commit e4a683c899cd5a49f8d684a054c95bd115a0c005 upstream.
Add kref_test_and_get() function, which atomically add a reference only if
refcount is not zero. This prevent to add a reference to an object that is
already being removed.
Signed-off-by: Jerome Marchand <jmarchan@redhat.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
commit 2d75af2f2a7a6103a6d539a492fe81deacabde44 upstream.
On older gcc (3.3) dynamic debug fails to compile:
include/net/inet_connection_sock.h: In function `inet_csk_reset_xmit_timer':
include/net/inet_connection_sock.h:236: error: duplicate label declaration `do_printk'
include/net/inet_connection_sock.h:219: error: this is a previous declaration
include/net/inet_connection_sock.h:236: error: duplicate label declaration `out'
include/net/inet_connection_sock.h:236: error: duplicate label `do_printk'
include/net/inet_connection_sock.h:236: error: duplicate label `out'
Fix, by reverting the usage of JUMP_LABEL() in dynamic debug for now.
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Tested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Signed-off-by: Jason Baron <jbaron@redhat.com>
This reverts commit e0fdace10e75dac67d906213b780ff1b1a4cc360.
On-list discussion seems to suggest that the robustness fixes for printk
make this unnecessary and DaveM has also agreed in person at Kernel Summit
and on list.
The main problem with this code is once we hit a lockdep splat we always
keep oops_in_progress set, the console layer uses oops_in_progress with KMS
to decide when it should be showing the oops and not showing X, so it causes
problems around suspend/resume time when a userspace resume can cause a console
switch away from X, only if oops_in_progress is set (which is what we want
if an oops actually is in progress, but not because we had a lockdep splat
2 days prior).
Cc: David S Miller <davem@davemloft.net>
Salman Qazi describes the following radix-tree bug:
In the following case, we get can get a deadlock:
0. The radix tree contains two items, one has the index 0.
1. The reader (in this case find_get_pages) takes the rcu_read_lock.
2. The reader acquires slot(s) for item(s) including the index 0 item.
3. The non-zero index item is deleted, and as a consequence the other item is
moved to the root of the tree. The place where it used to be is queued for
deletion after the readers finish.
3b. The zero item is deleted, removing it from the direct slot, it remains in
the rcu-delayed indirect node.
4. The reader looks at the index 0 slot, and finds that the page has 0 ref
count
5. The reader looks at it again, hoping that the item will either be freed or
the ref count will increase. This never happens, as the slot it is looking
at will never be updated. Also, this slot can never be reclaimed because
the reader is holding rcu_read_lock and is in an infinite loop.
The fix is to re-use the same "indirect" pointer case that requires a slot
lookup retry into a general "retry the lookup" bit.
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
Reported-by: Salman Qazi <sqazi@google.com>
Cc: <stable@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (48 commits)
DMAENGINE: move COH901318 to arch_initcall
dma: imx-dma: fix signedness bug
dma/timberdale: simplify conditional
ste_dma40: remove channel_type
ste_dma40: remove enum for endianess
ste_dma40: remove TIM_FOR_LINK option
ste_dma40: move mode_opt to separate config
ste_dma40: move channel mode to a separate field
ste_dma40: move priority to separate field
ste_dma40: add variable to indicate valid dma_cfg
async_tx: make async_tx channel switching opt-in
move async raid6 test to lib/Kconfig.debug
dmaengine: Add Freescale i.MX1/21/27 DMA driver
intel_mid_dma: change the slave interface
intel_mid_dma: fix the WARN_ONs
intel_mid_dma: Add sg list support to DMA driver
intel_mid_dma: Allow DMAC2 to share interrupt
intel_mid_dma: Allow IRQ sharing
intel_mid_dma: Add runtime PM support
DMAENGINE: define a dummy filter function for ste_dma40
Add idr/ida to kernel-api docbook.
Fix typos and kernel-doc notation.
