path: root/lib
2008-12-17driver core: add newlines to debugging enabled/disabled messagesMarcel Holtmann
Both messages are missing the newline and thus dmesg output gets scrambled. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-17driver core: fix using 'ret' variable in unregister_dynamic_debug_moduleJohann Felix Soden
The 'ret' variable is assigned, but not used in the return statement. Fix this. Signed-off-by: Johann Felix Soden <johfel@users.sourceforge.net> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-10lib/idr.c: Fix bug introduced by RCU fixManfred Spraul
The last patch to lib/idr.c caused a bug if idr_get_new_above() was called on an empty idr. Usually, nodes stay on the same layer. New layers are added to the top of the tree. The exception is idr_get_new_above() on an empty tree: In this case, the new root node is first added on layer 0, then moved upwards. p->layer was not updated. As usual: You shall never rely on the source code comments, they will only mislead you. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-10revert "percpu_counter: new function percpu_counter_sum_and_set"Andrew Morton
Revert commit e8ced39d5e8911c662d4d69a342b9d053eaaac4e Author: Mingming Cao <cmm@us.ibm.com> Date: Fri Jul 11 19:27:31 2008 -0400 percpu_counter: new function percpu_counter_sum_and_set As described in revert "percpu counter: clean up percpu_counter_sum_and_set()" the new percpu_counter_sum_and_set() is racy against updates to the cpu-local accumulators on other CPUs. Revert that change. This means that ext4 will be slow again. But correct. Reported-by: Eric Dumazet <dada1@cosmosbay.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mingming Cao <cmm@us.ibm.com> Cc: <linux-ext4@vger.kernel.org> Cc: <stable@kernel.org> [2.6.27.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-10revert "percpu counter: clean up percpu_counter_sum_and_set()"Andrew Morton
Revert commit 1f7c14c62ce63805f9574664a6c6de3633d4a354 Author: Mingming Cao <cmm@us.ibm.com> Date: Thu Oct 9 12:50:59 2008 -0400 percpu counter: clean up percpu_counter_sum_and_set() Before this patch we had the following: percpu_counter_sum(): return the percpu_counter's value percpu_counter_sum_and_set(): return the percpu_counter's value, copying that value into the central value and zeroing the per-cpu counters before returning. After this patch, percpu_counter_sum_and_set() has gone, and percpu_counter_sum() gets the old percpu_counter_sum_and_set() functionality. Problem is, as Eric points out, the old percpu_counter_sum_and_set() functionality was racy and wrong. It zeroes out counters on "other" cpus, without holding any locks which will prevent races agaist updates from those other CPUS. This patch reverts 1f7c14c62ce63805f9574664a6c6de3633d4a354. This means that percpu_counter_sum_and_set() still has the race, but percpu_counter_sum() does not. Note that this is not a simple revert - ext4 has since started using percpu_counter_sum() for its dirty_blocks counter as well. Note that this revert patch changes percpu_counter_sum() semantics. Before the patch, a call to percpu_counter_sum() will bring the counter's central counter mostly up-to-date, so a following percpu_counter_read() will return a close value. After this patch, a call to percpu_counter_sum() will leave the counter's central accumulator unaltered, so a subsequent call to percpu_counter_read() can now return a significantly inaccurate result. If there is any code in the tree which was introduced after e8ced39d5e8911c662d4d69a342b9d053eaaac4e was merged, and which depends upon the new percpu_counter_sum() semantics, that code will break. Reported-by: Eric Dumazet <dada1@cosmosbay.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mingming Cao <cmm@us.ibm.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-10percpu_counter: fix CPU unplug race in percpu_counter_destroy()Eric Dumazet
We should first delete the counter from percpu_counters list before freeing memory, or a percpu_counter_hotcpu_callback() could dereference a NULL pointer. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Acked-by: David S. Miller <davem@davemloft.net> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-01lib/idr.c: fix rcu related race with idr_findManfred Spraul
2nd part of the fixes needed for http://bugzilla.kernel.org/show_bug.cgi?id=11796. When the idr tree is either grown or shrunk, then the update to the number of layers and the top pointer were not atomic. This race caused crashes. The attached patch fixes that by replicating the layers counter in each layer, thus idr_find doesn't need idp->layers anymore. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Clement Calmels <cboulte@gmail.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Pierre Peiffer <peifferp@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-19lib/scatterlist.c: fix kunmap() argument in sg_miter_stop()Arjan van de Ven
