Ideally it would be possible to distinguish between NUMA hinting faults that
are private to a task and those that are shared. If treated identically
there is a risk that shared pages bounce between nodes depending on
the order they are referenced by tasks. Ultimately what is desirable is
that task private pages remain local to the task while shared pages are
interleaved between sharing tasks running on different nodes to give good
average performance. This is further complicated by THP as even
applications that partition their data may not be partitioning on a huge
page boundary.
To start with, this patch assumes that multi-threaded or multi-process
applications partition their data and that in general the private accesses
are more important for cpu->memory locality in the general case. Also,
no new infrastructure is required to treat private pages properly but
interleaving for shared pages requires additional infrastructure.
To detect private accesses the pid of the last accessing task is required
but the storage requirements are a high. This patch borrows heavily from
Ingo Molnar's patch "numa, mm, sched: Implement last-CPU+PID hash tracking"
to encode some bits from the last accessing task in the page flags as
well as the node information. Collisions will occur but it is better than
just depending on the node information. Node information is then used to
determine if a page needs to migrate. The PID information is used to detect
private/shared accesses. The preferred NUMA node is selected based on where
the maximum number of approximately private faults were measured. Shared
faults are not taken into consideration for a few reasons.
First, if there are many tasks sharing the page then they'll all move
towards the same node. The node will be compute overloaded and then
scheduled away later only to bounce back again. Alternatively the shared
tasks would just bounce around nodes because the fault information is
effectively noise. Either way accounting for shared faults the same as
private faults can result in lower performance overall.
The second reason is based on a hypothetical workload that has a small
number of very important, heavily accessed private pages but a large shared
array. The shared array would dominate the number of faults and be selected
as a preferred node even though it's the wrong decision.
The third reason is that multiple threads in a process will race each
other to fault the shared page making the fault information unreliable.
[ Fix complication error when !NUMA_BALANCING. ]
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/1381141781-10992-30-git-send-email-mgorman@suse.de
Currently automatic NUMA balancing is unable to distinguish between false
shared versus private pages except by ignoring pages with an elevated
page_mapcount entirely. This avoids shared pages bouncing between the
nodes whose task is using them but that is ignored quite a lot of data.
This patch kicks away the training wheels in preparation for adding support
for identifying shared/private pages is now in place. The ordering is so
that the impact of the shared/private detection can be easily measured. Note
that the patch does not migrate shared, file-backed within vmas marked
VM_EXEC as these are generally shared library pages. Migrating such pages
is not beneficial as there is an expectation they are read-shared between
caches and iTLB and iCache pressure is generally low.
Link: http://lkml.kernel.org/r/1381141781-10992-28-git-send-email-mgorman@suse.de
hinting faults
that are private to a task and those that are shared. This patch prepares
infrastructure for separately accounting shared and private faults by
allocating the necessary buffers and passing in relevant information. For
now, all faults are treated as private and detection will be introduced
later.
Link: http://lkml.kernel.org/r/1381141781-10992-26-git-send-email-mgorman@suse.de
The zero page is not replicated between nodes and is often shared between
processes. The data is read-only and likely to be cached in local CPUs
if heavily accessed meaning that the remote memory access cost is less
of a concern. This patch prevents trapping faults on the zero pages. For
tasks using the zero page this will reduce the number of PTE updates,
TLB flushes and hinting faults.
[ Correct use of is_huge_zero_page]
Link: http://lkml.kernel.org/r/1381141781-10992-13-git-send-email-mgorman@suse.de
NUMA PTE scanning is expensive both in terms of the scanning itself and
the TLB flush if there are any updates. The TLB flush is avoided if no
PTEs are updated but there is a bug where transhuge PMDs are considered
to be updated even if they were already pmd_numa. This patch addresses
the problem and TLB flushes should be reduced.
Link: http://lkml.kernel.org/r/1381141781-10992-12-git-send-email-mgorman@suse.de
THP migration uses the page lock to guard against parallel allocations
but there are cases like this still open
Task A Task B
do_huge_pmd_numa_page do_huge_pmd_numa_page
lock_page
mpol_misplaced == -1
unlock_page
goto clear_pmdnuma
lock_page
mpol_misplaced == 2
migrate_misplaced_transhuge
pmd = pmd_mknonnuma
set_pmd_at
During hours of testing, one crashed with weird errors and while I have
no direct evidence, I suspect something like the race above happened.
This patch extends the page lock to being held until the pmd_numa is
cleared to prevent migration starting in parallel while the pmd_numa is
being cleared. It also flushes the old pmd entry and orders pagetable
insertion before rmap insertion.
Link: http://lkml.kernel.org/r/1381141781-10992-9-git-send-email-mgorman@suse.de
There are three callers of task_numa_fault():
- do_huge_pmd_numa_page():
Accounts against the current node, not the node where the
page resides, unless we migrated, in which case it accounts
against the node we migrated to.
