path: root/lib
2014-12-03lib/genalloc.c: export devm_gen_pool_create() for modulesMichal Simek
Modules can use this function for creating pool. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Cc: Laura Abbott <lauraa@codeaurora.org> Cc: Olof Johansson <olof@lixom.net> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com> Cc: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-02mm: do not overwrite reserved pages counter at show_mem()Rafael Aquini
Minor fixlet to perform the reserved pages counter aggregation for each node, at show_mem() Signed-off-by: Rafael Aquini <aquini@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Johannes Weiner <jweiner@redhat.com> Acked-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-16reciprocal_div: objects with exported symbols should be obj-y rather than lib-yHannes Frederic Sowa
Otherwise the exported symbols might be discarded because of no users in vmlinux. Reported-by: Jim Davis <jim.epost@gmail.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-13lib: rhashtable - Remove weird non-ASCII characters from commentsHerbert Xu
My editor spewed garbage that looked like memory corruption on my screen. It turns out that a number of occurences of "fi" got turned into a ligature. This patch replaces these ligatures with the ASCII letters "fi". Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Cheers, Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-29Merge branch 'akpm' (incoming from Andrew Morton)Linus Torvalds
Merge misc fixes from Andrew Morton: "21 fixes" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (21 commits) mm/balloon_compaction: fix deflation when compaction is disabled sh: fix sh770x SCIF memory regions zram: avoid NULL pointer access in concurrent situation mm/slab_common: don't check for duplicate cache names ocfs2: fix d_splice_alias() return code checking mm: rmap: split out page_remove_file_rmap() mm: memcontrol: fix missed end-writeback page accounting mm: page-writeback: inline account_page_dirtied() into single caller lib/bitmap.c: fix undefined shift in __bitmap_shift_{left|right}() drivers/rtc/rtc-bq32k.c: fix register value memory-hotplug: clear pgdat which is allocated by bootmem in try_offline_node() drivers/rtc/rtc-s3c.c: fix initialization failure without rtc source clock kernel/kmod: fix use-after-free of the sub_info structure drivers/rtc/rtc-pm8xxx.c: rework to support pm8941 rtc mm, thp: fix collapsing of hugepages on madvise drivers: of: add return value to of_reserved_mem_device_init() mm: free compound page with correct order gcov: add ARM64 to GCOV_PROFILE_ALL fsnotify: next_i is freed during fsnotify_unmount_inodes. mm/compaction.c: avoid premature range skip in isolate_migratepages_range ...
2014-10-29lib/bitmap.c: fix undefined shift in __bitmap_shift_{left|right}()Jan Kara
If __bitmap_shift_left() or __bitmap_shift_right() are asked to shift by a multiple of BITS_PER_LONG, they will try to shift a long value by BITS_PER_LONG bits which is undefined. Change the functions to avoid the undefined shift. Coverity id: 1192175 Coverity id: 1192174 Signed-off-by: Jan Kara <jack@suse.cz> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-29Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block layer fixes from Jens Axboe: "A small collection of fixes for the current kernel. This contains: - Two error handling fixes from Jan Kara. One for null_blk on failure to add a device, and the other for the block/scsi_ioctl SCSI_IOCTL_SEND_COMMAND fixing up the error jump point. - A commit added in the merge window for the bio integrity bits unfortunately disabled merging for all requests if CONFIG_BLK_DEV_INTEGRITY wasn't set. Reverse the logic, so that integrity checking wont disallow merges when not enabled. - A fix from Ming Lei for merging and generating too many segments. This caused a BUG in virtio_blk. - Two error handling printk() fixups from Robert Elliott, improving the information given when we rate limit. - Error handling fixup on elevator_init() failure from Sudip Mukherjee. - A fix from Tony Battersby, fixing up a memory leak in the scatterlist handling with scsi-mq" * 'for-linus' of git://git.kernel.dk/linux-block: block: Fix merge logic when CONFIG_BLK_DEV_INTEGRITY is not defined lib/scatterlist: fix memory leak with scsi-mq block: fix wrong error return in elevator_init() scsi: Fix error handling in SCSI_IOCTL_SEND_COMMAND null_blk: Cleanup error recovery in null_add_dev() blk-merge: recaculate segment if it isn't less than max segments fs: clarify rate limit suppressed buffer I/O errors fs: merge I/O error prints into one line
2014-10-28lib/scatterlist: fix memory leak with scsi-mqTony Battersby
Fix a memory leak with scsi-mq triggered by commands with large data transfer length. Fixes: c53c6d6a68b1 ("scatterlist: allow chaining to preallocated chunks") Cc: <stable@vger.kernel.org> # 3.17.x Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-10-24Merge tag 'random_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random Pull /dev/random updates from Ted Ts'o: "This adds a memzero_explicit() call which is guaranteed not to be optimized away by GCC. This is important when we are wiping cryptographically sensitive material" * tag 'random_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random: crypto: memzero_explicit - make sure to clear out sensitive data random: add and use memzero_explicit() for clearing data
2014-10-23Merge branch 'x86-efi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 EFI updates from Peter Anvin: "This patchset falls under the "maintainers that grovel" clause in the v3.18-rc1 announcement. We had intended to push it late in the merge window since we got it into the -tip tree relatively late. Many of these are relatively simple things, but there are a couple of key bits, especially Ard's and Matt's patches" * 'x86-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits) rtc: Disable EFI rtc for x86 efi: rtc-efi: Export platform:rtc-efi as module alias efi: Delete the in_nmi() conditional runtime locking efi: Provide a non-blocking SetVariable() operation x86/efi: Adding efi_printks on memory allocationa and pci.reads x86/efi: Mark initialization code as such x86/efi: Update comment regarding required phys mapped EFI services x86/efi: Unexport add_efi_memmap variable x86/efi: Remove unused efi_call* macros efi: Resolve some shadow warnings arm64: efi: Format EFI memory type & attrs with efi_md_typeattr_format() ia64: efi: Format EFI memory type & attrs with efi_md_typeattr_format() x86: efi: Format EFI memory type & attrs with efi_md_typeattr_format() efi: Introduce efi_md_typeattr_format() efi: Add macro for EFI_MEMORY_UCE memory attribute x86/efi: Clear EFI_RUNTIME_SERVICES if failing to enter virtual mode arm64/efi: Do not enter virtual mode if booting with efi=noruntime or noefi arm64/efi: uefi_init error handling fix efi: Add kernel param efi=noruntime lib: Add a generic cmdline parse function parse_option_str ...
