commit 27c73ae759774e63313c1fbfeb17ba076cea64c5 upstream.
Commit 7cb2ef56e6a8 ("mm: fix aio performance regression for database
caused by THP") can cause dereference of a dangling pointer if
split_huge_page runs during PageHuge() if there are updates to the
tail_page->private field.
Also it is repeating compound_head twice for hugetlbfs and it is running
compound_head+compound_trans_head for THP when a single one is needed in
both cases.
The new code within the PageSlab() check doesn't need to verify that the
THP page size is never bigger than the smallest hugetlbfs page size, to
avoid memory corruption.
A longstanding theoretical race condition was found while fixing the
above (see the change right after the skip_unlock label, that is
relevant for the compound_lock path too).
By re-establishing the _mapcount tail refcounting for all compound
pages, this also fixes the below problem:
echo 0 >/sys/kernel/mm/hugepages/hugepages-2048kB/nr_hugepages
BUG: Bad page state in process bash pfn:59a01
page:ffffea000139b038 count:0 mapcount:10 mapping: (null) index:0x0
page flags: 0x1c00000000008000(tail)
Modules linked in:
CPU: 6 PID: 2018 Comm: bash Not tainted 3.12.0+ #25
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
Call Trace:
dump_stack+0x55/0x76
bad_page+0xd5/0x130
free_pages_prepare+0x213/0x280
__free_pages+0x36/0x80
update_and_free_page+0xc1/0xd0
free_pool_huge_page+0xc2/0xe0
set_max_huge_pages.part.58+0x14c/0x220
nr_hugepages_store_common.isra.60+0xd0/0xf0
nr_hugepages_store+0x13/0x20
kobj_attr_store+0xf/0x20
sysfs_write_file+0x189/0x1e0
vfs_write+0xc5/0x1f0
SyS_write+0x55/0xb0
system_call_fastpath+0x16/0x1b
Signed-off-by: Khalid Aziz <khalid.aziz@oracle.com>
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Tested-by: Khalid Aziz <khalid.aziz@oracle.com>
Cc: Pravin Shelar <pshelar@nicira.com>
Cc: Ben Hutchings <bhutchings@solarflare.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Johannes Weiner <jweiner@redhat.com>
Cc: Minchan Kim <minchan@kernel.org>
[Khalid Aziz: Backported to 3.4]
commit 13d60f4b6ab5b702dc8d2ee20999f98a93728aec upstream.
The futex_keys of process shared futexes are generated from the page
offset, the mapping host and the mapping index of the futex user space
address. This should result in an unique identifier for each futex.
Though this is not true when futexes are located in different subpages
of an hugepage. The reason is, that the mapping index for all those
futexes evaluates to the index of the base page of the hugetlbfs
mapping. So a futex at offset 0 of the hugepage mapping and another
one at offset PAGE_SIZE of the same hugepage mapping have identical
futex_keys. This happens because the futex code blindly uses
page->index.
Steps to reproduce the bug:
1. Map a file from hugetlbfs. Initialize pthread_mutex1 at offset 0
and pthread_mutex2 at offset PAGE_SIZE of the hugetlbfs
mapping.
The mutexes must be initialized as PTHREAD_PROCESS_SHARED because
PTHREAD_PROCESS_PRIVATE mutexes are not affected by this issue as
their keys solely depend on the user space address.
2. Lock mutex1 and mutex2
3. Create thread1 and in the thread function lock mutex1, which
results in thread1 blocking on the locked mutex1.
4. Create thread2 and in the thread function lock mutex2, which
results in thread2 blocking on the locked mutex2.
5. Unlock mutex2. Despite the fact that mutex2 got unlocked, thread2
still blocks on mutex2 because the futex_key points to mutex1.
To solve this issue we need to take the normal page index of the page
which contains the futex into account, if the futex is in an hugetlbfs
mapping. In other words, we calculate the normal page mapping index of
the subpage in the hugetlbfs mapping.
Mappings which are not based on hugetlbfs are not affected and still
use page->index.
Thanks to Mel Gorman who provided a patch for adding proper evaluation
functions to the hugetlbfs code to avoid exposing hugetlbfs specific
details to the futex code.
[ tglx: Massaged changelog ]
Signed-off-by: Zhang Yi <zhang.yi20@zte.com.cn>
Reviewed-by: Jiang Biao <jiang.biao2@zte.com.cn>
Tested-by: Ma Chenggong <ma.chenggong@zte.com.cn>
Reviewed-by: 'Mel Gorman' <mgorman@suse.de>
Acked-by: 'Darren Hart' <dvhart@linux.intel.com>
Cc: 'Peter Zijlstra' <peterz@infradead.org>
Link: http://lkml.kernel.org/r/000101ce71a6%24a83c5880%24f8b50980%24@com
[bwh: Backported to 3.2: adjust context]
commit 30dad30922ccc733cfdbfe232090cf674dc374dc upstream.
When we have a page fault for the address which is backed by a hugepage
under migration, the kernel can't wait correctly and do busy looping on
hugepage fault until the migration finishes. As a result, users who try
to kick hugepage migration (via soft offlining, for example) occasionally
experience long delay or soft lockup.
This is because pte_offset_map_lock() can't get a correct migration entry
or a correct page table lock for hugepage. This patch introduces
migration_entry_wait_huge() to solve this.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
commit 9cc3a5bd40067b9a0fbd49199d0780463fc2140f upstream.
With applying the previous patch "hugetlbfs: stop setting VM_DONTDUMP in
initializing vma(VM_HUGETLB)" to reenable hugepage coredump, if a memory
error happens on a hugepage and the affected processes try to access the
error hugepage, we hit VM_BUG_ON(atomic_read(&page->_count) <= 0) in
get_page().
