path: root/mm/Kconfig
2013-07-10zswap: add to mm/Seth Jennings
zswap is a thin backend for frontswap that takes pages that are in the process of being swapped out and attempts to compress them and store them in a RAM-based memory pool. This can result in a significant I/O reduction on the swap device and, in the case where decompressing from RAM is faster than reading from the swap device, can also improve workload performance. It also has support for evicting swap pages that are currently compressed in zswap to the swap device on an LRU(ish) basis. This functionality makes zswap a true cache in that, once the cache is full, the oldest pages can be moved out of zswap to the swap device so newer pages can be compressed and stored in zswap. This patch adds the zswap driver to mm/ Signed-off-by: Seth Jennings <sjenning@linux.vnet.ibm.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Robert Jennings <rcj@linux.vnet.ibm.com> Cc: Jenifer Hopper <jhopper@us.ibm.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dave Hansen <dave@sr71.net> Cc: Joe Perches <joe@perches.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Cody P Schafer <cody@linux.vnet.ibm.com> Cc: Hugh Dickens <hughd@google.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-10zbud: add to mm/Seth Jennings
zbud is an special purpose allocator for storing compressed pages. It is designed to store up to two compressed pages per physical page. While this design limits storage density, it has simple and deterministic reclaim properties that make it preferable to a higher density approach when reclaim will be used. zbud works by storing compressed pages, or "zpages", together in pairs in a single memory page called a "zbud page". The first buddy is "left justifed" at the beginning of the zbud page, and the last buddy is "right justified" at the end of the zbud page. The benefit is that if either buddy is freed, the freed buddy space, coalesced with whatever slack space that existed between the buddies, results in the largest possible free region within the zbud page. zbud also provides an attractive lower bound on density. The ratio of zpages to zbud pages can not be less than 1. This ensures that zbud can never "do harm" by using more pages to store zpages than the uncompressed zpages would have used on their own. This implementation is a rewrite of the zbud allocator internally used by zcache in the driver/staging tree. The rewrite was necessary to remove some of the zcache specific elements that were ingrained throughout and provide a generic allocation interface that can later be used by zsmalloc and others. This patch adds zbud to mm/ for later use by zswap. Signed-off-by: Seth Jennings <sjenning@linux.vnet.ibm.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Robert Jennings <rcj@linux.vnet.ibm.com> Cc: Jenifer Hopper <jhopper@us.ibm.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dave Hansen <dave@sr71.net> Cc: Joe Perches <joe@perches.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Cody P Schafer <cody@linux.vnet.ibm.com> Cc: Hugh Dickens <hughd@google.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Bob Liu <bob.liu@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm: soft-dirty bits for user memory changes trackingPavel Emelyanov
The soft-dirty is a bit on a PTE which helps to track which pages a task writes to. In order to do this tracking one should 1. Clear soft-dirty bits from PTEs ("echo 4 > /proc/PID/clear_refs) 2. Wait some time. 3. Read soft-dirty bits (55'th in /proc/PID/pagemap2 entries) To do this tracking, the writable bit is cleared from PTEs when the soft-dirty bit is. Thus, after this, when the task tries to modify a page at some virtual address the #PF occurs and the kernel sets the soft-dirty bit on the respective PTE. Note, that although all the task's address space is marked as r/o after the soft-dirty bits clear, the #PF-s that occur after that are processed fast. This is so, since the pages are still mapped to physical memory, and thus all the kernel does is finds this fact out and puts back writable, dirty and soft-dirty bits on the PTE. Another thing to note, is that when mremap moves PTEs they are marked with soft-dirty as well, since from the user perspective mremap modifies the virtual memory at mremap's new address. Signed-off-by: Pavel Emelyanov <xemul@parallels.com> Cc: Matt Mackall <mpm@selenic.com> Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Cc: Glauber Costa <glommer@parallels.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-03Finally eradicate CONFIG_HOTPLUGStephen Rothwell
Ever since commit 45f035ab9b8f ("CONFIG_HOTPLUG should be always on"), it has been basically impossible to build a kernel with CONFIG_HOTPLUG turned off. Remove all the remaining references to it. Cc: Russell King <linux@arm.linux.org.uk> Cc: Doug Thompson <dougthompson@xmission.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-29mmKconfig: add an option to disable bounceVinayak Menon
