commit a3cea9894157c20a5b1ec08b7e0b5f2019740c10 upstream.
Since 4.4 GCC on MIPS no longer recognizes the "h" constraint,
leading to this build failure:
CC lib/mpi/generic_mpih-mul1.o
lib/mpi/generic_mpih-mul1.c: In function 'mpihelp_mul_1':
lib/mpi/generic_mpih-mul1.c:50:3: error: impossible constraint in 'asm'
This patch updates MPI with the latest umul_ppm implementations for MIPS.
Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com>
Cc: Linux-MIPS <linux-mips@linux-mips.org>
Cc: Dmitry Kasatkin <dmitry.kasatkin@intel.com>
Patchwork: https://patchwork.linux-mips.org/patch/4612/
Cc: Shuah Khan <shuah.khan@hp.com>
commit eedce141cd2dad8d0cefc5468ef41898949a7031 upstream.
The genalloc code uses the bitmap API from include/linux/bitmap.h and
lib/bitmap.c, which is based on long values. Both bitmap_set from
lib/bitmap.c and bitmap_set_ll, which is the lockless version from
genalloc.c, use BITMAP_LAST_WORD_MASK to set the first bits in a long in
the bitmap.
That one uses (1 << bits) - 1, 0b111, if you are setting the first three
bits. This means that the API counts from the least significant bits
(LSB from now on) to the MSB. The LSB in the first long is bit 0, then.
The same works for the lookup functions.
The genalloc code uses longs for the bitmap, as it should. In
include/linux/genalloc.h, struct gen_pool_chunk has unsigned long
bits[0] as its last member. When allocating the struct, genalloc should
reserve enough space for the bitmap. This should be a proper number of
longs that can fit the amount of bits in the bitmap.
However, genalloc allocates an integer number of bytes that fit the
amount of bits, but may not be an integer amount of longs. 9 bytes, for
example, could be allocated for 70 bits.
This is a problem in itself if the Least Significat Bit in a long is in
the byte with the largest address, which happens in Big Endian machines.
This means genalloc is not allocating the byte in which it will try to
set or check for a bit.
This may end up in memory corruption, where genalloc will try to set the
bits it has not allocated. In fact, genalloc may not set these bits
because it may find them already set, because they were not zeroed since
they were not allocated. And that's what causes a BUG when
gen_pool_destroy is called and check for any set bits.
What really happens is that genalloc uses kmalloc_node with __GFP_ZERO
on gen_pool_add_virt. With SLAB and SLUB, this means the whole slab
will be cleared, not only the requested bytes. Since struct
gen_pool_chunk has a size that is a multiple of 8, and slab sizes are
multiples of 8, we get lucky and allocate and clear the right amount of
bytes.
Hower, this is not the case with SLOB or with older code that did memset
after allocating instead of using __GFP_ZERO.
So, a simple module as this (running 3.6.0), will cause a crash when
rmmod'ed.
[root@phantom-lp2 foo]# cat foo.c
#include <linux/kernel.h>
#include <linux/module.h>
#include <linux/init.h>
#include <linux/genalloc.h>
MODULE_LICENSE("GPL");
MODULE_VERSION("0.1");
static struct gen_pool *foo_pool;
static __init int foo_init(void)
int ret;
foo_pool = gen_pool_create(10, -1);
if (!foo_pool)
return -ENOMEM;
ret = gen_pool_add(foo_pool, 0xa0000000, 32 << 10, -1);
if (ret) {
gen_pool_destroy(foo_pool);
return ret;
return 0;
static __exit void foo_exit(void)
module_init(foo_init);
module_exit(foo_exit);
[root@phantom-lp2 foo]# zcat /proc/config.gz | grep SLOB
CONFIG_SLOB=y
[root@phantom-lp2 foo]# insmod ./foo.ko
[root@phantom-lp2 foo]# rmmod foo
kernel BUG at lib/genalloc.c:243!
cpu 0x4: Vector: 700 (Program Check) at [c0000000bb0e7960]
pc: c0000000003cb50c: .gen_pool_destroy+0xac/0x110
lr: c0000000003cb4fc: .gen_pool_destroy+0x9c/0x110
sp: c0000000bb0e7be0
msr: 8000000000029032
current = 0xc0000000bb0e0000
paca = 0xc000000006d30e00 softe: 0 irq_happened: 0x01
pid = 13044, comm = rmmod
[c0000000bb0e7ca0] d000000004b00020 .foo_exit+0x20/0x38 [foo]
[c0000000bb0e7d20] c0000000000dff98 .SyS_delete_module+0x1a8/0x290
[c0000000bb0e7e30] c0000000000097d4 syscall_exit+0x0/0x94
--- Exception: c00 (System Call) at 000000800753d1a0
SP (fffd0b0e640) is in userspace
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@linux.vnet.ibm.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Benjamin Gaignard <benjamin.gaignard@stericsson.com>
commit e96875677fb2b7cb739c5d7769824dff7260d31d upstream.
