path: root/mm/cma.c
2015-11-05mm/cma.c: suppress warningAndrew Morton
mm/cma.c: In function 'cma_alloc': mm/cma.c:366: warning: 'pfn' may be used uninitialized in this function The patch actually improves the tracing a bit: if alloc_contig_range() fails, tracing will display the offending pfn rather than -1. Cc: Stefan Strogin <stefan.strogin@gmail.com> Cc: Michal Nazarewicz <mpn@google.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Cc: Thierry Reding <treding@nvidia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-10-23mm: cma: fix incorrect type conversion for size during dma allocationRohit Vaswani
This was found during userspace fuzzing test when a large size dma cma allocation is made by driver(like ion) through userspace. show_stack+0x10/0x1c dump_stack+0x74/0xc8 kasan_report_error+0x2b0/0x408 kasan_report+0x34/0x40 __asan_storeN+0x15c/0x168 memset+0x20/0x44 __dma_alloc_coherent+0x114/0x18c Signed-off-by: Rohit Vaswani <rvaswani@codeaurora.org> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24mm/memblock: add extra "flags" to memblock to allow selection of memory ↵Tony Luck
based on attribute Some high end Intel Xeon systems report uncorrectable memory errors as a recoverable machine check. Linux has included code for some time to process these and just signal the affected processes (or even recover completely if the error was in a read only page that can be replaced by reading from disk). But we have no recovery path for errors encountered during kernel code execution. Except for some very specific cases were are unlikely to ever be able to recover. Enter memory mirroring. Actually 3rd generation of memory mirroing. Gen1: All memory is mirrored Pro: No s/w enabling - h/w just gets good data from other side of the mirror Con: Halves effective memory capacity available to OS/applications Gen2: Partial memory mirror - just mirror memory begind some memory controllers Pro: Keep more of the capacity Con: Nightmare to enable. Have to choose between allocating from mirrored memory for safety vs. NUMA local memory for performance Gen3: Address range partial memory mirror - some mirror on each memory controller Pro: Can tune the amount of mirror and keep NUMA performance Con: I have to write memory management code to implement The current plan is just to use mirrored memory for kernel allocations. This has been broken into two phases: 1) This patch series - find the mirrored memory, use it for boot time allocations 2) Wade into mm/page_alloc.c and define a ZONE_MIRROR to pick up the unused mirrored memory from mm/memblock.c and only give it out to select kernel allocations (this is still being scoped because page_alloc.c is scary). This patch (of 3): Add extra "flags" to memblock to allow selection of memory based on attribute. No functional changes Signed-off-by: Tony Luck <tony.luck@intel.com> Cc: Xishi Qiu <qiuxishi@huawei.com> Cc: Hanjun Guo <guohanjun@huawei.com> Cc: Xiexiuqi <xiexiuqi@huawei.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Naoya Horiguchi <nao.horiguchi@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24mm/cma.c: fix typos in commentsShailendra Verma
Signed-off-by: Shailendra Verma <shailendra.capricorn@gmail.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15mm: cma: add trace events for CMA allocations and freeingsStefan Strogin
Add trace events for cma_alloc() and cma_release(). The cma_alloc tracepoint is used both for successful and failed allocations, in case of allocation failure pfn=-1UL is stored and printed. Signed-off-by: Stefan Strogin <stefan.strogin@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Michal Nazarewicz <mpn@google.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Cc: Thierry Reding <treding@nvidia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-14mm: cma: constify and use correct signness in mm/cma.cSasha Levin
Constify function parameters and use correct signness where needed. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Acked-by: Gregory Fong <gregory.0xf0@gmail.com> Cc: Pintu Kumar <pintu.k@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-14mm: cma: allocation triggerSasha Levin
Provides a userspace interface to trigger a CMA allocation. Usage: echo [pages] > alloc This would provide testing/fuzzing access to the CMA allocation paths. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Acked-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Laura Abbott <lauraa@codeaurora.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-14mm: cma: debugfs interfaceSasha Levin
