[ Upstream commit 0b053c9518292705736329a8fe20ef4686ffc8e9 ]
OPTIMIZER_HIDE_VAR(), as defined when using gcc, is insufficient to
ensure protection from dead store optimization.
For the random driver and crypto drivers, calls are emitted ...
$ gdb vmlinux
(gdb) disassemble memzero_explicit
Dump of assembler code for function memzero_explicit:
0xffffffff813a18b0 <+0>: push %rbp
0xffffffff813a18b1 <+1>: mov %rsi,%rdx
0xffffffff813a18b4 <+4>: xor %esi,%esi
0xffffffff813a18b6 <+6>: mov %rsp,%rbp
0xffffffff813a18b9 <+9>: callq 0xffffffff813a7120 <memset>
0xffffffff813a18be <+14>: pop %rbp
0xffffffff813a18bf <+15>: retq
End of assembler dump.
(gdb) disassemble extract_entropy
0xffffffff814a5009 <+313>: mov %r12,%rdi
0xffffffff814a500c <+316>: mov $0xa,%esi
0xffffffff814a5011 <+321>: callq 0xffffffff813a18b0 <memzero_explicit>
0xffffffff814a5016 <+326>: mov -0x48(%rbp),%rax
... but in case in future we might use facilities such as LTO, then
OPTIMIZER_HIDE_VAR() is not sufficient to protect gcc from a possible
eviction of the memset(). We have to use a compiler barrier instead.
Minimal test example when we assume memzero_explicit() would *not* be
a call, but would have been *inlined* instead:
static inline void memzero_explicit(void *s, size_t count)
memset(s, 0, count);
<foo>
int main(void)
char buff[20];
snprintf(buff, sizeof(buff) - 1, "test");
printf("%s", buff);
memzero_explicit(buff, sizeof(buff));
return 0;
With <foo> := OPTIMIZER_HIDE_VAR():
(gdb) disassemble main
Dump of assembler code for function main:
0x0000000000400464 <+36>: callq 0x400410 <printf@plt>
0x0000000000400469 <+41>: xor %eax,%eax
0x000000000040046b <+43>: add $0x28,%rsp
0x000000000040046f <+47>: retq
With <foo> := barrier():
0x0000000000400469 <+41>: movq $0x0,(%rsp)
0x0000000000400471 <+49>: movq $0x0,0x8(%rsp)
0x000000000040047a <+58>: movl $0x0,0x10(%rsp)
0x0000000000400482 <+66>: xor %eax,%eax
0x0000000000400484 <+68>: add $0x28,%rsp
0x0000000000400488 <+72>: retq
As can be seen, movq, movq, movl are being emitted inlined
via memset().
Reference: http://thread.gmane.org/gmane.linux.kernel.cryptoapi/13764/
Fixes: d4c5efdb9777 ("random: add and use memzero_explicit() for clearing data")
Cc: Theodore Ts'o <tytso@mit.edu>
Signed-off-by: mancha security <mancha1@zoho.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Stephan Mueller <smueller@chronox.de>
[ Upstream commit d5e7cafd69da24e6d6cc988fab6ea313a2577efc ]
If the part of the compression data are corrupted, or the compression
data is totally fake, the memory access over the limit is possible.
This is the log from my system usning lz4 decompression.
[6502]data abort, halting
[6503]r0 0x00000000 r1 0x00000000 r2 0xdcea0ffc r3 0xdcea0ffc
[6509]r4 0xb9ab0bfd r5 0xdcea0ffc r6 0xdcea0ff8 r7 0xdce80000
[6515]r8 0x00000000 r9 0x00000000 r10 0x00000000 r11 0xb9a98000
[6522]r12 0xdcea1000 usp 0x00000000 ulr 0x00000000 pc 0x820149bc
[6528]spsr 0x400001f3
and the memory addresses of some variables at the moment are
ref:0xdcea0ffc, op:0xdcea0ffc, oend:0xdcea1000
As you can see, COPYLENGH is 8bytes, so @ref and @op can access the momory
over @oend.
Signed-off-by: JeHyeon Yeon <tom.yeon@windriver.com>
Reviewed-by: David Sterba <dsterba@suse.cz>
commit 9ce357795ef208faa0d59894d9d119a7434e37f3 upstream.
Fixed commit added from64to32 under _#ifndef do_csum_ but used it
under _#ifndef csum_tcpudp_nofold_, breaking some builds (Fengguang's
robot reported TILEGX's). Move from64to32 under the latter.
Fixes: 150ae0e94634 ("lib/checksum.c: fix carry in csum_tcpudp_nofold")
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Signed-off-by: Karl Beldan <karl.beldan@rivierawaves.com>
Cc: Eric Dumazet <edumazet@google.com>
commit 150ae0e94634714b23919f0c333fee28a5b199d5 upstream.
The carry from the 64->32bits folding was dropped, e.g with:
saddr=0xFFFFFFFF daddr=0xFF0000FF len=0xFFFF proto=0 sum=1,
csum_tcpudp_nofold returned 0 instead of 1.
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: netdev@vger.kernel.org
commit b5c8afe5be51078a979d86ae5ae78c4ac948063d upstream.
"origPtr" is used as an offset into the bd->dbuf[] array. That array is
allocated in start_bunzip() and has "bd->dbufSize" number of elements so
the test here should be >= instead of >.