The reason for this bug is that coredump-related code doesn't recognise
"hugepage hwpoison entry" with which a pmd entry is replaced when a memory
error occurs on a hugepage.
In other words, physical address information is stored in different bit
layout between hugepage hwpoison entry and pmd entry, so
follow_hugetlb_page() which is called in get_dump_page() returns a wrong
page from a given address.
The expected behavior is like this:
absent is_swap_pte FOLL_DUMP Expected behavior
true false false hugetlb_fault
false true false hugetlb_fault
false false false return page
true false true skip page (to avoid allocation)
false true true hugetlb_fault
false false true return page
With this patch, we can call hugetlb_fault() and take proper actions (we
wait for migration entries, fail with VM_FAULT_HWPOISON_LARGE for
hwpoisoned entries,) and as the result we can dump all hugepages except
for hwpoisoned ones.
Acked-by: Michal Hocko <mhocko@suse.cz>
Cc: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com>
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Acked-by: David Rientjes <rientjes@google.com>
accouting
commit d00285884c0892bb1310df96bce6056e9ce9b9d9 upstream.
hugetlb_total_pages is used for overcommit calculations but the current
implementation considers only the default hugetlb page size (which is
either the first defined hugepage size or the one specified by
default_hugepagesz kernel boot parameter).
If the system is configured for more than one hugepage size, which is
possible since commit a137e1cc6d6e ("hugetlbfs: per mount huge page
sizes") then the overcommit estimation done by __vm_enough_memory()
(resp. shown by meminfo_proc_show) is not precise - there is an
impression of more available/allowed memory. This can lead to an
unexpected ENOMEM/EFAULT resp. SIGSEGV when memory is accounted.
Testcase:
boot: hugepagesz=1G hugepages=1
the default overcommit ratio is 50
before patch:
egrep 'CommitLimit' /proc/meminfo
CommitLimit: 55434168 kB
after patch:
CommitLimit: 54909880 kB
[akpm@linux-foundation.org: coding-style tweak]
Signed-off-by: Wanpeng Li <liwanp@linux.vnet.ibm.com>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
Cc: Hillf Danton <dhillf@gmail.com>
commit 36e4f20af833d1ce196e6a4ade05dc26c44652d1 upstream.
Commit 0c176d52b0b2 ("mm: hugetlb: fix pgoff computation when unmapping
page from vma") fixed pgoff calculation but it has replaced it by
vma_hugecache_offset() which is not approapriate for offsets used for
vma_prio_tree_foreach() because that one expects index in page units
rather than in huge_page_shift.
Johannes said:
: The resulting index may not be too big, but it can be too small: assume
: hpage size of 2M and the address to unmap to be 0x200000. This is regular
: page index 512 and hpage index 1. If you have a VMA that maps the file
: only starting at the second huge page, that VMAs vm_pgoff will be 512 but
: you ask for offset 1 and miss it even though it does map the page of
: interest. hugetlb_cow() will try to unmap, miss the vma, and retry the
: cow until the allocation succeeds or the skipped vma(s) go away.
Acked-by: Hillf Danton <dhillf@gmail.com>
commit 0c176d52b0b2619f231b2bbf329b90c028134f58 upstream.
The computation for pgoff is incorrect, at least with
(vma->vm_pgoff >> PAGE_SHIFT)
involved. It is fixed with the available method if HPAGE_SIZE is
concerned in page cache lookup.
[akpm@linux-foundation.org: use vma_hugecache_offset() directly, per Michal]
Signed-off-by: Hillf Danton <dhillf@gmail.com>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
commit d833352a4338dc31295ed832a30c9ccff5c7a183 upstream.
If a process creates a large hugetlbfs mapping that is eligible for page
table sharing and forks heavily with children some of whom fault and
others which destroy the mapping then it is possible for page tables to
get corrupted. Some teardowns of the mapping encounter a "bad pmd" and
output a message to the kernel log. The final teardown will trigger a
BUG_ON in mm/filemap.c.
This was reproduced in 3.4 but is known to have existed for a long time
and goes back at least as far as 2.6.37. It was probably was introduced
in 2.6.20 by [39dde65c: shared page table for hugetlb page]. The messages
look like this;
[ ..........] Lots of bad pmd messages followed by this
[ 127.164256] mm/memory.c:391: bad pmd ffff880412e04fe8(80000003de4000e7).
[ 127.164257] mm/memory.c:391: bad pmd ffff880412e04ff0(80000003de6000e7).
[ 127.164258] mm/memory.c:391: bad pmd ffff880412e04ff8(80000003de0000e7).
[ 127.186778] ------------[ cut here ]------------
[ 127.186781] kernel BUG at mm/filemap.c:134!
