path: root/mm/compaction.c
2017-01-12mm, compaction: fix NR_ISOLATED_* stats for pfn based migrationMing Ling
commit 6afcf8ef0ca0a69d014f8edb613d94821f0ae700 upstream. Since commit bda807d44454 ("mm: migrate: support non-lru movable page migration") isolate_migratepages_block) can isolate !PageLRU pages which would acct_isolated account as NR_ISOLATED_*. Accounting these non-lru pages NR_ISOLATED_{ANON,FILE} doesn't make any sense and it can misguide heuristics based on those counters such as pgdat_reclaimable_pages resp. too_many_isolated which would lead to unexpected stalls during the direct reclaim without any good reason. Note that __alloc_contig_migrate_range can isolate a lot of pages at once. On mobile devices such as 512M ram android Phone, it may use a big zram swap. In some cases zram(zsmalloc) uses too many non-lru but migratedable pages, such as: MemTotal: 468148 kB Normal free:5620kB Free swap:4736kB Total swap:409596kB ZRAM: 164616kB(zsmalloc non-lru pages) active_anon:60700kB inactive_anon:60744kB active_file:34420kB inactive_file:37532kB Fix this by only accounting lru pages to NR_ISOLATED_* in isolate_migratepages_block right after they were isolated and we still know they were on LRU. Drop acct_isolated because it is called after the fact and we've lost that information. Batching per-cpu counter doesn't make much improvement anyway. Also make sure that we uncharge only LRU pages when putting them back on the LRU in putback_movable_pages resp. when unmap_and_move migrates the page. [mhocko@suse.com: replace acct_isolated() with direct counting] Fixes: bda807d44454 ("mm: migrate: support non-lru movable page migration") Link: http://lkml.kernel.org/r/20161019080240.9682-1-mhocko@kernel.org Signed-off-by: Ming Ling <ming.ling@spreadtrum.com> Signed-off-by: Michal Hocko <mhocko@suse.com> Acked-by: Minchan Kim <minchan@kernel.org> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Mel Gorman <mgorman@suse.de> Cc: Joonsoo Kim <js1304@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-07mm, compaction: restrict fragindex to costly ordersVlastimil Babka
Fragmentation index and the vm.extfrag_threshold sysctl is meant as a heuristic to prevent excessive compaction for costly orders (i.e. THP). It's unlikely to make any difference for non-costly orders, especially with the default threshold. But we cannot afford any uncertainty for the non-costly orders where the only alternative to successful reclaim/compaction is OOM. After the recent patches we are guaranteed maximum effort without heuristics from compaction before deciding OOM, and fragindex is the last remaining heuristic. Therefore skip fragindex altogether for non-costly orders. Suggested-by: Michal Hocko <mhocko@suse.com> Link: http://lkml.kernel.org/r/20160926162025.21555-5-vbabka@suse.cz Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: David Rientjes <rientjes@google.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-07mm, compaction: ignore fragindex from compaction_zonelist_suitable()Vlastimil Babka
The compaction_zonelist_suitable() function tries to determine if compaction will be able to proceed after sufficient reclaim, i.e. whether there are enough reclaimable pages to provide enough order-0 freepages for compaction. This addition of reclaimable pages to the free pages works well for the order-0 watermark check, but in the fragmentation index check we only consider truly free pages. Thus we can get fragindex value close to 0 which indicates failure do to lack of memory, and wrongly decide that compaction won't be suitable even after reclaim. Instead of trying to somehow adjust fragindex for reclaimable pages, let's just skip it from compaction_zonelist_suitable(). Link: http://lkml.kernel.org/r/20160926162025.21555-4-vbabka@suse.cz Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: David Rientjes <rientjes@google.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-07mm, compaction: make full priority ignore pageblock suitabilityVlastimil Babka
Several people have reported premature OOMs for order-2 allocations (stack) due to OOM rework in 4.7. In the scenario (parallel kernel build and dd writing to two drives) many pageblocks get marked as Unmovable and compaction free scanner struggles to isolate free pages. Joonsoo Kim pointed out that the free scanner skips pageblocks that are not movable to prevent filling them and forcing non-movable allocations to fallback to other pageblocks. Such heuristic makes sense to help prevent long-term fragmentation, but premature OOMs are relatively more urgent problem. As a compromise, this patch disables the heuristic only for the ultimate compaction priority. Link: http://lkml.kernel.org/r/20160906135258.18335-5-vbabka@suse.cz Reported-by: Ralf-Peter Rohbeck <Ralf-Peter.Rohbeck@quantum.com> Reported-by: Arkadiusz Miskiewicz <a.miskiewicz@gmail.com> Reported-by: Olaf Hering <olaf@aepfle.de> Suggested-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: David Rientjes <rientjes@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-07mm, compaction: require only min watermarks for non-costly ordersVlastimil Babka
The __compaction_suitable() function checks the low watermark plus a compact_gap() gap to decide if there's enough free memory to perform compaction. Then __isolate_free_page uses low watermark check to decide if particular free page can be isolated. In the latter case, using low watermark is needlessly pessimistic, as the free page isolations are only temporary. For __compaction_suitable() the higher watermark makes sense for high-order allocations where more freepages increase the chance of success, and we can typically fail with some order-0 fallback when the system is struggling to reach that watermark. But for low-order allocation, forming the page should not be that hard. So using low watermark here might just prevent compaction from even trying, and eventually lead to OOM killer even if we are above min watermarks. So after this patch, we use min watermark for non-costly orders in __compaction_suitable(), and for all orders in __isolate_free_page(). [vbabka@suse.cz: clarify __isolate_free_page() comment] Link: http://lkml.kernel.org/r/7ae4baec-4eca-e70b-2a69-94bea4fb19fa@suse.cz Link: http://lkml.kernel.org/r/20160810091226.6709-11-vbabka@suse.cz Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Tested-by: Lorenzo Stoakes <lstoakes@gmail.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: David Rientjes <rientjes@google.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Tested-by: Lorenzo Stoakes <lstoakes@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-07mm, compaction: use proper alloc_flags in __compaction_suitable()Vlastimil Babka
The __compaction_suitable() function checks the low watermark plus a compact_gap() gap to decide if there's enough free memory to perform compaction. This check uses direct compactor's alloc_flags, but that's wrong, since these flags are not applicable for freepage isolation. For example, alloc_flags may indicate access to memory reserves, making compaction proceed, and then fail watermark check during the isolation. A similar problem exists for ALLOC_CMA, which may be part of alloc_flags, but not during freepage isolation. In this case however it makes sense to use ALLOC_CMA both in __compaction_suitable() and __isolate_free_page(), since there's actually nothing preventing the freepage scanner to isolate from CMA pageblocks, with the assumption that a page that could be migrated once by compaction can be migrated also later by CMA allocation. Thus we should count pages in CMA pageblocks when considering compaction suitability and when isolating freepages. To sum up, this patch should remove some false positives from __compaction_suitable(), and allow compaction to proceed when free pages required for compaction reside in the CMA pageblocks. Link: http://lkml.kernel.org/r/20160810091226.6709-10-vbabka@suse.cz Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Tested-by: Lorenzo Stoakes <lstoakes@gmail.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: David Rientjes <rientjes@google.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-07mm, compaction: create compact_gap wrapperVlastimil Babka
Compaction uses a watermark gap of (2UL << order) pages at various places and it's not immediately obvious why. Abstract it through a compact_gap() wrapper to create a single place with a thorough explanation. [vbabka@suse.cz: clarify the comment of compact_gap()] Link: http://lkml.kernel.org/r/7b6aed1f-fdf8-2063-9ff4-bbe4de712d37@suse.cz Link: http://lkml.kernel.org/r/20160810091226.6709-9-vbabka@suse.cz Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Tested-by: Lorenzo Stoakes <lstoakes@gmail.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: David Rientjes <rientjes@google.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-07mm, compaction: use correct watermark when checking compaction successVlastimil Babka
The __compact_finished() function uses low watermark in a check that has to pass if the direct compaction is to finish and allocation should succeed. This is too pessimistic, as the allocation will typically use min watermark. It may happen that during compaction, we drop below the low watermark (due to parallel activity), but still form the target high-order page. By checking against low watermark, we might needlessly continue compaction. Similarly, __compaction_suitable() uses low watermark in a check whether allocation can succeed without compaction. Again, this is unnecessarily pessimistic. After this patch, these check will use direct compactor's alloc_flags to determine the watermark, which is effectively the min watermark. Link: http://lkml.kernel.org/r/20160810091226.6709-8-vbabka@suse.cz Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Tested-by: Lorenzo Stoakes <lstoakes@gmail.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: David Rientjes <rientjes@google.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-07mm, compaction: add the ultimate direct compaction priorityVlastimil Babka
