path: root/lib
2009-01-30cpumask: convert lib/smp_processor_id to new cpumask opsRusty Russell
Impact: fix debug_smp_processor_id() for CONFIG_CPUMASK_OFFSTACK=y The scheduler now uses the new cpumask API, which deals up to nr_cpumask_bits, whereas the API used NR_CPUS bits. If CONFIG_CPUMASK_OFFSTACK=y these two are not equal, so the top bits are undefined. Leading to bug 12518 "BUG: using smp_processor_id() in preemptible [00000000] code: dellWirelessCtl/..." The fix is simple: use the modern API in the check. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-26Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: debugobjects: add and use INIT_WORK_ON_STACK rcu: remove duplicate CONFIG_RCU_CPU_STALL_DETECTOR relay: fix lock imbalance in relay_late_setup_files oprofile: fix uninitialized use of struct op_entry rcu: move Kconfig menu softlock: fix false panic which can occur if softlockup_thresh is reduced rcu: add __cpuinit to rcu_init_percpu_data()
2009-01-26Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (29 commits) xen: unitialised return value in xenbus_write_transaction x86: fix section mismatch warning x86: unmask CPUID levels on Intel CPUs, fix x86: work around PAGE_KERNEL_WC not getting WC in iomap_atomic_prot_pfn. x86: use standard PIT frequency xen: handle highmem pages correctly when shrinking a domain x86, mm: fix pte_free() xen: actually release memory when shrinking domain x86: unmask CPUID levels on Intel CPUs x86: add MSR_IA32_MISC_ENABLE bits to <asm/msr-index.h> x86: fix PTE corruption issue while mapping RAM using /dev/mem x86: mtrr fix debug boot parameter x86: fix page attribute corruption with cpa() Revert "x86: signal: change type of paramter for sys_rt_sigreturn()" x86: use early clobbers in usercopy*.c x86: remove kernel_physical_mapping_init() from init section fix: crash: IP: __bitmap_intersects+0x48/0x73 cpufreq: use work_on_cpu in acpi-cpufreq.c for drv_read and drv_write work_on_cpu: Use our own workqueue. work_on_cpu: don't try to get_online_cpus() in work_on_cpu. ...
2009-01-22Merge branch 'core/debugobjects' into core/urgentThomas Gleixner
2009-01-22rcu: remove duplicate CONFIG_RCU_CPU_STALL_DETECTORLai Jiangshan
Impact: remove the old CONFIG_RCU_CPU_STALL_DETECTOR tree_rcu introduce CONFIG_RCU_CPU_STALL_DETECTOR again. These two are the same exactly except: the old one "depends on CLASSIC_RCU" the new one "depends on CLASSIC_RCU || TREE_RCU" This patch remove the old one. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-18x86: define ARCH_WANT_FRAME_POINTERSJeff Mahoney
Commit da4276b8299a6544dc41ac2485d3ffca5811b3fb changed a dependency for FRAME_POINTER from X86 to ARCH_WANT_FRAME_POINTERS, but didn't actually define it. This patch adds the definition for ARCH_WANT_FRAME_POINTERS. Without it, FRAME_POINTER can't be enabled on x86. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-15lib/idr.c: use kmem_cache_zalloc() for the idr_layer cacheAndrew Morton
David points out that the idr_remove_all() function returns unused slabs to the kmem cache, but needs to zero them first or else they will be uninitialized upon next use. This causes crashes which have been observed in the firewire subsystem. He fixed this by zeroing the object before freeing it in idr_remove_all(). But we agree that simply removing the constructor and zeroing the object at allocation time is simpler than relying upon slab constructor machinery and might even be faster. This problem was introduced by "idr: make idr_remove rcu-safe" (commit cf481c20c476ad2c0febdace9ce23f5a4db19582), which was first released in 2.6.27. There are no known codesites which trigger this bug in 2.6.27 or 2.6.28. The post-2.6.28 firewire changes are the only known triggerer. There might of course be not-yet-discovered triggerers in 2.6.27 and 2.6.28, and there might be out-of-tree triggerers which are added to those kernel versions. I'll let the -stable guys decide whether they want to backport this fix. Reported-by: David Moore <dcm@acm.org> Cc: Stefan Richter <stefanr@s5r6.in-berlin.de> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Paul E. McKenney <paulmck@us.ibm.com> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Kristian Hgsberg <krh@redhat.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15idr: fix wrong kernel-docLi Zefan
