path: root/mm/Makefile
2013-04-29memcg: add memory.pressure_level eventsAnton Vorontsov
With this patch userland applications that want to maintain the interactivity/memory allocation cost can use the pressure level notifications. The levels are defined like this: The "low" level means that the system is reclaiming memory for new allocations. Monitoring this reclaiming activity might be useful for maintaining cache level. Upon notification, the program (typically "Activity Manager") might analyze vmstat and act in advance (i.e. prematurely shutdown unimportant services). The "medium" level means that the system is experiencing medium memory pressure, the system might be making swap, paging out active file caches, etc. Upon this event applications may decide to further analyze vmstat/zoneinfo/memcg or internal memory usage statistics and free any resources that can be easily reconstructed or re-read from a disk. The "critical" level means that the system is actively thrashing, it is about to out of memory (OOM) or even the in-kernel OOM killer is on its way to trigger. Applications should do whatever they can to help the system. It might be too late to consult with vmstat or any other statistics, so it's advisable to take an immediate action. The events are propagated upward until the event is handled, i.e. the events are not pass-through. Here is what this means: for example you have three cgroups: A->B->C. Now you set up an event listener on cgroups A, B and C, and suppose group C experiences some pressure. In this situation, only group C will receive the notification, i.e. groups A and B will not receive it. This is done to avoid excessive "broadcasting" of messages, which disturbs the system and which is especially bad if we are low on memory or thrashing. So, organize the cgroups wisely, or propagate the events manually (or, ask us to implement the pass-through events, explaining why would you need them.) Performance wise, the memory pressure notifications feature itself is lightweight and does not require much of bookkeeping, in contrast to the rest of memcg features. Unfortunately, as of current memcg implementation, pages accounting is an inseparable part and cannot be turned off. The good news is that there are some efforts[1] to improve the situation; plus, implementing the same, fully API-compatible[2] interface for CONFIG_MEMCG=n case (e.g. embedded) is also a viable option, so it will not require any changes on the userland side. [1] http://permalink.gmane.org/gmane.linux.kernel.cgroups/6291 [2] http://lkml.org/lkml/2013/2/21/454 [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix CONFIG_CGROPUPS=n warnings] Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org> Acked-by: Kirill A. Shutemov <kirill@shutemov.name> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Tejun Heo <tj@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Glauber Costa <glommer@parallels.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Luiz Capitulino <lcapitulino@redhat.com> Cc: Greg Thelen <gthelen@google.com> Cc: Leonid Moiseichuk <leonid.moiseichuk@nokia.com> Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Cc: John Stultz <john.stultz@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-11mm: introduce a common interface for balloon pages mobilityRafael Aquini
Memory fragmentation introduced by ballooning might reduce significantly the number of 2MB contiguous memory blocks that can be used within a guest, thus imposing performance penalties associated with the reduced number of transparent huge pages that could be used by the guest workload. This patch introduces a common interface to help a balloon driver on making its page set movable to compaction, and thus allowing the system to better leverage the compation efforts on memory defragmentation. [akpm@linux-foundation.org: use PAGE_FLAGS_CHECK_AT_PREP, s/__balloon_page_flags/page_flags_cleared/, small cleanups] [rientjes@google.com: allow balloon compaction for any system with memory compaction enabled, which is the defconfig] Signed-off-by: Rafael Aquini <aquini@redhat.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: replace vma prio_tree with an interval treeMichel Lespinasse
Implement an interval tree as a replacement for the VMA prio_tree. The algorithms are similar to lib/interval_tree.c; however that code can't be directly reused as the interval endpoints are not explicitly stored in the VMA. So instead, the common algorithm is moved into a template and the details (node type, how to get interval endpoints from the node, etc) are filled in using the C preprocessor. Once the interval tree functions are available, using them as a replacement to the VMA prio tree is a relatively simple, mechanical job. Signed-off-by: Michel Lespinasse <walken@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm: factor out memory isolate functionsMinchan Kim
mm/page_alloc.c has some memory isolation functions but they are used only when we enable CONFIG_{CMA|MEMORY_HOTPLUG|MEMORY_FAILURE}. So let's make it configurable by new CONFIG_MEMORY_ISOLATION so that it can reduce binary size and we can check it simple by CONFIG_MEMORY_ISOLATION, not if defined CONFIG_{CMA|MEMORY_HOTPLUG|MEMORY_FAILURE}. Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31memcg: rename config variablesAndrew Morton
Sanity: CONFIG_CGROUP_MEM_RES_CTLR -> CONFIG_MEMCG CONFIG_CGROUP_MEM_RES_CTLR_SWAP -> CONFIG_MEMCG_SWAP CONFIG_CGROUP_MEM_RES_CTLR_SWAP_ENABLED -> CONFIG_MEMCG_SWAP_ENABLED CONFIG_CGROUP_MEM_RES_CTLR_KMEM -> CONFIG_MEMCG_KMEM [mhocko@suse.cz: fix missed bits] Cc: Glauber Costa <glommer@parallels.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Cc: Tejun Heo <tj@kernel.org> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: David Rientjes <rientjes@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm/hugetlb: add new HugeTLB cgroupAneesh Kumar K.V
Implement a new controller that allows us to control HugeTLB allocations. The extension allows to limit the HugeTLB usage per control group and enforces the controller limit during page fault. Since HugeTLB doesn't support page reclaim, enforcing the limit at page fault time implies that, the application will get SIGBUS signal if it tries to access HugeTLB pages beyond its limit. This requires the application to know beforehand how much HugeTLB pages it would require for its use. The charge/uncharge calls will be added to HugeTLB code in later patch. Support for cgroup removal will be added in later patches. [akpm@linux-foundation.org: s/CONFIG_CGROUP_HUGETLB_RES_CTLR/CONFIG_MEMCG_HUGETLB/g] [akpm@linux-foundation.org: s/CONFIG_MEMCG_HUGETLB/CONFIG_CGROUP_HUGETLB/g] Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: David Rientjes <rientjes@google.com> Cc: Hillf Danton <dhillf@gmail.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30Merge branch 'slab/next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux Pull SLAB changes from Pekka Enberg: "Most of the changes included are from Christoph Lameter's "common slab" patch series that unifies common parts of SLUB, SLAB, and SLOB allocators. The unification is needed for Glauber Costa's "kmem memcg" work that will hopefully appear for v3.7. The rest of the changes are fixes and speedups by various people." * 'slab/next' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux: (32 commits) mm: Fix build warning in kmem_cache_create() slob: Fix early boot kernel crash mm, slub: ensure irqs are enabled for kmemcheck mm, sl[aou]b: Move kmem_cache_create mutex handling to common code mm, sl[aou]b: Use a common mutex definition mm, sl[aou]b: Common definition for boot state of the slab allocators mm, sl[aou]b: Extract common code for kmem_cache_create() slub: remove invalid reference to list iterator variable mm: Fix signal SIGFPE in slabinfo.c. slab: move FULL state transition to an initcall slab: Fix a typo in commit 8c138b "slab: Get rid of obj_size macro" mm, slab: Build fix for recent kmem_cache changes slab: rename gfpflags to allocflags slub: refactoring unfreeze_partials() slub: use __cmpxchg_double_slab() at interrupt disabled place slab/mempolicy: always use local policy from interrupt context slab: Get rid of obj_size macro mm, sl[aou]b: Extract common fields from struct kmem_cache slab: Remove some accessors slab: Use page struct fields instead of casting ...