During reclaim/compaction loop, it's desirable to get a final answer from unsuccessful compaction so we can either fail the allocation or invoke the OOM killer. However, heuristics such as deferred compaction or pageblock skip bits can cause compaction to skip parts or whole zones and lead to premature OOM's, failures or excessive reclaim/compaction retries. To remedy this, we introduce a new direct compaction priority called COMPACT_PRIO_SYNC_FULL, which instructs direct compaction to: - ignore deferred compaction status for a zone - ignore pageblock skip hints - ignore cached scanner positions and scan the whole zone The new priority should get eventually picked up by should_compact_retry() and this should improve success rates for costly allocations using __GFP_REPEAT, such as hugetlbfs allocations, and reduce some corner-case OOM's for non-costly allocations. Link: http://lkml.kernel.org/r/20160810091226.6709-6-vbabka@suse.cz [vbabka@suse.cz: use the MIN_COMPACT_PRIORITY alias] Link: http://lkml.kernel.org/r/d443b884-87e7-1c93-8684-3a3a35759fb1@suse.cz Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Tested-by: Lorenzo Stoakes <lstoakes@gmail.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: David Rientjes <rientjes@google.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-07mm, compaction: don't recheck watermarks after COMPACT_SUCCESSVlastimil Babka
Joonsoo has reminded me that in a later patch changing watermark checks throughout compaction I forgot to update checks in try_to_compact_pages() and compactd_do_work(). Closer inspection however shows that they are redundant now in the success case, because compact_zone() now reliably reports this with COMPACT_SUCCESS. So effectively the checks just repeat (a subset) of checks that have just passed. So instead of checking watermarks again, just test the return value. Note it's also possible that compaction would declare failure e.g. because its find_suitable_fallback() is more strict than simple watermark check, and then the watermark check we are removing would then still succeed. After this patch this is not possible and it's arguably better, because for long-term fragmentation avoidance we should rather try a different zone than allocate with the unsuitable fallback. If compaction of all zones fail and the allocation is important enough, it will retry and succeed anyway. Also remove the stray "bool success" variable from kcompactd_do_work(). Link: http://lkml.kernel.org/r/20160810091226.6709-5-vbabka@suse.cz Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Reported-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Tested-by: Lorenzo Stoakes <lstoakes@gmail.com> Acked-by: Michal Hocko <mhocko@kernel.org> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: David Rientjes <rientjes@google.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-07mm, compaction: rename COMPACT_PARTIAL to COMPACT_SUCCESSVlastimil Babka
COMPACT_PARTIAL has historically meant that compaction returned after doing some work without fully compacting a zone. It however didn't distinguish if compaction terminated because it succeeded in creating the requested high-order page. This has changed recently and now we only return COMPACT_PARTIAL when compaction thinks it succeeded, or the high-order watermark check in compaction_suitable() passes and no compaction needs to be done. So at this point we can make the return value clearer by renaming it to COMPACT_SUCCESS. The next patch will remove some redundant tests for success where compaction just returned COMPACT_SUCCESS. Link: http://lkml.kernel.org/r/20160810091226.6709-4-vbabka@suse.cz Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Tested-by: Lorenzo Stoakes <lstoakes@gmail.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: David Rientjes <rientjes@google.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-07mm, compaction: cleanup unused functionsVlastimil Babka
Since kswapd compaction moved to kcompactd, compact_pgdat() is not called anymore, so we remove it. The only caller of __compact_pgdat() is compact_node(), so we merge them and remove code that was only reachable from kswapd. Link: http://lkml.kernel.org/r/20160810091226.6709-3-vbabka@suse.cz Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Tested-by: Lorenzo Stoakes <lstoakes@gmail.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: David Rientjes <rientjes@google.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-07mm, compaction: make whole_zone flag ignore cached scanner positionsVlastimil Babka
Patch series "make direct compaction more deterministic") This is mostly a followup to Michal's oom detection rework, which highlighted the need for direct compaction to provide better feedback in reclaim/compaction loop, so that it can reliably recognize when compaction cannot make further progress, and allocation should invoke OOM killer or fail. We've discussed this at LSF/MM [1] where I proposed expanding the async/sync migration mode used in compaction to more general "priorities". This patchset adds one new priority that just overrides all the heuristics and makes compaction fully scan all zones. I don't currently think that we need more fine-grained priorities, but we'll see. Other than that there's some smaller fixes and cleanups, mainly related to the THP-specific hacks. I've tested this with stress-highalloc in GFP_KERNEL order-4 and THP-like order-9 scenarios. There's some improvement for compaction stats for the order-4, which is likely due to the better watermarks handling. In the previous version I reported mostly noise wrt compaction stats, and decreased direct reclaim - now the reclaim is without difference. I believe this is due to the less aggressive compaction priority increase in patch 6. "before" is a mmotm tree prior to 4.7 release plus the first part of the series that was sent and merged separately before after order-4: Compaction stalls 27216 30759 Compaction success 19598 25475 Compaction failures 7617 5283 Page migrate success 370510 464919 Page migrate failure 25712 27987 Compaction pages isolated 849601 1041581 Compaction migrate scanned 143146541 101084990 Compaction free scanned 208355124 144863510 Compaction cost 1403 1210 order-9: Compaction stalls 7311 7401 Compaction success 1634 1683 Compaction failures 5677 5718 Page migrate success 194657 183988 Page migrate failure 4753 4170 Compaction pages isolated 498790 456130 Compaction migrate scanned 565371 524174 Compaction free scanned 4230296 4250744 Compaction cost 215 203 [1] https://lwn.net/Articles/684611/ This patch (of 11): A recent patch has added whole_zone flag that compaction sets when scanning starts from the zone boundary, in order to report that zone has been fully scanned in one attempt. For allocations that want to try really hard or cannot fail, we will want to introduce a mode where scanning whole zone is guaranteed regardless of the cached positions. This patch reuses the whole_zone flag in a way that if it's already passed true to compaction, the cached scanner positions are ignored. Employing this flag during reclaim/compaction loop will be done in the next patch. This patch however converts compaction invoked from userspace via procfs to use this flag. Before this patch, the cached positions were first reset to zone boundaries and then read back from struct zone, so there was a window where a parallel compaction could replace the reset values, making the manual compaction less effective. Using the flag instead of performing reset is more robust. [akpm@linux-foundation.org: coding-style fixes] Link: http://lkml.kernel.org/r/20160810091226.6709-2-vbabka@suse.cz Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Tested-by: Lorenzo Stoakes <lstoakes@gmail.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: David Rientjes <rientjes@google.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm, compaction: simplify contended compaction handlingVlastimil Babka
Async compaction detects contention either due to failing trylock on zone->lock or lru_lock, or by need_resched(). Since 1f9efdef4f3f ("mm, compaction: khugepaged should not give up due to need_resched()") the code got quite complicated to distinguish these two up to the __alloc_pages_slowpath() level, so different decisions could be taken for khugepaged allocations. After the recent changes, khugepaged allocations don't check for contended compaction anymore, so we again don't need to distinguish lock and sched contention, and simplify the current convoluted code a lot. However, I believe it's also possible to simplify even more and completely remove the check for contended compaction after the initial async compaction for costly orders, which was originally aimed at THP page fault allocations. There are several reasons why this can be done now: - with the new defaults, THP page faults no longer do reclaim/compaction at all, unless the system admin has overridden the default, or application has indicated via madvise that it can benefit from THP's. In both cases, it means that the potential extra latency is expected and worth the benefits. - even if reclaim/compaction proceeds after this patch where it previously wouldn't, the second compaction attempt is still async and will detect the contention and back off, if the contention persists - there are still heuristics like deferred compaction and pageblock skip bits in place that prevent excessive THP page fault latencies Link: http://lkml.kernel.org/r/20160721073614.24395-9-vbabka@suse.cz Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Mel Gorman <mgorman@techsingularity.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm, compaction: introduce direct compaction priorityVlastimil Babka