2014-10-18Merge tag 'fbdev-3.18' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux Pull fbdev updates from Tomi Valkeinen: - new 6x10 font - various small fixes and cleanups * tag 'fbdev-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux: (30 commits) fonts: Add 6x10 font videomode: provide dummy inline functions for !CONFIG_OF video/atmel_lcdfb: Introduce regulator support fbdev: sh_mobile_hdmi: Re-init regs before irq re-enable on resume framebuffer: fix screen corruption when copying framebuffer: fix border color arm, fbdev, omap2, LLVMLinux: Remove nested function from omapfb arm, fbdev, omap2, LLVMLinux: Remove nested function from omap2 dss video: fbdev: valkyriefb.c: use container_of to resolve fb_info_valkyrie from fb_info video: fbdev: pxafb.c: use container_of to resolve pxafb_info/layer from fb_info video: fbdev: cyber2000fb.c: use container_of to resolve cfb_info from fb_info video: fbdev: controlfb.c: use container_of to resolve fb_info_control from fb_info video: fbdev: sa1100fb.c: use container_of to resolve sa1100fb_info from fb_info video: fbdev: stifb.c: use container_of to resolve stifb_info from fb_info video: fbdev: sis: sis_main.c: Cleaning up missing null-terminate in conjunction with strncpy video: valkyriefb: Fix unused variable warning in set_valkyrie_clock() video: fbdev: use %*ph specifier to dump small buffers video: mx3fb: always enable BACKLIGHT_LCD_SUPPORT video: fbdev: au1200fb: delete double assignment video: fbdev: sis: delete double assignment ...
2014-10-18Merge tag 'md/3.18' of git://neil.brown.name/mdLinus Torvalds
Pull md updates from Neil Brown: - a few minor bug fixes - quite a lot of code tidy-up and simplification - remove PRINT_RAID_DEBUG ioctl. I'm fairly sure it is unused, and it isn't particularly useful. * tag 'md/3.18' of git://neil.brown.name/md: (21 commits) lib/raid6: Add log level to printks md: move EXPORT_SYMBOL to after function in md.c md: discard PRINT_RAID_DEBUG ioctl md: remove MD_BUG() md: clean up 'exit' labels in md_ioctl(). md: remove unnecessary test for MD_MAJOR in md_ioctl() md: don't allow "-sync" to be set for device in an active array. md: remove unwanted white space from md.c md: don't start resync thread directly from md thread. md: Just use RCU when checking for overlap between arrays. md: avoid potential long delay under pers_lock md: simplify export_array() md: discard find_rdev_nr in favour of find_rdev_nr_rcu md: use wait_event() to simplify md_super_wait() md: be more relaxed about stopping an array which isn't started. md/raid1: process_checks doesn't use its return value. md/raid5: fix init_stripe() inconsistencies md/raid10: another memory leak due to reshape. md: use set_bit/clear_bit instead of shift/mask for bi_flags changes. md/raid1: minor typos and reformatting. ...