There are times when HIGHMEM is enabled, but we don't prefer CONFIG_BOUNCE to be enabled. CONFIG_BOUNCE can reduce the block device throughput, and this is not ideal for machines where we don't gain much by enabling it. So provide an option to deselect CONFIG_BOUNCE. The observation was made while measuring eMMC throughput using iozone on an ARM device with 1GB RAM. Signed-off-by: Vinayak Menon <vinayakm.list@gmail.com> Cc: David Rientjes <rientjes@google.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-12Select VIRT_TO_BUS directly where neededStephen Rothwell
In commit 887cbce0adea ("arch Kconfig: centralise ARCH_NO_VIRT_TO_BUS") I introduced the config sybmol HAVE_VIRT_TO_BUS and selected that where needed. I am not sure what I was thinking. Instead, just directly select VIRT_TO_BUS where it is needed. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27arch Kconfig: centralise CONFIG_ARCH_NO_VIRT_TO_BUSStephen Rothwell
Change it to CONFIG_HAVE_VIRT_TO_BUS and set it in all architecures that already provide virt_to_bus(). Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Reviewed-by: James Hogan <james.hogan@imgtec.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: H Hartley Sweeten <hartleys@visionengravers.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Vineet Gupta <Vineet.Gupta1@synopsys.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-23memory-hotplug: implement register_page_bootmem_info_section of sparse-vmemmapYasuaki Ishimatsu
For removing memmap region of sparse-vmemmap which is allocated bootmem, memmap region of sparse-vmemmap needs to be registered by get_page_bootmem(). So the patch searches pages of virtual mapping and registers the pages by get_page_bootmem(). NOTE: register_page_bootmem_memmap() is not implemented for ia64, ppc, s390, and sparc. So introduce CONFIG_HAVE_BOOTMEM_INFO_NODE and revert register_page_bootmem_info_node() when platform doesn't support it. It's implemented by adding a new Kconfig option named CONFIG_HAVE_BOOTMEM_INFO_NODE, which will be automatically selected by memory-hotplug feature fully supported archs(currently only on x86_64). Since we have 2 config options called MEMORY_HOTPLUG and MEMORY_HOTREMOVE used for memory hot-add and hot-remove separately, and codes in function register_page_bootmem_info_node() are only used for collecting infomation for hot-remove, so reside it under MEMORY_HOTREMOVE. Besides page_isolation.c selected by MEMORY_ISOLATION under MEMORY_HOTPLUG is also such case, move it too. [mhocko@suse.cz: put register_page_bootmem_memmap inside CONFIG_MEMORY_HOTPLUG_SPARSE] [linfeng@cn.fujitsu.com: introduce CONFIG_HAVE_BOOTMEM_INFO_NODE and revert register_page_bootmem_info_node()] [mhocko@suse.cz: remove the arch specific functions without any implementation] [linfeng@cn.fujitsu.com: mm/Kconfig: move auto selects from MEMORY_HOTPLUG to MEMORY_HOTREMOVE as needed] [rientjes@google.com: fix defined but not used warning] Signed-off-by: Wen Congyang <wency@cn.fujitsu.com> Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com> Reviewed-by: Wu Jianguo <wujianguo@huawei.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Jiang Liu <jiang.liu@huawei.com> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Lin Feng <linfeng@cn.fujitsu.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21Merge branch 'akpm' (incoming from Andrew)Linus Torvalds
Merge misc patches from Andrew Morton: - Florian has vanished so I appear to have become fbdev maintainer again :( - Joel and Mark are distracted to welcome to the new OCFS2 maintainer - The backlight queue - Small core kernel changes - lib/ updates - The rtc queue - Various random bits * akpm: (164 commits) rtc: rtc-davinci: use devm_*() functions rtc: rtc-max8997: use devm_request_threaded_irq() rtc: rtc-max8907: use devm_request_threaded_irq() rtc: rtc-da9052: use devm_request_threaded_irq() rtc: rtc-wm831x: use devm_request_threaded_irq() rtc: rtc-tps80031: use devm_request_threaded_irq() rtc: rtc-lp8788: use devm_request_threaded_irq() rtc: rtc-coh901331: use devm_clk_get() rtc: rtc-vt8500: use devm_*() functions rtc: rtc-tps6586x: use devm_request_threaded_irq() rtc: rtc-imxdi: use devm_clk_get() rtc: rtc-cmos: use dev_warn()/dev_dbg() instead of printk()/pr_debug() rtc: rtc-pcf8583: use dev_warn() instead of printk() rtc: rtc-sun4v: use pr_warn() instead of printk() rtc: rtc-vr41xx: use dev_info() instead of printk() rtc: rtc-rs5c313: use pr_err() instead of printk() rtc: rtc-at91rm9200: use dev_dbg()/dev_err() instead of printk()/pr_debug() rtc: rtc-rs5c372: use dev_dbg()/dev_warn() instead of printk()/pr_debug() rtc: rtc-ds2404: use dev_err() instead of printk() rtc: rtc-efi: use dev_err()/dev_warn()/pr_err() instead of printk() ...