- do_numa_page():
- do_pmd_numa_page():
Accounts not at all when the page isn't migrated, otherwise
accounts against the node we migrated towards.
This seems wrong to me; all three sites should have the same
sementaics, furthermore we should accounts against where the page
really is, we already know where the task is.
So modify all three sites to always account; we did after all receive
the fault; and always account to where the page is after migration,
regardless of success.
They all still differ on when they clear the PTE/PMD; ideally that
would get sorted too.
Link: http://lkml.kernel.org/r/1381141781-10992-8-git-send-email-mgorman@suse.de
THP migrations are serialised by the page lock but on its own that does
not prevent THP splits. If the page is split during THP migration then
the pmd_same checks will prevent page table corruption but the unlock page
and other fix-ups potentially will cause corruption. This patch takes the
anon_vma lock to prevent parallel splits during migration.
Link: http://lkml.kernel.org/r/1381141781-10992-7-git-send-email-mgorman@suse.de
The locking for migrating THP is unusual. While normal page migration
prevents parallel accesses using a migration PTE, THP migration relies on
a combination of the page_table_lock, the page lock and the existance of
the NUMA hinting PTE to guarantee safety but there is a bug in the scheme.
If a THP page is currently being migrated and another thread traps a
fault on the same page it checks if the page is misplaced. If it is not,
then pmd_numa is cleared. The problem is that it checks if the page is
misplaced without holding the page lock meaning that the racing thread
can be migrating the THP when the second thread clears the NUMA bit
and faults a stale page.
This patch checks if the page is potentially being migrated and stalls
using the lock_page if it is potentially being migrated before checking
if the page is misplaced or not.
Link: http://lkml.kernel.org/r/1381141781-10992-6-git-send-email-mgorman@suse.de
If another task handled a hinting fault in parallel then do not double
account for it.
Link: http://lkml.kernel.org/r/1381141781-10992-5-git-send-email-mgorman@suse.de
Fix a 80 column violation and a PTE vs PMD reference.
Link: http://lkml.kernel.org/r/1381141781-10992-4-git-send-email-mgorman@suse.de
Merge more patches from Andrew Morton:
"The rest of MM. Plus one misc cleanup"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (35 commits)
mm/Kconfig: add MMU dependency for MIGRATION.
kernel: replace strict_strto*() with kstrto*()
mm, thp: count thp_fault_fallback anytime thp fault fails
thp: consolidate code between handle_mm_fault() and do_huge_pmd_anonymous_page()
thp: do_huge_pmd_anonymous_page() cleanup
thp: move maybe_pmd_mkwrite() out of mk_huge_pmd()
mm: cleanup add_to_page_cache_locked()
thp: account anon transparent huge pages into NR_ANON_PAGES
truncate: drop 'oldsize' truncate_pagecache() parameter
mm: make lru_add_drain_all() selective
memcg: document cgroup dirty/writeback memory statistics
memcg: add per cgroup writeback pages accounting
memcg: check for proper lock held in mem_cgroup_update_page_stat
memcg: remove MEMCG_NR_FILE_MAPPED
memcg: reduce function dereference
memcg: avoid overflow caused by PAGE_ALIGN
memcg: rename RESOURCE_MAX to RES_COUNTER_MAX
memcg: correct RESOURCE_MAX to ULLONG_MAX
mm: memcg: do not trap chargers with full callstack on OOM
mm: memcg: rework and document OOM waiting and wakeup
Currently, thp_fault_fallback in vmstat only gets incremented if a
hugepage allocation fails. If current's memcg hits its limit or the page
fault handler returns an error, it is incorrectly accounted as a
successful thp_fault_alloc.
Count thp_fault_fallback anytime the page fault handler falls back to
using regular pages and only count thp_fault_alloc when a hugepage has
actually been faulted.
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
do_huge_pmd_anonymous_page() has copy-pasted piece of handle_mm_fault()
to handle fallback path.
Let's consolidate code back by introducing VM_FAULT_FALLBACK return
code.
Acked-by: Hillf Danton <dhillf@gmail.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Matthew Wilcox <willy@linux.intel.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Minor cleanup: unindent most code of the fucntion by inverting one
condition. It's preparation for the next patch.
No functional changes.
It's confusing that mk_huge_pmd() has semantics different from mk_pte() or
mk_pmd(). I spent some time on debugging issue cased by this
inconsistency.
Let's move maybe_pmd_mkwrite() out of mk_huge_pmd() and adjust prototype
to match mk_pte().
Acked-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Hillf Danton <dhillf@gmail.com>
We use NR_ANON_PAGES as base for reporting AnonPages to user. There's
not much sense in not accounting transparent huge pages there, but add
them on printing to user.
Let's account transparent huge pages in NR_ANON_PAGES in the first place.
