path: root/lib
2007-10-23Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: [MTD] [NOR] Fix deadlock in Intel chip driver caused by get_chip recursion [JFFS2] Fix return value from jffs2_write_end() [MTD] [OneNAND] Fix wrong free the static address in onenand_sim [MTD] [NAND] Replace -1 with -EBADMSG in nand error correction code [RSLIB] BUG() when passing illegal parameters to decode_rs8() or decode_rs16() [MTD] [NAND] treat any negative return value from correct() as an error [MTD] [NAND] nandsim: bugfix in initialization [MTD] Fix typo in Alauda config option help text. [MTD] [NAND] add s3c2440-specific read_buf/write_buf [MTD] [OneNAND] onenand-sim: fix kernel-doc and typos [JFFS2] Tidy up fix for ACL/permissions problem.
2007-10-22Add CONFIG_DEBUG_SG sg validationJens Axboe
Add a Kconfig entry which will toggle some sanity checks on the sg entry and tables. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-22Update swiotlb to use sg helpersJens Axboe
2007-10-20[MTD] [NAND] Replace -1 with -EBADMSG in nand error correction codeJörn Engel
Magic numerical values are just bad style. Particularly so when undocumented. Signed-off-by: Jörn Engel <joern@logfs.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-10-20[RSLIB] BUG() when passing illegal parameters to decode_rs8() or decode_rs16()Jörn Engel
Returning -ERANGE should never happen. Signed-off-by: Jörn Engel <joern@logfs.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-10-20spelling fixes: lib/Simon Arlott
Spelling fix in lib/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20LIB: Replace inappropriate include of <linux/bug.h>Robert P. J. Day
Replace an irrelevant include of bug.h with the more appropriate includes of slab.h and module.h. it's not as if the original inclusion is an error, it's simply not related to the contents of that source file, while the other two are. compile-tested on i386. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Fix misspellings of "system", "controller", "interrupt" and "necessary".Robert P. J. Day
Fix the various misspellings of "system", controller", "interrupt" and "[un]necessary". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19markers: Add samples subdirMathieu Desnoyers
Begin infrastructure for kernel code samples in the samples/ directory. Add its Kconfig and Kbuild files. Source its Kconfig file in all arch/ Kconfigs. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Add irq protection in the percpu-counters cpu-hotplug-callback pathGautham R Shenoy
Some of the per-cpu counters and thus their locks are accessed from IRQ contexts. This can cause a deadlock if it interrupts a cpu-offline thread which is transferring a dead-cpu's counts to the global counter. Add appropriate IRQ protection in the cpu-hotplug callback path. Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Use helpers to obtain task pid in printksPavel Emelyanov
The task_struct->pid member is going to be deprecated, so start using the helpers (task_pid_nr/task_pid_vnr/task_pid_nr_ns) in the kernel. The first thing to start with is the pid, printed to dmesg - in this case we may safely use task_pid_nr(). Besides, printks produce more (much more) than a half of all the explicit pid usage. [akpm@linux-foundation.org: git-drm went and changed lots of stuff] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19remove asm/bitops.h includesJiri Slaby
remove asm/bitops.h includes including asm/bitops directly may cause compile errors. don't include it and include linux/bitops instead. next patch will deny including asm header directly. Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Fix cpusets update_cpumaskPaul Menage
Cause writes to cpuset "cpus" file to update cpus_allowed for member tasks: - collect batches of tasks under tasklist_lock and then call set_cpus_allowed() on them outside the lock (since this can sleep). - add a simple generic priority heap type to allow efficient collection of batches of tasks to be processed without duplicating or missing any tasks in subsequent batches. - make "cpus" file update a no-op if the mask hasn't changed - fix race between update_cpumask() and sched_setaffinity() by making sched_setaffinity() post-check that it's not running on any cpus outside cpuset_cpus_allowed(). [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Paul Menage <menage@google.com> Cc: Paul Jackson <pj@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18Replace __attribute_pure__ with __pureRalf Baechle
To be consistent with the use of attributes in the rest of the kernel replace all use of __attribute_pure__ with __pure and delete the definition of __attribute_pure__. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Russell King <rmk@arm.linux.org.uk> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Merge branch 'for-linus' of git://git.kernel.dk/data/git/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/data/git/linux-2.6-block: [SCSI] Remove full sg table memset() [SCSI] ide-scsi: remove usage of sg_last() Fix loop terminating conditions in fill_sg(). [BLOCK] Clear sg entry before filling in blk_rq_map_sg() IA64: iommu uses sg_next with an invalid sg element cciss: disable DMA refetch on Smart Array P600 swiotlb: fix map_sg failure handling SPARC64: fix iommu sg chaining [SCSI] ide-scsi: use scsi_sg_count() instead of ->use_sg
2007-10-17lib/iomap.c:bad_io_access(): print 0x hex prefixRene Herman
Be explicit about printing hex. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17avoid negative (and full-width) shifts in radix-tree.cPeter Lund
