path: root/lib
2018-09-15debugobjects: Make stack check warning more informativeJoel Fernandes (Google)
commit fc91a3c4c27acdca0bc13af6fbb68c35cfd519f2 upstream. While debugging an issue debugobject tracking warned about an annotation issue of an object on stack. It turned out that the issue was due to the object in concern being on a different stack which was due to another issue. Thomas suggested to print the pointers and the location of the stack for the currently running task. This helped to figure out that the object was on the wrong stack. As this is general useful information for debugging similar issues, make the error message more informative by printing the pointers. [ tglx: Massaged changelog ] Signed-off-by: Joel Fernandes (Google) <joel@joelfernandes.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Waiman Long <longman@redhat.com> Acked-by: Yang Shi <yang.shi@linux.alibaba.com> Cc: kernel-team@android.com Cc: Arnd Bergmann <arnd@arndb.de> Cc: astrachan@google.com Link: https://lkml.kernel.org/r/20180723212531.202328-1-joel@joelfernandes.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-17ioremap: Update pgtable free interfaces with addrChintan Pandya
commit 785a19f9d1dd8a4ab2d0633be4656653bd3de1fc upstream. The following kernel panic was observed on ARM64 platform due to a stale TLB entry. 1. ioremap with 4K size, a valid pte page table is set. 2. iounmap it, its pte entry is set to 0. 3. ioremap the same address with 2M size, update its pmd entry with a new value. 4. CPU may hit an exception because the old pmd entry is still in TLB, which leads to a kernel panic. Commit b6bdb7517c3d ("mm/vmalloc: add interfaces to free unmapped page table") has addressed this panic by falling to pte mappings in the above case on ARM64. To support pmd mappings in all cases, TLB purge needs to be performed in this case on ARM64. Add a new arg, 'addr', to pud_free_pmd_page() and pmd_free_pte_page() so that TLB purge can be added later in seprate patches. [toshi.kani@hpe.com: merge changes, rewrite patch description] Fixes: 28ee90fe6048 ("x86/mm: implement free pmd/pte page interfaces") Signed-off-by: Chintan Pandya <cpandya@codeaurora.org> Signed-off-by: Toshi Kani <toshi.kani@hpe.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: mhocko@suse.com Cc: akpm@linux-foundation.org Cc: hpa@zytor.com Cc: linux-mm@kvack.org Cc: linux-arm-kernel@lists.infradead.org Cc: Will Deacon <will.deacon@arm.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: stable@vger.kernel.org Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Michal Hocko <mhocko@suse.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: <stable@vger.kernel.org> Link: https://lkml.kernel.org/r/20180627141348.21777-3-toshi.kani@hpe.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-25lib/rhashtable: consider param->min_size when setting initial table sizeDavidlohr Bueso
[ Upstream commit 107d01f5ba10f4162c38109496607eb197059064 ] rhashtable_init() currently does not take into account the user-passed min_size parameter unless param->nelem_hint is set as well. As such, the default size (number of buckets) will always be HASH_DEFAULT_SIZE even if the smallest allowed size is larger than that. Remediate this by unconditionally calling into rounded_hashtable_size() and handling things accordingly. Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03lib/vsprintf: Remove atomic-unsafe support for %pCrGeert Uytterhoeven
commit 666902e42fd8344b923c02dc5b0f37948ff4f225 upstream. "%pCr" formats the current rate of a clock, and calls clk_get_rate(). The latter obtains a mutex, hence it must not be called from atomic context. Remove support for this rarely-used format, as vsprintf() (and e.g. printk()) must be callable from any context. Any remaining out-of-tree users will start seeing the clock's name printed instead of its rate. Reported-by: Jia-Ju Bai <baijiaju1990@gmail.com> Fixes: 900cca2944254edd ("lib/vsprintf: add %pC{,n,r} format specifiers for clocks") Link: http://lkml.kernel.org/r/1527845302-12159-5-git-send-email-geert+renesas@glider.be To: Jia-Ju Bai <baijiaju1990@gmail.com> To: Jonathan Corbet <corbet@lwn.net> To: Michael Turquette <mturquette@baylibre.com> To: Stephen Boyd <sboyd@kernel.org> To: Zhang Rui <rui.zhang@intel.com> To: Eduardo Valentin <edubezval@gmail.com> To: Eric Anholt <eric@anholt.net> To: Stefan Wahren <stefan.wahren@i2se.com> To: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Cc: Petr Mladek <pmladek@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: linux-doc@vger.kernel.org Cc: linux-clk@vger.kernel.org Cc: linux-pm@vger.kernel.org Cc: linux-serial@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-renesas-soc@vger.kernel.org Cc: linux-kernel@vger.kernel.org Cc: Geert Uytterhoeven <geert+renesas@glider.be> Cc: stable@vger.kernel.org # 4.1+ Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Petr Mladek <pmladek@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30bpf: fix selftests/bpf test_kmod.sh failure when CONFIG_BPF_JIT_ALWAYS_ON=yYonghong Song
[ Upstream commit 09584b406742413ac4c8d7e030374d4daa045b69 ] With CONFIG_BPF_JIT_ALWAYS_ON is defined in the config file, tools/testing/selftests/bpf/test_kmod.sh failed like below: [root@localhost bpf]# ./test_kmod.sh sysctl: setting key "net.core.bpf_jit_enable": Invalid argument [ JIT enabled:0 hardened:0 ] [ 132.175681] test_bpf: #297 BPF_MAXINSNS: Jump, gap, jump, ... FAIL to prog_create err=-524 len=4096 [ 132.458834] test_bpf: Summary: 348 PASSED, 1 FAILED, [340/340 JIT'ed] [ JIT enabled:1 hardened:0 ] [ 133.456025] test_bpf: #297 BPF_MAXINSNS: Jump, gap, jump, ... FAIL to prog_create err=-524 len=4096 [ 133.730935] test_bpf: Summary: 348 PASSED, 1 FAILED, [340/340 JIT'ed] [ JIT enabled:1 hardened:1 ] [ 134.769730] test_bpf: #297 BPF_MAXINSNS: Jump, gap, jump, ... FAIL to prog_create err=-524 len=4096 [ 135.050864] test_bpf: Summary: 348 PASSED, 1 FAILED, [340/340 JIT'ed] [ JIT enabled:1 hardened:2 ] [ 136.442882] test_bpf: #297 BPF_MAXINSNS: Jump, gap, jump, ... FAIL to prog_create err=-524 len=4096 [ 136.821810] test_bpf: Summary: 348 PASSED, 1 FAILED, [340/340 JIT'ed] [root@localhost bpf]# The test_kmod.sh load/remove test_bpf.ko multiple times with different settings for sysctl net.core.bpf_jit_{enable,harden}. The failed test #297 of test_bpf.ko is designed such that JIT always fails. Commit 290af86629b2 (bpf: introduce BPF_JIT_ALWAYS_ON config) introduced the following tightening logic: ... if (!bpf_prog_is_dev_bound(fp->aux)) { fp = bpf_int_jit_compile(fp); #ifdef CONFIG_BPF_JIT_ALWAYS_ON if (!fp->jited) { *err = -ENOTSUPP; return fp; } #endif ... With this logic, Test #297 always gets return value -ENOTSUPP when CONFIG_BPF_JIT_ALWAYS_ON is defined, causing the test failure. This patch fixed the failure by marking Test #297 as expected failure when CONFIG_BPF_JIT_ALWAYS_ON is defined. Fixes: 290af86629b2 (bpf: introduce BPF_JIT_ALWAYS_ON config) Signed-off-by: Yonghong Song <yhs@fb.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-01kobject: don't use WARN for registration failuresDmitry Vyukov
commit 3e14c6abbfb5c94506edda9d8e2c145d79375798 upstream. This WARNING proved to be noisy. The function still returns an error and callers should handle it. That's how most of kernel code works. Downgrade the WARNING to pr_err() and leave WARNINGs for kernel bugs. Signed-off-by: Dmitry Vyukov <dvyukov@google.com> Reported-by: syzbot+209c0f67f99fec8eb14b@syzkaller.appspotmail.com Reported-by: syzbot+7fb6d9525a4528104e05@syzkaller.appspotmail.com Reported-by: syzbot+2e63711063e2d8f9ea27@syzkaller.appspotmail.com Reported-by: syzbot+de73361ee4971b6e6f75@syzkaller.appspotmail.com Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-31rhashtable: Fix rhlist duplicates insertionPaul Blakey
[ Upstream commit d3dcf8eb615537526bd42ff27a081d46d337816e ] When inserting duplicate objects (those with the same key), current rhlist implementation messes up the chain pointers by updating the bucket pointer instead of prev next pointer to the newly inserted node. This causes missing elements on removal and travesal. Fix that by properly updating pprev pointer to point to the correct rhash_head next pointer. Issue: 1241076 Change-Id: I86b2c140bcb4aeb10b70a72a267ff590bb2b17e7 Fixes: ca26893f05e8 ('rhashtable: Add rhlist interface') Signed-off-by: Paul Blakey <paulb@mellanox.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-28mm/vmalloc: add interfaces to free unmapped page tableToshi Kani
