Pull perf events changes for v3.4 from Ingo Molnar:
- New "hardware based branch profiling" feature both on the kernel and
the tooling side, on CPUs that support it. (modern x86 Intel CPUs
with the 'LBR' hardware feature currently.)
This new feature is basically a sophisticated 'magnifying glass' for
branch execution - something that is pretty difficult to extract from
regular, function histogram centric profiles.
The simplest mode is activated via 'perf record -b', and the result
looks like this in perf report:
$ perf record -b any_call,u -e cycles:u branchy
$ perf report -b --sort=symbol
52.34% [.] main [.] f1
24.04% [.] f1 [.] f3
23.60% [.] f1 [.] f2
0.01% [k] _IO_new_file_xsputn [k] _IO_file_overflow
0.01% [k] _IO_vfprintf_internal [k] _IO_new_file_xsputn
0.01% [k] _IO_vfprintf_internal [k] strchrnul
0.01% [k] __printf [k] _IO_vfprintf_internal
0.01% [k] main [k] __printf
This output shows from/to branch columns and shows the highest
percentage (from,to) jump combinations - i.e. the most likely taken
branches in the system. "branches" can also include function calls
and any other synchronous and asynchronous transitions of the
instruction pointer that are not 'next instruction' - such as system
calls, traps, interrupts, etc.
This feature comes with (hopefully intuitive) flat ascii and TUI
support in perf report.
- Various 'perf annotate' visual improvements for us assembly junkies.
It will now recognize function calls in the TUI and by hitting enter
you can follow the call (recursively) and back, amongst other
improvements.
- Multiple threads/processes recording support in perf record, perf
stat, perf top - which is activated via a comma-list of PIDs:
perf top -p 21483,21485
perf stat -p 21483,21485 -ddd
perf record -p 21483,21485
- Support for per UID views, via the --uid paramter to perf top, perf
report, etc. For example 'perf top --uid mingo' will only show the
tasks that I am running, excluding other users, root, etc.
- Jump label restructurings and improvements - this includes the
factoring out of the (hopefully much clearer) include/linux/static_key.h
generic facility:
struct static_key key = STATIC_KEY_INIT_FALSE;
if (static_key_false(&key))
do unlikely code
else
do likely code
static_key_slow_inc();
The static_key_false() branch will be generated into the code with as
little impact to the likely code path as possible. the
static_key_slow_*() APIs flip the branch via live kernel code patching.
This facility can now be used more widely within the kernel to
micro-optimize hot branches whose likelihood matches the static-key
usage and fast/slow cost patterns.
- SW function tracer improvements: perf support and filtering support.
- Various hardenings of the perf.data ABI, to make older perf.data's
smoother on newer tool versions, to make new features integrate more
smoothly, to support cross-endian recording/analyzing workflows
better, etc.
- Restructuring of the kprobes code, the splitting out of 'optprobes',
and a corner case bugfix.
- Allow the tracing of kernel console output (printk).
- Improvements/fixes to user-space RDPMC support, allowing user-space
self-profiling code to extract PMU counts without performing any
system calls, while playing nice with the kernel side.
- 'perf bench' improvements
- ... and lots of internal restructurings, cleanups and fixes that made
these features possible. And, as usual this list is incomplete as
there were also lots of other improvements
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (120 commits)
perf report: Fix annotate double quit issue in branch view mode
perf report: Remove duplicate annotate choice in branch view mode
perf/x86: Prettify pmu config literals
perf report: Enable TUI in branch view mode
perf report: Auto-detect branch stack sampling mode
perf record: Add HEADER_BRANCH_STACK tag
perf record: Provide default branch stack sampling mode option
perf tools: Make perf able to read files from older ABIs
perf tools: Fix ABI compatibility bug in print_event_desc()
perf tools: Enable reading of perf.data files from different ABI rev
perf: Add ABI reference sizes
perf report: Add support for taken branch sampling
perf record: Add support for sampling taken branch
perf tools: Add code to support PERF_SAMPLE_BRANCH_STACK
x86/kprobes: Split out optprobe related code to kprobes-opt.c
x86/kprobes: Fix a bug which can modify kernel code permanently
x86/kprobes: Fix instruction recovery on optimized path
perf: Add callback to flush branch_stack on context switch
perf: Disable PERF_SAMPLE_BRANCH_* when not supported
perf/x86: Add LBR software filter support for Intel CPUs
Pull RCU changes for v3.4 from Ingo Molnar. The major features of this
series are:
- making RCU more aggressive about entering dyntick-idle mode in order
to improve energy efficiency
- converting a few more call_rcu()s to kfree_rcu()s
- applying a number of rcutree fixes and cleanups to rcutiny
- removing CONFIG_SMP #ifdefs from treercu
- allowing RCU CPU stall times to be set via sysfs
- adding CPU-stall capability to rcutorture
- adding more RCU-abuse diagnostics
- updating documentation
- fixing yet more issues located by the still-ongoing top-to-bottom
inspection of RCU, this time with a special focus on the CPU-hotplug
code path.