Later we check "origPtr" again before using it as an offset so I don't
know if this bug can be triggered in real life.
Fixes: bc22c17e12c1 ('bzip2/lzma: library support for gzip, bzip2 and lzma decompression')
Cc: Alain Knaff <alain@knaff.lu>
Cc: Yinghai Lu <yinghai@kernel.org>
Modules can use this function for creating pool.
Acked-by: Lad, Prabhakar <prabhakar.csengg@gmail.com>
Cc: Laura Abbott <lauraa@codeaurora.org>
Cc: Olof Johansson <olof@lixom.net>
Cc: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com>
Cc: Philipp Zabel <p.zabel@pengutronix.de>
Minor fixlet to perform the reserved pages counter aggregation for each
node, at show_mem()
Signed-off-by: Rafael Aquini <aquini@redhat.com>
Acked-by: Johannes Weiner <jweiner@redhat.com>
Acked-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Otherwise the exported symbols might be discarded because of no users
in vmlinux.
Reported-by: Jim Davis <jim.epost@gmail.com>
My editor spewed garbage that looked like memory corruption on
my screen. It turns out that a number of occurences of "fi" got
turned into a ligature.
This patch replaces these ligatures with the ASCII letters "fi".
Cheers,
Acked-by: Thomas Graf <tgraf@suug.ch>
Merge misc fixes from Andrew Morton:
"21 fixes"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (21 commits)
mm/balloon_compaction: fix deflation when compaction is disabled
sh: fix sh770x SCIF memory regions
zram: avoid NULL pointer access in concurrent situation
mm/slab_common: don't check for duplicate cache names
ocfs2: fix d_splice_alias() return code checking
mm: rmap: split out page_remove_file_rmap()
mm: memcontrol: fix missed end-writeback page accounting
mm: page-writeback: inline account_page_dirtied() into single caller
lib/bitmap.c: fix undefined shift in __bitmap_shift_{left|right}()
drivers/rtc/rtc-bq32k.c: fix register value
memory-hotplug: clear pgdat which is allocated by bootmem in try_offline_node()
drivers/rtc/rtc-s3c.c: fix initialization failure without rtc source clock
kernel/kmod: fix use-after-free of the sub_info structure
drivers/rtc/rtc-pm8xxx.c: rework to support pm8941 rtc
mm, thp: fix collapsing of hugepages on madvise
drivers: of: add return value to of_reserved_mem_device_init()
mm: free compound page with correct order
gcov: add ARM64 to GCOV_PROFILE_ALL
fsnotify: next_i is freed during fsnotify_unmount_inodes.
mm/compaction.c: avoid premature range skip in isolate_migratepages_range
If __bitmap_shift_left() or __bitmap_shift_right() are asked to shift by
a multiple of BITS_PER_LONG, they will try to shift a long value by
BITS_PER_LONG bits which is undefined. Change the functions to avoid
the undefined shift.
Coverity id: 1192175
Coverity id: 1192174
Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Cc: <stable@vger.kernel.org>
Pull block layer fixes from Jens Axboe:
"A small collection of fixes for the current kernel. This contains:
- Two error handling fixes from Jan Kara. One for null_blk on
failure to add a device, and the other for the block/scsi_ioctl
SCSI_IOCTL_SEND_COMMAND fixing up the error jump point.
- A commit added in the merge window for the bio integrity bits
unfortunately disabled merging for all requests if
CONFIG_BLK_DEV_INTEGRITY wasn't set. Reverse the logic, so that
integrity checking wont disallow merges when not enabled.
- A fix from Ming Lei for merging and generating too many segments.
This caused a BUG in virtio_blk.
- Two error handling printk() fixups from Robert Elliott, improving
the information given when we rate limit.
- Error handling fixup on elevator_init() failure from Sudip
Mukherjee.
- A fix from Tony Battersby, fixing up a memory leak in the
scatterlist handling with scsi-mq"
* 'for-linus' of git://git.kernel.dk/linux-block:
block: Fix merge logic when CONFIG_BLK_DEV_INTEGRITY is not defined
lib/scatterlist: fix memory leak with scsi-mq
block: fix wrong error return in elevator_init()
scsi: Fix error handling in SCSI_IOCTL_SEND_COMMAND
null_blk: Cleanup error recovery in null_add_dev()
blk-merge: recaculate segment if it isn't less than max segments
fs: clarify rate limit suppressed buffer I/O errors
fs: merge I/O error prints into one line
Fix a memory leak with scsi-mq triggered by commands with large data
transfer length.
Fixes: c53c6d6a68b1 ("scatterlist: allow chaining to preallocated chunks")
Cc: <stable@vger.kernel.org> # 3.17.x
Signed-off-by: Tony Battersby <tonyb@cybernetics.com>
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random
Pull /dev/random updates from Ted Ts'o:
"This adds a memzero_explicit() call which is guaranteed not to be
optimized away by GCC. This is important when we are wiping
cryptographically sensitive material"
* tag 'random_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random:
crypto: memzero_explicit - make sure to clear out sensitive data
Pull x86 EFI updates from Peter Anvin:
"This patchset falls under the "maintainers that grovel" clause in the
v3.18-rc1 announcement. We had intended to push it late in the merge
window since we got it into the -tip tree relatively late.
