[ Upstream commit a94b525241c0fff3598809131d7cfcfe1d572d8c ]
total_{migrate,free}_scanned will be added to COMPACTMIGRATE_SCANNED and
COMPACTFREE_SCANNED in compact_zone(). We should clear them before
scanning a new zone. In the proc triggered compaction, we forgot clearing
them.
[laoar.shao@gmail.com: introduce a helper compact_zone_counters_init()]
Link: http://lkml.kernel.org/r/1563869295-25748-1-git-send-email-laoar.shao@gmail.com
[akpm@linux-foundation.org: expand compact_zone_counters_init() into its single callsite, per mhocko]
[vbabka@suse.cz: squash compact_zone() list_head init as well]
Link: http://lkml.kernel.org/r/1fb6f7da-f776-9e42-22f8-bbb79b030b98@suse.cz
[akpm@linux-foundation.org: kcompactd_do_work(): avoid unnecessary initialization of cc.zone]
Link: http://lkml.kernel.org/r/1563789275-9639-1-git-send-email-laoar.shao@gmail.com
Fixes: 7f354a548d1c ("mm, compaction: add vmstats for kcompactd work")
Signed-off-by: Yafang Shao <laoar.shao@gmail.com>
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Reviewed-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Yafang Shao <shaoyafang@didiglobal.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
Cc: Michal Hocko <mhocko@suse.com>
Cc: <stable@vger.kernel.org>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Andrea brought to my attention that the L->{L,S} guarantees are
completely bogus for this case. I was looking at the diagram, from the
offending commit, when that _is_ the race, we had the load reordered
already.
What we need is at least S->L semantics, thus simply use
wq_has_sleeper() to serialize the call for good.
Link: http://lkml.kernel.org/r/20170914175313.GB811@linux-80c1.suse
Fixes: 46acef048a6 (mm,compaction: serialize waitqueue_active() checks)
Signed-off-by: Davidlohr Bueso <dbueso@suse.de>
Reported-by: Andrea Parri <parri.andrea@gmail.com>
__reset_isolation_suitable walks the whole zone pfn range and it tries
to jump over holes by checking the zone for each page. It might still
stumble over offline pages, though. Skip those by checking
pfn_to_online_page()
Link: http://lkml.kernel.org/r/20170515085827.16474-9-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Balbir Singh <bsingharora@gmail.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Daniel Kiper <daniel.kiper@oracle.com>
Cc: Igor Mammedov <imammedo@redhat.com>
Cc: Jerome Glisse <jglisse@redhat.com>
Cc: Joonsoo Kim <js1304@gmail.com>
Cc: Reza Arbab <arbab@linux.vnet.ibm.com>
Cc: Tobias Regnery <tobias.regnery@gmail.com>
Cc: Toshi Kani <toshi.kani@hpe.com>
Cc: Vitaly Kuznetsov <vkuznets@redhat.com>
Cc: Xishi Qiu <qiuxishi@huawei.com>
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
The main goal of direct compaction is to form a high-order page for
allocation, but it should also help against long-term fragmentation when
possible.
Most lower-than-pageblock-order compactions are for non-movable
allocations, which means that if we compact in a movable pageblock and
terminate as soon as we create the high-order page, it's unlikely that
the fallback heuristics will claim the whole block. Instead there might
be a single unmovable page in a pageblock full of movable pages, and the
next unmovable allocation might pick another pageblock and increase
long-term fragmentation.
To help against such scenarios, this patch changes the termination
criteria for compaction so that the current pageblock is finished even
though the high-order page already exists. Note that it might be
possible that the high-order page formed elsewhere in the zone due to
parallel activity, but this patch doesn't try to detect that.
This is only done with sync compaction, because async compaction is
limited to pageblock of the same migratetype, where it cannot result in
a migratetype fallback. (Async compaction also eagerly skips
order-aligned blocks where isolation fails, which is against the goal of
migrating away as much of the pageblock as possible.)
As a result of this patch, long-term memory fragmentation should be
reduced.
In testing based on 4.9 kernel with stress-highalloc from mmtests
configured for order-4 GFP_KERNEL allocations, this patch has reduced
the number of unmovable allocations falling back to movable pageblocks
by 20%. The number
Link: http://lkml.kernel.org/r/20170307131545.28577-9-vbabka@suse.cz
Acked-by: Mel Gorman <mgorman@techsingularity.net>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
The migrate scanner in async compaction is currently limited to
MIGRATE_MOVABLE pageblocks. This is a heuristic intended to reduce
latency, based on the assumption that non-MOVABLE pageblocks are
unlikely to contain movable pages.
However, with the exception of THP's, most high-order allocations are
not movable. Should the async compaction succeed, this increases the
chance that the non-MOVABLE allocations will fallback to a MOVABLE
pageblock, making the long-term fragmentation worse.
This patch attempts to help the situation by changing async direct
compaction so that the migrate scanner only scans the pageblocks of the
requested migratetype. If it's a non-MOVABLE type and there are such
pageblocks that do contain movable pages, chances are that the
allocation can succeed within one of such pageblocks, removing the need
for a fallback. If that fails, the subsequent sync attempt will ignore
this restriction.
by 30%. The number of movable allocations falling back is reduced by
12%.
Link: http://lkml.kernel.org/r/20170307131545.28577-8-vbabka@suse.cz
Preparation patch. We are going to need migratetype at lower layers
than compact_zone() and compact_finished().
Link: http://lkml.kernel.org/r/20170307131545.28577-7-vbabka@suse.cz
Preparation for making the decisions more complex and depending on
compact_control flags. No functional change.
Link: http://lkml.kernel.org/r/20170307131545.28577-6-vbabka@suse.cz
When detecting whether compaction has succeeded in forming a high-order
page, __compact_finished() employs a watermark check, followed by an own
search for a suitable page in the freelists. This is not ideal for two
reasons:
- The watermark check also searches high-order freelists, but has a
less strict criteria wrt fallback. It's therefore redundant and waste
of cycles. This was different in the past when high-order watermark
check attempted to apply reserves to high-order pages.
- The watermark check might actually fail due to lack of order-0 pages.
Compaction can't help with that, so there's no point in continuing
because of that. It's possible that high-order page still exists and
it terminates.
This patch therefore removes the watermark check. This should save some
cycles and terminate compaction sooner in some cases.
Link: http://lkml.kernel.org/r/20170307131545.28577-3-vbabka@suse.cz
By reviewing code, I find that if the migrate target is a large free
page and we ignore suitable, it may splite large target free page into
smaller block which is not good for defrag. So move the ignore block
suitable after check large free page.