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (48 commits)
rcu: Stop spurious warnings from synchronize_sched_expedited
rcu: Hold off RCU_FAST_NO_HZ after timer posted
rcu: Eliminate softirq-mediated RCU_FAST_NO_HZ idle-entry loop
rcu: Add RCU_NONIDLE() for idle-loop RCU read-side critical sections
rcu: Allow nesting of rcu_idle_enter() and rcu_idle_exit()
rcu: Remove redundant check for rcu_head misalignment
PTR_ERR should be called before its argument is cleared.
rcu: Convert WARN_ON_ONCE() in rcu_lock_acquire() to lockdep
rcu: Trace only after NULL-pointer check
rcu: Call out dangers of expedited RCU primitives
rcu: Rework detection of use of RCU by offline CPUs
lockdep: Add CPU-idle/offline warning to lockdep-RCU splat
rcu: No interrupt disabling for rcu_prepare_for_idle()
rcu: Move synchronize_sched_expedited() to rcutree.c
rcu: Check for illegal use of RCU from offlined CPUs
rcu: Update stall-warning documentation
rcu: Add CPU-stall capability to rcutorture
rcu: Make documentation give more realistic rcutorture duration
rcutorture: Permit holding off CPU-hotplug operations during boot
rcu: Print scheduling-clock information on RCU CPU stall-warning messages
Signed-off-by: Cong Wang <amwang@redhat.com>
Merge reason: We are going to queue up a dependent patch.
In some configurations, jiffies may be undefined in
lib/dynamic_queue_limits.c. Adding include of jiffies.h to avoid
this.
Signed-off-by: Tom Herbert <therbert@google.com>
This was done to resolve a conflict in the drivers/base/cpu.c file.
The queue handling in the udev daemon assumes that the events are
ordered.
Before this patch uevent_seqnum is incremented under sequence_lock,
than an event is send uner uevent_sock_mutex. I want to say that code
contained a window between incrementing seqnum and sending an event.
This patch locks uevent_sock_mutex before incrementing uevent_seqnum.
v2: delete sequence_lock, uevent_seqnum is protected by uevent_sock_mutex
v3: unlock the mutex before the goto exit
Thanks for Kay for the comments.
Signed-off-by: Andrew Vagin <avagin@openvz.org>
Tested-By: Kay Sievers <kay.sievers@vrfy.org>
Cc: stable <stable@vger.kernel.org>
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map
them onto including export.h -- or if the file isn't even
using those, then just delete the include. Fix up any implicit
include dependencies that were being masked by module.h along
the way.
kasprintf() (and potentially other functions that I didn't run across so
far) want to evaluate argument lists twice. Caring to do so for the
primary list is obviously their job, but they can't reasonably be
expected to check the format string for instances of %pV, which however
need special handling too: On architectures like x86-64 (as opposed to
e.g. ix86), using the same argument list twice doesn't produce the
expected results, as an internally managed cursor gets updated during
the first run.
Fix the problem by always acting on a copy of the original list when
handling %pV.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
debugobjects is now printing a warning when a fixup for a NOTAVAILABLE
object is run. This causes the selftest to fail like:
ODEBUG: selftest warnings failed 4 != 5
We could just increase the number of warnings that the selftest is
expecting to see because that is actually what has changed. But, it turns
out that fixup_activate() was written with inverted logic and thus a fixup
for a static object returned 1 indicating the object had been fixed, and 0
otherwise. Fix the logic to be correct and update the counts to reflect
that nothing needed fixing for a static object.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Reported-by: Thomas Gleixner <tglx@linutronix.de>
tools/perf/builtin-record.c
tools/perf/builtin-top.c
tools/perf/perf.h
tools/perf/util/top.h
Merge reason: resolve these cherry-picking conflicts.
With bug.h currently living right in linux/kernel.h there
are files that use BUG_ON and friends but are not including
the header explicitly. Fix them up so we can remove the
presence in kernel.h file.
A pending header cleanup will cause this to show up as:
lib/average.c:38: error: 'TAINT_WARN' undeclared (first use in this function)
lib/list_debug.c:24: error: 'TAINT_WARN' undeclared (first use in this function)
and TAINT_WARN comes from include/linux/kernel.h file.