2012-07-09mm, sl[aou]b: Extract common code for kmem_cache_create()Christoph Lameter
Kmem_cache_create() does a variety of sanity checks but those vary depending on the allocator. Use the strictest tests and put them into a slab_common file. Make the tests conditional on CONFIG_DEBUG_VM. This patch has the effect of adding sanity checks for SLUB and SLOB under CONFIG_DEBUG_VM and removes the checks in SLAB for !CONFIG_DEBUG_VM. Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2012-06-04Merge tag 'stable/frontswap.v16-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm Pull frontswap feature from Konrad Rzeszutek Wilk: "Frontswap provides a "transcendent memory" interface for swap pages. In some environments, dramatic performance savings may be obtained because swapped pages are saved in RAM (or a RAM-like device) instead of a swap disk. This tag provides the basic infrastructure along with some changes to the existing backends." Fix up trivial conflict in mm/Makefile due to removal of swap token code changing a line next to the new frontswap entry. This pull request came in before the merge window even opened, it got delayed to after the merge window by me just wanting to make sure it had actual users. Apparently IBM is using this on their embedded side, and Jan Beulich says that it's already made available for SLES and OpenSUSE users. Also acked by Rik van Riel, and Konrad points to other people liking it too. So in it goes. By Dan Magenheimer (4) and Konrad Rzeszutek Wilk (2) via Konrad Rzeszutek Wilk * tag 'stable/frontswap.v16-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm: frontswap: s/put_page/store/g s/get_page/load MAINTAINER: Add myself for the frontswap API mm: frontswap: config and doc files mm: frontswap: core frontswap functionality mm: frontswap: core swap subsystem hooks and headers mm: frontswap: add frontswap header file
2012-05-29Cross Memory Attach: make it KconfigurableChristopher Yeoh
Add a Kconfig option to allow people who don't want cross memory attach to not have it included in their build. Signed-off-by: Chris Yeoh <yeohc@au1.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm: remove swap token codeRik van Riel
The swap token code no longer fits in with the current VM model. It does not play well with cgroups or the better NUMA placement code in development, since we have only one swap token globally. It also has the potential to mess with scalability of the system, by increasing the number of non-reclaimable pages on the active and inactive anon LRU lists. Last but not least, the swap token code has been broken for a year without complaints, as reported by Konstantin Khlebnikov. This suggests we no longer have much use for it. The days of sub-1G memory systems with heavy use of swap are over. If we ever need thrashing reducing code in the future, we will have to implement something that does scale. Signed-off-by: Rik van Riel <riel@redhat.com> Cc: Konstantin Khlebnikov <khlebnikov@openvz.org> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Hugh Dickins <hughd@google.com> Acked-by: Bob Picco <bpicco@meloft.net> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-21mm: compaction: export some of the functionsMichal Nazarewicz
This commit exports some of the functions from compaction.c file outside of it adding their declaration into internal.h header file so that other mm related code can use them. This forced compaction.c to always be compiled (as opposed to being compiled only if CONFIG_COMPACTION is defined) but as to avoid introducing code that user did not ask for, part of the compaction.c is now wrapped in on #ifdef. Signed-off-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Rob Clark <rob.clark@linaro.org> Tested-by: Ohad Ben-Cohen <ohad@wizery.com> Tested-by: Benjamin Gaignard <benjamin.gaignard@linaro.org> Tested-by: Robert Nelson <robertcnelson@gmail.com> Tested-by: Barry Song <Baohua.Song@csr.com>
2012-05-15mm: frontswap: config and doc filesDan Magenheimer
This patch 4of4 adds configuration and documentation files including a FAQ. [v14: updated docs/FAQ to use zcache and RAMster as examples] [v10: no change] [v9: akpm@linux-foundation.org: sysfs->debugfs; no longer need Doc/ABI file] [v8: rebase to 3.0-rc4] [v7: rebase to 3.0-rc3] [v6: rebase to 3.0-rc1] [v5: change config default to n] [v4: rebase to 2.6.39] Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Acked-by: Jan Beulich <JBeulich@novell.com> Acked-by: Seth Jennings <sjenning@linux.vnet.ibm.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Chris Mason <chris.mason@oracle.com> Cc: Rik Riel <riel@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-10-31Cross Memory AttachChristopher Yeoh
The basic idea behind cross memory attach is to allow MPI programs doing intra-node communication to do a single copy of the message rather than a double copy of the message via shared memory. The following patch attempts to achieve this by allowing a destination process, given an address and size from a source process, to copy memory directly from the source process into its own address space via a system call. There is also a symmetrical ability to copy from the current process's address space into a destination process's address space. - Use of /proc/pid/mem has been considered, but there are issues with using it: - Does not allow for specifying iovecs for both src and dest, assuming preadv or pwritev was implemented either the area read from or written to would need to be contiguous. - Currently mem_read allows only processes who are currently ptrace'ing the target and are still able to ptrace the target to read from the target. This check could possibly be moved to the open call, but its not clear exactly what race this restriction is stopping (reason appears to have been lost) - Having to send the fd of /proc/self/mem via SCM_RIGHTS on unix domain socket is a bit ugly from a userspace point of view, especially when you may have hundreds if not (eventually) thousands of processes that all need to do this with each other - Doesn't allow for some future use of the interface we would like to consider adding in the future (see below) - Interestingly reading from /proc/pid/mem currently actually involves two copies! (But this could be fixed pretty easily) As mentioned previously use of vmsplice instead was considered, but has problems. Since you need the reader and writer working co-operatively if the pipe is not drained then you block. Which requires some wrapping to do non blocking on the send side or polling on the receive. In all to all communication it requires ordering otherwise you can deadlock. And in the example of many MPI tasks writing to one MPI task vmsplice serialises the copying. There are some cases of MPI collectives where even a single copy interface does not get us the performance gain we could. For example in an MPI_Reduce rather than copy the data from the source we would like to instead use it directly in a mathops (say the reduce is doing a sum) as this would save us doing a copy. We don't need to keep a copy of the data from the source. I haven't implemented this, but I think this interface could in the future do all this through the use of the flags - eg could specify the math operation and type and the kernel rather than just copying the data would apply the specified operation between the source and destination and store it in the destination. Although we don't have a "second user" of the interface (though I've had some nibbles from people who may be interested in using it for intra process messaging which is not MPI). This interface is something which hardware vendors are already doing for their custom drivers to implement fast local communication. And so in addition to this being useful for OpenMPI it would mean the driver maintainers don't have to fix things up when the mm changes. There was some discussion about how much faster a true zero copy would go. Here's a link back to the email with some testing I did on that: http://marc.info/?l=linux-mm&m=130105930902915&w=2 There is a basic man page for the proposed interface here: http://ozlabs.org/~cyeoh/cma/process_vm_readv.txt This has been implemented for x86 and powerpc, other architecture should mainly (I think) just need to add syscall numbers for the process_vm_readv and process_vm_writev. There are 32 bit compatibility versions for 64-bit kernels. For arch maintainers there are some simple tests to be able to quickly verify that the syscalls are working correctly here: http://ozlabs.org/~cyeoh/cma/cma-test-20110718.tgz Signed-off-by: Chris Yeoh <yeohc@au1.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Cc: <linux-man@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26mm: cleancache core ops functions and configDan Magenheimer