commit b6bdb7517c3d3f41f20e5c2948d6bc3f8897394e upstream. On architectures with CONFIG_HAVE_ARCH_HUGE_VMAP set, ioremap() may create pud/pmd mappings. A kernel panic was observed on arm64 systems with Cortex-A75 in the following steps as described by Hanjun Guo. 1. ioremap a 4K size, valid page table will build, 2. iounmap it, pte0 will set to 0; 3. ioremap the same address with 2M size, pgd/pmd is unchanged, then set the a new value for pmd; 4. pte0 is leaked; 5. CPU may meet exception because the old pmd is still in TLB, which will lead to kernel panic. This panic is not reproducible on x86. INVLPG, called from iounmap, purges all levels of entries associated with purged address on x86. x86 still has memory leak. The patch changes the ioremap path to free unmapped page table(s) since doing so in the unmap path has the following issues: - The iounmap() path is shared with vunmap(). Since vmap() only supports pte mappings, making vunmap() to free a pte page is an overhead for regular vmap users as they do not need a pte page freed up. - Checking if all entries in a pte page are cleared in the unmap path is racy, and serializing this check is expensive. - The unmap path calls free_vmap_area_noflush() to do lazy TLB purges. Clearing a pud/pmd entry before the lazy TLB purges needs extra TLB purge. Add two interfaces, pud_free_pmd_page() and pmd_free_pte_page(), which clear a given pud/pmd entry and free up a page for the lower level entries. This patch implements their stub functions on x86 and arm64, which work as workaround. [akpm@linux-foundation.org: fix typo in pmd_free_pte_page() stub] Link: http://lkml.kernel.org/r/20180314180155.19492-2-toshi.kani@hpe.com Fixes: e61ce6ade404e ("mm: change ioremap to set up huge I/O mappings") Reported-by: Lei Li <lious.lilei@hisilicon.com> Signed-off-by: Toshi Kani <toshi.kani@hpe.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Wang Xuefeng <wxf.wang@hisilicon.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Hanjun Guo <guohanjun@huawei.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Borislav Petkov <bp@suse.de> Cc: Matthew Wilcox <willy@infradead.org> Cc: Chintan Pandya <cpandya@codeaurora.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-03lib/mpi: Fix umul_ppmm() for MIPS64r6James Hogan
[ Upstream commit bbc25bee37d2b32cf3a1fab9195b6da3a185614a ] Current MIPS64r6 toolchains aren't able to generate efficient DMULU/DMUHU based code for the C implementation of umul_ppmm(), which performs an unsigned 64 x 64 bit multiply and returns the upper and lower 64-bit halves of the 128-bit result. Instead it widens the 64-bit inputs to 128-bits and emits a __multi3 intrinsic call to perform a 128 x 128 multiply. This is both inefficient, and it results in a link error since we don't include __multi3 in MIPS linux. For example commit 90a53e4432b1 ("cfg80211: implement regdb signature checking") merged in v4.15-rc1 recently broke the 64r6_defconfig and 64r6el_defconfig builds by indirectly selecting MPILIB. The same build errors can be reproduced on older kernels by enabling e.g. CRYPTO_RSA: lib/mpi/generic_mpih-mul1.o: In function `mpihelp_mul_1': lib/mpi/generic_mpih-mul1.c:50: undefined reference to `__multi3' lib/mpi/generic_mpih-mul2.o: In function `mpihelp_addmul_1': lib/mpi/generic_mpih-mul2.c:49: undefined reference to `__multi3' lib/mpi/generic_mpih-mul3.o: In function `mpihelp_submul_1': lib/mpi/generic_mpih-mul3.c:49: undefined reference to `__multi3' lib/mpi/mpih-div.o In function `mpihelp_divrem': lib/mpi/mpih-div.c:205: undefined reference to `__multi3' lib/mpi/mpih-div.c:142: undefined reference to `__multi3' Therefore add an efficient MIPS64r6 implementation of umul_ppmm() using inline assembly and the DMULU/DMUHU instructions, to prevent __multi3 calls being emitted. Fixes: 7fd08ca58ae6 ("MIPS: Add build support for the MIPS R6 ISA") Signed-off-by: James Hogan <jhogan@kernel.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: "David S. Miller" <davem@davemloft.net> Cc: linux-mips@linux-mips.org Cc: linux-crypto@vger.kernel.org Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25kasan: rework Kconfig settingsArnd Bergmann
commit e7c52b84fb18f08ce49b6067ae6285aca79084a8 upstream. We get a lot of very large stack frames using gcc-7.0.1 with the default -fsanitize-address-use-after-scope --param asan-stack=1 options, which can easily cause an overflow of the kernel stack, e.g. drivers/gpu/drm/i915/gvt/handlers.c:2434:1: warning: the frame size of 46176 bytes is larger than 3072 bytes drivers/net/wireless/ralink/rt2x00/rt2800lib.c:5650:1: warning: the frame size of 23632 bytes is larger than 3072 bytes lib/atomic64_test.c:250:1: warning: the frame size of 11200 bytes is larger than 3072 bytes drivers/gpu/drm/i915/gvt/handlers.c:2621:1: warning: the frame size of 9208 bytes is larger than 3072 bytes drivers/media/dvb-frontends/stv090x.c:3431:1: warning: the frame size of 6816 bytes is larger than 3072 bytes fs/fscache/stats.c:287:1: warning: the frame size of 6536 bytes is larger than 3072 bytes To reduce this risk, -fsanitize-address-use-after-scope is now split out into a separate CONFIG_KASAN_EXTRA Kconfig option, leading to stack frames that are smaller than 2 kilobytes most of the time on x86_64. An earlier version of this patch also prevented combining KASAN_EXTRA with KASAN_INLINE, but that is no longer necessary with gcc-7.0.1. All patches to get the frame size below 2048 bytes with CONFIG_KASAN=y and CONFIG_KASAN_EXTRA=n have been merged by maintainers now, so we can bring back that default now. KASAN_EXTRA=y still causes lots of warnings but now defaults to !COMPILE_TEST to disable it in allmodconfig, and it remains disabled in all other defconfigs since it is a new option. I arbitrarily raise the warning limit for KASAN_EXTRA to 3072 to reduce the noise, but an allmodconfig kernel still has around 50 warnings on gcc-7. I experimented a bit more with smaller stack frames and have another follow-up series that reduces the warning limit for 64-bit architectures to 1280 bytes (without CONFIG_KASAN). With earlier versions of this patch series, I also had patches to address the warnings we get with KASAN and/or KASAN_EXTRA, using a "noinline_if_stackbloat" annotation. That annotation now got replaced with a gcc-8 bugfix (see https://gcc.gnu.org/bugzilla/show_bug.cgi?id=81715) and a workaround for older compilers, which means that KASAN_EXTRA is now just as bad as before and will lead to an instant stack overflow in a few extreme cases. This reverts parts of commit 3f181b4d8652 ("lib/Kconfig.debug: disable -Wframe-larger-than warnings with KASAN=y"). Two patches in linux-next should be merged first to avoid introducing warnings in an allmodconfig build: 3cd890dbe2a4 ("media: dvb-frontends: fix i2c access helpers for KASAN") 16c3ada89cff ("media: r820t: fix r820t_write_reg for KASAN") Do we really need to backport this? I think we do: without this patch, enabling KASAN will lead to unavoidable kernel stack overflow in certain device drivers when built with gcc-7 or higher on linux-4.10+ or any version that contains a backport of commit c5caf21ab0cf8. Most people are probably still on older compilers, but it will get worse over time as they upgrade their distros. The warnings we get on kernels older than this should all be for code that uses dangerously large stack frames, though most of them do not cause an actual stack overflow by themselves.The asan-stack option was added in linux-4.0, and commit 3f181b4d8652 ("lib/Kconfig.debug: disable -Wframe-larger-than warnings with KASAN=y") effectively turned off the warning for allmodconfig kernels, so I would like to see this fix backported to any kernels later than 4.0. I have done dozens of fixes for individual functions with stack frames larger than 2048 bytes with asan-stack, and I plan to make sure that all those fixes make it into the stable kernels as well (most are already there). Part of the complication here is that asan-stack (from 4.0) was originally assumed to always require much larger stacks, but that turned out to be a combination of multiple gcc bugs that we have now worked around and fixed, but sanitize-address-use-after-scope (from v4.10) has a much higher inherent stack usage and also suffers from at least three other problems that we have analyzed but not yet fixed upstream, each of them makes the stack usage more severe than it should be. Link: http://lkml.kernel.org/r/20171221134744.2295529-1-arnd@arndb.de Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Mauro Carvalho Chehab <mchehab@kernel.org> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Alexander Potapenko <glider@google.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Andrey Konovalov <andreyknvl@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [arnd: rebase to v4.9; only re-enable warning] Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25509: fix printing uninitialized stack memory when OID is emptyEric Biggers