2014-10-17random: add and use memzero_explicit() for clearing dataDaniel Borkmann
zatimend has reported that in his environment (3.16/gcc4.8.3/corei7) memset() calls which clear out sensitive data in extract_{buf,entropy, entropy_user}() in random driver are being optimized away by gcc. Add a helper memzero_explicit() (similarly as explicit_bzero() variants) that can be used in such cases where a variable with sensitive data is being cleared out in the end. Other use cases might also be in crypto code. [ I have put this into lib/string.c though, as it's always built-in and doesn't need any dependencies then. ] Fixes kernel bugzilla: 82041 Reported-by: zatimend@hotmail.co.uk Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Cc: stable@vger.kernel.org
2014-10-14crypto: LLVMLinux: Remove VLAIS usage from libcrc32c.cJan-Simon Möller
Replaced the use of a Variable Length Array In Struct (VLAIS) with a C99 compliant equivalent. This patch allocates the appropriate amount of memory using a char array using the SHASH_DESC_ON_STACK macro. The new code can be compiled with both gcc and clang. Signed-off-by: Jan-Simon Möller <dl9pf@gmx.de> Signed-off-by: Behan Webster <behanw@converseincode.com> Reviewed-by: Mark Charlebois <charlebm@gmail.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Cc: pageexec@freemail.hu Cc: "David S. Miller" <davem@davemloft.net>
2014-10-14lib/raid6: Add log level to printksAnton Blanchard
Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: NeilBrown <neilb@suse.de>
2014-10-14lib/vsprintf: add %*pE[achnops] format specifierAndy Shevchenko
This allows user to print a given buffer as an escaped string. The rules are applied according to an optional mix of flags provided by additional format letters. For example, if the given buffer is: 1b 62 20 5c 43 07 22 90 0d 5d The result strings would be: %*pE "\eb \C\a"\220\r]" %*pEhp "\x1bb \C\x07"\x90\x0d]" %*pEa "\e\142\040\\\103\a\042\220\r\135" Please, read Documentation/printk-formats.txt and lib/string_helpers.c kernel documentation to get further information. [akpm@linux-foundation.org: tidy up comment layout, per Joe] Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Suggested-by: Joe Perches <joe@perches.com> Cc: "John W . Linville" <linville@tuxdriver.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14lib / string_helpers: introduce string_escape_mem()Andy Shevchenko
This is almost the opposite function to string_unescape(). Nevertheless it handles \0 and could be used for any byte buffer. The documentation is supplied together with the function prototype. The test cases covers most of the scenarios and would be expanded later on. [akpm@linux-foundation.org: avoid 1k stack consumption] Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: "John W . Linville" <linville@tuxdriver.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Joe Perches <joe@perches.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14lib / string_helpers: refactoring the test suiteAndy Shevchenko
This patch prepares test suite for a following update. It introduces test_string_check_buf() helper which checks the result and dumps an error. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: "John W . Linville" <linville@tuxdriver.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14lib / string_helpers: move documentation to c-fileAndy Shevchenko
The introduced function string_escape_mem() is a kind of opposite to string_unescape. We have several users of such functionality each of them created custom implementation. The series contains clean up of test suite, adding new call, and switching few users to use it via %*pE specifier. Test suite covers all of existing and most of potential use cases. This patch (of 11): The documentation of API belongs to c-file. This patch moves it accordingly. There is no functional change. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: "John W . Linville" <linville@tuxdriver.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14lib: string: Make all calls to strnicmp into calls to strncasecmpRasmus Villemoes
The previous patch made strnicmp into a wrapper for strncasecmp. This patch makes all in-tree users of strnicmp call strncasecmp directly, while still making sure that the strnicmp symbol can be used by out-of-tree modules. It should be considered a temporary hack until all in-tree callers have been converted. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14lib/string.c: remove duplicated functionRasmus Villemoes
lib/string.c contains two functions, strnicmp and strncasecmp, which do roughly the same thing, namely compare two strings case-insensitively up to a given bound. They have slightly different implementations, but the only important difference is that strncasecmp doesn't handle len==0 appropriately; it effectively becomes strcasecmp in that case. strnicmp correctly says that two strings are always equal in their first 0 characters. strncasecmp is the POSIX name for this functionality. So rename the non-broken function to the standard name. To minimize the impact on the rest of the kernel (and since both are exported to modules), make strnicmp a wrapper for strncasecmp. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Grant Likely <grant.likely@linaro.org> Cc: Andi Kleen <ak@linux.intel.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: "H. Peter Anvin" <hpa@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14lib: rename TEST_MODULE to TEST_LKMValentin Rothberg
The "_MODULE" suffix is reserved for tristates compiled as loadable kernel modules (LKM). The "TEST_MODULE" feature thereby violates this convention. The feature is used to compile the lib/test_module.c kernel module. Sadly this convention is not made explicit, but the Kconfig code documents it. The following code (./scripts/kconfig/confdata.c) is used to generate the autoconf.h header file during the build process. When a feature is selected as a kernel module ('m'), it is suffixed with "_MODULE" to indicate it. switch (*value) { case 'n': break; case 'm': suffix = "_MODULE"; /* fall through */ This causes problems for static code analysis, which assumes a consistent use of the "_MODULE" suffix. This patch renames the feature and its reference in a Makefile to "TEST_LKM", which still expresses the test of a LKM. Signed-off-by: Valentin Rothberg <valentinrothberg@gmail.com> Cc: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14lib: remove prio_heapLai Jiangshan
