possible limit with the current layers. sub_alloc() assumes the
start id value is inside the limit when called and test A is the only exit
condition check, so it ends up searching for empty slot while ignoring
high set bit.
So, for 4095->4096 test, level0 search fails but pa[1] contains a valid
pointer. However, going up 1 level wouldn't give any more empty slot so
it takes C and when the whole thing restarts nobody notices the high bit
set beyond the top level.
This patch fixes the bug by changing the fail exit condition check to full
id limit check.
Cc: <stable@kernel.org>
warning: symbol 'filter_fops' was not declared. Should it be static?
Signed-off-by: Thiago Farina <tfransosi@gmail.com>
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
* 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
tracing/filters: Add comment for match callbacks
tracing/filters: Fix MATCH_FULL filter matching for PTR_STRING
tracing/filters: Fix MATCH_MIDDLE_ONLY filter matching
lib: Introduce strnstr()
tracing/filters: Fix MATCH_END_ONLY filter matching
tracing/filters: Fix MATCH_FRONT_ONLY filter matching
ftrace: Fix MATCH_END_ONLY function filter
tracing/x86: Derive arch from bits argument in recordmcount.pl
ring-buffer: Add rb_list_head() wrapper around new reader page next field
ring-buffer: Wrap a list.next reference with rb_list_head()
It differs strstr() in that it limits the length to be searched
in the first string.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
LKML-Reference: <4B4E8743.6030805@cn.fujitsu.com>
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Commit ac4c2a3bbe5db5fc570b1d0ee1e474db7cb22585 broke the build
of all powerpc boot wrappers.
It attempts to add an include of autoconf.h but used the wrong
path for it. It also adds -D__KERNEL__ to our boot wrapper, both
things that we pretty much didn't do on purpose so far.
We want our boot wrapper to remain independent enough of the kernel
for various reasons, one of them being that you can "wrap" an existing
kernel at distro install time which allows to ship one kernel image
and a set of boot wrappers for different platforms, the wrappers
don't have to be built out of the same kernel build tree.
It's also incorrect to do what the patch does in our boot environment
since we may not have a proper alignment exception handler which means
we may not be able to fixup the few cases where an unaligned access will
need SW emulation (depends on the core variant, could be when crossing
page or segment boundaries for example).
This patch fixes it by putting the old code back in and using the
new "fancy" variant only when CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS
is set, which happens not to be set on powerpc since we don't include
autoconf.h. It also reverts the changes to our boot wrapper Makefile.
This means that x86 should, afaik, keep the optimisations since its
boot wrapper does include autoconf.h and define __KERNEL__ (though I
doubt they make that much different outside of slow embedded processors).
There are two copies of list_sort() in the tree already, one in the DRM
code, another in ubifs. Now XFS needs this as well. Create a generic
list_sort() function from the ubifs version and convert existing users
to it so we don't end up with yet another copy in the tree.
Signed-off-by: Dave Chinner <david@fromorbit.com>
Acked-by: Dave Airlie <airlied@redhat.com>
Acked-by: Artem Bityutskiy <dedekind@infradead.org>
Reported-by: Josip Rodin <joy@entuzijast.net>
Cc: Joe Perches <joe@perches.com>
lib/rational.c:62: warning: data definition has no type or storage class
lib/rational.c:62: warning: type defaults to 'int' in declaration of 'EXPORT_SYMBOL'
lib/rational.c:62: warning: parameter names (without types) in function declaration
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
Cc: Oskar Schirmer <os@emlix.com>
Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com>
Tested-by: Wu Zhangjin <wuzhangjin@gmail.com>
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
Tested-by: Russell King <rmk@arm.linux.org.uk>
Acked-by: Russell King <rmk@arm.linux.org.uk>
This patch series adds generic support for creating and extracting
LZO-compressed kernel images, as well as support for using such images on
the x86 and ARM architectures, and support for creating and using
LZO-compressed initrd and initramfs images.
