path: root/mm/balloon_compaction.c
2016-03-03virtio_balloon: fix race between migration and ballooningMinchan Kim
commit 21ea9fb69e7c4b1b1559c3e410943d3ff248ffcb upstream. In balloon_page_dequeue, pages_lock should cover the loop (ie, list_for_each_entry_safe). Otherwise, the cursor page could be isolated by compaction and then list_del by isolation could poison the page->lru.{prev,next} so the loop finally could access wrong address like this. This patch fixes the bug. general protection fault: 0000 [#1] SMP Dumping ftrace buffer: (ftrace buffer empty) Modules linked in: CPU: 2 PID: 82 Comm: vballoon Not tainted 4.4.0-rc5-mm1-access_bit+ #1906 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 task: ffff8800a7ff0000 ti: ffff8800a7fec000 task.ti: ffff8800a7fec000 RIP: 0010:[<ffffffff8115e754>] [<ffffffff8115e754>] balloon_page_dequeue+0x54/0x130 RSP: 0018:ffff8800a7fefdc0 EFLAGS: 00010246 RAX: ffff88013fff9a70 RBX: ffffea000056fe00 RCX: 0000000000002b7d RDX: ffff88013fff9a70 RSI: ffffea000056fe00 RDI: ffff88013fff9a68 RBP: ffff8800a7fefde8 R08: ffffea000056fda0 R09: 0000000000000000 R10: ffff8800a7fefd90 R11: 0000000000000001 R12: dead0000000000e0 R13: ffffea000056fe20 R14: ffff880138809070 R15: ffff880138809060 FS: 0000000000000000(0000) GS:ffff88013fc40000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 00007f229c10e000 CR3: 00000000b8b53000 CR4: 00000000000006a0 Stack: 0000000000000100 ffff880138809088 ffff880138809000 ffff880138809060 0000000000000046 ffff8800a7fefe28 ffffffff812c86d3 ffff880138809020 ffff880138809000 fffffffffff91900 0000000000000100 ffff880138809060 Call Trace: [<ffffffff812c86d3>] leak_balloon+0x93/0x1a0 [<ffffffff812c8bc7>] balloon+0x217/0x2a0 [<ffffffff8143739e>] ? __schedule+0x31e/0x8b0 [<ffffffff81078160>] ? abort_exclusive_wait+0xb0/0xb0 [<ffffffff812c89b0>] ? update_balloon_stats+0xf0/0xf0 [<ffffffff8105b6e9>] kthread+0xc9/0xe0 [<ffffffff8105b620>] ? kthread_park+0x60/0x60 [<ffffffff8143b4af>] ret_from_fork+0x3f/0x70 [<ffffffff8105b620>] ? kthread_park+0x60/0x60 Code: 8d 60 e0 0f 84 af 00 00 00 48 8b 43 20 a8 01 75 3b 48 89 d8 f0 0f ba 28 00 72 10 48 8b 03 f6 c4 08 75 2f 48 89 df e8 8c 83 f9 ff <49> 8b 44 24 20 4d 8d 6c 24 20 48 83 e8 20 4d 39 f5 74 7a 4c 89 RIP [<ffffffff8115e754>] balloon_page_dequeue+0x54/0x130 RSP <ffff8800a7fefdc0> ---[ end trace 43cf28060d708d5f ]--- Kernel panic - not syncing: Fatal exception Dumping ftrace buffer: (ftrace buffer empty) Kernel Offset: disabled Signed-off-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Acked-by: Rafael Aquini <aquini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-11-05mm: page migration trylock newpage at same level as oldpageHugh Dickins
Clean up page migration a little by moving the trylock of newpage from move_to_new_page() into __unmap_and_move(), where the old page has been locked. Adjust unmap_and_move_huge_page() and balloon_page_migrate() accordingly. But make one kind-of-functional change on the way: whereas trylock of newpage used to BUG() if it failed, now simply return -EAGAIN if so. Cutting out BUG()s is good, right? But, to be honest, this is really to extend the usefulness of the custom put_new_page feature, allowing a pool of new pages to be shared perhaps with racing uses. Use an "else" instead of that "skip_unmap" label. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Christoph Lameter <cl@linux.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Rik van Riel <riel@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Rafael Aquini <aquini@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-29mm/balloon_compaction: fix deflation when compaction is disabledKonstantin Khlebnikov
If CONFIG_BALLOON_COMPACTION=n balloon_page_insert() does not link pages with balloon and doesn't set PagePrivate flag, as a result balloon_page_dequeue() cannot get any pages because it thinks that all of them are isolated. Without balloon compaction nobody can isolate ballooned pages. It's safe to remove this check. Fixes: d6d86c0a7f8d ("mm/balloon_compaction: redesign ballooned pages management"). Signed-off-by: Konstantin Khlebnikov <k.khlebnikov@samsung.com> Reported-by: Matt Mullins <mmullins@mmlx.us> Cc: <stable@vger.kernel.org> [3.17] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-09mm/balloon_compaction: add vmstat counters and kpageflags bitKonstantin Khlebnikov
Always mark pages with PageBalloon even if balloon compaction is disabled and expose this mark in /proc/kpageflags as KPF_BALLOON. Also this patch adds three counters into /proc/vmstat: "balloon_inflate", "balloon_deflate" and "balloon_migrate". They accumulate balloon activity. Current size of balloon is (balloon_inflate - balloon_deflate) pages. All generic balloon code now gathered under option CONFIG_MEMORY_BALLOON. It should be selected by ballooning driver which wants use this feature. Currently virtio-balloon is the only user. Signed-off-by: Konstantin Khlebnikov <k.khlebnikov@samsung.com> Cc: Rafael Aquini <aquini@redhat.com> Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-09mm/balloon_compaction: remove balloon mapping and flag AS_BALLOON_MAPKonstantin Khlebnikov