Cc: Ning Qu <quning@google.com>
Pull vfs pile 4 from Al Viro:
"list_lru pile, mostly"
This came out of Andrew's pile, Al ended up doing the merge work so that
Andrew didn't have to.
Additionally, a few fixes.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (42 commits)
super: fix for destroy lrus
list_lru: dynamically adjust node arrays
shrinker: Kill old ->shrink API.
shrinker: convert remaining shrinkers to count/scan API
staging/lustre/libcfs: cleanup linux-mem.h
staging/lustre/ptlrpc: convert to new shrinker API
staging/lustre/obdclass: convert lu_object shrinker to count/scan API
staging/lustre/ldlm: convert to shrinkers to count/scan API
hugepage: convert huge zero page shrinker to new shrinker API
i915: bail out earlier when shrinker cannot acquire mutex
drivers: convert shrinkers to new count/scan API
fs: convert fs shrinkers to new scan/count API
xfs: fix dquot isolation hang
xfs-convert-dquot-cache-lru-to-list_lru-fix
xfs: convert dquot cache lru to list_lru
xfs: rework buffer dispose list tracking
xfs-convert-buftarg-lru-to-generic-code-fix
xfs: convert buftarg LRU to generic code
fs: convert inode and dentry shrinking to be node aware
vmscan: per-node deferred work
In collapse_huge_page() there is a race window between releasing the
mmap_sem read lock and taking the mmap_sem write lock, so find_vma() may
return NULL. So check the return value to avoid NULL pointer dereference.
collapse_huge_page
khugepaged_alloc_page
up_read(&mm->mmap_sem)
down_write(&mm->mmap_sem)
vma = find_vma(mm, address)
Signed-off-by: Libin <huawei.libin@huawei.com>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Cc: <stable@vger.kernel.org> # v3.0+
The use of strict_strtoul() is not preferred, because strict_strtoul() is
obsolete. Thus, kstrtoul() should be used.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
It consists of:
* returning long instead of int
* separating count from scan
* returning the number of freed entities in scan
Signed-off-by: Glauber Costa <glommer@openvz.org>
Reviewed-by: Greg Thelen <gthelen@google.com>
Cc: Dave Chinner <dchinner@redhat.com>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Cc: Arve Hjønnevåg <arve@android.com>
Cc: Carlos Maiolino <cmaiolino@redhat.com>
Cc: Chuck Lever <chuck.lever@oracle.com>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Gleb Natapov <gleb@redhat.com>
Cc: J. Bruce Fields <bfields@redhat.com>
Cc: Jerome Glisse <jglisse@redhat.com>
Cc: John Stultz <john.stultz@linaro.org>
Cc: Kent Overstreet <koverstreet@google.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Thomas Hellstrom <thellstrom@vmware.com>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
active/inactive lru lists can contain unevicable pages (i.e. ramfs pages
that have been placed on the LRU lists when first allocated), but these
pages must not have PageUnevictable set - otherwise shrink_[in]active_list
goes crazy:
kernel BUG at /home/space/kas/git/public/linux-next/mm/vmscan.c:1122!
1090 static unsigned long isolate_lru_pages(unsigned long nr_to_scan,
1091 struct lruvec *lruvec, struct list_head *dst,
1092 unsigned long *nr_scanned, struct scan_control *sc,
1093 isolate_mode_t mode, enum lru_list lru)
1094 {
1108 switch (__isolate_lru_page(page, mode)) {
1109 case 0:
1116 case -EBUSY:
1121 default:
1122 BUG();
1123 }
1124 }
1130 }
__isolate_lru_page() returns EINVAL for PageUnevictable(page).
For lru_add_page_tail(), it means we should not set PageUnevictable()
for tail pages unless we're sure that it will go to LRU_UNEVICTABLE.
Let's just copy PG_active and PG_unevictable from head page in
__split_huge_page_refcount(), it will simplify lru_add_page_tail().
This will fix one more bug in lru_add_page_tail(): if
page_evictable(page_tail) is false and PageLRU(page) is true, page_tail
will go to the same lru as page, but nobody cares to sync page_tail
active/inactive state with page. So we can end up with inactive page on
active lru. The patch will fix it as well since we copy PG_active from
head page.
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc updates from Ben Herrenschmidt:
"This is the powerpc changes for the 3.11 merge window. In addition to
the usual bug fixes and small updates, the main highlights are:
- Support for transparent huge pages by Aneesh Kumar for 64-bit
server processors. This allows the use of 16M pages as transparent
huge pages on kernels compiled with a 64K base page size.
- Base VFIO support for KVM on power by Alexey Kardashevskiy
- Wiring up of our nvram to the pstore infrastructure, including
putting compressed oopses in there by Aruna Balakrishnaiah
- Move, rework and improve our "EEH" (basically PCI error handling
and recovery) infrastructure. It is no longer specific to pseries
but is now usable by the new "powernv" platform as well (no
hypervisor) by Gavin Shan.