idr_get_new_above() and ida_get_new_above() return an id in the range of @staring_id ... 0x7fffffff, not 0 ... 0x7fffffff. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-10Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (36 commits) x86: fix section mismatch warnings in mcheck/mce_amd_64.c x86: offer frame pointers in all build modes x86: remove duplicated #include's x86: k8 numa register active regions later x86: update Alan Cox's email addresses x86: rename all fields of mpc_table mpc_X to X x86: rename all fields of mpc_oemtable oem_X to X x86: rename all fields of mpc_bus mpc_X to X x86: rename all fields of mpc_cpu mpc_X to X x86: rename all fields of mpc_intsrc mpc_X to X x86: rename all fields of mpc_lintsrc mpc_X to X x86: rename all fields of mpc_iopic mpc_X to X x86: irqinit_64.c init_ISA_irqs should be static Documentation/x86/boot.txt: payload length was changed to payload_length x86: setup_percpu.c fix style problems x86: irqinit_64.c fix style problems x86: irqinit_32.c fix style problems x86: i8259.c fix style problems x86: irq_32.c fix style problems x86: ioport.c fix style problems ...
2009-01-10rbtree: add const qualifier to some functionsArtem Bityutskiy
The 'rb_first()', 'rb_last()', 'rb_next()' and 'rb_prev()' calls take a pointer to an RB node or RB root. They do not change the pointed objects, so add a 'const' qualifier in order to make life of the users of these functions easier. Indeed, if I have my own constant pointer &const struct my_type *p, and I call 'rb_next(&p->rb)', I get a GCC warning: warning: passing argument 1 of ‘rb_next’ discards qualifiers from pointer target type Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-nommuLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-nommu: NOMMU: Support XIP on initramfs NOMMU: Teach kobjsize() about VMA regions. FLAT: Don't attempt to expand the userspace stack to fill the space allocated FDPIC: Don't attempt to expand the userspace stack to fill the space allocated NOMMU: Improve procfs output using per-MM VMAs NOMMU: Make mmap allocation page trimming behaviour configurable. NOMMU: Make VMAs per MM as for MMU-mode linux NOMMU: Delete askedalloc and realalloc variables NOMMU: Rename ARM's struct vm_region NOMMU: Fix cleanup handling in ramfs_nommu_get_umapped_area()
2009-01-08generic swap(): lib/sort.c: rename swap to swap_funcWu Fengguang
This is to avoid name clashes for the introduction of a global swap() macro. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08NOMMU: Make VMAs per MM as for MMU-mode linuxDavid Howells
Make VMAs per mm_struct as for MMU-mode linux. This solves two problems: (1) In SYSV SHM where nattch for a segment does not reflect the number of shmat's (and forks) done. (2) In mmap() where the VMA's vm_mm is set to point to the parent mm by an exec'ing process when VM_EXECUTABLE is specified, regardless of the fact that a VMA might be shared and already have its vm_mm assigned to another process or a dead process. A new struct (vm_region) is introduced to track a mapped region and to remember the circumstances under which it may be shared and the vm_list_struct structure is discarded as it's no longer required. This patch makes the following additional changes: (1) Regions are now allocated with alloc_pages() rather than kmalloc() and with no recourse to __GFP_COMP, so the pages are not composite. Instead, each page has a reference on it held by the region. Anything else that is interested in such a page will have to get a reference on it to retain it. When the pages are released due to unmapping, each page is passed to put_page() and will be freed when the page usage count reaches zero. (2) Excess pages are trimmed after an allocation as the allocation must be made as a power-of-2 quantity of pages. (3) VMAs are added to the parent MM's R/B tree and mmap lists. As an MM may end up with overlapping VMAs within the tree, the VMA struct address is appended to the sort key. (4) Non-anonymous VMAs are now added to the backing inode's prio list. (5) Holes may be punched in anonymous VMAs with munmap(), releasing parts of the backing region. The VMA and region structs will be split if necessary. (6) sys_shmdt() only releases one attachment to a SYSV IPC shared memory segment instead of all the attachments at that addresss. Multiple shmat()'s return the same address under