Account for all properties when a and/or b are 0:
gcd(0, 0) = 0
gcd(a, 0) = a
gcd(0, b) = b
Fixes no known problems in current kernels.
Signed-off-by: Davidlohr Bueso <dave@gnu.org>
When racing with CPU hotplug, percpu_counter_sum() can return negative
values for the number of observed events.
This confuses fprop_new_period(), which uses unsigned type and as a
result number of events is set to big *positive* number. From that
moment on, things go pear shaped and can result e.g. in division by
zero as denominator is later truncated to 32-bits.
This bug causes a divide-by-zero oops in bdi_dirty_limit() in Borislav's
3.6.0-rc6 based kernel.
Fix the issue by using a signed type in fprop_new_period(). That makes
us bail out from the function without doing anything (mistakenly)
thinking there are no events to age. That makes aging somewhat
inaccurate but getting accurate data would be rather hard.
Reported-by: Borislav Petkov <bp@amd64.org>
Reported-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: <stable@vger.kernel.org>
When pkcs_1_v1_5_decode_emsa() returns without error and hash sizes do
not match, hash comparision is not done and digsig_verify_rsa() returns
no error. This is a bug and this patch fixes it.
The bug was introduced in v3.3 by commit b35e286a640f ("lib/digsig:
pkcs_1_v1_5_decode_emsa cleanup").
Cc: stable@vger.kernel.org
Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com>
Pull second vfs pile from Al Viro:
"The stuff in there: fsfreeze deadlock fixes by Jan (essentially, the
deadlock reproduced by xfstests 068), symlink and hardlink restriction
patches, plus assorted cleanups and fixes.
Note that another fsfreeze deadlock (emergency thaw one) is *not*
dealt with - the series by Fernando conflicts a lot with Jan's, breaks
userland ABI (FIFREEZE semantics gets changed) and trades the deadlock
for massive vfsmount leak; this is going to be handled next cycle.
There probably will be another pull request, but that stuff won't be
in it."
Fix up trivial conflicts due to unrelated changes next to each other in
drivers/{staging/gdm72xx/usb_boot.c, usb/gadget/storage_common.c}
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (54 commits)
delousing target_core_file a bit
Documentation: Correct s_umount state for freeze_fs/unfreeze_fs
fs: Remove old freezing mechanism
ext2: Implement freezing
btrfs: Convert to new freezing mechanism
nilfs2: Convert to new freezing mechanism
ntfs: Convert to new freezing mechanism
fuse: Convert to new freezing mechanism
gfs2: Convert to new freezing mechanism
ocfs2: Convert to new freezing mechanism
xfs: Convert to new freezing code
ext4: Convert to new freezing mechanism
fs: Protect write paths by sb_start_write - sb_end_write
fs: Skip atime update on frozen filesystem
fs: Add freezing handling to mnt_want_write() / mnt_drop_write()
fs: Improve filesystem freezing handling
switch the protection of percpu_counter list to spinlock
nfsd: Push mnt_want_write() outside of i_mutex
btrfs: Push mnt_want_write() outside of i_mutex
fat: Push mnt_want_write() outside of i_mutex
... making percpu_counter_destroy() non-blocking
git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux
Pull writeback updates from Wu Fengguang:
"Use time based periods to age the writeback proportions, which can
adapt equally well to fast/slow devices."
Fix up trivial conflict in comment in fs/sync.c
* tag 'writeback-proportions' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux:
writeback: Fix some comment errors
block: Convert BDI proportion calculations to flexible proportions
lib: Fix possible deadlock in flexible proportion code
lib: Proportions with flexible period
Merge Andrew's first set of patches:
"Non-MM patches:
- lots of misc bits
- tree-wide have_clk() cleanups
- quite a lot of printk tweaks. I draw your attention to "printk:
convert the format for KERN_<LEVEL> to a 2 byte pattern" which
looks a bit scary. But afaict it's solid.