- I fixed some bugs in our math-emu instruction decoding and made it
usable to emulate some optional FP instructions on processors with
hard FP that lack them (such as fsqrt on Freescale embedded
processors).
- Support for Power8 "Event Based Branch" facility by Michael
Ellerman. This facility allows what is basically "userspace
interrupts" for performance monitor events.
- A bunch of Transactional Memory vs. Signals bug fixes and HW
breakpoint/watchpoint fixes by Michael Neuling.
And more ... I appologize in advance if I've failed to highlight
something that somebody deemed worth it."
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (156 commits)
pstore: Add hsize argument in write_buf call of pstore_ftrace_call
powerpc/fsl: add MPIC timer wakeup support
powerpc/mpic: create mpic subsystem object
powerpc/mpic: add global timer support
powerpc/mpic: add irq_set_wake support
powerpc/85xx: enable coreint for all the 64bit boards
powerpc/8xx: Erroneous double irq_eoi() on CPM IRQ in MPC8xx
powerpc/fsl: Enable CONFIG_E1000E in mpc85xx_smp_defconfig
powerpc/mpic: Add get_version API both for internal and external use
powerpc: Handle both new style and old style reserve maps
powerpc/hw_brk: Fix off by one error when validating DAWR region end
powerpc/pseries: Support compression of oops text via pstore
powerpc/pseries: Re-organise the oops compression code
pstore: Pass header size in the pstore write callback
powerpc/powernv: Fix iommu initialization again
powerpc/pseries: Inform the hypervisor we are using EBB regs
powerpc/perf: Add power8 EBB support
powerpc/perf: Core EBB support for 64-bit book3s
powerpc/perf: Drop MMCRA from thread_struct
powerpc/perf: Don't enable if we have zero events
The soft-dirty is a bit on a PTE which helps to track which pages a task
writes to. In order to do this tracking one should
1. Clear soft-dirty bits from PTEs ("echo 4 > /proc/PID/clear_refs)
2. Wait some time.
3. Read soft-dirty bits (55'th in /proc/PID/pagemap2 entries)
To do this tracking, the writable bit is cleared from PTEs when the
soft-dirty bit is. Thus, after this, when the task tries to modify a
page at some virtual address the #PF occurs and the kernel sets the
soft-dirty bit on the respective PTE.
Note, that although all the task's address space is marked as r/o after
the soft-dirty bits clear, the #PF-s that occur after that are processed
fast. This is so, since the pages are still mapped to physical memory,
and thus all the kernel does is finds this fact out and puts back
writable, dirty and soft-dirty bits on the PTE.
Another thing to note, is that when mremap moves PTEs they are marked
with soft-dirty as well, since from the user perspective mremap modifies
the virtual memory at mremap's new address.
Signed-off-by: Pavel Emelyanov <xemul@parallels.com>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
Cc: Glauber Costa <glommer@parallels.com>
Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com>
Architectures like powerpc use the deposited pgtable to store hash index
values. We need to make the deposted pgtable is visible to other cpus
before we are ready to take a hash fault.
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: David Gibson <david@gibson.dropbear.id.au>
For architectures like ppc64 we look at deposited pgtable when calling
pmdp_get_and_clear. So do the pgtable_trans_huge_withdraw after finishing
pmdp related operations.
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
This will be later used by powerpc THP support. In powerpc we want to use
pgtable for storing the hash index values. So instead of adding them to
mm_context list, we would like to store them in the second half of pmd
Reviewed-by: David Gibson <david@gibson.dropbear.id.au>
We should use pmdp_set_access_flags to update access flags. Archs like
powerpc use extra checks(_PAGE_BUSY) when updating a hugepage PTE. A
set_pmd_at doesn't do those checks. We should use set_pmd_at only when
updating a none hugepage PTE.
Cc: Andrea Arcangeli <aarcange@redhat.com>a
We should not use set_pmd_at to update pmd_t with pgtable_t pointer.
set_pmd_at is used to set pmd with huge pte entries and architectures
like ppc64, clear few flags from the pte when saving a new entry.
Without this change we observe bad pte errors like below on ppc64 with
THP enabled.
BUG: Bad page map in process ld mm=0xc000001ee39f4780 pte:7fc3f37848000001 pmd:c000001ec0000000
Current implementation of huge zero page uses pfn value 0 to indicate
that the page hasn't allocated yet. It assumes that buddy page
allocator can't return page with pfn == 0.
Let's rework the code to store 'struct page *' of huge zero page, not
its pfn. This way we can avoid the weak assumption.