kunmap() takes as argument the struct page that orginally got kmap()'d, however the sg_miter_stop() function passed it the kernel virtual address instead, resulting in weird stuff. Somehow I ended up fixing this bug by accident while looking for a bug in the same area. Reported-by: kerneloops.org Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: <stable@kernel.org> [2.6.27.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-17swiotlb: use coherent_dma_mask in alloc_coherentFUJITA Tomonori
Impact: fix DMA buffer allocation coherency bug in certain configs This patch fixes swiotlb to use dev->coherent_dma_mask in swiotlb_alloc_coherent(). coherent_dma_mask is a subset of dma_mask (equal to it most of the time), enumerating the address range that a given device is able to DMA to/from in a cache-coherent way. But currently, swiotlb uses dev->dma_mask in alloc_coherent() implicitly via address_needs_mapping(), but alloc_coherent is really supposed to use coherent_dma_mask. This bug could break drivers that uses smaller coherent_dma_mask than dma_mask (though the current code works for the majority that use the same mask for coherent_dma_mask and dma_mask). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: tony.luck@intel.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-09cpumask: introduce new API, without changing anything, v3Rusty Russell
Impact: cleanup Clean up based on feedback from Andrew Morton and others: - change to inline functions instead of macros - add __init to bootmem method - add a missing debug check Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-07cpumask: new API, v2Rusty Russell
- add cpumask_of() - add free_bootmem_cpumask_var() Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-06cpumask: introduce new API, without changing anythingRusty Russell
Impact: introduce new APIs We want to deprecate cpumasks on the stack, as we are headed for gynormous numbers of CPUs. Eventually, we want to head towards an undefined 'struct cpumask' so they can never be declared on stack. 1) New cpumask functions which take pointers instead of copies. (cpus_* -> cpumask_*) 2) Several new helpers to reduce requirements for temporary cpumasks (cpumask_first_and, cpumask_next_and, cpumask_any_and) 3) Helpers for declaring cpumasks on or offstack for large NR_CPUS (cpumask_var_t, alloc_cpumask_var and free_cpumask_var) 4) 'struct cpumask' for explicitness and to mark new-style code. 5) Make iterator functions stop at nr_cpu_ids (a runtime constant), not NR_CPUS for time efficiency and for smaller dynamic allocations in future. 6) cpumask_copy() so we can allocate less than a full cpumask eventually (for alloc_cpumask_var), and so we can eliminate the 'struct cpumask' definition eventually. 7) work_on_cpu() helper for doing task on a CPU, rather than saving old cpumask for current thread and manipulating it. 8) smp_call_function_many() which is smp_call_function_mask() except taking a cpumask pointer. Note that this patch simply introduces the new functions and leaves the obsolescent ones in place. This is to simplify the transition patches. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-29Driver core: fix 'dynamic_debug' cmd line parameterJason Baron
In testing 2.6.28-rc1, I found that passing 'dynamic_printk' on the command line didn't activate the debug code. The problem is that dynamic_printk_setup() (which activates the debugging) is being called before dynamic_printk_init() is called (which initializes infrastructure). Fix this by setting setting the state to 'DYNAMIC_ENABLED_ALL' in dynamic_printk_setup(), which will also cause all subsequent modules to have debugging automatically started, which is probably the behavior we want. Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-28Merge branch 'tracing-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (31 commits) ftrace: fix current_tracer error return tracing: fix a build error on alpha ftrace: use a real variable for ftrace_nop in x86 tracing/ftrace: make boot tracer select the sched_switch tracer tracepoint: check if the probe has been registered asm-generic: define DIE_OOPS in asm-generic trace: fix printk warning for u64 ftrace: warning in kernel/trace/ftrace.c ftrace: fix build failure ftrace, powerpc, sparc64, x86: remove notrace from arch ftrace file ftrace: remove ftrace hash ftrace: remove mcount set ftrace: remove daemon ftrace: disable dynamic ftrace for all archs that use daemon ftrace: add ftrace warn on to disable ftrace ftrace: only have ftrace_kill atomic ftrace: use probe_kernel ftrace: comment arch ftrace code ftrace: return error on failed modified text. ftrace: dynamic ftrace process only text section ...