NOMMU-mode instead of different virtual addresses as under MMU-mode. (7) Core dumping for ELF-FDPIC requires fewer exceptions for NOMMU-mode. (8) /proc/maps is now the global list of mapped regions, and may list bits that aren't actually mapped anywhere. (9) /proc/meminfo gains a line (tagged "MmapCopy") that indicates the amount of RAM currently allocated by mmap to hold mappable regions that can't be mapped directly. These are copies of the backing device or file if not anonymous. These changes make NOMMU mode more similar to MMU mode. The downside is that NOMMU mode requires some extra memory to track things over NOMMU without this patch (VMAs are no longer shared, and there are now region structs). Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Paul Mundt <lethal@linux-sh.org>
2009-01-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (24 commits) trivial: chack -> check typo fix in main Makefile trivial: Add a space (and a comma) to a printk in 8250 driver trivial: Fix misspelling of "firmware" in docs for ncr53c8xx/sym53c8xx trivial: Fix misspelling of "firmware" in powerpc Makefile trivial: Fix misspelling of "firmware" in usb.c trivial: Fix misspelling of "firmware" in qla1280.c trivial: Fix misspelling of "firmware" in a100u2w.c trivial: Fix misspelling of "firmware" in megaraid.c trivial: Fix misspelling of "firmware" in ql4_mbx.c trivial: Fix misspelling of "firmware" in acpi_memhotplug.c trivial: Fix misspelling of "firmware" in ipw2100.c trivial: Fix misspelling of "firmware" in atmel.c trivial: Fix misspelled firmware in Kconfig trivial: fix an -> a typos in documentation and comments trivial: fix then -> than typos in comments and documentation trivial: update Jesper Juhl CREDITS entry with new email trivial: fix singal -> signal typo trivial: Fix incorrect use of "loose" in event.c trivial: printk: fix indentation of new_text_line declaration trivial: rtc-stk17ta8: fix sparse warning ...
2009-01-07x86: offer frame pointers in all build modesIngo Molnar
CONFIG_FRAME_POINTERS=y results in much better debug info for the kernel (clear and precise backtraces), with the only drawback being a ~1% increase in kernel size. So offer it unconditionally and enable it by default. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-06Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rcu: fix rcutorture bug rcu: eliminate synchronize_rcu_xxx macro rcu: make treercu safe for suspend and resume rcu: fix rcutree grace-period-latency bug on small systems futex: catch certain assymetric (get|put)_futex_key calls futex: make futex_(get|put)_key() calls symmetric locking, percpu counters: introduce separate lock classes swiotlb: clean up EXPORT_SYMBOL usage swiotlb: remove unnecessary declaration swiotlb: replace architecture-specific swiotlb.h with linux/swiotlb.h swiotlb: add support for systems with highmem swiotlb: store phys address in io_tlb_orig_addr array swiotlb: add hwdev to swiotlb_phys_to_bus() / swiotlb_sg_to_bus()
2009-01-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (60 commits) uio: make uio_info's name and version const UIO: Documentation for UIO ioport info handling UIO: Pass information about ioports to userspace (V2) UIO: uio_pdrv_genirq: allow custom irq_flags UIO: use pci_ioremap_bar() in drivers/uio arm: struct device - replace bus_id with dev_name(), dev_set_name() libata: struct device - replace bus_id with dev_name(), dev_set_name() avr: struct device - replace bus_id with dev_name(), dev_set_name() block: struct device - replace bus_id with dev_name(), dev_set_name() chris: struct device - replace bus_id with dev_name(), dev_set_name() dmi: struct device - replace bus_id with dev_name(), dev_set_name() gadget: struct device - replace bus_id with dev_name(), dev_set_name() gpio: struct device - replace bus_id with dev_name(), dev_set_name() gpu: struct device - replace bus_id with dev_name(), dev_set_name() hwmon: struct device - replace bus_id with dev_name(), dev_set_name() i2o: struct device - replace bus_id with dev_name(), dev_set_name() IA64: struct device - replace bus_id with dev_name(), dev_set_name() i7300_idle: struct device - replace bus_id with dev_name(), dev_set_name() infiniband: struct device - replace bus_id with dev_name(), dev_set_name() ISDN: struct device - replace bus_id with dev_name(), dev_set_name() ...