[ Upstream commit 8dfd2f22d3bf3ab7714f7495ad5d897b8845e8c1 ] Callers of sprint_oid() do not check its return value before printing the result. In the case where the OID is zero-length, -EBADMSG was being returned without anything being written to the buffer, resulting in uninitialized stack memory being printed. Fix this by writing "(bad)" to the buffer in the cases where -EBADMSG is returned. Fixes: 4f73175d0375 ("X.509: Add utility functions to render OIDs as strings") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-17lib/ubsan: add type mismatch handler for new GCC/ClangAndrey Ryabinin
commit 42440c1f9911b4b7b8ba3dc4e90c1197bc561211 upstream. UBSAN=y fails to build with new GCC/clang: arch/x86/kernel/head64.o: In function `sanitize_boot_params': arch/x86/include/asm/bootparam_utils.h:37: undefined reference to `__ubsan_handle_type_mismatch_v1' because Clang and GCC 8 slightly changed ABI for 'type mismatch' errors. Compiler now uses new __ubsan_handle_type_mismatch_v1() function with slightly modified 'struct type_mismatch_data'. Let's add new 'struct type_mismatch_data_common' which is independent from compiler's layout of 'struct type_mismatch_data'. And make __ubsan_handle_type_mismatch[_v1]() functions transform compiler-dependent type mismatch data to our internal representation. This way, we can support both old and new compilers with minimal amount of change. Link: http://lkml.kernel.org/r/20180119152853.16806-1-aryabinin@virtuozzo.com Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Reported-by: Sodagudi Prasad <psodagud@codeaurora.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-17lib/ubsan.c: s/missaligned/misaligned/Andrew Morton
commit b8fe1120b4ba342b4f156d24e952d6e686b20298 upstream. A vist from the spelling fairy. Cc: David Laight <David.Laight@ACULAB.COM> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-31bpf: introduce BPF_JIT_ALWAYS_ON configAlexei Starovoitov
[ upstream commit 290af86629b25ffd1ed6232c4e9107da031705cb ] The BPF interpreter has been used as part of the spectre 2 attack CVE-2017-5715. A quote from goolge project zero blog: "At this point, it would normally be necessary to locate gadgets in the host kernel code that can be used to actually leak data by reading from an attacker-controlled location, shifting and masking the result appropriately and then using the result of that as offset to an attacker-controlled address for a load. But piecing gadgets together and figuring out which ones work in a speculation context seems annoying. So instead, we decided to use the eBPF interpreter, which is built into the host kernel - while there is no legitimate way to invoke it from inside a VM, the presence of the code in the host kernel's text section is sufficient to make it usable for the attack, just like with ordinary ROP gadgets." To make attacker job harder introduce BPF_JIT_ALWAYS_ON config option that removes interpreter from the kernel in favor of JIT-only mode. So far eBPF JIT is supported by: x64, arm64, arm32, sparc64, s390, powerpc64, mips64 The start of JITed program is randomized and code page is marked as read-only. In addition "constant blinding" can be turned on with net.core.bpf_jit_harden v2->v3: - move __bpf_prog_ret0 under ifdef (Daniel) v1->v2: - fix init order, test_bpf and cBPF (Daniel's feedback) - fix offloaded bpf (Jakub's feedback) - add 'return 0' dummy in case something can invoke prog->bpf_func - retarget bpf tree. For bpf-next the patch would need one extra hunk. It will be sent when the trees are merged back to net-next Considered doing: int bpf_jit_enable __read_mostly = BPF_EBPF_JIT_DEFAULT; but it seems better to land the patch as-is and in bpf-next remove bpf_jit_enable global variable from all JITs, consolidate in one place and remove this jit_init() function. Signed-off-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14dynamic-debug-howto: fix optional/omitted ending line number to be LARGE ↵Randy Dunlap
instead of 0 [ Upstream commit 1f3c790bd5989fcfec9e53ad8fa09f5b740c958f ] line-range is supposed to treat "1-" as "1-endoffile", so handle the special case by setting last_lineno to UINT_MAX. Fixes this error: dynamic_debug:ddebug_parse_query: last-line:0 < 1st-line:1 dynamic_debug:ddebug_exec_query: query parse failed Link: http://lkml.kernel.org/r/10a6a101-e2be-209f-1f41-54637824788e@infradead.org Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Acked-by: Jason Baron <jbaron@akamai.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14lib/genalloc.c: make the avail variable an atomic_long_tStephen Bates
[ Upstream commit 36a3d1dd4e16bcd0d2ddfb4a2ec7092f0ae0d931 ] If the amount of resources allocated to a gen_pool exceeds 2^32 then the avail atomic overflows and this causes problems when clients try and borrow resources from the pool. This is only expected to be an issue on 64 bit systems. Add the <linux/atomic.h> header to pull in atomic_long* operations. So that 32 bit systems continue to use atomic32_t but 64 bit systems can use atomic64_t. Link: http://lkml.kernel.org/r/1509033843-25667-1-git-send-email-sbates@raithlin.com Signed-off-by: Stephen Bates <sbates@raithlin.com> Reviewed-by: Logan Gunthorpe <logang@deltatee.com> Reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Reviewed-by: Daniel Mentz <danielmentz@google.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Will Deacon <will.deacon@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14ASN.1: check for error from ASN1_OP_END__ACT actionsEric Biggers
commit 81a7be2cd69b412ab6aeacfe5ebf1bb6e5bce955 upstream. asn1_ber_decoder() was ignoring errors from actions associated with the opcodes ASN1_OP_END_SEQ_ACT, ASN1_OP_END_SET_ACT, ASN1_OP_END_SEQ_OF_ACT, and ASN1_OP_END_SET_OF_ACT. In practice, this meant the pkcs7_note_signed_info() action (since that was the only user of those opcodes). Fix it by checking for the error, just like the decoder does for actions associated with the other opcodes. This bug allowed users to leak slab memory by repeatedly trying to add a specially crafted "pkcs7_test" key (requires CONFIG_PKCS7_TEST_KEY). In theory, this bug could also be used to bypass module signature verification, by providing a PKCS#7 message that is misparsed such that a signature's ->authattrs do not contain its ->msgdigest. But it doesn't seem practical in normal cases, due to restrictions on the format of the ->authattrs. Fixes: 42d5ec27f873 ("X.509: Add an ASN.1 decoder") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14ASN.1: fix out-of-bounds read when parsing indefinite length itemEric Biggers