The prio_heap code is unused since commit 889ed9ceaa97 ("cgroup: remove css_scan_tasks()"). It should be compiled out to shrink the binary kernel size which can be done via introducing CONFIG_PRIO_HEAD or by removing the code. We can simply recover the code from git when needed, so it would be better to remove it IMO. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Tejun Heo <tj@kernel.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Ingo Molnar <mingo@kernel.org> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Kees Cook <keescook@chromium.org> Cc: Francesco Fusco <ffusco@redhat.com> Cc: Greg Thelen <gthelen@google.com> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: George Spelvin <linux@horizon.com> Cc: Mark Salter <msalter@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14lib/textsearch.c: remove textsearch_put reference from commentsRaphael Silva
There is no textsearch_put(). Remove it from the comments to avoid misunderstanding. Textsearch prepare no longer needs textsearch_put(). Signed-off-by: Raphael Silva <rapphil@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14lib/dynamic_debug.c: use seq_open_private() instead of seq_open()Rob Jones
Using seq_open_private() removes boilerplate code from ddebug_proc_open(). The resultant code is shorter and easier to follow. This patch does not change any functionality. Signed-off-by: Rob Jones <rob.jones@codethink.co.uk> Acked-by: Jason Baron <jbaron@akamai.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-13Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler updates from Ingo Molnar: "The main changes in this cycle were: - Optimized support for Intel "Cluster-on-Die" (CoD) topologies (Dave Hansen) - Various sched/idle refinements for better idle handling (Nicolas Pitre, Daniel Lezcano, Chuansheng Liu, Vincent Guittot) - sched/numa updates and optimizations (Rik van Riel) - sysbench speedup (Vincent Guittot) - capacity calculation cleanups/refactoring (Vincent Guittot) - Various cleanups to thread group iteration (Oleg Nesterov) - Double-rq-lock removal optimization and various refactorings (Kirill Tkhai) - various sched/deadline fixes ... and lots of other changes" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (72 commits) sched/dl: Use dl_bw_of() under rcu_read_lock_sched() sched/fair: Delete resched_cpu() from idle_balance() sched, time: Fix build error with 64 bit cputime_t on 32 bit systems sched: Improve sysbench performance by fixing spurious active migration sched/x86: Fix up typo in topology detection x86, sched: Add new topology for multi-NUMA-node CPUs sched/rt: Use resched_curr() in task_tick_rt() sched: Use rq->rd in sched_setaffinity() under RCU read lock sched: cleanup: Rename 'out_unlock' to 'out_free_new_mask' sched: Use dl_bw_of() under RCU read lock sched/fair: Remove duplicate code from can_migrate_task() sched, mips, ia64: Remove __ARCH_WANT_UNLOCKED_CTXSW sched: print_rq(): Don't use tasklist_lock sched: normalize_rt_tasks(): Don't use _irqsave for tasklist_lock, use task_rq_lock() sched: Fix the task-group check in tg_has_rt_tasks() sched/fair: Leverage the idle state info when choosing the "idlest" cpu sched: Let the scheduler see CPU idle states sched/deadline: Fix inter- exclusive cpusets migrations sched/deadline: Clear dl_entity params when setscheduling to different class sched/numa: Kill the wrong/dead TASK_DEAD check in task_numa_fault() ...
2014-10-13Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core locking updates from Ingo Molnar: "The main updates in this cycle were: - mutex MCS refactoring finishing touches: improve comments, refactor and clean up code, reduce debug data structure footprint, etc. - qrwlock finishing touches: remove old code, self-test updates. - small rwsem optimization - various smaller fixes/cleanups" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: locking/lockdep: Revert qrwlock recusive stuff locking/rwsem: Avoid double checking before try acquiring write lock locking/rwsem: Move EXPORT_SYMBOL() lines to follow function definition locking/rwlock, x86: Delete unused asm/rwlock.h and rwlock.S locking/rwlock, x86: Clean up asm/spinlock*.h to remove old rwlock code locking/semaphore: Resolve some shadow warnings locking/selftest: Support queued rwlock locking/lockdep: Restrict the use of recursive read_lock() with qrwlock locking/spinlocks: Always evaluate the second argument of spin_lock_nested() locking/Documentation: Update locking/mutex-design.txt disadvantages locking/Documentation: Move locking related docs into Documentation/locking/ locking/mutexes: Use MUTEX_SPIN_ON_OWNER when appropriate locking/mutexes: Refactor optimistic spinning code locking/mcs: Remove obsolete comment locking/mutexes: Document quick lock release when unlocking locking/mutexes: Standardize arguments in lock/unlock slowpaths locking: Remove deprecated smp_mb__() barriers
2014-10-13Merge branch 'locking-arch-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull arch atomic cleanups from Ingo Molnar: "This is a series kept separate from the main locking tree, which cleans up and improves various details in the atomics type handling: - Remove the unused atomic_or_long() method - Consolidate and compress atomic ops implementations between architectures, to reduce linecount and to make it easier to add new ops. - Rewrite generic atomic support to only require cmpxchg() from an architecture - generate all other methods from that" * 'locking-arch-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits) locking,arch: Use ACCESS_ONCE() instead of cast to volatile in atomic_read() locking, mips: Fix atomics locking, sparc64: Fix atomics locking,arch: Rewrite generic atomic support locking,arch,xtensa: Fold atomic_ops locking,arch,sparc: Fold atomic_ops locking,arch,sh: Fold atomic_ops locking,arch,powerpc: Fold atomic_ops locking,arch,parisc: Fold atomic_ops locking,arch,mn10300: Fold atomic_ops locking,arch,mips: Fold atomic_ops locking,arch,metag: Fold atomic_ops locking,arch,m68k: Fold atomic_ops locking,arch,m32r: Fold atomic_ops locking,arch,ia64: Fold atomic_ops locking,arch,hexagon: Fold atomic_ops locking,arch,cris: Fold atomic_ops locking,arch,avr32: Fold atomic_ops locking,arch,arm64: Fold atomic_ops locking,arch,arm: Fold atomic_ops ...