There have been situations where RCU CPU stall warnings were caused by
issues in scheduling-clock timer initialization. To make it easier to
track these down, this commit causes the RCU CPU stall-warning messages
to print out the number of scheduling-clock interrupts taken in the
current grace period for each stalled CPU.
Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org>
The RCU_TRACE kernel parameter has always been intended for debugging,
not for production use. Formalize this by moving RCU_TRACE from
init/Kconfig to lib/Kconfig.debug.
The soft and hard lockup thresholds have changed so the
corresponding Kconfig entries need to be updated accordingly.
Add a reference to watchdog_thresh while at it.
Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp>
Signed-off-by: Don Zickus <dzickus@redhat.com>
Link: http://lkml.kernel.org/r/1328827342-6253-2-git-send-email-dzickus@redhat.com
_parse_integer() does one or two division instructions (which are slow)
per digit parsed to perform the overflow check.
Furthermore, these are particularly expensive examples of division
instruction as the number of clock cycles required to complete them may
go up with the position of the most significant set bit in the dividend:
if (*res > div_u64(ULLONG_MAX - val, base))
which is as maximal as possible.
Worse, on 32-bit arches, more than one of these division instructions
may be required per digit.
So, assuming we don't support a base of more than 16, skip the check if the
top nibble of the result is not set at this point.
[ Changed it to not dereference the pointer all the time - even if the
compiler can and does optimize it away, the code just looks cleaner.
And edited the top nybble test slightly to make the code generated on
x86-64 better in the loop - test against a hoisted constant instead of
shifting and testing the result ]
arch: fix ioport mapping on mips,sh
Kevin Cernekee reported that recent cleanup that replaced pci_iomap with
a generic function failed to take into account the differences in io
port handling on mips and sh architectures.
Rather than revert the changes reintroducing the code duplication, this
patchset fixes this by adding ability for architectures to override
ioport mapping for pci devices.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
* tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost:
sh: use the the PCI channels's io_map_base
mips: use the the PCI controller's io_map_base
lib: add NO_GENERIC_PCI_IOPORT_MAP
'sched-urgent-for-linus' and 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
bugs, x86: Fix printk levels for panic, softlockups and stack dumps
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf top: Fix number of samples displayed
perf tools: Fix strlen() bug in perf_event__synthesize_event_type()
perf tools: Fix broken build by defining _GNU_SOURCE in Makefile
x86/dumpstack: Remove unneeded check in dump_trace()
perf: Fix broken interrupt rate throttling
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
sched/rt: Fix task stack corruption under __ARCH_WANT_INTERRUPTS_ON_CTXSW
sched: Fix ancient race in do_exit()
sched/nohz: Fix nohz cpu idle load balancing state with cpu hotplug
sched/s390: Fix compile error in sched/core.c
sched: Fix rq->nr_uninterruptible update race
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/reboot: Remove VersaLogic Menlow reboot quirk
x86/reboot: Skip DMI checks if reboot set by user
x86: Properly parenthesize cmpxchg() macro arguments
This copy of longlong.h is extremely dated and results in compile
errors on sparc32 when MPILIB is enabled, copy over the more uptodate
implementation from arch/sparc/math/sfp-util_32.h
Reported-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: James Morris <jmorris@namei.org>
Both sparc 32-bit's software divide assembler and MPILIB provide
clz_tab[] with identical contents.
Break it out into a seperate object file and select it when
SPARC32 or MPILIB is set.
mpi_read_from_buffer() return value must not be NULL.
Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com>
Reviewed-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Added missing NULL check after mpi_alloc_limb_space().
Comment explains that existing clients do not call this function
with dsize == 0, which means that 1/0 should not happen.
Buggy client might pass zero nlimbs which is meaningless.
Added check for zero length.
Removed useless 'is_valid' variable in pkcs_1_v1_5_decode_emsa(),
which was inhereted from original code. Client now uses return value
to check for an error.
Added sanity checks for possible wrongly formatted key payload data:
- minimum key payload size
- zero modulus length
- corrected upper key payload boundary.
do_encode_md() and mpi_get_keyid() are not parts of mpi library.
They were used early versions of gnupg and in digsig project,
but they are not used neither here nor there anymore.
Divisor length should not be 0.
Definitely better to return error code than to divide by zero.
MPI_NULL is replaced with normal NULL.
Added missing NULL check after mpi_alloc().
Some architectures need to override the way
IO port mapping is done on PCI devices.