Negative shifts are not allowed in C (the result is undefined). Same thing with full-width shifts. It works on most platforms but not on the VAX with gcc 4.0.1 (it results in an "operand reserved" fault). Shifting by more than the width of the value on the left is also not allowed. I think the extra '>> 1' tacked on at the end in the original code was an attempt to work around that. Getting rid of that is an extra feature of this patch. Here's the chapter and verse, taken from the final draft of the C99 standard ("6.5.7 Bitwise shift operators", paragraph 3): "The integer promotions are performed on each of the operands. The type of the result is that of the promoted left operand. If the value of the right operand is negative or is greater than or equal to the width of the promoted left operand, the behavior is undefined." Thank you to Jan-Benedict Glaw, Christoph Hellwig, Maciej Rozycki, Pekka Enberg, Andreas Schwab, and Christoph Lameter for review. Special thanks to Andreas for spotting that my fix only removed half the undefined behaviour. Signed-off-by: Peter Lund <firefly@vax64.dk> Christoph Lameter <clameter@sgi.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: "Maciej W. Rozycki" <macro@linux-mips.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Andreas Schwab <schwab@suse.de> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: WU Fengguang <wfg@mail.ustc.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17handle recursive calls to bust_spinlocks()Jan Beulich
Various architectures may call bust_spinlocks() recursively; the function itself, however, doesn't appear to be meant to be called in this manner. Nevertheless, this doesn't appear to be a problem as long as bust_spinlocks(0) doesn't get called twice in a row (otherwise, unblank_screen() may enter the scheduler). However, at least on i386 die() has been capable of returning (and on other architectures this should really be that way, too) when notify_die() returns NOTIFY_STOP. Short of getting a reply to a respective query, this patch makes bust_spinlocks() increment/decrement oops_in_progress, and wake klogd only when the count drops back to zero. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17lib/sort.c optimizationSubbaiah Venkata
Hello, I fixed and tested a small bug in lib/sort.c file, heap sort function. The fix avoids unnecessary swap of contents when i is 0 (saves few loads and stores), which happens every time sort function is called. I felt the fix is worth bringing it to your attention given the importance and frequent use of the sort function. Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17lib/ioremap.c should #include <linux/io.h>Adrian Bunk
Every file should include the headers containing the prototypes for its global functions (in this case ioremap_page_range()). Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17argv_split: allow argv_split to handle NULL pointer in argcp parameter ↵Neil Horman
gracefully It would be nice if the argv_split library function could gracefully handle a NULL pointer in the argcp parameter, so as to allow functions using it that did not care about the value of argc to not have to declare a useless variable. This patch accomplishes that. Tested by me, with successful results. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Satyam Sharma <satyam@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Slab API: remove useless ctor parameter and reorder parametersChristoph Lameter
Slab constructors currently have a flags parameter that is never used. And the order of the arguments is opposite to other slab functions. The object pointer is placed before the kmem_cache pointer. Convert ctor(void *object, struct kmem_cache *s, unsigned long flags) to ctor(struct kmem_cache *s, void *object) throughout the kernel [akpm@linux-foundation.org: coupla fixes] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17lib: floating proportionsPeter Zijlstra
Given a set of objects, floating proportions aims to efficiently give the proportional 'activity' of a single item as compared to the whole set. Where 'activity' is a measure of a temporal property of the items. It is efficient in that it need not inspect any other items of the set in order to provide the answer. It is not even needed to know how many other items there are. It has one parameter, and that is the period of 'time' over which the 'activity' is measured. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17lib: percpu_counter_init_irqPeter Zijlstra
provide a way to tell lockdep about percpu_counters that are supposed to be used from irq safe contexts. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17lib: percpu_counter_init error handlingPeter Zijlstra
alloc_percpu can fail, propagate that error. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17lib: percpu_count_sum()Peter Zijlstra
Provide an accurate version of percpu_counter_read. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17lib: percpu_counter_sum_positivePeter Zijlstra
s/percpu_counter_sum/&_positive/ Because its consitent with percpu_counter_read* Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17lib: percpu_counter_setPeter Zijlstra
Provide a method to set a percpu counter to a specified value. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17lib: make percpu_counter_add take s64Peter Zijlstra
percpu_counter is a s64 counter, make _add consitent. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17lib: percpu_counter variable batchPeter Zijlstra
Because the current batch setup has an quadric error bound on the counter, allow for an alternative setup. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17lib: percpu_counter_addPeter Zijlstra
s/percpu_counter_mod/percpu_counter_add/ Because its a better name, _mod implies modulo. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17swiotlb: fix map_sg failure handlingFUJITA Tomonori
sg list elements might not be continuous. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-16Merge branch 'for-linus' of git://git.kernel.dk/data/git/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/data/git/linux-2.6-block: (63 commits) Fix memory leak in dm-crypt SPARC64: sg chaining support SPARC: sg chaining support PPC: sg chaining support PS3: sg chaining support IA64: sg chaining support x86-64: enable sg chaining x86-64: update pci-gart iommu to sg helpers x86-64: update nommu to sg helpers x86-64: update calgary iommu to sg helpers swiotlb: sg chaining support i386: enable sg chaining i386 dma_map_sg: convert to using sg helpers mmc: need to zero sglist on init Panic in blk_rq_map_sg() from CCISS driver remove sglist_len remove blk_queue_max_phys_segments in libata revert sg segment size ifdefs Fixup u14-34f ENABLE_SG_CHAINING qla1280: enable use_sg_chaining option ...