2014-10-12Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris. Mostly ima, selinux, smack and key handling updates. * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (65 commits) integrity: do zero padding of the key id KEYS: output last portion of fingerprint in /proc/keys KEYS: strip 'id:' from ca_keyid KEYS: use swapped SKID for performing partial matching KEYS: Restore partial ID matching functionality for asymmetric keys X.509: If available, use the raw subjKeyId to form the key description KEYS: handle error code encoded in pointer selinux: normalize audit log formatting selinux: cleanup error reporting in selinux_nlmsg_perm() KEYS: Check hex2bin()'s return when generating an asymmetric key ID ima: detect violations for mmaped files ima: fix race condition on ima_rdwr_violation_check and process_measurement ima: added ima_policy_flag variable ima: return an error code from ima_add_boot_aggregate() ima: provide 'ima_appraise=log' kernel option ima: move keyring initialization to ima_init() PKCS#7: Handle PKCS#7 messages that contain no X.509 certs PKCS#7: Better handling of unsupported crypto KEYS: Overhaul key identification when searching for asymmetric keys KEYS: Implement binary asymmetric key ID handling ...
2014-10-10Merge branch 'for-3.18' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu Pull percpu updates from Tejun Heo: "A lot of activities on percpu front. Notable changes are... - percpu allocator now can take @gfp. If @gfp doesn't contain GFP_KERNEL, it tries to allocate from what's already available to the allocator and a work item tries to keep the reserve around certain level so that these atomic allocations usually succeed. This will replace the ad-hoc percpu memory pool used by blk-throttle and also be used by the planned blkcg support for writeback IOs. Please note that I noticed a bug in how @gfp is interpreted while preparing this pull request and applied the fix 6ae833c7fe0c ("percpu: fix how @gfp is interpreted by the percpu allocator") just now. - percpu_ref now uses longs for percpu and global counters instead of ints. It leads to more sparse packing of the percpu counters on 64bit machines but the overhead should be negligible and this allows using percpu_ref for refcnting pages and in-memory objects directly. - The switching between percpu and single counter modes of a percpu_ref is made independent of putting the base ref and a percpu_ref can now optionally be initialized in single or killed mode. This allows avoiding percpu shutdown latency for cases where the refcounted objects may be synchronously created and destroyed in rapid succession with only a fraction of them reaching fully operational status (SCSI probing does this when combined with blk-mq support). It's also planned to be used to implement forced single mode to detect underflow more timely for debugging. There's a separate branch percpu/for-3.18-consistent-ops which cleans up the duplicate percpu accessors. That branch causes a number of conflicts with s390 and other trees. I'll send a separate pull request w/ resolutions once other branches are merged" * 'for-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (33 commits) percpu: fix how @gfp is interpreted by the percpu allocator blk-mq, percpu_ref: start q->mq_usage_counter in atomic mode percpu_ref: make INIT_ATOMIC and switch_to_atomic() sticky percpu_ref: add PERCPU_REF_INIT_* flags percpu_ref: decouple switching to percpu mode and reinit percpu_ref: decouple switching to atomic mode and killing percpu_ref: add PCPU_REF_DEAD percpu_ref: rename things to prepare for decoupling percpu/atomic mode switch percpu_ref: replace pcpu_ prefix with percpu_ percpu_ref: minor code and comment updates percpu_ref: relocate percpu_ref_reinit() Revert "blk-mq, percpu_ref: implement a kludge for SCSI blk-mq stall during probe" Revert "percpu: free percpu allocation info for uniprocessor system" percpu-refcount: make percpu_ref based on longs instead of ints percpu-refcount: improve WARN messages percpu: fix locking regression in the failure path of pcpu_alloc() percpu-refcount: add @gfp to percpu_ref_init() proportions: add @gfp to init functions percpu_counter: add @gfp to percpu_counter_init() percpu_counter: make percpu_counters_lock irq-safe ...
