commit 45f87de57f8fad59302fd263dd81ffa4843b5b24 upstream.
Commit 2457aec63745 ("mm: non-atomically mark page accessed during page
cache allocation where possible") has added a separate parameter for
specifying gfp mask for radix tree allocations.
Not only this is less than optimal from the API point of view because it
is error prone, it is also buggy currently because
grab_cache_page_write_begin is using GFP_KERNEL for radix tree and if
fgp_flags doesn't contain FGP_NOFS (mostly controlled by fs by
AOP_FLAG_NOFS flag) but the mapping_gfp_mask has __GFP_FS cleared then
the radix tree allocation wouldn't obey the restriction and might
recurse into filesystem and cause deadlocks. This is the case for most
filesystems unfortunately because only ext4 and gfs2 are using
AOP_FLAG_NOFS.
Let's simply remove radix_gfp_mask parameter because the allocation
context is same for both page cache and for the radix tree. Just make
sure that the radix tree gets only the sane subset of the mask (e.g. do
not pass __GFP_WRITE).
Long term it is more preferable to convert remaining users of
AOP_FLAG_NOFS to use mapping_gfp_mask instead and simplify this
interface even further.
Reported-by: Dave Chinner <david@fromorbit.com>
Signed-off-by: Paul McQuade <paulmcquad@gmail.com>
Pull NFS client updates from Trond Myklebust:
"Highlights include:
Stable fixes:
- fix an NFSv4.1 state renewal regression
- fix open/lock state recovery error handling
- fix lock recovery when CREATE_SESSION/SETCLIENTID_CONFIRM fails
- fix statd when reconnection fails
- don't wake tasks during connection abort
- don't start reboot recovery if lease check fails
- fix duplicate proc entries
Features:
- pNFS block driver fixes and clean ups from Christoph
- More code cleanups from Anna
- Improve mmap() writeback performance
- Replace use of PF_TRANS with a more generic mechanism for avoiding
deadlocks in nfs_release_page"
* tag 'nfs-for-3.18-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (66 commits)
NFSv4.1: Fix an NFSv4.1 state renewal regression
NFSv4: fix open/lock state recovery error handling
NFSv4: Fix lock recovery when CREATE_SESSION/SETCLIENTID_CONFIRM fails
NFS: Fabricate fscache server index key correctly
SUNRPC: Add missing support for RPC_CLNT_CREATE_NO_RETRANS_TIMEOUT
NFSv3: Fix missing includes of nfs3_fs.h
NFS/SUNRPC: Remove other deadlock-avoidance mechanisms in nfs_release_page()
NFS: avoid waiting at all in nfs_release_page when congested.
NFS: avoid deadlocks with loop-back mounted NFS filesystems.
MM: export page_wakeup functions
SCHED: add some "wait..on_bit...timeout()" interfaces.
NFS: don't use STABLE writes during writeback.
NFSv4: use exponential retry on NFS4ERR_DELAY for async requests.
rpc: Add -EPERM processing for xs_udp_send_request()
rpc: return sent and err from xs_sendpages()
lockd: Try to reconnect if statd has moved
SUNRPC: Don't wake tasks during connection abort
Fixing lease renewal
nfs: fix duplicate proc entries
pnfs/blocklayout: Fix a 64-bit division/remainder issue in bl_map_stripe
Pull "trivial tree" updates from Jiri Kosina:
"Usual pile from trivial tree everyone is so eagerly waiting for"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Remove MN10300_PROC_MN2WS0038
mei: fix comments
treewide: Fix typos in Kconfig
kprobes: update jprobe_example.c for do_fork() change
Documentation: change "&" to "and" in Documentation/applying-patches.txt
Documentation: remove obsolete pcmcia-cs from Changes
Documentation: update links in Changes
Documentation: Docbook: Fix generated DocBook/kernel-api.xml
score: Remove GENERIC_HAS_IOMAP
gpio: fix 'CONFIG_GPIO_IRQCHIP' comments
tty: doc: Fix grammar in serial/tty
dma-debug: modify check_for_stack output
treewide: fix errors in printk
genirq: fix reference in devm_request_threaded_irq comment
treewide: fix synchronize_rcu() in comments
checkstack.pl: port to AArch64
doc: queue-sysfs: minor fixes
init/do_mounts: better syntax description
MIPS: fix comment spelling
powerpc/simpleboot: fix comment
This will allow NFS to wait for PG_private to be cleared and,
particularly, to send a wake-up when it is.
Signed-off-by: NeilBrown <neilb@suse.de>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
In commit c1221321b7c25b53204447cff9949a6d5a7ddddc
sched: Allow wait_on_bit_action() functions to support a timeout
I suggested that a "wait_on_bit_timeout()" interface would not meet my
need. This isn't true - I was just over-engineering.
Including a 'private' field in wait_bit_key instead of a focused
"timeout" field was just premature generalization. If some other
use is ever found, it can be generalized or added later.