- backlight updates
- lib/ feature work (notably the addition and use of memweight())
- checkpatch updates
- rtc updates
- nilfs updates
- fatfs updates (partial, still waiting for acks)
- kdump, proc, fork, IPC, sysctl, taskstats, pps, etc
- new fault-injection feature work"
* Merge emailed patches from Andrew Morton <akpm@linux-foundation.org>: (128 commits)
drivers/misc/lkdtm.c: fix missing allocation failure check
lib/scatterlist: do not re-write gfp_flags in __sg_alloc_table()
fault-injection: add tool to run command with failslab or fail_page_alloc
fault-injection: add selftests for cpu and memory hotplug
powerpc: pSeries reconfig notifier error injection module
memory: memory notifier error injection module
PM: PM notifier error injection module
cpu: rewrite cpu-notifier-error-inject module
fault-injection: notifier error injection
c/r: fcntl: add F_GETOWNER_UIDS option
resource: make sure requested range is included in the root range
include/linux/aio.h: cpp->C conversions
fs: cachefiles: add support for large files in filesystem caching
pps: return PTR_ERR on error in device_create
taskstats: check nla_reserve() return
sysctl: suppress kmemleak messages
ipc: use Kconfig options for __ARCH_WANT_[COMPAT_]IPC_PARSE_VERSION
ipc: compat: use signed size_t types for msgsnd and msgrcv
ipc: allow compat IPC version field parsing if !ARCH_WANT_OLD_COMPAT_IPC
ipc: add COMPAT_SHMLBA support
We are seeing a lot of sg_alloc_table allocation failures using the new
drm prime infrastructure. We isolated the cause to code in
__sg_alloc_table that was re-writing the gfp_flags.
There is a comment in the code that suggest that there is an assumption
about the allocation coming from a memory pool. This was likely true
when sg lists were primarily used for disk I/O.
Signed-off-by: Mandeep Singh Baines <msb@chromium.org>
Cc: Cong Wang <amwang@redhat.com>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Rob Clark <rob.clark@linaro.org>
Cc: Sumit Semwal <sumit.semwal@linaro.org>
Cc: Inki Dae <inki.dae@samsung.com>
Cc: Dave Airlie <airlied@redhat.com>
Cc: Sonny Rao <sonnyrao@chromium.org>
Cc: Olof Johansson <olofj@chromium.org>
This provides the ability to inject artifical errors to pSeries reconfig
notifier chain callbacks. It is controlled through debugfs interface
under /sys/kernel/debug/notifier-error-inject/pSeries-reconfig
If the notifier call chain should be failed with some events
notified, write the error code to "actions/<notifier event>/error".
Cc: Pavel Machek <pavel@ucw.cz>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Greg KH <greg@kroah.com>
Cc: Michael Ellerman <michael@ellerman.id.au>
Cc: Dave Jones <davej@redhat.com>
This provides the ability to inject artifical errors to memory hotplug
under /sys/kernel/debug/notifier-error-inject/memory
If the notifier call chain should be failed with some events notified,
Example: Inject memory hotplug offline error (-12 == -ENOMEM)
# cd /sys/kernel/debug/notifier-error-inject/memory
# echo -12 > actions/MEM_GOING_OFFLINE/error
# echo offline > /sys/devices/system/memory/memoryXXX/state
bash: echo: write error: Cannot allocate memory
This provides the ability to inject artifical errors to PM notifier chain
callbacks. It is controlled through debugfs interface under
/sys/kernel/debug/notifier-error-inject/pm
Each of the files in "error" directory represents an event which can be
failed and contains the error code. If the notifier call chain should be
failed with some events notified, write the error code to the files.
Example: Inject PM suspend error (-12 = -ENOMEM)
# cd /sys/kernel/debug/notifier-error-inject/pm
# echo -12 > actions/PM_SUSPEND_PREPARE/error
# echo mem > /sys/power/state
Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl>
Rewrite existing cpu-notifier-error-inject module to use debugfs based new
framework.
This change removes cpu_up_prepare_error and cpu_down_prepare_error module
parameters which were used to specify error code to be injected. We could
keep these module parameters for backward compatibility by module_param_cb
but it seems overkill for this module.
This provides the ability to inject artifical errors to CPU notifier chain
/sys/kernel/debug/notifier-error-inject/cpu
Example1: inject CPU offline error (-1 == -EPERM)
# cd /sys/kernel/debug/notifier-error-inject/cpu
# echo -1 > actions/CPU_DOWN_PREPARE/error
# echo 0 > /sys/devices/system/cpu/cpu1/online
bash: echo: write error: Operation not permitted
Example2: inject CPU online error (-2 == -ENOENT)
# echo -2 > actions/CPU_UP_PREPARE/error
# echo 1 > /sys/devices/system/cpu/cpu1/online
bash: echo: write error: No such file or directory
This patchset provides kernel modules that can be used to test the error
handling of notifier call chain failures by injecting artifical errors to
the following notifier chain callbacks.
* CPU notifier
* PM notifier
* memory hotplug notifier
* powerpc pSeries reconfig notifier
Example: Inject CPU offline error (-1 == -EPERM)
The patchset also adds cpu and memory hotplug tests to
tools/testing/selftests These tests first do simple online and offline
test and then do fault injection tests if notifier error injection
module is available.