[ 127.186782] invalid opcode: 0000 [#1] SMP
[ 127.186783] CPU 7
[ 127.186784] Modules linked in: af_packet cpufreq_conservative cpufreq_userspace cpufreq_powersave acpi_cpufreq mperf ext3 jbd dm_mod coretemp crc32c_intel usb_storage ghash_clmulni_intel aesni_intel i2c_i801 r8169 mii uas sr_mod cdrom sg iTCO_wdt iTCO_vendor_support shpchp serio_raw cryptd aes_x86_64 e1000e pci_hotplug dcdbas aes_generic container microcode ext4 mbcache jbd2 crc16 sd_mod crc_t10dif i915 drm_kms_helper drm i2c_algo_bit ehci_hcd ahci libahci usbcore rtc_cmos usb_common button i2c_core intel_agp video intel_gtt fan processor thermal thermal_sys hwmon ata_generic pata_atiixp libata scsi_mod
[ 127.186801]
[ 127.186802] Pid: 9017, comm: hugetlbfs-test Not tainted 3.4.0-autobuild #53 Dell Inc. OptiPlex 990/06D7TR
[ 127.186804] RIP: 0010:[<ffffffff810ed6ce>] [<ffffffff810ed6ce>] __delete_from_page_cache+0x15e/0x160
[ 127.186809] RSP: 0000:ffff8804144b5c08 EFLAGS: 00010002
[ 127.186810] RAX: 0000000000000001 RBX: ffffea000a5c9000 RCX: 00000000ffffffc0
[ 127.186811] RDX: 0000000000000000 RSI: 0000000000000009 RDI: ffff88042dfdad00
[ 127.186812] RBP: ffff8804144b5c18 R08: 0000000000000009 R09: 0000000000000003
[ 127.186813] R10: 0000000000000000 R11: 000000000000002d R12: ffff880412ff83d8
[ 127.186814] R13: ffff880412ff83d8 R14: 0000000000000000 R15: ffff880412ff83d8
[ 127.186815] FS: 00007fe18ed2c700(0000) GS:ffff88042dce0000(0000) knlGS:0000000000000000
[ 127.186816] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 127.186817] CR2: 00007fe340000503 CR3: 0000000417a14000 CR4: 00000000000407e0
[ 127.186818] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 127.186819] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 127.186820] Process hugetlbfs-test (pid: 9017, threadinfo ffff8804144b4000, task ffff880417f803c0)
[ 127.186821] Stack:
[ 127.186822] ffffea000a5c9000 0000000000000000 ffff8804144b5c48 ffffffff810ed83b
[ 127.186824] ffff8804144b5c48 000000000000138a 0000000000001387 ffff8804144b5c98
[ 127.186825] ffff8804144b5d48 ffffffff811bc925 ffff8804144b5cb8 0000000000000000
[ 127.186827] Call Trace:
[ 127.186829] [<ffffffff810ed83b>] delete_from_page_cache+0x3b/0x80
[ 127.186832] [<ffffffff811bc925>] truncate_hugepages+0x115/0x220
[ 127.186834] [<ffffffff811bca43>] hugetlbfs_evict_inode+0x13/0x30
[ 127.186837] [<ffffffff811655c7>] evict+0xa7/0x1b0
[ 127.186839] [<ffffffff811657a3>] iput_final+0xd3/0x1f0
[ 127.186840] [<ffffffff811658f9>] iput+0x39/0x50
[ 127.186842] [<ffffffff81162708>] d_kill+0xf8/0x130
[ 127.186843] [<ffffffff81162812>] dput+0xd2/0x1a0
[ 127.186845] [<ffffffff8114e2d0>] __fput+0x170/0x230
[ 127.186848] [<ffffffff81236e0e>] ? rb_erase+0xce/0x150
[ 127.186849] [<ffffffff8114e3ad>] fput+0x1d/0x30
[ 127.186851] [<ffffffff81117db7>] remove_vma+0x37/0x80
[ 127.186853] [<ffffffff81119182>] do_munmap+0x2d2/0x360
[ 127.186855] [<ffffffff811cc639>] sys_shmdt+0xc9/0x170
[ 127.186857] [<ffffffff81410a39>] system_call_fastpath+0x16/0x1b
[ 127.186858] Code: 0f 1f 44 00 00 48 8b 43 08 48 8b 00 48 8b 40 28 8b b0 40 03 00 00 85 f6 0f 88 df fe ff ff 48 89 df e8 e7 cb 05 00 e9 d2 fe ff ff <0f> 0b 55 83 e2 fd 48 89 e5 48 83 ec 30 48 89 5d d8 4c 89 65 e0
[ 127.186868] RIP [<ffffffff810ed6ce>] __delete_from_page_cache+0x15e/0x160
[ 127.186870] RSP <ffff8804144b5c08>
[ 127.186871] ---[ end trace 7cbac5d1db69f426 ]---
The bug is a race and not always easy to reproduce. To reproduce it I was
doing the following on a single socket I7-based machine with 16G of RAM.
$ hugeadm --pool-pages-max DEFAULT:13G
$ echo $((18*1048576*1024)) > /proc/sys/kernel/shmmax
$ echo $((18*1048576*1024)) > /proc/sys/kernel/shmall
$ for i in `seq 1 9000`; do ./hugetlbfs-test; done
On my particular machine, it usually triggers within 10 minutes but
enabling debug options can change the timing such that it never hits.
Once the bug is triggered, the machine is in trouble and needs to be
rebooted. The machine will respond but processes accessing proc like "ps
aux" will hang due to the BUG_ON. shutdown will also hang and needs a
hard reset or a sysrq-b.
The basic problem is a race between page table sharing and teardown. For
the most part page table sharing depends on i_mmap_mutex. In some cases,
it is also taking the mm->page_table_lock for the PTE updates but with
shared page tables, it is the i_mmap_mutex that is more important.
Unfortunately it appears to be also insufficient. Consider the following
situation
Process A Process B
hugetlb_fault shmdt
LockWrite(mmap_sem)
do_munmap
unmap_region
unmap_vmas
unmap_single_vma
unmap_hugepage_range
Lock(i_mmap_mutex)
Lock(mm->page_table_lock)
huge_pmd_unshare/unmap tables <--- (1)
Unlock(mm->page_table_lock)
Unlock(i_mmap_mutex)
huge_pte_alloc ...
Lock(i_mmap_mutex) ...
vma_prio_walk, find svma, spte ...
Lock(mm->page_table_lock) ...
share spte ...
Unlock(mm->page_table_lock) ...