[akpm@linux-foundation.org: fix sparse warning]
Reported-by: Minchan Kim <minchan@kernel.org>
Acked-by: Minchan Kim <minchan@kernel.org>
In page reclaim, huge page is split. split_huge_page() adds tail pages
to LRU list. Since we are reclaiming a huge page, it's better we
reclaim all subpages of the huge page instead of just the head page.
This patch adds split tail pages to shrink page list so the tail pages
can be reclaimed soon.
Before this patch, run a swap workload:
thp_fault_alloc 3492
thp_fault_fallback 608
thp_collapse_alloc 6
thp_collapse_alloc_failed 0
thp_split 916
With this patch:
thp_fault_alloc 4085
thp_fault_fallback 16
thp_collapse_alloc 90
thp_split 1272
fallback allocation is reduced a lot.
[akpm@linux-foundation.org: fix CONFIG_SWAP=n build]
Signed-off-by: Shaohua Li <shli@fusionio.com>
Currently the memory barrier in __do_huge_pmd_anonymous_page doesn't
work. Because lru_cache_add_lru uses pagevec so it could miss spinlock
easily so above rule was broken so user might see inconsistent data.
I was not first person who pointed out the problem. Mel and Peter
pointed out a few months ago and Peter pointed out further that even
spin_lock/unlock can't make sure of it:
http://marc.info/?t=134333512700004
In particular:
*A = a;
LOCK
UNLOCK
*B = b;
may occur as:
LOCK, STORE *B, STORE *A, UNLOCK
At last, Hugh pointed out that even we don't need memory barrier in
there because __SetPageUpdate already have done it from Nick's commit
0ed361dec369 ("mm: fix PageUptodate data race") explicitly.
So this patch fixes comment on THP and adds same comment for
do_anonymous_page, too because everybody except Hugh was missing that.
It means we need a comment about that.
Signed-off-by: Minchan Kim <minchan@kernel.org>
Acked-by: Andrea Arcangeli <aarcange@redhat.com>
Acked-by: David Rientjes <rientjes@google.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
I'm not sure why, but the hlist for each entry iterators were conceived
list_for_each_entry(pos, head, member)
The hlist ones were greedy and wanted an extra parameter:
hlist_for_each_entry(tpos, pos, head, member)
Why did they need an extra pos parameter? I'm not quite sure. Not only
they don't really need it, it also prevents the iterator from looking
exactly like the list iterator, which is unfortunate.
Besides the semantic patch, there was some manual work required:
- Fix up the actual hlist iterators in linux/list.h
- Fix up the declaration of other iterators based on the hlist ones.
- A very small amount of places were using the 'node' parameter, this
was modified to use 'obj->member' instead.
- Coccinelle didn't handle the hlist_for_each_entry_safe iterator
properly, so those had to be fixed up manually.
The semantic patch which is mostly the work of Peter Senna Tschudin is here:
iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host;
type T;
expression a,c,d,e;
identifier b;
statement S;
-T b;
<+... when != b
hlist_for_each_entry(a,
- b,
c, d) S
hlist_for_each_entry_continue(a,
- b,
c) S
hlist_for_each_entry_from(a,
- b,
c) S
hlist_for_each_entry_rcu(a,
- b,
c, d) S
hlist_for_each_entry_rcu_bh(a,
- b,
c, d) S
hlist_for_each_entry_continue_rcu_bh(a,
- b,
c) S
for_each_busy_worker(a, c,
- b,
d) S
ax25_uid_for_each(a,
- b,
c) S
ax25_for_each(a,
- b,
c) S
inet_bind_bucket_for_each(a,
- b,
c) S
sctp_for_each_hentry(a,
- b,
c) S
sk_for_each(a,
- b,
c) S
sk_for_each_rcu(a,
- b,
c) S
sk_for_each_from
-(a, b)
+(a)
S
+ sk_for_each_from(a) S
sk_for_each_safe(a,
- b,
c, d) S
sk_for_each_bound(a,
- b,
c) S
hlist_for_each_entry_safe(a,
- b,
c, d, e) S
hlist_for_each_entry_continue_rcu(a,
- b,
c) S
nr_neigh_for_each(a,
- b,
c) S
nr_neigh_for_each_safe(a,
- b,
c, d) S
nr_node_for_each(a,
- b,
c) S
nr_node_for_each_safe(a,
- b,
c, d) S
- for_each_gfn_sp(a, c, d, b) S
+ for_each_gfn_sp(a, c, d) S
- for_each_gfn_indirect_valid_sp(a, c, d, b) S
+ for_each_gfn_indirect_valid_sp(a, c, d) S
for_each_host(a,
- b,
c) S
for_each_host_safe(a,
- b,
c, d) S
for_each_mesh_entry(a,
- b,
c, d) S
[akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c]
[akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c]
[akpm@linux-foundation.org: checkpatch fixes]
[akpm@linux-foundation.org: fix warnings]
[akpm@linux-foudnation.org: redo intrusive kvm changes]
Tested-by: Peter Senna Tschudin <peter.senna@gmail.com>
Make a sweep through mm/ and convert code that uses -1 directly to using
the more appropriate NUMA_NO_NODE.
Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
The function names page_xchg_last_nid(), page_last_nid() and
reset_page_last_nid() were judged to be inconsistent so rename them to a
struct_field_op style pattern. As it looked jarring to have
reset_page_mapcount() and page_nid_reset_last() beside each other in
memmap_init_zone(), this patch also renames reset_page_mapcount() to
page_mapcount_reset(). There are others like init_page_count() but as
it is used throughout the arch code a rename would likely cause more
conflicts than it is worth.
[akpm@linux-foundation.org: fix zcache]
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
When calculating amount of dirtyable memory, min_free_kbytes should be
subtracted because it is not intended for dirty pages.
Addresses http://bugs.debian.org/695182
[akpm@linux-foundation.org: fix up min_free_kbytes extern declarations]
[akpm@linux-foundation.org: fix min() warning]
Signed-off-by: Paul Szabo <psz@maths.usyd.edu.au>
The comment in commit 4fc3f1d66b1e ("mm/rmap, migration: Make
rmap_walk_anon() and try_to_unmap_anon() more scalable") says:
| Rename anon_vma_[un]lock() => anon_vma_[un]lock_write(),
| to make it clearer that it's an exclusive write-lock in
| that case - suggested by Rik van Riel.
But that commit renames only anon_vma_lock()
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
When correcting commit 04fa5d6a6547 ("mm: migrate: check page_count of
THP before migrating") Hugh Dickins noted that the control flow for
transhuge migration was difficult to follow. Unconditionally calling
put_page() in numamigrate_isolate_page() made the failure paths of both
migrate_misplaced_transhuge_page() and migrate_misplaced_page() more
complex that they should be. Further, he was extremely wary that an
unlock_page() should ever happen after a put_page() even if the
put_page() should never be the final put_page.
Hugh implemented the following cleanup to simplify the path by calling
putback_lru_page() inside numamigrate_isolate_page() if it failed to
isolate and always calling unlock_page() within
migrate_misplaced_transhuge_page().
There is no functional change after this patch is applied but the code
is easier to follow and unlock_page() always happens before put_page().
[mgorman@suse.de: changelog only]
Cc: Simon Jeons <simon.jeons@gmail.com>
Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com>
Switch hugemem to use the new hashtable implementation. This reduces
the amount of generic unrelated code in the hugemem.
This also removes the dymanic allocation of the hash table. The upside
is that we save a pointer dereference when accessing the hashtable, but
we lose 8KB if CONFIG_TRANSPARENT_HUGEPAGE is enabled but the processor
doesn't support hugepages.
No reason to preserve the huge zero page in core dumps.
Reported-by: Michel Lespinasse <walken@google.com>
Reviewed-by: Michel Lespinasse <walken@google.com>
Zhouping Liu reported the following against 3.8-rc1 when running a mmap
testcase from LTP.
mapcount 0 page_mapcount 3
kernel BUG at mm/huge_memory.c:1798!
invalid opcode: 0000 [#1] SMP
Modules linked in: ip6table_filter ip6_tables ebtable_nat ebtables bnep bluetooth rfkill iptable_mangle ipt_REJECT nf_conntrack_ipv4 nf_defrag_ipv4 xt_conntrack nf_conntrack iptable_filter ip_tables be2iscsi iscsi_boot_sysfs bnx2i cnic uio cxgb4i cxgb4 cxgb3i cxgb3 mdio libcxgbi ib_iser rdma_cm ib_addr iw_cm ib_cm ib_sa ib_mad ib_core iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi vfat fat dm_mirror dm_region_hash dm_log dm_mod cdc_ether iTCO_wdt i7core_edac coretemp usbnet iTCO_vendor_support mii crc32c_intel edac_core lpc_ich shpchp ioatdma mfd_core i2c_i801 pcspkr serio_raw bnx2 microcode dca vhost_net tun macvtap macvlan kvm_intel kvm uinput mgag200 sr_mod cdrom i2c_algo_bit sd_mod drm_kms_helper crc_t10dif ata_generic pata_acpi ttm ata_piix drm libata i2c_core megaraid_sas
CPU 1
Pid: 23217, comm: mmap10 Not tainted 3.8.0-rc1mainline+ #17 IBM IBM System x3400 M3 Server -[7379I08]-/69Y4356
RIP: __split_huge_page+0x677/0x6d0
RSP: 0000:ffff88017a03fc08 EFLAGS: 00010293
RAX: 0000000000000003 RBX: ffff88027a6c22e0 RCX: 00000000000034d2
RDX: 000000000000748b RSI: 0000000000000046 RDI: 0000000000000246
RBP: ffff88017a03fcb8 R08: ffffffff819d2440 R09: 000000000000054a
R10: 0000000000aaaaaa R11: 00000000ffffffff R12: 0000000000000000