2008-10-28Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: lockdep: fix irqs on/off ip tracing lockdep: minor fix for debug_show_all_locks() x86: restore the old swiotlb alloc_coherent behavior x86: use GFP_DMA for 24bit coherent_dma_mask swiotlb: remove panic for alloc_coherent failure xen: compilation fix of drivers/xen/events.c on IA64 xen: portability clean up and some minor clean up for xencomm.c xen: don't reload cr3 on suspend kernel/resource: fix reserve_region_with_split() section mismatch printk: remove unused code from kernel/printk.c
2008-10-27Merge commit 'v2.6.28-rc2' into tracing/urgentIngo Molnar
2008-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (21 commits) [SCSI] sd: fix computation of the full size of the device [SCSI] lib: string_get_size(): don't hang on zero; no decimals on exact [SCSI] sun3x_esp: Convert && to || [SCSI] sd: remove command-size switching code [SCSI] 3w-9xxx: remove unnecessary local_irq_save/restore for scsi sg copy API [SCSI] 3w-xxxx: remove unnecessary local_irq_save/restore for scsi sg copy API [SCSI] fix netlink kernel-doc [SCSI] sd: Fix handling of NO_SENSE check condition [SCSI] export busy state via q->lld_busy_fn() [SCSI] refactor sdev/starget/shost busy checking [SCSI] mptfusion: Increase scsi-timeouts, similariy to the LSI 4.x driver. [SCSI] aic7xxx: Take the LED out of diagnostic mode on PM resume [SCSI] aic79xx: user visible misuse wrong SI units (not disk size!) [SCSI] ipr: use memory_read_from_buffer() [SCSI] aic79xx: fix shadowed variables [SCSI] aic79xx: fix shadowed variables, add statics [SCSI] aic7xxx: update *_shipped files [SCSI] aic7xxx: update .reg files [SCSI] aic7xxx: introduce "dont_generate_debug_code" keyword in aicasm parser [SCSI] scsi_dh: Initialize path state to be passive when path is not owned ...
2008-10-23swiotlb: remove panic for alloc_coherent failureFUJITA Tomonori
swiotlb_alloc_coherent calls panic() when allocated swiotlb pages is not fit for a device's dma mask. However, alloc_coherent failure is not a disaster at all. AFAIK, none of other x86 and IA64 IOMMU implementations don't crash in case of alloc_coherent failure. There are some drivers that don't check alloc_coherent failure but not many (about ten and I've already started to fix some of them). alloc_coherent returns NULL in case of failure so it's likely that these guilty drivers crash immediately. So swiotlb doesn't need to call panic() just for them. Reported-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Tested-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-23[SCSI] lib: string_get_size(): don't hang on zero; no decimals on exactH. Peter Anvin
We would hang forever when passing a zero to string_get_size(). Furthermore, string_get_size() would produce decimals on a value small enough to be exact. Finally, a few formatting issues are inconsistent with standard SI style guidelines. - If the value is less than the divisor, skip the entire rounding step. This prints out all small values including zero as integers, without decimals. - Add a space between the value and the symbol for the unit, consistent with standard SI practice. - Lower case k in kB since we are talking about powers of 10. - Finally, change "int" to "unsigned int" in one place to shut up a gcc warning when compiling the code out-of-kernel for testing. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-23Merge branch 'for-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb * 'for-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb: (47 commits) uwb: wrong sizeof argument in mac address compare uwb: don't use printk_ratelimit() so often uwb: use kcalloc where appropriate uwb: use time_after() when purging stale beacons uwb: add credits for the original developers of the UWB/WUSB/WLP subsystems uwb: add entries in the MAINTAINERS file uwb: depend on EXPERIMENTAL wusb: wusb-cbaf (CBA driver) sysfs ABI simplification uwb: document UWB and WUSB sysfs files uwb: add symlinks in sysfs between radio controllers and PALs uwb: dont tranmit identification IEs uwb: i1480/GUWA100U: fix firmware download issues uwb: i1480: remove MAC/PHY information checking function uwb: add Intel i1480 HWA to the UWB RC quirk table uwb: disable command/event filtering for D-Link DUB-1210 uwb: initialize the debug sub-system uwb: Fix handling IEs with empty IE data in uwb_est_get_size() wusb: fix bmRequestType for Abort RPipe request wusb: fix error path for wusb_set_dev_addr() wusb: add HWA host controller driver ...
