commit f231fe4235e22e18d847e05cbe705deaca56580a upstream.
Uninitialized memmaps contain garbage and in the worst case trigger
kernel BUGs, especially with CONFIG_PAGE_POISONING. They should not get
touched.
Let's make sure that we only consider online memory (managed by the
buddy) that has initialized memmaps. ZONE_DEVICE is not applicable.
page_zone() will call page_to_nid(), which will trigger
VM_BUG_ON_PGFLAGS(PagePoisoned(page), page) with CONFIG_PAGE_POISONING
and CONFIG_DEBUG_VM_PGFLAGS when called on uninitialized memmaps. This
can be the case when an offline memory block (e.g., never onlined) is
spanned by a zone.
Note: As explained by Michal in [1], alloc_contig_range() will verify
the range. So it boils down to the wrong access in this function.
[1] http://lkml.kernel.org/r/20180423000943.GO17484@dhcp22.suse.cz
Link: http://lkml.kernel.org/r/20191015120717.4858-1-david@redhat.com
Fixes: f1dd2cd13c4b ("mm, memory_hotplug: do not associate hotadded memory to zones until online") [visible after d0dc12e86b319]
Signed-off-by: David Hildenbrand <david@redhat.com>
Reported-by: Michal Hocko <mhocko@kernel.org>
Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com>
Cc: Anshuman Khandual <anshuman.khandual@arm.com>
Cc: <stable@vger.kernel.org> [4.13+]
[ Upstream commit 0919e1b69ab459e06df45d3ba6658d281962db80 ]
When a huge page is allocated, PagePrivate() is set if the allocation
consumed a reservation. When freeing a huge page, PagePrivate is checked.
If set, it indicates the reservation should be restored. PagePrivate
being set at free huge page time mostly happens on error paths.
When huge page reservations are created, a check is made to determine if
the mapping is associated with an explicitly mounted filesystem. If so,
pages are also reserved within the filesystem. The default action when
freeing a huge page is to decrement the usage count in any associated
explicitly mounted filesystem. However, if the reservation is to be
restored the reservation/use count within the filesystem should not be
decrementd. Otherwise, a subsequent page allocation and free for the same
mapping location will cause the file filesystem usage to go 'negative'.
Filesystem Size Used Avail Use% Mounted on
nodev 4.0G -4.0M 4.1G - /opt/hugepool
To fix, when freeing a huge page do not adjust filesystem usage if
PagePrivate() is set to indicate the reservation should be restored.
I did not cc stable as the problem has been around since reserves were
added to hugetlbfs and nobody has noticed.
Link: http://lkml.kernel.org/r/20190328234704.27083-2-mike.kravetz@oracle.com
Signed-off-by: Mike Kravetz <mike.kravetz@oracle.com>
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Davidlohr Bueso <dave@stgolabs.net>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: "Kirill A . Shutemov" <kirill.shutemov@linux.intel.com>
commit 1b426bac66e6cc83c9f2d92b96e4e72acf43419a upstream.
hugetlb uses a fault mutex hash table to prevent page faults of the
same pages concurrently. The key for shared and private mappings is
different. Shared keys off address_space and file index. Private keys
off mm and virtual address. Consider a private mappings of a populated
hugetlbfs file. A fault will map the page from the file and if needed
do a COW to map a writable page.
Hugetlbfs hole punch uses the fault mutex to prevent mappings of file
pages. It uses the address_space file index key. However, private
mappings will use a different key and could race with this code to map
the file page. This causes problems (BUG) for the page cache remove
code as it expects the page to be unmapped. A sample stack is:
page dumped because: VM_BUG_ON_PAGE(page_mapped(page))
kernel BUG at mm/filemap.c:169!
RIP: 0010:unaccount_page_cache_page+0x1b8/0x200
Call Trace:
__delete_from_page_cache+0x39/0x220
delete_from_page_cache+0x45/0x70
remove_inode_hugepages+0x13c/0x380
? __add_to_page_cache_locked+0x162/0x380
hugetlbfs_fallocate+0x403/0x540
? _cond_resched+0x15/0x30
? __inode_security_revalidate+0x5d/0x70
? selinux_file_permission+0x100/0x130
vfs_fallocate+0x13f/0x270
ksys_fallocate+0x3c/0x80
__x64_sys_fallocate+0x1a/0x20
do_syscall_64+0x5b/0x180
entry_SYSCALL_64_after_hwframe+0x44/0xa9
There seems to be another potential COW issue/race with this approach
of different private and shared keys as noted in commit 8382d914ebf7
("mm, hugetlb: improve page-fault scalability").
Since every hugetlb mapping (even anon and private) is actually a file
mapping, just use the address_space index key for all mappings. This
results in potentially more hash collisions. However, this should not
be the common case.