2013-02-21block: optionally snapshot page contents to provide stable pages during writeDarrick J. Wong
This provides a band-aid to provide stable page writes on jbd without needing to backport the fixed locking and page writeback bit handling schemes of jbd2. The band-aid works by using bounce buffers to snapshot page contents instead of waiting. For those wondering about the ext3 bandage -- fixing the jbd locking (which was done as part of ext4dev years ago) is a lot of surgery, and setting PG_writeback on data pages when we actually hold the page lock dropped ext3 performance by nearly an order of magnitude. If we're going to migrate iscsi and raid to use stable page writes, the complaints about high latency will likely return. We might as well centralize their page snapshotting thing to one place. Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Tested-by: Andy Lutomirski <luto@amacapital.net> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Artem Bityutskiy <dedekind1@gmail.com> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Joel Becker <jlbec@evilplan.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ron Minnich <rminnich@sandia.gov> Cc: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-17mm: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. CC: Andrew Morton <akpm@linux-foundation.org> CC: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> CC: Jan Beulich <JBeulich@novell.com> CC: Mel Gorman <mel@csn.ul.ie> CC: Seth Jennings <sjenning@linux.vnet.ibm.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-18memory-hotplug: document and enable CONFIG_MOVABLE_NODETang Chen
Add help info for CONFIG_MOVABLE_NODE and permit its selection. This option allows the user to online all memory of a node as movable memory. So that the whole node can be hotplugged. Users who don't use the hotplug feature are also fine with this option on since they won't online memory as movable. Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com> Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Ingo Molnar <mingo@elte.hu> [akpm@linux-foundation.org: tweak help text] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-13Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge misc VM changes from Andrew Morton: "The rest of most-of-MM. The other MM bits await a slab merge. This patch includes the addition of a huge zero_page. Not a performance boost but it an save large amounts of physical memory in some situations. Also a bunch of Fujitsu engineers are working on memory hotplug. Which, as it turns out, was badly broken. About half of their patches are included here; the remainder are 3.8 material." However, this merge disables CONFIG_MOVABLE_NODE, which was totally broken. We don't add new features with "default y", nor do we add Kconfig questions that are incomprehensible to most people without any help text. Does the feature even make sense without compaction or memory hotplug? * akpm: (54 commits) mm/bootmem.c: remove unused wrapper function reserve_bootmem_generic() mm/memory.c: remove unused code from do_wp_page() asm-generic, mm: pgtable: consolidate zero page helpers mm/hugetlb.c: fix warning on freeing hwpoisoned hugepage hwpoison, hugetlbfs: fix RSS-counter warning hwpoison, hugetlbfs: fix "bad pmd" warning in unmapping hwpoisoned hugepage mm: protect against concurrent vma expansion memcg: do not check for mm in __mem_cgroup_count_vm_event tmpfs: support SEEK_DATA and SEEK_HOLE (reprise) mm: provide more accurate estimation of pages occupied by memmap fs/buffer.c: remove redundant initialization in alloc_page_buffers() fs/buffer.c: do not inline exported function writeback: fix a typo in comment mm: introduce new field "managed_pages" to struct zone mm, oom: remove statically defined arch functions of same name mm, oom: remove redundant sleep in pagefault oom handler mm, oom: cleanup pagefault oom handler memory_hotplug: allow online/offline memory to result movable node numa: add CONFIG_MOVABLE_NODE for movable-dedicated node mm, memcg: avoid unnecessary function call when memcg is disabled ...
2012-12-12numa: add CONFIG_MOVABLE_NODE for movable-dedicated nodeLai Jiangshan
We need a node which only contains movable memory. This feature is very important for node hotplug. If a node has normal/highmem, the memory may be used by the kernel and can't be offlined. If the node only contains movable memory, we can offline the memory and the node. All are prepared, we can actually introduce N_MEMORY. add CONFIG_MOVABLE_NODE make we can use it for movable-dedicated node [akpm@linux-foundation.org: fix Kconfig text] Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Tested-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Signed-off-by: Wen Congyang <wency@cn.fujitsu.com> Cc: Jiang Liu <jiang.liu@huawei.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Mel Gorman <mgorman@suse.de> Cc: David Rientjes <rientjes@google.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-11mm: introduce a common interface for balloon pages mobilityRafael Aquini
Memory fragmentation introduced by ballooning might reduce significantly the number of 2MB contiguous memory blocks that can be used within a guest, thus imposing performance penalties associated with the reduced number of transparent huge pages that could be used by the guest workload. This patch introduces a common interface to help a balloon driver on making its page set movable to compaction, and thus allowing the system to better leverage the compation efforts on memory defragmentation. [akpm@linux-foundation.org: use PAGE_FLAGS_CHECK_AT_PREP, s/__balloon_page_flags/page_flags_cleared/, small cleanups] [rientjes@google.com: allow balloon compaction for any system with memory compaction enabled, which is the defconfig] Signed-off-by: Rafael Aquini <aquini@redhat.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: enable CONFIG_COMPACTION by defaultRik van Riel