2009-01-06percpu_counter: FBC_BATCH should be a variableEric Dumazet
For NR_CPUS >= 16 values, FBC_BATCH is 2*NR_CPUS Considering more and more distros are using high NR_CPUS values, it makes sense to use a more sensible value for FBC_BATCH, and get rid of NR_CPUS. A sensible value is 2*num_online_cpus(), with a minimum value of 32 (This minimum value helps branch prediction in __percpu_counter_add()) We already have a hotcpu notifier, so we can adjust FBC_BATCH dynamically. We rename FBC_BATCH to percpu_counter_batch since its not a constant anymore. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06strict_strto* is not strict enoughPavel Machek
It decodes "\n" as 0, which is bad, because stray echo into backlight will turn your backlight off, etc... Signed-off-by: Pavel Machek <pavel@suse.cz> Cc: Yi Yang <yi.y.yang@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06lib: proportions.c trivial sparse lock annotationHarvey Harrison
Suppresses sparse warning: lib/proportions.c:159:16: warning: context imbalance in 'prop_get_global': wrong count at exit lib/proportions.c:159:16: context 'RCU': wanted 0, got 1 lib/proportions.c:164:2: warning: context imbalance in 'prop_put_global': unexpected unlock lib/proportions.c:164:2: context 'RCU': wanted 0, got -1 Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06lib: radix_tree.c make percpu variable staticHarvey Harrison
radix_tree_preloads is unused outside of this file, make it static. Noticed by sparse: lib/radix-tree.c:84:1: warning: symbol 'per_cpu__radix_tree_preloads' was not declared. Should it be static? Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06lib: fix sparse shadowed variable warningHarvey Harrison
pos is always set before being used, no need to declare a second one inside the if() block. lib/prio_heap.c:34:7: warning: symbol 'pos' shadows an earlier one lib/prio_heap.c:30:6: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06Remove remaining unwinder codeAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Gabor Gombas <gombasg@sztaki.hu> Cc: Jan Beulich <jbeulich@novell.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@elte.hu>, Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06oops handling: ensure that any oops is flushed to the mtdoops consoleViktor Rosendahl
This used to work unpatched with older kernels, during the development phase of mtdoops. Before commit e3e8a75d2acfc61ebf25524666a0a2c6abb0620c a space was printed with console_loglevel set to 15, which probably flushed the oops message as a side effect. This is another patch from the Nokia N810 kernel. Signed-off-by: Viktor Rosendahl <viktor.rosendahl@nokia.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06swiotlb: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-06dynamic_printk: reduce one level of indentationWu Fengguang
Cleanup pr_debug_write() to reduce one level of indentation. Cc: Marcel Holtmann <marcel@holtmann.org> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-06kobject: return the result of uevent sending by netlinkMing Lei
We need to return the result of uevent sending by netlink to caller, when uevent_helper is disabled and CONFIG_NET is defined. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-06uevent: don't pass envp_ext[] as format string in kobject_uevent_env()Tejun Heo
kobject_uevent_env() uses envp_ext[] as verbatim format string which can cause problems ranging from unexpectedly mangled string to oops if a string in envp_ext[] contains substring which can be interpreted as format. Fix it. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-06driver core: Remove completion from struct klist_nodeMatthew Wilcox
Removing the completion from klist_node reduces its size from 64 bytes to 28 on x86-64. To maintain the semantics of klist_remove(), we add a single list of klist nodes which are pending deletion and scan them. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-06trivial: radix-tree: document wrap-around issue of radix_tree_next_hole()Wu Fengguang