As Vlastimil pointed out in RFC version that this patch is just based on
logical analyses which might be better for future-proofing the function
and it is most likely won't have any visible effect right now, for
direct compaction shouldn't have to be called if there's a
>=pageblock_order page already available.
Link: http://lkml.kernel.org/r/1489490743-5364-1-git-send-email-xieyisheng1@huawei.com
Signed-off-by: Yisheng Xie <xieyisheng1@huawei.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Hanjun Guo <guohanjun@huawei.com>
<linux/sched.h> into <linux/sched/signal.h>
Fix up affected files that include this signal functionality via sched.h.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Patch series "HWPOISON: soft offlining for non-lru movable page", v6.
After Minchan's commit bda807d44454 ("mm: migrate: support non-lru
movable page migration"), some type of non-lru page like zsmalloc and
virtio-balloon page also support migration.
Therefore, we can:
1) soft offlining no-lru movable pages, which means when memory
corrected errors occur on a non-lru movable page, we can stop to use
it by migrating data onto another page and disable the original
(maybe half-broken) one.
2) enable memory hotplug for non-lru movable pages, i.e. we may offline
blocks, which include such pages, by using non-lru page migration.
This patchset is heavily dependent on non-lru movable page migration.
This patch (of 4):
Change the return type of isolate_movable_page() from bool to int. It
will return 0 when isolate movable page successfully, and return -EBUSY
when it isolates failed.
There is no functional change within this patch but prepare for later
patch.
[xieyisheng1@huawei.com: v6]
Link: http://lkml.kernel.org/r/1486108770-630-2-git-send-email-xieyisheng1@huawei.com
Link: http://lkml.kernel.org/r/1485867981-16037-2-git-send-email-ysxie@foxmail.com
Suggested-by: Michal Hocko <mhocko@kernel.org>
Acked-by: Minchan Kim <minchan@kernel.org>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Taku Izumi <izumi.taku@jp.fujitsu.com>
Without a memory barrier, the following race can occur with a high-order
allocation:
wakeup_kcompactd(order == 1) kcompactd()
[L] waitqueue_active(kcompactd_wait)
[S] prepare_to_wait_event(kcompactd_wait)
[L] (kcompactd_max_order == 0)
[S] kcompactd_max_order = order; schedule()
Where the waitqueue_active() check is speculatively re-ordered to before
setting the actual condition (max_order), not seeing the threads that's
going to block; making us miss a wakeup. There are a couple of options
to fix this, including calling wq_has_sleepers() which adds a full
barrier, or unconditionally doing the wake_up_interruptible() and
serialize on the q->lock. However, to make use of the control
dependency, we just need to add L->L guarantees.
While this bug is theoretical, there have been other offenders of the
lockless waitqueue_active() in the past -- this is also documented in
the call itself.
Link: http://lkml.kernel.org/r/1483975528-24342-1-git-send-email-dave@stgolabs.net
A "compact_daemon_wake" vmstat exists that represents the number of
times kcompactd has woken up. This doesn't represent how much work it
actually did, though.
It's useful to understand how much compaction work is being done by
kcompactd versus other methods such as direct compaction and explicitly
triggered per-node (or system) compaction.
This adds two new vmstats: "compact_daemon_migrate_scanned" and
"compact_daemon_free_scanned" to represent the number of pages kcompactd
has scanned as part of its migration scanner and freeing scanner,
respectively.
These values are still accounted for in the general
"compact_migrate_scanned" and "compact_free_scanned" for compatibility.
It could be argued that explicitly triggered compaction could also be
tracked separately, and that could be added if others find it useful.
Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1612071749390.69852@chino.kir.corp.google.com
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Michal Hocko <mhocko@kernel.org>
compaction has been disabled for GFP_NOFS and GFP_NOIO requests since
the direct compaction was introduced by commit 56de7263fcf3 ("mm:
compaction: direct compact when a high-order allocation fails"). The
main reason is that the migration of page cache pages might recurse back
to fs/io layer and we could potentially deadlock. This is overly
conservative because all the anonymous memory is migrateable in the
GFP_NOFS context just fine. This might be a large portion of the memory
in many/most workkloads.
Remove the GFP_NOFS restriction and make sure that we skip all fs pages
(those with a mapping) while isolating pages to be migrated. We cannot
consider clean fs pages because they might need a metadata update so
only isolate pages without any mapping for nofs requests.
The effect of this patch will be probably very limited in many/most
workloads because higher order GFP_NOFS requests are quite rare,
although different configurations might lead to very different results.
David Chinner has mentioned a heavy metadata workload with 64kB block
which to quote him:
: Unfortunately, there was an era of cargo cult configuration tweaks in the
: Ceph community that has resulted in a large number of production machines
: with XFS filesystems configured this way. And a lot of them store large
: numbers of small files and run under significant sustained memory
: pressure.
: I slowly working towards getting rid of these high order allocations and
: replacing them with the equivalent number of single page allocations, but
: I haven't got that (complex) change working yet.