Many of these are relatively simple things, but there are a couple of
key bits, especially Ard's and Matt's patches"
* 'x86-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits)
rtc: Disable EFI rtc for x86
efi: rtc-efi: Export platform:rtc-efi as module alias
efi: Delete the in_nmi() conditional runtime locking
efi: Provide a non-blocking SetVariable() operation
x86/efi: Adding efi_printks on memory allocationa and pci.reads
x86/efi: Mark initialization code as such
x86/efi: Update comment regarding required phys mapped EFI services
x86/efi: Unexport add_efi_memmap variable
x86/efi: Remove unused efi_call* macros
efi: Resolve some shadow warnings
arm64: efi: Format EFI memory type & attrs with efi_md_typeattr_format()
ia64: efi: Format EFI memory type & attrs with efi_md_typeattr_format()
x86: efi: Format EFI memory type & attrs with efi_md_typeattr_format()
efi: Introduce efi_md_typeattr_format()
efi: Add macro for EFI_MEMORY_UCE memory attribute
x86/efi: Clear EFI_RUNTIME_SERVICES if failing to enter virtual mode
arm64/efi: Do not enter virtual mode if booting with efi=noruntime or noefi
arm64/efi: uefi_init error handling fix
efi: Add kernel param efi=noruntime
lib: Add a generic cmdline parse function parse_option_str
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux
Pull fbdev updates from Tomi Valkeinen:
- new 6x10 font
- various small fixes and cleanups
* tag 'fbdev-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux: (30 commits)
fonts: Add 6x10 font
videomode: provide dummy inline functions for !CONFIG_OF
video/atmel_lcdfb: Introduce regulator support
fbdev: sh_mobile_hdmi: Re-init regs before irq re-enable on resume
framebuffer: fix screen corruption when copying
framebuffer: fix border color
arm, fbdev, omap2, LLVMLinux: Remove nested function from omapfb
arm, fbdev, omap2, LLVMLinux: Remove nested function from omap2 dss
video: fbdev: valkyriefb.c: use container_of to resolve fb_info_valkyrie from fb_info
video: fbdev: pxafb.c: use container_of to resolve pxafb_info/layer from fb_info
video: fbdev: cyber2000fb.c: use container_of to resolve cfb_info from fb_info
video: fbdev: controlfb.c: use container_of to resolve fb_info_control from fb_info
video: fbdev: sa1100fb.c: use container_of to resolve sa1100fb_info from fb_info
video: fbdev: stifb.c: use container_of to resolve stifb_info from fb_info
video: fbdev: sis: sis_main.c: Cleaning up missing null-terminate in conjunction with strncpy
video: valkyriefb: Fix unused variable warning in set_valkyrie_clock()
video: fbdev: use %*ph specifier to dump small buffers
video: mx3fb: always enable BACKLIGHT_LCD_SUPPORT
video: fbdev: au1200fb: delete double assignment
video: fbdev: sis: delete double assignment
Pull md updates from Neil Brown:
- a few minor bug fixes
- quite a lot of code tidy-up and simplification
- remove PRINT_RAID_DEBUG ioctl. I'm fairly sure it is unused, and it
isn't particularly useful.
* tag 'md/3.18' of git://neil.brown.name/md: (21 commits)
lib/raid6: Add log level to printks
md: move EXPORT_SYMBOL to after function in md.c
md: discard PRINT_RAID_DEBUG ioctl
md: remove MD_BUG()
md: clean up 'exit' labels in md_ioctl().
md: remove unnecessary test for MD_MAJOR in md_ioctl()
md: don't allow "-sync" to be set for device in an active array.
md: remove unwanted white space from md.c
md: don't start resync thread directly from md thread.
md: Just use RCU when checking for overlap between arrays.
md: avoid potential long delay under pers_lock
md: simplify export_array()
md: discard find_rdev_nr in favour of find_rdev_nr_rcu
md: use wait_event() to simplify md_super_wait()
md: be more relaxed about stopping an array which isn't started.
md/raid1: process_checks doesn't use its return value.
md/raid5: fix init_stripe() inconsistencies
md/raid10: another memory leak due to reshape.
md: use set_bit/clear_bit instead of shift/mask for bi_flags changes.
md/raid1: minor typos and reformatting.
zatimend has reported that in his environment (3.16/gcc4.8.3/corei7)
memset() calls which clear out sensitive data in extract_{buf,entropy,
entropy_user}() in random driver are being optimized away by gcc.
Add a helper memzero_explicit() (similarly as explicit_bzero() variants)
that can be used in such cases where a variable with sensitive data is
being cleared out in the end. Other use cases might also be in crypto
code. [ I have put this into lib/string.c though, as it's always built-in
and doesn't need any dependencies then. ]
Fixes kernel bugzilla: 82041
Reported-by: zatimend@hotmail.co.uk
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Cc: stable@vger.kernel.org
Replaced the use of a Variable Length Array In Struct (VLAIS) with a C99
compliant equivalent. This patch allocates the appropriate amount of memory
using a char array using the SHASH_DESC_ON_STACK macro.
The new code can be compiled with both gcc and clang.
Signed-off-by: Jan-Simon Möller <dl9pf@gmx.de>
Signed-off-by: Behan Webster <behanw@converseincode.com>
Reviewed-by: Mark Charlebois <charlebm@gmail.com>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Cc: pageexec@freemail.hu
Signed-off-by: NeilBrown <neilb@suse.de>
This allows user to print a given buffer as an escaped string. The
rules are applied according to an optional mix of flags provided by
additional format letters.