Unlock(i_mmap_mutex) ...
hugetlb_no_page <--- (2)
free_pgtables
unlink_file_vma
hugetlb_free_pgd_range
remove_vma_list
In this scenario, it is possible for Process A to share page tables with
Process B that is trying to tear them down. The i_mmap_mutex on its own
does not prevent Process A walking Process B's page tables. At (1) above,
the page tables are not shared yet so it unmaps the PMDs. Process A sets
up page table sharing and at (2) faults a new entry. Process B then trips
up on it in free_pgtables.
This patch fixes the problem by adding a new function
__unmap_hugepage_range_final that is only called when the VMA is about to
be destroyed. This function clears VM_MAYSHARE during
unmap_hugepage_range() under the i_mmap_mutex. This makes the VMA
ineligible for sharing and avoids the race. Superficially this looks like
it would then be vunerable to truncate and madvise issues but hugetlbfs
has its own truncate handlers so does not use unmap_mapping_range() and
does not support madvise(DONTNEED).
This should be treated as a -stable candidate if it is merged.
Test program is as follows. The test case was mostly written by Michal
Hocko with a few minor changes to reproduce this bug.
==== CUT HERE ====
static size_t huge_page_size = (2UL << 20);
static size_t nr_huge_page_A = 512;
static size_t nr_huge_page_B = 5632;
unsigned int get_random(unsigned int max)
struct timeval tv;
gettimeofday(&tv, NULL);
srandom(tv.tv_usec);
return random() % max;
static void play(void *addr, size_t size)
unsigned char *start = addr,
*end = start + size,
*a;
start += get_random(size/2);
/* we could itterate on huge pages but let's give it more time. */
for (a = start; a < end; a += 4096)
*a = 0;
int main(int argc, char **argv)
key_t key = IPC_PRIVATE;
size_t sizeA = nr_huge_page_A * huge_page_size;
size_t sizeB = nr_huge_page_B * huge_page_size;
int shmidA, shmidB;
void *addrA = NULL, *addrB = NULL;
int nr_children = 300, n = 0;
if ((shmidA = shmget(key, sizeA, IPC_CREAT|SHM_HUGETLB|0660)) == -1) {
perror("shmget:");
return 1;
if ((addrA = shmat(shmidA, addrA, SHM_R|SHM_W)) == (void *)-1UL) {
perror("shmat");
return 1;
if ((shmidB = shmget(key, sizeB, IPC_CREAT|SHM_HUGETLB|0660)) == -1) {
perror("shmget:");
return 1;
if ((addrB = shmat(shmidB, addrB, SHM_R|SHM_W)) == (void *)-1UL) {
perror("shmat");
return 1;
fork_child:
switch(fork()) {
case 0:
switch (n%3) {
case 0:
play(addrA, sizeA);
break;
case 1:
play(addrB, sizeB);
break;
case 2:
break;
break;
case -1:
perror("fork:");
break;
default:
if (++n < nr_children)
goto fork_child;
play(addrA, sizeA);
break;
shmdt(addrA);
shmdt(addrB);
do {
wait(NULL);
} while (--n > 0);
shmctl(shmidA, IPC_RMID, NULL);
shmctl(shmidB, IPC_RMID, NULL);
return 0;
[akpm@linux-foundation.org: name the declaration's args, fix CONFIG_HUGETLBFS=n build]
- Adjust context
- Drop the mmu_gather * parameters]
commit b1c12cbcd0a02527c180a862e8971e249d3b347d upstream.
Stable note: Not tracked in Bugzilla. [get|put]_mems_allowed() is extremely
expensive and severely impacted page allocator performance. This
is part of a series of patches that reduce page allocator overhead.
Fix a gcc warning (and bug?) introduced in cc9a6c877 ("cpuset: mm: reduce
large amounts of memory barrier related damage v3")
Local variable "page" can be uninitialized if the nodemask from vma policy
does not intersects with nodemask from cpuset. Even if it doesn't happens
it is better to initialize this variable explicitly than to introduce
a kernel oops in a weird corner case.
mm/hugetlb.c: In function `alloc_huge_page':
mm/hugetlb.c:1135:5: warning: `page' may be used uninitialized in this function
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
commit cc9a6c8776615f9c194ccf0b63a0aa5628235545 upstream.
Commit c0ff7453bb5c ("cpuset,mm: fix no node to alloc memory when
changing cpuset's mems") wins a super prize for the largest number of
memory barriers entered into fast paths for one commit.
[get|put]_mems_allowed is incredibly heavy with pairs of full memory
barriers inserted into a number of hot paths. This was detected while
investigating at large page allocator slowdown introduced some time
after 2.6.32. The largest portion of this overhead was shown by
oprofile to be at an mfence introduced by this commit into the page
allocator hot path.
For extra style points, the commit introduced the use of yield() in an
implementation of what looks like a spinning mutex.
This patch replaces the full memory barriers on both read and write
sides with a sequence counter with just read barriers on the fast path
side. This is much cheaper on some architectures, including x86. The
main bulk of the patch is the retry logic if the nodemask changes in a
manner that can cause a false failure.
While updating the nodemask, a check is made to see if a false failure
is a risk. If it is, the sequence number gets bumped and parallel
allocators will briefly stall while the nodemask update takes place.