And some 80-line cleanups. Signed-off-by: Wu Fengguang <wfg@linux.intel.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-06Merge branches 'core/futexes', 'core/locking', 'core/rcu' and 'linus' into ↵Ingo Molnar
core/urgent
2009-01-05Merge branch 'core/iommu' into core/urgentIngo Molnar
Conflicts: lib/swiotlb.c
2009-01-04swiotlb: Don't include linux/swiotlb.h twice in lib/swiotlb.cJesper Juhl
There's no point in including the linux/swiotlb.h header twice in lib/swiotlb.c - this patch gets rid of the unneeded include. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-04Merge branch 'linus' into core/urgentIngo Molnar
2009-01-03Merge branch 'cpus4096-for-linus-3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'cpus4096-for-linus-3' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (77 commits) x86: setup_per_cpu_areas() cleanup cpumask: fix compile error when CONFIG_NR_CPUS is not defined cpumask: use alloc_cpumask_var_node where appropriate cpumask: convert shared_cpu_map in acpi_processor* structs to cpumask_var_t x86: use cpumask_var_t in acpi/boot.c x86: cleanup some remaining usages of NR_CPUS where s/b nr_cpu_ids sched: put back some stack hog changes that were undone in kernel/sched.c x86: enable cpus display of kernel_max and offlined cpus ia64: cpumask fix for is_affinity_mask_valid() cpumask: convert RCU implementations, fix xtensa: define __fls mn10300: define __fls m32r: define __fls h8300: define __fls frv: define __fls cris: define __fls cpumask: CONFIG_DISABLE_OBSOLETE_CPUMASK_FUNCTIONS cpumask: zero extra bits in alloc_cpumask_var_node cpumask: replace for_each_cpu_mask_nr with for_each_cpu in kernel/time/ cpumask: convert mm/ ...
2009-01-03Make %p print '(null)' for NULL pointersLinus Torvalds
Before, when we only ever printed out the pointer value itself, a NULL pointer would never cause issues and might as well be printed out as just its numeric value. However, with the extended %p formats, especially %pR, we might validly want to print out resources for debugging. And sometimes they don't even exist, and the resource pointer is just NULL. Print it out as such, rather than oopsing. This is a more generic version of a patch done by Trent Piepho (catching all %p cases rather than just %pR, and using "(null)" instead of "[NULL]" to match glibc). Requested-by: Trent Piepho <xyzzy@speakeasy.org> Acked-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02swiotlb: add missing __init annotationsRoland Dreier
Impact: cleanup, reduce kernel size a bit The current kernel build warns: WARNING: vmlinux.o(.text+0x11458): Section mismatch in reference from the function swiotlb_alloc_boot() to the function .init.text:__alloc_bootmem_low() The function swiotlb_alloc_boot() references the function __init __alloc_bootmem_low(). This is often because swiotlb_alloc_boot lacks a __init annotation or the annotation of __alloc_bootmem_low is wrong. WARNING: vmlinux.o(.text+0x1011f2): Section mismatch in reference from the function swiotlb_late_init_with_default_size() to the function .init.text:__alloc_bootmem_low() The function swiotlb_late_init_with_default_size() references the function __init __alloc_bootmem_low(). This is often because swiotlb_late_init_with_default_size lacks a __init annotation or the annotation of __alloc_bootmem_low is wrong. and indeed the functions calling __alloc_bootmem_low() can be marked __init as well. Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-02Merge branch 'cpus4096-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'cpus4096-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (66 commits) x86: export vector_used_by_percpu_irq x86: use logical apicid in x2apic_cluster's x2apic_cpu_mask_to_apicid_and() sched: nominate preferred wakeup cpu, fix x86: fix lguest used_vectors breakage, -v2 x86: fix warning in arch/x86/kernel/io_apic.c sched: fix warning in kernel/sched.c sched: move test_sd_parent() to an SMP section of sched.h sched: add SD_BALANCE_NEWIDLE at MC and CPU level for sched_mc>0 sched: activate active load balancing in new idle cpus sched: bias task wakeups to preferred semi-idle packages sched: nominate preferred wakeup cpu sched: favour lower logical cpu number for sched_mc balance sched: framework for sched_mc/smt_power_savings=N sched: convert BALANCE_FOR_xx_POWER to inline functions x86: use possible_cpus=NUM to extend the possible cpus allowed x86: fix cpu_mask_to_apicid_and to include cpu_online_mask x86: update io_apic.c to the new cpumask code x86: Introduce topology_core_cpumask()/topology_thread_cpumask() x86: xen: use smp_call_function_many() x86: use work_on_cpu in x86/kernel/cpu/mcheck/mce_amd_64.c ... Fixed up trivial conflict in kernel/time/tick-sched.c manually
2009-01-01cpumask: CONFIG_DISABLE_OBSOLETE_CPUMASK_FUNCTIONSRusty Russell
Impact: new debug CONFIG options This helps find unconverted code. It currently breaks compile horribly, but we never wanted a flag day so that's expected. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-01-01cpumask: zero extra bits in alloc_cpumask_var_nodeRusty Russell
Impact: extra safety checks during transition When CONFIG_CPUMASKS_OFFSTACK is set, the new cpumask_ operators only use bits up to nr_cpu_ids, not NR_CPUS. Using the old cpus_ operators on these masks can mean accessing undefined bits. After some discussion, Mike and I decided to err on the side of caution; we zero the "undefined" bits in alloc_cpumask_var_node() until all the old cpumask functions are removed. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-01-01bitmap: find_last_bit()Rusty Russell
Impact: New API As the name suggests. For the moment everyone uses the generic one. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-01-01cpumask: fix bogus kernel-docLi Zefan
Impact: fix kernel-doc alloc_bootmem_cpumask_var() returns avoid. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-12-31Merge branch 'master' of ↵Rusty Russell
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: arch/x86/kernel/io_apic.c
2008-12-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6: slub: avoid leaking caches or refcounts on sysfs error slab: Fix comment on #endif slab: remove GFP_THISNODE clearing from alloc_slabmgmt() slub: Add might_sleep_if() to slab_alloc() SLUB: failslab support slub: Fix incorrect use of loose slab: Update the kmem_cache_create documentation regarding the name parameter slub: make early_kmem_cache_node_alloc void slab: unsigned slabp->inuse cannot be less than 0 slub - fix get_object_page comment SLUB: Replace __builtin_return_address(0) with _RET_IP_. SLUB: cleanup - define macros instead of hardcoded numbers
2008-12-30Merge branch 'core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (63 commits) stacktrace: provide save_stack_trace_tsk() weak alias rcu: provide RCU options on non-preempt architectures too printk: fix discarding message when recursion_bug futex: clean up futex_(un)lock_pi fault handling "Tree RCU": scalable classic RCU implementation futex: rename field in futex_q to clarify single waiter semantics x86/swiotlb: add default swiotlb_arch_range_needs_mapping x86/swiotlb: add default phys<->bus conversion x86: unify pci iommu setup and allow swiotlb to compile for 32 bit x86: add swiotlb allocation functions swiotlb: consolidate swiotlb info message printing swiotlb: support bouncing of HighMem pages swiotlb: factor out copy to/from device swiotlb: add arch hook to force mapping swiotlb: allow architectures to override phys<->bus<->phys conversions swiotlb: add comment where we handle the overflow of a dma mask on 32 bit rcu: fix rcutorture behavior during reboot resources: skip sanity check of busy resources swiotlb: move some definitions to header swiotlb: allow architectures to override swiotlb pool allocation ... Fix up trivial conflicts in arch/x86/kernel/Makefile arch/x86/mm/init_32.c include/linux/hardirq.h as per Ingo's suggestions.