For example, if the given buffer is:
1b 62 20 5c 43 07 22 90 0d 5d
The result strings would be:
%*pE "\eb \C\a"\220\r]"
%*pEhp "\x1bb \C\x07"\x90\x0d]"
%*pEa "\e\142\040\\\103\a\042\220\r\135"
Please, read Documentation/printk-formats.txt and lib/string_helpers.c
kernel documentation to get further information.
[akpm@linux-foundation.org: tidy up comment layout, per Joe]
Suggested-by: Joe Perches <joe@perches.com>
Cc: "John W . Linville" <linville@tuxdriver.com>
Cc: Johannes Berg <johannes@sipsolutions.net>
This is almost the opposite function to string_unescape(). Nevertheless
it handles \0 and could be used for any byte buffer.
The documentation is supplied together with the function prototype.
The test cases covers most of the scenarios and would be expanded later
on.
[akpm@linux-foundation.org: avoid 1k stack consumption]
Cc: Joe Perches <joe@perches.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
This patch prepares test suite for a following update. It introduces
test_string_check_buf() helper which checks the result and dumps an error.
The introduced function string_escape_mem() is a kind of opposite to
string_unescape. We have several users of such functionality each of
them created custom implementation. The series contains clean up of
test suite, adding new call, and switching few users to use it via %*pE
specifier.
Test suite covers all of existing and most of potential use cases.
This patch (of 11):
The documentation of API belongs to c-file. This patch moves it
accordingly.
There is no functional change.
The previous patch made strnicmp into a wrapper for strncasecmp.
This patch makes all in-tree users of strnicmp call strncasecmp
directly, while still making sure that the strnicmp symbol can be used
by out-of-tree modules. It should be considered a temporary hack until
all in-tree callers have been converted.
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
lib/string.c contains two functions, strnicmp and strncasecmp, which do
roughly the same thing, namely compare two strings case-insensitively up
to a given bound. They have slightly different implementations, but the
only important difference is that strncasecmp doesn't handle len==0
appropriately; it effectively becomes strcasecmp in that case. strnicmp
correctly says that two strings are always equal in their first 0
characters.
strncasecmp is the POSIX name for this functionality. So rename the
non-broken function to the standard name. To minimize the impact on the
rest of the kernel (and since both are exported to modules), make strnicmp
Cc: Grant Likely <grant.likely@linaro.org>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Cc: "H. Peter Anvin" <hpa@linux.intel.com>
The "_MODULE" suffix is reserved for tristates compiled as loadable kernel
modules (LKM). The "TEST_MODULE" feature thereby violates this
convention. The feature is used to compile the lib/test_module.c kernel
module.
Sadly this convention is not made explicit, but the Kconfig code documents
it. The following code (./scripts/kconfig/confdata.c) is used to generate
the autoconf.h header file during the build process. When a feature is
selected as a kernel module ('m'), it is suffixed with "_MODULE" to
indicate it.
switch (*value) {
case 'n':
break;
case 'm':
suffix = "_MODULE";
/* fall through */
This causes problems for static code analysis, which assumes a consistent
use of the "_MODULE" suffix.
This patch renames the feature and its reference in a Makefile to
"TEST_LKM", which still expresses the test of a LKM.
Signed-off-by: Valentin Rothberg <valentinrothberg@gmail.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
The prio_heap code is unused since commit 889ed9ceaa97 ("cgroup: remove
css_scan_tasks()"). It should be compiled out to shrink the binary
kernel size which can be done via introducing CONFIG_PRIO_HEAD or by
removing the code.
We can simply recover the code from git when needed, so it would be
better to remove it IMO.
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Acked-by: Tejun Heo <tj@kernel.org>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Cc: Francesco Fusco <ffusco@redhat.com>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: George Spelvin <linux@horizon.com>
Cc: Mark Salter <msalter@redhat.com>
There is no textsearch_put(). Remove it from the comments to avoid
misunderstanding. Textsearch prepare no longer needs textsearch_put().
Signed-off-by: Raphael Silva <rapphil@gmail.com>
Using seq_open_private() removes boilerplate code from ddebug_proc_open().
The resultant code is shorter and easier to follow.
This patch does not change any functionality.