Russell King said:
: Testing on a Cortex A9 model:
: - lzo decompressor is 65% of the time gzip takes to decompress a kernel
: - lzo kernel is 9% larger than a gzip kernel
: which I'm happy to say confirms your figures when comparing the two.
: However, when comparing your new gzip code to the old gzip code:
: - new is 99% of the size of the old code
: - new takes 42% of the time to decompress than the old code
: What this means is that for a proper comparison, the results get even better:
: - lzo is 7.5% larger than the old gzip'd kernel image
: - lzo takes 28% of the time that the old gzip code took
: So the expense seems definitely worth the effort. The only reason I
: can think of ever using gzip would be if you needed the additional
: compression (eg, because you have limited flash to store the image.)
: I would argue that the default for ARM should therefore be LZO.
This patch:
The lzo compressor is worse than gzip at compression, but faster at
extraction. Here are some figures for an ARM board I'm working on:
Uncompressed size: 3.24Mo
gzip 1.61Mo 0.72s
lzo 1.75Mo 0.48s
So for a compression ratio that is still relatively close to gzip, it's
much faster to extract, at least in that case.
This part contains:
- Makefile routine to support lzo compression
- Fixes to the existing lzo compressor so that it can be used in
compressed kernels
- wrapper around the existing lzo1x_decompress, as it only extracts one
block at a time, while we need to extract a whole file here
- config dialog for kernel compression
[akpm@linux-foundation.org: cleanup]
JFFS2 uses lesser compression ratio and inflate always ends up in "copy
direct from output" case.
This patch tries to optimize the direct copy procedure. Uses
get_unaligned() but only in one place.
The copy loop just above this one can also use this optimization, but I
havn't done so as I have not tested if it is a win there too.
On my MPC8321 this is about 17% faster on my JFFS2 root FS than the
original.
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
Cc: Roel Kluin <roel.kluin@gmail.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
DMA_FROM_DEVICE and
There is no need to perform full BIDIR sync (copying the buffers in case
of swiotlb and similar schemes) if we know that the owner (CPU or device)
hasn't altered the data.
Addresses the false-positive reported at
http://bugzilla.kernel.org/show_bug.cgi?id=14169
Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl>
Cc: Joerg Roedel <joerg.roedel@amd.com>
* 'x86-fixes-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
dma-debug: Fix bug causing build warning
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86/agp: Fix agp_amd64_init() initialization with CONFIG_GART_IOMMU enabled
x86: SGI UV: Fix writes to led registers on remote uv hubs
x86, kmemcheck: Use KERN_WARNING for error reporting
x86: Use KERN_DEFAULT log-level in __show_regs()
x86, compress: Force i386 instructions for the decompressor
x86/amd-iommu: Fix initialization failure panic
dma-debug: Do not add notifier when dma debugging is disabled.
x86: Fix objdump version check in chkobjdump.awk for different formats.
Trivial conflicts in arch/x86/include/asm/uv/uv_hub.h due to me having
applied an earlier version of an SGI UV fix.
Stephen Rothwell reported the following build warning:
lib/dma-debug.c: In function 'dma_debug_device_change':
lib/dma-debug.c:680: warning: 'return' with no value, in function returning non-void
Introduced by commit f797d9881b62c2ddb1d2e7bd80d87141949c84aa
("dma-debug: Do not add notifier when dma debugging is disabled").
Return 0 [notify-done] when disabled. (this is standard bus notifier behavior.)
Signed-off-by: Shaun Ruffell <sruffell@digium.com>
LKML-Reference: <20091231125624.GA14666@liondog.tnic>
git://git.kernel.org/pub/scm/linux/kernel/git/joro/linux-2.6-iommu into x86/urgent
Fix kernel-doc warnings (@arg name) in string.c::skip_spaces().