Now that lumpy reclaim has been removed, compaction is the only way left to free up contiguous memory areas. It is time to just enable CONFIG_COMPACTION by default. Signed-off-by: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Acked-by: Rafael Aquini <aquini@redhat.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09thp, x86: introduce HAVE_ARCH_TRANSPARENT_HUGEPAGEGerald Schaefer
Cleanup patch in preparation for transparent hugepage support on s390. Adding new architectures to the TRANSPARENT_HUGEPAGE config option can make the "depends" line rather ugly, like "depends on (X86 || (S390 && 64BIT)) && MMU". This patch adds a HAVE_ARCH_TRANSPARENT_HUGEPAGE instead. x86 already has MMU "def_bool y", so the MMU check is superfluous there and HAVE_ARCH_TRANSPARENT_HUGEPAGE can be selected in arch/x86/Kconfig. Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm: factor out memory isolate functionsMinchan Kim
mm/page_alloc.c has some memory isolation functions but they are used only when we enable CONFIG_{CMA|MEMORY_HOTPLUG|MEMORY_FAILURE}. So let's make it configurable by new CONFIG_MEMORY_ISOLATION so that it can reduce binary size and we can check it simple by CONFIG_MEMORY_ISOLATION, not if defined CONFIG_{CMA|MEMORY_HOTPLUG|MEMORY_FAILURE}. Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-06-04Merge tag 'stable/frontswap.v16-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm Pull frontswap feature from Konrad Rzeszutek Wilk: "Frontswap provides a "transcendent memory" interface for swap pages. In some environments, dramatic performance savings may be obtained because swapped pages are saved in RAM (or a RAM-like device) instead of a swap disk. This tag provides the basic infrastructure along with some changes to the existing backends." Fix up trivial conflict in mm/Makefile due to removal of swap token code changing a line next to the new frontswap entry. This pull request came in before the merge window even opened, it got delayed to after the merge window by me just wanting to make sure it had actual users. Apparently IBM is using this on their embedded side, and Jan Beulich says that it's already made available for SLES and OpenSUSE users. Also acked by Rik van Riel, and Konrad points to other people liking it too. So in it goes. By Dan Magenheimer (4) and Konrad Rzeszutek Wilk (2) via Konrad Rzeszutek Wilk * tag 'stable/frontswap.v16-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm: frontswap: s/put_page/store/g s/get_page/load MAINTAINER: Add myself for the frontswap API mm: frontswap: config and doc files mm: frontswap: core frontswap functionality mm: frontswap: core swap subsystem hooks and headers mm: frontswap: add frontswap header file
2012-05-29Cross Memory Attach: make it KconfigurableChristopher Yeoh
Add a Kconfig option to allow people who don't want cross memory attach to not have it included in their build. Signed-off-by: Chris Yeoh <yeohc@au1.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-21mm: mmzone: MIGRATE_CMA migration type addedMichal Nazarewicz
The MIGRATE_CMA migration type has two main characteristics: (i) only movable pages can be allocated from MIGRATE_CMA pageblocks and (ii) page allocator will never change migration type of MIGRATE_CMA pageblocks. This guarantees (to some degree) that page in a MIGRATE_CMA page block can always be migrated somewhere else (unless there's no memory left in the system). It is designed to be used for allocating big chunks (eg. 10MiB) of physically contiguous memory. Once driver requests contiguous memory, pages from MIGRATE_CMA pageblocks may be migrated away to create a contiguous block. To minimise number of migrations, MIGRATE_CMA migration type is the last type tried when page allocator falls back to other migration types when requested. Signed-off-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Rob Clark <rob.clark@linaro.org> Tested-by: Ohad Ben-Cohen <ohad@wizery.com> Tested-by: Benjamin Gaignard <benjamin.gaignard@linaro.org> Tested-by: Robert Nelson <robertcnelson@gmail.com> Tested-by: Barry Song <Baohua.Song@csr.com>
2012-05-15mm: frontswap: config and doc filesDan Magenheimer
This patch 4of4 adds configuration and documentation files including a FAQ. [v14: updated docs/FAQ to use zcache and RAMster as examples] [v10: no change] [v9: akpm@linux-foundation.org: sysfs->debugfs; no longer need Doc/ABI file] [v8: rebase to 3.0-rc4] [v7: rebase to 3.0-rc3] [v6: rebase to 3.0-rc1] [v5: change config default to n] [v4: rebase to 2.6.39] Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Acked-by: Jan Beulich <JBeulich@novell.com> Acked-by: Seth Jennings <sjenning@linux.vnet.ibm.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Chris Mason <chris.mason@oracle.com> Cc: Rik Riel <riel@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-11-28Merge branch 'master' into x86/memblockTejun Heo
Conflicts & resolutions: * arch/x86/xen/setup.c dc91c728fd "xen: allow extra memory to be in multiple regions" 24aa07882b "memblock, x86: Replace memblock_x86_reserve/free..." conflicted on xen_add_extra_mem() updates. The resolution is trivial as the latter just want to replace memblock_x86_reserve_range() with memblock_reserve(). * drivers/pci/intel-iommu.c 166e9278a3f "x86/ia64: intel-iommu: move to drivers/iommu/" 5dfe8660a3d "bootmem: Replace work_with_active_regions() with..." conflicted as the former moved the file under drivers/iommu/. Resolved by applying the chnages from the latter on the moved file. * mm/Kconfig 6661672053a "memblock: add NO_BOOTMEM config symbol" c378ddd53f9 "memblock, x86: Make ARCH_DISCARD_MEMBLOCK a config option" conflicted trivially. Both added config options. Just letting both add their own options resolves the conflict. * mm/memblock.c d1f0ece6cdc "mm/memblock.c: small function definition fixes" ed7b56a799c "memblock: Remove memblock_memory_can_coalesce()" confliected. The former updates function removed by the latter. Resolution is trivial. Signed-off-by: Tejun Heo <tj@kernel.org>