Signed-off-by: Rob Jones <rob.jones@codethink.co.uk>
Acked-by: Jason Baron <jbaron@akamai.com>
Pull scheduler updates from Ingo Molnar:
"The main changes in this cycle were:
- Optimized support for Intel "Cluster-on-Die" (CoD) topologies (Dave
Hansen)
- Various sched/idle refinements for better idle handling (Nicolas
Pitre, Daniel Lezcano, Chuansheng Liu, Vincent Guittot)
- sched/numa updates and optimizations (Rik van Riel)
- sysbench speedup (Vincent Guittot)
- capacity calculation cleanups/refactoring (Vincent Guittot)
- Various cleanups to thread group iteration (Oleg Nesterov)
- Double-rq-lock removal optimization and various refactorings
(Kirill Tkhai)
- various sched/deadline fixes
... and lots of other changes"
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (72 commits)
sched/dl: Use dl_bw_of() under rcu_read_lock_sched()
sched/fair: Delete resched_cpu() from idle_balance()
sched, time: Fix build error with 64 bit cputime_t on 32 bit systems
sched: Improve sysbench performance by fixing spurious active migration
sched/x86: Fix up typo in topology detection
x86, sched: Add new topology for multi-NUMA-node CPUs
sched/rt: Use resched_curr() in task_tick_rt()
sched: Use rq->rd in sched_setaffinity() under RCU read lock
sched: cleanup: Rename 'out_unlock' to 'out_free_new_mask'
sched: Use dl_bw_of() under RCU read lock
sched/fair: Remove duplicate code from can_migrate_task()
sched, mips, ia64: Remove __ARCH_WANT_UNLOCKED_CTXSW
sched: print_rq(): Don't use tasklist_lock
sched: normalize_rt_tasks(): Don't use _irqsave for tasklist_lock, use task_rq_lock()
sched: Fix the task-group check in tg_has_rt_tasks()
sched/fair: Leverage the idle state info when choosing the "idlest" cpu
sched: Let the scheduler see CPU idle states
sched/deadline: Fix inter- exclusive cpusets migrations
sched/deadline: Clear dl_entity params when setscheduling to different class
sched/numa: Kill the wrong/dead TASK_DEAD check in task_numa_fault()
Pull core locking updates from Ingo Molnar:
"The main updates in this cycle were:
- mutex MCS refactoring finishing touches: improve comments, refactor
and clean up code, reduce debug data structure footprint, etc.
- qrwlock finishing touches: remove old code, self-test updates.
- small rwsem optimization
- various smaller fixes/cleanups"
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
locking/lockdep: Revert qrwlock recusive stuff
locking/rwsem: Avoid double checking before try acquiring write lock
locking/rwsem: Move EXPORT_SYMBOL() lines to follow function definition
locking/rwlock, x86: Delete unused asm/rwlock.h and rwlock.S
locking/rwlock, x86: Clean up asm/spinlock*.h to remove old rwlock code
locking/semaphore: Resolve some shadow warnings
locking/selftest: Support queued rwlock
locking/lockdep: Restrict the use of recursive read_lock() with qrwlock
locking/spinlocks: Always evaluate the second argument of spin_lock_nested()
locking/Documentation: Update locking/mutex-design.txt disadvantages
locking/Documentation: Move locking related docs into Documentation/locking/
locking/mutexes: Use MUTEX_SPIN_ON_OWNER when appropriate
locking/mutexes: Refactor optimistic spinning code
locking/mcs: Remove obsolete comment
locking/mutexes: Document quick lock release when unlocking
locking/mutexes: Standardize arguments in lock/unlock slowpaths
locking: Remove deprecated smp_mb__() barriers
Pull arch atomic cleanups from Ingo Molnar:
"This is a series kept separate from the main locking tree, which
cleans up and improves various details in the atomics type handling:
- Remove the unused atomic_or_long() method
- Consolidate and compress atomic ops implementations between
architectures, to reduce linecount and to make it easier to add new
ops.
- Rewrite generic atomic support to only require cmpxchg() from an
architecture - generate all other methods from that"
* 'locking-arch-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits)
locking,arch: Use ACCESS_ONCE() instead of cast to volatile in atomic_read()
locking, mips: Fix atomics
locking, sparc64: Fix atomics
locking,arch: Rewrite generic atomic support
locking,arch,xtensa: Fold atomic_ops
locking,arch,sparc: Fold atomic_ops
locking,arch,sh: Fold atomic_ops
locking,arch,powerpc: Fold atomic_ops
locking,arch,parisc: Fold atomic_ops
locking,arch,mn10300: Fold atomic_ops
locking,arch,mips: Fold atomic_ops
locking,arch,metag: Fold atomic_ops
locking,arch,m68k: Fold atomic_ops
locking,arch,m32r: Fold atomic_ops
locking,arch,ia64: Fold atomic_ops
locking,arch,hexagon: Fold atomic_ops
locking,arch,cris: Fold atomic_ops
locking,arch,avr32: Fold atomic_ops
locking,arch,arm64: Fold atomic_ops
locking,arch,arm: Fold atomic_ops
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris.
Mostly ima, selinux, smack and key handling updates.
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (65 commits)
integrity: do zero padding of the key id
KEYS: output last portion of fingerprint in /proc/keys
KEYS: strip 'id:' from ca_keyid
KEYS: use swapped SKID for performing partial matching
KEYS: Restore partial ID matching functionality for asymmetric keys
X.509: If available, use the raw subjKeyId to form the key description
KEYS: handle error code encoded in pointer
selinux: normalize audit log formatting
selinux: cleanup error reporting in selinux_nlmsg_perm()
KEYS: Check hex2bin()'s return when generating an asymmetric key ID
ima: detect violations for mmaped files
ima: fix race condition on ima_rdwr_violation_check and process_measurement
ima: added ima_policy_flag variable
ima: return an error code from ima_add_boot_aggregate()
ima: provide 'ima_appraise=log' kernel option
ima: move keyring initialization to ima_init()
PKCS#7: Handle PKCS#7 messages that contain no X.509 certs
PKCS#7: Better handling of unsupported crypto
KEYS: Overhaul key identification when searching for asymmetric keys
KEYS: Implement binary asymmetric key ID handling
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
Pull percpu updates from Tejun Heo:
"A lot of activities on percpu front. Notable changes are...