This third patch of eight in this cleancache series provides the core code for cleancache that interfaces between the hooks in VFS and individual filesystems and a cleancache backend. It also includes build and config patches. Two new files are added: mm/cleancache.c and include/linux/cleancache.h. Note that CONFIG_CLEANCACHE can default to on; in systems that do not provide a cleancache backend, all hooks devolve to a simple check of a global enable flag, so performance impact should be negligible but can be reduced to zero impact if config'ed off. However for this first commit, it defaults to off. Details and a FAQ can be found in Documentation/vm/cleancache.txt Credits: Cleancache_ops design derived from Jeremy Fitzhardinge design for tmem [v8: dan.magenheimer@oracle.com: fix exportfs call affecting btrfs] [v8: akpm@linux-foundation.org: use static inline function, not macro] [v7: dan.magenheimer@oracle.com: cleanup sysfs and remove cleancache prefix] [v6: JBeulich@novell.com: robustly handle buggy fs encode_fh actor definition] [v5: jeremy@goop.org: clean up global usage and static var names] [v5: jeremy@goop.org: simplify init hook and any future fs init changes] [v5: hch@infradead.org: cleaner non-global interface for ops registration] [v4: adilger@sun.com: interface must support exportfs FS's] [v4: hch@infradead.org: interface must support 64-bit FS on 32-bit kernel] [v3: akpm@linux-foundation.org: use one ops struct to avoid pointer hops] [v3: akpm@linux-foundation.org: document and ensure PageLocked reqts are met] [v3: ngupta@vflare.org: fix success/fail codes, change funcs to void] [v2: viro@ZenIV.linux.org.uk: use sane types] Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Reviewed-by: Jeremy Fitzhardinge <jeremy@goop.org> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Acked-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Nitin Gupta <ngupta@vflare.org> Acked-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Andreas Dilger <adilger@sun.com> Acked-by: Jan Beulich <JBeulich@novell.com> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik Van Riel <riel@redhat.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Ted Ts'o <tytso@mit.edu> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <joel.becker@oracle.com>
2011-02-24bootmem: Separate out CONFIG_NO_BOOTMEM code into nobootmem.cYinghai Lu
mm/bootmem.c contained code paths for both bootmem and no bootmem configurations. They implement about the same set of APIs in different ways and as a result bootmem.c contains massive amount of #ifdef CONFIG_NO_BOOTMEM. Separate out CONFIG_NO_BOOTMEM code into mm/nobootmem.c. As the common part is relatively small, duplicate them in nobootmem.c instead of creating a common file or ifdef'ing in bootmem.c. The followings are duplicated. * {min|max}_low_pfn, max_pfn, saved_max_pfn * free_bootmem_late() * ___alloc_bootmem() * __alloc_bootmem_low() The followings are applicable only to nobootmem and moved verbatim. * __free_pages_memory() * free_all_memory_core_early() The followings are not applicable to nobootmem and omitted in nobootmem.c. * reserve_bootmem_node() * reserve_bootmem() The rest split function bodies according to CONFIG_NO_BOOTMEM. Makefile is updated so that only either bootmem.c or nobootmem.c is built according to CONFIG_NO_BOOTMEM. This patch doesn't introduce any behavior change. -tj: Rewrote commit description. Suggested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Acked-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2011-01-13thp: transparent hugepage coreAndrea Arcangeli
Lately I've been working to make KVM use hugepages transparently without the usual restrictions of hugetlbfs. Some of the restrictions I'd like to see removed: 1) hugepages have to be swappable or the guest physical memory remains locked in RAM and can't be paged out to swap 2) if a hugepage allocation fails, regular pages should be allocated instead and mixed in the same vma without any failure and without userland noticing 3) if some task quits and more hugepages become available in the buddy, guest physical memory backed by regular pages should be relocated on hugepages automatically in regions under madvise(MADV_HUGEPAGE) (ideally event driven by waking up the kernel deamon if the order=HPAGE_PMD_SHIFT-PAGE_SHIFT list becomes not null) 4) avoidance of reservation and maximization of use of hugepages whenever possible. Reservation (needed to avoid runtime fatal faliures) may be ok for 1 machine with 1 database with 1 database cache with 1 database cache size known at boot time. It's definitely not feasible with a virtualization hypervisor usage like RHEV-H that runs an unknown number of virtual machines with an unknown size of each virtual machine with an unknown amount of pagecache that could be potentially useful in the host for guest not using O_DIRECT (aka cache=off). hugepages in the virtualization hypervisor (and also in the guest!) are much more important than in a regular host not using virtualization, becasue with NPT/EPT they decrease the tlb-miss cacheline accesses from 24 to 19 in case only the hypervisor uses transparent hugepages, and they decrease the tlb-miss cacheline accesses from 19 to 15 in case both the linux hypervisor and the linux guest both uses this patch (though the guest will limit the addition speedup to anonymous regions only for now...). Even more important is that the tlb miss handler is much slower on a NPT/EPT guest than for a regular shadow paging or no-virtualization scenario. So maximizing the amount of virtual memory cached by the TLB pays off significantly more with NPT/EPT than without (even if there would be no significant speedup in the tlb-miss runtime). The first (and more tedious) part of this work requires allowing the VM to handle anonymous hugepages mixed with regular pages transparently on regular anonymous vmas. This is what this patch tries to achieve in the least intrusive possible way. We want hugepages and hugetlb to be used in a way so that all applications can benefit without changes (as usual we leverage the KVM virtualization design: by improving the Linux VM at large, KVM gets the performance boost too). The most important design choice is: always fallback to 4k allocation if the hugepage allocation fails! This is the _very_ opposite of some large pagecache patches that failed with -EIO back then if a 64k (or similar) allocation failed... Second important decision (to reduce the impact of the feature on the existing pagetable handling code) is that at any time we can split an hugepage into 512 regular pages and it has