We can do the following to simulate that workload:
$ mkfs.xfs -f -n size=64k <dev>
$ mount <dev> /mnt/scratch
$ time ./fs_mark -D 10000 -S0 -n 100000 -s 0 -L 32 \
-d /mnt/scratch/0 -d /mnt/scratch/1 \
-d /mnt/scratch/2 -d /mnt/scratch/3 \
-d /mnt/scratch/4 -d /mnt/scratch/5 \
-d /mnt/scratch/6 -d /mnt/scratch/7 \
-d /mnt/scratch/8 -d /mnt/scratch/9 \
-d /mnt/scratch/10 -d /mnt/scratch/11 \
-d /mnt/scratch/12 -d /mnt/scratch/13 \
-d /mnt/scratch/14 -d /mnt/scratch/15
and indeed is hammers the system with many high order GFP_NOFS requests as
per a simle tracepoint during the load:
$ echo '!(gfp_flags & 0x80) && (gfp_flags &0x400000)' > $TRACE_MNT/events/kmem/mm_page_alloc/filter
I am getting
5287609 order=0
37 order=1
1594905 order=2
3048439 order=3
6699207 order=4
66645 order=5
My testing was done in a kvm guest so performance numbers should be
taken with a grain of salt but there seems to be a difference when the
patch is applied:
* Original kernel
FSUse% Count Size Files/sec App Overhead
1 1600000 0 4300.1 20745838
3 3200000 0 4239.9 23849857
5 4800000 0 4243.4 25939543
6 6400000 0 4248.4 19514050
8 8000000 0 4262.1 20796169
9 9600000 0 4257.6 21288675
11 11200000 0 4259.7 19375120
13 12800000 0 4220.7 22734141
14 14400000 0 4238.5 31936458
16 16000000 0 4231.5 23409901
18 17600000 0 4045.3 23577700
19 19200000 0 2783.4 58299526
21 20800000 0 2678.2 40616302
23 22400000 0 2693.5 83973996
and xfs complaining about memory allocation not making progress
[ 2304.372647] XFS: fs_mark(3289) possible memory allocation deadlock size 65624 in kmem_alloc (mode:0x2408240)
[ 2304.443323] XFS: fs_mark(3285) possible memory allocation deadlock size 65728 in kmem_alloc (mode:0x2408240)
[ 4796.772477] XFS: fs_mark(3424) possible memory allocation deadlock size 46936 in kmem_alloc (mode:0x2408240)
[ 4796.775329] XFS: fs_mark(3423) possible memory allocation deadlock size 51416 in kmem_alloc (mode:0x2408240)
[ 4797.388808] XFS: fs_mark(3424) possible memory allocation deadlock size 65728 in kmem_alloc (mode:0x2408240)
* Patched kernel
1 1600000 0 4289.1 19243934
3 3200000 0 4241.6 32828865
5 4800000 0 4248.7 32884693
6 6400000 0 4314.4 19608921
8 8000000 0 4269.9 24953292
9 9600000 0 4270.7 33235572
11 11200000 0 4346.4 40817101
13 12800000 0 4285.3 29972397
14 14400000 0 4297.2 20539765
16 16000000 0 4219.6 18596767
18 17600000 0 4273.8 49611187
19 19200000 0 4300.4 27944451
21 20800000 0 4270.6 22324585
22 22400000 0 4317.6 22650382
24 24000000 0 4065.2 22297964
So the dropdown at Count 19200000 didn't happen and there was only a
single warning about allocation not making progress
[ 3063.815003] XFS: fs_mark(3272) possible memory allocation deadlock size 65624 in kmem_alloc (mode:0x2408240)
This suggests that the patch has helped even though there is not all that
much of anonymous memory as the workload mostly generates fs metadata. I
assume the success rate would be higher with more anonymous memory which
should be the case in many workloads.
[akpm@linux-foundation.org: fix comment]
Link: http://lkml.kernel.org/r/20161012114721.31853-1-mhocko@kernel.org
Merge updates from Andrew Morton:
- various misc bits
- most of MM (quite a lot of MM material is awaiting the merge of
linux-next dependencies)
- kasan
- printk updates
- procfs updates
- MAINTAINERS
- /lib updates
- checkpatch updates
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (123 commits)
init: reduce rootwait polling interval time to 5ms
binfmt_elf: use vmalloc() for allocation of vma_filesz
checkpatch: don't emit unified-diff error for rename-only patches
checkpatch: don't check c99 types like uint8_t under tools
checkpatch: avoid multiple line dereferences
checkpatch: don't check .pl files, improve absolute path commit log test
scripts/checkpatch.pl: fix spelling
checkpatch: don't try to get maintained status when --no-tree is given
lib/ida: document locking requirements a bit better
lib/rbtree.c: fix typo in comment of ____rb_erase_color
lib/Kconfig.debug: make CONFIG_STRICT_DEVMEM depend on CONFIG_DEVMEM
MAINTAINERS: add drm and drm/i915 irc channels
MAINTAINERS: add "C:" for URI for chat where developers hang out
MAINTAINERS: add drm and drm/i915 bug filing info
MAINTAINERS: add "B:" for URI where to file bugs
get_maintainer: look for arbitrary letter prefixes in sections
printk: add Kconfig option to set default console loglevel
printk/sound: handle more message headers
printk/btrfs: handle more message headers
printk/kdb: handle more message headers
Since commit bda807d44454 ("mm: migrate: support non-lru movable page
migration") isolate_migratepages_block) can isolate !PageLRU pages which
would acct_isolated account as NR_ISOLATED_*. Accounting these non-lru
pages NR_ISOLATED_{ANON,FILE} doesn't make any sense and it can misguide
heuristics based on those counters such as pgdat_reclaimable_pages resp.
too_many_isolated which would lead to unexpected stalls during the
direct reclaim without any good reason. Note that
__alloc_contig_migrate_range can isolate a lot of pages at once.
On mobile devices such as 512M ram android Phone, it may use a big zram
swap. In some cases zram(zsmalloc) uses too many non-lru but
migratedable pages, such as:
MemTotal: 468148 kB
Normal free:5620kB
Free swap:4736kB
Total swap:409596kB
ZRAM: 164616kB(zsmalloc non-lru pages)
active_anon:60700kB
inactive_anon:60744kB
active_file:34420kB
inactive_file:37532kB
Fix this by only accounting lru pages to NR_ISOLATED_* in
isolate_migratepages_block right after they were isolated and we still
know they were on LRU. Drop acct_isolated because it is called after
the fact and we've lost that information. Batching per-cpu counter
doesn't make much improvement anyway. Also make sure that we uncharge
only LRU pages when putting them back on the LRU in
putback_movable_pages resp. when unmap_and_move migrates the page.
[mhocko@suse.com: replace acct_isolated() with direct counting]
Fixes: bda807d44454 ("mm: migrate: support non-lru movable page migration")
Link: http://lkml.kernel.org/r/20161019080240.9682-1-mhocko@kernel.org
Signed-off-by: Ming Ling <ming.ling@spreadtrum.com>
Install the callbacks via the state machine. Should the hotplug init fail then
no threads are spawned.
Signed-off-by: Anna-Maria Gleixner <anna-maria@linutronix.de>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: linux-mm@kvack.org
Cc: rt@linutronix.de
Link: http://lkml.kernel.org/r/20161126231350.10321-15-bigeasy@linutronix.de
Fragmentation index and the vm.extfrag_threshold sysctl is meant as a
heuristic to prevent excessive compaction for costly orders (i.e. THP).
It's unlikely to make any difference for non-costly orders, especially
with the default threshold. But we cannot afford any uncertainty for
the non-costly orders where the only alternative to successful
reclaim/compaction is OOM. After the recent patches we are guaranteed
maximum effort without heuristics from compaction before deciding OOM,
and fragindex is the last remaining heuristic. Therefore skip fragindex
altogether for non-costly orders.
Suggested-by: Michal Hocko <mhocko@suse.com>
Link: http://lkml.kernel.org/r/20160926162025.21555-5-vbabka@suse.cz
The compaction_zonelist_suitable() function tries to determine if
compaction will be able to proceed after sufficient reclaim, i.e.
whether there are enough reclaimable pages to provide enough order-0
freepages for compaction.