This patch:
The notifier error injection provides the ability to inject artifical
errors to specified notifier chain callbacks. It is useful to test the
error handling of notifier call chain failures.
This adds common basic functions to define which type of events can be
fail and to initialize the debugfs interface to control what error code
should be returned and which event should be failed.
Variables t4, t5, t6 and t7 are only used when CRC_LE_BITS != 32. Fix
the following compilation warnings:
lib/crc32.c: In function 'crc32_body':
lib/crc32.c:77:55: warning: unused variable 't7'
lib/crc32.c:77:41: warning: unused variable 't6'
lib/crc32.c:77:27: warning: unused variable 't5'
lib/crc32.c:77:13: warning: unused variable 't4'
Signed-off-by: Thiago Rafael Becker <trbecker@trbecker.org>
Cc: "Darrick J. Wong" <djwong@us.ibm.com>
Cc: Bob Pearson <rpearson@systemfabricworks.com>
If there are two spinlocks embedded in a structure that kallsyms knows
about and one of the spinlocks locks up we will print the name of the
containing structure instead of the address of the lock. This is quite
bad, so let's use %pS instead of %ps so we get an offset in addition to
the symbol so we can determine which particular lock is having problems.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Introduce CONFIG_ARCH_HAS_ATOMIC64_DEC_IF_POSITIVE and use this instead
of the multitude of #if defined() checks in atomic64_test.c
memweight() is the function that counts the total number of bits set in
memory area. Unlike bitmap_weight(), memweight() takes pointer and size
in bytes to specify a memory area which does not need to be aligned to
long-word boundary.
[akpm@linux-foundation.org: rename `w' to `ret']
Cc: Anders Larsen <al@alarsen.net>
Cc: Alasdair Kergon <agk@redhat.com>
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Andreas Dilger <adilger.kernel@dilger.ca>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Tony Luck <tony.luck@gmail.com>
There are many places in the kernel where the drivers print small buffers
as a hex string. This patch adds a support of the variable width buffer
to print it as a hex string with a delimiter. The idea came from Pavel
Roskin here: http://www.digipedia.pl/usenet/thread/18835/17449/
Sample output of
pr_info("buf[%d:%d] %*phC\n", from, len, len, &buf[from]);
could be look like this:
[ 0.726130] buf[51:8] e8:16:b6:ef:e3:74:45:6e
[ 0.750736] buf[59:15] 31:81:b8:3f:35:49:06:ae:df:32:06:05:4a:af:55
[ 0.757602] buf[17:5] ac:16:d5:2c:ef
Cc: Joe Perches <joe@perches.com>
When using ALT+SysRq+Q all the pointers are replaced with "pK-error" like
this:
[23153.208033] .base: pK-error
with echo h > /proc/sysrq-trigger it works:
[23107.776363] .base: ffff88023e60d540
The intent behind this behavior was to return "pK-error" in cases where
the %pK format specifier was used in interrupt context, because the
CAP_SYSLOG check wouldn't be meaningful. Clearly this should only apply
when kptr_restrict is actually enabled though.
Reported-by: Stevie Trujillo <stevie.trujillo@gmail.com>
Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com>
when adding printk formats
Cc: Randy Dunlap <rdunlap@xenotime.net>
Bluetooth uses mostly LE byte order which is reversed for visual
interpretation. Currently in Bluetooth in use unsafe batostr function.
This is a slightly modified version of Joe's patch (sent Sat, Dec 4,
2010).
Signed-off-by: Andrei Emeltchenko <andrei.emeltchenko@intel.com>
Cc: Marcel Holtmann <marcel@holtmann.org>
Pull MIPS updates from Ralf Baechle:
"More hardware support across the field including a bunch of device
drivers. The highlight however really are further steps towards
device tree.
This has been sitting in -next for ages. All MIPS _defconfigs have
been tested to boot or where I don't have hardware available, to at
least build fine."
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (77 commits)
MIPS: Loongson 1B: Add defconfig
MIPS: Loongson 1B: Add board support
MIPS: Netlogic: early console fix
MIPS: Netlogic: Fix indentation of smpboot.S
MIPS: Netlogic: remove cpu_has_dc_aliases define for XLP
MIPS: Netlogic: Remove unused pcibios_fixups
MIPS: Netlogic: Add XLP SoC devices in FDT
MIPS: Netlogic: Add IRQ mappings for more devices
MIPS: Netlogic: USB support for XLP
MIPS: Netlogic: XLP PCIe controller support.