I've noticed that there is no interfaces exposed by CMA which would let me fuzz what's going on in there. This small patchset exposes some information out to userspace, plus adds the ability to trigger allocation and freeing from userspace. This patch (of 3): Implement a simple debugfs interface to expose information about CMA areas in the system. Useful for testing/sanity checks for CMA since it was impossible to previously retrieve this information in userspace. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Acked-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Laura Abbott <lauraa@codeaurora.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-12mm: cma: fix CMA aligned offset calculationDanesh Petigara
The CMA aligned offset calculation is incorrect for non-zero order_per_bit values. For example, if cma->order_per_bit=1, cma->base_pfn= 0x2f800000 and align_order=12, the function returns a value of 0x17c00 instead of 0x400. This patch fixes the CMA aligned offset calculation. The previous calculation was wrong and would return too-large values for the offset, so that when cma_alloc looks for free pages in the bitmap with the requested alignment > order_per_bit, it starts too far into the bitmap and so CMA allocations will fail despite there actually being plenty of free pages remaining. It will also probably have the wrong alignment. With this change, we will get the correct offset into the bitmap. One affected user is powerpc KVM, which has kvm_cma->order_per_bit set to KVM_CMA_CHUNK_ORDER - PAGE_SHIFT, or 18 - 12 = 6. [gregory.0xf0@gmail.com: changelog additions] Signed-off-by: Danesh Petigara <dpetigara@broadcom.com> Reviewed-by: Gregory Fong <gregory.0xf0@gmail.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-11mm: cma: fix totalcma_pages to include DT defined CMA regionsGeorge G. Davis
The totalcma_pages variable is not updated to account for CMA regions defined via device tree reserved-memory sub-nodes. Fix this omission by moving the calculation of totalcma_pages into cma_init_reserved_mem() instead of cma_declare_contiguous() such that it will include reserved memory used by all CMA regions. Signed-off-by: George G. Davis <george_davis@mentor.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-18mm: cma: split cma-reserved in dmesg logPintu Kumar
When the system boots up, in the dmesg logs we can see the memory statistics along with total reserved as below. Memory: 458840k/458840k available, 65448k reserved, 0K highmem When CMA is enabled, still the total reserved memory remains the same. However, the CMA memory is not considered as reserved. But, when we see /proc/meminfo, the CMA memory is part of free memory. This creates confusion. This patch corrects the problem by properly subtracting the CMA reserved memory from the total reserved memory in dmesg logs. Below is the dmesg snapshot from an arm based device with 512MB RAM and 12MB single CMA region. Before this change: Memory: 458840k/458840k available, 65448k reserved, 0K highmem After this change: Memory: 458840k/458840k available, 53160k reserved, 12288k cma-reserved, 0K highmem Signed-off-by: Pintu Kumar <pintu.k@samsung.com> Signed-off-by: Vishnu Pratap Singh <vishnu.ps@samsung.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Cc: Rafael Aquini <aquini@redhat.com> Cc: Jerome Marchand <jmarchan@redhat.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-13mm/cma: make kmemleak ignore CMA regionsThierry Reding
kmemleak will add allocations as objects to a pool. The memory allocated for each object in this pool is periodically searched for pointers to other allocated objects. This only works for memory that is mapped into the kernel's virtual address space, which happens not to be the case for most CMA regions. Furthermore, CMA regions are typically used to store data transferred to or from a device and therefore don't contain pointers to other objects. Without this, the kernel crashes on the first execution of the scan_gray_list() because it tries to access highmem. Perhaps a more appropriate fix would be to reject any object that can't map to a kernel virtual address? [akpm@linux-foundation.org: add comment] [akpm@linux-foundation.org: fix comment, per Catalin] [sfr@canb.auug.org.au: include linux/io.h for phys_to_virt()] Signed-off-by: Thierry Reding <treding@nvidia.com> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-13mm: cma: align to physical address, not CMA region positionGregory Fong
The alignment in cma_alloc() was done w.r.t. the bitmap. This is a problem when, for example: - a device requires 16M (order 12) alignment - the CMA region is not 16 M aligned In such a case, can result with the CMA region starting at, say, 0x2f800000 but any allocation you make from there will be aligned from there. Requesting an allocation of 32 M with 16 M alignment will result in an allocation from 0x2f800000 to 0x31800000, which doesn't work very well if your strange device requires 16M alignment. Change to use bitmap_find_next_zero_area_off() to account for the difference in alignment at reserve-time and alloc-time. Signed-off-by: Gregory Fong <gregory.0xf0@gmail.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Cc: Laura Abbott <lauraa@codeaurora.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-10mm/CMA: fix boot regression due to physical address of high_memoryJoonsoo Kim