commit e0058f3a874ebb48b25be7ff79bc3b4e59929f90 upstream. In asn1_ber_decoder(), indefinitely-sized ASN.1 items were being passed to the action functions before their lengths had been computed, using the bogus length of 0x80 (ASN1_INDEFINITE_LENGTH). This resulted in reading data past the end of the input buffer, when given a specially crafted message. Fix it by rearranging the code so that the indefinite length is resolved before the action is called. This bug was originally found by fuzzing the X.509 parser in userspace using libFuzzer from the LLVM project. KASAN report (cleaned up slightly): BUG: KASAN: slab-out-of-bounds in memcpy ./include/linux/string.h:341 [inline] BUG: KASAN: slab-out-of-bounds in x509_fabricate_name.constprop.1+0x1a4/0x940 crypto/asymmetric_keys/x509_cert_parser.c:366 Read of size 128 at addr ffff880035dd9eaf by task keyctl/195 CPU: 1 PID: 195 Comm: keyctl Not tainted 4.14.0-09238-g1d3b78bbc6e9 #26 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.11.0-20171110_100015-anatol 04/01/2014 Call Trace: __dump_stack lib/dump_stack.c:17 [inline] dump_stack+0xd1/0x175 lib/dump_stack.c:53 print_address_description+0x78/0x260 mm/kasan/report.c:252 kasan_report_error mm/kasan/report.c:351 [inline] kasan_report+0x23f/0x350 mm/kasan/report.c:409 memcpy+0x1f/0x50 mm/kasan/kasan.c:302 memcpy ./include/linux/string.h:341 [inline] x509_fabricate_name.constprop.1+0x1a4/0x940 crypto/asymmetric_keys/x509_cert_parser.c:366 asn1_ber_decoder+0xb4a/0x1fd0 lib/asn1_decoder.c:447 x509_cert_parse+0x1c7/0x620 crypto/asymmetric_keys/x509_cert_parser.c:89 x509_key_preparse+0x61/0x750 crypto/asymmetric_keys/x509_public_key.c:174 asymmetric_key_preparse+0xa4/0x150 crypto/asymmetric_keys/asymmetric_type.c:388 key_create_or_update+0x4d4/0x10a0 security/keys/key.c:850 SYSC_add_key security/keys/keyctl.c:122 [inline] SyS_add_key+0xe8/0x290 security/keys/keyctl.c:62 entry_SYSCALL_64_fastpath+0x1f/0x96 Allocated by task 195: __do_kmalloc_node mm/slab.c:3675 [inline] __kmalloc_node+0x47/0x60 mm/slab.c:3682 kvmalloc ./include/linux/mm.h:540 [inline] SYSC_add_key security/keys/keyctl.c:104 [inline] SyS_add_key+0x19e/0x290 security/keys/keyctl.c:62 entry_SYSCALL_64_fastpath+0x1f/0x96 Fixes: 42d5ec27f873 ("X.509: Add an ASN.1 decoder") Reported-by: Alexander Potapenko <glider@google.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-30lib/mpi: call cond_resched() from mpi_powm() loopEric Biggers
commit 1d9ddde12e3c9bab7f3d3484eb9446315e3571ca upstream. On a non-preemptible kernel, if KEYCTL_DH_COMPUTE is called with the largest permitted inputs (16384 bits), the kernel spends 10+ seconds doing modular exponentiation in mpi_powm() without rescheduling. If all threads do it, it locks up the system. Moreover, it can cause rcu_sched-stall warnings. Notwithstanding the insanity of doing this calculation in kernel mode rather than in userspace, fix it by calling cond_resched() as each bit from the exponent is processed. It's still noninterruptible, but at least it's preemptible now. Do the cond_resched() once per bit rather than once per MPI limb because each limb might still easily take 100+ milliseconds on slow CPUs. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-15KEYS: fix NULL pointer dereference during ASN.1 parsing [ver #2]Eric Biggers
commit 624f5ab8720b3371367327a822c267699c1823b8 upstream. syzkaller reported a NULL pointer dereference in asn1_ber_decoder(). It can be reproduced by the following command, assuming CONFIG_PKCS7_TEST_KEY=y: keyctl add pkcs7_test desc '' @s The bug is that if the data buffer is empty, an integer underflow occurs in the following check: if (unlikely(dp >= datalen - 1)) goto data_overrun_error; This results in the NULL data pointer being dereferenced. Fix it by checking for 'datalen - dp < 2' instead. Also fix the similar check for 'dp >= datalen - n' later in the same function. That one possibly could result in a buffer overread. The NULL pointer dereference was reproducible using the "pkcs7_test" key type but not the "asymmetric" key type because the "asymmetric" key type checks for a 0-length payload before calling into the ASN.1 decoder but the "pkcs7_test" key type does not. The bug report was: BUG: unable to handle kernel NULL pointer dereference at (null) IP: asn1_ber_decoder+0x17f/0xe60 lib/asn1_decoder.c:233 PGD 7b708067 P4D 7b708067 PUD 7b6ee067 PMD 0 Oops: 0000 [#1] SMP Modules linked in: CPU: 0 PID: 522 Comm: syz-executor1 Not tainted 4.14.0-rc8 #7 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.3-20171021_125229-anatol 04/01/2014 task: ffff9b6b3798c040 task.stack: ffff9b6b37970000 RIP: 0010:asn1_ber_decoder+0x17f/0xe60 lib/asn1_decoder.c:233 RSP: 0018:ffff9b6b37973c78 EFLAGS: 00010216 RAX: 0000000000000000 RBX: 0000000000000000 RCX: 000000000000021c RDX: ffffffff814a04ed RSI: ffffb1524066e000 RDI: ffffffff910759e0 RBP: ffff9b6b37973d60 R08: 0000000000000001 R09: ffff9b6b3caa4180 R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000002 R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000 FS: 00007f10ed1f2700(0000) GS:ffff9b6b3ea00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000000 CR3: 000000007b6f3000 CR4: 00000000000006f0 Call Trace: pkcs7_parse_message+0xee/0x240 crypto/asymmetric_keys/pkcs7_parser.c:139 verify_pkcs7_signature+0x33/0x180 certs/system_keyring.c:216 pkcs7_preparse+0x41/0x70 crypto/asymmetric_keys/pkcs7_key_type.c:63 key_create_or_update+0x180/0x530 security/keys/key.c:855 SYSC_add_key security/keys/keyctl.c:122 [inline] SyS_add_key+0xbf/0x250 security/keys/keyctl.c:62 entry_SYSCALL_64_fastpath+0x1f/0xbe RIP: 0033:0x4585c9 RSP: 002b:00007f10ed1f1bd8 EFLAGS: 00000216 ORIG_RAX: 00000000000000f8 RAX: ffffffffffffffda RBX: 00007f10ed1f2700 RCX: 00000000004585c9 RDX: 0000000020000000 RSI: 0000000020008ffb RDI: 0000000020008000 RBP: 0000000000000000 R08: ffffffffffffffff R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000216 R12: 00007fff1b2260ae R13: 00007fff1b2260af R14: 00007f10ed1f2700 R15: 0000000000000000 Code: dd ca ff 48 8b 45 88 48 83 e8 01 4c 39 f0 0f 86 a8 07 00 00 e8 53 dd ca ff 49 8d 46 01 48 89 85 58 ff ff ff 48 8b 85 60 ff ff ff <42> 0f b6 0c 30 89 c8 88 8d 75 ff ff ff 83 e0 1f 89 8d 28 ff ff RIP: asn1_ber_decoder+0x17f/0xe60 lib/asn1_decoder.c:233 RSP: ffff9b6b37973c78 CR2: 0000000000000000 Fixes: 42d5ec27f873 ("X.509: Add an ASN.1 decoder") Reported-by: syzbot <syzkaller@googlegroups.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-08KEYS: fix out-of-bounds read during ASN.1 parsingEric Biggers
commit 2eb9eabf1e868fda15808954fb29b0f105ed65f1 upstream. syzkaller with KASAN reported an out-of-bounds read in asn1_ber_decoder(). It can be reproduced by the following command, assuming CONFIG_X509_CERTIFICATE_PARSER=y and CONFIG_KASAN=y: keyctl add asymmetric desc $'\x30\x30' @s The bug is that the length of an ASN.1 data value isn't validated in the case where it is encoded using the short form, causing the decoder to read past the end of the input buffer. Fix it by validating the length. The bug report was: BUG: KASAN: slab-out-of-bounds in asn1_ber_decoder+0x10cb/0x1730 lib/asn1_decoder.c:233 Read of size 1 at addr ffff88003cccfa02 by task syz-executor0/6818 CPU: 1 PID: 6818 Comm: syz-executor0 Not tainted 4.14.0-rc7-00008-g5f479447d983 #2 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 Call Trace: __dump_stack lib/dump_stack.c:16 [inline] dump_stack+0xb3/0x10b lib/dump_stack.c:52 print_address_description+0x79/0x2a0 mm/kasan/report.c:252 kasan_report_error mm/kasan/report.c:351 [inline] kasan_report+0x236/0x340 mm/kasan/report.c:409 __asan_report_load1_noabort+0x14/0x20 mm/kasan/report.c:427 asn1_ber_decoder+0x10cb/0x1730 lib/asn1_decoder.c:233 x509_cert_parse+0x1db/0x650 crypto/asymmetric_keys/x509_cert_parser.c:89 x509_key_preparse+0x64/0x7a0 crypto/asymmetric_keys/x509_public_key.c:174 asymmetric_key_preparse+0xcb/0x1a0 crypto/asymmetric_keys/asymmetric_type.c:388 key_create_or_update+0x347/0xb20 security/keys/key.c:855 SYSC_add_key security/keys/keyctl.c:122 [inline] SyS_add_key+0x1cd/0x340 security/keys/keyctl.c:62 entry_SYSCALL_64_fastpath+0x1f/0xbe RIP: 0033:0x447c89 RSP: 002b:00007fca7a5d3bd8 EFLAGS: 00000246 ORIG_RAX: 00000000000000f8 RAX: ffffffffffffffda RBX: 00007fca7a5d46cc RCX: 0000000000447c89 RDX: 0000000020006f4a RSI: 0000000020006000 RDI: 0000000020001ff5 RBP: 0000000000000046 R08: fffffffffffffffd R09: 0000000000000000 R10: 0000000000000002 R11: 0000000000000246 R12: 0000000000000000 R13: 0000000000000000 R14: 00007fca7a5d49c0 R15: 00007fca7a5d4700 Fixes: 42d5ec27f873 ("X.509: Add an ASN.1 decoder") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-02assoc_array: Fix a buggy node-splitting caseDavid Howells