2011-10-31memblock: add NO_BOOTMEM config symbolSam Ravnborg
With the NO_BOOTMEM symbol added architectures may now use the following syntax to tell that they do not need bootmem: select NO_BOOTMEM This is much more convinient than adding a new kconfig symbol which was otherwise required. Adding this symbol does not conflict with the architctures that already define their own symbol. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Yinghai Lu <yinghai@kernel.org> Acked-by: Tejun Heo <tj@kernel.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-14memblock, x86: Make ARCH_DISCARD_MEMBLOCK a config optionTejun Heo
From 6839454ae63f1eb21e515c10229ca95c22955fec Mon Sep 17 00:00:00 2001 From: Tejun Heo <tj@kernel.org> Date: Thu, 14 Jul 2011 11:22:17 +0200 Make ARCH_DISCARD_MEMBLOCK a config option so that it can be handled together with other MEMBLOCK options. Signed-off-by: Tejun Heo <tj@kernel.org> Link: http://lkml.kernel.org/r/20110714094603.GH3455@htj.dyndns.org Cc: Yinghai Lu <yinghai@kernel.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-07-14memblock: Add optional region->nidTejun Heo
From 83103b92f3234ec830852bbc5c45911bd6cbdb20 Mon Sep 17 00:00:00 2001 From: Tejun Heo <tj@kernel.org> Date: Thu, 14 Jul 2011 11:22:16 +0200 Add optional region->nid which can be enabled by arch using CONFIG_HAVE_MEMBLOCK_NODE_MAP. When enabled, memblock also carries NUMA node information and replaces early_node_map[]. Newly added memblocks have MAX_NUMNODES as nid. Arch can then call memblock_set_node() to set node information. memblock takes care of merging and node affine allocations w.r.t. node information. When MEMBLOCK_NODE_MAP is enabled, early_node_map[], related data structures and functions to manipulate and iterate it are disabled. memblock version of __next_mem_pfn_range() is provided such that for_each_mem_pfn_range() behaves the same and its users don't have to be updated. -v2: Yinghai spotted section mismatch caused by missing __init_memblock in memblock_set_node(). Fixed. Signed-off-by: Tejun Heo <tj@kernel.org> Link: http://lkml.kernel.org/r/20110714094342.GF3455@htj.dyndns.org Cc: Yinghai Lu <yinghai@kernel.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-06-10mm Kconfig typo: cleancacne -> cleancacheMichael Witten
Signed-off-by: Michael Witten <mfwitten@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-26mm: cleancache core ops functions and configDan Magenheimer
This third patch of eight in this cleancache series provides the core code for cleancache that interfaces between the hooks in VFS and individual filesystems and a cleancache backend. It also includes build and config patches. Two new files are added: mm/cleancache.c and include/linux/cleancache.h. Note that CONFIG_CLEANCACHE can default to on; in systems that do not provide a cleancache backend, all hooks devolve to a simple check of a global enable flag, so performance impact should be negligible but can be reduced to zero impact if config'ed off. However for this first commit, it defaults to off. Details and a FAQ can be found in Documentation/vm/cleancache.txt Credits: Cleancache_ops design derived from Jeremy Fitzhardinge design for tmem [v8: dan.magenheimer@oracle.com: fix exportfs call affecting btrfs] [v8: akpm@linux-foundation.org: use static inline function, not macro] [v7: dan.magenheimer@oracle.com: cleanup sysfs and remove cleancache prefix] [v6: JBeulich@novell.com: robustly handle buggy fs encode_fh actor definition] [v5: jeremy@goop.org: clean up global usage and static var names] [v5: jeremy@goop.org: simplify init hook and any future fs init changes] [v5: hch@infradead.org: cleaner non-global interface for ops registration] [v4: adilger@sun.com: interface must support exportfs FS's] [v4: hch@infradead.org: interface must support 64-bit FS on 32-bit kernel] [v3: akpm@linux-foundation.org: use one ops struct to avoid pointer hops] [v3: akpm@linux-foundation.org: document and ensure PageLocked reqts are met] [v3: ngupta@vflare.org: fix success/fail codes, change funcs to void] [v2: viro@ZenIV.linux.org.uk: use sane types] Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Reviewed-by: Jeremy Fitzhardinge <jeremy@goop.org> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Acked-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Nitin Gupta <ngupta@vflare.org> Acked-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Andreas Dilger <adilger@sun.com> Acked-by: Jan Beulich <JBeulich@novell.com> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik Van Riel <riel@redhat.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Ted Ts'o <tytso@mit.edu> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <joel.becker@oracle.com>
2011-01-26mm: compaction: don't depend on HUGETLB_PAGEAndrea Arcangeli
Commit 5d6892407 ("thp: select CONFIG_COMPACTION if TRANSPARENT_HUGEPAGE enabled") causes this warning during the configuration process: warning: (TRANSPARENT_HUGEPAGE) selects COMPACTION which has unmet direct dependencies (EXPERIMENTAL && HUGETLB_PAGE && MMU) COMPACTION doesn't depend on HUGETLB_PAGE, it doesn't depend on THP either, it is also useful for regular alloc_pages(order > 0) including the very kernel stack during fork (THREAD_ORDER = 1). It's always better to enable COMPACTION. The warning should be an error because we would end up with MIGRATION not selected, and COMPACTION wouldn't work without migration (despite it seems to build with an inline migrate_pages returning -ENOSYS). I'd also like to remove EXPERIMENTAL: compaction has been in the kernel for some releases (for full safety the default remains disabled which I think is enough). Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Reported-by: Luca Tettamanti <kronos.it@gmail.com> Tested-by: Luca Tettamanti <kronos.it@gmail.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: select CONFIG_COMPACTION if TRANSPARENT_HUGEPAGE enabledAndrea Arcangeli