R13: 00007f4f11a00000 R14: ffff880179e96e00 R15: ffffea0005c08000
FS: 00007f4f11f4a740(0000) GS:ffff88017bc20000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 00000037e9ebb404 CR3: 000000017a436000 CR4: 00000000000007e0
Process mmap10 (pid: 23217, threadinfo ffff88017a03e000, task ffff880172dd32e0)
Stack:
ffff88017a540ec8 ffff88017a03fc20 ffffffff816017b5 ffff88017a03fc88
ffffffff812fa014 0000000000000000 ffff880279ebd5c0 00000000f4f11a4c
00000007f4f11f49 00000007f4f11a00 ffff88017a540ef0 ffff88017a540ee8
Call Trace:
split_huge_page+0x68/0xb0
__split_huge_page_pmd+0x134/0x330
split_huge_page_pmd_mm+0x51/0x60
split_huge_page_address+0x3b/0x50
__vma_adjust_trans_huge+0x9c/0xf0
vma_adjust+0x684/0x750
__split_vma.isra.28+0x1fa/0x220
do_munmap+0xf9/0x420
vm_munmap+0x4e/0x70
sys_munmap+0x2b/0x40
system_call_fastpath+0x16/0x1b
Alexander Beregalov and Alex Xu reported similar bugs and Hillf Danton
identified that commit 5a505085f043 ("mm/rmap: Convert the struct
anon_vma::mutex to an rwsem") and commit 4fc3f1d66b1e ("mm/rmap,
migration: Make rmap_walk_anon() and try_to_unmap_anon() more scalable")
were likely the problem. Reverting these commits was reported to solve
the problem for Alexander.
Despite the reason for these commits, NUMA balancing is not the direct
source of the problem. split_huge_page() expects the anon_vma lock to
be exclusive to serialise the whole split operation. Ordinarily it is
expected that the anon_vma lock would only be required when updating the
avcs but THP also uses the anon_vma rwsem for collapse and split
operations where the page lock or compound lock cannot be used (as the
page is changing from base to THP or vice versa) and the page table
locks are insufficient.
This patch takes the anon_vma lock for write to serialise against parallel
split_huge_page as THP expected before the conversion to rwsem.
Reported-and-tested-by: Zhouping Liu <zliu@redhat.com>
Reported-by: Alexander Beregalov <a.beregalov@gmail.com>
Reported-by: Alex Xu <alex_y_xu@yahoo.ca>
Clarify error messages and correct a few typos in the transparent hugepage
sysfs init code.
Signed-off-by: Jeremy Eder <jeder@redhat.com>
Acked-by: Rafael Aquini <aquini@redhat.com>
Andrea's autonuma-benchmark numa01 hits kernel BUG at huge_memory.c:1474!
in change_huge_pmd called from change_protection from change_prot_numa
from task_numa_work.
That BUG, introduced in the huge zero page commit cad7f613c4d0 ("thp:
change_huge_pmd(): make sure we don't try to make a page writable")
was trying to verify that newprot never adds write permission to an
anonymous huge page; but Automatic NUMA Balancing's 4b10e7d562c9 ("mm:
mempolicy: Implement change_prot_numa() in terms of change_protection()")
adds a new prot_numa path into change_huge_pmd(), which makes no use of
the newprot provided, and may retain the write bit in the pmd.
Just move the BUG_ON(pmd_write(entry)) up into the !prot_numa block.
git://git.kernel.org/pub/scm/linux/kernel/git/mel/linux-balancenuma
Pull Automatic NUMA Balancing bare-bones from Mel Gorman:
"There are three implementations for NUMA balancing, this tree
(balancenuma), numacore which has been developed in tip/master and
autonuma which is in aa.git.
In almost all respects balancenuma is the dumbest of the three because
its main impact is on the VM side with no attempt to be smart about
scheduling. In the interest of getting the ball rolling, it would be
desirable to see this much merged for 3.8 with the view to building
scheduler smarts on top and adapting the VM where required for 3.9.
The most recent set of comparisons available from different people are
mel: https://lkml.org/lkml/2012/12/9/108
mingo: https://lkml.org/lkml/2012/12/7/331
tglx: https://lkml.org/lkml/2012/12/10/437
srikar: https://lkml.org/lkml/2012/12/10/397
The results are a mixed bag. In my own tests, balancenuma does
reasonably well. It's dumb as rocks and does not regress against
mainline. On the other hand, Ingo's tests shows that balancenuma is
incapable of converging for this workloads driven by perf which is bad
but is potentially explained by the lack of scheduler smarts. Thomas'
results show balancenuma improves on mainline but falls far short of
numacore or autonuma. Srikar's results indicate we all suffer on a
large machine with imbalanced node sizes.