Acked-by: Tejun Heo <tj@kernel.org>
Cc: Naohiro Aota <naota@elisp.net>
Cc: Jiri Kosina <jkosina@suse.cz>
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile:
arch/tile: convert a BUG_ON to BUILD_BUG_ON
arch/tile: make ptrace() work properly for TILE-Gx COMPAT mode
arch/tile: support new info op generated by compiler
arch/tile: minor whitespace/naming changes for string support files
arch/tile: enable single-step support for TILE-Gx
arch/tile: parameterize system PLs to support KVM port
arch/tile: add Tilera's <arch/sim.h> header as an open-source header
arch/tile: Bomb C99 comments to C89 comments in tile's <arch/sim_def.h>
arch/tile: prevent corrupt top frame from causing backtracer runaway
arch/tile: various top-level Makefile cleanups
arch/tile: change lower bound on syscall error return to -4095
arch/tile: properly export __mb_incoherent for modules
arch/tile: provide a definition of MAP_STACK
kmemleak: add TILE to the list of supported architectures.
char: hvc: check for error case
arch/tile: Add a warning if we try to allocate too much vmalloc memory.
arch/tile: update some comments to clarify register usage.
arch/tile: use better "punctuation" for VMSPLIT_3_5G and friends
arch/tile: Use <asm-generic/syscalls.h>
tile: replace some BUG_ON checks with BUILD_BUG_ON checks
The current implementation of div64_u64 for 32bit systems returns an
approximately correct result when the divisor exceeds 32bits. Since doing
64bit division using 32bit hardware is a long since solved problem we just
use one of the existing proven methods.
Additionally, add a div64_s64 function to correctly handle doing signed
64bit division.
Addresses https://bugzilla.redhat.com/show_bug.cgi?id=616105
Signed-off-by: Brian Behlendorf <behlendorf1@llnl.gov>
Cc: Ben Woodard <bwoodard@llnl.gov>
Cc: Mark Grondona <mgrondona@llnl.gov>
Use new variable 'len' to make code more readable.
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
this_cpu_ptr() avoids an array lookup and can use the percpu offset of the
local cpu directly.
Signed-off-by: Christoph Lameter <cl@linux.com>
Cc: Tejun Heo <tj@kernel.org>
Improve 'lib_sort()' test and check that:
o 'cmp()' is called only for elements which were present in the original list,
i.e., the 'a' and 'b' parameters are valid
o the resulted (sorted) list consists onlly of the original elements
o intdoruce "poison" fields to make sure data around 'struc list_head' field
are not corrupted.
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Cc: Don Mullis <don.mullis@gmail.com>
This patch unifies 'list_sort_test()' messages a bit and makes sure all of
them start with the "list_sort_test:" prefix to make it obvious for users
where the messages come from.
The 'lib_sort()' test does not free memory if it fails, and it makes the
kernel panic if it cannot allocate memory. This patch fixes the problem.
This patch also changes several small things:
o use 'list_add()' helper instead of adding manually
o introduce temporary 'el1' variable to avoid ugly and unreadalbe
"if" statement
o make 'head' to be stack variable instead of 'kmalloc()'ed, which
simplifies code a bit
Overall, this patch is of clean-up type.
Instead of using own pseudo-random generator, use generic linux
'random32()' function. Presumably, this should improve test coverage.
At the same time, do the following changes:
o Use shorter macro name for test list length
o Do not use strange 'l_h' name for 'struct list_head' element,
use 'list', because it is traditional name and thus, makes the
code more obvious and readable.
I do not see any reason to use KERN_WARN for normal messages and
KERN_EMERG for error messages in the lib_sort testing routine. Let's use
more reasonable KERN_NORM and KERN_ERR levels.
While hunting a non-existing bug in 'list_sort()', I've improved the
'list_sort_test()' function which tests the 'list_sort()' library call.
Although at the end I found a bug in my code, but not in 'list_sort()', I
think my clean-ups and improvements are worth merging because they make
the test function better.
This patch:
Make the self-tests selectable via Kconfig rather than by manual enabling
of DEBUG_LIST_SORT.
All percpu counters are linked to a global list on initialization and
removed from it on destruction. The list is walked during CPU up/down.
If a percpu counter is freed without being properly destroyed, the system
will oops only on the next CPU up/down making it pretty nasty to track
down. This patch adds debugobj support for percpu counters so that such
problems can be found easily.
As percpu counters don't make sense on stack and can't be statically
initialized, debugobj support is pretty simple. It's initialized and
activated on counter initialization, and deactivatd and destroyed on
counter destruction. With this patch applied, the bug fixed by commit
602586a83b719df0fbd94196a1359ed35aeb2df3 (shmem: put_super must
percpu_counter_destroy) triggers the following warning on tmpfs unmount
and the system won't oops on the next cpu up/down operation.