commit ea6789980fdaa610d7eb63602c746bf6ec70cd2b upstream. This fixes CVE-2017-12193. Fix a case in the assoc_array implementation in which a new leaf is added that needs to go into a node that happens to be full, where the existing leaves in that node cluster together at that level to the exclusion of new leaf. What needs to happen is that the existing leaves get moved out to a new node, N1, at level + 1 and the existing node needs replacing with one, N0, that has pointers to the new leaf and to N1. The code that tries to do this gets this wrong in two ways: (1) The pointer that should've pointed from N0 to N1 is set to point recursively to N0 instead. (2) The backpointer from N0 needs to be set correctly in the case N0 is either the root node or reached through a shortcut. Fix this by removing this path and using the split_node path instead, which achieves the same end, but in a more general way (thanks to Eric Biggers for spotting the redundancy). The problem manifests itself as: BUG: unable to handle kernel NULL pointer dereference at 0000000000000010 IP: assoc_array_apply_edit+0x59/0xe5 Fixes: 3cb989501c26 ("Add a generic associative array implementation.") Reported-and-tested-by: WU Fan <u3536072@connect.hku.hk> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27lib/digsig: fix dereference of NULL user_key_payloadEric Biggers
commit 192cabd6a296cbc57b3d8c05c4c89d87fc102506 upstream. digsig_verify() requests a user key, then accesses its payload. However, a revoked key has a NULL payload, and we failed to check for this. request_key() *does* skip revoked keys, but there is still a window where the key can be revoked before we acquire its semaphore. Fix it by checking for a NULL payload, treating it like a key which was already revoked at the time it was requested. Fixes: 051dbb918c7f ("crypto: digital signature verification support") Reviewed-by: James Morris <james.l.morris@oracle.com> Cc: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-12lib/ratelimit.c: use deferred printk() versionSergey Senozhatsky
commit 656d61ce9666209c4c4a13c71902d3ee70d1ff6f upstream. printk_ratelimit() invokes ___ratelimit() which may invoke a normal printk() (pr_warn() in this particular case) to warn about suppressed output. Given that printk_ratelimit() may be called from anywhere, that pr_warn() is dangerous - it may end up deadlocking the system. Fix ___ratelimit() by using deferred printk(). Sasha reported the following lockdep error: : Unregister pv shared memory for cpu 8 : select_fallback_rq: 3 callbacks suppressed : process 8583 (trinity-c78) no longer affine to cpu8 : : ====================================================== : WARNING: possible circular locking dependency detected : 4.14.0-rc2-next-20170927+ #252 Not tainted : ------------------------------------------------------ : migration/8/62 is trying to acquire lock: : (&port_lock_key){-.-.}, at: serial8250_console_write() : : but task is already holding lock: : (&rq->lock){-.-.}, at: sched_cpu_dying() : : which lock already depends on the new lock. : : : the existing dependency chain (in reverse order) is: : : -> #3 (&rq->lock){-.-.}: : __lock_acquire() : lock_acquire() : _raw_spin_lock() : task_fork_fair() : sched_fork() : copy_process.part.31() : _do_fork() : kernel_thread() : rest_init() : start_kernel() : x86_64_start_reservations() : x86_64_start_kernel() : verify_cpu() : : -> #2 (&p->pi_lock){-.-.}: : __lock_acquire() : lock_acquire() : _raw_spin_lock_irqsave() : try_to_wake_up() : default_wake_function() : woken_wake_function() : __wake_up_common() : __wake_up_common_lock() : __wake_up() : tty_wakeup() : tty_port_default_wakeup() : tty_port_tty_wakeup() : uart_write_wakeup() : serial8250_tx_chars() : serial8250_handle_irq.part.25() : serial8250_default_handle_irq() : serial8250_interrupt() : __handle_irq_event_percpu() : handle_irq_event_percpu() : handle_irq_event() : handle_level_irq() : handle_irq() : do_IRQ() : ret_from_intr() : native_safe_halt() : default_idle() : arch_cpu_idle() : default_idle_call() : do_idle() : cpu_startup_entry() : rest_init() : start_kernel() : x86_64_start_reservations() : x86_64_start_kernel() : verify_cpu() : : -> #1 (&tty->write_wait){-.-.}: : __lock_acquire() : lock_acquire() : _raw_spin_lock_irqsave() : __wake_up_common_lock() : __wake_up() : tty_wakeup() : tty_port_default_wakeup() : tty_port_tty_wakeup() : uart_write_wakeup() : serial8250_tx_chars() : serial8250_handle_irq.part.25() : serial8250_default_handle_irq() : serial8250_interrupt() : __handle_irq_event_percpu() : handle_irq_event_percpu() : handle_irq_event() : handle_level_irq() : handle_irq() : do_IRQ() : ret_from_intr() : native_safe_halt() : default_idle() : arch_cpu_idle() : default_idle_call() : do_idle() : cpu_startup_entry() : rest_init() : start_kernel() : x86_64_start_reservations() : x86_64_start_kernel() : verify_cpu() : : -> #0 (&port_lock_key){-.-.}: : check_prev_add() : __lock_acquire() : lock_acquire() : _raw_spin_lock_irqsave() : serial8250_console_write() : univ8250_console_write() : console_unlock() : vprintk_emit() : vprintk_default() : vprintk_func() : printk() : ___ratelimit() : __printk_ratelimit() : select_fallback_rq() : sched_cpu_dying() : cpuhp_invoke_callback() : take_cpu_down() : multi_cpu_stop() : cpu_stopper_thread() : smpboot_thread_fn() : kthread() : ret_from_fork() : : other info that might help us debug this: : : Chain exists of: : &port_lock_key --> &p->pi_lock --> &rq->lock : : Possible unsafe locking scenario: : : CPU0 CPU1 : ---- ---- : lock(&rq->lock); : lock(&p->pi_lock); : lock(&rq->lock); : lock(&port_lock_key); : : *** DEADLOCK *** : : 4 locks held by migration/8/62: : #0: (&p->pi_lock){-.-.}, at: sched_cpu_dying() : #1: (&rq->lock){-.-.}, at: sched_cpu_dying() : #2: (printk_ratelimit_state.lock){....}, at: ___ratelimit() : #3: (console_lock){+.+.}, at: vprintk_emit() : : stack backtrace: : CPU: 8 PID: 62 Comm: migration/8 Not tainted 4.14.0-rc2-next-20170927+ #252 : Call Trace: : dump_stack() : print_circular_bug() : check_prev_add() : ? add_lock_to_list.isra.26() : ? check_usage() : ? kvm_clock_read() : ? kvm_sched_clock_read() : ? sched_clock() : ? check_preemption_disabled() : __lock_acquire() : ? __lock_acquire() : ? add_lock_to_list.isra.26() : ? debug_check_no_locks_freed() : ? memcpy() : lock_acquire() : ? serial8250_console_write() : _raw_spin_lock_irqsave() : ? serial8250_console_write() : serial8250_console_write() : ? serial8250_start_tx() : ? lock_acquire() : ? memcpy() : univ8250_console_write() : console_unlock() : ? __down_trylock_console_sem() : vprintk_emit() : vprintk_default() : vprintk_func() : printk() : ? show_regs_print_info() : ? lock_acquire() : ___ratelimit() : __printk_ratelimit() : select_fallback_rq() : sched_cpu_dying() : ? sched_cpu_starting() : ? rcutree_dying_cpu() : ? sched_cpu_starting() : cpuhp_invoke_callback() : ? cpu_disable_common() : take_cpu_down() : ? trace_hardirqs_off_caller() : ? cpuhp_invoke_callback() : multi_cpu_stop() : ? __this_cpu_preempt_check() : ? cpu_stop_queue_work() : cpu_stopper_thread() : ? cpu_stop_create() : smpboot_thread_fn() : ? sort_range() : ? schedule() : ? __kthread_parkme() : kthread() : ? sort_range() : ? kthread_create_on_node() : ret_from_fork() : process 9121 (trinity-c78) no longer affine to cpu8 : smpboot: CPU 8 is now offline Link: http://lkml.kernel.org/r/20170928120405.18273-1-sergey.senozhatsky@gmail.com Fixes: 6b1d174b0c27b ("ratelimit: extend to print suppressed messages on release") Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Reported-by: Sasha Levin <levinsasha928@gmail.com> Reviewed-by: Petr Mladek <pmladek@suse.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Borislav Petkov <bp@suse.de> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-07lib/mpi: kunmap after finishing accessing bufferStephan Mueller
commit dea3eb8b452e36cf2dd572b0a797915ccf452ae6 upstream. Using sg_miter_start and sg_miter_next, the buffer of an SG is kmap'ed to *buff. The current code calls sg_miter_stop (and thus kunmap) on the SG entry before the last access of *buff. The patch moves the sg_miter_stop call after the last access to *buff to ensure that the memory pointed to by *buff is still mapped. Fixes: 4816c9406430 ("lib/mpi: Fix SG miter leak") Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-02lz4: fix bogus gcc warningGreg Kroah-Hartman