In the context of direct compaction, for some types of allocations we would like the compaction to either succeed or definitely fail while trying as hard as possible. Current async/sync_light migration mode is insufficient, as there are heuristics such as caching scanner positions, marking pageblocks as unsuitable or deferring compaction for a zone. At least the final compaction attempt should be able to override these heuristics. To communicate how hard compaction should try, we replace migration mode with a new enum compact_priority and change the relevant function signatures. In compact_zone_order() where struct compact_control is constructed, the priority is mapped to suitable control flags. This patch itself has no functional change, as the current priority levels are mapped back to the same migration modes as before. Expanding them will be done next. Note that !CONFIG_COMPACTION variant of try_to_compact_pages() is removed, as the only caller exists under CONFIG_COMPACTION. Link: http://lkml.kernel.org/r/20160721073614.24395-8-vbabka@suse.cz Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Mel Gorman <mgorman@techsingularity.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm, compaction: don't isolate PageWriteback pages in MIGRATE_SYNC_LIGHT modeHugh Dickins
At present MIGRATE_SYNC_LIGHT is allowing __isolate_lru_page() to isolate a PageWriteback page, which __unmap_and_move() then rejects with -EBUSY: of course the writeback might complete in between, but that's not what we usually expect, so probably better not to isolate it. When tested by stress-highalloc from mmtests, this has reduced the number of page migrate failures by 60-70%. Link: http://lkml.kernel.org/r/20160721073614.24395-2-vbabka@suse.cz Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm: remove reclaim and compaction retry approximationsMel Gorman
If per-zone LRU accounting is available then there is no point approximating whether reclaim and compaction should retry based on pgdat statistics. This is effectively a revert of "mm, vmstat: remove zone and node double accounting by approximating retries" with the difference that inactive/active stats are still available. This preserves the history of why the approximation was retried and why it had to be reverted to handle OOM kills on 32-bit systems. Link: http://lkml.kernel.org/r/1469110261-7365-4-git-send-email-mgorman@techsingularity.net Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Minchan Kim <minchan@kernel.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm, vmstat: remove zone and node double accounting by approximating retriesMel Gorman
The number of LRU pages, dirty pages and writeback pages must be accounted for on both zones and nodes because of the reclaim retry logic, compaction retry logic and highmem calculations all depending on per-zone stats. Many lowmem allocations are immune from OOM kill due to a check in __alloc_pages_may_oom for (ac->high_zoneidx < ZONE_NORMAL) since commit 03668b3ceb0c ("oom: avoid oom killer for lowmem allocations"). The exception is costly high-order allocations or allocations that cannot fail. If the __alloc_pages_may_oom avoids OOM-kill for low-order lowmem allocations then it would fall through to __alloc_pages_direct_compact. This patch will blindly retry reclaim for zone-constrained allocations in should_reclaim_retry up to MAX_RECLAIM_RETRIES. This is not ideal but without per-zone stats there are not many alternatives. The impact it that zone-constrained allocations may delay before considering the OOM killer. As there is no guarantee enough memory can ever be freed to satisfy compaction, this patch avoids retrying compaction for zone-contrained allocations. In combination, that means that the per-node stats can be used when deciding whether to continue reclaim using a rough approximation. While it is possible this will make the wrong decision on occasion, it will not infinite loop as the number of reclaim attempts is capped by MAX_RECLAIM_RETRIES. The final step is calculating the number of dirtyable highmem pages. As those calculations only care about the global count of file pages in highmem. This patch uses a global counter used instead of per-zone stats as it is sufficient. In combination, this allows the per-zone LRU and dirty state counters to be removed. [mgorman@techsingularity.net: fix acct_highmem_file_pages()] Link: http://lkml.kernel.org/r/1468853426-12858-4-git-send-email-mgorman@techsingularity.netLink: http://lkml.kernel.org/r/1467970510-21195-35-git-send-email-mgorman@techsingularity.net Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Suggested by: Michal Hocko <mhocko@kernel.org> Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@surriel.com> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm, vmscan: move LRU lists to nodeMel Gorman
This moves the LRU lists from the zone to the node and related data such as counters, tracing, congestion tracking and writeback tracking. Unfortunately, due to reclaim and compaction retry logic, it is necessary to account for the number of LRU pages on both zone and node logic. Most reclaim logic is based on the node counters but the retry logic uses the zone counters which do not distinguish inactive and active sizes. It would be possible to leave the LRU counters on a per-zone basis but it's a heavier calculation across multiple cache lines that is much more frequent than the retry checks. Other than the LRU counters, this is mostly a mechanical patch but note that it introduces a number of anomalies. For example, the scans are per-zone but using per-node counters. We also mark a node as congested when a zone is congested. This causes weird problems that are fixed later but is easier to review. In the event that there is excessive overhead on 32-bit systems due to the nodes being on LRU then there are two potential solutions 1. Long-term isolation of highmem pages when reclaim is lowmem When pages are skipped, they are immediately added back onto the LRU list. If lowmem reclaim persisted for long periods of time, the same highmem pages get continually scanned. The idea would be that lowmem keeps those pages on a separate list until a reclaim for highmem pages arrives that splices the highmem pages back onto the LRU. It potentially could be implemented similar to the UNEVICTABLE list. That would reduce the skip rate with the potential corner case is that highmem pages have to be scanned and reclaimed to free lowmem slab pages. 2. Linear scan lowmem pages if the initial LRU shrink fails This will break LRU ordering but may be preferable and faster during memory pressure than skipping LRU pages. Link: http://lkml.kernel.org/r/1467970510-21195-4-git-send-email-mgorman@techsingularity.net Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Hillf Danton <hillf.zj@alibaba-inc.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@surriel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm, vmscan: move lru_lock to the nodeMel Gorman
Node-based reclaim requires node-based LRUs and locking. This is a preparation patch that just moves the lru_lock to the node so later patches are easier to review. It is a mechanical change but note this patch makes contention worse because the LRU lock is hotter and direct reclaim and kswapd can contend on the same lock even when reclaiming from different zones. Link: http://lkml.kernel.org/r/1467970510-21195-3-git-send-email-mgorman@techsingularity.net Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Reviewed-by: Minchan Kim <minchan@kernel.org> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Hillf Danton <hillf.zj@alibaba-inc.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Rik van Riel <riel@surriel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm/compaction: remove unnecessary order check in try_to_compact_pages()Ganesh Mahendran
The caller __alloc_pages_direct_compact() already checked (order == 0) so there's no need to check again. Link: http://lkml.kernel.org/r/1465973568-3496-1-git-send-email-opensource.ganesh@gmail.com Signed-off-by: Ganesh Mahendran <opensource.ganesh@gmail.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Anshuman Khandual <khandual@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26mm/page_alloc: introduce post allocation processing on page allocatorJoonsoo Kim
This patch is motivated from Hugh and Vlastimil's concern [1]. There are two ways to get freepage from the allocator. One is using normal memory allocation API and the other is __isolate_free_page() which is internally used for compaction and pageblock isolation. Later usage is rather tricky since it doesn't do whole post allocation processing done by normal API. One problematic thing I already know is that poisoned page would not be checked if it is allocated by __isolate_free_page(). Perhaps, there would be more. We could add more debug logic for allocated page in the future and this separation would cause more problem. I'd like to fix this situation at this time. Solution is simple. This patch commonize some logic for newly allocated page and uses it on all sites. This will solve the problem. [1] http://marc.info/?i=alpine.LSU.2.11.1604270029350.7066%40eggly.anvils%3E [iamjoonsoo.kim@lge.com: mm-page_alloc-introduce-post-allocation-processing-on-page-allocator-v3] Link: http://lkml.kernel.org/r/1464230275-25791-7-git-send-email-iamjoonsoo.kim@lge.com Link: http://lkml.kernel.org/r/1466150259-27727-9-git-send-email-iamjoonsoo.kim@lge.com Link: http://lkml.kernel.org/r/1464230275-25791-7-git-send-email-iamjoonsoo.kim@lge.com Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Minchan Kim <minchan@kernel.org> Cc: Alexander Potapenko <glider@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Michal Hocko <mhocko@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26mm/page_owner: initialize page owner without holding the zone lockJoonsoo Kim