Supply a generic macro that calls
ioport_map, and make it possible for architectures
to override.
rsyslog will display KERN_EMERG messages on a connected
terminal. However, these messages are useless/undecipherable
for a general user.
For example, after a softlockup we get:
Message from syslogd@intel-s3e37-04 at Jan 25 14:18:06 ...
kernel:Stack:
kernel:Call Trace:
kernel:Code: ff ff a8 08 75 25 31 d2 48 8d 86 38 e0 ff ff 48 89
d1 0f 01 c8 0f ae f0 48 8b 86 38 e0 ff ff a8 08 75 08 b1 01 4c 89 e0 0f 01 c9 <e8> ea 69 dd ff 4c 29 e8 48 89 c7 e8 0f bc da ff 49 89 c4 49 89
This happens because the printk levels for these messages are
incorrect. Only an informational message should be displayed on
a terminal.
I modified the printk levels for various messages in the kernel
and tested the output by using the drivers/misc/lkdtm.c kernel
modules (ie, softlockups, panics, hard lockups, etc.) and
confirmed that the console output was still the same and that
the output to the terminals was correct.
For example, in the case of a softlockup we now see the much
more informative:
Message from syslogd@intel-s3e37-04 at Jan 25 10:18:06 ...
BUG: soft lockup - CPU4 stuck for 60s!
instead of the above confusing messages.
AFAICT, the messages no longer have to be KERN_EMERG. In the
most important case of a panic we set console_verbose(). As for
the other less severe cases the correct data is output to the
console and /var/log/messages.
Successfully tested by me using the drivers/misc/lkdtm.c module.
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
Cc: dzickus@redhat.com
Link: http://lkml.kernel.org/r/1327586134-11926-1-git-send-email-prarit@redhat.com
- Stop validating subdirectories now that we only register leaf tables
- Cleanup and improve the duplicate filename check.
* Run the duplicate filename check under the sysctl_lock to guarantee
we never add duplicate names.
* Reduce the duplicate filename check to nearly O(M*N) where M is the
number of entries in tthe table we are registering and N is the
number of entries in the directory before we got there.
- Move the duplicate filename check into it's own function and call
it directtly from __register_sysctl_table
- Kill the config option as the sanity checks are now cheap enough
the config option is unnecessary. The original reason for the config
option was because we had a huge table used to verify the proc filename
to binary sysctl mapping. That table has now evolved into the binary_sysctl
translation layer and is no longer part of the sysctl_check code.
- Tighten up the permission checks. Guarnateeing that files only have read
or write permissions.
- Removed redudant check for parents having a procname as now everything has
a procname.
- Generalize the backtrace logic so that we print a backtrace from
any failure of __register_sysctl_table that was not caused by
a memmory allocation failure. The backtrace allows us to track
down who erroneously registered a sysctl table.
Bechmark before (CONFIG_SYSCTL_CHECK=y):
make-dummies 0 999 -> 12s
rmmod dummy -> 0.08s
Bechmark before (CONFIG_SYSCTL_CHECK=n):
make-dummies 0 999 -> 0.7s
rmmod dummy -> 0.06s
make-dummies 0 99999 -> 1m13s
rmmod dummy -> 0.38s
Benchmark after:
make-dummies 0 999 -> 0.65s
rmmod dummy -> 0.055s
make-dummies 0 9999 -> 1m10s
rmmod dummy -> 0.39s
The sysctl sanity checks now impose no measurable cost.
As part of the removal of get_driver()/put_driver(), this patch
(as1512) gets rid of various useless and unnecessary calls in several
drivers. In some cases it may be desirable to pin the driver by
calling try_module_get(), but that can be done later.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: "David S. Miller" <davem@davemloft.net>
CC: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
CC: Michael Buesch <m@bues.ch>
CC: Joerg Roedel <joerg.roedel@amd.com>
Insert ddebug_exec_queries() in place of ddebug_exec_query(). It
splits the query string on [;\n], and calls ddebug_exec_query() on
each. All queries are processed independent of errors, allowing a
query to fail, for example when a module is not installed. Empty
lines and comments are skipped. Errors are counted, and the last
error seen (negative) or the number of callsites found (0 or positive)
is returned. Return code checks are altered accordingly.
With this, multiple queries can be given in ddebug_query, allowing
more selective enabling of callsites. As a side effect, a set of
commands can be batched in:
cat cmd-file > $DBGMT/dynamic_debug/control
We dont want a ddebug_query syntax error to kill the dynamic debug
facility, so dynamic_debug_init() zeros ddebug_exec_queries()'s return
code after logging the appropriate message, so that ddebug tables are
preserved and $DBGMT/dynamic_debug/control file is created. This
would be appropriate even without accepting multiple queries.