In a page fault test microbenchmark, oprofile samples from
__alloc_pages_nodemask went from 4.53% of all samples to 1.15%. The
actual results were
3.3.0-rc3 3.3.0-rc3
rc3-vanilla nobarrier-v2r1
Clients 1 UserTime 0.07 ( 0.00%) 0.08 (-14.19%)
Clients 2 UserTime 0.07 ( 0.00%) 0.07 ( 2.72%)
Clients 4 UserTime 0.08 ( 0.00%) 0.07 ( 3.29%)
Clients 1 SysTime 0.70 ( 0.00%) 0.65 ( 6.65%)
Clients 2 SysTime 0.85 ( 0.00%) 0.82 ( 3.65%)
Clients 4 SysTime 1.41 ( 0.00%) 1.41 ( 0.32%)
Clients 1 WallTime 0.77 ( 0.00%) 0.74 ( 4.19%)
Clients 2 WallTime 0.47 ( 0.00%) 0.45 ( 3.73%)
Clients 4 WallTime 0.38 ( 0.00%) 0.37 ( 1.58%)
Clients 1 Flt/sec/cpu 497620.28 ( 0.00%) 520294.53 ( 4.56%)
Clients 2 Flt/sec/cpu 414639.05 ( 0.00%) 429882.01 ( 3.68%)
Clients 4 Flt/sec/cpu 257959.16 ( 0.00%) 258761.48 ( 0.31%)
Clients 1 Flt/sec 495161.39 ( 0.00%) 517292.87 ( 4.47%)
Clients 2 Flt/sec 820325.95 ( 0.00%) 850289.77 ( 3.65%)
Clients 4 Flt/sec 1020068.93 ( 0.00%) 1022674.06 ( 0.26%)
MMTests Statistics: duration
Sys Time Running Test (seconds) 135.68 132.17
User+Sys Time Running Test (seconds) 164.2 160.13
Total Elapsed Time (seconds) 123.46 120.87
The overall improvement is small but the System CPU time is much
improved and roughly in correlation to what oprofile reported (these
performance figures are without profiling so skew is expected). The
actual number of page faults is noticeably improved.
For benchmarks like kernel builds, the overall benefit is marginal but
the system CPU time is slightly reduced.
To test the actual bug the commit fixed I opened two terminals. The
first ran within a cpuset and continually ran a small program that
faulted 100M of anonymous data. In a second window, the nodemask of the
cpuset was continually randomised in a loop.
Without the commit, the program would fail every so often (usually
within 10 seconds) and obviously with the commit everything worked fine.
With this patch applied, it also worked fine so the fix should be
functionally equivalent.
Cc: Miao Xie <miaox@cn.fujitsu.com>
[bwh: Forward-ported from 3.0 to 3.2: apply the upstream changes
to get_any_partial()]
commit 90481622d75715bfcb68501280a917dbfe516029 upstream.
hugetlbfs_{get,put}_quota() are badly named. They don't interact with the
general quota handling code, and they don't much resemble its behaviour.
Rather than being about maintaining limits on on-disk block usage by
particular users, they are instead about maintaining limits on in-memory
page usage (including anonymous MAP_PRIVATE copied-on-write pages)
associated with a particular hugetlbfs filesystem instance.
Worse, they work by having callbacks to the hugetlbfs filesystem code from
the low-level page handling code, in particular from free_huge_page().
This is a layering violation of itself, but more importantly, if the
kernel does a get_user_pages() on hugepages (which can happen from KVM
amongst others), then the free_huge_page() can be delayed until after the
associated inode has already been freed. If an unmount occurs at the
wrong time, even the hugetlbfs superblock where the "quota" limits are
stored may have been freed.
Andrew Barry proposed a patch to fix this by having hugepages, instead of
storing a pointer to their address_space and reaching the superblock from
there, had the hugepages store pointers directly to the superblock,
bumping the reference count as appropriate to avoid it being freed.
Andrew Morton rejected that version, however, on the grounds that it made
the existing layering violation worse.
This is a reworked version of Andrew's patch, which removes the extra, and
some of the existing, layering violation. It works by introducing the
concept of a hugepage "subpool" at the lower hugepage mm layer - that is a
finite logical pool of hugepages to allocate from. hugetlbfs now creates
a subpool for each filesystem instance with a page limit set, and a
pointer to the subpool gets added to each allocated hugepage, instead of
the address_space pointer used now. The subpool has its own lifetime and
is only freed once all pages in it _and_ all other references to it (i.e.
superblocks) are gone.
subpools are optional - a NULL subpool pointer is taken by the code to
mean that no subpool limits are in effect.
Previous discussion of this bug found in: "Fix refcounting in hugetlbfs
quota handling.". See: https://lkml.org/lkml/2011/8/11/28 or
http://marc.info/?l=linux-mm&m=126928970510627&w=1
v2: Fixed a bug spotted by Hillf Danton, and removed the extra parameter to
alloc_huge_page() - since it already takes the vma, it is not necessary.
Signed-off-by: Andrew Barry <abarry@cray.com>
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Cc: Minchan Kim <minchan.kim@gmail.com>
[bwh: Backported to 3.2: adjust context to apply after commit
c50ac050811d6485616a193eb0f37bfbd191cc89 'hugetlb: fix resv_map leak in
error path', backported in 3.2.20]
commit 4523e1458566a0e8ecfaff90f380dd23acc44d27 upstream.
hugetlb_reserve_pages() can be used for either normal file-backed
hugetlbfs mappings, or MAP_HUGETLB. In the MAP_HUGETLB, semi-anonymous
mode, there is not a VMA around. The new call to resv_map_put() assumed
that there was, and resulted in a NULL pointer dereference:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000030
IP: vma_resv_map+0x9/0x30
PGD 141453067 PUD 1421e1067 PMD 0
Oops: 0000 [#1] PREEMPT SMP
Pid: 14006, comm: trinity-child6 Not tainted 3.4.0+ #36
RIP: vma_resv_map+0x9/0x30
Process trinity-child6 (pid: 14006, threadinfo ffff8801414e0000, task ffff8801414f26b0)
Call Trace:
resv_map_put+0xe/0x40
hugetlb_reserve_pages+0xa6/0x1d0
hugetlb_file_setup+0x102/0x2c0
newseg+0x115/0x360
ipcget+0x1ce/0x310
sys_shmget+0x5a/0x60
This was reported by Dave Jones, but was reproducible with the
libhugetlbfs test cases, so shame on me for not running them in the
first place.