It's not necessary to initialized page_owner with holding the zone lock. It would cause more contention on the zone lock although it's not a big problem since it is just debug feature. But, it is better than before so do it. This is also preparation step to use stackdepot in page owner feature. Stackdepot allocates new pages when there is no reserved space and holding the zone lock in this case will cause deadlock. Link: http://lkml.kernel.org/r/1464230275-25791-2-git-send-email-iamjoonsoo.kim@lge.com Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Minchan Kim <minchan@kernel.org> Cc: Alexander Potapenko <glider@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Michal Hocko <mhocko@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26mm/compaction: split freepages without holding the zone lockJoonsoo Kim
We don't need to split freepages with holding the zone lock. It will cause more contention on zone lock so not desirable. [rientjes@google.com: if __isolate_free_page() fails, avoid adding to freelist so we don't call map_pages() with it] Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1606211447001.43430@chino.kir.corp.google.com Link: http://lkml.kernel.org/r/1464230275-25791-1-git-send-email-iamjoonsoo.kim@lge.com Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Minchan Kim <minchan@kernel.org> Cc: Alexander Potapenko <glider@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Michal Hocko <mhocko@kernel.org> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26zsmalloc: introduce zspage structureMinchan Kim
We have squeezed meta data of zspage into first page's descriptor. So, to get meta data from subpage, we should get first page first of all. But it makes trouble to implment page migration feature of zsmalloc because any place where to get first page from subpage can be raced with first page migration. IOW, first page it got could be stale. For preventing it, I have tried several approahces but it made code complicated so finally, I concluded to separate metadata from first page. Of course, it consumes more memory. IOW, 16bytes per zspage on 32bit at the moment. It means we lost 1% at *worst case*(40B/4096B) which is not bad I think at the cost of maintenance. Link: http://lkml.kernel.org/r/1464736881-24886-9-git-send-email-minchan@kernel.org Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26mm: balloon: use general non-lru movable page featureMinchan Kim
Now, VM has a feature to migrate non-lru movable pages so balloon doesn't need custom migration hooks in migrate.c and compaction.c. Instead, this patch implements the page->mapping->a_ops-> {isolate|migrate|putback} functions. With that, we could remove hooks for ballooning in general migration functions and make balloon compaction simple. [akpm@linux-foundation.org: compaction.h requires that the includer first include node.h] Link: http://lkml.kernel.org/r/1464736881-24886-4-git-send-email-minchan@kernel.org Signed-off-by: Gioh Kim <gi-oh.kim@profitbricks.com> Signed-off-by: Minchan Kim <minchan@kernel.org> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Rafael Aquini <aquini@redhat.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26mm: migrate: support non-lru movable page migrationMinchan Kim
We have allowed migration for only LRU pages until now and it was enough to make high-order pages. But recently, embedded system(e.g., webOS, android) uses lots of non-movable pages(e.g., zram, GPU memory) so we have seen several reports about troubles of small high-order allocation. For fixing the problem, there were several efforts (e,g,. enhance compaction algorithm, SLUB fallback to 0-order page, reserved memory, vmalloc and so on) but if there are lots of non-movable pages in system, their solutions are void in the long run. So, this patch is to support facility to change non-movable pages with movable. For the feature, this patch introduces functions related to migration to address_space_operations as well as some page flags. If a driver want to make own pages movable, it should define three functions which are function pointers of struct address_space_operations. 1. bool (*isolate_page) (struct page *page, isolate_mode_t mode); What VM expects on isolate_page function of driver is to return *true* if driver isolates page successfully. On returing true, VM marks the page as PG_isolated so concurrent isolation in several CPUs skip the page for isolation. If a driver cannot isolate the page, it should return *false*. Once page is successfully isolated, VM uses page.lru fields so driver shouldn't expect to preserve values in that fields. 2. int (*migratepage) (struct address_space *mapping, struct page *newpage, struct page *oldpage, enum migrate_mode); After isolation, VM calls migratepage of driver with isolated page. The function of migratepage is to move content of the old page to new page and set up fields of struct page newpage. Keep in mind that you should indicate to the VM the oldpage is no longer movable via __ClearPageMovable() under page_lock if you migrated the oldpage successfully and returns 0. If driver cannot migrate the page at the moment, driver can return -EAGAIN. On -EAGAIN, VM will retry page migration in a short time because VM interprets -EAGAIN as "temporal migration failure". On returning any error except -EAGAIN, VM will give up the page migration without retrying in this time. Driver shouldn't touch page.lru field VM using in the functions. 3. void (*putback_page)(struct page *); If migration fails on isolated page, VM should return the isolated page to the driver so VM calls driver's putback_page with migration failed page. In this function, driver should put the isolated page back to the own data structure. 4. non-lru movable page flags There are two page flags for supporting non-lru movable page. * PG_movable Driver should use the below function to make page movable under page_lock. void __SetPageMovable(struct page *page, struct address_space *mapping) It needs argument of address_space for registering migration family functions which will be called by VM. Exactly speaking, PG_movable is not a real flag of struct page. Rather than, VM reuses page->mapping's lower bits to represent it. #define PAGE_MAPPING_MOVABLE 0x2 page->mapping = page->mapping | PAGE_MAPPING_MOVABLE; so driver shouldn't access page->mapping directly. Instead, driver should use page_mapping which mask off the low two bits of page->mapping so it can get right struct address_space. For testing of non-lru movable page, VM supports __PageMovable function. However, it doesn't guarantee to identify non-lru movable page because page->mapping field is unified with other variables in struct page. As well, if driver releases the page after isolation by VM, page->mapping doesn't have stable value although it has PAGE_MAPPING_MOVABLE (Look at __ClearPageMovable). But __PageMovable is cheap to catch whether page is LRU or non-lru movable once the page has been isolated. Because LRU pages never can have PAGE_MAPPING_MOVABLE in page->mapping. It is also good for just peeking to test non-lru movable pages before more expensive checking with lock_page in pfn scanning to select victim. For guaranteeing non-lru movable page, VM provides PageMovable function. Unlike __PageMovable, PageMovable functions validates page->mapping and mapping->a_ops->isolate_page under lock_page. The lock_page prevents sudden destroying of page->mapping. Driver using __SetPageMovable should clear the flag via __ClearMovablePage under page_lock before the releasing the page. * PG_isolated To prevent concurrent isolation among several CPUs, VM marks isolated page as PG_isolated under lock_page. So if a CPU encounters PG_isolated non-lru movable page, it can skip it. Driver doesn't need to manipulate the flag because VM will set/clear it automatically. Keep in mind that if driver sees PG_isolated page, it means the page have been isolated by VM so it shouldn't touch page.lru field. PG_isolated is alias with PG_reclaim flag so driver shouldn't use the flag for own purpose. [opensource.ganesh@gmail.com: mm/compaction: remove local variable is_lru] Link: http://lkml.kernel.org/r/20160618014841.GA7422@leo-test Link: http://lkml.kernel.org/r/1464736881-24886-3-git-send-email-minchan@kernel.org Signed-off-by: Gioh Kim <gi-oh.kim@profitbricks.com> Signed-off-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Ganesh Mahendran <opensource.ganesh@gmail.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Hugh Dickins <hughd@google.com> Cc: Rafael Aquini <aquini@redhat.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: John Einar Reitan <john.reitan@foss.arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-15mm, compaction: prevent VM_BUG_ON when terminating freeing scannerDavid Rientjes
