path: root/mm/highmem.c
2008-03-19mm: highmem kernel-doc additionsRandy Dunlap
Add kernel-doc comments to highmem.c. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05mm: remove fastcall from mm/Harvey Harrison
fastcall is always defined to be empty, remove it [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Create the ZONE_MOVABLE zoneMel Gorman
The following 8 patches against 2.6.20-mm2 create a zone called ZONE_MOVABLE that is only usable by allocations that specify both __GFP_HIGHMEM and __GFP_MOVABLE. This has the effect of keeping all non-movable pages within a single memory partition while allowing movable allocations to be satisfied from either partition. The patches may be applied with the list-based anti-fragmentation patches that groups pages together based on mobility. The size of the zone is determined by a kernelcore= parameter specified at boot-time. This specifies how much memory is usable by non-movable allocations and the remainder is used for ZONE_MOVABLE. Any range of pages within ZONE_MOVABLE can be released by migrating the pages or by reclaiming. When selecting a zone to take pages from for ZONE_MOVABLE, there are two things to consider. First, only memory from the highest populated zone is used for ZONE_MOVABLE. On the x86, this is probably going to be ZONE_HIGHMEM but it would be ZONE_DMA on ppc64 or possibly ZONE_DMA32 on x86_64. Second, the amount of memory usable by the kernel will be spread evenly throughout NUMA nodes where possible. If the nodes are not of equal size, the amount of memory usable by the kernel on some nodes may be greater than others. By default, the zone is not as useful for hugetlb allocations because they are pinned and non-migratable (currently at least). A sysctl is provided that allows huge pages to be allocated from that zone. This means that the huge page pool can be resized to the size of ZONE_MOVABLE during the lifetime of the system assuming that pages are not mlocked. Despite huge pages being non-movable, we do not introduce additional external fragmentation of note as huge pages are always the largest contiguous block we care about. Credit goes to Andy Whitcroft for catching a large variety of problems during review of the patches. This patch creates an additional zone, ZONE_MOVABLE. This zone is only usable by allocations which specify both __GFP_HIGHMEM and __GFP_MOVABLE. Hot-added memory continues to be placed in their existing destination as there is no mechanism to redirect them to a specific zone. [y-goto@jp.fujitsu.com: Fix section mismatch of memory hotplug related code] [akpm@linux-foundation.org: various fixes] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02[PATCH] i386: PARAVIRT: add kmap_atomic_pte for mapping highpte pagesJeremy Fitzhardinge
Xen and VMI both have special requirements when mapping a highmem pte page into the kernel address space. These can be dealt with by adding a new kmap_atomic_pte() function for mapping highptes, and hooking it into the paravirt_ops infrastructure. Xen specifically wants to map the pte page RO, so this patch exposes a helper function, kmap_atomic_prot, which maps the page with the specified page protections. This also adds a kmap_flush_unused() function to clear out the cached kmap mappings. Xen needs this to clear out any potential stray RW mappings of pages which will become part of a pagetable. [ Zach - vmi.c will need some attention after this patch. It wasn't immediately obvious to me what needs to be done. ] Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: Zachary Amsden <zach@vmware.com>
2007-02-11[PATCH] Use ZVC for free_pagesChristoph Lameter
This is again simplifies some of the VM counter calculations through the use of the ZVC consolidated counters. [michal.k.k.piotrowski@gmail.com: build fix] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-30[PATCH] BLOCK: Separate the bounce buffering code from the highmem code [try #6]David Howells
Move the bounce buffer code from mm/highmem.c to mm/bounce.c so that it can be more easily disabled when the block layer is disabled. !!!NOTE!!! There may be a bug in this code: Should init_emergency_pool() be contingent on CONFIG_HIGHMEM? Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-26[PATCH] reduce MAX_NR_ZONES: move HIGHMEM counters into highmem.c/.hChristoph Lameter
Move totalhigh_pages and nr_free_highpages() into highmem.c/.h Move the totalhigh_pages definition into highmem.c/.h. Move the nr_free_highpages function into highmem.c [yoichi_yuasa@tripeaks.co.jp: build fix] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30[PATCH] zoned vm counters: conversion of nr_bounce to per zone counterChristoph Lameter
Conversion of nr_bounce to a per zone counter nr_bounce is only used for proc output. So it could be left as an event counter. However, the event counters may not be accurate and nr_bounce is categorizing types of pages in a zone. So we really need this to also be a per zone counter. [akpm@osdl.org: bugfix] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-02BUG_ON() Conversion in mm/highmem.cEric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-26[PATCH] mempool: use common mempool page allocatorMatthew Dobson
Convert two mempool users that currently use their own mempool-backed page allocators to use the generic mempool page allocator. Also included are 2 trivial whitespace fixes. Signed-off-by: Matthew Dobson <colpatch@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] Block queue IO tracing support (blktrace) as of 2006-03-23Jens Axboe
Signed-off-by: Jens Axboe <axboe@suse.de>
2005-10-28[PATCH] gfp_t: the restAl Viro
zone handling, mapping->flags handling Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] count bounce buffer pages in vmstatKAMEZAWA Hiroyuki
This is a patch for counting the number of pages for bounce buffers. It's shown in /proc/vmstat. Currently, the number of bounce pages are not counted anywhere. So, if there are many bounce pages, it seems that there are leaked pages. And it's difficult for a user to imagine the usage of bounce pages. So, it's meaningful to show # of bouce pages. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