With this, the oops is gone, and the output of libhugetlbfs's
run_tests.py is identical to plain 3.4 again.
[ Marked for stable, since this was introduced by commit c50ac050811d
("hugetlb: fix resv_map leak in error path") which was also marked for
stable ]
Reported-by: Dave Jones <davej@redhat.com>
commit c50ac050811d6485616a193eb0f37bfbd191cc89 upstream.
When called for anonymous (non-shared) mappings, hugetlb_reserve_pages()
does a resv_map_alloc(). It depends on code in hugetlbfs's
vm_ops->close() to release that allocation.
However, in the mmap() failure path, we do a plain unmap_region() without
the remove_vma() which actually calls vm_ops->close().
This is a decent fix. This leak could get reintroduced if new code (say,
after hugetlb_reserve_pages() in hugetlbfs_file_mmap()) decides to return
an error. But, I think it would have to unroll the reservation anyway.
Christoph's test case:
http://marc.info/?l=linux-mm&m=133728900729735
Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com>
[Christoph Lameter: I have rediffed the patch against 2.6.32 and 3.2.0.]
commit 4998a6c0edce7fae9c0a5463f6ec3fa585258ee7 upstream.
Commit 66aebce747eaf ("hugetlb: fix race condition in hugetlb_fault()")
added code to avoid a race condition by elevating the page refcount in
hugetlb_fault() while calling hugetlb_cow().
However, one code path in hugetlb_cow() includes an assertion that the
page count is 1, whereas it may now also have the value 2 in this path.
The consensus is that this BUG_ON has served its purpose, so rather than
extending it to cover both cases, we just remove it.
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
Acked-by: Mel Gorman <mel@csn.ul.ie>
commit 66aebce747eaf9bc456bf1f1b217d8db843031d0 upstream.
The race is as follows:
Suppose a multi-threaded task forks a new process (on cpu A), thus
bumping up the ref count on all the pages. While the fork is occurring
(and thus we have marked all the PTEs as read-only), another thread in
the original process (on cpu B) tries to write to a huge page, taking an
access violation from the write-protect and calling hugetlb_cow(). Now,
suppose the fork() fails. It will undo the COW and decrement the ref
count on the pages, so the ref count on the huge page drops back to 1.
Meanwhile hugetlb_cow() also decrements the ref count by one on the
original page, since the original address space doesn't need it any
more, having copied a new page to replace the original page. This
leaves the ref count at zero, and when we call unlock_page(), we panic.
fork on CPU A fault on CPU B
down_write(&parent->mmap_sem);
down_write_nested(&child->mmap_sem);
while duplicating vmas
if error
break;
up_write(&child->mmap_sem);
up_write(&parent->mmap_sem); ...
down_read(&parent->mmap_sem);
lock_page(page);
handle COW
page_mapcount(old_page) == 2
alloc and prepare new_page
handle error
page_remove_rmap(page);
put_page(page);
fold new_page into pte
put_page(page);
oops ==> unlock_page(page);
up_read(&parent->mmap_sem);
The solution is to take an extra reference to the page while we are
holding the lock on it.
If a huge page is enqueued under the protection of hugetlb_lock, then the
operation is atomic and safe.
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: <stable@vger.kernel.org> [2.6.37+]
Commit 70b50f94f1644 ("mm: thp: tail page refcounting fix") keeps all
page_tail->_count zero at all times. But the current kernel does not
set page_tail->_count to zero if a 1GB page is utilized. So when an
IOMMU 1GB page is used by KVM, it wil result in a kernel oops because a
tail page's _count does not equal zero.
kernel BUG at include/linux/mm.h:386!
Call Trace:
gup_pud_range+0xb8/0x19d
get_user_pages_fast+0xcb/0x192
? trace_hardirqs_off+0xd/0xf
hva_to_pfn+0x119/0x2f2
gfn_to_pfn_memslot+0x2c/0x2e
kvm_iommu_map_pages+0xfd/0x1c1
kvm_iommu_map_memslots+0x7c/0xbd
kvm_iommu_map_guest+0xaa/0xbf
kvm_vm_ioctl_assigned_device+0x2ef/0xa47
kvm_vm_ioctl+0x36c/0x3a2
do_vfs_ioctl+0x49e/0x4e4
sys_ioctl+0x5a/0x7c
RIP gup_huge_pud+0xf2/0x159
Signed-off-by: Youquan Song <youquan.song@intel.com>
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
If we fail to prepare an anon_vma, the {new, old}_page should be released,
or they will leak.
Fix coding style issues flagged by checkpatch.pl
Signed-off-by: Chris Forbes <chrisf@ijw.co.nz>
Acked-by: Eric B Munson <emunson@mgebm.net>
This is needed on HIGHMEM systems - we don't always have a virtual
address so store the physical address and map it in as needed.
[akpm@linux-foundation.org: cleanup]
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
When 1GB hugepages are allocated on a system, free(1) reports less
available memory than what really is installed in the box. Also, if the
total size of hugepages allocated on a system is over half of the total
memory size, CommitLimit becomes a negative number.
The problem is that gigantic hugepages (order > MAX_ORDER) can only be
allocated at boot with bootmem, thus its frames are not accounted to
'totalram_pages'. However, they are accounted to hugetlb_total_pages()
What happens to turn CommitLimit into a negative number is this
calculation, in fs/proc/meminfo.c:
allowed = ((totalram_pages - hugetlb_total_pages())
* sysctl_overcommit_ratio / 100) + total_swap_pages;
A similar calculation occurs in __vm_enough_memory() in mm/mmap.c.