It's possible to isolate some freepages in a pageblock and then fail split_free_page() due to the low watermark check. In this case, we hit VM_BUG_ON() because the freeing scanner terminated early without a contended lock or enough freepages. This should never have been a VM_BUG_ON() since it's not a fatal condition. It should have been a VM_WARN_ON() at best, or even handled gracefully. Regardless, we need to terminate anytime the full pageblock scan was not done. The logic belongs in isolate_freepages_block(), so handle its state gracefully by terminating the pageblock loop and making a note to restart at the same pageblock next time since it was not possible to complete the scan this time. [rientjes@google.com: don't rescan pages in a pageblock] Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1607111244150.83138@chino.kir.corp.google.com Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1606291436300.145590@chino.kir.corp.google.com Signed-off-by: David Rientjes <rientjes@google.com> Reported-by: Minchan Kim <minchan@kernel.org> Tested-by: Minchan Kim <minchan@kernel.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Hugh Dickins <hughd@google.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-06-24mm, compaction: abort free scanner if split failsDavid Rientjes
If the memory compaction free scanner cannot successfully split a free page (only possible due to per-zone low watermark), terminate the free scanner rather than continuing to scan memory needlessly. If the watermark is insufficient for a free page of order <= cc->order, then terminate the scanner since all future splits will also likely fail. This prevents the compaction freeing scanner from scanning all memory on very large zones (very noticeable for zones > 128GB, for instance) when all splits will likely fail while holding zone->lock. compaction_alloc() iterating a 128GB zone has been benchmarked to take over 400ms on some systems whereas any free page isolated and ready to be split ends up failing in split_free_page() because of the low watermark check and thus the iteration continues. The next time compaction occurs, the freeing scanner will likely start at the end of the zone again since no success was made previously and we get the same lengthy iteration until the zone is brought above the low watermark. All thp page faults can take >400ms in such a state without this fix. Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1606211820350.97086@chino.kir.corp.google.com Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Minchan Kim <minchan@kernel.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Hugh Dickins <hughd@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20mm/compaction.c: fix zoneindex in kcompactd()Chen Feng
While testing the kcompactd in my platform 3G MEM only DMA ZONE. I found the kcompactd never wakeup. It seems the zoneindex has already minus 1 before. So the traverse here should be <=. It fixes a regression where kswapd could previously compact, but kcompactd not. Not a crash fix though. [akpm@linux-foundation.org: fix kcompactd_do_work() as well, per Hugh] Link: http://lkml.kernel.org/r/1463659121-84124-1-git-send-email-puck.chen@hisilicon.com Fixes: accf62422b3a ("mm, kswapd: replace kswapd compaction with waking up kcompactd") Signed-off-by: Chen Feng <puck.chen@hisilicon.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Tejun Heo <tj@kernel.org> Cc: Zhuangluan Su <suzhuangluan@hisilicon.com> Cc: Yiping Xu <xuyiping@hisilicon.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20mm, oom, compaction: prevent from should_compact_retry looping for ever for ↵Michal Hocko
costly orders "mm: consider compaction feedback also for costly allocation" has removed the upper bound for the reclaim/compaction retries based on the number of reclaimed pages for costly orders. While this is desirable the patch did miss a mis interaction between reclaim, compaction and the retry logic. The direct reclaim tries to get zones over min watermark while compaction backs off and returns COMPACT_SKIPPED when all zones are below low watermark + 1<<order gap. If we are getting really close to OOM then __compaction_suitable can keep returning COMPACT_SKIPPED a high order request (e.g. hugetlb order-9) while the reclaim is not able to release enough pages to get us over low watermark. The reclaim is still able to make some progress (usually trashing over few remaining pages) so we are not able to break out from the loop. I have seen this happening with the same test described in "mm: consider compaction feedback also for costly allocation" on a swapless system. The original problem got resolved by "vmscan: consider classzone_idx in compaction_ready" but it shows how things might go wrong when we approach the oom event horizont. The reason why compaction requires being over low rather than min watermark is not clear to me. This check was there essentially since 56de7263fcf3 ("mm: compaction: direct compact when a high-order allocation fails"). It is clearly an implementation detail though and we shouldn't pull it into the generic retry logic while we should be able to cope with such eventuality. The only place in should_compact_retry where we retry without any upper bound is for compaction_withdrawn() case. Introduce compaction_zonelist_suitable function which checks the given zonelist and returns true only if there is at least one zone which would would unblock __compaction_suitable if more memory got reclaimed. In this implementation it checks __compaction_suitable with NR_FREE_PAGES plus part of the reclaimable memory as the target for the watermark check. The reclaimable memory is reduced linearly by the allocation order. The idea is that we do not want to reclaim all the remaining memory for a single allocation request just unblock __compaction_suitable which doesn't guarantee we will make a further progress. The new helper is then used if compaction_withdrawn() feedback was provided so we do not retry if there is no outlook for a further progress. !costly requests shouldn't be affected much - e.g. order-2 pages would require to have at least 64kB on the reclaimable LRUs while order-9 would need at least 32M which should be enough to not lock up. [vbabka@suse.cz: fix classzone_idx vs. high_zoneidx usage in compaction_zonelist_suitable] [akpm@linux-foundation.org: fix it for Mel's mm-page_alloc-remove-field-from-alloc_context.patch] Signed-off-by: Michal Hocko <mhocko@suse.com> Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: David Rientjes <rientjes@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Vladimir Davydov <vdavydov@virtuozzo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20mm, compaction: distinguish between full and partial COMPACT_COMPLETEMichal Hocko
COMPACT_COMPLETE now means that compaction and free scanner met. This is not very useful information if somebody just wants to use this feedback and make any decisions based on that. The current caller might be a poor guy who just happened to scan tiny portion of the zone and that could be the reason no suitable pages were compacted. Make sure we distinguish the full and partial zone walks. Consumers should treat COMPACT_PARTIAL_SKIPPED as a potential success and be optimistic in retrying. The existing users of COMPACT_COMPLETE are conservatively changed to use COMPACT_PARTIAL_SKIPPED as well but some of them should be probably reconsidered and only defer the compaction only for COMPACT_COMPLETE with the new semantic. This patch shouldn't introduce any functional changes. Signed-off-by: Michal Hocko <mhocko@suse.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com> Cc: David Rientjes <rientjes@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Vladimir Davydov <vdavydov@virtuozzo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20mm, compaction: distinguish COMPACT_DEFERRED from COMPACT_SKIPPEDMichal Hocko
try_to_compact_pages() can currently return COMPACT_SKIPPED even when the compaction is defered for some zone just because zone DMA is skipped in 99% of cases due to watermark checks. This makes COMPACT_DEFERRED basically unusable for the page allocator as a feedback mechanism. Make sure we distinguish those two states properly and switch their ordering in the enum. This would mean that the COMPACT_SKIPPED will be returned only when all eligible zones are skipped. As a result COMPACT_DEFERRED handling for THP in __alloc_pages_slowpath will be more precise and we would bail out rather than reclaim. Signed-off-by: Michal Hocko <mhocko@suse.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com> Cc: David Rientjes <rientjes@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Vladimir Davydov <vdavydov@virtuozzo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20mm, compaction: cover all compaction mode in compact_zoneMichal Hocko
The compiler is complaining after "mm, compaction: change COMPACT_ constants into enum" mm/compaction.c: In function `compact_zone': mm/compaction.c:1350:2: warning: enumeration value `COMPACT_DEFERRED' not handled in switch [-Wswitch] switch (ret) { ^ mm/compaction.c:1350:2: warning: enumeration value `COMPACT_COMPLETE' not handled in switch [-Wswitch] mm/compaction.c:1350:2: warning: enumeration value `COMPACT_NO_SUITABLE_PAGE' not handled in switch [-Wswitch] mm/compaction.c:1350:2: warning: enumeration value `COMPACT_NOT_SUITABLE_ZONE' not handled in switch [-Wswitch] mm/compaction.c:1350:2: warning: enumeration value `COMPACT_CONTENDED' not handled in switch [-Wswitch] compaction_suitable is allowed to return only COMPACT_PARTIAL, COMPACT_SKIPPED and COMPACT_CONTINUE so other cases are simply impossible. Put a VM_BUG_ON to catch an impossible return value. Signed-off-by: Michal Hocko <mhocko@suse.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com> Cc: David Rientjes <rientjes@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Vladimir Davydov <vdavydov@virtuozzo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20mm, compaction: change COMPACT_ constants into enumMichal Hocko