2014-10-09lib/genalloc.c: add genpool range check functionLaura Abbott
After allocating an address from a particular genpool, there is no good way to verify if that address actually belongs to a genpool. Introduce addr_in_gen_pool which will return if an address plus size falls completely within the genpool range. Signed-off-by: Laura Abbott <lauraa@codeaurora.org> Acked-by: Will Deacon <will.deacon@arm.com> Reviewed-by: Olof Johansson <olof@lixom.net> Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: David Riley <davidriley@chromium.org> Cc: Ritesh Harjain <ritesh.harjani@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Thierry Reding <thierry.reding@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-09lib/genalloc.c: add power aligned algorithmLaura Abbott
One of the more common algorithms used for allocation is to align the start address of the allocation to the order of size requested. Add this as an algorithm option for genalloc. Signed-off-by: Laura Abbott <lauraa@codeaurora.org> Acked-by: Will Deacon <will.deacon@arm.com> Acked-by: Olof Johansson <olof@lixom.net> Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: David Riley <davidriley@chromium.org> Cc: Ritesh Harjain <ritesh.harjani@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Thierry Reding <thierry.reding@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-09fonts: Add 6x10 fontMaarten ter Huurne
This font is suitable for framebuffer consoles on devices with a 320x240 screen, to get a reasonable number of characters (53x24) that are still at a readable size. The font is derived from the existing 6x11 font, but gets 3 extra lines without sacrificing readability. Also I redesigned a some glyhps so they are more distinct and better fill the available space. Signed-off-by: Maarten ter Huurne <maarten@treewalker.org> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2014-10-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Most notable changes in here: 1) By far the biggest accomplishment, thanks to a large range of contributors, is the addition of multi-send for transmit. This is the result of discussions back in Chicago, and the hard work of several individuals. Now, when the ->ndo_start_xmit() method of a driver sees skb->xmit_more as true, it can choose to defer the doorbell telling the driver to start processing the new TX queue entires. skb->xmit_more means that the generic networking is guaranteed to call the driver immediately with another SKB to send. There is logic added to the qdisc layer to dequeue multiple packets at a time, and the handling mis-predicted offloads in software is now done with no locks held. Finally, pktgen is extended to have a "burst" parameter that can be used to test a multi-send implementation. Several drivers have xmit_more support: i40e, igb, ixgbe, mlx4, virtio_net Adding support is almost trivial, so export more drivers to support this optimization soon. I want to thank, in no particular or implied order, Jesper Dangaard Brouer, Eric Dumazet, Alexander Duyck, Tom Herbert, Jamal Hadi Salim, John Fastabend, Florian Westphal, Daniel Borkmann, David Tat, Hannes Frederic Sowa, and Rusty Russell. 2) PTP and timestamping support in bnx2x, from Michal Kalderon. 3) Allow adjusting the rx_copybreak threshold for a driver via ethtool, and add rx_copybreak support to enic driver. From Govindarajulu Varadarajan. 4) Significant enhancements to the generic PHY layer and the bcm7xxx driver in particular (EEE support, auto power down, etc.) from Florian Fainelli. 5) Allow raw buffers to be used for flow dissection, allowing drivers to determine the optimal "linear pull" size for devices that DMA into pools of pages. The objective is to get exactly the necessary amount of headers into the linear SKB area pre-pulled, but no more. The new interface drivers use is eth_get_headlen(). From WANG Cong, with driver conversions (several had their own by-hand duplicated implementations) by Alexander Duyck and Eric Dumazet. 6) Support checksumming more smoothly and efficiently for encapsulations, and add "foo over UDP" facility. From Tom Herbert. 7) Add Broadcom SF2 switch driver to DSA layer, from Florian Fainelli. 8) eBPF now can load programs via a system call and has an extensive testsuite. Alexei Starovoitov and Daniel Borkmann. 9) Major overhaul of the packet scheduler to use RCU in several major areas such as the classifiers and rate estimators. From John Fastabend. 10) Add driver for Intel FM10000 Ethernet Switch, from Alexander Duyck. 11) Rearrange TCP_SKB_CB() to reduce cache line misses, from Eric Dumazet. 12) Add Datacenter TCP congestion control algorithm support, From Florian Westphal. 13) Reorganize sk_buff so that __copy_skb_header() is significantly faster. From Eric Dumazet" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1558 commits) netlabel: directly return netlbl_unlabel_genl_init() net: add netdev_txq_bql_{enqueue, complete}_prefetchw() helpers net: description of dma_cookie cause make xmldocs warning cxgb4: clean up a type issue cxgb4: potential shift wrapping bug i40e: skb->xmit_more support net: fs_enet: Add NAPI TX net: fs_enet: Remove non NAPI RX r8169:add support for RTL8168EP net_sched: copy exts->type in tcf_exts_change() wimax: convert printk to pr_foo() af_unix: remove 0 assignment on static ipv6: Do not warn for informational ICMP messages, regardless of type. Update Intel Ethernet Driver maintainers list bridge: Save frag_max_size between PRE_ROUTING and POST_ROUTING tipc: fix bug in multicast congestion handling net: better IFF_XMIT_DST_RELEASE support net/mlx4_en: remove NETDEV_TX_BUSY 3c59x: fix bad split of cpu_to_le32(pci_map_single()) net: bcmgenet: fix Tx ring priority programming ...