So this patch renames "private" to "timeout" with a meaning "stop
waiting when "jiffies" reaches or passes "timeout",
and adds two of the many possible wait..bit..timeout() interfaces:
wait_on_page_bit_killable_timeout(), which is the one I want to use,
and out_of_line_wait_on_bit_timeout() which is a reasonably general
example. Others can be added as needed.
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Acked-by: Ingo Molnar <mingo@kernel.org>
This patch fix spelling typo found in DocBook/kernel-api.xml.
It is because the file is generated from the source comments,
I have to fix the comments in source codes.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
Pull vfs updates from Al Viro:
"Stuff in here:
- acct.c fixes and general rework of mnt_pin mechanism. That allows
to go for delayed-mntput stuff, which will permit mntput() on deep
stack without worrying about stack overflows - fs shutdown will
happen on shallow stack. IOW, we can do Eric's umount-on-rmdir
series without introducing tons of stack overflows on new mntput()
call chains it introduces.
- Bruce's d_splice_alias() patches
- more Miklos' rename() stuff.
- a couple of regression fixes (stable fodder, in the end of branch)
and a fix for API idiocy in iov_iter.c.
There definitely will be another pile, maybe even two. I'd like to
get Eric's series in this time, but even if we miss it, it'll go right
in the beginning of for-next in the next cycle - the tricky part of
prereqs is in this pile"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (40 commits)
fix copy_tree() regression
__generic_file_write_iter(): fix handling of sync error after DIO
switch iov_iter_get_pages() to passing maximal number of pages
fs: mark __d_obtain_alias static
dcache: d_splice_alias should detect loops
exportfs: update Exporting documentation
dcache: d_find_alias needn't recheck IS_ROOT && DCACHE_DISCONNECTED
dcache: remove unused d_find_alias parameter
dcache: d_obtain_alias callers don't all want DISCONNECTED
dcache: d_splice_alias should ignore DCACHE_DISCONNECTED
dcache: d_splice_alias mustn't create directory aliases
dcache: close d_move race in d_splice_alias
dcache: move d_splice_alias
namei: trivial fix to vfs_rename_dir comment
VFS: allow ->d_manage() to declare -EISDIR in rcu_walk mode.
cifs: support RENAME_NOREPLACE
hostfs: support rename flags
shmem: support RENAME_EXCHANGE
shmem: support RENAME_NOREPLACE
btrfs: add RENAME_NOREPLACE
If DIO results in short write and sync write fails, we want to bugger off
whether the DIO part has written anything or not; the logics on the return
will take care of the right return value.
Cc: stable@vger.kernel.org [3.16]
Reported-by: Anton Altaparmakov <aia21@cam.ac.uk>
The memcg uncharging code that is involved towards the end of a page's
lifetime - truncation, reclaim, swapout, migration - is impressively
complicated and fragile.
Because anonymous and file pages were always charged before they had their
page->mapping established, uncharges had to happen when the page type
could still be known from the context; as in unmap for anonymous, page
cache removal for file and shmem pages, and swap cache truncation for swap
pages. However, these operations happen well before the page is actually
freed, and so a lot of synchronization is necessary:
- Charging, uncharging, page migration, and charge migration all need
to take a per-page bit spinlock as they could race with uncharging.
- Swap cache truncation happens during both swap-in and swap-out, and
possibly repeatedly before the page is actually freed. This means
that the memcg swapout code is called from many contexts that make
no sense and it has to figure out the direction from page state to
make sure memory and memory+swap are always correctly charged.
- On page migration, the old page might be unmapped but then reused,
so memcg code has to prevent untimely uncharging in that case.
Because this code - which should be a simple charge transfer - is so
special-cased, it is not reusable for replace_page_cache().
But now that charged pages always have a page->mapping, introduce
mem_cgroup_uncharge(), which is called after the final put_page(), when we
know for sure that nobody is looking at the page anymore.
For page migration, introduce mem_cgroup_migrate(), which is called after
the migration is successful and the new page is fully rmapped. Because
the old page is no longer uncharged after migration, prevent double
charges by decoupling the page's memcg association (PCG_USED and
pc->mem_cgroup) from the page holding an actual charge. The new bits
PCG_MEM and PCG_MEMSW represent the respective charges and are transferred
to the new page during migration.
mem_cgroup_migrate() is suitable for replace_page_cache() as well,
which gets rid of mem_cgroup_replace_page_cache(). However, care
needs to be taken because both the source and the target page can
already be charged and on the LRU when fuse is splicing: grab the page
lock on the charge moving side to prevent changing pc->mem_cgroup of a
page under migration. Also, the lruvecs of both pages change as we
uncharge the old and charge the new during migration, and putback may
race with us, so grab the lru lock and isolate the pages iff on LRU to
prevent races and ensure the pages are on the right lruvec afterward.
Swap accounting is massively simplified: because the page is no longer
uncharged as early as swap cache deletion, a new mem_cgroup_swapout() can
transfer the page's memory+swap charge (PCG_MEMSW) to the swap entry
before the final put_page() in page reclaim.
Finally, page_cgroup changes are now protected by whatever protection the
page itself offers: anonymous pages are charged under the page table lock,
whereas page cache insertions, swapin, and migration hold the page lock.