When building lz4 under gcc-7 we get the following bogus warning: CC [M] lib/lz4/lz4hc_compress.o lib/lz4/lz4hc_compress.c: In function ‘lz4hc_compress’: lib/lz4/lz4hc_compress.c:179:42: warning: ‘delta’ may be used uninitialized in this function [-Wmaybe-uninitialized] chaintable[(size_t)(ptr) & MAXD_MASK] = delta; ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^~~~~~~ lib/lz4/lz4hc_compress.c:134:6: note: ‘delta’ was declared here u16 delta; ^~~~~ This doesn't show up in the 4.4-stable tree due to us turning off warnings like this. It also doesn't show up in newer kernel versions as this code was totally rewritten. So for now, to get the 4.9-stable tree to build with 0 warnings on x86 allmodconfig, let's just shut the compiler up by initializing the variable to 0, despite it not really doing anything. To be far, this code is crazy complex, so the fact that gcc can't determine if the variable is really used or not isn't that bad, I'd blame the code here instead of the compiler. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-11lib/Kconfig.debug: fix frv build failureSudip Mukherjee
[ Upstream commit da0510c47519fe0999cffe316e1d370e29f952be ] The build of frv allmodconfig was failing with the errors like: /tmp/cc0JSPc3.s: Assembler messages: /tmp/cc0JSPc3.s:1839: Error: symbol `.LSLT0' is already defined /tmp/cc0JSPc3.s:1842: Error: symbol `.LASLTP0' is already defined /tmp/cc0JSPc3.s:1969: Error: symbol `.LELTP0' is already defined /tmp/cc0JSPc3.s:1970: Error: symbol `.LELT0' is already defined Commit 866ced950bcd ("kbuild: Support split debug info v4") introduced splitting the debug info and keeping that in a separate file. Somehow, the frv-linux gcc did not like that and I am guessing that instead of splitting it started copying. The first report about this is at: https://lists.01.org/pipermail/kbuild-all/2015-July/010527.html. I will try and see if this can work with frv and if still fails I will open a bug report with gcc. But meanwhile this is the easiest option to solve build failure of frv. Fixes: 866ced950bcd ("kbuild: Support split debug info v4") Link: http://lkml.kernel.org/r/1482062348-5352-1-git-send-email-sudipm.mukherjee@gmail.com Signed-off-by: Sudip Mukherjee <sudip.mukherjee@codethink.co.uk> Reported-by: Fengguang Wu <fengguang.wu@intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-21sched/fair, cpumask: Export for_each_cpu_wrap()Peter Zijlstra
commit c6508a39640b9a27fc2bc10cb708152672c82045 upstream. commit c743f0a5c50f2fcbc628526279cfa24f3dabe182 upstream. More users for for_each_cpu_wrap() have appeared. Promote the construct to generic cpumask interface. The implementation is slightly modified to reduce arguments. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Lauro Ramos Venancio <lvenanci@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: lwang@redhat.com Link: http://lkml.kernel.org/r/20170414122005.o35me2h5nowqkxbv@hirez.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05swiotlb: ensure that page-sized mappings are page-alignedNikita Yushchenko
[ Upstream commit 602d9858f07c72eab64f5f00e2fae55f9902cfbe ] Some drivers do depend on page mappings to be page aligned. Swiotlb already enforces such alignment for mappings greater than page, extend that to page-sized mappings as well. Without this fix, nvme hits BUG() in nvme_setup_prps(), because that routine assumes page-aligned mappings. Signed-off-by: Nikita Yushchenko <nikita.yoush@cogentembedded.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Sagi Grimberg <sagi@grimberg.me> Signed-off-by: Konrad Rzeszutek Wilk <konrad@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-29lib/cmdline.c: fix get_options() overflow while parsing rangesIlya Matveychikov
commit a91e0f680bcd9e10c253ae8b62462a38bd48f09f upstream. When using get_options() it's possible to specify a range of numbers, like 1-100500. The problem is that it doesn't track array size while calling internally to get_range() which iterates over the range and fills the memory with numbers. Link: http://lkml.kernel.org/r/2613C75C-B04D-4BFF-82A6-12F97BA0F620@gmail.com Signed-off-by: Ilya V. Matveychikov <matvejchikov@gmail.com> Cc: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-24crypto: Work around deallocated stack frame reference gcc bug on sparc.David Miller
commit d41519a69b35b10af7fda867fb9100df24fdf403 upstream. On sparc, if we have an alloca() like situation, as is the case with SHASH_DESC_ON_STACK(), we can end up referencing deallocated stack memory. The result can be that the value is clobbered if a trap or interrupt arrives at just the right instruction. It only occurs if the function ends returning a value from that alloca() area and that value can be placed into the return value register using a single instruction. For example, in lib/libcrc32c.c:crc32c() we end up with a return sequence like: return %i7+8 lduw [%o5+16], %o0 ! MEM[(u32 *)__shash_desc.1_10 + 16B], %o5 holds the base of the on-stack area allocated for the shash descriptor. But the return released the stack frame and the register window. So if an intererupt arrives between 'return' and 'lduw', then the value read at %o5+16 can be corrupted. Add a data compiler barrier to work around this problem. This is exactly what the gcc fix will end up doing as well, and it absolutely should not change the code generated for other cpus (unless gcc on them has the same bug :-) With crucial insight from Eric Sandeen. Reported-by: Anatoly Pugachev <matorola@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14usercopy: Adjust tests to deal with SMAP/PANKees Cook
commit f5f893c57e37ca730808cb2eee3820abd05e7507 upstream. Under SMAP/PAN/etc, we cannot write directly to userspace memory, so this rearranges the test bytes to get written through copy_to_user(). Additionally drops the bad copy_from_user() test that would trigger a memcpy() against userspace on failure. [arnd: the test module was added in 3.14, and this backported patch should apply cleanly on all version from 3.14 to 4.10. The original patch was in 4.11 on top of a context change I saw the bug triggered with kselftest on a 4.4.y stable kernel] Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-14bpf, arm64: fix jit branch offset related to ldimm64Daniel Borkmann
[ Upstream commit ddc665a4bb4b728b4e6ecec8db1b64efa9184b9c ] When the instruction right before the branch destination is a 64 bit load immediate, we currently calculate the wrong jump offset in the ctx->offset[] array as we only account one instruction slot for the 64 bit load immediate although it uses two BPF instructions. Fix it up by setting the offset into the right slot after we incremented the index. Before (ldimm64 test 1): [...] 00000020: 52800007 mov w7, #0x0 // #0 00000024: d2800060 mov x0, #0x3 // #3 00000028: d2800041 mov x1, #0x2 // #2 0000002c: eb01001f cmp x0, x1 00000030: 54ffff82 b.cs 0x00000020 00000034: d29fffe7 mov x7, #0xffff // #65535 00000038: f2bfffe7 movk x7, #0xffff, lsl #16 0000003c: f2dfffe7 movk x7, #0xffff, lsl #32 00000040: f2ffffe7 movk x7, #0xffff, lsl #48 00000044: d29dddc7 mov x7, #0xeeee // #61166 00000048: f2bdddc7 movk x7, #0xeeee, lsl #16 0000004c: f2ddddc7 movk x7, #0xeeee, lsl #32 00000050: f2fdddc7 movk x7, #0xeeee, lsl #48 [...] After (ldimm64 test 1): [...] 00000020: 52800007 mov w7, #0x0 // #0 00000024: d2800060 mov x0, #0x3 // #3 00000028: d2800041 mov x1, #0x2 // #2 0000002c: eb01001f cmp x0, x1 00000030: 540000a2 b.cs 0x00000044 00000034: d29fffe7 mov x7, #0xffff // #65535 00000038: f2bfffe7 movk x7, #0xffff, lsl #16 0000003c: f2dfffe7 movk x7, #0xffff, lsl #32 00000040: f2ffffe7 movk x7, #0xffff, lsl #48 00000044: d29dddc7 mov x7, #0xeeee // #61166 00000048: f2bdddc7 movk x7, #0xeeee, lsl #16 0000004c: f2ddddc7 movk x7, #0xeeee, lsl #32 00000050: f2fdddc7 movk x7, #0xeeee, lsl #48 [...] Also, add a couple of test cases to make sure JITs pass this test. Tested on Cavium ThunderX ARMv8. The added test cases all pass after the fix. Fixes: 8eee539ddea0 ("arm64: bpf: fix out-of-bounds read in bpf2a64_offset()") Reported-by: David S. Miller <davem@davemloft.net> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@kernel.org> Cc: Xi Wang <xi.wang@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-21new privimitive: iov_iter_revert()Al Viro