2008-12-30Merge branch 'master' of ↵Rusty Russell
2008-12-29locking, percpu counters: introduce separate lock classesPeter Zijlstra
Impact: fix lockdep false positives Classify percpu_counter instances similar to regular lock objects -- that is, per instantiation site. The networking code has increased its use of percpu_counters, which leads to false positives if they are treated as a single class. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-29SLUB: failslab supportAkinobu Mita
Currently fault-injection capability for SLAB allocator is only available to SLAB. This patch makes it available to SLUB, too. [penberg@cs.helsinki.fi: unify slab and slub implementations] Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-12-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1429 commits) net: Allow dependancies of FDDI & Tokenring to be modular. igb: Fix build warning when DCA is disabled. net: Fix warning fallout from recent NAPI interface changes. gro: Fix potential use after free sfc: If AN is enabled, always read speed/duplex from the AN advertising bits sfc: When disabling the NIC, close the device rather than unregistering it sfc: SFT9001: Add cable diagnostics sfc: Add support for multiple PHY self-tests sfc: Merge top-level functions for self-tests sfc: Clean up PHY mode management in loopback self-test sfc: Fix unreliable link detection in some loopback modes sfc: Generate unique names for per-NIC workqueues 802.3ad: use standard ethhdr instead of ad_header 802.3ad: generalize out mac address initializer 802.3ad: initialize ports LACPDU from const initializer 802.3ad: remove typedef around ad_system 802.3ad: turn ports is_individual into a bool 802.3ad: turn ports is_enabled into a bool 802.3ad: make ntt bool ixgbe: Fix set_ringparam in ixgbe to use the same memory pools. ... Fixed trivial IPv4/6 address printing conflicts in fs/cifs/connect.c due to the conversion to %pI (in this networking merge) and the addition of doing IPv6 addresses (from the earlier merge of CIFS).
2008-12-28Merge branch 'x86-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (246 commits) x86: traps.c replace #if CONFIG_X86_32 with #ifdef CONFIG_X86_32 x86: PAT: fix address types in track_pfn_vma_new() x86: prioritize the FPU traps for the error code x86: PAT: pfnmap documentation update changes x86: PAT: move track untrack pfnmap stubs to asm-generic x86: PAT: remove follow_pfnmap_pte in favor of follow_phys x86: PAT: modify follow_phys to return phys_addr prot and return value x86: PAT: clarify is_linear_pfn_mapping() interface x86: ia32_signal: remove unnecessary declaration x86: common.c boot_cpu_stack and boot_exception_stacks should be static x86: fix intel x86_64 llc_shared_map/cpu_llc_id anomolies x86: fix warning in arch/x86/kernel/microcode_amd.c x86: ia32.h: remove unused struct sigfram32 and rt_sigframe32 x86: asm-offset_64: use rt_sigframe_ia32 x86: sigframe.h: include headers for dependency x86: traps.c declare functions before they get used x86: PAT: update documentation to cover pgprot and remap_pfn related changes - v3 x86: PAT: add pgprot_writecombine() interface for drivers - v3 x86: PAT: change pgprot_noncached to uc_minus instead of strong uc - v3 x86: PAT: implement track/untrack of pfnmap regions for x86 - v3 ...