WARNING: at lib/debugobjects.c:259 debug_print_object+0x5c/0x70()
Hardware name: Bochs
ODEBUG: free active (active state 0) object type: percpu_counter
Modules linked in:
Pid: 3999, comm: umount Not tainted 2.6.36-rc2-work+ #5
Call Trace:
[<ffffffff81083f7f>] warn_slowpath_common+0x7f/0xc0
[<ffffffff81084076>] warn_slowpath_fmt+0x46/0x50
[<ffffffff813b45cc>] debug_print_object+0x5c/0x70
[<ffffffff813b50e5>] debug_check_no_obj_freed+0x125/0x210
[<ffffffff811577d3>] kfree+0xb3/0x2f0
[<ffffffff81132edd>] shmem_put_super+0x1d/0x30
[<ffffffff81162e96>] generic_shutdown_super+0x56/0xe0
[<ffffffff81162f86>] kill_anon_super+0x16/0x60
[<ffffffff81162ff7>] kill_litter_super+0x27/0x30
[<ffffffff81163295>] deactivate_locked_super+0x45/0x60
[<ffffffff81163cfa>] deactivate_super+0x4a/0x70
[<ffffffff8117d446>] mntput_no_expire+0x86/0xe0
[<ffffffff8117df7f>] sys_umount+0x6f/0x360
[<ffffffff8103f01b>] system_call_fastpath+0x16/0x1b
---[ end trace cce2a341ba3611a7 ]---
Acked-by: Thomas Gleixner <tglxlinutronix.de>
Despite the idr_pre_get() kernel-doc, there are some cases where you can
call idr_pre_get() from within locked regions. Add a description for such
cases.
See also: http://lkml.org/lkml/2010/9/16/462
[akpm@linux-foundation.org: cleanups, grammatical fixes]
Signed-off-by: Naohiro Aota <naota@elisp.net>
Signed-off-by: Andy Shevchenko <andy.shevchenko@gmail.com>
scnprintf() should return 0 if @size is == 0. Update the comment for it,
as @size is unsigned.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
Cc: Joe Perches <joe@perches.com>
It might be nicer to align the output.
For instance, ACPI messages sometimes have "(null)" pointers.
$ dmesg | grep "(null)" -A 1 -B 1
[ 0.198733] ACPI: Dynamic OEM Table Load:
[ 0.198745] ACPI: SSDT (null) 00239 (v02 PmRef Cpu0Ist 00003000 INTL 20051117)
[ 0.199294] ACPI: SSDT 7f596e10 001C7 (v02 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.200708] ACPI: Dynamic OEM Table Load:
[ 0.200721] ACPI: SSDT (null) 001C7 (v02 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.201950] ACPI: SSDT 7f597f10 000D0 (v02 PmRef Cpu1Ist 00003000 INTL 20051117)
[ 0.203386] ACPI: Dynamic OEM Table Load:
[ 0.203398] ACPI: SSDT (null) 000D0 (v02 PmRef Cpu1Ist 00003000 INTL 20051117)
[ 0.203871] ACPI: SSDT 7f595f10 00083 (v02 PmRef Cpu1Cst 00003000 INTL 20051117)
[ 0.205301] ACPI: Dynamic OEM Table Load:
[ 0.205315] ACPI: SSDT (null) 00083 (v02 PmRef Cpu1Cst 00003000 INTL 20051117)
[akpm@linux-foundation.org: add code comment]
WARNING: at lib/list_debug.c:26 __list_add+0x3f/0x81()
Hardware name: Express5800/B120a [N8400-085]
list_add corruption. next->prev should be prev (ffffffff81a7ea00), but was dead000000200200. (next=ffff88080b872d58).