Also, every vm statistic which depends on 'totalram_pages' will render
confusing values, as if system were 'missing' some part of its memory.
Impact of this bug:
When gigantic hugepages are allocated and sysctl_overcommit_memory ==
OVERCOMMIT_NEVER. In a such situation, __vm_enough_memory() goes through
the mentioned 'allowed' calculation and might end up mistakenly returning
-ENOMEM, thus forcing the system to start reclaiming pages earlier than it
would be ususal, and this could cause detrimental impact to overall
system's performance, depending on the workload.
Besides the aforementioned scenario, I can only think of this causing
annoyances with memory reports from /proc/meminfo and free(1).
[akpm@linux-foundation.org: standardize comment layout]
Reported-by: Russ Anderson <rja@sgi.com>
Signed-off-by: Rafael Aquini <aquini@linux.com>
Acked-by: Russ Anderson <rja@sgi.com>
Cc: <stable@kernel.org>
Al Viro observes that in the hugetlb case, handle_mm_fault() may return
a value of the kind ENOSPC when its caller is expecting a value of the
kind VM_FAULT_SIGBUS: fix alloc_huge_page()'s failure returns.
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Cc: stable@kernel.org
The type of vma->vm_flags is 'unsigned long'. Neither 'int' nor
'unsigned int'. This patch fixes such misuse.
[ Changed to use a typedef - we'll extend it to cover more cases
later, since there has been discussion about making it a 64-bit
type.. - Linus ]
Straightforward conversion of i_mmap_lock to a mutex.
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Namhyung Kim <namhyung@gmail.com>
Fast-forwarded to current state of Linus' tree as there are patches to be
applied for files that didn't exist on the old branch.
When the user inserts a negative value into /proc/sys/vm/nr_hugepages it
will cause the kernel to allocate as many hugepages as possible and to
then update /proc/meminfo to reflect this.
This changes the behavior so that the negative input will result in
nr_hugepages value being unchanged.
Signed-off-by: Petr Holasek <pholasek@redhat.com>
Signed-off-by: Anton Arapov <anton@redhat.com>
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
When parsing changes to the huge page pool sizes made from userspace via
the sysfs interface, bogus input values are being covered up by
nr_hugepages_store_common and nr_overcommit_hugepages_store returning 0
when strict_strtoul returns an error. This can cause an infinite loop in
the nr_hugepages_store code. This patch changes the return value for
these functions to -EINVAL when strict_strtoul returns an error.
Signed-off-by: Eric B Munson <emunson@mgebm.net>
Reported-by: CAI Qian <caiqian@redhat.com>
Cc: Eric B Munson <emunson@mgebm.net>
Cc: Nishanth Aravamudan <nacc@us.ibm.com>
Huge pages with order >= MAX_ORDER must be allocated at boot via the
kernel command line, they cannot be allocated or freed once the kernel is
up and running. Currently we allow values to be written to the sysfs and
sysctl files controling pool size for these huge page sizes. This patch
makes the store functions for nr_hugepages and nr_overcommit_hugepages
return -EINVAL when the pool for a page size >= MAX_ORDER is changed.
[akpm@linux-foundation.org: avoid multiple return paths in nr_hugepages_store_common()]
[caiqian@redhat.com: add checking in hugetlb_overcommit_handler()]
proc_doulongvec_minmax may fail if the given buffer doesn't represent a
valid number. If we provide something invalid we will initialize the
resulting value (nr_overcommit_huge_pages in this case) to a random value
from the stack.
The issue was introduced by a3d0c6aa when the default handler has been
replaced by the helper function where we do not check the return value.
Reproducer:
echo "" > /proc/sys/vm/nr_overcommit_hugepages
[akpm@linux-foundation.org: correctly propagate proc_doulongvec_minmax return code]
Cc: CAI Qian <caiqian@redhat.com>
The NODEMASK_ALLOC macro may dynamically allocate memory for its second
argument ('nodes_allowed' in this context).
In nr_hugepages_store_common() we may abort early if strict_strtoul()
fails, but in that case we do not free the memory already allocated to
'nodes_allowed', causing a memory leak.
This patch closes the leak by freeing the memory in the error path.
[akpm@linux-foundation.org: use NODEMASK_FREE, per Minchan Kim]
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Move the copy/clear_huge_page functions to common code to share between
hugetlb.c and huge_memory.c.
Have hugetlb_fault() call unlock_page(page) only if it had previously
called lock_page(page).
Setting CONFIG_DEBUG_VM=y and then running the libhugetlbfs test suite,
resulted in the tripping of VM_BUG_ON(!PageLocked(page)) in
unlock_page() having been called by hugetlb_fault() when page ==
pagecache_page. This patch remedied the problem.
Signed-off-by: Dean Nelson <dnelson@redhat.com>
Add missing spin_lock() of the page_table_lock before an error return in
hugetlb_cow(). Callers of hugtelb_cow() expect it to be held upon return.
This fixes a problem introduced with the hugetlb hwpoison handling
The user space SIGBUS signalling wants to know the size of the hugepage
that caused a HWPOISON fault.
Unfortunately the architecture page fault handlers do not have easy
access to the struct page.
Pass the information out in the fault error code instead.
I added a separate VM_FAULT_HWPOISON_LARGE bit for this case and encode
the hpage index in some free upper bits of the fault code. The small
page hwpoison keeps stays with the VM_FAULT_HWPOISON name to minimize
changes.
Also add code to hugetlb.h to convert that index into a page shift.
Will be used in a further patch.