to be done with an operation that can't fail. This way the reliability of the swapping isn't decreased (no need to allocate memory when we are short on memory to swap) and it's trivial to plug a split_huge_page* one-liner where needed without polluting the VM. Over time we can teach mprotect, mremap and friends to handle pmd_trans_huge natively without calling split_huge_page*. The fact it can't fail isn't just for swap: if split_huge_page would return -ENOMEM (instead of the current void) we'd need to rollback the mprotect from the middle of it (ideally including undoing the split_vma) which would be a big change and in the very wrong direction (it'd likely be simpler not to call split_huge_page at all and to teach mprotect and friends to handle hugepages instead of rolling them back from the middle). In short the very value of split_huge_page is that it can't fail. The collapsing and madvise(MADV_HUGEPAGE) part will remain separated and incremental and it'll just be an "harmless" addition later if this initial part is agreed upon. It also should be noted that locking-wise replacing regular pages with hugepages is going to be very easy if compared to what I'm doing below in split_huge_page, as it will only happen when page_count(page) matches page_mapcount(page) if we can take the PG_lock and mmap_sem in write mode. collapse_huge_page will be a "best effort" that (unlike split_huge_page) can fail at the minimal sign of trouble and we can try again later. collapse_huge_page will be similar to how KSM works and the madvise(MADV_HUGEPAGE) will work similar to madvise(MADV_MERGEABLE). The default I like is that transparent hugepages are used at page fault time. This can be changed with /sys/kernel/mm/transparent_hugepage/enabled. The control knob can be set to three values "always", "madvise", "never" which mean respectively that hugepages are always used, or only inside madvise(MADV_HUGEPAGE) regions, or never used. /sys/kernel/mm/transparent_hugepage/defrag instead controls if the hugepage allocation should defrag memory aggressively "always", only inside "madvise" regions, or "never". The pmd_trans_splitting/pmd_trans_huge locking is very solid. The put_page (from get_user_page users that can't use mmu notifier like O_DIRECT) that runs against a __split_huge_page_refcount instead was a pain to serialize in a way that would result always in a coherent page count for both tail and head. I think my locking solution with a compound_lock taken only after the page_first is valid and is still a PageHead should be safe but it surely needs review from SMP race point of view. In short there is no current existing way to serialize the O_DIRECT final put_page against split_huge_page_refcount so I had to invent a new one (O_DIRECT loses knowledge on the mapping status by the time gup_fast returns so...). And I didn't want to impact all gup/gup_fast users for now, maybe if we change the gup interface substantially we can avoid this locking, I admit I didn't think too much about it because changing the gup unpinning interface would be invasive. If we ignored O_DIRECT we could stick to the existing compound refcounting code, by simply adding a get_user_pages_fast_flags(foll_flags) where KVM (and any other mmu notifier user) would call it without FOLL_GET (and if FOLL_GET isn't set we'd just BUG_ON if nobody registered itself in the current task mmu notifier list yet). But O_DIRECT is fundamental for decent performance of virtualized I/O on fast storage so we can't avoid it to solve the race of put_page against split_huge_page_refcount to achieve a complete hugepage feature for KVM. Swap and oom works fine (well just like with regular pages ;). MMU notifier is handled transparently too, with the exception of the young bit on the pmd, that didn't have a range check but I think KVM will be fine because the whole point of hugepages is that EPT/NPT will also use a huge pmd when they notice gup returns pages with PageCompound set, so they won't care of a range and there's just the pmd young bit to check in that case. NOTE: in some cases if the L2 cache is small, this may slowdown and waste memory during COWs because 4M of memory are accessed in a single fault instead of 8k (the payoff is that after COW the program can run faster). So we might want to switch the copy_huge_page (and clear_huge_page too) to not temporal stores. I also extensively researched ways to avoid this cache trashing with a full prefault logic that would cow in 8k/16k/32k/64k up to 1M (I can send those patches that fully implemented prefault) but I concluded they're not worth it and they add an huge additional complexity and they remove all tlb benefits until the full hugepage has been faulted in, to save a little bit of memory and some cache during app startup, but they still don't improve substantially the cache-trashing during startup if the prefault happens in >4k chunks. One reason is that those 4k pte entries copied are still mapped on a perfectly cache-colored hugepage, so the trashing is the worst one can generate in those copies (cow of 4k page copies aren't so well colored so they trashes less, but again this results in software running faster after the page fault). Those prefault patches allowed things like a pte where post-cow pages were local 4k regular anon pages and the not-yet-cowed pte entries were pointing in the middle of some hugepage mapped read-only. If it doesn't payoff substantially with todays hardware it will payoff even less in the future with larger l2 caches, and the prefault logic would blot the VM a lot. If one is emebdded transparent_hugepage can be disabled during boot with sysfs or with the boot commandline parameter transparent_hugepage=0 (or transparent_hugepage=2 to restrict hugepages inside madvise regions) that will ensure not a single hugepage is allocated at boot time. It is simple enough to just disable transparent hugepage globally and let transparent hugepages be allocated selectively by applications in the MADV_HUGEPAGE region (both at page fault time, and if enabled with the collapse_huge_page too through the kernel daemon). This patch supports only hugepages mapped in the pmd, archs that have smaller hugepages will not fit in this patch alone. Also some archs like power have certain tlb limits that prevents mixing different page size in the same regions so they will not fit in this framework that requires "graceful fallback" to basic PAGE_SIZE in case of physical memory fragmentation. hugetlbfs remains a perfect fit for those because its software limits happen to match the hardware limits. hugetlbfs also remains a perfect fit for hugepage sizes like 1GByte that cannot be hoped to be found not fragmented after a certain system uptime and that would be very expensive to defragment with relocation, so requiring reservation. hugetlbfs is the "reservation way", the point of transparent hugepages is not to have any reservation at all and maximizing the use of cache and hugepages at all times automatically. Some performance result: vmx andrea # LD_PRELOAD=/usr/lib64/libhugetlbfs.so HUGETLB_MORECORE=yes HUGETLB_PATH=/mnt/huge/ ./largep ages3 memset page fault 1566023 memset tlb miss 453854 memset second tlb miss 453321 random access tlb miss 41635 random access second tlb miss 41658 vmx andrea # LD_PRELOAD=/usr/lib64/libhugetlbfs.so HUGETLB_MORECORE=yes HUGETLB_PATH=/mnt/huge/ ./largepages3 memset page fault 1566471 memset tlb miss 453375 memset second tlb miss 453320 random access tlb miss 41636 random access second tlb miss 41637 vmx andrea # ./largepages3 memset page fault 1566642 memset tlb miss 453417 memset second tlb miss 453313 random access tlb miss 41630 random