MIPS: Netlogic: Platform changes for XLR/XLS I2C
MIPS: Netlogic: Platform NAND/NOR flash support
MIPS: Netlogic: Platform changes for XLS USB
MIPS: Netlogic: Remove NETLOGIC_ prefix
MIPS: Netlogic: SMP wakeup code update
MIPS: Netlogic: Update comments in smpboot.S
MIPS: BCM63XX: Add 96328avng reference board
MIPS: Expose PCIe drivers for MIPS
MIPS: BCM63XX: Add PCIe Support for BCM6328
MIPS: BCM63XX: Move the PCI initialization into its own function
git://git.linaro.org/people/mszyprowski/linux-dma-mapping
Pull DMA-mapping updates from Marek Szyprowski:
"Those patches are continuation of my earlier work.
They contains extensions to DMA-mapping framework to remove limitation
of the current ARM implementation (like limited total size of DMA
coherent/write combine buffers), improve performance of buffer sharing
between devices (attributes to skip cpu cache operations or creation
of additional kernel mapping for some specific use cases) as well as
some unification of the common code for dma_mmap_attrs() and
dma_mmap_coherent() functions. All extensions have been implemented
and tested for ARM architecture."
* 'for-linus-for-3.6-rc1' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping:
ARM: dma-mapping: add support for DMA_ATTR_SKIP_CPU_SYNC attribute
common: DMA-mapping: add DMA_ATTR_SKIP_CPU_SYNC attribute
ARM: dma-mapping: add support for dma_get_sgtable()
common: dma-mapping: introduce dma_get_sgtable() function
ARM: dma-mapping: add support for DMA_ATTR_NO_KERNEL_MAPPING attribute
common: DMA-mapping: add DMA_ATTR_NO_KERNEL_MAPPING attribute
common: dma-mapping: add support for generic dma_mmap_* calls
ARM: dma-mapping: fix error path for memory allocation failure
ARM: dma-mapping: add more sanity checks in arm_dma_mmap()
ARM: dma-mapping: remove custom consistent dma region
mm: vmalloc: use const void * for caller argument
scatterlist: add sg_alloc_table_from_pages function
This patch adds a new constructor for an sg table. The table is constructed
from an array of struct pages. All contiguous chunks of the pages are merged
into a single sg nodes. A user may provide an offset and a size of a buffer if
the buffer is not page-aligned.
The function is dedicated for DMABUF exporters which often perform conversion
from an page array to a scatterlist. Moreover the scatterlist should be
squashed in order to save memory and to speed-up the process of DMA mapping
using dma_map_sg.
The code is based on the patch 'v4l: vb2-dma-contig: add support for
scatterlist in userptr mode' and hints from Laurent Pinchart.
Signed-off-by: Tomasz Stanislawski <t.stanislaws@samsung.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
CC: Andrew Morton <akpm@linux-foundation.org>
Pull trivial tree from Jiri Kosina:
"Trivial updates all over the place as usual."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (29 commits)
Fix typo in include/linux/clk.h .
pci: hotplug: Fix typo in pci
iommu: Fix typo in iommu
video: Fix typo in drivers/video
Documentation: Add newline at end-of-file to files lacking one
arm,unicore32: Remove obsolete "select MISC_DEVICES"
module.c: spelling s/postition/position/g
cpufreq: Fix typo in cpufreq driver
trivial: typo in comment in mksysmap
mach-omap2: Fix typo in debug message and comment
scsi: aha152x: Fix sparse warning and make printing pointer address more portable.
Change email address for Steve Glendinning
Btrfs: fix typo in convert_extent_bit
via: Remove bogus if check
netprio_cgroup.c: fix comment typo
backlight: fix memory leak on obscure error path
Documentation: asus-laptop.txt references an obsolete Kconfig item
Documentation: ManagementStyle: fixed typo
mm/vmscan: cleanup comment error in balance_pgdat
mm: cleanup on the comments of zone_reclaim_stat
Pull networking changes from David S Miller:
1) Remove the ipv4 routing cache. Now lookups go directly into the FIB
trie and use prebuilt routes cached there.
No more garbage collection, no more rDOS attacks on the routing
cache. Instead we now get predictable and consistent performance,
no matter what the pattern of traffic we service.
This has been almost 2 years in the making. Special thanks to
Julian Anastasov, Eric Dumazet, Steffen Klassert, and others who
have helped along the way.
I'm sure that with a change of this magnitude there will be some
kind of fallout, but such things ought the be simple to fix at this
point. Luckily I'm not European so I'll be around all of August to
fix things :-)
The major stages of this work here are each fronted by a forced
merge commit whose commit message contains a top-level description
of the motivations and implementation issues.
2) Pre-demux of established ipv4 TCP sockets, saves a route demux on
input.
3) TCP SYN/ACK performance tweaks from Eric Dumazet.
4) Add namespace support for netfilter L4 conntrack helpers, from Gao
Feng.