2008-10-22Merge branch 'tracing/ftrace' into tracing/urgentIngo Molnar
2008-10-20ftrace: rename FTRACE to FUNCTION_TRACERSteven Rostedt
Due to confusion between the ftrace infrastructure and the gcc profiling tracer "ftrace", this patch renames the config options from FTRACE to FUNCTION_TRACER. The other two names that are offspring from FTRACE DYNAMIC_FTRACE and FTRACE_MCOUNT_RECORD will stay the same. This patch was generated mostly by script, and partially by hand. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-20Implement %pR to print struct resource contentLinus Torvalds
Add a %pR option to the kernel vsnprintf that prints the range of addresses inside a struct resource passed by pointer. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20bitmask: remove bitmap_scnprintf_len()Lai Jiangshan
bitmap_scnprintf_len() is not used now, so we remove it. Otherwise we have to maintain it and make its return value always equal to bitmap_scnprintf()'s return value. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Paul Menage <menage@google.com> Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20Merge branch 'master' into for-upstreamDavid Vrabel
Conflicts: Documentation/ABI/testing/sysfs-bus-usb drivers/Makefile
2008-10-17block: add BIG FAT WARNING to CONFIG_DEBUG_BLOCK_EXT_DEVTTejun Heo
CONFIG_DEBUG_BLOCK_EXT_DEVT can break booting even on some modern distros. Add BIG FAT WARNING to keep people at a safe distance. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-16lib: remove defining macros for strict_strto??Harvey Harrison
Open-code them rather than using defining macros. The function bodies are now next to their kerneldoc comments as a bonus. Add casts to the signed cases as they call into the unsigned versions. Avoids the sparse warnings: lib/vsprintf.c:249:1: warning: incorrect type in argument 3 (different signedness) lib/vsprintf.c:249:1: expected unsigned long *res lib/vsprintf.c:249:1: got long *res lib/vsprintf.c:249:1: warning: incorrect type in argument 3 (different signedness) lib/vsprintf.c:249:1: expected unsigned long *res lib/vsprintf.c:249:1: got long *res lib/vsprintf.c:251:1: warning: incorrect type in argument 3 (different signedness) lib/vsprintf.c:251:1: expected unsigned long long *res lib/vsprintf.c:251:1: got long long *res lib/vsprintf.c:251:1: warning: incorrect type in argument 3 (different signedness) lib/vsprintf.c:251:1: expected unsigned long long *res lib/vsprintf.c:251:1: got long long *res Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16lib: trivial whitespace tidyHarvey Harrison
Remove extra lines before the EXPORT_SYMBOL()s Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16lib: pull base-guessing logic to helper functionHarvey Harrison
The default base is 10 unless there is a leading zero, in which case the base will be guessed as 8. The base will only be guesed as 16 when the string starts with '0x' the third character is a valid hex digit. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (46 commits) UIO: Fix mapping of logical and virtual memory UIO: add automata sercos3 pci card support UIO: Change driver name of uio_pdrv UIO: Add alignment warnings for uio-mem Driver core: add bus_sort_breadthfirst() function NET: convert the phy_device file to use bus_find_device_by_name kobject: Cleanup kobject_rename and !CONFIG_SYSFS kobject: Fix kobject_rename and !CONFIG_SYSFS sysfs: Make dir and name args to sysfs_notify() const platform: add new device registration helper sysfs: use ilookup5() instead of ilookup5_nowait() PNP: create device attributes via default device attributes Driver core: make bus_find_device_by_name() more robust usb: turn dev_warn+WARN_ON combos into dev_WARN debug: use dev_WARN() rather than WARN_ON() in device_pm_add() debug: Introduce a dev_WARN() function sysfs: fix deadlock device model: Do a quickcheck for driver binding before doing an expensive check Driver core: Fix cleanup in device_create_vargs(). Driver core: Clarify device cleanup. ...