This addition of reclaimable pages to the free pages works well for the
order-0 watermark check, but in the fragmentation index check we only
consider truly free pages. Thus we can get fragindex value close to 0
which indicates failure do to lack of memory, and wrongly decide that
compaction won't be suitable even after reclaim.
Instead of trying to somehow adjust fragindex for reclaimable pages,
let's just skip it from compaction_zonelist_suitable().
Link: http://lkml.kernel.org/r/20160926162025.21555-4-vbabka@suse.cz
Several people have reported premature OOMs for order-2 allocations
(stack) due to OOM rework in 4.7. In the scenario (parallel kernel
build and dd writing to two drives) many pageblocks get marked as
Unmovable and compaction free scanner struggles to isolate free pages.
Joonsoo Kim pointed out that the free scanner skips pageblocks that are
not movable to prevent filling them and forcing non-movable allocations
to fallback to other pageblocks. Such heuristic makes sense to help
prevent long-term fragmentation, but premature OOMs are relatively more
urgent problem. As a compromise, this patch disables the heuristic only
for the ultimate compaction priority.
Link: http://lkml.kernel.org/r/20160906135258.18335-5-vbabka@suse.cz
Reported-by: Ralf-Peter Rohbeck <Ralf-Peter.Rohbeck@quantum.com>
Reported-by: Arkadiusz Miskiewicz <a.miskiewicz@gmail.com>
Reported-by: Olaf Hering <olaf@aepfle.de>
Suggested-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
The __compaction_suitable() function checks the low watermark plus a
compact_gap() gap to decide if there's enough free memory to perform
compaction. Then __isolate_free_page uses low watermark check to decide
if particular free page can be isolated. In the latter case, using low
watermark is needlessly pessimistic, as the free page isolations are
only temporary. For __compaction_suitable() the higher watermark makes
sense for high-order allocations where more freepages increase the
chance of success, and we can typically fail with some order-0 fallback
when the system is struggling to reach that watermark. But for
low-order allocation, forming the page should not be that hard. So
using low watermark here might just prevent compaction from even trying,
and eventually lead to OOM killer even if we are above min watermarks.
So after this patch, we use min watermark for non-costly orders in
__compaction_suitable(), and for all orders in __isolate_free_page().
[vbabka@suse.cz: clarify __isolate_free_page() comment]
Link: http://lkml.kernel.org/r/7ae4baec-4eca-e70b-2a69-94bea4fb19fa@suse.cz
Link: http://lkml.kernel.org/r/20160810091226.6709-11-vbabka@suse.cz
Tested-by: Lorenzo Stoakes <lstoakes@gmail.com>
compaction. This check uses direct compactor's alloc_flags, but that's
wrong, since these flags are not applicable for freepage isolation.
For example, alloc_flags may indicate access to memory reserves, making
compaction proceed, and then fail watermark check during the isolation.
A similar problem exists for ALLOC_CMA, which may be part of
alloc_flags, but not during freepage isolation. In this case however it
makes sense to use ALLOC_CMA both in __compaction_suitable() and
__isolate_free_page(), since there's actually nothing preventing the
freepage scanner to isolate from CMA pageblocks, with the assumption
that a page that could be migrated once by compaction can be migrated
also later by CMA allocation. Thus we should count pages in CMA
pageblocks when considering compaction suitability and when isolating
freepages.
To sum up, this patch should remove some false positives from
__compaction_suitable(), and allow compaction to proceed when free pages
required for compaction reside in the CMA pageblocks.
Link: http://lkml.kernel.org/r/20160810091226.6709-10-vbabka@suse.cz
Compaction uses a watermark gap of (2UL << order) pages at various
places and it's not immediately obvious why. Abstract it through a
compact_gap() wrapper to create a single place with a thorough
explanation.
[vbabka@suse.cz: clarify the comment of compact_gap()]
Link: http://lkml.kernel.org/r/7b6aed1f-fdf8-2063-9ff4-bbe4de712d37@suse.cz
Link: http://lkml.kernel.org/r/20160810091226.6709-9-vbabka@suse.cz
The __compact_finished() function uses low watermark in a check that has
to pass if the direct compaction is to finish and allocation should
succeed. This is too pessimistic, as the allocation will typically use
min watermark. It may happen that during compaction, we drop below the
low watermark (due to parallel activity), but still form the target
high-order page. By checking against low watermark, we might needlessly
continue compaction.
Similarly, __compaction_suitable() uses low watermark in a check whether
allocation can succeed without compaction. Again, this is unnecessarily
pessimistic.
After this patch, these check will use direct compactor's alloc_flags to
determine the watermark, which is effectively the min watermark.
Link: http://lkml.kernel.org/r/20160810091226.6709-8-vbabka@suse.cz
During reclaim/compaction loop, it's desirable to get a final answer
from unsuccessful compaction so we can either fail the allocation or
invoke the OOM killer. However, heuristics such as deferred compaction
or pageblock skip bits can cause compaction to skip parts or whole zones
and lead to premature OOM's, failures or excessive reclaim/compaction
retries.
To remedy this, we introduce a new direct compaction priority called
COMPACT_PRIO_SYNC_FULL, which instructs direct compaction to:
- ignore deferred compaction status for a zone
- ignore pageblock skip hints
- ignore cached scanner positions and scan the whole zone
The new priority should get eventually picked up by
should_compact_retry() and this should improve success rates for costly
allocations using __GFP_REPEAT, such as hugetlbfs allocations, and
reduce some corner-case OOM's for non-costly allocations.
Link: http://lkml.kernel.org/r/20160810091226.6709-6-vbabka@suse.cz
[vbabka@suse.cz: use the MIN_COMPACT_PRIORITY alias]
Link: http://lkml.kernel.org/r/d443b884-87e7-1c93-8684-3a3a35759fb1@suse.cz
Joonsoo has reminded me that in a later patch changing watermark checks
throughout compaction I forgot to update checks in
try_to_compact_pages() and compactd_do_work(). Closer inspection
however shows that they are redundant now in the success case, because
compact_zone() now reliably reports this with COMPACT_SUCCESS. So
effectively the checks just repeat (a subset) of checks that have just
passed. So instead of checking watermarks again, just test the return
value.
Note it's also possible that compaction would declare failure e.g.
because its find_suitable_fallback() is more strict than simple
watermark check, and then the watermark check we are removing would then
still succeed. After this patch this is not possible and it's arguably
better, because for long-term fragmentation avoidance we should rather
try a different zone than allocate with the unsuitable fallback. If
compaction of all zones fail and the allocation is important enough, it
will retry and succeed anyway.