5) Add config mechanism for Energy Efficient Ethernet to ethtool, from
Yuval Mintz.
6) Remove quadratic behavior from /proc/net/unix, from Eric Dumazet.
7) Support for connection tracker helpers in userspace, from Pablo
Neira Ayuso.
8) Allow userspace driven TX load balancing functions in TEAM driver,
from Jiri Pirko.
9) Kill off NLMSG_PUT and RTA_PUT macros, more gross stuff with
embedded gotos.
10) TCP Small Queues, essentially minimize the amount of TCP data queued
up in the packet scheduler layer. Whereas the existing BQL (Byte
Queue Limits) limits the pkt_sched --> netdevice queuing levels,
this controls the TCP --> pkt_sched queueing levels.
From Eric Dumazet.
11) Reduce the number of get_page/put_page ops done on SKB fragments,
from Alexander Duyck.
12) Implement protection against blind resets in TCP (RFC 5961), from
Eric Dumazet.
13) Support the client side of TCP Fast Open, basically the ability to
send data in the SYN exchange, from Yuchung Cheng.
Basically, the sender queues up data with a sendmsg() call using
MSG_FASTOPEN, then they do the connect() which emits the queued up
fastopen data.
14) Avoid all the problems we get into in TCP when timers or PMTU events
hit a locked socket. The TCP Small Queues changes added a
tcp_release_cb() that allows us to queue work up to the
release_sock() caller, and that's what we use here too. From Eric
Dumazet.
15) Zero copy on TX support for TUN driver, from Michael S. Tsirkin.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1870 commits)
genetlink: define lockdep_genl_is_held() when CONFIG_LOCKDEP
r8169: revert "add byte queue limit support".
ipv4: Change rt->rt_iif encoding.
net: Make skb->skb_iif always track skb->dev
ipv4: Prepare for change of rt->rt_iif encoding.
ipv4: Remove all RTCF_DIRECTSRC handliing.
ipv4: Really ignore ICMP address requests/replies.
decnet: Don't set RTCF_DIRECTSRC.
net/ipv4/ip_vti.c: Fix __rcu warnings detected by sparse.
ipv4: Remove redundant assignment
rds: set correct msg_namelen
openvswitch: potential NULL deref in sample()
tcp: dont drop MTU reduction indications
bnx2x: Add new 57840 device IDs
tcp: avoid oops in tcp_metrics and reset tcpm_stamp
niu: Change niu_rbr_fill() to use unlikely() to check niu_rbr_add_page() return value
niu: Fix to check for dma mapping errors.
net: Fix references to out-of-scope variables in put_cmsg_compat()
net: ethernet: davinci_emac: add pm_runtime support
net: ethernet: davinci_emac: Remove unnecessary #include
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux
Pull misc Itanium fixes from Tony Luck.
* tag 'please-pull-misc-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux:
debug: Do not permit CONFIG_DEBUG_STACK_USAGE=y on IA64 or PARISC
[IA64] Port OOM changes to ia64_do_page_fault
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"Nothing groundbreaking for this kernel, just cleanups and fixes, and a
couple of Smack enhancements."
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (21 commits)
Smack: Maintainer Record
Smack: don't show empty rules when /smack/load or /smack/load2 is read
Smack: user access check bounds
Smack: onlycap limits on CAP_MAC_ADMIN
Smack: fix smack_new_inode bogosities
ima: audit is compiled only when enabled
ima: ima_initialized is set only if successful
ima: add policy for pseudo fs
ima: remove unused cleanup functions
ima: free securityfs violations file
ima: use full pathnames in measurement list
security: Fix nommu build.
samples: seccomp: add .gitignore for untracked executables
tpm: check the chip reference before using it
TPM: fix memleak when register hardware fails
TPM: chip disabled state erronously being reported as error
MAINTAINERS: TPM maintainers' contacts update
Merge branches 'next-queue' and 'next' into next
Remove unused code from MPI library
Revert "crypto: GnuPG based MPI lib - additional sources (part 4)"
libfdt is part of the device tree support in scripts/dtc/libfdt. For
some platforms that use the Device Tree, we want to be able to edit
the flattened device tree form.
We don't want to burden kernel builds that do not require it, so we
gate compilation of libfdt files with CONFIG_LIBFDT. So if it is
needed, you need to do this in your Kconfig:
select LIBFDT
And in the Makefile of the code using libfdt something like:
ccflags-y := -I$(src)/../../../scripts/dtc/libfdt
Signed-off-by: David Daney <david.daney@cavium.com>
Cc: linux-mips@linux-mips.org
Cc: devicetree-discuss@lists.ozlabs.org
Cc: Grant Likely <grant.likely@secretlab.ca>
Acked-by: Rob Herring <rob.herring@calxeda.com>
Pull RCU changes from Ingo Molnar:
"Quoting from Paul, the major features of this series are:
1. Preventing latency spikes of more than 200 microseconds for
kernels built with NR_CPUS=4096, which is reportedly becoming the
default for some distros. This is a first step, as it does not
help with systems that actually -have- 4096 CPUs (work on this case
is in progress, but is not yet ready for mainline).