2008-10-16introduce generic iommu_num_pages functionJoerg Roedel
This patch introduces the generic iommu_num_pages function. It can be used by a given memory area. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16Add kerneldoc documentation for new printk format extensionsAndi Kleen
Add documentation in kerneldoc for new printk format extensions This patch documents the new %pS/%pF options in printk in kernel doc. Hope I didn't miss any other extension. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16Kconfig: eliminate "def_bool n" constructsJan Beulich
Using "def_bool n" is pointless, simply using bool here appears more appropriate. Further, retaining such options that don't have a prompt and aren't selected by anything seems also at least questionable. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Tony Luck <tony.luck@intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16kobject: Cleanup kobject_rename and !CONFIG_SYSFSEric W. Biederman
It finally dawned on me what the clean fix to sysfs_rename_dir calling kobject_set_name is. Move the work into kobject_rename where it belongs. The callers serialize us anyway so this is safe. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-16kobject: Fix kobject_rename and !CONFIG_SYSFSEric W. Biederman
When looking at kobject_rename I found two bugs with that exist when sysfs support is disabled in the kernel. kobject_rename does not change the name on the kobject when sysfs support is not compiled in. kobject_rename without locking attempts to check the validity of a rename operation, which the kobject layer simply does not have the infrastructure to do. This patch documents the previously unstated requirement of kobject_rename that is the responsibility of the caller to provide mutual exclusion and to be certain that the new_name for the kobject is valid. This patch modifies sysfs_rename_dir in !CONFIG_SYSFS case to call kobject_set_name to actually change the kobject_name. This patch removes the bogus and misleading check in kobject_rename that attempts to see if a rename is valid. The check is bogus because we do not have the proper locking. The check is misleading because it looks like we can and do perform checking at the kobject level that we don't. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-16driver core: basic infrastructure for per-module dynamic debug messagesJason Baron
Base infrastructure to enable per-module debug messages. I've introduced CONFIG_DYNAMIC_PRINTK_DEBUG, which when enabled centralizes control of debugging statements on a per-module basis in one /proc file, currently, <debugfs>/dynamic_printk/modules. When, CONFIG_DYNAMIC_PRINTK_DEBUG, is not set, debugging statements can still be enabled as before, often by defining 'DEBUG' for the proper compilation unit. Thus, this patch set has no affect when CONFIG_DYNAMIC_PRINTK_DEBUG is not set. The infrastructure currently ties into all pr_debug() and dev_dbg() calls. That is, if CONFIG_DYNAMIC_PRINTK_DEBUG is set, all pr_debug() and dev_dbg() calls can be dynamically enabled/disabled on a per-module basis. Future plans include extending this functionality to subsystems, that define their own debug levels and flags. Usage: Dynamic debugging is controlled by the debugfs file, <debugfs>/dynamic_printk/modules. This file contains a list of the modules that can be enabled. The format of the file is as follows: <module_name> <enabled=0/1> . . . <module_name> : Name of the module in which the debug call resides <enabled=0/1> : whether the messages are enabled or not For example: snd_hda_intel enabled=0 fixup enabled=1 driver enabled=0 Enable a module: $echo "set enabled=1 <module_name>" > dynamic_printk/modules Disable a module: $echo "set enabled=0 <module_name>" > dynamic_printk/modules Enable all modules: $echo "set enabled=1 all" > dynamic_printk/modules Disable all modules: $echo "set enabled=0 all" > dynamic_printk/modules Finally, passing "dynamic_printk" at the command line enables debugging for all modules. This mode can be turned off via the above disable command. [gkh: minor cleanups and tweaks to make the build work quietly] Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-13vfs: Use const for kernel parser tableSteven Whitehouse