Link: http://lkml.kernel.org/r/20190328234704.27083-3-mike.kravetz@oracle.com
Link: http://lkml.kernel.org/r/20190412165235.t4sscoujczfhuiyt@linux-r8p5
Fixes: b5cec28d36f5 ("hugetlbfs: truncate_hugepages() takes a range of pages")
Reviewed-by: Davidlohr Bueso <dbueso@suse.de>
commit 8fde12ca79aff9b5ba951fce1a2641901b8d8e64 upstream.
If the page refcount wraps around past zero, it will be freed while
there are still four billion references to it. One of the possible
avenues for an attacker to try to make this happen is by doing direct IO
on a page multiple times. This patch makes get_user_pages() refuse to
take a new page reference if there are already more than two billion
references to the page.
Reported-by: Jann Horn <jannh@google.com>
Acked-by: Matthew Wilcox <willy@infradead.org>
Cc: stable@kernel.org
commit cb6acd01e2e43fd8bad11155752b7699c3d0fb76 upstream.
hugetlb pages should only be migrated if they are 'active'. The
routines set/clear_page_huge_active() modify the active state of hugetlb
pages.
When a new hugetlb page is allocated at fault time, set_page_huge_active
is called before the page is locked. Therefore, another thread could
race and migrate the page while it is being added to page table by the
fault code. This race is somewhat hard to trigger, but can be seen by
strategically adding udelay to simulate worst case scheduling behavior.
Depending on 'how' the code races, various BUG()s could be triggered.
To address this issue, simply delay the set_page_huge_active call until
after the page is successfully added to the page table.
Hugetlb pages can also be leaked at migration time if the pages are
associated with a file in an explicitly mounted hugetlbfs filesystem.
For example, consider a two node system with 4GB worth of huge pages
available. A program mmaps a 2G file in a hugetlbfs filesystem. It
then migrates the pages associated with the file from one node to
another. When the program exits, huge page counts are as follows:
node0
1024 free_hugepages
1024 nr_hugepages
node1
0 free_hugepages
1024 nr_hugepages
nodev 4.0G 2.0G 2.0G 50% /var/opt/hugepool
That is as expected. 2G of huge pages are taken from the free_hugepages
counts, and 2G is the size of the file in the explicitly mounted
filesystem. If the file is then removed, the counts become:
node0
1024 free_hugepages
1024 nr_hugepages
node1
1024 free_hugepages
1024 nr_hugepages
Note that the filesystem still shows 2G of pages used, while there
actually are no huge pages in use. The only way to 'fix' the filesystem
accounting is to unmount the filesystem
If a hugetlb page is associated with an explicitly mounted filesystem,
this information in contained in the page_private field. At migration
time, this information is not preserved. To fix, simply transfer
page_private from old to new page at migration time if necessary.
There is a related race with removing a huge page from a file and
migration. When a huge page is removed from the pagecache, the
page_mapping() field is cleared, yet page_private remains set until the
page is actually freed by free_huge_page(). A page could be migrated
while in this state. However, since page_mapping() is not set the
hugetlbfs specific routine to transfer page_private is not called and we
leak the page count in the filesystem.
To fix that, check for this condition before migrating a huge page. If
the condition is detected, return EBUSY for the page.
Link: http://lkml.kernel.org/r/74510272-7319-7372-9ea6-ec914734c179@oracle.com
Link: http://lkml.kernel.org/r/20190212221400.3512-1-mike.kravetz@oracle.com
Fixes: bcc54222309c ("mm: hugetlb: introduce page_huge_active")
Cc: Mel Gorman <mgorman@techsingularity.net>
[mike.kravetz@oracle.com: v2]
Link: http://lkml.kernel.org/r/7534d322-d782-8ac6-1c8d-a8dc380eb3ab@oracle.com
[mike.kravetz@oracle.com: update comment and changelog]
Link: http://lkml.kernel.org/r/420bcfd6-158b-38e4-98da-26d0cd85bd01@oracle.com
commit 9e368259ad988356c4c95150fafd1a06af095d98 upstream.
Patch series "userfaultfd shmem updates".
Jann found two bugs in the userfaultfd shmem MAP_SHARED backend: the
lack of the VM_MAYWRITE check and the lack of i_size checks.
Then looking into the above we also fixed the MAP_PRIVATE case.
Hugh by source review also found a data loss source if UFFDIO_COPY is
used on shmem MAP_SHARED PROT_READ mappings (the production usages
incidentally run with PROT_READ|PROT_WRITE, so the data loss couldn't
happen in those production usages like with QEMU).
The whole patchset is marked for stable.
We verified QEMU postcopy live migration with guest running on shmem
MAP_PRIVATE run as well as before after the fix of shmem MAP_PRIVATE.