2014-10-08Merge tag 'compress-3.18-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull compression update from Greg KH: "More fun with the LZO compression code. Here's some patches that properly document what the logic is, and fix up all of the previously reported issues against the LZO code. This has been in linux-next for a while with no issues" * tag 'compress-3.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: lzo: check for length overrun in variable length encoding. Revert "lzo: properly check for overruns" Documentation: lzo: document part of the encoding
2014-10-08Merge tag 'driver-core-3.18-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the driver core patches for 3.18-rc1. Just a few small things, and the addition of a new interface to dump firmware "core dumps" to userspace through sysfs that the wireless and graphic drivers want to use. All of these have been in linux-next for a while" * tag 'driver-core-3.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: dynamic_debug: change __dynamic_<foo>_dbg return types to void driver/base/node: remove unnecessary kfree of node struct from unregister_one_node devres: Improve devm_kasprintf()/kvasprintf() support Documentation: devres: Add missing devm_kstrdup() managed interface Documentation: devres: Add missing IRQ functions firmware_class: make sure fw requests contain a name driver core: Remove kerneldoc from local function attribute_container: fix coding style issues attribute_container: fix whitespace errors drivers/base: Fix length checks in create_syslog_header()/dev_vprintk_emit() device coredump: add new device coredump class Documentation/sysfs-rules.txt: Add device attribute error code documentation
2014-10-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull "trivial tree" updates from Jiri Kosina: "Usual pile from trivial tree everyone is so eagerly waiting for" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Remove MN10300_PROC_MN2WS0038 mei: fix comments treewide: Fix typos in Kconfig kprobes: update jprobe_example.c for do_fork() change Documentation: change "&" to "and" in Documentation/applying-patches.txt Documentation: remove obsolete pcmcia-cs from Changes Documentation: update links in Changes Documentation: Docbook: Fix generated DocBook/kernel-api.xml score: Remove GENERIC_HAS_IOMAP gpio: fix 'CONFIG_GPIO_IRQCHIP' comments tty: doc: Fix grammar in serial/tty dma-debug: modify check_for_stack output treewide: fix errors in printk genirq: fix reference in devm_request_threaded_irq comment treewide: fix synchronize_rcu() in comments checkstack.pl: port to AArch64 doc: queue-sysfs: minor fixes init/do_mounts: better syntax description MIPS: fix comment spelling powerpc/simpleboot: fix comment ...
2014-10-03dynamic_debug: change __dynamic_<foo>_dbg return types to voidJoe Perches
The return value is not used by callers of these functions so change the functions to return void. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Jason Baron <jbaron@akamai.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-03Merge branch 'next' into efi-next-mergeMatt Fleming
Conflicts: arch/x86/boot/compressed/eboot.c
2014-10-03lib: Add a generic cmdline parse function parse_option_strDave Young
There should be a generic function to parse params like a=b,c Adding parse_option_str in lib/cmdline.c which will return true if there's specified option set in the params. Also updated efi=old_map parsing code to use the new function Signed-off-by: Dave Young <dyoung@redhat.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com>
2014-10-03locking/lockdep: Revert qrwlock recusive stuffPeter Zijlstra
Commit f0bab73cb539 ("locking/lockdep: Restrict the use of recursive read_lock() with qrwlock") changed lockdep to try and conform to the qrwlock semantics which differ from the traditional rwlock semantics. In particular qrwlock is fair outside of interrupt context, but in interrupt context readers will ignore all fairness. The problem modeling this is that read and write side have different lock state (interrupts) semantics but we only have a single representation of these. Therefore lockdep will get confused, thinking the lock can cause interrupt lock inversions. So revert it for now; the old rwlock semantics were already imperfectly modeled and the qrwlock extra won't fit either. If we want to properly fix this, I think we need to resurrect the work by Gautham did a few years ago that split the read and write state of locks: http://lwn.net/Articles/332801/ FWIW the locking selftest that would've failed (and was reported by Borislav earlier) is something like: RL(X1); /* IRQ-ON */ LOCK(A); UNLOCK(A); RU(X1); IRQ_ENTER(); RL(X1); /* IN-IRQ */ RU(X1); IRQ_EXIT(); At which point it would report that because A is an IRQ-unsafe lock we can suffer the following inversion: CPU0 CPU1 lock(A) lock(X1) lock(A) <IRQ> lock(X1) And this is 'wrong' because X1 can recurse (assuming the above lock are in fact read-lock) but lockdep doesn't know about this. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Waiman Long <Waiman.Long@hp.com> Cc: ego@linux.vnet.ibm.com Cc: bp@alien8.de Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/20140930132600.GA7444@worktop.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-10-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/usb/r8152.c net/netfilter/nfnetlink.c Both r8152 and nfnetlink conflicts were simple overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Don't halt the firmware in r8152 driver, from Hayes Wang. 2) Handle full sized 802.1ad frames in bnx2 and tg3 drivers properly, from Vlad Yasevich. 3) Don't sleep while holding tx_clean_lock in netxen driver, fix from Manish Chopra. 4) Certain kinds of ipv6 routes can end up endlessly failing the route validation test, causing it to be re-looked up over and over again. This particularly kills input route caching in TCP sockets. Fix from Hannes Frederic Sowa. 5) netvsc_start_xmit() has a use-after-free access to skb->len, fix from K Y Srinivasan. 6) Fix matching of inverted containers in ematch module, from Ignacy Gawędzki. 7) Aggregation of GRO frames via SKB ->frag_list for linear skbs isn't handled properly, regression fix from Eric Dumazet. 8) Don't test return value of ipv4_neigh_lookup(), which returns an error pointer, against NULL. From WANG Cong. 9) Fix an old regression where we mistakenly allow a double add of the same tunnel. Fixes from Steffen Klassert. 10) macvtap device delete and open can run in parallel and corrupt lists etc., fix from Vlad Yasevich. 11) Fix build error with IPV6=m NETFILTER_XT_TARGET_TPROXY=y, from Pablo Neira Ayuso. 12) rhashtable_destroy() triggers lockdep splats, fix also from Pablo. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (32 commits) bna: Update Maintainer Email r8152: disable power cut for RTL8153 r8152: remove clearing bp bnx2: Correctly receive full sized 802.1ad fragmes tg3: Allow for recieve of full-size 8021AD frames r8152: fix setting RTL8152_UNPLUG netxen: Fix bug in Tx completion path. netxen: Fix BUG "sleeping function called from invalid context" ipv6: remove rt6i_genid hyperv: Fix a bug in netvsc_start_xmit() net: stmmac: fix stmmac_pci_probe failed when CONFIG_HAVE_CLK is selected ematch: Fix matching of inverted containers. gro: fix aggregation for skb using frag_list neigh: check error pointer instead of NULL for ipv4_neigh_lookup() ip6_gre: Return an error when adding an existing tunnel. ip6_vti: Return an error when adding an existing tunnel. ip6_tunnel: Return an error when adding an existing tunnel. ip6gre: add a rtnl link alias for ip6gretap net/mlx4_core: Allow not to specify probe_vf in SRIOV IB mode r8152: fix the carrier off when autoresuming ...