- percpu allocator now can take @gfp. If @gfp doesn't contain
GFP_KERNEL, it tries to allocate from what's already available to
the allocator and a work item tries to keep the reserve around
certain level so that these atomic allocations usually succeed.
This will replace the ad-hoc percpu memory pool used by
blk-throttle and also be used by the planned blkcg support for
writeback IOs.
Please note that I noticed a bug in how @gfp is interpreted while
preparing this pull request and applied the fix 6ae833c7fe0c
("percpu: fix how @gfp is interpreted by the percpu allocator")
just now.
- percpu_ref now uses longs for percpu and global counters instead of
ints. It leads to more sparse packing of the percpu counters on
64bit machines but the overhead should be negligible and this
allows using percpu_ref for refcnting pages and in-memory objects
directly.
- The switching between percpu and single counter modes of a
percpu_ref is made independent of putting the base ref and a
percpu_ref can now optionally be initialized in single or killed
mode. This allows avoiding percpu shutdown latency for cases where
the refcounted objects may be synchronously created and destroyed
in rapid succession with only a fraction of them reaching fully
operational status (SCSI probing does this when combined with
blk-mq support). It's also planned to be used to implement forced
single mode to detect underflow more timely for debugging.
There's a separate branch percpu/for-3.18-consistent-ops which cleans
up the duplicate percpu accessors. That branch causes a number of
conflicts with s390 and other trees. I'll send a separate pull
request w/ resolutions once other branches are merged"
* 'for-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (33 commits)
blk-mq, percpu_ref: start q->mq_usage_counter in atomic mode
percpu_ref: make INIT_ATOMIC and switch_to_atomic() sticky
percpu_ref: add PERCPU_REF_INIT_* flags
percpu_ref: decouple switching to percpu mode and reinit
percpu_ref: decouple switching to atomic mode and killing
percpu_ref: add PCPU_REF_DEAD
percpu_ref: rename things to prepare for decoupling percpu/atomic mode switch
percpu_ref: replace pcpu_ prefix with percpu_
percpu_ref: minor code and comment updates
percpu_ref: relocate percpu_ref_reinit()
Revert "blk-mq, percpu_ref: implement a kludge for SCSI blk-mq stall during probe"
Revert "percpu: free percpu allocation info for uniprocessor system"
percpu-refcount: make percpu_ref based on longs instead of ints
percpu-refcount: improve WARN messages
percpu: fix locking regression in the failure path of pcpu_alloc()
percpu-refcount: add @gfp to percpu_ref_init()
proportions: add @gfp to init functions
percpu_counter: add @gfp to percpu_counter_init()
percpu_counter: make percpu_counters_lock irq-safe
After allocating an address from a particular genpool, there is no good
way to verify if that address actually belongs to a genpool. Introduce
addr_in_gen_pool which will return if an address plus size falls
completely within the genpool range.
Signed-off-by: Laura Abbott <lauraa@codeaurora.org>
Acked-by: Will Deacon <will.deacon@arm.com>
Reviewed-by: Olof Johansson <olof@lixom.net>
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
Cc: David Riley <davidriley@chromium.org>
Cc: Ritesh Harjain <ritesh.harjani@gmail.com>
Cc: Thierry Reding <thierry.reding@gmail.com>
One of the more common algorithms used for allocation is to align the
start address of the allocation to the order of size requested. Add this
as an algorithm option for genalloc.
Acked-by: Olof Johansson <olof@lixom.net>
This font is suitable for framebuffer consoles on devices with a
320x240 screen, to get a reasonable number of characters (53x24) that
are still at a readable size.
The font is derived from the existing 6x11 font, but gets 3 extra
lines without sacrificing readability. Also I redesigned a some glyhps
so they are more distinct and better fill the available space.
Signed-off-by: Maarten ter Huurne <maarten@treewalker.org>
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Pull networking updates from David Miller:
"Most notable changes in here:
1) By far the biggest accomplishment, thanks to a large range of
contributors, is the addition of multi-send for transmit. This is
the result of discussions back in Chicago, and the hard work of
several individuals.
Now, when the ->ndo_start_xmit() method of a driver sees
skb->xmit_more as true, it can choose to defer the doorbell
telling the driver to start processing the new TX queue entires.
skb->xmit_more means that the generic networking is guaranteed to
call the driver immediately with another SKB to send.
There is logic added to the qdisc layer to dequeue multiple
packets at a time, and the handling mis-predicted offloads in
software is now done with no locks held.
Finally, pktgen is extended to have a "burst" parameter that can
be used to test a multi-send implementation.
Several drivers have xmit_more support: i40e, igb, ixgbe, mlx4,
virtio_net
Adding support is almost trivial, so export more drivers to
support this optimization soon.
I want to thank, in no particular or implied order, Jesper
Dangaard Brouer, Eric Dumazet, Alexander Duyck, Tom Herbert, Jamal
Hadi Salim, John Fastabend, Florian Westphal, Daniel Borkmann,
David Tat, Hannes Frederic Sowa, and Rusty Russell.
2) PTP and timestamping support in bnx2x, from Michal Kalderon.
3) Allow adjusting the rx_copybreak threshold for a driver via
ethtool, and add rx_copybreak support to enic driver. From
Govindarajulu Varadarajan.