high_memory isn't direct mapped memory so retrieving it's physical address isn't appropriate. But, it would be useful to check physical address of highmem boundary so it's justfiable to get physical address from it. In x86, there is a validation check if CONFIG_DEBUG_VIRTUAL and it triggers following boot failure reported by Ingo. ... BUG: Int 6: CR2 00f06f53 ... Call Trace: dump_stack+0x41/0x52 early_idt_handler+0x6b/0x6b cma_declare_contiguous+0x33/0x212 dma_contiguous_reserve_area+0x31/0x4e dma_contiguous_reserve+0x11d/0x125 setup_arch+0x7b5/0xb63 start_kernel+0xb8/0x3e6 i386_start_kernel+0x79/0x7d To fix boot regression, this patch implements workaround to avoid validation check in x86 when retrieving physical address of high_memory. __pa_nodebug() used by this patch is implemented only in x86 so there is no choice but to use dirty #ifdef. [akpm@linux-foundation.org: tweak comment] Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Reported-by: Ingo Molnar <mingo@kernel.org> Tested-by: Ingo Molnar <mingo@kernel.org> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-27mm: cma: Use %pa to print physical addressesLaurent Pinchart
Casting physical addresses to unsigned long and using %lu truncates the values on systems where physical addresses are larger than 32 bits. Use %pa and get rid of the cast instead. Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Acked-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com>
2014-10-27mm: cma: Ensure that reservations never cross the low/high mem boundaryLaurent Pinchart
Commit 95b0e655f914 ("ARM: mm: don't limit default CMA region only to low memory") extended CMA memory reservation to allow usage of high memory. It relied on commit f7426b983a6a ("mm: cma: adjust address limit to avoid hitting low/high memory boundary") to ensure that the reserved block never crossed the low/high memory boundary. While the implementation correctly lowered the limit, it failed to consider the case where the base..limit range crossed the low/high memory boundary with enough space on each side to reserve the requested size on either low or high memory. Rework the base and limit adjustment to fix the problem. The function now starts by rejecting the reservation altogether for fixed reservations that cross the boundary, tries to reserve from high memory first and then falls back to low memory. Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com>
2014-10-27mm: cma: Always consider a 0 base address reservation as dynamicLaurent Pinchart
The fixed parameter to cma_declare_contiguous() tells the function whether the given base address must be honoured or should be considered as a hint only. The API considers a zero base address as meaning any base address, which must never be considered as a fixed value. Part of the implementation correctly checks both fixed and base != 0, but two locations check the fixed value only. Set fixed to false when base is 0 to fix that and simplify the code. Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com>
2014-10-27mm: cma: Don't crash on allocation if CMA area can't be activatedLaurent Pinchart
If activation of the CMA area fails its mutex won't be initialized, leading to an oops at allocation time when trying to lock the mutex. Fix this by setting the cma area count field to 0 when activation fails, leading to allocation returning NULL immediately. Cc: <stable@vger.kernel.org> # v3.17 Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com>
2014-10-14drivers: dma-contiguous: add initialization from device treeMarek Szyprowski
Add a function to create CMA region from previously reserved memory and add support for handling 'shared-dma-pool' reserved-memory device tree nodes. Based on previous code provided by Josh Cartwright <joshc@codeaurora.org> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: Grant Likely <grant.likely@linaro.org> Cc: Laura Abbott <lauraa@codeaurora.org> Cc: Josh Cartwright <joshc@codeaurora.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14mm/cma: fix cma bitmap aligned mask computingWeijie Yang
The current cma bitmap aligned mask computation is incorrect. It could cause an unexpected alignment when using cma_alloc() if the wanted align order is larger than cma->order_per_bit. Take kvm for example (PAGE_SHIFT = 12), kvm_cma->order_per_bit is set to 6. When kvm_alloc_rma() tries to alloc kvm_rma_pages, it will use 15 as the expected align value. After using the current implementation however, we get 0 as cma bitmap aligned mask other than 511. This patch fixes the cma bitmap aligned mask calculation. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Weijie Yang <weijie.yang@samsung.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: <stable@vger.kernel.org> [3.17] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-09mm: cma: adjust address limit to avoid hitting low/high memory boundaryMarek Szyprowski