2007-10-16Group short-lived and reclaimable kernel allocationsMel Gorman
This patch marks a number of allocations that are either short-lived such as network buffers or are reclaimable such as inode allocations. When something like updatedb is called, long-lived and unmovable kernel allocations tend to be spread throughout the address space which increases fragmentation. This patch groups these allocations together as much as possible by adding a new MIGRATE_TYPE. The MIGRATE_RECLAIMABLE type is for allocations that can be reclaimed on demand, but not moved. i.e. they can be migrated by deleting them and re-reading the information from elsewhere. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fix the max path calculation in radix-tree.cJeff Moyer
A while back, Nick Piggin introduced a patch to reduce the node memory usage for small files (commit cfd9b7df4abd3257c9e381b0e445817b26a51c0c): -#define RADIX_TREE_MAP_SHIFT 6 +#define RADIX_TREE_MAP_SHIFT (CONFIG_BASE_SMALL ? 4 : 6) Unfortunately, he didn't take into account the fact that the calculation of the maximum path was based on an assumption of having to round up: #define RADIX_TREE_MAX_PATH (RADIX_TREE_INDEX_BITS/RADIX_TREE_MAP_SHIFT + 2) So, if CONFIG_BASE_SMALL is set, you will end up with a RADIX_TREE_MAX_PATH that is one greater than necessary. The practical upshot of this is just a bit of wasted memory (one long in the height_to_maxindex array, an extra pre-allocated radix tree node per cpu, and extra stack usage in a couple of functions), but it seems worth getting right. It's also worth noting that I never build with CONFIG_BASE_SMALL. What I did to test this was duplicate the code in a small user-space program and check the results of the calculations for max path and the contents of the height_to_maxindex array. Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Acked-by: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16radix-tree: use indirect bitNick Piggin
Rather than sign direct radix-tree pointers with a special bit, sign the indirect one that hangs off the root. This means that, given a lookup_slot operation, the invalid result will be differentiated from the valid (previously, valid results could have the bit either set or clear). This does not affect slot lookups which occur under lock -- they can never return an invalid result. Is needed in future for lockless pagecache. Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16radixtree: introduce radix_tree_next_hole()Fengguang Wu
Introduce radix_tree_next_hole(root, index, max_scan) to scan radix tree for the first hole. It will be used in interleaved readahead. The implementation is dumb and obviously correct. It can help debug(and document) the possible smart one in future. Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16slow down printk during bootRandy Dunlap
Optionally add a boot delay after each kernel printk() call, crudely measured in milliseconds, with a maximum delay of 10 seconds per printk. Enable CONFIG_BOOT_PRINTK_DELAY=y and then add (e.g.): "lpj=loops_per_jiffy boot_delay=100" to the kernel command line. It has been useful in cases like "during boot, my machine just reboots or the screen goes black" by slowing down printk, (and adding initcall_debug), we can usually see the last thing that happened before the lights went out which is usually a valuable clue. [akpm@linux-foundation.org: not all architectures implement CONFIG_HZ] [akpm@linux-foundation.org: fix lots of stuff] [bunk@stusta.de: kernel/printk.c: make 2 variables static] [heiko.carstens@de.ibm.com: fix slow down printk on boot compile error] Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16swiotlb: sg chaining supportJens Axboe
2007-10-14more low-hanging fruits - kernel, fs, lib signednessAl Viro
2007-10-12Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: (37 commits) PCI: merge almost all of pci_32.h and pci_64.h together PCI: X86: Introduce and enable PCI domain support PCI: Add 'nodomains' boot option, and pci_domains_supported global PCI: modify PCI bridge control ISA flag for clarity PCI: use _CRS for PCI resource allocation PCI: avoid P2P prefetch window for expansion ROMs PCI: skip ISA ioresource alignment on some systems PCI: remove transparent bridge sizing pci: write file size to inode on proc bus file write pci: use size stored in proc_dir_entry for proc bus files pci: implement "pci=noaer" PCI: fix IDE legacy mode resources MSI: Use correct data offset for 32-bit MSI in read_msi_msg() PCI: Fix incorrect argument order to list_add_tail() in PCI dynamic ID code PCI: i386: Compaq EVO N800c needs PCI bus renumbering PCI: Remove no longer correct documentation regarding MSI vector assignment PCI: re-enable onboard sound on "MSI K8T Neo2-FIR" PCI: quirk_vt82c586_acpi: Omit reading PCI revision ID PCI: quirk amd_8131_mmrbc: Omit reading pci revision ID cpqphp: Use PCI_CLASS_REVISION instead of PCI_REVISION_ID for read ...