Compaction code is doing weird dances between COMPACT_FOO -> int -> unsigned long But there doesn't seem to be any reason for that. All functions which return/use one of those constants are not expecting any other value so it really makes sense to define an enum for them and make it clear that no other values are expected. This is a pure cleanup and shouldn't introduce any functional changes. Signed-off-by: Michal Hocko <mhocko@suse.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com> Cc: David Rientjes <rientjes@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Vladimir Davydov <vdavydov@virtuozzo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-19mm, page_alloc: remove field from alloc_contextMel Gorman
The classzone_idx can be inferred from preferred_zoneref so remove the unnecessary field and save stack space. Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-19mm, page_alloc: convert alloc_flags to unsignedMel Gorman
alloc_flags is a bitmask of flags but it is signed which does not necessarily generate the best code depending on the compiler. Even without an impact, it makes more sense that this be unsigned. Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-19mm, compaction: skip blocks where isolation fails in async direct compactionVlastimil Babka
The goal of direct compaction is to quickly make a high-order page available for the pending allocation. Within an aligned block of pages of desired order, a single allocated page that cannot be isolated for migration means that the block cannot fully merge to a buddy page that would satisfy the allocation request. Therefore we can reduce the allocation stall by skipping the rest of the block immediately on isolation failure. For async compaction, this also means a higher chance of succeeding until it detects contention. We however shouldn't completely sacrifice the second objective of compaction, which is to reduce overal long-term memory fragmentation. As a compromise, perform the eager skipping only in direct async compaction, while sync compaction (including kcompactd) remains thorough. Testing was done using stress-highalloc from mmtests, configured for order-4 GFP_KERNEL allocations: 4.6-rc1 4.6-rc1 before after Success 1 Min 24.00 ( 0.00%) 27.00 (-12.50%) Success 1 Mean 30.20 ( 0.00%) 31.60 ( -4.64%) Success 1 Max 37.00 ( 0.00%) 35.00 ( 5.41%) Success 2 Min 42.00 ( 0.00%) 32.00 ( 23.81%) Success 2 Mean 44.00 ( 0.00%) 44.80 ( -1.82%) Success 2 Max 48.00 ( 0.00%) 52.00 ( -8.33%) Success 3 Min 91.00 ( 0.00%) 92.00 ( -1.10%) Success 3 Mean 92.20 ( 0.00%) 92.80 ( -0.65%) Success 3 Max 94.00 ( 0.00%) 93.00 ( 1.06%) We can see that success rates are unaffected by the skipping. 4.6-rc1 4.6-rc1 before after User 2587.42 2566.53 System 482.89 471.20 Elapsed 1395.68 1382.00 Times are not so useful metric for this benchmark as main portion is the interfering kernel builds, but results do hint at reduced system times. 4.6-rc1 4.6-rc1 before after Direct pages scanned 163614 159608 Kswapd pages scanned 2070139 2078790 Kswapd pages reclaimed 2061707 2069757 Direct pages reclaimed 163354 159505 Reduced direct reclaim was unintended, but could be explained by more successful first attempt at (async) direct compaction, which is attempted before the first reclaim attempt in __alloc_pages_slowpath(). Compaction stalls 33052 39853 Compaction success 12121 19773 Compaction failures 20931 20079 Compaction is indeed more successful, and thus less likely to get deferred, so there are also more direct compaction stalls. Page migrate success 3781876 3326819 Page migrate failure 45817 41774 Compaction pages isolated 7868232 6941457 Compaction migrate scanned 168160492 127269354 Compaction migrate prescanned 0 0 Compaction free scanned 2522142582 2326342620 Compaction free direct alloc 0 0 Compaction free dir. all. miss 0 0 Compaction cost 5252 4476 The patch reduces migration scanned pages by 25% thanks to the eager skipping. [hughd@google.com: prevent nr_isolated_* from going negative] Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Rik van Riel <riel@redhat.com> Cc: David Rientjes <rientjes@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Michal Hocko <mhocko@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-19mm, compaction: reduce spurious pcplist drainsVlastimil Babka
Compaction drains the local pcplists each time migration scanner moves away from a cc->order aligned block where it isolated pages for migration, so that the pages freed by migrations can merge into higher orders. The detection is currently coarser than it could be. The cc->last_migrated_pfn variable should track the lowest pfn that was isolated for migration. But it is set to the pfn where isolate_migratepages_block() starts scanning, which is typically the first pfn of the pageblock. There, the scanner might fail to isolate several order-aligned blocks, and then isolate COMPACT_CLUSTER_MAX in another block. This would cause the pcplists drain to be performed, although the scanner didn't yet finish the block where it isolated from. This patch thus makes cc->last_migrated_pfn handling more accurate by setting it to the pfn of an actually isolated page in isolate_migratepages_block(). Although practical effects of this patch are likely low, it arguably makes the intent of the code more obvious. Also the next patch will make async direct compaction skip blocks more aggressively, and draining pcplists due to skipped blocks is wasteful. Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Rik van Riel <riel@redhat.com> Cc: David Rientjes <rientjes@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Michal Hocko <mhocko@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-19mm, compaction: wrap calculating first and last pfn of pageblockVlastimil Babka
Compaction code has accumulated numerous instances of manual calculations of the first (inclusive) and last (exclusive) pfn of a pageblock (or a smaller block of given order), given a pfn within the pageblock. Wrap these calculations by introducing pageblock_start_pfn(pfn) and pageblock_end_pfn(pfn) macros. [vbabka@suse.cz: fix crash in get_pfnblock_flags_mask() from isolate_freepages():] Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Rik van Riel <riel@redhat.com> Cc: David Rientjes <rientjes@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Michal Hocko <mhocko@suse.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-05mm: fix kcompactd hang during memory offliningVlastimil Babka
Assume memory47 is the last online block left in node1. This will hang: # echo offline > /sys/devices/system/node/node1/memory47/state After a couple of minutes, the following pops up in dmesg: INFO: task bash:957 blocked for more than 120 seconds. Not tainted 4.6.0-rc6+ #6 "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. bash D ffff8800b7adbaf8 0 957 951 0x00000000 Call Trace: schedule+0x35/0x80 schedule_timeout+0x1ac/0x270 wait_for_completion+0xe1/0x120 kthread_stop+0x4f/0x110 kcompactd_stop+0x26/0x40 __offline_pages.constprop.28+0x7e6/0x840 offline_pages+0x11/0x20 memory_block_action+0x73/0x1d0 memory_subsys_offline+0x47/0x60 device_offline+0x86/0xb0 store_mem_state+0xda/0xf0 dev_attr_store+0x18/0x30 sysfs_kf_write+0x37/0x40 kernfs_fop_write+0x11d/0x170 __vfs_write+0x37/0x120 vfs_write+0xa9/0x1a0 SyS_write+0x55/0xc0 entry_SYSCALL_64_fastpath+0x1a/0xa4 kcompactd is waiting for kcompactd_max_order > 0 when it's woken up to actually exit. Check kthread_should_stop() to break out of the wait. Fixes: 698b1b306 ("mm, compaction: introduce kcompactd"). Reported-by: Reza Arbab <arbab@linux.vnet.ibm.com> Tested-by: Reza Arbab <arbab@linux.vnet.ibm.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Rik van Riel <riel@redhat.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: David Rientjes <rientjes@google.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-05mm, cma: prevent nr_isolated_* counters from going negativeHugh Dickins
/proc/sys/vm/stat_refresh warns nr_isolated_anon and nr_isolated_file go increasingly negative under compaction: which would add delay when should be none, or no delay when should delay. The bug in compaction was due to a recent mmotm patch, but much older instance of the bug was also noticed in isolate_migratepages_range() which is used for CMA and gigantic hugepage allocations. The bug is caused by putback_movable_pages() in an error path decrementing the isolated counters without them being previously incremented by acct_isolated(). Fix isolate_migratepages_range() by removing the error-path putback, thus reaching acct_isolated() with migratepages still isolated, and leaving putback to caller like most other places do. Fixes: edc2ca612496 ("mm, compaction: move pageblock checks up from isolate_migratepages_range()") [vbabka@suse.cz: expanded the changelog] Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-17mm, kswapd: replace kswapd compaction with waking up kcompactdVlastimil Babka