With transparent hugepage support we need compaction for the "defrag" sysfs controls to be effective. At the moment THP hangs the system if COMPACTION isn't selected, as without COMPACTION lumpy reclaim wouldn't be entirely disabled. So at the moment it's not orthogonal. When lumpy will be removed from the VM I can remove the select COMPACTION in theory, but then 99% of THP users would be still doing a mistake in disabling compaction, even if the mistake won't return in fatal runtime but just slightly degraded performance. So from a theoretical standpoing forcing the below select is not needed (the dependency isn't strict nor at compile time nor at runtime) but from a practical standpoint it is safer. If anybody really wants THP to run without compaction, it'd be such a weird setup that editing the Kconfig file to allow it will be surely not a problem. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: transparent hugepage config choiceAndrea Arcangeli
Allow to choose between the always|madvise default for page faults and khugepaged at config time. madvise guarantees zero risk of higher memory footprint for applications (applications using madvise(MADV_HUGEPAGE) won't risk to use any more memory by backing their virtual regions with hugepages). Initially set the default to N and don't depend on EMBEDDED. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: add x86 32bit supportJohannes Weiner
Add support for transparent hugepages to x86 32bit. Share the same VM_ bitflag for VM_MAPPED_COPY. mm/nommu.c will never support transparent hugepages. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: CONFIG_TRANSPARENT_HUGEPAGEAndrea Arcangeli
Add config option. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu: update comments to reflect that percpu allocations are always zero-filled percpu: Optimize __get_cpu_var() x86, percpu: Optimize this_cpu_ptr percpu: clear memory allocated with the km allocator percpu: fix build breakage on s390 and cleanup build configuration tests percpu: use percpu allocator on UP too percpu: reduce PCPU_MIN_UNIT_SIZE to 32k vmalloc: pcpu_get/free_vm_areas() aren't needed on UP Fixed up trivial conflicts in include/linux/percpu.h
2010-09-09mm: avoid warning when COMPACTION is selectedAndrea Arcangeli
COMPACTION enables MIGRATION, but MIGRATION spawns a warning if numa or memhotplug aren't selected. However MIGRATION doesn't depend on them. I guess it's just trying to be strict doing a double check on who's enabling it, but it doesn't know that compaction also enables MIGRATION. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-08percpu: use percpu allocator on UP tooTejun Heo
On UP, percpu allocations were redirected to kmalloc. This has the following problems. * For certain amount of allocations (determined by PERCPU_DYNAMIC_EARLY_SLOTS and PERCPU_DYNAMIC_EARLY_SIZE), percpu allocator can be used before the usual kernel memory allocator is brought online. On SMP, this is used to initialize the kernel memory allocator. * percpu allocator honors alignment upto PAGE_SIZE but kmalloc() doesn't. For example, workqueue makes use of larger alignments for cpu_workqueues. Currently, users of percpu allocators need to handle UP differently, which is somewhat fragile and ugly. Other than small amount of memory, there isn't much to lose by enabling percpu allocator on UP. It can simply use kernel memory based chunk allocation which was added for SMP archs w/o MMUs. This patch removes mm/percpu_up.c, builds mm/percpu.c on UP too and makes UP build use percpu-km. As percpu addresses and kernel addresses are always identity mapped and static percpu variables don't need any special treatment, nothing is arch dependent and mm/percpu.c implements generic setup_per_cpu_areas() for UP. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
2010-07-14lmb: rename to memblockYinghai Lu
via following scripts FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/lmb/memblock/g' \ -e 's/LMB/MEMBLOCK/g' \ $FILES for N in $(find . -name lmb.[ch]); do M=$(echo $N | sed 's/lmb/memblock/g') mv $N $M done and remove some wrong change like lmbench and dlmb etc. also move memblock.c from lib/ to mm/ Suggested-by: Ingo Molnar <mingo@elte.hu> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-05-25mm: allow CONFIG_MIGRATION to be set without CONFIG_NUMA or memory hot-removeMel Gorman
CONFIG_MIGRATION currently depends on CONFIG_NUMA or on the architecture being able to hot-remove memory. The main users of page migration such as sys_move_pages(), sys_migrate_pages() and cpuset process migration are only beneficial on NUMA so it makes sense. As memory compaction will operate within a zone and is useful on both NUMA and non-NUMA systems, this patch allows CONFIG_MIGRATION to be set if the user selects CONFIG_COMPACTION as an option. [akpm@linux-foundation.org: Depend on CONFIG_HUGETLB_PAGE] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-03Merge branch 'x86-bootmem-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-bootmem-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (30 commits) early_res: Need to save the allocation name in drop_range_partial() sparsemem: Fix compilation on PowerPC early_res: Add free_early_partial() x86: Fix non-bootmem compilation on PowerPC core: Move early_res from arch/x86 to kernel/ x86: Add find_fw_memmap_area Move round_up/down to kernel.h x86: Make 32bit support NO_BOOTMEM early_res: Enhance check_and_double_early_res x86: Move back find_e820_area to e820.c x86: Add find_early_area_size x86: Separate early_res related code from e820.c x86: Move bios page reserve early to head32/64.c sparsemem: Put mem map for one node together. sparsemem: Put usemap for one node together x86: Make 64 bit use early_res instead of bootmem before slab x86: Only call dma32_reserve_bootmem 64bit !CONFIG_NUMA x86: Make early_node_mem get mem > 4 GB if possible x86: Dynamically increase early_res array size x86: Introduce max_early_res and early_res_count ...