2007-10-12dma_free_coherent() needs irqs enabled (sigh)David Brownell
On at least ARM (and I'm told MIPS too) dma_free_coherent() has a newish call context requirement: unlike its dma_alloc_coherent() sibling, it may not be called with IRQs disabled. (This was new behavior on ARM as of late 2005, caused by ARM SMP updates.) This little surprise can be annoyingly driver-visible. Since it looks like that restriction won't be removed, this patch changes the definition of the API to include that requirement. Also, to help catch nonportable drivers, it updates the x86 and swiotlb versions to include the relevant warnings. (I already observed that it trips on the bus_reset_tasklet of the new firewire_ohci driver.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: David Miller <davem@davemloft.net> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12kobject: update the copyrightsGreg Kroah-Hartman
I've been hacking on these files for a while now, might as well make it official... Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12driver core: remove subsystem_init()Greg Kroah-Hartman
There is only one user of it, and it is only a wrapper for kset_init(). Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: move sysfs file poll implementation to sysfs_open_direntTejun Heo
Sysfs file poll implementation is scattered over sysfs and kobject. Event numbering is done in sysfs_dirent but wait itself is done on kobject. This not only unecessarily bloats both kobject and sysfs_dirent but is also buggy - if a sysfs_dirent is removed while there still are pollers, the associaton betwen the kobject and sysfs_dirent breaks and kobject may be freed with the pollers still sleeping on it. This patch moves whole poll implementation into sysfs_open_dirent. Each time a sysfs_open_dirent is created, event number restarts from 1 and pollers sleep on sysfs_open_dirent. As event sequence number is meaningless without any open file and pollers should have open file and thus sysfs_open_dirent, this ephemeral event counting works and is a saner implementation. This patch fixes the dnagling sleepers bug and reduces the sizes of kobject and sysfs_dirent by one pointer. Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12Driver core: kerneldoc - kobject_uevent_env is not "usually KOBJ_MOVE"Kay Sievers
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12Driver core: exclude kobject_uevent.c for !CONFIG_HOTPLUGKay Sievers
Move uevent specific logic from the core into kobject_uevent.c, which does no longer require to link the unused string array if hotplug is not compiled in. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: Remove first pass at shadow directory supportEric W. Biederman
While shadow directories appear to be a good idea, the current scheme of controlling their creation and destruction outside of sysfs appears to be a locking and maintenance nightmare in the face of sysfs directories dynamically coming and going. Which can now occur for directories containing network devices when CONFIG_SYSFS_DEPRECATED is not set. This patch removes everything from the initial shadow directory support that allowed the shadow directory creation to be controlled at a higher level. So except for a few bits of sysfs_rename_dir everything from commit b592fcfe7f06c15ec11774b5be7ce0de3aa86e73 is now gone. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12kobject: remove the static array for the nameGreg Kroah-Hartman
Due to historical reasons, struct kobject contained a static array for the name, and a dynamic pointer in case the name got bigger than the array. That's just dumb, as people didn't always know which variable to reference, even with the accessor for the kobject name. This patch removes the static array, potentially saving a lot of memory as the majority of kobjects do not have a very long name. Thanks to Kay for the idea to do this. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12Driver core: remove subsys_get()Greg Kroah-Hartman
There are no more subsystems, it's a kset now so remove the function and the only two users, which are in the driver core. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