My own testing showed that recent numacore results have improved
dramatically, particularly in the last week but not universally.
We've butted heads heavily on system CPU usage and high levels of
migration even when it shows that overall performance is better.
There are also cases where it regresses. Of interest is that for
specjbb in some configurations it will regress for lower numbers of
warehouses and show gains for higher numbers which is not reported by
the tool by default and sometimes missed in treports. Recently I
reported for numacore that the JVM was crashing with
NullPointerExceptions but currently it's unclear what the source of
this problem is. Initially I thought it was in how numacore batch
handles PTEs but I'm no longer think this is the case. It's possible
numacore is just able to trigger it due to higher rates of migration.
These reports were quite late in the cycle so I/we would like to start
with this tree as it contains much of the code we can agree on and has
not changed significantly over the last 2-3 weeks."
* tag 'balancenuma-v11' of git://git.kernel.org/pub/scm/linux/kernel/git/mel/linux-balancenuma: (50 commits)
mm/rmap, migration: Make rmap_walk_anon() and try_to_unmap_anon() more scalable
mm/rmap: Convert the struct anon_vma::mutex to an rwsem
mm: migrate: Account a transhuge page properly when rate limiting
mm: numa: Account for failed allocations and isolations as migration failures
mm: numa: Add THP migration for the NUMA working set scanning fault case build fix
mm: numa: Add THP migration for the NUMA working set scanning fault case.
mm: sched: numa: Delay PTE scanning until a task is scheduled on a new node
mm: sched: numa: Control enabling and disabling of NUMA balancing if !SCHED_DEBUG
mm: sched: Adapt the scanning rate if a NUMA hinting fault does not migrate
mm: numa: Use a two-stage filter to restrict pages being migrated for unlikely task<->node relationships
mm: numa: migrate: Set last_nid on newly allocated page
mm: numa: split_huge_page: Transfer last_nid on tail page
mm: numa: Introduce last_nid to the page frame
sched: numa: Slowly increase the scanning period as NUMA faults are handled
mm: numa: Rate limit setting of pte_numa if node is saturated
mm: numa: Rate limit the amount of memory that is migrated between nodes
mm: numa: Structures for Migrate On Fault per NUMA migration rate limiting
mm: numa: Migrate pages handled during a pmd_numa hinting fault
mm: numa: Migrate on reference policy
pmd value is stable only with mm->page_table_lock taken. After taking
the lock we need to check that nobody modified the pmd before changing it.
Cc: Jiri Slaby <jslaby@suse.cz>
Reviewed-by: Bob Liu <lliubbo@gmail.com>
By default kernel tries to use huge zero page on read page fault. It's
possible to disable huge zero page by writing 0 or enable it back by
writing 1:
echo 0 >/sys/kernel/mm/transparent_hugepage/khugepaged/use_zero_page
echo 1 >/sys/kernel/mm/transparent_hugepage/khugepaged/use_zero_page
Cc: "H. Peter Anvin" <hpa@linux.intel.com>
hzp_alloc is incremented every time a huge zero page is successfully
allocated. It includes allocations which where dropped due
race with other allocation. Note, it doesn't count every map
of the huge zero page, only its allocation.
hzp_alloc_failed is incremented if kernel fails to allocate huge zero
page and falls back to using small pages.
H. Peter Anvin doesn't like huge zero page which sticks in memory forever
after the first allocation. Here's implementation of lockless refcounting
for huge zero page.
We have two basic primitives: {get,put}_huge_zero_page(). They
manipulate reference counter.
If counter is 0, get_huge_zero_page() allocates a new huge page and takes
two references: one for caller and one for shrinker. We free the page
only in shrinker callback if counter is 1 (only shrinker has the
reference).
put_huge_zero_page() only decrements counter. Counter is never zero in
put_huge_zero_page() since shrinker holds on reference.
Freeing huge zero page in shrinker callback helps to avoid frequent
allocate-free.
Refcounting has cost. On 4 socket machine I observe ~1% slowdown on
parallel (40 processes) read page faulting comparing to lazy huge page
allocation. I think it's pretty reasonable for synthetic benchmark.
[lliubbo@gmail.com: fix mismerge]
Signed-off-by: Bob Liu <lliubbo@gmail.com>
Instead of allocating huge zero page on hugepage_init() we can postpone it
until first huge zero page map. It saves memory if THP is not in use.
cmpxchg() is used to avoid race on huge_zero_pfn initialization.
All code paths seems covered. Now we can map huge zero page on read page
fault.
We setup it in do_huge_pmd_anonymous_page() if area around fault address
is suitable for THP and we've got read page fault.
If we fail to setup huge zero page (ENOMEM) we fallback to
handle_pte_fault() as we normally do in THP.