Now ballooned pages are detected using PageBalloon(). Fake mapping is no longer required. This patch links ballooned pages to balloon device using field page->private instead of page->mapping. Also this patch embeds balloon_dev_info directly into struct virtio_balloon. Signed-off-by: Konstantin Khlebnikov <k.khlebnikov@samsung.com> Cc: Rafael Aquini <aquini@redhat.com> Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-09mm/balloon_compaction: redesign ballooned pages managementKonstantin Khlebnikov
Sasha Levin reported KASAN splash inside isolate_migratepages_range(). Problem is in the function __is_movable_balloon_page() which tests AS_BALLOON_MAP in page->mapping->flags. This function has no protection against anonymous pages. As result it tried to check address space flags inside struct anon_vma. Further investigation shows more problems in current implementation: * Special branch in __unmap_and_move() never works: balloon_page_movable() checks page flags and page_count. In __unmap_and_move() page is locked, reference counter is elevated, thus balloon_page_movable() always fails. As a result execution goes to the normal migration path. virtballoon_migratepage() returns MIGRATEPAGE_BALLOON_SUCCESS instead of MIGRATEPAGE_SUCCESS, move_to_new_page() thinks this is an error code and assigns newpage->mapping to NULL. Newly migrated page lose connectivity with balloon an all ability for further migration. * lru_lock erroneously required in isolate_migratepages_range() for isolation ballooned page. This function releases lru_lock periodically, this makes migration mostly impossible for some pages. * balloon_page_dequeue have a tight race with balloon_page_isolate: balloon_page_isolate could be executed in parallel with dequeue between picking page from list and locking page_lock. Race is rare because they use trylock_page() for locking. This patch fixes all of them. Instead of fake mapping with special flag this patch uses special state of page->_mapcount: PAGE_BALLOON_MAPCOUNT_VALUE = -256. Buddy allocator uses PAGE_BUDDY_MAPCOUNT_VALUE = -128 for similar purpose. Storing mark directly in struct page makes everything safer and easier. PagePrivate is used to mark pages present in page list (i.e. not isolated, like PageLRU for normal pages). It replaces special rules for reference counter and makes balloon migration similar to migration of normal pages. This flag is protected by page_lock together with link to the balloon device. Signed-off-by: Konstantin Khlebnikov <k.khlebnikov@samsung.com> Reported-by: Sasha Levin <sasha.levin@oracle.com> Link: http://lkml.kernel.org/p/53E6CEAA.9020105@oracle.com Cc: Rafael Aquini <aquini@redhat.com> Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com> Cc: <stable@vger.kernel.org> [3.8+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23mm: print more details for bad_page()Dave Hansen
bad_page() is cool in that it prints out a bunch of data about the page. But, I can never remember which page flags are good and which are bad, or whether ->index or ->mapping is required to be NULL. This patch allows bad/dump_page() callers to specify a string about why they are dumping the page and adds explanation strings to a number of places. It also adds a 'bad_flags' argument to bad_page(), which it then dumps out separately from the flags which are actually set. This way, the messages will show specifically why the page was bad, *specifically* which flags it is complaining about, if it was a page flag combination which was the problem. [akpm@linux-foundation.org: switch to pr_alert] Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Reviewed-by: Christoph Lameter <cl@linux.com> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-11mm: introduce a common interface for balloon pages mobilityRafael Aquini
Memory fragmentation introduced by ballooning might reduce significantly the number of 2MB contiguous memory blocks that can be used within a guest, thus imposing performance penalties associated with the reduced number of transparent huge pages that could be used by the guest workload. This patch introduces a common interface to help a balloon driver on making its page set movable to compaction, and thus allowing the system to better leverage the compation efforts on memory defragmentation. [akpm@linux-foundation.org: use PAGE_FLAGS_CHECK_AT_PREP, s/__balloon_page_flags/page_flags_cleared/, small cleanups] [rientjes@google.com: allow balloon compaction for any system with memory compaction enabled, which is the defconfig] Signed-off-by: Rafael Aquini <aquini@redhat.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