access second tlb miss 41647 vmx andrea # ./largepages3 memset page fault 1566872 memset tlb miss 453418 memset second tlb miss 453315 random access tlb miss 41618 random access second tlb miss 41659 vmx andrea # echo 0 > /proc/sys/vm/transparent_hugepage vmx andrea # ./largepages3 memset page fault 2182476 memset tlb miss 460305 memset second tlb miss 460179 random access tlb miss 44483 random access second tlb miss 44186 vmx andrea # ./largepages3 memset page fault 2182791 memset tlb miss 460742 memset second tlb miss 459962 random access tlb miss 43981 random access second tlb miss 43988 ============ #include <stdio.h> #include <stdlib.h> #include <string.h> #include <sys/time.h> #define SIZE (3UL*1024*1024*1024) int main() { char *p = malloc(SIZE), *p2; struct timeval before, after; gettimeofday(&before, NULL); memset(p, 0, SIZE); gettimeofday(&after, NULL); printf("memset page fault %Lu\n", (after.tv_sec-before.tv_sec)*1000000UL + after.tv_usec-before.tv_usec); gettimeofday(&before, NULL); memset(p, 0, SIZE); gettimeofday(&after, NULL); printf("memset tlb miss %Lu\n", (after.tv_sec-before.tv_sec)*1000000UL + after.tv_usec-before.tv_usec); gettimeofday(&before, NULL); memset(p, 0, SIZE); gettimeofday(&after, NULL); printf("memset second tlb miss %Lu\n", (after.tv_sec-before.tv_sec)*1000000UL + after.tv_usec-before.tv_usec); gettimeofday(&before, NULL); for (p2 = p; p2 < p+SIZE; p2 += 4096) *p2 = 0; gettimeofday(&after, NULL); printf("random access tlb miss %Lu\n", (after.tv_sec-before.tv_sec)*1000000UL + after.tv_usec-before.tv_usec); gettimeofday(&before, NULL); for (p2 = p; p2 < p+SIZE; p2 += 4096) *p2 = 0; gettimeofday(&after, NULL); printf("random access second tlb miss %Lu\n", (after.tv_sec-before.tv_sec)*1000000UL + after.tv_usec-before.tv_usec); return 0; } ============ Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: add pmd mangling generic functionsAndrea Arcangeli
Some are needed to build but not actually used on archs not supporting transparent hugepages. Others like pmdp_clear_flush are used by x86 too. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-08percpu: use percpu allocator on UP tooTejun Heo
On UP, percpu allocations were redirected to kmalloc. This has the following problems. * For certain amount of allocations (determined by PERCPU_DYNAMIC_EARLY_SLOTS and PERCPU_DYNAMIC_EARLY_SIZE), percpu allocator can be used before the usual kernel memory allocator is brought online. On SMP, this is used to initialize the kernel memory allocator. * percpu allocator honors alignment upto PAGE_SIZE but kmalloc() doesn't. For example, workqueue makes use of larger alignments for cpu_workqueues. Currently, users of percpu allocators need to handle UP differently, which is somewhat fragile and ugly. Other than small amount of memory, there isn't much to lose by enabling percpu allocator on UP. It can simply use kernel memory based chunk allocation which was added for SMP archs w/o MMUs. This patch removes mm/percpu_up.c, builds mm/percpu.c on UP too and makes UP build use percpu-km. As percpu addresses and kernel addresses are always identity mapped and static percpu variables don't need any special treatment, nothing is arch dependent and mm/percpu.c implements generic setup_per_cpu_areas() for UP. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
2010-07-14lmb: rename to memblockYinghai Lu
via following scripts FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/lmb/memblock/g' \ -e 's/LMB/MEMBLOCK/g' \ $FILES for N in $(find . -name lmb.[ch]); do M=$(echo $N | sed 's/lmb/memblock/g') mv $N $M done and remove some wrong change like lmbench and dlmb etc. also move memblock.c from lib/ to mm/ Suggested-by: Ingo Molnar <mingo@elte.hu> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-05-25mm: compaction: memory compaction coreMel Gorman
This patch is the core of a mechanism which compacts memory in a zone by relocating movable pages towards the end of the zone. A single compaction run involves a migration scanner and a free scanner. Both scanners operate on pageblock-sized areas in the zone. The migration scanner starts at the bottom of the zone and searches for all movable pages within each area, isolating them onto a private list called migratelist. The free scanner starts at the top of the zone and searches for suitable areas and consumes the free pages within making them available for the migration scanner. The pages isolated for migration are then migrated to the newly isolated free pages. [aarcange@redhat.com: Fix unsafe optimisation] [mel@csn.ul.ie: do not schedule work on other CPUs for compaction] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-30percpu: don't implicitly include slab.h from percpu.hTejun Heo
percpu.h has always been including slab.h to get k[mz]alloc/free() for UP inline implementation. percpu.h being used by very low level headers including module.h and sched.h, this meant that a lot files unintentionally got slab.h inclusion. Lee Schermerhorn was trying to make topology.h use percpu.h and got bitten by this implicit inclusion. The right thing to do is break this ultimately unnecessary dependency. The previous patch added explicit inclusion of either gfp.h or slab.h to the source files using them. This patch updates percpu.h such that slab.h is no longer included from percpu.h. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-16make generic_acl slightly more genericChristoph Hellwig
Now that we cache the ACL pointers in the generic inode all the generic_acl cruft can go away and generic_acl.c can directly implement xattr handlers dealing with the full Posix ACL semantics for in-memory filesystems. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-10-02percpu: kill legacy percpu allocatorTejun Heo
With ia64 converted, there's no arch left which still uses legacy percpu allocator. Kill it. Signed-off-by: Tejun Heo <tj@kernel.org> Delightedly-acked-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@redhat.com> Cc: Christoph Lameter <cl@linux-foundation.org>
2009-09-24procfs: disable per-task stack usage on NOMMUAndrew Morton
It needs walk_page_range(). Reported-by: Michal Simek <monstr@monstr.eu> Tested-by: Michal Simek <monstr@monstr.eu> Cc: Stefani Seibold <stefani@seibold.net> Cc: David Howells <dhowells@redhat.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24Merge branch 'hwpoison' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6 * 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: (21 commits) HWPOISON: Enable error_remove_page on btrfs HWPOISON: Add simple debugfs interface to inject hwpoison on arbitary PFNs HWPOISON: Add madvise() based injector for hardware poisoned pages v4 HWPOISON: Enable error_remove_page for NFS HWPOISON: Enable .remove_error_page for migration aware file systems HWPOISON: The high level memory error handler in the VM v7 HWPOISON: Add PR_MCE_KILL prctl to control early kill behaviour per process HWPOISON: shmem: call set_page_dirty() with locked page HWPOISON: Define a new error_remove_page address space op for async truncation HWPOISON: Add invalidate_inode_page HWPOISON: Refactor truncate to allow direct truncating of page v2 HWPOISON: check and isolate corrupted free pages v2 HWPOISON: Handle hardware poisoned pages in try_to_unmap HWPOISON: Use bitmask/action code for try_to_unmap behaviour HWPOISON: x86: Add VM_FAULT_HWPOISON handling to x86 page fault handler v2 HWPOISON: Add poison check to page fault handling HWPOISON: Add basic support for poisoned pages in fault handler v3 HWPOISON: Add new SIGBUS error codes for hardware poison signals HWPOISON: Add support for poison swap entries v2 HWPOISON: Export some rmap vma locking to outside world ...