Also remove the stray "bool success" variable from kcompactd_do_work().
Link: http://lkml.kernel.org/r/20160810091226.6709-5-vbabka@suse.cz
Reported-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Acked-by: Michal Hocko <mhocko@kernel.org>
COMPACT_PARTIAL has historically meant that compaction returned after
doing some work without fully compacting a zone. It however didn't
distinguish if compaction terminated because it succeeded in creating
the requested high-order page. This has changed recently and now we
only return COMPACT_PARTIAL when compaction thinks it succeeded, or the
high-order watermark check in compaction_suitable() passes and no
compaction needs to be done.
So at this point we can make the return value clearer by renaming it to
COMPACT_SUCCESS. The next patch will remove some redundant tests for
success where compaction just returned COMPACT_SUCCESS.
Link: http://lkml.kernel.org/r/20160810091226.6709-4-vbabka@suse.cz
Since kswapd compaction moved to kcompactd, compact_pgdat() is not
called anymore, so we remove it. The only caller of __compact_pgdat()
is compact_node(), so we merge them and remove code that was only
reachable from kswapd.
Link: http://lkml.kernel.org/r/20160810091226.6709-3-vbabka@suse.cz
Patch series "make direct compaction more deterministic")
This is mostly a followup to Michal's oom detection rework, which
highlighted the need for direct compaction to provide better feedback in
reclaim/compaction loop, so that it can reliably recognize when
compaction cannot make further progress, and allocation should invoke
OOM killer or fail. We've discussed this at LSF/MM [1] where I proposed
expanding the async/sync migration mode used in compaction to more
general "priorities". This patchset adds one new priority that just
overrides all the heuristics and makes compaction fully scan all zones.
I don't currently think that we need more fine-grained priorities, but
we'll see. Other than that there's some smaller fixes and cleanups,
mainly related to the THP-specific hacks.
I've tested this with stress-highalloc in GFP_KERNEL order-4 and
THP-like order-9 scenarios. There's some improvement for compaction
stats for the order-4, which is likely due to the better watermarks
handling. In the previous version I reported mostly noise wrt
compaction stats, and decreased direct reclaim - now the reclaim is
without difference. I believe this is due to the less aggressive
compaction priority increase in patch 6.
"before" is a mmotm tree prior to 4.7 release plus the first part of the
series that was sent and merged separately
before after
order-4:
Compaction stalls 27216 30759
Compaction success 19598 25475
Compaction failures 7617 5283
Page migrate success 370510 464919
Page migrate failure 25712 27987
Compaction pages isolated 849601 1041581
Compaction migrate scanned 143146541 101084990
Compaction free scanned 208355124 144863510
Compaction cost 1403 1210
order-9:
Compaction stalls 7311 7401
Compaction success 1634 1683
Compaction failures 5677 5718
Page migrate success 194657 183988
Page migrate failure 4753 4170
Compaction pages isolated 498790 456130
Compaction migrate scanned 565371 524174
Compaction free scanned 4230296 4250744
Compaction cost 215 203
[1] https://lwn.net/Articles/684611/
This patch (of 11):
A recent patch has added whole_zone flag that compaction sets when
scanning starts from the zone boundary, in order to report that zone has
been fully scanned in one attempt. For allocations that want to try
really hard or cannot fail, we will want to introduce a mode where
scanning whole zone is guaranteed regardless of the cached positions.
This patch reuses the whole_zone flag in a way that if it's already
passed true to compaction, the cached scanner positions are ignored.
Employing this flag during reclaim/compaction loop will be done in the
next patch. This patch however converts compaction invoked from
userspace via procfs to use this flag. Before this patch, the cached
positions were first reset to zone boundaries and then read back from
struct zone, so there was a window where a parallel compaction could
replace the reset values, making the manual compaction less effective.
Using the flag instead of performing reset is more robust.
Link: http://lkml.kernel.org/r/20160810091226.6709-2-vbabka@suse.cz
Async compaction detects contention either due to failing trylock on
zone->lock or lru_lock, or by need_resched(). Since 1f9efdef4f3f ("mm,
compaction: khugepaged should not give up due to need_resched()") the
code got quite complicated to distinguish these two up to the
__alloc_pages_slowpath() level, so different decisions could be taken
for khugepaged allocations.
After the recent changes, khugepaged allocations don't check for
contended compaction anymore, so we again don't need to distinguish lock
and sched contention, and simplify the current convoluted code a lot.
However, I believe it's also possible to simplify even more and
completely remove the check for contended compaction after the initial
async compaction for costly orders, which was originally aimed at THP
page fault allocations. There are several reasons why this can be done
now:
- with the new defaults, THP page faults no longer do reclaim/compaction at
all, unless the system admin has overridden the default, or application has
indicated via madvise that it can benefit from THP's. In both cases, it
means that the potential extra latency is expected and worth the benefits.
- even if reclaim/compaction proceeds after this patch where it previously
wouldn't, the second compaction attempt is still async and will detect the
contention and back off, if the contention persists
- there are still heuristics like deferred compaction and pageblock skip bits
in place that prevent excessive THP page fault latencies
Link: http://lkml.kernel.org/r/20160721073614.24395-9-vbabka@suse.cz
In the context of direct compaction, for some types of allocations we
would like the compaction to either succeed or definitely fail while
trying as hard as possible. Current async/sync_light migration mode is
insufficient, as there are heuristics such as caching scanner positions,
marking pageblocks as unsuitable or deferring compaction for a zone. At
least the final compaction attempt should be able to override these
heuristics.
To communicate how hard compaction should try, we replace migration mode
with a new enum compact_priority and change the relevant function
signatures. In compact_zone_order() where struct compact_control is
constructed, the priority is mapped to suitable control flags. This
patch itself has no functional change, as the current priority levels
are mapped back to the same migration modes as before. Expanding them
will be done next.
Note that !CONFIG_COMPACTION variant of try_to_compact_pages() is
removed, as the only caller exists under CONFIG_COMPACTION.
Link: http://lkml.kernel.org/r/20160721073614.24395-8-vbabka@suse.cz
At present MIGRATE_SYNC_LIGHT is allowing __isolate_lru_page() to
isolate a PageWriteback page, which __unmap_and_move() then rejects with
-EBUSY: of course the writeback might complete in between, but that's
not what we usually expect, so probably better not to isolate it.
When tested by stress-highalloc from mmtests, this has reduced the
number of page migrate failures by 60-70%.