2010-02-12sparsemem: Put mem map for one node together.Yinghai Lu
Add vmemmap_alloc_block_buf for mem map only. It will fallback to the old way if it cannot get a block that big. Before this patch, when a node have 128g ram installed, memmap are split into two parts or more. [ 0.000000] [ffffea0000000000-ffffea003fffffff] PMD -> [ffff880100600000-ffff88013e9fffff] on node 1 [ 0.000000] [ffffea0040000000-ffffea006fffffff] PMD -> [ffff88013ec00000-ffff88016ebfffff] on node 1 [ 0.000000] [ffffea0070000000-ffffea007fffffff] PMD -> [ffff882000600000-ffff8820105fffff] on node 0 [ 0.000000] [ffffea0080000000-ffffea00bfffffff] PMD -> [ffff882010800000-ffff8820507fffff] on node 0 [ 0.000000] [ffffea00c0000000-ffffea00dfffffff] PMD -> [ffff882050a00000-ffff8820709fffff] on node 0 [ 0.000000] [ffffea00e0000000-ffffea00ffffffff] PMD -> [ffff884000600000-ffff8840205fffff] on node 2 [ 0.000000] [ffffea0100000000-ffffea013fffffff] PMD -> [ffff884020800000-ffff8840607fffff] on node 2 [ 0.000000] [ffffea0140000000-ffffea014fffffff] PMD -> [ffff884060a00000-ffff8840709fffff] on node 2 [ 0.000000] [ffffea0150000000-ffffea017fffffff] PMD -> [ffff886000600000-ffff8860305fffff] on node 3 [ 0.000000] [ffffea0180000000-ffffea01bfffffff] PMD -> [ffff886030800000-ffff8860707fffff] on node 3 [ 0.000000] [ffffea01c0000000-ffffea01ffffffff] PMD -> [ffff888000600000-ffff8880405fffff] on node 4 [ 0.000000] [ffffea0200000000-ffffea022fffffff] PMD -> [ffff888040800000-ffff8880707fffff] on node 4 [ 0.000000] [ffffea0230000000-ffffea023fffffff] PMD -> [ffff88a000600000-ffff88a0105fffff] on node 5 [ 0.000000] [ffffea0240000000-ffffea027fffffff] PMD -> [ffff88a010800000-ffff88a0507fffff] on node 5 [ 0.000000] [ffffea0280000000-ffffea029fffffff] PMD -> [ffff88a050a00000-ffff88a0709fffff] on node 5 [ 0.000000] [ffffea02a0000000-ffffea02bfffffff] PMD -> [ffff88c000600000-ffff88c0205fffff] on node 6 [ 0.000000] [ffffea02c0000000-ffffea02ffffffff] PMD -> [ffff88c020800000-ffff88c0607fffff] on node 6 [ 0.000000] [ffffea0300000000-ffffea030fffffff] PMD -> [ffff88c060a00000-ffff88c0709fffff] on node 6 [ 0.000000] [ffffea0310000000-ffffea033fffffff] PMD -> [ffff88e000600000-ffff88e0305fffff] on node 7 [ 0.000000] [ffffea0340000000-ffffea037fffffff] PMD -> [ffff88e030800000-ffff88e0707fffff] on node 7 after patch will get [ 0.000000] [ffffea0000000000-ffffea006fffffff] PMD -> [ffff880100200000-ffff88016e5fffff] on node 0 [ 0.000000] [ffffea0070000000-ffffea00dfffffff] PMD -> [ffff882000200000-ffff8820701fffff] on node 1 [ 0.000000] [ffffea00e0000000-ffffea014fffffff] PMD -> [ffff884000200000-ffff8840701fffff] on node 2 [ 0.000000] [ffffea0150000000-ffffea01bfffffff] PMD -> [ffff886000200000-ffff8860701fffff] on node 3 [ 0.000000] [ffffea01c0000000-ffffea022fffffff] PMD -> [ffff888000200000-ffff8880701fffff] on node 4 [ 0.000000] [ffffea0230000000-ffffea029fffffff] PMD -> [ffff88a000200000-ffff88a0701fffff] on node 5 [ 0.000000] [ffffea02a0000000-ffffea030fffffff] PMD -> [ffff88c000200000-ffff88c0701fffff] on node 6 [ 0.000000] [ffffea0310000000-ffffea037fffffff] PMD -> [ffff88e000200000-ffff88e0701fffff] on node 7 -v2: change buf to vmemmap_buf instead according to Ingo also add CONFIG_SPARSEMEM_ALLOC_MEM_MAP_TOGETHER according to Ingo -v3: according to Andrew, use sizeof(name) instead of hard coded 15 Signed-off-by: Yinghai Lu <yinghai@kernel.org> LKML-Reference: <1265793639-15071-19-git-send-email-yinghai@kernel.org> Cc: Christoph Lameter <cl@linux-foundation.org> Acked-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2010-01-05sh: Drop down to a single quicklist.Paul Mundt
We previously had 2 quicklists, one for the PGD case and one for PTEs. Now that the PGD/PMD cases are handled through slab caches due to the multi-level configurability, only the PTE quicklist remains. As such, reduce NR_QUICK to its appropriate size and bump down the PTE quicklist index. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-12-21HWPOISON: Add PROC_FS dependency to hwpoison injector v2Andi Kleen
The injector filter requires stable_page_flags() which is supplied by procfs. So make it dependent on that. Also add ifdefs around the filter code in memory-failure.c so that when the filter is disabled due to missing dependencies the whole code still builds. Reported-by: Ingo Molnar Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-12-17NOMMU: Optimise away the {dac_,}mmap_min_addr testsDavid Howells
In NOMMU mode clamp dac_mmap_min_addr to zero to cause the tests on it to be skipped by the compiler. We do this as the minimum mmap address doesn't make any sense in NOMMU mode. mmap_min_addr and round_hint_to_min() can be discarded entirely in NOMMU mode. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-12-16HWPOISON: mention HWPoison in Kconfig entryAndi Kleen
2009-12-16HWPOISON: add page flags filterWu Fengguang