2009-09-23procfs: provide stack information for threadsStefani Seibold
A patch to give a better overview of the userland application stack usage, especially for embedded linux. Currently you are only able to dump the main process/thread stack usage which is showed in /proc/pid/status by the "VmStk" Value. But you get no information about the consumed stack memory of the the threads. There is an enhancement in the /proc/<pid>/{task/*,}/*maps and which marks the vm mapping where the thread stack pointer reside with "[thread stack xxxxxxxx]". xxxxxxxx is the maximum size of stack. This is a value information, because libpthread doesn't set the start of the stack to the top of the mapped area, depending of the pthread usage. A sample output of /proc/<pid>/task/<tid>/maps looks like: 08048000-08049000 r-xp 00000000 03:00 8312 /opt/z 08049000-0804a000 rw-p 00001000 03:00 8312 /opt/z 0804a000-0806b000 rw-p 00000000 00:00 0 [heap] a7d12000-a7d13000 ---p 00000000 00:00 0 a7d13000-a7f13000 rw-p 00000000 00:00 0 [thread stack: 001ff4b4] a7f13000-a7f14000 ---p 00000000 00:00 0 a7f14000-a7f36000 rw-p 00000000 00:00 0 a7f36000-a8069000 r-xp 00000000 03:00 4222 /lib/libc.so.6 a8069000-a806b000 r--p 00133000 03:00 4222 /lib/libc.so.6 a806b000-a806c000 rw-p 00135000 03:00 4222 /lib/libc.so.6 a806c000-a806f000 rw-p 00000000 00:00 0 a806f000-a8083000 r-xp 00000000 03:00 14462 /lib/libpthread.so.0 a8083000-a8084000 r--p 00013000 03:00 14462 /lib/libpthread.so.0 a8084000-a8085000 rw-p 00014000 03:00 14462 /lib/libpthread.so.0 a8085000-a8088000 rw-p 00000000 00:00 0 a8088000-a80a4000 r-xp 00000000 03:00 8317 /lib/ld-linux.so.2 a80a4000-a80a5000 r--p 0001b000 03:00 8317 /lib/ld-linux.so.2 a80a5000-a80a6000 rw-p 0001c000 03:00 8317 /lib/ld-linux.so.2 afaf5000-afb0a000 rw-p 00000000 00:00 0 [stack] ffffe000-fffff000 r-xp 00000000 00:00 0 [vdso] Also there is a new entry "stack usage" in /proc/<pid>/{task/*,}/status which will you give the current stack usage in kb. A sample output of /proc/self/status looks like: Name: cat State: R (running) Tgid: 507 Pid: 507 . . . CapBnd: fffffffffffffeff voluntary_ctxt_switches: 0 nonvoluntary_ctxt_switches: 0 Stack usage: 12 kB I also fixed stack base address in /proc/<pid>/{task/*,}/stat to the base address of the associated thread stack and not the one of the main process. This makes more sense. [akpm@linux-foundation.org: fs/proc/array.c now needs walk_page_range()] Signed-off-by: Stefani Seibold <stefani@seibold.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: move use_mm/unuse_mm from aio.c to mm/Michael S. Tsirkin
Anyone who wants to do copy to/from user from a kernel thread, needs use_mm (like what fs/aio has). Move that into mm/, to make reusing and exporting easier down the line, and make aio use it. Next intended user, besides aio, will be vhost-net. Acked-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22ksm: the mm interface to ksmHugh Dickins
This patch presents the mm interface to a dummy version of ksm.c, for better scrutiny of that interface: the real ksm.c follows later. When CONFIG_KSM is not set, madvise(2) reject MADV_MERGEABLE and MADV_UNMERGEABLE with EINVAL, since that seems more helpful than pretending that they can be serviced. But when CONFIG_KSM=y, accept them even if KSM is not currently running, and even on areas which KSM will not touch (e.g. hugetlb or shared file or special driver mappings). Like other madvices, report ENOMEM despite success if any area in the range is unmapped, and use EAGAIN to report out of memory. Define vma flag VM_MERGEABLE to identify an area on which KSM may try merging pages: leave it to ksm_madvise() to decide whether to set it. Define mm flag MMF_VM_MERGEABLE to identify an mm which might contain VM_MERGEABLE areas, to minimize callouts when forking or exiting. Based upon earlier patches by Chris Wright and Izik Eidus. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Chris Wright <chrisw@redhat.com> Signed-off-by: Izik Eidus <ieidus@redhat.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Avi Kivity <avi@redhat.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-16HWPOISON: Add simple debugfs interface to inject hwpoison on arbitary PFNsAndi Kleen
Useful for some testing scenarios, although specific testing is often done better through MADV_POISON This can be done with the x86 level MCE injector too, but this interface allows it to do independently from low level x86 changes. v2: Add module license (Haicheng Li) Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-09-16HWPOISON: The high level memory error handler in the VM v7Andi Kleen
Add the high level memory handler that poisons pages that got corrupted by hardware (typically by a two bit flip in a DIMM or a cache) on the Linux level. The goal is to prevent everyone from accessing these pages in the future. This done at the VM level by marking a page hwpoisoned and doing the appropriate action based on the type of page it is. The code that does this is portable and lives in mm/memory-failure.c To quote the overview comment: High level machine check handler. Handles pages reported by the hardware as being corrupted usually due to a 2bit ECC memory or cache failure. This focuses on pages detected as corrupted in the background. When the current CPU tries to consume corruption the currently running process can just be killed directly instead. This implies that if the error cannot be handled for some reason it's safe to just ignore it because no corruption has been consumed yet. Instead when that happens another machine check will happen. Handles page cache pages in various states. The tricky part here is that we can access any page asynchronous to other VM users, because memory failures could happen anytime and anywhere, possibly violating some of their assumptions. This is why this code has to be extremely careful. Generally it tries to use normal locking rules, as in get the standard locks, even if that means the error handling takes potentially a long time. Some of the operations here are somewhat inefficient and have non linear algorithmic complexity, because the data structures have not been optimized for this case. This is in particular the case for the mapping from a vma to a process. Since this case is expected to be rare we hope we can get away with this. There are in principle two strategies to kill processes on poison: - just unmap the data and wait for an actual reference before killing - kill as soon as corruption is detected. Both have advantages and disadvantages and should be used in different situations. Right now both are implemented and can be switched with a new sysctl vm.memory_failure_early_kill The default is early kill. The patch does some rmap data structure walking on its own to collect processes to kill. This is unusual because normally all rmap data structure knowledge is in rmap.c only. I put it here for now to keep everything together and rmap knowledge has been seeping out anyways Includes contributions from Johannes Weiner, Chris Mason, Fengguang Wu, Nick Piggin (who did a lot of great work) and others. Cc: npiggin@suse.de Cc: riel@redhat.com Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rik van Riel <riel@redhat.com> Reviewed-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com>
2009-09-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (46 commits) powerpc64: convert to dynamic percpu allocator sparc64: use embedding percpu first chunk allocator percpu: kill lpage first chunk allocator x86,percpu: use embedding for 64bit NUMA and page for 32bit NUMA percpu: update embedding first chunk allocator to handle sparse units percpu: use group information to allocate vmap areas sparsely vmalloc: implement pcpu_get_vm_areas() vmalloc: separate out insert_vmalloc_vm() percpu: add chunk->base_addr percpu: add pcpu_unit_offsets[] percpu: introduce pcpu_alloc_info and pcpu_group_info percpu: move pcpu_lpage_build_unit_map() and pcpul_lpage_dump_cfg() upward percpu: add @align to pcpu_fc_alloc_fn_t percpu: make @dyn_size mandatory for pcpu_setup_first_chunk() percpu: drop @static_size from first chunk allocators percpu: generalize first chunk allocator selection percpu: build first chunk allocators selectively percpu: rename 4k first chunk allocator to page percpu: improve boot messages percpu: fix pcpu_reclaim() locking ... Fix trivial conflict as by Tejun Heo in kernel/sched.c
2009-09-11writeback: get rid of pdflush completelyJens Axboe
It is now unused, so kill it off. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-06-24percpu: use dynamic percpu allocator as the default percpu allocatorTejun Heo