4) Significant enhancements to the generic PHY layer and the bcm7xxx
driver in particular (EEE support, auto power down, etc.) from
Florian Fainelli.
5) Allow raw buffers to be used for flow dissection, allowing drivers
to determine the optimal "linear pull" size for devices that DMA
into pools of pages. The objective is to get exactly the
necessary amount of headers into the linear SKB area pre-pulled,
but no more. The new interface drivers use is eth_get_headlen().
From WANG Cong, with driver conversions (several had their own
by-hand duplicated implementations) by Alexander Duyck and Eric
Dumazet.
6) Support checksumming more smoothly and efficiently for
encapsulations, and add "foo over UDP" facility. From Tom
Herbert.
7) Add Broadcom SF2 switch driver to DSA layer, from Florian
Fainelli.
8) eBPF now can load programs via a system call and has an extensive
testsuite. Alexei Starovoitov and Daniel Borkmann.
9) Major overhaul of the packet scheduler to use RCU in several major
areas such as the classifiers and rate estimators. From John
Fastabend.
10) Add driver for Intel FM10000 Ethernet Switch, from Alexander
Duyck.
11) Rearrange TCP_SKB_CB() to reduce cache line misses, from Eric
Dumazet.
12) Add Datacenter TCP congestion control algorithm support, From
Florian Westphal.
13) Reorganize sk_buff so that __copy_skb_header() is significantly
faster. From Eric Dumazet"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1558 commits)
netlabel: directly return netlbl_unlabel_genl_init()
net: add netdev_txq_bql_{enqueue, complete}_prefetchw() helpers
net: description of dma_cookie cause make xmldocs warning
cxgb4: clean up a type issue
cxgb4: potential shift wrapping bug
i40e: skb->xmit_more support
net: fs_enet: Add NAPI TX
net: fs_enet: Remove non NAPI RX
r8169:add support for RTL8168EP
net_sched: copy exts->type in tcf_exts_change()
wimax: convert printk to pr_foo()
af_unix: remove 0 assignment on static
ipv6: Do not warn for informational ICMP messages, regardless of type.
Update Intel Ethernet Driver maintainers list
bridge: Save frag_max_size between PRE_ROUTING and POST_ROUTING
tipc: fix bug in multicast congestion handling
net: better IFF_XMIT_DST_RELEASE support
net/mlx4_en: remove NETDEV_TX_BUSY
3c59x: fix bad split of cpu_to_le32(pci_map_single())
net: bcmgenet: fix Tx ring priority programming
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull compression update from Greg KH:
"More fun with the LZO compression code. Here's some patches that
properly document what the logic is, and fix up all of the previously
reported issues against the LZO code.
This has been in linux-next for a while with no issues"
* tag 'compress-3.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
lzo: check for length overrun in variable length encoding.
Revert "lzo: properly check for overruns"
Documentation: lzo: document part of the encoding
Pull driver core update from Greg KH:
"Here's the driver core patches for 3.18-rc1. Just a few small things,
and the addition of a new interface to dump firmware "core dumps" to
userspace through sysfs that the wireless and graphic drivers want to
use.
All of these have been in linux-next for a while"
* tag 'driver-core-3.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
dynamic_debug: change __dynamic_<foo>_dbg return types to void
driver/base/node: remove unnecessary kfree of node struct from unregister_one_node
devres: Improve devm_kasprintf()/kvasprintf() support
Documentation: devres: Add missing devm_kstrdup() managed interface
Documentation: devres: Add missing IRQ functions
firmware_class: make sure fw requests contain a name
driver core: Remove kerneldoc from local function
attribute_container: fix coding style issues
attribute_container: fix whitespace errors
drivers/base: Fix length checks in create_syslog_header()/dev_vprintk_emit()
device coredump: add new device coredump class
Documentation/sysfs-rules.txt: Add device attribute error code documentation
Pull "trivial tree" updates from Jiri Kosina:
"Usual pile from trivial tree everyone is so eagerly waiting for"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Remove MN10300_PROC_MN2WS0038
mei: fix comments
treewide: Fix typos in Kconfig
kprobes: update jprobe_example.c for do_fork() change
Documentation: change "&" to "and" in Documentation/applying-patches.txt
Documentation: remove obsolete pcmcia-cs from Changes
Documentation: update links in Changes
Documentation: Docbook: Fix generated DocBook/kernel-api.xml
score: Remove GENERIC_HAS_IOMAP
gpio: fix 'CONFIG_GPIO_IRQCHIP' comments
tty: doc: Fix grammar in serial/tty
dma-debug: modify check_for_stack output
treewide: fix errors in printk
genirq: fix reference in devm_request_threaded_irq comment
treewide: fix synchronize_rcu() in comments
checkstack.pl: port to AArch64
doc: queue-sysfs: minor fixes
init/do_mounts: better syntax description
MIPS: fix comment spelling
powerpc/simpleboot: fix comment
The return value is not used by callers of these functions
so change the functions to return void.
arch/x86/boot/compressed/eboot.c
There should be a generic function to parse params like a=b,c
Adding parse_option_str in lib/cmdline.c which will return true
if there's specified option set in the params.
Also updated efi=old_map parsing code to use the new function
Signed-off-by: Dave Young <dyoung@redhat.com>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
Commit f0bab73cb539 ("locking/lockdep: Restrict the use of recursive
read_lock() with qrwlock") changed lockdep to try and conform to the
qrwlock semantics which differ from the traditional rwlock semantics.