This patch also alters ddebug_change() to return number of callsites
matched (which typically is the same as number of callsites changed).
ddebug_exec_query() also returns the number found, or a negative value
if theres a parse error on the query.
Splitting on [;\n] prevents their use in format-specs, but selecting
callsites on punctuation is brittle anyway, meaningful and selective
substrings are more typical.
Note: splitting queries on ';' before handling trailing #comments
means that a ';' also terminates a comment, and text after the ';' is
treated as another query. This trailing query will almost certainly
result in a parse error and thus have no effect other than the error
message. The double corner case with unexpected results is:
ddebug_query="func foo +p # enable foo ; +p"
Signed-off-by: Jim Cromie <jim.cromie@gmail.com>
Signed-off-by: Jason Baron <jbaron@redhat.com>
Factor pr_info(query) out of ddebug_parse_query, into vpr_info_dq(),
for reuse later. Also change the printed labels: file, func to agree
with the query-spec keywords accepted in the control file. Pass ""
when string is null, to avoid "(null)" output from sprintf. For
format print, use precision to skip last char, assuming its '\n', no
great harm if not, its a debug msg.
trim_prefix(path) skips past the absolute source path root, and
returns the pointer to the relative path from there. It is used to
shorten the displayed path in $DBGMT/dynamic_debug/control via
ddebug_proc_show(), and in ddebug_change() to allow relative filenames
to be used in applied queries. For example:
~# echo file kernel/freezer.c +p > $DBGMT/dynamic_debug/control
kernel/freezer.c:128 [freezer]cancel_freezing p " clean up: %s\012"
trim_prefix(path) insures common prefix before trimming it, so
out-of-tree module paths are shown as full absolute paths.
Current query write buffer is 256 bytes, on stack. In comparison, the
ddebug_query boot-arg is 1024. Allocate the buffer off heap, and
enlarge it to 4096 bytes, big enough for ~100 queries (at 40 bytes
each), and error out if not. This makes it play nicely with large
query sets (to be added later). The buffer should be enough for most
uses, and others should probably be split into subsets.
[jbaron@redhat.com: changed USER_BUF_PAGE from 4095 -> 4096 ]
If a token begins with #, the remainder of query string is a comment,
so drop it. Doing it here avoids '#' in quoted strings.
If _ddebug table is empty (in a CONFIG_DYNAMIC_DEBUG build this
shouldn't happen), then warn (error?) and return early. This skips
empty table scan and parsing of setup-string, including the pr_info
call noting the parse. By inspection, copy return-code handling from
1st ddebug_add_module() callsite to 2nd.
Issue error when a match-spec is given multiple times in a rule.
Previous code kept last one, but was silent about it. Docs imply only
one is allowed by saying match-specs are ANDed together, given that
module M cannot match both A and B. Also error when last_line < 1st_line.
Change describe_flags() to emit '=[pmflt_]+' for current callsite
flags, or just '=_' when they're disabled. Having '=' in output
allows a more selective grep expression; in contrast '-' may appear
in filenames, line-ranges, and format-strings. '=' also has better
mnemonics, saying; "the current setting is equal to <flags>".
This allows grep "=_" <dbgfs>/dynamic_debug/control to see disabled
callsites while avoiding the many occurrences of " = " seen in format
strings.
Enlarge flagsbufs to handle additional flag char, and alter
ddebug_parse_flags() to allow flags=0, so that user can turn off all
debug flags via:
~# echo =_ > <dbgfs>/dynamic_debug/control
Convert 'if (x !=NULL)' checks into 'if (x)'.
Issue keyword/parsing errors even w/o verbose set;
uncover otherwize mysterious non-functionality.
Replace strcpy with strlcpy, and add define for the size constant.
[jbaron@redhat.com: Use DDEBUG_STRING_SIZE for overflow check]
Allow changing dynamic_debug verbosity at run-time, to ease debugging
of ddebug queries as you add them, improving usability.
at boot time: dynamic_debug.verbose=1
at runtime:
root@voyage:~# echo 1 > /sys/module/dynamic_debug/parameters/verbose
Currently any enabled dynamic-debug flag on a pr_debug callsite will
enable printing, even if _DPRINTK_FLAGS_PRINT is off. Checking print
flag directly allows "-p" to disable callsites without fussing with
other flags, so the following disables everything, without altering
flags user may have set:
echo -p > $DBGFS/dynamic_debug/control
Style cleanups.