commit 27c0e3748e41ca79171ffa3e97415a20af6facd0 upstream. opposite to iov_iter_advance(); the caller is responsible for never using it to move back past the initial position. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-08lib/syscall: Clear return values when no stackKees Cook
commit 854fbd6e5f60fe99e8e3a569865409fca378f143 upstream. Commit: aa1f1a639621 ("lib/syscall: Pin the task stack in collect_syscall()") ... added logic to handle a process stack not existing, but left sp and pc uninitialized, which can be later reported via /proc/$pid/syscall for zombie processes, potentially exposing kernel memory to userspace. Zombie /proc/$pid/syscall before: -1 0xffffffff9a060100 0xffff92f42d6ad900 Zombie /proc/$pid/syscall after: -1 0x0 0x0 Reported-by: Robert Święcki <robert@swiecki.net> Signed-off-by: Kees Cook <keescook@chromium.org> Reviewed-by: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: aa1f1a639621 ("lib/syscall: Pin the task stack in collect_syscall()") Link: http://lkml.kernel.org/r/20170323224616.GA92694@beast Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-26swiotlb: Add swiotlb=noforce debug optionGeert Uytterhoeven
commit fff5d99225107f5f13fe4a9805adc2a1c4b5fb00 upstream. On architectures like arm64, swiotlb is tied intimately to the core architecture DMA support. In addition, ZONE_DMA cannot be disabled. To aid debugging and catch devices not supporting DMA to memory outside the 32-bit address space, add a kernel command line option "swiotlb=noforce", which disables the use of bounce buffers. If specified, trying to map memory that cannot be used with DMA will fail, and a rate-limited warning will be printed. Note that io_tlb_nslabs is set to 1, which is the minimal supported value. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-26swiotlb: Convert swiotlb_force from int to enumGeert Uytterhoeven
commit ae7871be189cb41184f1e05742b4a99e2c59774d upstream. Convert the flag swiotlb_force from an int to an enum, to prepare for the advent of more possible values. Suggested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-19fix a fencepost error in pipe_advance()Al Viro
commit b9dc6f65bc5e232d1c05fe34b5daadc7e8bbf1fb upstream. The logics in pipe_advance() used to release all buffers past the new position failed in cases when the number of buffers to release was equal to pipe->buffers. If that happened, none of them had been released, leaving pipe full. Worse, it was trivial to trigger and we end up with pipe full of uninitialized pages. IOW, it's an infoleak. Reported-by: "Alan J. Wylie" <alan@wylie.me.uk> Tested-by: "Alan J. Wylie" <alan@wylie.me.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-09Revert "radix tree test suite: fix compilation"Linus Torvalds
This reverts commit 53855d10f4567a0577360b6448d52a863929775b. It shouldn't have come in yet - it depends on the changes in linux-next that will come in during the next merge window. As Matthew Wilcox says, the test suite is broken with the current state without the revert. Requested-by: Matthew Wilcox <mawilcox@microsoft.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-12-07radix tree test suite: fix compilationMatthew Wilcox
Patch "lib/radix-tree: Convert to hotplug state machine" breaks the test suite as it adds a call to cpuhp_setup_state_nocalls() which is not currently emulated in the test suite. Add it, and delete the emulation of the old CPU hotplug mechanism. Link: http://lkml.kernel.org/r/1480369871-5271-36-git-send-email-mawilcox@linuxonhyperv.com Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com> Tested-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Matthew Wilcox <mawilcox@microsoft.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-12-07Merge branch 'locking-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking fixes from Ingo Molnar: "Two rtmutex race fixes (which miraculously never triggered, that we know of), plus two lockdep printk formatting regression fixes" * 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: lockdep: Fix report formatting locking/rtmutex: Use READ_ONCE() in rt_mutex_owner() locking/rtmutex: Prevent dequeue vs. unlock race locking/selftest: Fix output since KERN_CONT changes
2016-11-30kasan: support use-after-scope detectionDmitry Vyukov
Gcc revision 241896 implements use-after-scope detection. Will be available in gcc 7. Support it in KASAN. Gcc emits 2 new callbacks to poison/unpoison large stack objects when they go in/out of scope. Implement the callbacks and add a test. [dvyukov@google.com: v3] Link: http://lkml.kernel.org/r/1479998292-144502-1-git-send-email-dvyukov@google.com Link: http://lkml.kernel.org/r/1479226045-145148-1-git-send-email-dvyukov@google.com Signed-off-by: Dmitry Vyukov <dvyukov@google.com> Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Alexander Potapenko <glider@google.com> Cc: <stable@vger.kernel.org> [4.0+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-30lib/debugobjects: export for use in modulesChris Wilson
Drivers, or other modules, that use a mixture of objects (especially objects embedded within other objects) would like to take advantage of the debugobjects facilities to help catch misuse. Currently, the debugobjects interface is only available to builtin drivers and requires a set of EXPORT_SYMBOL_GPL for use by modules. I am using the debugobjects in i915.ko to try and catch some invalid operations on embedded objects. The problem currently only presents itself across module unload so forcing i915 to be builtin is not an option. Link: http://lkml.kernel.org/r/20161122143039.6433-1-chris@chris-wilson.co.uk Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: "Du, Changbin" <changbin.du@intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-25locking/selftest: Fix output since KERN_CONT changesMichael Ellerman
Since the KERN_CONT changes the locking-selftest output is messed up, eg: ---------------------------------------------------------------------------- | spin |wlock |rlock |mutex | wsem | rsem | -------------------------------------------------------------------------- A-A deadlock: ok | ok | ok | ok | ok | ok | Use pr_cont() to get it looking normal again: ---------------------------------------------------------------------------- | spin |wlock |rlock |mutex | wsem | rsem | -------------------------------------------------------------------------- A-A deadlock: ok | ok | ok | ok | ok | ok | Reported-by: Christian Kujau <lists@nerdbynature.de> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linuxppc-dev@ozlabs.org Link: http://lkml.kernel.org/r/1480027528-934-1-git-send-email-mpe@ellerman.id.au Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-11-25mpi: Fix NULL ptr dereference in mpi_powm() [ver #3]Andrey Ryabinin