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: fengguang.wu@intel.com
Fixes warning reported by Stephen Rothwell
mm/hugetlb.c:2950: warning: 'is_hugepage_on_freelist' defined but not used
for the !CONFIG_MEMORY_FAILURE case.
Currently error recovery for free hugepage works only for MF_COUNT_INCREASED.
This patch enables !MF_COUNT_INCREASED case.
Free hugepages can be handled directly by alloc_huge_page() and
dequeue_hwpoisoned_huge_page(), and both of them are protected
by hugetlb_lock, so there is no race between them.
Note that this patch defines the refcount of HWPoisoned hugepage
dequeued from freelist is 1, deviated from present 0, thereby we
can avoid race between unpoison and memory failure on free hugepage.
This is reasonable because unlikely to free buddy pages, free hugepage
is governed by hugetlbfs even after error handling finishes.
And it also makes unpoison code added in the later patch cleaner.
Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
Currently alloc_huge_page() raises page refcount outside hugetlb_lock.
but it causes race when dequeue_hwpoison_huge_page() runs concurrently
with alloc_huge_page().
To avoid it, this patch moves set_page_refcounted() in hugetlb_lock.
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Reviewed-by: Christoph Lameter <cl@linux.com>
This check is necessary to avoid race between dequeue and allocation,
which can cause a free hugepage to be dequeued twice and get kernel unstable.
This patch extends page migration code to support hugepage migration.
One of the potential users of this feature is soft offlining which
is triggered by memory corrected errors (added by the next patch.)
Todo:
- there are other users of page migration such as memory policy,
memory hotplug and memocy compaction.
They are not ready for hugepage support for now.
ChangeLog since v4:
- define migrate_huge_pages()
- remove changes on isolation/putback_lru_page()
ChangeLog since v2:
- refactor isolate/putback_lru_page() to handle hugepage
- add comment about race on unmap_and_move_huge_page()
ChangeLog since v1:
- divide migration code path for hugepage
- define routine checking migration swap entry for hugetlb
- replace "goto" with "if/else" in remove_migration_pte()
This patch modifies hugepage copy functions to have only destination
and source hugepages as arguments for later use.
The old ones are renamed from copy_{gigantic,huge}_page() to
copy_user_{gigantic,huge}_page().
This naming convention is consistent with that between copy_highpage()
and copy_user_highpage().
ChangeLog since v4:
- add blank line between local declaration and code
- remove unnecessary might_sleep()
ChangeLog since v2:
- change copy_huge_page() from macro to inline dummy function
to avoid compile warning when !CONFIG_HUGETLB_PAGE.
We can't use existing hugepage allocation functions to allocate hugepage
for page migration, because page migration can happen asynchronously with
the running processes and page migration users should call the allocation
function with physical addresses (not virtual addresses) as arguments.
ChangeLog since v3:
- unify alloc_buddy_huge_page() and alloc_buddy_huge_page_node()
ChangeLog since v2:
- remove unnecessary get/put_mems_allowed() (thanks to David Rientjes)
ChangeLog since v1:
- add comment on top of alloc_huge_page_no_vma()
Since the PageHWPoison() check is for avoiding hwpoisoned page remained
in pagecache mapping to the process, it should be done in "found in pagecache"
branch, not in the common path.
Otherwise, metadata corruption occurs if memory failure happens between
alloc_huge_page() and lock_page() because page fault fails with metadata
changes remained (such as refcount, mapcount, etc.)
This patch moves the check to "found in pagecache" branch and fix the problem.
ChangeLog since v2:
- remove retry check in "new allocation" path.
- make description more detailed
- change patch name from "HWPOISON, hugetlb: move PG_HWPoison bit check"
Reviewed-by: Wu Fengguang <fengguang.wu@intel.com>
The "if (!trylock_page)" block in the avoidcopy path of hugetlb_cow()
looks confusing and is buggy. Originally this trylock_page() was
intended to make sure that old_page is locked even when old_page !=
pagecache_page, because then only pagecache_page is locked.
This patch fixes it by moving page locking into hugetlb_fault().
Obviously, setting anon_vma for COWed hugepage should be done
by hugepage_add_new_anon_rmap() to scan vmas faster.
This patch fixes it.
Acked-by: Andrea Arcangeli <aarcange@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6
* 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6:
hugetlb: add missing unlock in avoidcopy path in hugetlb_cow()
hwpoison: rename CONFIG
HWPOISON, hugetlb: support hwpoison injection for hugepage
HWPOISON, hugetlb: detect hwpoison in hugetlb code
HWPOISON, hugetlb: isolate corrupted hugepage
HWPOISON, hugetlb: maintain mce_bad_pages in handling hugepage error
HWPOISON, hugetlb: set/clear PG_hwpoison bits on hugepage
HWPOISON, hugetlb: enable error handling path for hugepage
hugetlb, rmap: add reverse mapping for hugepage
hugetlb: move definition of is_vm_hugetlb_page() to hugepage_inline.h
Fix up trivial conflicts in mm/memory-failure.c
This patch fixes possible deadlock in hugepage lock_page()
by adding missing unlock_page().
libhugetlbfs test will hit this bug when the next patch in this
patchset ("hugetlb, HWPOISON: move PG_HWPoison bit check") is applied.
Acked-by: Fengguang Wu <fengguang.wu@intel.com>
This patch enables hwpoison injection through debug/hwpoison interfaces,
with which we can test memory error handling for free or reserved
hugepages (which cannot be tested by madvise() injector).
[AK: Export PageHuge too for the injection module]
This patch enables to block access to hwpoisoned hugepage and
also enables to block unmapping for it.
Dependency:
"HWPOISON, hugetlb: enable error handling path for hugepage"