Link: http://lkml.kernel.org/r/20160721073614.24395-2-vbabka@suse.cz
Acked-by: David Rientjes <rientjes@google.com>
If per-zone LRU accounting is available then there is no point
approximating whether reclaim and compaction should retry based on pgdat
statistics. This is effectively a revert of "mm, vmstat: remove zone
and node double accounting by approximating retries" with the difference
that inactive/active stats are still available. This preserves the
history of why the approximation was retried and why it had to be
reverted to handle OOM kills on 32-bit systems.
Link: http://lkml.kernel.org/r/1469110261-7365-4-git-send-email-mgorman@techsingularity.net
Signed-off-by: Mel Gorman <mgorman@techsingularity.net>
The number of LRU pages, dirty pages and writeback pages must be
accounted for on both zones and nodes because of the reclaim retry
logic, compaction retry logic and highmem calculations all depending on
per-zone stats.
Many lowmem allocations are immune from OOM kill due to a check in
__alloc_pages_may_oom for (ac->high_zoneidx < ZONE_NORMAL) since commit
03668b3ceb0c ("oom: avoid oom killer for lowmem allocations"). The
exception is costly high-order allocations or allocations that cannot
fail. If the __alloc_pages_may_oom avoids OOM-kill for low-order lowmem
allocations then it would fall through to __alloc_pages_direct_compact.
This patch will blindly retry reclaim for zone-constrained allocations
in should_reclaim_retry up to MAX_RECLAIM_RETRIES. This is not ideal
but without per-zone stats there are not many alternatives. The impact
it that zone-constrained allocations may delay before considering the
OOM killer.
As there is no guarantee enough memory can ever be freed to satisfy
compaction, this patch avoids retrying compaction for zone-contrained
allocations.
In combination, that means that the per-node stats can be used when
deciding whether to continue reclaim using a rough approximation. While
it is possible this will make the wrong decision on occasion, it will
not infinite loop as the number of reclaim attempts is capped by
The final step is calculating the number of dirtyable highmem pages. As
those calculations only care about the global count of file pages in
highmem. This patch uses a global counter used instead of per-zone
stats as it is sufficient.
In combination, this allows the per-zone LRU and dirty state counters to
be removed.
[mgorman@techsingularity.net: fix acct_highmem_file_pages()]
Link: http://lkml.kernel.org/r/1468853426-12858-4-git-send-email-mgorman@techsingularity.netLink: http://lkml.kernel.org/r/1467970510-21195-35-git-send-email-mgorman@techsingularity.net
Suggested by: Michal Hocko <mhocko@kernel.org>
Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com>
Cc: Rik van Riel <riel@surriel.com>
This moves the LRU lists from the zone to the node and related data such
as counters, tracing, congestion tracking and writeback tracking.
Unfortunately, due to reclaim and compaction retry logic, it is
necessary to account for the number of LRU pages on both zone and node
logic. Most reclaim logic is based on the node counters but the retry
logic uses the zone counters which do not distinguish inactive and
active sizes. It would be possible to leave the LRU counters on a
per-zone basis but it's a heavier calculation across multiple cache
lines that is much more frequent than the retry checks.
Other than the LRU counters, this is mostly a mechanical patch but note
that it introduces a number of anomalies. For example, the scans are
per-zone but using per-node counters. We also mark a node as congested
when a zone is congested. This causes weird problems that are fixed
later but is easier to review.
In the event that there is excessive overhead on 32-bit systems due to
the nodes being on LRU then there are two potential solutions
1. Long-term isolation of highmem pages when reclaim is lowmem
When pages are skipped, they are immediately added back onto the LRU
list. If lowmem reclaim persisted for long periods of time, the same
highmem pages get continually scanned. The idea would be that lowmem
keeps those pages on a separate list until a reclaim for highmem pages
arrives that splices the highmem pages back onto the LRU. It potentially
could be implemented similar to the UNEVICTABLE list.
That would reduce the skip rate with the potential corner case is that
highmem pages have to be scanned and reclaimed to free lowmem slab pages.
2. Linear scan lowmem pages if the initial LRU shrink fails
This will break LRU ordering but may be preferable and faster during
memory pressure than skipping LRU pages.
Link: http://lkml.kernel.org/r/1467970510-21195-4-git-send-email-mgorman@techsingularity.net
Cc: Hillf Danton <hillf.zj@alibaba-inc.com>
Node-based reclaim requires node-based LRUs and locking. This is a
preparation patch that just moves the lru_lock to the node so later
patches are easier to review. It is a mechanical change but note this
patch makes contention worse because the LRU lock is hotter and direct
reclaim and kswapd can contend on the same lock even when reclaiming
from different zones.
Link: http://lkml.kernel.org/r/1467970510-21195-3-git-send-email-mgorman@techsingularity.net
Reviewed-by: Minchan Kim <minchan@kernel.org>
The caller __alloc_pages_direct_compact() already checked (order == 0)
so there's no need to check again.
Link: http://lkml.kernel.org/r/1465973568-3496-1-git-send-email-opensource.ganesh@gmail.com
Signed-off-by: Ganesh Mahendran <opensource.ganesh@gmail.com>
Cc: Michal Nazarewicz <mina86@mina86.com>
Cc: Anshuman Khandual <khandual@linux.vnet.ibm.com>
This patch is motivated from Hugh and Vlastimil's concern [1].
There are two ways to get freepage from the allocator. One is using
normal memory allocation API and the other is __isolate_free_page()
which is internally used for compaction and pageblock isolation. Later
usage is rather tricky since it doesn't do whole post allocation
processing done by normal API.
One problematic thing I already know is that poisoned page would not be
checked if it is allocated by __isolate_free_page(). Perhaps, there
would be more.
We could add more debug logic for allocated page in the future and this
separation would cause more problem. I'd like to fix this situation at
this time. Solution is simple. This patch commonize some logic for
newly allocated page and uses it on all sites. This will solve the
problem.
[1] http://marc.info/?i=alpine.LSU.2.11.1604270029350.7066%40eggly.anvils%3E
[iamjoonsoo.kim@lge.com: mm-page_alloc-introduce-post-allocation-processing-on-page-allocator-v3]
Link: http://lkml.kernel.org/r/1464230275-25791-7-git-send-email-iamjoonsoo.kim@lge.com
Link: http://lkml.kernel.org/r/1466150259-27727-9-git-send-email-iamjoonsoo.kim@lge.com
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Alexander Potapenko <glider@google.com>
It's not necessary to initialized page_owner with holding the zone lock.