Uncharging happens under full exclusion with no outstanding references.
Charging and uncharging also ensure that the page is off-LRU, which
serializes against charge migration. Remove the very costly page_cgroup
lock and set pc->flags non-atomically.
[mhocko@suse.cz: mem_cgroup_charge_statistics needs preempt_disable]
[vdavydov@parallels.com: fix flags definition]
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Cc: Tejun Heo <tj@kernel.org>
Cc: Vladimir Davydov <vdavydov@parallels.com>
Tested-by: Jet Chen <jet.chen@intel.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
Tested-by: Felipe Balbi <balbi@ti.com>
Signed-off-by: Vladimir Davydov <vdavydov@parallels.com>
These patches rework memcg charge lifetime to integrate more naturally
with the lifetime of user pages. This drastically simplifies the code and
reduces charging and uncharging overhead. The most expensive part of
charging and uncharging is the page_cgroup bit spinlock, which is removed
entirely after this series.
Here are the top-10 profile entries of a stress test that reads a 128G
sparse file on a freshly booted box, without even a dedicated cgroup (i.e.
executing in the root memcg). Before:
15.36% cat [kernel.kallsyms] [k] copy_user_generic_string
13.31% cat [kernel.kallsyms] [k] memset
11.48% cat [kernel.kallsyms] [k] do_mpage_readpage
4.23% cat [kernel.kallsyms] [k] get_page_from_freelist
2.38% cat [kernel.kallsyms] [k] put_page
2.32% cat [kernel.kallsyms] [k] __mem_cgroup_commit_charge
2.18% kswapd0 [kernel.kallsyms] [k] __mem_cgroup_uncharge_common
1.92% kswapd0 [kernel.kallsyms] [k] shrink_page_list
1.86% cat [kernel.kallsyms] [k] __radix_tree_lookup
1.62% cat [kernel.kallsyms] [k] __pagevec_lru_add_fn
After:
15.67% cat [kernel.kallsyms] [k] copy_user_generic_string
13.48% cat [kernel.kallsyms] [k] memset
11.42% cat [kernel.kallsyms] [k] do_mpage_readpage
3.98% cat [kernel.kallsyms] [k] get_page_from_freelist
2.46% cat [kernel.kallsyms] [k] put_page
2.13% kswapd0 [kernel.kallsyms] [k] shrink_page_list
1.88% cat [kernel.kallsyms] [k] __radix_tree_lookup
1.67% cat [kernel.kallsyms] [k] __pagevec_lru_add_fn
1.39% kswapd0 [kernel.kallsyms] [k] free_pcppages_bulk
1.30% cat [kernel.kallsyms] [k] kfree
As you can see, the memcg footprint has shrunk quite a bit.
37970 9892 400 48262 bc86 mm/memcontrol.o.old
35239 9892 400 45531 b1db mm/memcontrol.o
This patch (of 4):
The memcg charge API charges pages before they are rmapped - i.e. have an
actual "type" - and so every callsite needs its own set of charge and
uncharge functions to know what type is being operated on. Worse,
uncharge has to happen from a context that is still type-specific, rather
than at the end of the page's lifetime with exclusive access, and so
requires a lot of synchronization.
Rewrite the charge API to provide a generic set of try_charge(),
commit_charge() and cancel_charge() transaction operations, much like
what's currently done for swap-in:
mem_cgroup_try_charge() attempts to reserve a charge, reclaiming
pages from the memcg if necessary.
mem_cgroup_commit_charge() commits the page to the charge once it
has a valid page->mapping and PageAnon() reliably tells the type.
mem_cgroup_cancel_charge() aborts the transaction.
This reduces the charge API and enables subsequent patches to
drastically simplify uncharging.
As pages need to be committed after rmap is established but before they
are added to the LRU, page_add_new_anon_rmap() must stop doing LRU
additions again. Revive lru_cache_add_active_or_unevictable().
[hughd@google.com: fix shmem_unuse]
[hughd@google.com: Add comments on the private use of -EAGAIN]
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Add a comment describing the circumstances in which
__lock_page_or_retry() will or will not release the mmap_sem when
returning 0.
Add comments to lock_page_or_retry()'s callers (filemap_fault(),
do_swap_page()) noting the impact on VM_FAULT_RETRY returns.
Add comments on up the call tree, particularly replacing the false "We
return with mmap_sem still held" comments.
Signed-off-by: Paul Cassella <cassella@cray.com>
Do we really need an exported alias for __SetPageReferenced()? Its
callers better know what they're doing, in which case the page would not
be already marked referenced. Kill init_page_accessed(), just
__SetPageReferenced() inline.
Cc: Prabhakar Lad <prabhakar.csengg@gmail.com>
Pull scheduler updates from Ingo Molnar:
- Move the nohz kick code out of the scheduler tick to a dedicated IPI,
from Frederic Weisbecker.