This fixes CVE-2016-8650. If mpi_powm() is given a zero exponent, it wants to immediately return either 1 or 0, depending on the modulus. However, if the result was initalised with zero limb space, no limbs space is allocated and a NULL-pointer exception ensues. Fix this by allocating a minimal amount of limb space for the result when the 0-exponent case when the result is 1 and not touching the limb space when the result is 0. This affects the use of RSA keys and X.509 certificates that carry them. BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<ffffffff8138ce5d>] mpi_powm+0x32/0x7e6 PGD 0 Oops: 0002 [#1] SMP Modules linked in: CPU: 3 PID: 3014 Comm: keyctl Not tainted 4.9.0-rc6-fscache+ #278 Hardware name: ASUS All Series/H97-PLUS, BIOS 2306 10/09/2014 task: ffff8804011944c0 task.stack: ffff880401294000 RIP: 0010:[<ffffffff8138ce5d>] [<ffffffff8138ce5d>] mpi_powm+0x32/0x7e6 RSP: 0018:ffff880401297ad8 EFLAGS: 00010212 RAX: 0000000000000000 RBX: ffff88040868bec0 RCX: ffff88040868bba0 RDX: ffff88040868b260 RSI: ffff88040868bec0 RDI: ffff88040868bee0 RBP: ffff880401297ba8 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000047 R11: ffffffff8183b210 R12: 0000000000000000 R13: ffff8804087c7600 R14: 000000000000001f R15: ffff880401297c50 FS: 00007f7a7918c700(0000) GS:ffff88041fb80000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000000 CR3: 0000000401250000 CR4: 00000000001406e0 Stack: ffff88040868bec0 0000000000000020 ffff880401297b00 ffffffff81376cd4 0000000000000100 ffff880401297b10 ffffffff81376d12 ffff880401297b30 ffffffff81376f37 0000000000000100 0000000000000000 ffff880401297ba8 Call Trace: [<ffffffff81376cd4>] ? __sg_page_iter_next+0x43/0x66 [<ffffffff81376d12>] ? sg_miter_get_next_page+0x1b/0x5d [<ffffffff81376f37>] ? sg_miter_next+0x17/0xbd [<ffffffff8138ba3a>] ? mpi_read_raw_from_sgl+0xf2/0x146 [<ffffffff8132a95c>] rsa_verify+0x9d/0xee [<ffffffff8132acca>] ? pkcs1pad_sg_set_buf+0x2e/0xbb [<ffffffff8132af40>] pkcs1pad_verify+0xc0/0xe1 [<ffffffff8133cb5e>] public_key_verify_signature+0x1b0/0x228 [<ffffffff8133d974>] x509_check_for_self_signed+0xa1/0xc4 [<ffffffff8133cdde>] x509_cert_parse+0x167/0x1a1 [<ffffffff8133d609>] x509_key_preparse+0x21/0x1a1 [<ffffffff8133c3d7>] asymmetric_key_preparse+0x34/0x61 [<ffffffff812fc9f3>] key_create_or_update+0x145/0x399 [<ffffffff812fe227>] SyS_add_key+0x154/0x19e [<ffffffff81001c2b>] do_syscall_64+0x80/0x191 [<ffffffff816825e4>] entry_SYSCALL64_slow_path+0x25/0x25 Code: 56 41 55 41 54 53 48 81 ec a8 00 00 00 44 8b 71 04 8b 42 04 4c 8b 67 18 45 85 f6 89 45 80 0f 84 b4 06 00 00 85 c0 75 2f 41 ff ce <49> c7 04 24 01 00 00 00 b0 01 75 0b 48 8b 41 18 48 83 38 01 0f RIP [<ffffffff8138ce5d>] mpi_powm+0x32/0x7e6 RSP <ffff880401297ad8> CR2: 0000000000000000 ---[ end trace d82015255d4a5d8d ]--- Basically, this is a backport of a libgcrypt patch: http://git.gnupg.org/cgi-bin/gitweb.cgi?p=libgcrypt.git;a=patch;h=6e1adb05d290aeeb1c230c763970695f4a538526 Fixes: cdec9cb5167a ("crypto: GnuPG based MPI lib - source files (part 1)") Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Signed-off-by: David Howells <dhowells@redhat.com> cc: Dmitry Kasatkin <dmitry.kasatkin@gmail.com> cc: linux-ima-devel@lists.sourceforge.net cc: stable@vger.kernel.org Signed-off-by: James Morris <james.l.morris@oracle.com>
2016-11-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull sparc fixes from David Miller: 1) With modern networking cards we can run out of 32-bit DMA space, so support 64-bit DMA addressing when possible on sparc64. From Dave Tushar. 2) Some signal frame validation checks are inverted on sparc32, fix from Andreas Larsson. 3) Lockdep tables can get too large in some circumstances on sparc64, add a way to adjust the size a bit. From Babu Moger. 4) Fix NUMA node probing on some sun4v systems, from Thomas Tai. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc: drop duplicate header scatterlist.h lockdep: Limit static allocations if PROVE_LOCKING_SMALL is defined config: Adding the new config parameter CONFIG_PROVE_LOCKING_SMALL for sparc sunbmac: Fix compiler warning sunqe: Fix compiler warnings sparc64: Enable 64-bit DMA sparc64: Enable sun4v dma ops to use IOMMU v2 APIs sparc64: Bind PCIe devices to use IOMMU v2 service sparc64: Initialize iommu_map_table and iommu_pool sparc64: Add ATU (new IOMMU) support sparc64: Add FORCE_MAX_ZONEORDER and default to 13 sparc64: fix compile warning section mismatch in find_node() sparc32: Fix inverted invalid_frame_pointer checks on sigreturns sparc64: Fix find_node warning if numa node cannot be found
2016-11-18config: Adding the new config parameter CONFIG_PROVE_LOCKING_SMALL for sparcBabu Moger
This new config parameter limits the space used for "Lock debugging: prove locking correctness" by about 4MB. The current sparc systems have the limitation of 32MB size for kernel size including .text, .data and .bss sections. With PROVE_LOCKING feature, the kernel size could grow beyond this limit and causing system boot-up issues. With this option, kernel limits the size of the entries of lock_chains, stack_trace etc., so that kernel fits in required size limit. This is not visible to user and only used for sparc. Signed-off-by: Babu Moger <babu.moger@oracle.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-11-17fix iov_iter_advance() for ITER_PIPEAbhi Das
iov_iter_advance() needs to decrement iter->count by the number of bytes we'd moved beyond. Normal flavours do that, but ITER_PIPE doesn't and ITER_PIPE generic_file_read_iter() for O_DIRECT files ends up with a bogus fallback to page cache read, resulting in incorrect values for file offset and bytes read. Signed-off-by: Abhi Das <adas@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-11-11lib/stackdepot: export save/fetch stack for driversChris Wilson
Some drivers would like to record stacktraces in order to aide leak tracing. As stackdepot already provides a facility for only storing the unique traces, thereby reducing the memory required, export that functionality for use by drivers. The code was originally created for KASAN and moved under lib in commit cd11016e5f521 ("mm, kasan: stackdepot implementation. Enable stackdepot for SLAB") so that it could be shared with mm/. In turn, we want to share it now with drivers. Link: http://lkml.kernel.org/r/20161108133209.22704-1-chris@chris-wilson.co.uk Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Alexander Potapenko <glider@google.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "Lots of fixes, mostly drivers as is usually the case. 1) Don't treat zero DMA address as invalid in vmxnet3, from Alexey Khoroshilov. 2) Fix element timeouts in netfilter's nft_dynset, from Anders K. Pedersen. 3) Don't put aead_req crypto struct on the stack in mac80211, from Ard Biesheuvel. 4) Several uninitialized variable warning fixes from Arnd Bergmann. 5) Fix memory leak in cxgb4, from Colin Ian King. 6) Fix bpf handling of VLAN header push/pop, from Daniel Borkmann. 7) Several VRF semantic fixes from David Ahern. 8) Set skb->protocol properly in ip6_tnl_xmit(), from Eli Cooper. 9) Socket needs to be locked in udp_disconnect(), from Eric Dumazet. 10) Div-by-zero on 32-bit fix in mlx4 driver, from Eugenia Emantayev. 11) Fix stale link state during failover in NCSCI driver, from Gavin Shan. 12) Fix netdev lower adjacency list traversal, from Ido Schimmel. 13) Propvide proper handle when emitting notifications of filter deletes, from Jamal Hadi Salim. 14) Memory leaks and big-endian issues in rtl8xxxu, from Jes Sorensen. 15) Fix DESYNC_FACTOR handling in ipv6, from Jiri Bohac. 16) Several routing offload fixes in mlxsw driver, from Jiri Pirko. 17) Fix broadcast sync problem in TIPC, from Jon Paul Maloy. 18) Validate chunk len before using it in SCTP, from Marcelo Ricardo Leitner. 19) Revert a netns locking change that causes regressions, from Paul Moore. 20) Add recursion limit to GRO handling, from Sabrina Dubroca. 21) GFP_KERNEL in irq context fix in ibmvnic, from Thomas Falcon. 22) Avoid accessing stale vxlan/geneve socket in data path, from Pravin Shelar" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (189 commits) geneve: avoid using stale geneve socket. vxlan: avoid using stale vxlan socket. qede: Fix out-of-bound fastpath memory access net: phy: dp83848: add dp83822 PHY support enic: fix rq disable tipc: fix broadcast link synchronization problem ibmvnic: Fix missing brackets in init_sub_crq_irqs ibmvnic: Fix releasing of sub-CRQ IRQs in interrupt context Revert "ibmvnic: Fix releasing of sub-CRQ IRQs in interrupt context" arch/powerpc: Update parameters for csum_tcpudp_magic & csum_tcpudp_nofold net/mlx4_en: Save slave ethtool stats command net/mlx4_en: Fix potential deadlock in port statistics flow net/mlx4: Fix firmware command timeout during interrupt test net/mlx4_core: Do not access comm channel if it has not yet been initialized net/mlx4_en: Fix panic during reboot net/mlx4_en: Process all completions in RX rings after port goes up net/mlx4_en: Resolve dividing by zero in 32-bit system net/mlx4_core: Change the default value of enable_qos net/mlx4_core: Avoid setting ports to auto when only one port type is supported net/mlx4_core: Fix the resource-type enum in res tracker to conform to FW spec ...