Warning(lib/string.c:347): No description found for parameter 'str'
Warning(lib/string.c:347): Excess function parameter 's' description in 'skip_spaces'
If CONFIG_HAVE_DMA_API_DEBUG is defined and "dma_debug=off" is
specified on the kernel command line, when you detach a driver from a
device you can cause the following NULL pointer dereference:
IP: [<c0580d35>] dma_debug_device_change+0x5d/0x117
The problem is that the dma_debug_device_change notifier function is
added to the bus notifier chain even though the dma_entry_hash array
was never initialized. If dma debugging is disabled, this patch both
prevents dma_debug_device_change notifiers from being added to the
chain, and additionally ensures that the dma_debug_device_change
notifier function is a no-op.
Cc: stable@kernel.org
x86, irq: Allow 0xff for /proc/irq/[n]/smp_affinity on an 8-cpu system
Makefile: Unexport LC_ALL instead of clearing it
x86: Fix objdump version check in arch/x86/tools/chkobjdump.awk
x86: Reenable TSC sync check at boot, even with NONSTOP_TSC
x86: Don't use POSIX character classes in gen-insn-attr-x86.awk
Makefile: set LC_CTYPE, LC_COLLATE, LC_NUMERIC to C
x86: Increase MAX_EARLY_RES; insufficient on 32-bit NUMA
x86: Fix checking of SRAT when node 0 ram is not from 0
x86, cpuid: Add "volatile" to asm in native_cpuid()
x86, msr: msrs_alloc/free for CONFIG_SMP=n
x86, amd: Get multi-node CPU info from NodeId MSR instead of PCI config space
x86: Add IA32_TSC_AUX MSR and use it
x86, msr/cpuid: Register enough minors for the MSR and CPUID drivers
initramfs: add missing decompressor error check
bzip2: Add missing checks for malloc returning NULL
bzip2/lzma/gzip: pre-boot malloc doesn't return NULL on failure
* 'kmemleak' of git://linux-arm.org/linux-2.6:
kmemleak: fix kconfig for crc32 build error
kmemleak: Reduce the false positives by checking for modified objects
kmemleak: Show the age of an unreferenced object
kmemleak: Release the object lock before calling put_object()
kmemleak: Scan the _ftrace_events section in modules
kmemleak: Simplify the kmemleak_scan_area() function prototype
kmemleak: Do not use off-slab management with SLAB_NOLEAKTRACE
These were added in
9ac6e44 (lib/vsprintf.c: add %pU to print UUID/GUIDs)
c7dabef (vsprintf: use %pR, %pr instead of %pRt, %pRf)
8a27f7c (lib/vsprintf.c: Add "%pI6c" - print pointer as compressed ipv6 address)
4aa9960 (printk: add %I4, %I6, %i4, %i6 format specifiers)
dd45c9c (printk: add %pM format specifier for MAC addresses)
but only added comments to pointer() not vsnprintf() that is refered to by
printk's comments.
Cc: Harvey Harrison <harvey.harrison@gmail.com>
Cc: Jens Rosenboom <jens@mcbone.net>
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
* 'next' of git://git.secretlab.ca/git/linux-2.6: (23 commits)
powerpc: fix up for mmu_mapin_ram api change
powerpc: wii: allow ioremap within the memory hole
powerpc: allow ioremap within reserved memory regions
wii: use both mem1 and mem2 as ram
wii: bootwrapper: add fixup to calc useable mem2
powerpc: gamecube/wii: early debugging using usbgecko
powerpc: reserve fixmap entries for early debug
powerpc: wii: default config
powerpc: wii: platform support
powerpc: wii: hollywood interrupt controller support
powerpc: broadway processor support
powerpc: wii: bootwrapper bits
powerpc: wii: device tree
powerpc: gamecube: default config
powerpc: gamecube: platform support
powerpc: gamecube/wii: flipper interrupt controller support
powerpc: gamecube/wii: udbg support for usbgecko
powerpc: gamecube/wii: do not include PCI support
powerpc: gamecube/wii: declare as non-coherent platforms
powerpc: gamecube/wii: introduce GAMECUBE_COMMON
Fix up conflicts in arch/powerpc/mm/fsl_booke_mmu.c.