This necessiated quite some background infrastructure rework,
including:
* Clean up some irq-work internals
* Implement remote irq-work
* Implement nohz kick on top of remote irq-work
* Move full dynticks timer enqueue notification to new kick
* Move multi-task notification to new kick
* Remove unecessary barriers on multi-task notification
- Remove proliferation of wait_on_bit() action functions and allow
wait_on_bit_action() functions to support a timeout. (Neil Brown)
- Another round of sched/numa improvements, cleanups and fixes. (Rik
van Riel)
- Implement fast idling of CPUs when the system is partially loaded,
for better scalability. (Tim Chen)
- Restructure and fix the CPU hotplug handling code that may leave
cfs_rq and rt_rq's throttled when tasks are migrated away from a dead
cpu. (Kirill Tkhai)
- Robustify the sched topology setup code. (Peterz Zijlstra)
- Improve sched_feat() handling wrt. static_keys (Jason Baron)
- Misc fixes.
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (37 commits)
sched/fair: Fix 'make xmldocs' warning caused by missing description
sched: Use macro for magic number of -1 for setparam
sched: Robustify topology setup
sched: Fix sched_setparam() policy == -1 logic
sched: Remove proliferation of wait_on_bit() action functions
sched/numa: Revert "Use effective_load() to balance NUMA loads"
sched: Fix static_key race with sched_feat()
sched: Remove extra static_key*() function indirection
sched/rt: Fix replenish_dl_entity() comments to match the current upstream code
sched: Transform resched_task() into resched_curr()
sched/deadline: Kill task_struct->pi_top_task
sched: Rework check_for_tasks()
sched/rt: Enqueue just unthrottled rt_rq back on the stack in __disable_runtime()
sched/fair: Disable runtime_enabled on dying rq
sched/numa: Change scan period code to match intent
sched/numa: Rework best node setting in task_numa_migrate()
sched/numa: Examine a task move when examining a task swap
sched/numa: Simplify task_numa_compare()
sched/numa: Use effective_load() to balance NUMA loads
Fix kernel-doc warnings in mm/filemap.c: pagecache_get_page():
Warning(..//mm/filemap.c:1054): No description found for parameter 'cache_gfp_mask'
Warning(..//mm/filemap.c:1054): No description found for parameter 'radix_gfp_mask'
Warning(..//mm/filemap.c:1054): Excess function parameter 'gfp_mask' description in 'pagecache_get_page'
Fixes: 2457aec63745 ("mm: non-atomically mark page accessed during page cache allocation where possible")
[mgorman@suse.de: change everything]
The current "wait_on_bit" interface requires an 'action'
function to be provided which does the actual waiting.
There are over 20 such functions, many of them identical.
Most cases can be satisfied by one of just two functions, one
which uses io_schedule() and one which just uses schedule().
So:
Rename wait_on_bit and wait_on_bit_lock to
wait_on_bit_action and wait_on_bit_lock_action
to make it explicit that they need an action function.
Introduce new wait_on_bit{,_lock} and wait_on_bit{,_lock}_io
which are *not* given an action function but implicitly use
a standard one.
The decision to error-out if a signal is pending is now made
based on the 'mode' argument rather than being encoded in the action
function.
All instances of the old wait_on_bit and wait_on_bit_lock which
can use the new version have been changed accordingly and their
action functions have been discarded.
wait_on_bit{_lock} does not return any specific error code in the
event of a signal so the caller must check for non-zero and
interpolate their own error code as appropriate.
The wait_on_bit() call in __fscache_wait_on_invalidate() was
ambiguous as it specified TASK_UNINTERRUPTIBLE but used
fscache_wait_bit_interruptible as an action function.
David Howells confirms this should be uniformly
"uninterruptible"
The main remaining user of wait_on_bit{,_lock}_action is NFS
which needs to use a freezer-aware schedule() call.
A comment in fs/gfs2/glock.c notes that having multiple 'action'
functions is useful as they display differently in the 'wchan'
field of 'ps'. (and /proc/$PID/wchan).
As the new bit_wait{,_io} functions are tagged "__sched", they
will not show up at all, but something higher in the stack. So
the distinction will still be visible, only with different
function names (gds2_glock_wait versus gfs2_glock_dq_wait in the
gfs2/glock.c case).
Since first version of this patch (against 3.15) two new action
functions appeared, on in NFS and one in CIFS. CIFS also now
uses an action function that makes the same freezer aware
schedule call as NFS.
Acked-by: David Howells <dhowells@redhat.com> (fscache, keys)
Acked-by: Steven Whitehouse <swhiteho@redhat.com> (gfs2)
Acked-by: Peter Zijlstra <peterz@infradead.org>
Cc: Steve French <sfrench@samba.org>
Link: http://lkml.kernel.org/r/20140707051603.28027.72349.stgit@notabene.brown
"This the bunch that sat in -next + lock_parent() fix. This is the
minimal set; there's more pending stuff.