Modules linked in: aoe ipt_MASQUERADE iptable_nat nf_nat autofs4 sunrpc bridge 8021q garp stp llc ipv6 cpufreq_ondemand acpi_cpufreq freq_table dm_round_robin dm_multipath kvm_intel kvm uinput lpfc scsi_transport_fc igb ioatdma scsi_tgt i2c_i801 i2c_core dca iTCO_wdt iTCO_vendor_support pcspkr shpchp megaraid_sas [last unloaded: aoe]
Pid: 54, comm: events/3 Tainted: G W 2.6.34-vanilla1 #1
Call Trace:
[<ffffffff8104bd77>] warn_slowpath_common+0x7c/0x94
[<ffffffff8104bde6>] warn_slowpath_fmt+0x41/0x43
[<ffffffff8120fd2e>] __list_add+0x3f/0x81
[<ffffffff81212a12>] __percpu_counter_init+0x59/0x6b
[<ffffffff810d8499>] bdi_init+0x118/0x17e
[<ffffffff811f2c50>] blk_alloc_queue_node+0x79/0x143
[<ffffffff811f2d2b>] blk_alloc_queue+0x11/0x13
[<ffffffffa02a931d>] aoeblk_gdalloc+0x8e/0x1c9 [aoe]
[<ffffffffa02aa655>] aoecmd_sleepwork+0x25/0xa8 [aoe]
[<ffffffff8106186c>] worker_thread+0x1a9/0x237
[<ffffffffa02aa630>] ? aoecmd_sleepwork+0x0/0xa8 [aoe]
[<ffffffff81065827>] ? autoremove_wake_function+0x0/0x39
[<ffffffff810616c3>] ? worker_thread+0x0/0x237
[<ffffffff810653ad>] kthread+0x7f/0x87
[<ffffffff8100aa24>] kernel_thread_helper+0x4/0x10
[<ffffffff8106532e>] ? kthread+0x0/0x87
[<ffffffff8100aa20>] ? kernel_thread_helper+0x0/0x10
It's because there is no initialization code for a list_head contained in
the struct backing_dev_info under CONFIG_HOTPLUG_CPU, and the bug comes up
when block device drivers calling blk_alloc_queue() are used. In case of
me, I got them by using aoe.
Signed-off-by: Masanori Itoh <itoumsn@nttdata.co.jp>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
include/linux/percpu.h
mm/percpu.c
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (31 commits)
driver core: Display error codes when class suspend fails
Driver core: Add section count to memory_block struct
Driver core: Add mutex for adding/removing memory blocks
Driver core: Move find_memory_block routine
hpilo: Despecificate driver from iLO generation
driver core: Convert link_mem_sections to use find_memory_block_hinted.
driver core: Introduce find_memory_block_hinted which utilizes kset_find_obj_hinted.
kobject: Introduce kset_find_obj_hinted.
driver core: fix build for CONFIG_BLOCK not enabled
driver-core: base: change to new flag variable
sysfs: only access bin file vm_ops with the active lock
sysfs: Fail bin file mmap if vma close is implemented.
FW_LOADER: fix kconfig dependency warning on HOTPLUG
uio: Statically allocate uio_class and use class .dev_attrs.
uio: Support 2^MINOR_BITS minors
uio: Cleanup irq handling.
uio: Don't clear driver data
uio: Fix lack of locking in init_uio_class
SYSFS: Allow boot time switching between deprecated and modern sysfs layout
driver core: remove CONFIG_SYSFS_DEPRECATED_V2 but keep it for block devices
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
vfs: make no_llseek the default
vfs: don't use BKL in default_llseek
llseek: automatically add .llseek fop
libfs: use generic_file_llseek for simple_attr
mac80211: disallow seeks in minstrel debug code
lirc: make chardev nonseekable
viotape: use noop_llseek
raw: use explicit llseek file operations
ibmasmfs: use generic_file_llseek
spufs: use llseek in all file operations
arm/omap: use generic_file_llseek in iommu_debug
lkdtm: use generic_file_llseek in debugfs
net/wireless: use generic_file_llseek in debugfs
drm: use noop_llseek
* 'config' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
BKL: introduce CONFIG_BKL.
dabusb: remove the BKL
sunrpc: remove the big kernel lock
init/main.c: remove BKL notations
blktrace: remove the big kernel lock
rtmutex-tester: make it build without BKL
dvb-core: kill the big kernel lock
dvb/bt8xx: kill the big kernel lock
tlclk: remove big kernel lock
fix rawctl compat ioctls breakage on amd64 and itanic
uml: kill big kernel lock
parisc: remove big kernel lock
cris: autoconvert trivial BKL users
alpha: kill big kernel lock
isapnp: BKL removal
s390/block: kill the big kernel lock
hpet: kill BKL, add compat_ioctl
One call chain getting to kset_find_obj is:
link_mem_sections()
find_mem_section()
kset_find_obj()
This is done during boot. The memory sections were added in a linearly
increasing order and link_mem_sections tends to utilize them in that
same linear order.
Introduce a kset_find_obj_hinted which is passed the result of the
previous kset_find_obj which it uses for a quick "is the next object
our desired object" check before falling back to the old behavior.