Hopefully even close to correctly.
Use bitmap library and kill some unused iommu helper functions.
1. s/iommu_area_free/bitmap_clear/
2. s/iommu_area_reserve/bitmap_set/
3. Use bitmap_find_next_zero_area instead of find_next_zero_area
This cannot be simple substitution because find_next_zero_area
doesn't check the last bit of the limit in bitmap
4. Remove iommu_area_free, iommu_area_reserve, and find_next_zero_area
Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
This introduces new bitmap functions:
bitmap_set: Set specified bit area
bitmap_clear: Clear specified bit area
bitmap_find_next_zero_area: Find free bit area
These are mostly stolen from iommu helper. The differences are:
- Use find_next_bit instead of doing test_bit for each bit
- Rewrite bitmap_set and bitmap_clear
Instead of setting or clearing for each bit.
- Check the last bit of the limit
iommu-helper doesn't want to find such area
- The return value if there is no zero area
find_next_zero_area in iommu helper: returns -1
bitmap_find_next_zero_area: return >= bitmap size
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Lothar Wassmann <LW@KARO-electronics.de>
Cc: Roland Dreier <rolandd@cisco.com>
Cc: Yevgeny Petrilin <yevgenyp@mellanox.co.il>
dma_mask is, when interpreted as address, the last valid byte, and hence
comparison msut also be done using the last valid of the buffer in
question.
Also fix the open-coded instances in lib/swiotlb.c.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Cc: Becky Bruce <beckyb@kernel.crashing.org>
Cc: "Luck, Tony" <tony.luck@intel.com>
Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
LKML-Reference: <4b26b1ef.ln20bM9Mn4gzB21L%phillip@lougher.demon.co.uk>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (26 commits)
clockevents: Convert to raw_spinlock
clockevents: Make tick_device_lock static
debugobjects: Convert to raw_spinlocks
perf_event: Convert to raw_spinlock
hrtimers: Convert to raw_spinlocks
genirq: Convert irq_desc.lock to raw_spinlock
smp: Convert smplocks to raw_spinlocks
rtmutes: Convert rtmutex.lock to raw_spinlock
sched: Convert pi_lock to raw_spinlock
sched: Convert cpupri lock to raw_spinlock
sched: Convert rt_runtime_lock to raw_spinlock
sched: Convert rq->lock to raw_spinlock
plist: Make plist debugging raw_spinlock aware
bkl: Fixup core_lock fallout
locking: Cleanup the name space completely
locking: Further name space cleanups
alpha: Fix fallout from locking changes
locking: Implement new raw_spinlock
locking: Convert raw_rwlock functions to arch_rwlock
locking: Convert raw_rwlock to arch_rwlock
Move common crc body to new function crc32_body() cleaup and micro
optimize crc32_body for speed and less size.
Recently, We marked strstrip() as must_check. because it was frequently
misused and it should be checked. However, we found one exception.
scsi/ipr.c intentionally ignore return value of strstrip. Because it
wishes to keep the whitespace at the beginning.
Thus we need to keep with and without checked whitespace trim function.
This patch adds a new strim() and changes ipr.c to use it.
Suggested-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
UUID/GUIDs are somewhat common in kernel source.
Standardize the printed style of UUID/GUIDs by using
another extension to %p.
%pUb: 01020304-0506-0708-090a-0b0c0d0e0f10
%pUB: 01020304-0506-0708-090A-0B0C0D0E0F10 (upper case)
%pUl: 04030201-0605-0807-090a-0b0c0d0e0f10
%pUL: 04030201-0605-0807-090A-0B0C0D0E0F10 (upper case)
%pU defaults to %pUb
Cc: Jeff Garzik <jgarzik@redhat.com>
Cc: Alex Elder <aelder@sgi.com>
Cc: Artem Bityutskiy <dedekind@infradead.org>
Cc: Adrian Hunter <adrian.hunter@nokia.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Neil Brown <neilb@suse.de>
No functional change. Cache strlen() result to avoid recalculating it up
to 3 times on the worst case.