In particular, I really hope to get acct.c fixes merged this cycle -
we need that to deal sanely with delayed-mntput stuff. In the next
pile, hopefully - that series is fairly short and localized
(kernel/acct.c, fs/super.c and fs/namespace.c). In this pile: more
iov_iter work. Most of prereqs for ->splice_write with sane locking
order are there and Kent's dio rewrite would also fit nicely on top of
this pile"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (70 commits)
lock_parent: don't step on stale ->d_parent of all-but-freed one
kill generic_file_splice_write()
ceph: switch to iter_file_splice_write()
shmem: switch to iter_file_splice_write()
nfs: switch to iter_splice_write_file()
fs/splice.c: remove unneeded exports
ocfs2: switch to iter_file_splice_write()
->splice_write() via ->write_iter()
bio_vec-backed iov_iter
optimize copy_page_{to,from}_iter()
bury generic_file_aio_{read,write}
lustre: get rid of messing with iovecs
ceph: switch to ->write_iter()
ceph_sync_direct_write: stop poking into iov_iter guts
ceph_sync_read: stop poking into iov_iter guts
new helper: copy_page_from_iter()
fuse: switch to ->write_iter()
btrfs: switch to ->write_iter()
ocfs2: switch to ->write_iter()
xfs: switch to ->write_iter()
Backmerge of dcache.c changes from mainline. It's that, or complete
rebase...
fs/splice.c
If a page is marked for immediate reclaim then it is moved to the tail of
the LRU list. This occurs when the system is under enough memory pressure
for pages under writeback to reach the end of the LRU but we test for this
using atomic operations on every writeback. This patch uses an optimistic
non-atomic test first. It'll miss some pages in rare cases but the
consequences are not severe enough to warrant such a penalty.
While the function does not dominate profiles during a simple dd test the
cost of it is reduced.
73048 0.7428 vmlinux-3.15.0-rc5-mmotm-20140513 end_page_writeback
23740 0.2409 vmlinux-3.15.0-rc5-lessatomic end_page_writeback
possible
aops->write_begin may allocate a new page and make it visible only to have
mark_page_accessed called almost immediately after. Once the page is
visible the atomic operations are necessary which is noticable overhead
when writing to an in-memory filesystem like tmpfs but should also be
noticable with fast storage. The objective of the patch is to initialse
the accessed information with non-atomic operations before the page is
visible.
The bulk of filesystems directly or indirectly use
grab_cache_page_write_begin or find_or_create_page for the initial
allocation of a page cache page. This patch adds an init_page_accessed()
helper which behaves like the first call to mark_page_accessed() but may
called before the page is visible and can be done non-atomically.
The primary APIs of concern in this care are the following and are used
by most filesystems.
find_get_page
find_lock_page
find_or_create_page
grab_cache_page_nowait
All of them are very similar in detail to the patch creates a core helper
pagecache_get_page() which takes a flags parameter that affects its
behavior such as whether the page should be marked accessed or not. Then
old API is preserved but is basically a thin wrapper around this core
function.
Each of the filesystems are then updated to avoid calling
mark_page_accessed when it is known that the VM interfaces have already
done the job. There is a slight snag in that the timing of the
mark_page_accessed() has now changed so in rare cases it's possible a page
gets to the end of the LRU as PageReferenced where as previously it might
have been repromoted. This is expected to be rare but it's worth the
filesystem people thinking about it in case they see a problem with the
timing change. It is also the case that some filesystems may be marking
pages accessed that previously did not but it makes sense that filesystems
have consistent behaviour in this regard.
The test case used to evaulate this is a simple dd of a large file done
multiple times with the file deleted on each iterations. The size of the
file is 1/10th physical memory to avoid dirty page balancing. In the
async case it will be possible that the workload completes without even
hitting the disk and will have variable results but highlight the impact
of mark_page_accessed for async IO. The sync results are expected to be
more stable. The exception is tmpfs where the normal case is for the "IO"
to not hit the disk.
The test machine was single socket and UMA to avoid any scheduling or NUMA
artifacts. Throughput and wall times are presented for sync IO, only wall
times are shown for async as the granularity reported by dd and the
variability is unsuitable for comparison. As async results were variable
do to writback timings, I'm only reporting the maximum figures. The sync
results were stable enough to make the mean and stddev uninteresting.
The performance results are reported based on a run with no profiling.
Profile data is based on a separate run with oprofile running.
async dd
3.15.0-rc3 3.15.0-rc3
vanilla accessed-v2
ext3 Max elapsed 13.9900 ( 0.00%) 11.5900 ( 17.16%)
tmpfs Max elapsed 0.5100 ( 0.00%) 0.4900 ( 3.92%)
btrfs Max elapsed 12.8100 ( 0.00%) 12.7800 ( 0.23%)
ext4 Max elapsed 18.6000 ( 0.00%) 13.3400 ( 28.28%)
xfs Max elapsed 12.5600 ( 0.00%) 2.0900 ( 83.36%)
The XFS figure is a bit strange as it managed to avoid a worst case by
sheer luck but the average figures looked reasonable.
samples percentage
ext3 86107 0.9783 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
ext3 23833 0.2710 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
ext3 5036 0.0573 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
ext4 64566 0.8961 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
ext4 5322 0.0713 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
ext4 2869 0.0384 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
xfs 62126 1.7675 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
xfs 1904 0.0554 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
xfs 103 0.0030 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
btrfs 10655 0.1338 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
btrfs 2020 0.0273 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
btrfs 587 0.0079 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
tmpfs 59562 3.2628 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
tmpfs 1210 0.0696 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
tmpfs 94 0.0054 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
[akpm@linux-foundation.org: don't run init_page_accessed() against an uninitialised pointer]
Cc: Jan Kara <jack@suse.cz>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Tested-by: Prabhakar Lad <prabhakar.csengg@gmail.com>
page_endio() takes care of updating all the appropriate page flags once
I/O has finished to a page. Switch to using mapping_set_error() instead
of setting AS_EIO directly; this will handle thin-provisioned devices
correctly.
Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com>
Cc: Dheeraj Reddy <dheeraj.reddy@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next
Pull core locking updates from Ingo Molnar:
"The main changes in this cycle were:
- reduced/streamlined smp_mb__*() interface that allows more usecases
and makes the existing ones less buggy, especially in rarer
architectures
- add rwsem implementation comments
- bump up lockdep limits"
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (33 commits)
rwsem: Add comments to explain the meaning of the rwsem's count field
lockdep: Increase static allocations
arch: Mass conversion of smp_mb__*()
arch,doc: Convert smp_mb__*()
arch,xtensa: Convert smp_mb__*()
arch,x86: Convert smp_mb__*()
arch,tile: Convert smp_mb__*()
arch,sparc: Convert smp_mb__*()
arch,sh: Convert smp_mb__*()
arch,score: Convert smp_mb__*()
arch,s390: Convert smp_mb__*()
arch,powerpc: Convert smp_mb__*()
arch,parisc: Convert smp_mb__*()
arch,openrisc: Convert smp_mb__*()
arch,mn10300: Convert smp_mb__*()
arch,mips: Convert smp_mb__*()
arch,metag: Convert smp_mb__*()
arch,m68k: Convert smp_mb__*()
arch,m32r: Convert smp_mb__*()
arch,ia64: Convert smp_mb__*()
In some testing I ran today (some fio jobs that spread over two nodes),
we end up spending 40% of the time in filemap_check_errors(). That
smells fishy. Looking further, this is basically what happens:
blkdev_aio_read()
generic_file_aio_read()
filemap_write_and_wait_range()
if (!mapping->nr_pages)
and filemap_check_errors() always attempts two test_and_clear_bit() on
the mapping flags, thus dirtying it for every single invocation. The
patch below tests each of these bits before clearing them, avoiding this
issue. In my test case (4-socket box), performance went from 1.7M IOPS
to 4.0M IOPS.
Signed-off-by: Jens Axboe <axboe@fb.com>
Acked-by: Jeff Moyer <jmoyer@redhat.com>
no callers left
all users converted to __generic_file_write_iter() now
Now It Can Be Done(tm) - we don't need to do iov_shorten() in
generic_file_direct_write() anymore, now that all ->direct_IO()
instances are converted to proper iov_iter methods and honour
iter->count and iter->iov_offset properly.
Get rid of count/ocount arguments of generic_file_direct_write(),
while we are at it.
For now, just use the same thing we pass to ->direct_IO() - it's all
iovec-based at the moment. Pass it explicitly to iov_iter_init() and
account for kvec vs. iovec in there, by the same kludge NFS ->direct_IO()
uses.
iov_iter-using variant of generic_file_aio_read(). Some callers
converted. Note that it's still not quite there for use as ->read_iter() -
we depend on having zero iter->iov_offset in O_DIRECT case. Fortunately,
that's true for all converted callers (and for generic_file_aio_read() itself).
the thing is, we want to advance what's given to ->direct_IO() as we
are forming the request; however, the callers care about the amount
of data actually transferred, not the amount we tried to transfer.
It's more convenient to allow ->direct_IO() instances do use
iov_iter_advance() on the copy of iov_iter, leaving the actual
advancing of the original to caller.
all callers have iov_length(iter->iov, iter->nr_segs) == iov_iter_count(iter)
unmodified, for now
all callers of ->aio_read() and ->aio_write() have iov/nr_segs already
checked - generic_segment_checks() done after that is just an odd way
to spell iov_length().
Dave Jones reports the following crash when find_get_pages_tag() runs
into an exceptional entry:
kernel BUG at mm/filemap.c:1347!
RIP: find_get_pages_tag+0x1cb/0x220
Call Trace:
find_get_pages_tag+0x36/0x220
pagevec_lookup_tag+0x21/0x30
filemap_fdatawait_range+0xbe/0x1e0
filemap_fdatawait+0x27/0x30
sync_inodes_sb+0x204/0x2a0
sync_inodes_one_sb+0x19/0x20
iterate_supers+0xb2/0x110
sys_sync+0x44/0xb0
ia32_do_call+0x13/0x13
1343 /*
1344 * This function is never used on a shmem/tmpfs
1345 * mapping, so a swap entry won't be found here.
1346 */
1347 BUG();
After commit 0cd6144aadd2 ("mm + fs: prepare for non-page entries in
page cache radix trees") this comment and BUG() are out of date because
exceptional entries can now appear in all mappings - as shadows of
recently evicted pages.