Signed-off-by: Robin Holt <holt@sgi.com>
To: Robert P. J. Day <rpjday@crashcourse.ca>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Having the ddebug_query= boot parameter it makes sense to set up
dynamic debug as soon as possible.
I expect sysfs files cannot be set up via an arch_initcall, because
this one is even before fs_initcall. Therefore I splitted the
dynamic_debug_init function into an early one and a later one providing
/sys/../dynamic_debug/control file.
Possibly dynamic_debug can be initialized even earlier, not sure whether
this still makes sense then. I picked up arch_initcall as it covers
quite a lot already.
Dynamic debug needs to allocate memory, therefore it's not easily possible to
set it up even before the command line gets parsed.
Therefore the boot param query string is stored in a temp string which is
applied when dynamic debug gets set up.
This has been tested with ddebug_query="file ec.c +p"
and I could retrieve pr_debug() messages early at boot during ACPI setup:
ACPI: EC: Look up EC in DSDT
ACPI: EC: ---> status = 0x08
ACPI: EC: transaction start
ACPI: EC: <--- command = 0x80
ACPI: EC: ~~~> interrupt
ACPI: EC: <--- data = 0xa4
ACPI: Interpreter enabled
ACPI: (supports S0 S3 S4 S5)
ACPI: Using IOAPIC for interrupt routing
ACPI: EC: ---> status = 0x00
Signed-off-by: Thomas Renninger <trenn@suse.de>
Acked-by: jbaron@redhat.com
Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
CC: linux-acpi@vger.kernel.org
Dynamic debug lacks the ability to enable debug messages at boot time.
One could patch initramfs or service startup scripts to write to
/sys/../dynamic_debug/control, but this sucks.
This patch makes it possible to pass a query in the same format one can
write to /sys/../dynamic_debug/control via boot param.
When dynamic debug gets initialized, this query will automatically be
applied.
The parsing and applying of dynamic debug strings is not only useful for
/sys/../dynamic_debug/control write access, but can also be used for
boot parameter parsing.
The boot parameter is introduced in a follow up patch.
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/swiotlb-2.6
* 'stable/swiotlb-0.9' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/swiotlb-2.6:
swiotlb: Use page alignment for early buffer allocation
swiotlb: make io_tlb_overflow static
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (163 commits)
tracing: Fix compile issue for trace_sched_wakeup.c
[S390] hardirq: remove pointless header file includes
[IA64] Move local_softirq_pending() definition
perf, powerpc: Fix power_pmu_event_init to not use event->ctx
ftrace: Remove recursion between recordmcount and scripts/mod/empty
jump_label: Add COND_STMT(), reducer wrappery
perf: Optimize sw events
perf: Use jump_labels to optimize the scheduler hooks
jump_label: Add atomic_t interface
jump_label: Use more consistent naming
perf, hw_breakpoint: Fix crash in hw_breakpoint creation
perf: Find task before event alloc
perf: Fix task refcount bugs
perf: Fix group moving
irq_work: Add generic hardirq context callbacks
perf_events: Fix transaction recovery in group_sched_in()
perf_events: Fix bogus AMD64 generic TLB events
perf_events: Fix bogus context time tracking
tracing: Remove parent recording in latency tracer graph options
tracing: Use one prologue for the preempt irqs off tracer function tracers
With all the patches we have queued in the BKL removal tree, only a
few dozen modules are left that actually rely on the BKL, and even
there are lots of low-hanging fruit. We need to decide what to do
about them, this patch illustrates one of the options:
Every user of the BKL is marked as 'depends on BKL' in Kconfig,
and the CONFIG_BKL becomes a user-visible option. If it gets
disabled, no BKL using module can be built any more and the BKL
code itself is compiled out.
The one exception is file locking, which is practically always
enabled and does a 'select BKL' instead. This effectively forces
CONFIG_BKL to be enabled until we have solved the fs/lockd
mess and can apply the patch that removes the BKL from fs/locks.c.
Now that there's still only a few users around, rename things to make
them more consistent.
LKML-Reference: <20101014203625.448565169@chello.nl>
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
All the necessary functionality was already there; we just need
to make it possible to select the config option.
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
We could call free_bootmem_late() if swiotlb is not used, and
it will shrink to page alignment.