When specified, only poison pages if ((page_flags & mask) == value). - corrupt-filter-flags-mask - corrupt-filter-flags-value This allows stress testing of many kinds of pages. Strictly speaking, the buddy pages requires taking zone lock, to avoid setting PG_hwpoison on a "was buddy but now allocated to someone" page. However we can just do nothing because we set PG_locked in the beginning, this prevents the page allocator from allocating it to someone. (It will BUG() on the unexpected PG_locked, which is fine for hwpoison testing.) [AK: Add select PROC_PAGE_MONITOR to satisfy dependency] CC: Nick Piggin <npiggin@suse.de> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-12-15ksm: remove unswappable max_kernel_pagesHugh Dickins
Now that ksm pages are swappable, and the known holes plugged, remove mention of unswappable kernel pages from KSM documentation and comments. Remove the totalram_pages/4 initialization of max_kernel_pages. In fact, remove max_kernel_pages altogether - we can reinstate it if removal turns out to break someone's script; but if we later want to limit KSM's memory usage, limiting the stable nodes would not be an effective approach. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Chris Wright <chrisw@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15mm: stop ptlock enlarging struct pageHugh Dickins
CONFIG_DEBUG_SPINLOCK adds 12 or 16 bytes to a 32- or 64-bit spinlock_t, and CONFIG_DEBUG_LOCK_ALLOC adds another 12 or 24 bytes to it: lockdep enables both of those, and CONFIG_LOCK_STAT adds 8 or 16 bytes to that. When 2.6.15 placed the split page table lock inside struct page (usually sized 32 or 56 bytes), only CONFIG_DEBUG_SPINLOCK was a possibility, and we ignored the enlargement (but fitted in CONFIG_GENERIC_LOCKBREAK's 4 by letting the spinlock_t occupy both page->private and page->mapping). Should these debugging options be allowed to double the size of a struct page, when only one minority use of the page (as a page table) needs to fit a spinlock in there? Perhaps not. Take the easy way out: switch off SPLIT_PTLOCK_CPUS when DEBUG_SPINLOCK or DEBUG_LOCK_ALLOC is in force. I've sometimes tried to be cleverer, kmallocing a cacheline for the spinlock when it doesn't fit, but given up each time. Falling back to mm->page_table_lock (as we do when ptlock is not split) lets lockdep check out the strictest path anyway. And now that some arches allow 8192 cpus, use 999999 for infinity. (What has this got to do with KSM swapping? It doesn't care about the size of struct page, but may care about random junk in page->mapping - to be explained separately later.) Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Nick Piggin <npiggin@suse.de> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15mm: CONFIG_MMU for PG_mlockedHugh Dickins
Remove three degrees of obfuscation, left over from when we had CONFIG_UNEVICTABLE_LRU. MLOCK_PAGES is CONFIG_HAVE_MLOCKED_PAGE_BIT is CONFIG_HAVE_MLOCK is CONFIG_MMU. rmap.o (and memory-failure.o) are only built when CONFIG_MMU, so don't need such conditions at all. Somehow, I feel no compulsion to remove the CONFIG_HAVE_MLOCK* lines from 169 defconfigs: leave those to evolve in due course. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Nick Piggin <npiggin@suse.de> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-17mm: allow memory hotplug and hibernation in the same kernelAndi Kleen
Allow memory hotplug and hibernation in the same kernel Memory hotplug and hibernation were exclusive in Kconfig. This is obviously a problem for distribution kernels who want to support both in the same image. After some discussions with Rafael and others the only problem is with parallel memory hotadd or removal while a hibernation operation is in process. It was also working for s390 before. This patch removes the Kconfig level exclusion, and simply makes the memory add / remove functions grab the pm_mutex to exclude against hibernation. Fixes a regression - old kernels didn't exclude memory hotadd and hibernation. Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc/ppc64: Use preempt_schedule_irq instead of preempt_schedule powerpc: Minor cleanup to lib/Kconfig.debug powerpc: Minor cleanup to sound/ppc/Kconfig powerpc: Minor cleanup to init/Kconfig powerpc: Limit memory hotplug support to PPC64 Book-3S machines powerpc: Limit hugetlbfs support to PPC64 Book-3S machines powerpc: Fix compile errors found by new ppc64e_defconfig powerpc: Add a Book-3E 64-bit defconfig powerpc/booke: Fix xmon single step on PowerPC Book-E powerpc: Align vDSO base address powerpc: Fix segment mapping in vdso32 powerpc/iseries: Remove compiler version dependent hack powerpc/perf_events: Fix priority of MSR HV vs PR bits powerpc/5200: Update defconfigs drivers/serial/mpc52xx_uart.c: Use UPIO_MEM rather than SERIAL_IO_MEM powerpc/boot/dts: drop obsolete 'fsl5200-clocking' of: Remove nested function mpc5200: support for the MAN mpc5200 based board mucmc52 mpc5200: support for the MAN mpc5200 based board uc101