However, as Hugh Dickins notes,
"it is truly surprising for a PAGECACHE_TAG_WRITEBACK (and probably
any other PAGECACHE_TAG_*) to appear on an exceptional entry.
I expect it comes down to an occasional race in RCU lookup of the
radix_tree: lacking absolute synchronization, we might sometimes
catch an exceptional entry, with the tag which really belongs with
the unexceptional entry which was there an instant before."
And indeed, not only is the tree walk lockless, the tags are also read
in chunks, one radix tree node at a time. There is plenty of time for
page reclaim to swoop in and replace a page that was already looked up
as tagged with a shadow entry.
Remove the BUG() and update the comment. While reviewing all other
lookup sites for whether they properly deal with shadow entries of
evicted pages, update all the comments and fix memcg file charge moving
to not miss shmem/tmpfs swapcache pages.
Fixes: 0cd6144aadd2 ("mm + fs: prepare for non-page entries in page cache radix trees")
Reported-by: Dave Jones <davej@redhat.com>
Fix new kernel-doc warning in mm/filemap.c:
Warning(mm/filemap.c:2600): Excess function parameter 'ppos' description in '__generic_file_aio_write'
Mostly scripted conversion of the smp_mb__* barriers.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/n/tip-55dhyhocezdw1dg7u19hmh1u@git.kernel.org
"The first vfs pile, with deep apologies for being very late in this
window.
Assorted cleanups and fixes, plus a large preparatory part of iov_iter
work. There's a lot more of that, but it'll probably go into the next
merge window - it *does* shape up nicely, removes a lot of
boilerplate, gets rid of locking inconsistencie between aio_write and
splice_write and I hope to get Kent's direct-io rewrite merged into
the same queue, but some of the stuff after this point is having
(mostly trivial) conflicts with the things already merged into
mainline and with some I want more testing.
This one passes LTP and xfstests without regressions, in addition to
usual beating. BTW, readahead02 in ltp syscalls testsuite has started
giving failures since "mm/readahead.c: fix readahead failure for
memoryless NUMA nodes and limit readahead pages" - might be a false
positive, might be a real regression..."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
missing bits of "splice: fix racy pipe->buffers uses"
cifs: fix the race in cifs_writev()
ceph_sync_{,direct_}write: fix an oops on ceph_osdc_new_request() failure
kill generic_file_buffered_write()
ocfs2_file_aio_write(): switch to generic_perform_write()
ceph_aio_write(): switch to generic_perform_write()
xfs_file_buffered_aio_write(): switch to generic_perform_write()
export generic_perform_write(), start getting rid of generic_file_buffer_write()
generic_file_direct_write(): get rid of ppos argument
btrfs_file_aio_write(): get rid of ppos
kill the 5th argument of generic_file_buffered_write()
kill the 4th argument of __generic_file_aio_write()
lustre: don't open-code kernel_recvmsg()
ocfs2: don't open-code kernel_recvmsg()
drbd: don't open-code kernel_recvmsg()
constify blk_rq_map_user_iov() and friends
lustre: switch to kernel_sendmsg()
ocfs2: don't open-code kernel_sendmsg()
take iov_iter stuff to mm/iov_iter.c
process_vm_access: tidy up a bit
mem_cgroup_newpage_charge is used only for charging anonymous memory so
it is better to rename it to mem_cgroup_charge_anon.
mem_cgroup_cache_charge is used for file backed memory so rename it to
mem_cgroup_charge_file.
Minor cleanups:
- 'size' variable is now in bytes, not pages;
- use round_up(): it should be easier to read.
Cc: Matthew Wilcox <matthew.r.wilcox@intel.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Ning Qu <quning@gmail.com>
filemap_map_pages() is generic implementation of ->map_pages() for
filesystems who uses page cache.
It should be safe to use filemap_map_pages() for ->map_pages() if
filesystem use filemap_fault() for ->fault().
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
This patch removes read_cache_page_async() which wasn't really needed
anywhere and simplifies the code around it a bit.
read_cache_page_async() is useful when we want to read a page into the
cache without waiting for it to complete. This happens when the
appropriate callback 'filler' doesn't complete its read operation and
releases the page lock immediately, and instead queues a different
completion routine to do that. This never actually happened anywhere in
the code.
read_cache_page_async() had 3 different callers:
- read_cache_page() which is the sync version, it would just wait for
the requested read to complete using wait_on_page_read().
- JFFS2 would call it from jffs2_gc_fetch_page(), but the filler
function it supplied doesn't do any async reads, and would complete
before the filler function returns - making it actually a sync read.
- CRAMFS would call it using the read_mapping_page_async() wrapper, with
a similar story to JFFS2 - the filler function doesn't do anything that
reminds async reads and would always complete before the filler function
returns.
To sum it up, the code in mm/filemap.c never took advantage of having
read_cache_page_async(). While there are filler callbacks that do async
reads (such as the block one), we always called it with the
read_cache_page().
This patch adds a mandatory wait for read to complete when adding a new
page to the cache, and removes read_cache_page_async() and its wrappers.