This is a much better version of a previous patch to make the parser tables constant. Rather than changing the typedef, we put the "const" in all the various places where its required, allowing the __initconst exception for nfsroot which was the cause of the previous trouble. This was posted for review some time ago and I believe its been in -mm since then. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Alexander Viro <aviro@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-12Merge branches 'x86/xen', 'x86/build', 'x86/microcode', 'x86/mm-debug-v2', ↵Ingo Molnar
'x86/memory-corruption-check', 'x86/early-printk', 'x86/xsave', 'x86/ptrace-v2', 'x86/quirks', 'x86/setup', 'x86/spinlocks' and 'x86/signal' into x86/core-v2
2008-10-12Merge branch 'linus' into x86/xenIngo Molnar
Conflicts: arch/x86/kernel/cpu/common.c arch/x86/kernel/process_64.c arch/x86/xen/enlighten.c
2008-10-11Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (43 commits) ext4: Rename ext4dev to ext4 ext4: Avoid double dirtying of super block in ext4_put_super() Update ext4 MAINTAINERS file Hook ext4 to the vfs fiemap interface. generic block based fiemap implementation ocfs2: fiemap support vfs: vfs-level fiemap interface ext4: fix xattr deadlock jbd2: Fix buffer head leak when writing the commit block ext4: Add debugging markers that can be used by systemtap jbd2: abort instead of waiting for nonexistent transaction ext4: fix initialization of UNINIT bitmap blocks ext4: Remove old legacy block allocator ext4: Use readahead when reading an inode from the inode table ext4: Improve the documentation for ext4's /proc tunables ext4: Combine proc file handling into a single set of functions ext4: move /proc setup and teardown out of mballoc.c ext4: Don't use 'struct dentry' for internal lookups ext4/jbd2: Avoid WARN() messages when failing to write to the superblock ext4: use percpu data structures for lg_prealloc_list ...
2008-10-11Merge phase #3 (IOMMU) of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-v28-for-linus-phase3-B' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (74 commits) AMD IOMMU: use iommu_device_max_index, fix AMD IOMMU: use iommu_device_max_index x86: add PCI IDs for AMD Barcelona PCI devices x86/iommu: use __GFP_ZERO instead of memset for GART x86/iommu: convert GART need_flush to bool x86/iommu: make GART driver checkpatch clean x86 gart: remove unnecessary initialization x86: restore old GART alloc_coherent behavior revert "x86: make GART to respect device's dma_mask about virtual mappings" x86: export pci-nommu's alloc_coherent iommu: remove fullflush and nofullflush in IOMMU generic option x86: remove set_bit_string() iommu: export iommu_area_reserve helper function AMD IOMMU: use coherent_dma_mask in alloc_coherent add AMD IOMMU tree to MAINTAINERS file AMD IOMMU: use cmd_buf_size when freeing the command buffer AMD IOMMU: calculate IVHD size with a function AMD IOMMU: remove unnecessary cast to u64 in the init code AMD IOMMU: free domain bitmap with its allocation order AMD IOMMU: simplify dma_mask_to_pages ...
2008-10-10Merge branch 'rcu-v28-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'rcu-v28-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (21 commits) rcu: RCU-based detection of stalled CPUs for Classic RCU, fix rcu: RCU-based detection of stalled CPUs for Classic RCU rcu: add rcu_read_lock_sched() / rcu_read_unlock_sched() rcu: fix sparse shadowed variable warning doc/RCU: fix pseudocode in rcuref.txt rcuclassic: fix compiler warning rcu: use irq-safe locks rcuclassic: fix compilation NG rcu: fix locking cleanup fallout rcu: remove redundant ACCESS_ONCE definition from rcupreempt.c rcu: fix classic RCU locking cleanup lockdep problem rcu: trace fix possible mem-leak rcu: just rename call_rcu_bh instead of making it a macro rcu: remove list_for_each_rcu() rcu: fixes to include/linux/rcupreempt.h rcu: classic RCU locking and memory-barrier cleanups rcu: prevent console flood when one CPU sees another AWOL via RCU rcu, debug: detect stalled grace periods, cleanups rcu, debug: detect stalled grace periods rcu classic: new algorithm for callbacks-processing(v2) ...