Similarly to direct reclaim/compaction, kswapd attempts to combine reclaim and compaction to attempt making memory allocation of given order available. The details differ from direct reclaim e.g. in having high watermark as a goal. The code involved in kswapd's reclaim/compaction decisions has evolved to be quite complex. Testing reveals that it doesn't actually work in at least one scenario, and closer inspection suggests that it could be greatly simplified without compromising on the goal (make high-order page available) or efficiency (don't reclaim too much). The simplification relieas of doing all compaction in kcompactd, which is simply woken up when high watermarks are reached by kswapd's reclaim. The scenario where kswapd compaction doesn't work was found with mmtests test stress-highalloc configured to attempt order-9 allocations without direct reclaim, just waking up kswapd. There was no compaction attempt from kswapd during the whole test. Some added instrumentation shows what happens: - balance_pgdat() sets end_zone to Normal, as it's not balanced - reclaim is attempted on DMA zone, which sets nr_attempted to 99, but it cannot reclaim anything, so sc.nr_reclaimed is 0 - for zones DMA32 and Normal, kswapd_shrink_zone uses testorder=0, so it merely checks if high watermarks were reached for base pages. This is true, so no reclaim is attempted. For DMA, testorder=0 wasn't used, as compaction_suitable() returned COMPACT_SKIPPED - even though the pgdat_needs_compaction flag wasn't set to false, no compaction happens due to the condition sc.nr_reclaimed > nr_attempted being false (as 0 < 99) - priority-- due to nr_reclaimed being 0, repeat until priority reaches 0 pgdat_balanced() is false as only the small zone DMA appears balanced (curiously in that check, watermark appears OK and compaction_suitable() returns COMPACT_PARTIAL, because a lower classzone_idx is used there) Now, even if it was decided that reclaim shouldn't be attempted on the DMA zone, the scenario would be the same, as (sc.nr_reclaimed=0 > nr_attempted=0) is also false. The condition really should use >= as the comment suggests. Then there is a mismatch in the check for setting pgdat_needs_compaction to false using low watermark, while the rest uses high watermark, and who knows what other subtlety. Hopefully this demonstrates that this is unsustainable. Luckily we can simplify this a lot. The reclaim/compaction decisions make sense for direct reclaim scenario, but in kswapd, our primary goal is to reach high watermark in order-0 pages. Afterwards we can attempt compaction just once. Unlike direct reclaim, we don't reclaim extra pages (over the high watermark), the current code already disallows it for good reasons. After this patch, we simply wake up kcompactd to process the pgdat, after we have either succeeded or failed to reach the high watermarks in kswapd, which goes to sleep. We pass kswapd's order and classzone_idx, so kcompactd can apply the same criteria to determine which zones are worth compacting. Note that we use the classzone_idx from wakeup_kswapd(), not balanced_classzone_idx which can include higher zones that kswapd tried to balance too, but didn't consider them in pgdat_balanced(). Since kswapd now cannot create high-order pages itself, we need to adjust how it determines the zones to be balanced. The key element here is adding a "highorder" parameter to zone_balanced, which, when set to false, makes it consider only order-0 watermark instead of the desired higher order (this was done previously by kswapd_shrink_zone(), but not elsewhere). This false is passed for example in pgdat_balanced(). Importantly, wakeup_kswapd() uses true to make sure kswapd and thus kcompactd are woken up for a high-order allocation failure. The last thing is to decide what to do with pageblock_skip bitmap handling. Compaction maintains a pageblock_skip bitmap to record pageblocks where isolation recently failed. This bitmap can be reset by three ways: 1) direct compaction is restarting after going through the full deferred cycle 2) kswapd goes to sleep, and some other direct compaction has previously finished scanning the whole zone and set zone->compact_blockskip_flush. Note that a successful direct compaction clears this flag. 3) compaction was invoked manually via trigger in /proc The case 2) is somewhat fuzzy to begin with, but after introducing kcompactd we should update it. The check for direct compaction in 1), and to set the flush flag in 2) use current_is_kswapd(), which doesn't work for kcompactd. Thus, this patch adds bool direct_compaction to compact_control to use in 2). For the case 1) we remove the check completely - unlike the former kswapd compaction, kcompactd does use the deferred compaction functionality, so flushing tied to restarting from deferred compaction makes sense here. Note that when kswapd goes to sleep, kcompactd is woken up, so it will see the flushed pageblock_skip bits. This is different from when the former kswapd compaction observed the bits and I believe it makes more sense. Kcompactd can afford to be more thorough than a direct compaction trying to limit allocation latency, or kswapd whose primary goal is to reclaim. For testing, I used stress-highalloc configured to do order-9 allocations with GFP_NOWAIT|__GFP_HIGH|__GFP_COMP, so they relied just on kswapd/kcompactd reclaim/compaction (the interfering kernel builds in phases 1 and 2 work as usual): stress-highalloc 4.5-rc1+before 4.5-rc1+after -nodirect -nodirect Success 1 Min 1.00 ( 0.00%) 5.00 (-66.67%) Success 1 Mean 1.40 ( 0.00%) 6.20 (-55.00%) Success 1 Max 2.00 ( 0.00%) 7.00 (-16.67%) Success 2 Min 1.00 ( 0.00%) 5.00 (-66.67%) Success 2 Mean 1.80 ( 0.00%) 6.40 (-52.38%) Success 2 Max 3.00 ( 0.00%) 7.00 (-16.67%) Success 3 Min 34.00 ( 0.00%) 62.00 ( 1.59%) Success 3 Mean 41.80 ( 0.00%) 63.80 ( 1.24%) Success 3 Max 53.00 ( 0.00%) 65.00 ( 2.99%) User 3166.67 3181.09 System 1153.37 1158.25 Elapsed 1768.53 1799.37 4.5-rc1+before 4.5-rc1+after -nodirect -nodirect Direct pages scanned 32938 32797 Kswapd pages scanned 2183166 2202613 Kswapd pages reclaimed 2152359 2143524 Direct pages reclaimed 32735 32545 Percentage direct scans 1% 1% THP fault alloc 579 612 THP collapse alloc 304 316 THP splits 0 0 THP fault fallback 793 778 THP collapse fail 11 16 Compaction stalls 1013 1007 Compaction success 92 67 Compaction failures 920 939 Page migrate success 238457 721374 Page migrate failure 23021 23469 Compaction pages isolated 504695 1479924 Compaction migrate scanned 661390 8812554 Compaction free scanned 13476658 84327916 Compaction cost 262 838 After this patch we see improvements in allocation success rate (especially for phase 3) along with increased compaction activity. The compaction stalls (direct compaction) in the interfering kernel builds (probably THP's) also decreased somewhat thanks to kcompactd activity, yet THP alloc successes improved a bit. Note that elapsed and user time isn't so useful for this benchmark, because of the background interference being unpredictable. It's just to quickly spot some major unexpected differences. System time is somewhat more useful and that didn't increase. Also (after adjusting mmtests' ftrace monitor): Time kswapd awake 2547781 2269241 Time kcompactd awake 0 119253 Time direct compacting 939937 557649 Time kswapd compacting 0 0 Time kcompactd compacting 0 119099 The decrease of overal time spent compacting appears to not match the increased compaction stats. I suspect the tasks get rescheduled and since the ftrace monitor doesn't see that, the reported time is wall time, not CPU time. But arguably direct compactors care about overall latency anyway, whether busy compacting or waiting for CPU doesn't matter. And that latency seems to almost halved. It's also interesting how much time kswapd spent awake just going through all the priorities and failing to even try compacting, over and over. We can also configure stress-highalloc to perform both direct reclaim/compaction and wakeup kswapd/kcompactd, by using GFP_KERNEL|__GFP_HIGH|__GFP_COMP: stress-highalloc 4.5-rc1+before 4.5-rc1+after -direct -direct Success 1 Min 4.00 ( 0.00%) 9.00 (-50.00%) Success 1 Mean 8.00 ( 0.00%) 10.00 (-19.05%) Success 1 Max 12.00 ( 0.00%) 11.00 ( 15.38%) Success 2 Min 4.00 ( 0.00%) 9.00 (-50.00%) Success 2 Mean 8.20 ( 0.00%) 10.00 (-16.28%) Success 2 Max 13.00 ( 0.00%) 11.00 ( 8.33%) Success 3 Min 75.00 ( 0.00%) 74.00 ( 1.33%) Success 3 Mean 75.60 ( 0.00%) 75.20 ( 0.53%) Success 3 Max 77.00 ( 0.00%) 76.00 ( 0.00%) User 3344.73 3246.04 System 1194.24 1172.29 Elapsed 1838.04 1836.76 4.5-rc1+before 4.5-rc1+after -direct -direct Direct pages scanned 125146 120966 Kswapd pages scanned 2119757 2135012 Kswapd pages reclaimed 2073183 2108388 Direct pages reclaimed 124909 120577 Percentage direct scans 5% 5% THP fault alloc 599 652 THP collapse alloc 323 354 THP splits 0 0 THP fault fallback 806 793 THP collapse fail 17 16 Compaction stalls 2457 2025 Compaction success 906 518 Compaction failures 1551 1507 Page migrate success 2031423 2360608 Page migrate failure 32845 40852 Compaction pages isolated 4129761 4802025 Compaction migrate scanned 11996712 21750613 Compaction free scanned 214970969 344372001 Compaction cost 2271 2694 In this scenario, this patch doesn't change the overall success rate as direct compaction already tries all it can. There's however significant reduction in direct compaction stalls (that is, the number of allocations that went into direct compaction). The number of successes (i.e. direct compaction stalls that ended up with successful allocation) is reduced by the same number. This means the offload to kcompactd is working as expected, and direct compaction is reduced either due to detecting contention, or compaction deferred by kcompactd. In the previous version of this patchset there was some apparent reduction of success rate, but the changes in this version (such as using sync compaction only), new baseline kernel, and/or averaging results from 5 executions (my bet), made this go away. Ftrace-based stats seem to roughly agree: Time kswapd awake 2532984 2326824 Time kcompactd awake 0 257916 Time direct compacting 864839 735130 Time kswapd compacting 0 0 Time kcompactd compacting 0 257585 Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Rik van Riel <riel@redhat.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: David Rientjes <rientjes@google.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-17mm, compaction: introduce kcompactdVlastimil Babka