Reduces code size a little by 32 bytes:
1385 0 0 1385 569 lib/parser.o-BEFORE
1353 0 0 1353 549 lib/parser.o-AFTER
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Makes use of skip_spaces() defined in lib/string.c for removing leading
spaces from strings all over the tree.
It decreases lib.a code size by 47 bytes and reuses the function tree-wide:
64688 584 592 65864 10148 (TOTALS-BEFORE)
64641 584 592 65817 10119 (TOTALS-AFTER)
Also, while at it, if we see (*str && isspace(*str)), we can be sure to
remove the first condition (*str) as the second one (isspace(*str)) also
evaluates to 0 whenever *str == 0, making it redundant. In other words,
"a char equals zero is never a space".
Julia Lawall tried the semantic patch (http://coccinelle.lip6.fr) below,
and found occurrences of this pattern on 3 more files:
drivers/leds/led-class.c
drivers/leds/ledtrig-timer.c
drivers/video/output.c
expression str;
( // ignore skip_spaces cases
while (*str && isspace(*str)) { \(str++;\|++str;\) }
- *str &&
isspace(*str)
Cc: Julia Lawall <julia@diku.dk>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
Cc: <linux-ext4@vger.kernel.org>
Cc: Samuel Ortiz <samuel@sortiz.org>
Cc: Takashi Iwai <tiwai@suse.de>
... so that strlen() iterates over a smaller string comprising of the
remaining characters only.
On the following sentence:
while (*s && isspace(*s))
s++;
If *s == 0, isspace() evaluates to ((_ctype[*s] & 0x20) != 0), which
evaluates to ((0x08 & 0x20) != 0) which equals to 0 as well.
If *s == 1, we depend on isspace() result anyway. In other words,
"a char equals zero is never a space", so remove this check.
Also, *s != 0 is most common case (non-null string).
Fixed const return as noticed by Jan Engelhardt and James Bottomley.
Fixed unnecessary extra cast on strstrip() as noticed by Jan Engelhardt.
While at it, use tabs to indent the comments.
The difference between simple_strtoul() and simple_strtoull() is just
the size of the variable used to keep track of the sum of characters
converted to numbers:
unsigned long simple_strtoul() {...}
unsigned long long simple_strtoull(){...}
Both are same size on my Core 2/gcc 4.4.1.
Overflow condition is not checked on both functions, so an extremely large
string can break these functions so that they don't even notice it.
As we do not care for overflowing on these functions, always keep the sum
using the larger variable around (unsigned long long) on simple_strtoull()
and cast it to (unsigned long) on simple_strtoul(), which then becomes
just a wrapper around simple_strtoull().
Code size decreases by 304 bytes:
15534 0 8 15542 3cb6 vsprintf.o (ex lib/lib.a-BEFORE)
15230 0 8 15238 3b86 vsprintf.o (ex lib/lib.a-AFTER)
When converting more caller sites, the inline decision will be left up to gcc.
It decreases code size:
15710 0 8 15718 3d66 vsprintf.o (ex lib/lib.a-BEFORE)
15534 0 8 15542 3cb6 vsprintf.o (ex lib/lib.a-AFTER)
Cleanup by moving variables closer to the scope where they're used in fact.
Also, remove unneeded ones.
No functional change, just refactor the code so that it avoid checking
"if (hi)" two times in a sequence, taking advantage of previous check made.
It also reduces code size:
15726 0 8 15734 3d76 vsprintf.o (ex lib/lib.a-BEFORE)
15710 0 8 15718 3d66 vsprintf.o (ex lib/lib.a-AFTER)
It decreases code size as well:
15758 0 8 15766 3d96 vsprintf.o (ex lib/lib.a-BEFORE)
15726 0 8 15734 3d76 vsprintf.o (ex lib/lib.a-TOLOWER)
Most relevant complaints were addressed.