So alloc them with page alignment at first, to avoid lose two pages
before patch:
[ 0.000000] memblock_x86_reserve_range: [00d3600000, 00d7600000] swiotlb buffer
[ 0.000000] memblock_x86_reserve_range: [00d7e7ef40, 00d7e9ef40] swiotlb list
[ 0.000000] memblock_x86_reserve_range: [00d7e3ef40, 00d7e7ef40] swiotlb orig_ad
[ 0.000000] memblock_x86_reserve_range: [000008a000, 0000092000] swiotlb overflo
after patch will get
[ 0.000000] memblock_x86_reserve_range: [00d7e7e000, 00d7e9e000] swiotlb list
[ 0.000000] memblock_x86_reserve_range: [00d7e3e000, 00d7e7e000] swiotlb orig_ad
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: Becky Bruce <beckyb@kernel.crashing.org>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
We don't need to export io_tlb_overflow_buffer. I'll remove
io_tlb_overflow_buffer completely in the long term though.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
arch/x86/kernel/module.c
Merge reason: Resolve the conflict, pick up fixes.
The prompt for "Self test for hardware accelerated raid6 recovery" does not
belong in the top level configuration menu. All the options in
crypto/async_tx/Kconfig are selected and do not depend on CRYPTO.
Kconfig.debug seems like a reasonable fit.
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: David Woodhouse <David.Woodhouse@intel.com>
Merge reason: Update from -rc3 to -rc7.
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-2.6-rcu into core/rcu
Currently disabling CONFIG_SLUB_DEBUG also disabled SYSFS support meaning
that the slabs cannot be tuned without DEBUG.
Make SYSFS support independent of CONFIG_SLUB_DEBUG
Signed-off-by: Pekka Enberg <penberg@kernel.org>
With all the recent module loading cleanups, we've minimized the code
that sits under module_mutex, fixing various deadlocks and making it
possible to do most of the module loading in parallel.
However, that whole conversion totally missed the rather obscure code
that adds a new module to the list for BUG() handling. That code was
doubly obscure because (a) the code itself lives in lib/bugs.c (for
dubious reasons) and (b) it gets called from the architecture-specific
"module_finalize()" rather than from generic code.
Calling it from arch-specific code makes no sense what-so-ever to begin
with, and is now actively wrong since that code isn't protected by the
module loading lock any more.
So this commit moves the "module_bug_{finalize,cleanup}()" calls away
from the arch-specific code, and into the generic code - and in the
process protects it with the module_mutex so that the list operations
are now safe.
Future fixups:
- move the module list handling code into kernel/module.c where it
belongs.
- get rid of 'module_bug_list' and just use the regular list of modules
(called 'modules' - imagine that) that we already create and maintain
for other reasons.
Reported-and-tested-by: Thomas Gleixner <tglx@linutronix.de>
Cc: Adrian Bunk <bunk@kernel.org>
Cc: stable@kernel.org
If the original list is a POT in length, the first callback from line 73
will pass a==b both pointing to the original list_head. This is dangerous
because the 'list_sort()' user can use 'container_of()' and accesses the
"containing" object, which does not necessary exist for the list head. So
the user can access RAM which does not belong to him. If this is a write
access, we can end up with memory corruption.
Signed-off-by: Don Mullis <don.mullis@gmail.com>
Tested-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
The PROVE_RCU_REPEATEDLY has no "Say Y"/"Say N" advice, so this commit
adds it.
Reported-by: Johannes Berg <johannes@sipsolutions.net>
Convert the 'dynamic debug' infrastructure to use jump labels.
LKML-Reference: <b77627358cea3e27d7be4386f45f66219afb8452.1284733808.git.jbaron@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/core
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
block: Range check cpu in blk_cpu_to_group
scatterlist: prevent invalid free when alloc fails
writeback: Fix lost wake-up shutting down writeback thread
writeback: do not lose wakeup events when forking bdi threads
cciss: fix reporting of max queue depth since init
block: switch s390 tape_block and mg_disk to elevator_change()
block: add function call to switch the IO scheduler from a driver
fs/bio-integrity.c: return -ENOMEM on kmalloc failure
bio-integrity.c: remove dependency on __GFP_NOFAIL
BLOCK: fix bio.bi_rw handling
block: put dev->kobj in blk_register_queue fail path
cciss: handle allocation failure
cfq-iosched: Documentation help for new tunables
cfq-iosched: blktrace print per slice sector stats
cfq-iosched: Implement tunable group_idle
cfq-iosched: Do group share accounting in IOPS when slice_idle=0
cfq-iosched: Do not idle if slice_idle=0
cciss: disable doorbell reset on reset_devices
blkio: Fix return code for mkdir calls