Previously, page cache radix tree nodes were freed after reclaim emptied
out their page pointers. But now reclaim stores shadow entries in their
place, which are only reclaimed when the inodes themselves are
reclaimed. This is problematic for bigger files that are still in use
after they have a significant amount of their cache reclaimed, without
any of those pages actually refaulting. The shadow entries will just
sit there and waste memory. In the worst case, the shadow entries will
accumulate until the machine runs out of memory.
To get this under control, the VM will track radix tree nodes
exclusively containing shadow entries on a per-NUMA node list. Per-NUMA
rather than global because we expect the radix tree nodes themselves to
be allocated node-locally and we want to reduce cross-node references of
otherwise independent cache workloads. A simple shrinker will then
reclaim these nodes on memory pressure.
A few things need to be stored in the radix tree node to implement the
shadow node LRU and allow tree deletions coming from the list:
1. There is no index available that would describe the reverse path
from the node up to the tree root, which is needed to perform a
deletion. To solve this, encode in each node its offset inside the
parent. This can be stored in the unused upper bits of the same
member that stores the node's height at no extra space cost.
2. The number of shadow entries needs to be counted in addition to the
regular entries, to quickly detect when the node is ready to go to
the shadow node LRU list. The current entry count is an unsigned
int but the maximum number of entries is 64, so a shadow counter
can easily be stored in the unused upper bits.
3. Tree modification needs tree lock and tree root, which are located
in the address space, so store an address_space backpointer in the
node. The parent pointer of the node is in a union with the 2-word
rcu_head, so the backpointer comes at no extra cost as well.
4. The node needs to be linked to an LRU list, which requires a list
head inside the node. This does increase the size of the node, but
it does not change the number of objects that fit into a slab page.
[akpm@linux-foundation.org: export the right function]
Reviewed-by: Minchan Kim <minchan@kernel.org>
Cc: Bob Liu <bob.liu@oracle.com>
Cc: Luigi Semenzato <semenzato@google.com>
Cc: Metin Doslu <metin@citusdata.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Ozgun Erdogan <ozgun@citusdata.com>
Cc: Roman Gushchin <klamm@yandex-team.ru>
Cc: Ryan Mallon <rmallon@gmail.com>
The VM maintains cached filesystem pages on two types of lists. One
list holds the pages recently faulted into the cache, the other list
holds pages that have been referenced repeatedly on that first list.
The idea is to prefer reclaiming young pages over those that have shown
to benefit from caching in the past. We call the recently usedbut
ultimately was not significantly better than a FIFO policy and still
thrashed cache based on eviction speed, rather than actual demand for
cache.
This patch solves one half of the problem by decoupling the ability to
detect working set changes from the inactive list size. By maintaining
a history of recently evicted file pages it can detect frequently used
pages with an arbitrarily small inactive list size, and subsequently
apply pressure on the active list based on actual demand for cache, not
just overall eviction speed.
Every zone maintains a counter that tracks inactive list aging speed.
When a page is evicted, a snapshot of this counter is stored in the
now-empty page cache radix tree slot. On refault, the minimum access
distance of the page can be assessed, to evaluate whether the page
should be part of the active list or not.
This fixes the VM's blindness towards working set changes in excess of
the inactive list. And it's the foundation to further improve the
protection ability and reduce the minimum inactive list size of 50%.
Reviewed-by: Bob Liu <bob.liu@oracle.com>
Reclaim will be leaving shadow entries in the page cache radix tree upon
evicting the real page. As those pages are found from the LRU, an
iput() can lead to the inode being freed concurrently. At this point,
reclaim must no longer install shadow pages because the inode freeing
code needs to ensure the page tree is really empty.
Add an address_space flag, AS_EXITING, that the inode freeing code sets
under the tree lock before doing the final truncate. Reclaim will check
for this flag before installing shadow pages.
shmem mappings already contain exceptional entries where swap slot
information is remembered.
To be able to store eviction information for regular page cache, prepare
every site dealing with the radix trees directly to handle entries other
than pages.
The common lookup functions will filter out non-page entries and return
NULL for page cache holes, just as before. But provide a raw version of
the API which returns non-page entries as well, and switch shmem over to
use it.
The radix tree hole searching code is only used for page cache, for
example the readahead code trying to get a a picture of the area
surrounding a fault.
It sufficed to rely on the radix tree definition of holes, which is
"empty tree slot". But this is about to change, though, as shadow page
descriptors will be stored in the page cache after the actual pages get
evicted from memory.
Move the functions over to mm/filemap.c and make them native page cache
operations, where they can later be adapted to handle the new definition
of "page cache hole".
Since put_mems_allowed() is strictly optional, its a seqcount retry, we
don't need to evaluate the function if the allocation was in fact
successful, saving a smp_rmb some loads and comparisons on some relative
fast-paths.
Since the naming, get/put_mems_allowed() does suggest a mandatory
pairing, rename the interface, as suggested by Mel, to resemble the
seqcount interface.
This gives us: read_mems_allowed_begin() and read_mems_allowed_retry(),
where it is important to note that the return value of the latter call
is inverted from its previous incarnation.