Memory compaction can be currently performed in several contexts: - kswapd balancing a zone after a high-order allocation failure - direct compaction to satisfy a high-order allocation, including THP page fault attemps - khugepaged trying to collapse a hugepage - manually from /proc The purpose of compaction is two-fold. The obvious purpose is to satisfy a (pending or future) high-order allocation, and is easy to evaluate. The other purpose is to keep overal memory fragmentation low and help the anti-fragmentation mechanism. The success wrt the latter purpose is more The current situation wrt the purposes has a few drawbacks: - compaction is invoked only when a high-order page or hugepage is not available (or manually). This might be too late for the purposes of keeping memory fragmentation low. - direct compaction increases latency of allocations. Again, it would be better if compaction was performed asynchronously to keep fragmentation low, before the allocation itself comes. - (a special case of the previous) the cost of compaction during THP page faults can easily offset the benefits of THP. - kswapd compaction appears to be complex, fragile and not working in some scenarios. It could also end up compacting for a high-order allocation request when it should be reclaiming memory for a later order-0 request. To improve the situation, we should be able to benefit from an equivalent of kswapd, but for compaction - i.e. a background thread which responds to fragmentation and the need for high-order allocations (including hugepages) somewhat proactively. One possibility is to extend the responsibilities of kswapd, which could however complicate its design too much. It should be better to let kswapd handle reclaim, as order-0 allocations are often more critical than high-order ones. Another possibility is to extend khugepaged, but this kthread is a single instance and tied to THP configs. This patch goes with the option of a new set of per-node kthreads called kcompactd, and lays the foundations, without introducing any new tunables. The lifecycle mimics kswapd kthreads, including the memory hotplug hooks. For compaction, kcompactd uses the standard compaction_suitable() and ompact_finished() criteria and the deferred compaction functionality. Unlike direct compaction, it uses only sync compaction, as there's no allocation latency to minimize. This patch doesn't yet add a call to wakeup_kcompactd. The kswapd compact/reclaim loop for high-order pages will be replaced by waking up kcompactd in the next patch with the description of what's wrong with the old approach. Waking up of the kcompactd threads is also tied to kswapd activity and follows these rules: - we don't want to affect any fastpaths, so wake up kcompactd only from the slowpath, as it's done for kswapd - if kswapd is doing reclaim, it's more important than compaction, so don't invoke kcompactd until kswapd goes to sleep - the target order used for kswapd is passed to kcompactd Future possible future uses for kcompactd include the ability to wake up kcompactd on demand in special situations, such as when hugepages are not available (currently not done due to __GFP_NO_KSWAPD) or when a fragmentation event (i.e. __rmqueue_fallback()) occurs. It's also possible to perform periodic compaction with kcompactd. [arnd@arndb.de: fix build errors with kcompactd] [paul.gortmaker@windriver.com: don't use modular references for non modular code] Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Rik van Riel <riel@redhat.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: David Rientjes <rientjes@google.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-15mm/compaction: speed up pageblock_pfn_to_page() when zone is contiguousJoonsoo Kim
There is a performance drop report due to hugepage allocation and in there half of cpu time are spent on pageblock_pfn_to_page() in compaction [1]. In that workload, compaction is triggered to make hugepage but most of pageblocks are un-available for compaction due to pageblock type and skip bit so compaction usually fails. Most costly operations in this case is to find valid pageblock while scanning whole zone range. To check if pageblock is valid to compact, valid pfn within pageblock is required and we can obtain it by calling pageblock_pfn_to_page(). This function checks whether pageblock is in a single zone and return valid pfn if possible. Problem is that we need to check it every time before scanning pageblock even if we re-visit it and this turns out to be very expensive in this workload. Although we have no way to skip this pageblock check in the system where hole exists at arbitrary position, we can use cached value for zone continuity and just do pfn_to_page() in the system where hole doesn't exist. This optimization considerably speeds up in above workload. Before vs After Max: 1096 MB/s vs 1325 MB/s Min: 635 MB/s 1015 MB/s Avg: 899 MB/s 1194 MB/s Avg is improved by roughly 30% [2]. [1]: http://www.spinics.net/lists/linux-mm/msg97378.html [2]: https://lkml.org/lkml/2015/12/9/23 [akpm@linux-foundation.org: don't forget to restore zone->contiguous on error path, per Vlastimil] Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Reported-by: Aaron Lu <aaron.lu@intel.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Tested-by: Aaron Lu <aaron.lu@intel.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-15mm/compaction: pass only pageblock aligned range to pageblock_pfn_to_pageJoonsoo Kim
pageblock_pfn_to_page() is used to check there is valid pfn and all pages in the pageblock is in a single zone. If there is a hole in the pageblock, passing arbitrary position to pageblock_pfn_to_page() could cause to skip whole pageblock scanning, instead of just skipping the hole page. For deterministic behaviour, it's better to always pass pageblock aligned range to pageblock_pfn_to_page(). It will also help further optimization on pageblock_pfn_to_page() in the following patch. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Aaron Lu <aaron.lu@intel.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-15mm/compaction: fix invalid free_pfn and compact_cached_free_pfnJoonsoo Kim
free_pfn and compact_cached_free_pfn are the pointer that remember restart position of freepage scanner. When they are reset or invalid, we set them to zone_end_pfn because freepage scanner works in reverse direction. But, because zone range is defined as [zone_start_pfn, zone_end_pfn), zone_end_pfn is invalid to access. Therefore, we should not store it to free_pfn and compact_cached_free_pfn. Instead, we need to store zone_end_pfn - 1 to them. There is one more thing we should consider. Freepage scanner scan reversely by pageblock unit. If free_pfn and compact_cached_free_pfn are set to middle of pageblock, it regards that sitiation as that it already scans front part of pageblock so we lose opportunity to scan there. To fix-up, this patch do round_down() to guarantee that reset position will be pageblock aligned. Note that thanks to the current pageblock_pfn_to_page() implementation, actual access to zone_end_pfn doesn't happen until now. But, following patch will change pageblock_pfn_to_page() so this patch is needed from now on. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: David Rientjes <rientjes@google.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Aaron Lu <aaron.lu@intel.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-14mm/compaction.c: __compact_pgdat() code cleanuupJoonsoo Kim
This patch uses is_via_compact_memory() to distinguish compaction from sysfs or sysctl. And, this patch also reduces indentation on compaction_defer_reset() by filtering these cases first before checking watermark. There is no functional change. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Yaowei Bai <baiyaowei@cmss.chinamobile.com> Acked-by: David Rientjes <rientjes@google.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-14mm/compaction: improve comment for compact_memory tunable knob handlerYaowei Bai
sysctl_compaction_handler() is the handler function for compact_memory tunable knob under /proc/sys/vm, add the missing knob name to make this more accurate in comment. No functional change. Signed-off-by: Yaowei Bai <baiyaowei@cmss.chinamobile.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-05mm, compaction: distinguish contended status in tracepointsVlastimil Babka
Compaction returns prematurely with COMPACT_PARTIAL when contended or has fatal signal pending. This is ok for the callers, but might be misleading in the traces, as the usual reason to return COMPACT_PARTIAL is that we think the allocation should succeed. After this patch we distinguish the premature ending condition in the mm_compaction_finished and mm_compaction_end tracepoints. The contended status covers the following reasons: - lock contention or need_resched() detected in async compaction - fatal signal pending - too many pages isolated in the zone (only for async compaction) Further distinguishing the exact reason seems unnecessary for now. Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Mel Gorman <mgorman@suse.de> Cc: David Rientjes <rientjes@google.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Ingo Molnar <mingo@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