2008-10-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (37 commits) [SCSI] zfcp: fix double dbf id usage [SCSI] zfcp: wait on SCSI work to be finished before proceeding with init dev [SCSI] zfcp: fix erp list usage without using locks [SCSI] zfcp: prevent fc_remote_port_delete calls for unregistered rport [SCSI] zfcp: fix deadlock caused by shared work queue tasks [SCSI] zfcp: put threshold data in hba trace [SCSI] zfcp: Simplify zfcp data structures [SCSI] zfcp: Simplify get_adapter_by_busid [SCSI] zfcp: remove all typedefs and replace them with standards [SCSI] zfcp: attach and release SAN nameserver port on demand [SCSI] zfcp: remove unused references, declarations and flags [SCSI] zfcp: Update message with input from review [SCSI] zfcp: add queue_full sysfs attribute [SCSI] scsi_dh: suppress comparison warning [SCSI] scsi_dh: add Dell product information into rdac device handler [SCSI] qla2xxx: remove the unused SCSI_QLOGIC_FC_FIRMWARE option [SCSI] qla2xxx: fix printk format warnings [SCSI] qla2xxx: Update version number to 8.02.01-k8. [SCSI] qla2xxx: Ignore payload reserved-bits during RSCN processing. [SCSI] qla2xxx: Additional residual-count corrections during UNDERRUN handling. ...
2008-10-09block: add fault injection mechanism for faking request timeoutsJens Axboe
Only works for the generic request timer handling. Allows one to sporadically ignore request completions, thus exercising the timeout handling. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09init: DEBUG_BLOCK_EXT_DEVT requires explicit root= paramTejun Heo
DEBUG_BLOCK_EXT_DEVT shuffles SCSI and IDE device numbers and root device number set using rdev become meaningless. Root devices should be explicitly specified using textual names. Warn about it if root can't be found and DEBUG_BLOCK_EXT_DEVT is enabled. Also, add warning to the help text. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09Change default value of CONFIG_DEBUG_BLOCK_EXT_DEVT to 'n'Jens Axboe
It's a debug option that you would explicitly enable to test this feature, we should default it to 'n' to prevent accidental surprises for now. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: implement CONFIG_DEBUG_BLOCK_EXT_DEVTTejun Heo
Extended devt introduces non-contiguos device numbers. This patch implements a debug option which forces most devt allocations to be from the extended area and spreads them out. This is enabled by default if DEBUG_KERNEL is set and achieves... 1. Detects code paths in kernel or userland which expect predetermined consecutive device numbers. 2. When something goes wrong, avoid corruption as adding to the minor of earlier partition won't lead to the wrong but valid device. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09klist: don't iterate over deleted entriesTejun Heo
A klist entry is kept on the list till all its current iterations are finished; however, a new iteration after deletion also iterates over deleted entries as long as their reference count stays above zero. This causes problems for cases where there are users which iterate over the list while synchronized against list manipulations and natuarally expect already deleted entries to not show up during iteration. This patch implements dead flag which gets set on deletion so that iteration can skip already deleted entries. The dead flag piggy backs on the lowest bit of knode->n_klist and only visible to klist implementation proper. While at it, drop klist_iter->i_head as it's redundant and doesn't offer anything in semantics or performance wise as klist_iter->i_klist is dereferenced on every iteration anyway. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-03[SCSI] lib: add generic helper to print sizes rounded to the correct SI rangeJames Bottomley
This patch adds the ability to print sizes in either units of 10^3 (SI) or 2^10 (Binary) units. It rounds up to three significant figures and can be used for either memory or storage capacities. Oh, and I'm fully aware that 64 bits is only 16EiB ... the Zetta and Yotta units are added for future proofing against the day we have 128 bit computers ... [fujita.tomonori@lab.ntt.co.jp: fix missed unsigned long long cast] Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-03rcu: RCU-based detection of stalled CPUs for Classic RCUPaul E. McKenney
This patch adds stalled-CPU detection to Classic RCU. This capability is enabled by a new config variable CONFIG_RCU_CPU_STALL_DETECTOR, which defaults disabled. This is a debugging feature to detect infinite loops in kernel code, not something that non-kernel-hackers would be expected to care about. This feature can detect looping CPUs in !PREEMPT builds and looping CPUs with preemption disabled in PREEMPT builds. This is essentially a port of this functionality from the treercu patch, replacing the stall debug patch that is already in tip/core/rcu (commit 67182ae1c4). The changes from the patch in tip/core/rcu include making the config variable name match that in treercu, changing from seconds to jiffies to avoid spurious warnings, and printing a boot message when this feature is enabled. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
