path: root/mm/backing-dev.c
2008-05-20mm: bdi: fix race in bdi_class device creationGreg Kroah-Hartman
There is a race from when a device is created with device_create() and then the drvdata is set with a call to dev_set_drvdata() in which a sysfs file could be open, yet the drvdata will be NULL, causing all sorts of bad things to happen. This patch fixes the problem by using the new function, device_create_vargs(). Many thanks to Arthur Jones <ajones@riverbed.com> for reporting the bug, and testing patches out. Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Arthur Jones <ajones@riverbed.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-30mm: bdi: move statistics to debugfsMiklos Szeredi
Move BDI statistics to debugfs: /sys/kernel/debug/bdi/<bdi>/stats Use postcore_initcall() to initialize the sysfs class and debugfs, because debugfs is initialized in core_initcall(). Update descriptions in ABI documentation. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30mm: bdi: allow setting a maximum for the bdi dirty limitPeter Zijlstra
Add "max_ratio" to /sys/class/bdi. This indicates the maximum percentage of the global dirty threshold allocated to this bdi. [mszeredi@suse.cz] - fix parsing in max_ratio_store(). - export bdi_set_max_ratio() to modules - limit bdi_dirty with bdi->max_ratio - document new sysfs attribute Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30mm: bdi: allow setting a minimum for the bdi dirty limitPeter Zijlstra
Under normal circumstances each device is given a part of the total write-back cache that relates to its current avg writeout speed in relation to the other devices. min_ratio - allows one to assign a minimum portion of the write-back cache to a particular device. This is useful in situations where you might want to provide a minimum QoS. (One request for this feature came from flash based storage people who wanted to avoid writing out at all costs - they of course needed some pdflush hacks as well) max_ratio - allows one to assign a maximum portion of the dirty limit to a particular device. This is useful in situations where you want to avoid one device taking all or most of the write-back cache. Eg. an NFS mount that is prone to get stuck, or a FUSE mount which you don't trust to play fair. Add "min_ratio" to /sys/class/bdi. This indicates the minimum percentage of the global dirty threshold allocated to this bdi. [mszeredi@suse.cz] - fix parsing in min_ratio_store() - document new sysfs attribute Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30mm: bdi: export BDI attributes in sysfsPeter Zijlstra
Provide a place in sysfs (/sys/class/bdi) for the backing_dev_info object. This allows us to see and set the various BDI specific variables. In particular this properly exposes the read-ahead window for all relevant users and /sys/block/<block>/queue/read_ahead_kb should be deprecated. With patient help from Kay Sievers and Greg KH [mszeredi@suse.cz] - split off NFS and FUSE changes into separate patches - document new sysfs attributes under Documentation/ABI - do bdi_class_init as a core_initcall, otherwise the "default" BDI won't be initialized - remove bdi_init_fmt macro, it's not used very much [akpm@linux-foundation.org: fix ia64 warning] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Kay Sievers <kay.sievers@vrfy.org> Acked-by: Greg KH <greg@kroah.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-05mm/backing-dev.c: fix percpu_counter_destroy call bug in bdi_initDenis Cheng
this call should use the array index j, not i. But with this approach, just one int i is enough, int j is not needed. Signed-off-by: Denis Cheng <crquan@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17mm: per device dirty thresholdPeter Zijlstra
Scale writeback cache per backing device, proportional to its writeout speed. By decoupling the BDI dirty thresholds a number of problems we currently have will go away, namely: - mutual interference starvation (for any number of BDIs); - deadlocks with stacked BDIs (loop, FUSE and local NFS mounts). It might be that all dirty pages are for a single BDI while other BDIs are idling. By giving each BDI a 'fair' share of the dirty limit, each one can have dirty pages outstanding and make progress. A global threshold also creates a deadlock for stacked BDIs; when A writes to B, and A generates enough dirty pages to get throttled, B will never start writeback until the dirty pages go away. Again, by giving each BDI its own 'independent' dirty limit, this problem is avoided. So the problem is to determine how to distribute the total dirty limit across the BDIs fairly and efficiently. A DBI that has a large dirty limit but does not have any dirty pages outstanding is a waste. What is done is to keep a floating proportion between the DBIs based on writeback completions. This way faster/more active devices get a larger share than slower/idle devices. [akpm@linux-foundation.org: fix warnings] [hugh@veritas.com: Fix occasional hang when a task couldn't get out of balance_dirty_pages] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17mm: scalable bdi statistics countersPeter Zijlstra
Provide scalable per backing_dev_info statistics counters. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17nfs: remove congestion_end()Peter Zijlstra
These patches aim to improve balance_dirty_pages() and directly address three issues: 1) inter device starvation 2) stacked device deadlocks 3) inter process starvation 1 and 2 are a direct result from removing the global dirty limit and using per device dirty limits. By giving each device its own dirty limit is will no longer starve another device, and the cyclic dependancy on the dirty limit is broken. In order to efficiently distribute the dirty limit across the independant devices a floating proportion is used, this will allocate a share of the total limit proportional to the device's recent activity. 3 is done by also scaling the dirty limit proportional to the current task's recent dirty rate. This patch: nfs: remove congestion_end(). It's redundant, clear_bdi_congested() already wakes the waiters. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16remove mm/backing-dev.c:congestion_wait_interruptible()Adrian Bunk
congestion_wait_interruptible() is no longer used. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-16[PATCH] nfs: fix congestion controlPeter Zijlstra
The current NFS client congestion logic is severly broken, it marks the backing device congested during each nfs_writepages() call but doesn't mirror this in nfs_writepage() which makes for deadlocks. Also it implements its own waitqueue. Replace this by a more regular congestion implementation that puts a cap on the number of active writeback pages and uses the bdi congestion waitqueue. Also always use an interruptible wait since it makes sense to be able to SIGKILL the process even for mounts without 'intr'. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Christoph Lameter <clameter@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-20[PATCH] separate bdi congestion functions from queue congestion functionsAndrew Morton
Separate out the concept of "queue congestion" from "backing-dev congestion". Congestion is a backing-dev concept, not a queue concept. The blk_* congestion functions are retained, as wrappers around the core backing-dev congestion functions. This proper layering is needed so that NFS can cleanly use the congestion functions, and so that CONFIG_BLOCK=n actually links. Cc: "Thomas Maier" <balagi@justmail.de> Cc: "Jens Axboe" <jens.axboe@oracle.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: David Howells <dhowells@redhat.com> Cc: Peter Osterlund <petero2@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