This category also includes improving concurrency of rcu_barrier(),
placed here due to conflicts. Posted to LKML at:
https://lkml.org/lkml/2012/6/22/381
Note that patches 18-22 of that series have been defered to 3.7, as
they have not yet proven themselves to be mainline-ready (and yes,
these are the ones intended to get rid of RCU's latency spikes for
systems that actually have 4096 CPUs).
2. Updates to documentation and rcutorture fixes, the latter category
including improvements to rcu_barrier() testing. Posted to LKML at
http://lkml.indiana.edu/hypermail/linux/kernel/1206.1/04094.html.
3. Miscellaneous fixes posted to LKML at:
https://lkml.org/lkml/2012/6/22/500
with the exception of the last commit, which was posted here:
http://www.gossamer-threads.com/lists/linux/kernel/1561830
4. RCU_FAST_NO_HZ fixes and improvements. Posted to LKML at:
http://lkml.indiana.edu/hypermail/linux/kernel/1206.1/00006.html
http://www.gossamer-threads.com/lists/linux/kernel/1561833
The first four patches of the first series went into 3.5 to fix a
regression.
5. Code-style fixes. These were posted to LKML at
http://lkml.indiana.edu/hypermail/linux/kernel/1205.2/01180.html
http://lkml.indiana.edu/hypermail/linux/kernel/1205.2/01181.html"
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (48 commits)
rcu: Fix broken strings in RCU's source code.
rcu: Fix code-style issues involving "else"
rcu: Introduce check for callback list/count mismatch
rcu: Make RCU_FAST_NO_HZ respect nohz= boot parameter
rcu: Fix qlen_lazy breakage
rcu: Round FAST_NO_HZ lazy timeout to nearest second
rcu: The rcu_needs_cpu() function is not a quiescent state
rcu: Dump only the current CPU's buffers for idle-entry/exit warnings
rcu: Add check for CPUs going offline with callbacks queued
rcu: Disable preemption in rcu_blocking_is_gp()
rcu: Prevent uninitialized string in RCU CPU stall info
rcu: Fix rcu_is_cpu_idle() #ifdef in TINY_RCU
rcu: Split RCU core processing out of __call_rcu()
rcu: Prevent __call_rcu() from invoking RCU core on offline CPUs
rcu: Make __call_rcu() handle invocation from idle
rcu: Remove function versions of __kfree_rcu and __is_kfree_rcu_offset
rcu: Consolidate tree/tiny __rcu_read_{,un}lock() implementations
rcu: Remove return value from rcu_assign_pointer()
key: Remove extraneous parentheses from rcu_assign_keypointer()
rcu: Remove return value from RCU_INIT_POINTER()
drivers/net/ethernet/intel/ixgbevf/ixgbevf_main.c
The stack_not_used() function in <linux/sched.h> assumes that stacks
grow downwards. This is not true on IA64 or PARISC, so this function
would walk off in the wrong direction and into the weeds.
Found on IA64 because of a compilation failure with recursive dependencies
on IA64_TASKSIZE and IA64_THREAD_INFO_SIZE.
Fixing the code is possible, but should be combined with other
infrastructure additions to set up the "canary" at the end of the stack.
Reported-by: Fengguang Wu <fengguang.wu@intel.com> (failed allmodconfig build)
Signed-off-by: Tony Luck <tony.luck@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull IOMMU fixes from Joerg Roedel:
"The patches fix several issues in the AMD IOMMU driver, the NVidia
SMMU driver, and the DMA debug code.
The most important fix for the AMD IOMMU solves a problem with SR-IOV
devices where virtual functions did not work with IOMMU enabled. The
NVidia SMMU patch fixes a possible sleep while spin-lock situation
(queued the small fix for v3.5, a better but more intrusive fix is
coming for v3.6). The DMA debug patches fix a possible data
corruption issue due to bool vs u32 usage."
* tag 'iommu-fixes-v3.5-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu:
iommu/amd: fix type bug in flush code
dma-debug: debugfs_create_bool() takes a u32 pointer
iommu/tegra: smmu: Fix unsleepable memory allocation
iommu/amd: Initialize dma_ops for hotplug and sriov devices
iommu/amd: Fix missing iommu_shutdown initialization in passthrough mode
Although the C language allows you to break strings across lines, doing
this makes it hard for people to find the Linux kernel code corresponding
to a given console message. This commit therefore fixes broken strings
throughout RCU's source code.