In particular qrwlock is fair outside of interrupt context, but in
interrupt context readers will ignore all fairness.
The problem modeling this is that read and write side have different
lock state (interrupts) semantics but we only have a single
representation of these. Therefore lockdep will get confused, thinking
the lock can cause interrupt lock inversions.
So revert it for now; the old rwlock semantics were already imperfectly
modeled and the qrwlock extra won't fit either.
If we want to properly fix this, I think we need to resurrect the work
by Gautham did a few years ago that split the read and write state of
locks:
http://lwn.net/Articles/332801/
FWIW the locking selftest that would've failed (and was reported by
Borislav earlier) is something like:
RL(X1); /* IRQ-ON */
LOCK(A);
UNLOCK(A);
RU(X1);
IRQ_ENTER();
RL(X1); /* IN-IRQ */
RU(X1);
IRQ_EXIT();
At which point it would report that because A is an IRQ-unsafe lock we
can suffer the following inversion:
CPU0 CPU1
lock(A)
lock(X1)
lock(A)
<IRQ>
lock(X1)
And this is 'wrong' because X1 can recurse (assuming the above lock are
in fact read-lock) but lockdep doesn't know about this.
Cc: Waiman Long <Waiman.Long@hp.com>
Cc: ego@linux.vnet.ibm.com
Cc: bp@alien8.de
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/20140930132600.GA7444@worktop.programming.kicks-ass.net
drivers/net/usb/r8152.c
net/netfilter/nfnetlink.c
Both r8152 and nfnetlink conflicts were simple overlapping changes.
Pull networking fixes from David Miller:
1) Don't halt the firmware in r8152 driver, from Hayes Wang.
2) Handle full sized 802.1ad frames in bnx2 and tg3 drivers properly,
from Vlad Yasevich.
3) Don't sleep while holding tx_clean_lock in netxen driver, fix from
Manish Chopra.
4) Certain kinds of ipv6 routes can end up endlessly failing the route
validation test, causing it to be re-looked up over and over again.
This particularly kills input route caching in TCP sockets. Fix
from Hannes Frederic Sowa.
5) netvsc_start_xmit() has a use-after-free access to skb->len, fix
from K Y Srinivasan.
6) Fix matching of inverted containers in ematch module, from Ignacy
Gawędzki.
7) Aggregation of GRO frames via SKB ->frag_list for linear skbs isn't
handled properly, regression fix from Eric Dumazet.
8) Don't test return value of ipv4_neigh_lookup(), which returns an
error pointer, against NULL. From WANG Cong.
9) Fix an old regression where we mistakenly allow a double add of the
same tunnel. Fixes from Steffen Klassert.
10) macvtap device delete and open can run in parallel and corrupt lists
etc., fix from Vlad Yasevich.
11) Fix build error with IPV6=m NETFILTER_XT_TARGET_TPROXY=y, from Pablo
Neira Ayuso.
12) rhashtable_destroy() triggers lockdep splats, fix also from Pablo.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (32 commits)
bna: Update Maintainer Email
r8152: disable power cut for RTL8153
r8152: remove clearing bp
bnx2: Correctly receive full sized 802.1ad fragmes
tg3: Allow for recieve of full-size 8021AD frames
r8152: fix setting RTL8152_UNPLUG
netxen: Fix bug in Tx completion path.
netxen: Fix BUG "sleeping function called from invalid context"
ipv6: remove rt6i_genid
hyperv: Fix a bug in netvsc_start_xmit()
net: stmmac: fix stmmac_pci_probe failed when CONFIG_HAVE_CLK is selected
ematch: Fix matching of inverted containers.
gro: fix aggregation for skb using frag_list
neigh: check error pointer instead of NULL for ipv4_neigh_lookup()
ip6_gre: Return an error when adding an existing tunnel.
ip6_vti: Return an error when adding an existing tunnel.
ip6_tunnel: Return an error when adding an existing tunnel.
ip6gre: add a rtnl link alias for ip6gretap
net/mlx4_core: Allow not to specify probe_vf in SRIOV IB mode
r8152: fix the carrier off when autoresuming
This fix ensures that we never meet an integer overflow while adding
255 while parsing a variable length encoding. It works differently from
commit 206a81c ("lzo: properly check for overruns") because instead of
ensuring that we don't overrun the input, which is tricky to guarantee
due to many assumptions in the code, it simply checks that the cumulated
number of 255 read cannot overflow by bounding this number.
The MAX_255_COUNT is the maximum number of times we can add 255 to a base
count without overflowing an integer. The multiply will overflow when
multiplying 255 by more than MAXINT/255. The sum will overflow earlier
depending on the base count. Since the base count is taken from a u8
and a few bits, it is safe to assume that it will always be lower than
or equal to 2*255, thus we can always prevent any overflow by accepting
two less 255 steps.
This patch also reduces the CPU overhead and actually increases performance
by 1.1% compared to the initial code, while the previous fix costs 3.1%
(measured on x86_64).
The fix needs to be backported to all currently supported stable kernels.
Reported-by: Willem Pinckaers <willem@lekkertech.net>
Cc: "Don A. Bailey" <donb@securitymouse.com>
Cc: stable <stable@vger.kernel.org>
Signed-off-by: Willy Tarreau <w@1wt.eu>