This patch makes most !CONFIG_HAVE_SETUP_PER_CPU_AREA archs use dynamic percpu allocator. The first chunk is allocated using embedding helper and 8k is reserved for modules. This ensures that the new allocator behaves almost identically to the original allocator as long as static percpu variables are concerned, so it shouldn't introduce much breakage. s390 and alpha use custom SHIFT_PERCPU_PTR() to work around addressing range limit the addressing model imposes. Unfortunately, this breaks if the address is specified using a variable, so for now, the two archs aren't converted. The following architectures are affected by this change. * sh * arm * cris * mips * sparc(32) * blackfin * avr32 * parisc (broken, under investigation) * m32r * powerpc(32) As this change makes the dynamic allocator the default one, CONFIG_HAVE_DYNAMIC_PER_CPU_AREA is replaced with its invert - CONFIG_HAVE_LEGACY_PER_CPU_AREA, which is added to yet-to-be converted archs. These archs implement their own setup_per_cpu_areas() and the conversion is not trivial. * powerpc(64) * sparc(64) * ia64 * alpha * s390 Boot and batch alloc/free tests on x86_32 with debug code (x86_32 doesn't use default first chunk initialization). Compile tested on sparc(32), powerpc(32), arm and alpha. Kyle McMartin reported that this change breaks parisc. The problem is still under investigation and he is okay with pushing this patch forward and fixing parisc later. [ Impact: use dynamic allocator for most archs w/o custom percpu setup ] Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Reviewed-by: Christoph Lameter <cl@linux.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Mikael Starvik <starvik@axis.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Bryan Wu <cooloney@kernel.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu>
2009-06-16Merge branch 'akpm'Linus Torvalds
* akpm: (182 commits) fbdev: bf54x-lq043fb: use kzalloc over kmalloc/memset fbdev: *bfin*: fix __dev{init,exit} markings fbdev: *bfin*: drop unnecessary calls to memset fbdev: bfin-t350mcqb-fb: drop unused local variables fbdev: blackfin has __raw I/O accessors, so use them in fb.h fbdev: s1d13xxxfb: add accelerated bitblt functions tcx: use standard fields for framebuffer physical address and length fbdev: add support for handoff from firmware to hw framebuffers intelfb: fix a bug when changing video timing fbdev: use framebuffer_release() for freeing fb_info structures radeon: P2G2CLK_ALWAYS_ONb tested twice, should 2nd be P2G2CLK_DAC_ALWAYS_ONb? s3c-fb: CPUFREQ frequency scaling support s3c-fb: fix resource releasing on error during probing carminefb: fix possible access beyond end of carmine_modedb[] acornfb: remove fb_mmap function mb862xxfb: use CONFIG_OF instead of CONFIG_PPC_OF mb862xxfb: restrict compliation of platform driver to PPC Samsung SoC Framebuffer driver: add Alpha Channel support atmel-lcdc: fix pixclock upper bound detection offb: use framebuffer_alloc() to allocate fb_info struct ... Manually fix up conflicts due to kmemcheck in mm/slab.c
2009-06-16mm: consolidate init_mm definitionAlexey Dobriyan
* create mm/init-mm.c, move init_mm there * remove INIT_MM, initialize init_mm with C99 initializer * unexport init_mm on all arches: init_mm is already unexported on x86. One strange place is some OMAP driver (drivers/video/omap/) which won't build modular, but it's already wants get_vm_area() export. Somebody should look there. [akpm@linux-foundation.org: add missing #includes] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Americo Wang <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-15kmemcheck: add mm functionsVegard Nossum
With kmemcheck enabled, the slab allocator needs to do this: 1. Tell kmemcheck to allocate the shadow memory which stores the status of each byte in the allocation proper, e.g. whether it is initialized or uninitialized. 2. Tell kmemcheck which parts of memory that should be marked uninitialized. There are actually a few more states, such as "not yet allocated" and "recently freed". If a slab cache is set up using the SLAB_NOTRACK flag, it will never return memory that can take page faults because of kmemcheck. If a slab cache is NOT set up using the SLAB_NOTRACK flag, callers can still request memory with the __GFP_NOTRACK flag. This does not prevent the page faults from occuring, however, but marks the object in question as being initialized so that no warnings will ever be produced for this object. In addition to (and in contrast to) __GFP_NOTRACK, the __GFP_NOTRACK_FALSE_POSITIVE flag indicates that the allocation should not be tracked _because_ it would produce a false positive. Their values are identical, but need not be so in the future (for example, we could now enable/disable false positives with a config option). Parts of this patch were contributed by Pekka Enberg but merged for atomicity. Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Ingo Molnar <mingo@elte.hu> [rebased for mainline inclusion] Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
2009-06-11kmemleak: Simple testing module for kmemleakCatalin Marinas
This patch adds a loadable module that deliberately leaks memory. It is used for testing various memory leaking scenarios. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-06-11kmemleak: Enable the building of the memory leak detectorCatalin Marinas
This patch adds the Kconfig.debug and Makefile entries needed for building kmemleak into the kernel. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-04-01generic debug pageallocAkinobu Mita
CONFIG_DEBUG_PAGEALLOC is now supported by x86, powerpc, sparc64, and s390. This patch implements it for the rest of the architectures by filling the pages with poison byte patterns after free_pages() and verifying the poison patterns before alloc_pages(). This generic one cannot detect invalid page accesses immediately but invalid read access may cause invalid dereference by poisoned memory and invalid write access can be detected after a long delay. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-20percpu: implement new dynamic percpu allocatorTejun Heo
Impact: new scalable dynamic percpu allocator which allows dynamic percpu areas to be accessed the same way as static ones Implement scalable dynamic percpu allocator which can be used for both static and dynamic percpu areas. This will allow static and dynamic areas to share faster direct access methods. This feature is optional and enabled only when CONFIG_HAVE_DYNAMIC_PER_CPU_AREA is defined by arch. Please read comment on top of mm/percpu.c for details. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org>
2009-01-06shmem: unify regular and tiny shmemMatt Mackall
tiny-shmem shares most of its 130 lines of code with shmem and tends to break when particular bits of shmem get modified. Unifying saves code and makes keeping these two in sync much easier. before: 14367 392 24 14783 39bf mm/shmem.o 396 72 8 476 1dc mm/tiny-shmem.o after: 14367 392 24 14783 39bf mm/shmem.o 412 72 8 492 1ec mm/shmem.o tiny Signed-off-by: Matt Mackall <mpm@selenic.com> Acked-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-29SLUB: failslab supportAkinobu Mita
Currently fault-injection capability for SLAB allocator is only available to SLAB. This patch makes it available to SLUB, too. [penberg@cs.helsinki.fi: unify slab and slub implementations] Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-10-20memcg: allocate all page_cgroup at bootKAMEZAWA Hiroyuki
Allocate all page_cgroup at boot and remove page_cgroup poitner from struct page. This patch adds an interface as struct page_cgroup *lookup_page_cgroup(struct page*) All FLATMEM/DISCONTIGMEM/SPARSEMEM and MEMORY_HOTPLUG is supported. Remove page_cgroup pointer reduces the amount of memory by - 4 bytes per PAGE_SIZE. - 8 bytes per PAGE_SIZE if memory controller is disabled. (even if configured.) On usual 8GB x86-32 server, this saves 8MB of NORMAL_ZONE memory. On my x86-64 server with 48GB of memory, this saves 96MB of memory. I think this reduction makes sense. By pre-allocation, kmalloc/kfree in charge/uncharge are removed. This means - we're not necessary to be afraid of kmalloc faiulre. (this can happen because of gfp_mask type.) - we can avoid calling kmalloc/kfree. - we can avoid allocating tons of small objects which can be fragmented. - we can know what amount of memory will be used for this extra-lru handling. I added printk message as "allocated %ld bytes of page_cgroup" "please try cgroup_disable=memory option if you don't want" maybe enough informative for users. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-28mmu-notifiers: coreAndrea Arcangeli