Suggested-by: Josh Triplett <josh@joshtriplett.org>
Suggested-by: Ingo Molnar <mingo@kernel.org>
Even though it has "bool" in the name, you have pass a u32 pointer to
debugfs_create_bool(). Otherwise you get memory corruption in
write_file_bool(). Fortunately in this case the corruption happens in
an alignment hole between variables so it doesn't cause any problems.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
This patch adds the following structure:
struct netlink_kernel_cfg {
unsigned int groups;
void (*input)(struct sk_buff *skb);
struct mutex *cb_mutex;
That can be passed to netlink_kernel_create to set optional configurations
for netlink kernel sockets.
I've populated this structure by looking for NULL and zero parameters at the
existing code. The remaining parameters that always need to be set are still
left in the original interface.
That includes optional parameters for the netlink socket creation. This allows
easy extensibility of this interface in the future.
This patch also adapts all callers to use this new interface.
include/linux/mmzone.h
Synced with Linus' tree so that trivial patch can be applied
on top of up-to-date code properly.
Cc: Jiri Kosina <trivial@kernel.org>
After enabling CONFIG_FAILSLAB I noticed random32 in profiles even if slub
fault injection wasn't enabled at runtime.
should_fail forces a comparison against random32() even if probability is
0:
if (attr->probability <= random32() % 100)
return false;
Add a check up front for probability == 0 and avoid all of the more
complicated checks.
Acked-by: Akinobu Mita <akinobu.mita@gmail.com>
Pull core updates (RCU and locking) from Ingo Molnar:
"Most of the diffstat comes from the RCU slow boot regression fixes,
but there's also a debuggability improvements/fixes."
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
memblock: Document memblock_is_region_{memory,reserved}()
rcu: Precompute RCU_FAST_NO_HZ timer offsets
rcu: Move RCU_FAST_NO_HZ per-CPU variables to rcu_dynticks structure
rcu: Update RCU_FAST_NO_HZ tracing for lazy callbacks
rcu: RCU_FAST_NO_HZ detection of callback adoption
spinlock: Indicate that a lockup is only suspected
kdump: Execute kmsg_dump(KMSG_DUMP_PANIC) after smp_send_stop()
panic: Make panic_on_oops configurable
When percpu counter function in fprop_new_period() is interrupted by an
interrupt while holding counter lock, it can cause deadlock when the
interrupt wants to take the lock as well. Fix the problem by disabling
interrupts when calling percpu counter functions.
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
Implement code computing proportions of events of different type (like code in
lib/proportions.c) but allowing periods to have different lengths. This allows
us to have aging periods of fixed wallclock time which gives better proportion
estimates given the hugely varying throughput of different devices - previous
measuring of aging period by number of events has the problem that a reasonable
period length for a system with low-end USB stick is not a reasonable period
length for a system with high-end storage array resulting either in too slow
proportion updates or too fluctuating proportion updates.
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Storing NULL values in the btree is illegal and can lead to memory
corruption and possible other fun as well. Catch it on insert, instead
of waiting for the inevitable.
Signed-off-by: Joern Engel <joern@logfs.org>
Signed-off-by: Roland Dreier <roland@purestorage.com>
The memory the parameter __key points to is used as an iterator in
btree_get_prev(), so if we save off a bkey() pointer in retry_key and
then assign that to __key, we'll end up corrupting the btree internals
when we do eg
longcpy(__key, bkey(geo, node, i), geo->keylen);
to return the key value. What we should do instead is use longcpy() to
copy the key value that retry_key points to __key.
This can cause a btree to get corrupted by seemingly read-only
operations such as btree_for_each_safe.
[akpm@linux-foundation.org: avoid the double longcpy()]
Acked-by: Joern Engel <joern@logfs.org>
Pull two md fixes from NeilBrown:
"One sparse-warning fix, one bugfix for 3.4-stable"
* tag 'md-3.5-fixes' of git://neil.brown.name/md:
md: raid1/raid10: fix problem with merge_bvec_fn
lib/raid6: fix sparse warnings in recovery functions
On an over-committed KVM system we got a:
"BUG: spinlock lockup on CPU#2, swapper/2/0"
message on the heavily contended virtio blk spinlock.
While we might want to reconsider the locking of virtio-blk
(lock is held while switching to the host) this patch tries to
make the message clearer: the lockup is only suspected.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Michael S. Tsirkin <mst@redhat.com>
Link: http://lkml.kernel.org/r/1338283124-7063-1-git-send-email-borntraeger@de.ibm.com
Merge two debugging patchlets that were waiting for
preparatory commits to hit upstream.