Russell King recently noticed that limiting default CMA region only to low memory on ARM architecture causes serious memory management issues with machines having a lot of memory (which is mainly available as high memory). More information can be found the following thread: http://thread.gmane.org/gmane.linux.ports.arm.kernel/348441/ Those two patches removes this limit letting kernel to put default CMA region into high memory when this is possible (there is enough high memory available and architecture specific DMA limit fits). This should solve strange OOM issues on systems with lots of RAM (i.e. >1GiB) and large (>256M) CMA area. This patch (of 2): Automatically allocated regions should not cross low/high memory boundary, because such regions cannot be later correctly initialized due to spanning across two memory zones. This patch adds a check for this case and a simple code for moving region to low memory if automatically selected address might not fit completely into high memory. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Cc: Daniel Drake <drake@endlessm.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-06mm, CMA: clean-up log messageJoonsoo Kim
We don't need explicit 'CMA:' prefix, since we already define prefix 'cma:' in pr_fmt. So remove it. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Reviewed-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Alexander Graf <agraf@suse.de> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Gleb Natapov <gleb@kernel.org> Acked-by: Marek Szyprowski <m.szyprowski@samsung.com> Tested-by: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-06mm, CMA: change cma_declare_contiguous() to obey coding conventionJoonsoo Kim
Conventionally, we put output param to the end of param list and put the 'base' ahead of 'size', but cma_declare_contiguous() doesn't look like that, so change it. Additionally, move down cma_areas reference code to the position where it is really needed. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Alexander Graf <agraf@suse.de> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Gleb Natapov <gleb@kernel.org> Acked-by: Marek Szyprowski <m.szyprowski@samsung.com> Tested-by: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-06mm, CMA: clean-up CMA allocation error pathJoonsoo Kim
We can remove one call sites for clear_cma_bitmap() if we first call it before checking error number. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Minchan Kim <minchan@kernel.org> Reviewed-by: Michal Nazarewicz <mina86@mina86.com> Reviewed-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Alexander Graf <agraf@suse.de> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Gleb Natapov <gleb@kernel.org> Acked-by: Marek Szyprowski <m.szyprowski@samsung.com> Tested-by: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-06CMA: generalize CMA reserved area management functionalityJoonsoo Kim
Currently, there are two users on CMA functionality, one is the DMA subsystem and the other is the KVM on powerpc. They have their own code to manage CMA reserved area even if they looks really similar. From my guess, it is caused by some needs on bitmap management. KVM side wants to maintain bitmap not for 1 page, but for more size. Eventually it use bitmap where one bit represents 64 pages. When I implement CMA related patches, I should change those two places to apply my change and it seem to be painful to me. I want to change this situation and reduce future code management overhead through this patch. This change could also help developer who want to use CMA in their new feature development, since they can use CMA easily without copying & pasting this reserved area management code. In previous patches, we have prepared some features to generalize CMA reserved area management and now it's time to do it. This patch moves core functions to mm/cma.c and change DMA APIs to use these functions. There is no functional change in DMA APIs. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Acked-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Acked-by: Minchan Kim <minchan@kernel.org> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Alexander Graf <agraf@suse.de> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Gleb Natapov <gleb@kernel.org> Acked-by: Marek Szyprowski <m.szyprowski@samsung.com> Tested-by: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