It would cause more contention on the zone lock although it's not a big
problem since it is just debug feature. But, it is better than before
so do it. This is also preparation step to use stackdepot in page owner
feature. Stackdepot allocates new pages when there is no reserved space
and holding the zone lock in this case will cause deadlock.
Link: http://lkml.kernel.org/r/1464230275-25791-2-git-send-email-iamjoonsoo.kim@lge.com
We don't need to split freepages with holding the zone lock. It will
cause more contention on zone lock so not desirable.
[rientjes@google.com: if __isolate_free_page() fails, avoid adding to freelist so we don't call map_pages() with it]
Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1606211447001.43430@chino.kir.corp.google.com
Link: http://lkml.kernel.org/r/1464230275-25791-1-git-send-email-iamjoonsoo.kim@lge.com
We have squeezed meta data of zspage into first page's descriptor. So,
to get meta data from subpage, we should get first page first of all.
But it makes trouble to implment page migration feature of zsmalloc
because any place where to get first page from subpage can be raced with
first page migration. IOW, first page it got could be stale. For
preventing it, I have tried several approahces but it made code
complicated so finally, I concluded to separate metadata from first
page. Of course, it consumes more memory. IOW, 16bytes per zspage on
32bit at the moment. It means we lost 1% at *worst case*(40B/4096B)
which is not bad I think at the cost of maintenance.
Link: http://lkml.kernel.org/r/1464736881-24886-9-git-send-email-minchan@kernel.org
Signed-off-by: Minchan Kim <minchan@kernel.org>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Now, VM has a feature to migrate non-lru movable pages so balloon
doesn't need custom migration hooks in migrate.c and compaction.c.
Instead, this patch implements the page->mapping->a_ops->
{isolate|migrate|putback} functions.
With that, we could remove hooks for ballooning in general migration
functions and make balloon compaction simple.
[akpm@linux-foundation.org: compaction.h requires that the includer first include node.h]
Link: http://lkml.kernel.org/r/1464736881-24886-4-git-send-email-minchan@kernel.org
Signed-off-by: Gioh Kim <gi-oh.kim@profitbricks.com>
Cc: Rafael Aquini <aquini@redhat.com>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
We have allowed migration for only LRU pages until now and it was enough
to make high-order pages. But recently, embedded system(e.g., webOS,
android) uses lots of non-movable pages(e.g., zram, GPU memory) so we
have seen several reports about troubles of small high-order allocation.
For fixing the problem, there were several efforts (e,g,. enhance
compaction algorithm, SLUB fallback to 0-order page, reserved memory,
vmalloc and so on) but if there are lots of non-movable pages in system,
their solutions are void in the long run.
So, this patch is to support facility to change non-movable pages with
movable. For the feature, this patch introduces functions related to
migration to address_space_operations as well as some page flags.
If a driver want to make own pages movable, it should define three
functions which are function pointers of struct
address_space_operations.
1. bool (*isolate_page) (struct page *page, isolate_mode_t mode);
What VM expects on isolate_page function of driver is to return *true*
if driver isolates page successfully. On returing true, VM marks the
page as PG_isolated so concurrent isolation in several CPUs skip the
page for isolation. If a driver cannot isolate the page, it should
return *false*.
Once page is successfully isolated, VM uses page.lru fields so driver
shouldn't expect to preserve values in that fields.
2. int (*migratepage) (struct address_space *mapping,
struct page *newpage, struct page *oldpage, enum migrate_mode);
After isolation, VM calls migratepage of driver with isolated page. The
function of migratepage is to move content of the old page to new page
and set up fields of struct page newpage. Keep in mind that you should
indicate to the VM the oldpage is no longer movable via
__ClearPageMovable() under page_lock if you migrated the oldpage
successfully and returns 0. If driver cannot migrate the page at the
moment, driver can return -EAGAIN. On -EAGAIN, VM will retry page
migration in a short time because VM interprets -EAGAIN as "temporal
migration failure". On returning any error except -EAGAIN, VM will give
up the page migration without retrying in this time.
Driver shouldn't touch page.lru field VM using in the functions.
3. void (*putback_page)(struct page *);
If migration fails on isolated page, VM should return the isolated page
to the driver so VM calls driver's putback_page with migration failed
page. In this function, driver should put the isolated page back to the
own data structure.
4. non-lru movable page flags
There are two page flags for supporting non-lru movable page.
* PG_movable
Driver should use the below function to make page movable under
page_lock.
void __SetPageMovable(struct page *page, struct address_space *mapping)
It needs argument of address_space for registering migration family
functions which will be called by VM. Exactly speaking, PG_movable is
not a real flag of struct page. Rather than, VM reuses page->mapping's
lower bits to represent it.
#define PAGE_MAPPING_MOVABLE 0x2
page->mapping = page->mapping | PAGE_MAPPING_MOVABLE;
so driver shouldn't access page->mapping directly. Instead, driver
should use page_mapping which mask off the low two bits of page->mapping
so it can get right struct address_space.
For testing of non-lru movable page, VM supports __PageMovable function.
However, it doesn't guarantee to identify non-lru movable page because
page->mapping field is unified with other variables in struct page. As
well, if driver releases the page after isolation by VM, page->mapping
doesn't have stable value although it has PAGE_MAPPING_MOVABLE (Look at
__ClearPageMovable). But __PageMovable is cheap to catch whether page
is LRU or non-lru movable once the page has been isolated. Because LRU
pages never can have PAGE_MAPPING_MOVABLE in page->mapping. It is also
good for just peeking to test non-lru movable pages before more
expensive checking with lock_page in pfn scanning to select victim.
For guaranteeing non-lru movable page, VM provides PageMovable function.
Unlike __PageMovable, PageMovable functions validates page->mapping and
mapping->a_ops->isolate_page under lock_page. The lock_page prevents
sudden destroying of page->mapping.
Driver using __SetPageMovable should clear the flag via
__ClearMovablePage under page_lock before the releasing the page.
* PG_isolated
To prevent concurrent isolation among several CPUs, VM marks isolated
page as PG_isolated under lock_page. So if a CPU encounters PG_isolated
non-lru movable page, it can skip it. Driver doesn't need to manipulate
the flag because VM will set/clear it automatically. Keep in mind that
if driver sees PG_isolated page, it means the page have been isolated by
VM so it shouldn't touch page.lru field. PG_isolated is alias with
PG_reclaim flag so driver shouldn't use the flag for own purpose.
