path: root/mm/highmem.c
2006-06-30[PATCH] zoned vm counters: conversion of nr_bounce to per zone counterChristoph Lameter
Conversion of nr_bounce to a per zone counter nr_bounce is only used for proc output. So it could be left as an event counter. However, the event counters may not be accurate and nr_bounce is categorizing types of pages in a zone. So we really need this to also be a per zone counter. [akpm@osdl.org: bugfix] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-02BUG_ON() Conversion in mm/highmem.cEric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-26[PATCH] mempool: use common mempool page allocatorMatthew Dobson
Convert two mempool users that currently use their own mempool-backed page allocators to use the generic mempool page allocator. Also included are 2 trivial whitespace fixes. Signed-off-by: Matthew Dobson <colpatch@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] Block queue IO tracing support (blktrace) as of 2006-03-23Jens Axboe
Signed-off-by: Jens Axboe <axboe@suse.de>
2005-10-28[PATCH] gfp_t: the restAl Viro
zone handling, mapping->flags handling Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] count bounce buffer pages in vmstatKAMEZAWA Hiroyuki
This is a patch for counting the number of pages for bounce buffers. It's shown in /proc/vmstat. Currently, the number of bounce pages are not counted anywhere. So, if there are many bounce pages, it seems that there are leaked pages. And it's difficult for a user to imagine the usage of bounce pages. So, it's meaningful to show # of bouce pages. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