2014-10-01Merge commit 'v3.16' into nextJames Morris
2014-09-28lzo: check for length overrun in variable length encoding.Willy Tarreau
This fix ensures that we never meet an integer overflow while adding 255 while parsing a variable length encoding. It works differently from commit 206a81c ("lzo: properly check for overruns") because instead of ensuring that we don't overrun the input, which is tricky to guarantee due to many assumptions in the code, it simply checks that the cumulated number of 255 read cannot overflow by bounding this number. The MAX_255_COUNT is the maximum number of times we can add 255 to a base count without overflowing an integer. The multiply will overflow when multiplying 255 by more than MAXINT/255. The sum will overflow earlier depending on the base count. Since the base count is taken from a u8 and a few bits, it is safe to assume that it will always be lower than or equal to 2*255, thus we can always prevent any overflow by accepting two less 255 steps. This patch also reduces the CPU overhead and actually increases performance by 1.1% compared to the initial code, while the previous fix costs 3.1% (measured on x86_64). The fix needs to be backported to all currently supported stable kernels. Reported-by: Willem Pinckaers <willem@lekkertech.net> Cc: "Don A. Bailey" <donb@securitymouse.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Willy Tarreau <w@1wt.eu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-28Revert "lzo: properly check for overruns"Willy Tarreau
This reverts commit 206a81c ("lzo: properly check for overruns"). As analysed by Willem Pinckaers, this fix is still incomplete on certain rare corner cases, and it is easier to restart from the original code. Reported-by: Willem Pinckaers <willem@lekkertech.net> Cc: "Don A. Bailey" <donb@securitymouse.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Willy Tarreau <w@1wt.eu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nfDavid S. Miller
Pablo Neira Ayuso says: ==================== nf pull request for net This series contains netfilter fixes for net, they are: 1) Fix lockdep splat in nft_hash when releasing sets from the rcu_callback context. We don't the mutex there anymore. 2) Remove unnecessary spinlock_bh in the destroy path of the nf_tables rbtree set type from rcu_callback context. 3) Fix another lockdep splat in rhashtable. None of the callers hold a mutex when calling rhashtable_destroy. 4) Fix duplicated error reporting from nfnetlink when aborting and replaying a batch. 5) Fix a Kconfig issue reported by kbuild robot. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-26bpf: mini eBPF library, test stubs and verifier testsuiteAlexei Starovoitov
1. the library includes a trivial set of BPF syscall wrappers: int bpf_create_map(int key_size, int value_size, int max_entries); int bpf_update_elem(int fd, void *key, void *value); int bpf_lookup_elem(int fd, void *key, void *value); int bpf_delete_elem(int fd, void *key); int bpf_get_next_key(int fd, void *key, void *next_key); int bpf_prog_load(enum bpf_prog_type prog_type, const struct sock_filter_int *insns, int insn_len, const char *license); bpf_prog_load() stores verifier log into global bpf_log_buf[] array and BPF_*() macros to build instructions 2. test stubs configure eBPF infra with 'unspec' map and program types. These are fake types used by user space testsuite only. 3. verifier tests valid and invalid programs and expects predefined error log messages from kernel. 40 tests so far. $ sudo ./test_verifier #0 add+sub+mul OK #1 unreachable OK #2 unreachable2 OK #3 out of range jump OK #4 out of range jump2 OK #5 test1 ld_imm64 OK ... Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-26genalloc: fix device node resource counterVladimir Zapolskiy
Decrement the np_pool device_node refcount, which was incremented on the preceding of_parse_phandle() call. Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Olof Johansson <olof@lixom.net> Cc: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-09-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