[opensource.ganesh@gmail.com: mm/compaction: remove local variable is_lru]
Link: http://lkml.kernel.org/r/20160618014841.GA7422@leo-test
Link: http://lkml.kernel.org/r/1464736881-24886-3-git-send-email-minchan@kernel.org
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: John Einar Reitan <john.reitan@foss.arm.com>
It's possible to isolate some freepages in a pageblock and then fail
split_free_page() due to the low watermark check. In this case, we hit
VM_BUG_ON() because the freeing scanner terminated early without a
contended lock or enough freepages.
This should never have been a VM_BUG_ON() since it's not a fatal
condition. It should have been a VM_WARN_ON() at best, or even handled
gracefully.
Regardless, we need to terminate anytime the full pageblock scan was not
done. The logic belongs in isolate_freepages_block(), so handle its
state gracefully by terminating the pageblock loop and making a note to
restart at the same pageblock next time since it was not possible to
complete the scan this time.
[rientjes@google.com: don't rescan pages in a pageblock]
Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1607111244150.83138@chino.kir.corp.google.com
Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1606291436300.145590@chino.kir.corp.google.com
Reported-by: Minchan Kim <minchan@kernel.org>
Tested-by: Minchan Kim <minchan@kernel.org>
If the memory compaction free scanner cannot successfully split a free
page (only possible due to per-zone low watermark), terminate the free
scanner rather than continuing to scan memory needlessly. If the
watermark is insufficient for a free page of order <= cc->order, then
terminate the scanner since all future splits will also likely fail.
This prevents the compaction freeing scanner from scanning all memory on
very large zones (very noticeable for zones > 128GB, for instance) when
all splits will likely fail while holding zone->lock.
compaction_alloc() iterating a 128GB zone has been benchmarked to take
over 400ms on some systems whereas any free page isolated and ready to
be split ends up failing in split_free_page() because of the low
watermark check and thus the iteration continues.
The next time compaction occurs, the freeing scanner will likely start
at the end of the zone again since no success was made previously and we
get the same lengthy iteration until the zone is brought above the low
watermark. All thp page faults can take >400ms in such a state without
this fix.
Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1606211820350.97086@chino.kir.corp.google.com
While testing the kcompactd in my platform 3G MEM only DMA ZONE. I
found the kcompactd never wakeup. It seems the zoneindex has already
minus 1 before. So the traverse here should be <=.
It fixes a regression where kswapd could previously compact, but
kcompactd not. Not a crash fix though.
[akpm@linux-foundation.org: fix kcompactd_do_work() as well, per Hugh]
Link: http://lkml.kernel.org/r/1463659121-84124-1-git-send-email-puck.chen@hisilicon.com
Fixes: accf62422b3a ("mm, kswapd: replace kswapd compaction with waking up kcompactd")
Signed-off-by: Chen Feng <puck.chen@hisilicon.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Zhuangluan Su <suzhuangluan@hisilicon.com>
Cc: Yiping Xu <xuyiping@hisilicon.com>
costly orders
"mm: consider compaction feedback also for costly allocation" has
removed the upper bound for the reclaim/compaction retries based on the
number of reclaimed pages for costly orders. While this is desirable
the patch did miss a mis interaction between reclaim, compaction and the
retry logic. The direct reclaim tries to get zones over min watermark
while compaction backs off and returns COMPACT_SKIPPED when all zones
are below low watermark + 1<<order gap. If we are getting really close
to OOM then __compaction_suitable can keep returning COMPACT_SKIPPED a
high order request (e.g. hugetlb order-9) while the reclaim is not able
to release enough pages to get us over low watermark. The reclaim is
still able to make some progress (usually trashing over few remaining
pages) so we are not able to break out from the loop.
I have seen this happening with the same test described in "mm: consider
compaction feedback also for costly allocation" on a swapless system.
The original problem got resolved by "vmscan: consider classzone_idx in
compaction_ready" but it shows how things might go wrong when we
approach the oom event horizont.
The reason why compaction requires being over low rather than min
watermark is not clear to me. This check was there essentially since
56de7263fcf3 ("mm: compaction: direct compact when a high-order
allocation fails"). It is clearly an implementation detail though and
we shouldn't pull it into the generic retry logic while we should be
able to cope with such eventuality. The only place in
should_compact_retry where we retry without any upper bound is for
compaction_withdrawn() case.
Introduce compaction_zonelist_suitable function which checks the given
zonelist and returns true only if there is at least one zone which would
would unblock __compaction_suitable if more memory got reclaimed. In
this implementation it checks __compaction_suitable with NR_FREE_PAGES
plus part of the reclaimable memory as the target for the watermark
check. The reclaimable memory is reduced linearly by the allocation
order. The idea is that we do not want to reclaim all the remaining
memory for a single allocation request just unblock
__compaction_suitable which doesn't guarantee we will make a further
progress.
The new helper is then used if compaction_withdrawn() feedback was
provided so we do not retry if there is no outlook for a further
progress. !costly requests shouldn't be affected much - e.g. order-2
pages would require to have at least 64kB on the reclaimable LRUs while
order-9 would need at least 32M which should be enough to not lock up.
[vbabka@suse.cz: fix classzone_idx vs. high_zoneidx usage in compaction_zonelist_suitable]
[akpm@linux-foundation.org: fix it for Mel's mm-page_alloc-remove-field-from-alloc_context.patch]
Cc: Mel Gorman <mgorman@techsingularity.net>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: Vladimir Davydov <vdavydov@virtuozzo.com>
COMPACT_COMPLETE now means that compaction and free scanner met. This
is not very useful information if somebody just wants to use this
feedback and make any decisions based on that. The current caller might
be a poor guy who just happened to scan tiny portion of the zone and
that could be the reason no suitable pages were compacted. Make sure we
distinguish the full and partial zone walks.
Consumers should treat COMPACT_PARTIAL_SKIPPED as a potential success
and be optimistic in retrying.
The existing users of COMPACT_COMPLETE are conservatively changed to use
COMPACT_PARTIAL_SKIPPED as well but some of them should be probably
reconsidered and only defer the compaction only for COMPACT_COMPLETE
with the new semantic.
This patch shouldn't introduce any functional changes.
try_to_compact_pages() can currently return COMPACT_SKIPPED even when
the compaction is defered for some zone just because zone DMA is skipped
in 99% of cases due to watermark checks. This makes COMPACT_DEFERRED
basically unusable for the page allocator as a feedback mechanism.
Make sure we distinguish those two states properly and switch their
ordering in the enum. This would mean that the COMPACT_SKIPPED will be
returned only when all eligible zones are skipped.
As a result COMPACT_DEFERRED handling for THP in __alloc_pages_slowpath
will be more precise and we would bail out rather than reclaim.