With KVM/GFP/XPMEM there isn't just the primary CPU MMU pointing to pages. There are secondary MMUs (with secondary sptes and secondary tlbs) too. sptes in the kvm case are shadow pagetables, but when I say spte in mmu-notifier context, I mean "secondary pte". In GRU case there's no actual secondary pte and there's only a secondary tlb because the GRU secondary MMU has no knowledge about sptes and every secondary tlb miss event in the MMU always generates a page fault that has to be resolved by the CPU (this is not the case of KVM where the a secondary tlb miss will walk sptes in hardware and it will refill the secondary tlb transparently to software if the corresponding spte is present). The same way zap_page_range has to invalidate the pte before freeing the page, the spte (and secondary tlb) must also be invalidated before any page is freed and reused. Currently we take a page_count pin on every page mapped by sptes, but that means the pages can't be swapped whenever they're mapped by any spte because they're part of the guest working set. Furthermore a spte unmap event can immediately lead to a page to be freed when the pin is released (so requiring the same complex and relatively slow tlb_gather smp safe logic we have in zap_page_range and that can be avoided completely if the spte unmap event doesn't require an unpin of the page previously mapped in the secondary MMU). The mmu notifiers allow kvm/GRU/XPMEM to attach to the tsk->mm and know when the VM is swapping or freeing or doing anything on the primary MMU so that the secondary MMU code can drop sptes before the pages are freed, avoiding all page pinning and allowing 100% reliable swapping of guest physical address space. Furthermore it avoids the code that teardown the mappings of the secondary MMU, to implement a logic like tlb_gather in zap_page_range that would require many IPI to flush other cpu tlbs, for each fixed number of spte unmapped. To make an example: if what happens on the primary MMU is a protection downgrade (from writeable to wrprotect) the secondary MMU mappings will be invalidated, and the next secondary-mmu-page-fault will call get_user_pages and trigger a do_wp_page through get_user_pages if it called get_user_pages with write=1, and it'll re-establishing an updated spte or secondary-tlb-mapping on the copied page. Or it will setup a readonly spte or readonly tlb mapping if it's a guest-read, if it calls get_user_pages with write=0. This is just an example. This allows to map any page pointed by any pte (and in turn visible in the primary CPU MMU), into a secondary MMU (be it a pure tlb like GRU, or an full MMU with both sptes and secondary-tlb like the shadow-pagetable layer with kvm), or a remote DMA in software like XPMEM (hence needing of schedule in XPMEM code to send the invalidate to the remote node, while no need to schedule in kvm/gru as it's an immediate event like invalidating primary-mmu pte). At least for KVM without this patch it's impossible to swap guests reliably. And having this feature and removing the page pin allows several other optimizations that simplify life considerably. Dependencies: 1) mm_take_all_locks() to register the mmu notifier when the whole VM isn't doing anything with "mm". This allows mmu notifier users to keep track if the VM is in the middle of the invalidate_range_begin/end critical section with an atomic counter incraese in range_begin and decreased in range_end. No secondary MMU page fault is allowed to map any spte or secondary tlb reference, while the VM is in the middle of range_begin/end as any page returned by get_user_pages in that critical section could later immediately be freed without any further ->invalidate_page notification (invalidate_range_begin/end works on ranges and ->invalidate_page isn't called immediately before freeing the page). To stop all page freeing and pagetable overwrites the mmap_sem must be taken in write mode and all other anon_vma/i_mmap locks must be taken too. 2) It'd be a waste to add branches in the VM if nobody could possibly run KVM/GRU/XPMEM on the kernel, so mmu notifiers will only enabled if CONFIG_KVM=m/y. In the current kernel kvm won't yet take advantage of mmu notifiers, but this already allows to compile a KVM external module against a kernel with mmu notifiers enabled and from the next pull from kvm.git we'll start using them. And GRU/XPMEM will also be able to continue the development by enabling KVM=m in their config, until they submit all GRU/XPMEM GPLv2 code to the mainline kernel. Then they can also enable MMU_NOTIFIERS in the same way KVM does it (even if KVM=n). This guarantees nobody selects MMU_NOTIFIER=y if KVM and GRU and XPMEM are all =n. The mmu_notifier_register call can fail because mm_take_all_locks may be interrupted by a signal and return -EINTR. Because mmu_notifier_reigster is used when a driver startup, a failure can be gracefully handled. Here an example of the change applied to kvm to register the mmu notifiers. Usually when a driver startups other allocations are required anyway and -ENOMEM failure paths exists already. struct kvm *kvm_arch_create_vm(void) { struct kvm *kvm = kzalloc(sizeof(struct kvm), GFP_KERNEL); + int err; if (!kvm) return ERR_PTR(-ENOMEM); INIT_LIST_HEAD(&kvm->arch.active_mmu_pages); + kvm->arch.mmu_notifier.ops = &kvm_mmu_notifier_ops; + err = mmu_notifier_register(&kvm->arch.mmu_notifier, current->mm); + if (err) { + kfree(kvm); + return ERR_PTR(err); + } + return kvm; } mmu_notifier_unregister returns void and it's reliable. The patch also adds a few needed but missing includes that would prevent kernel to compile after these changes on non-x86 archs (x86 didn't need them by luck). [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix mm/filemap_xip.c build] [akpm@linux-foundation.org: fix mm/mmu_notifier.c build] Signed-off-by: Andrea Arcangeli <andrea@qumranet.com> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jack Steiner <steiner@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Kanoj Sarcar <kanojsarcar@yahoo.com> Cc: Roland Dreier <rdreier@cisco.com> Cc: Steve Wise <swise@opengridcomputing.com> Cc: Avi Kivity <avi@qumranet.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Anthony Liguori <aliguori@us.ibm.com> Cc: Chris Wright <chrisw@redhat.com> Cc: Marcelo Tosatti <marcelo@kvack.org> Cc: Eric Dumazet <dada1@cosmosbay.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Cc: Izik Eidus <izike@qumranet.com> Cc: Anthony Liguori <aliguori@us.ibm.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24mm: remove mm_init compilation dependency on CONFIG_DEBUG_MEMORY_INITNishanth Aravamudan
Towards the end of putting all core mm initialization in mm_init.c, I plan on putting the creation of a mm kobject in a function in that file. However, the file is currently only compiled if CONFIG_DEBUG_MEMORY_INIT is set. Remove this dependency, but put the code under an #ifdef on the same config option. This should result in no functional changes. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24mm: add a basic debugging framework for memory initialisationMel Gorman
Boot initialisation is very complex, with significant numbers of architecture-specific routines, hooks and code ordering. While significant amounts of the initialisation is architecture-independent, it trusts the data received from the architecture layer. This is a mistake, and has resulted in a number of difficult-to-diagnose bugs. This patchset adds some validation and tracing to memory initialisation. It also introduces a few basic defensive measures. The validation code can be explicitly disabled for embedded systems. This patch: Add additional debugging and verification code for memory initialisation. Once enabled, the verification checks are always run and when required additional debugging information may be outputted via a mminit_loglevel= command-line parameter. The verification code is placed in a new file mm/mm_init.c. Ideally other mm initialisation code will be moved here over time. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-17uaccess: add probe_kernel_write()Ingo Molnar
add probe_kernel_read() and probe_kernel_write(). Uninlined and restricted to kernel range memory only, as suggested by Linus. Signed-off-by: Ingo Molnar <mingo@elte.hu> Reviewed-by: Thomas Gleixner <tglx@linutronix.de>
2008-03-04Memory controller: rename to Memory Resource ControllerBalbir Singh
Rename Memory Controller to Memory Resource Controller. Reflect the same changes in the CONFIG definition for the Memory Resource Controller. Group together the config options for Resource Counters and Memory Resource Controller. Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Memory controller: cgroups setupBalbir Singh
Setup the memory cgroup and add basic hooks and controls to integrate and work with the cgroup. Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Pavel Emelianov <xemul@openvz.org> Cc: Paul Menage <menage@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Kirill Korotaev <dev@sw.ru> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: David Rientjes <rientjes@google.com> Cc: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