Regardless if it's shmem or hugetlbfs or MAP_PRIVATE or MAP_SHARED, QEMU
unconditionally invokes a punch hole if the guest mapping is filebacked
and a MADV_DONTNEED too (needed to get rid of the MAP_PRIVATE COWs and
for the anon backend).
This patch (of 5):
We internally used EFAULT to communicate with the caller, switch to
ENOENT, so EFAULT can be used as a non internal retval.
Link: http://lkml.kernel.org/r/20181126173452.26955-2-aarcange@redhat.com
Fixes: 4c27fe4c4c84 ("userfaultfd: shmem: add shmem_mcopy_atomic_pte for userfaultfd support")
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Reviewed-by: Mike Rapoport <rppt@linux.ibm.com>
Reviewed-by: Hugh Dickins <hughd@google.com>
Cc: Mike Kravetz <mike.kravetz@oracle.com>
Cc: Jann Horn <jannh@google.com>
Cc: Peter Xu <peterx@redhat.com>
Cc: "Dr. David Alan Gilbert" <dgilbert@redhat.com>
Cc: stable@vger.kernel.org
commit 5e41540c8a0f0e98c337dda8b391e5dda0cde7cf upstream.
This bug has been experienced several times by the Oracle DB team. The
BUG is in remove_inode_hugepages() as follows:
* If page is mapped, it was faulted in after being
* unmapped in caller. Unmap (again) now after taking
* the fault mutex. The mutex will prevent faults
* until we finish removing the page.
* This race can only happen in the hole punch case.
* Getting here in a truncate operation is a bug.
if (unlikely(page_mapped(page))) {
BUG_ON(truncate_op);
In this case, the elevated map count is not the result of a race.
Rather it was incorrectly incremented as the result of a bug in the huge
pmd sharing code. Consider the following:
- Process A maps a hugetlbfs file of sufficient size and alignment
(PUD_SIZE) that a pmd page could be shared.
- Process B maps the same hugetlbfs file with the same size and
alignment such that a pmd page is shared.
- Process B then calls mprotect() to change protections for the mapping
with the shared pmd. As a result, the pmd is 'unshared'.
- Process B then calls mprotect() again to chage protections for the
mapping back to their original value. pmd remains unshared.
- Process B then forks and process C is created. During the fork
process, we do dup_mm -> dup_mmap -> copy_page_range to copy page
tables. Copying page tables for hugetlb mappings is done in the
routine copy_hugetlb_page_range.
In copy_hugetlb_page_range(), the destination pte is obtained by:
dst_pte = huge_pte_alloc(dst, addr, sz);
If pmd sharing is possible, the returned pointer will be to a pte in an
existing page table. In the situation above, process C could share with
either process A or process B. Since process A is first in the list,
the returned pte is a pointer to a pte in process A's page table.
However, the check for pmd sharing in copy_hugetlb_page_range is:
/* If the pagetables are shared don't copy or take references */
if (dst_pte == src_pte)
continue;
Since process C is sharing with process A instead of process B, the
above test fails. The code in copy_hugetlb_page_range which follows
assumes dst_pte points to a huge_pte_none pte. It copies the pte entry
from src_pte to dst_pte and increments this map count of the associated
page. This is how we end up with an elevated map count.
To solve, check the dst_pte entry for huge_pte_none. If !none, this
implies PMD sharing so do not copy.
Link: http://lkml.kernel.org/r/20181105212315.14125-1-mike.kravetz@oracle.com
Fixes: c5c99429fa57 ("fix hugepages leak due to pagetable page sharing")
Cc: Prakash Sangappa <prakash.sangappa@oracle.com>
commit 22146c3ce98962436e401f7b7016a6f664c9ffb5 upstream.
Some test systems were experiencing negative huge page reserve counts and
incorrect file block counts. This was traced to /proc/sys/vm/drop_caches
removing clean pages from hugetlbfs file pagecaches. When non-hugetlbfs
explicit code removes the pages, the appropriate accounting is not
performed.
This can be recreated as follows:
fallocate -l 2M /dev/hugepages/foo
echo 1 > /proc/sys/vm/drop_caches
grep -i huge /proc/meminfo
AnonHugePages: 0 kB
ShmemHugePages: 0 kB
HugePages_Total: 2048
HugePages_Free: 2047
HugePages_Rsvd: 18446744073709551615
HugePages_Surp: 0
Hugepagesize: 2048 kB
Hugetlb: 4194304 kB
ls -lsh /dev/hugepages/foo
4.0M -rw-r--r--. 1 root root 2.0M Oct 17 20:05 /dev/hugepages/foo
To address this issue, dirty pages as they are added to pagecache. This
can easily be reproduced with fallocate as shown above. Read faulted
pages will eventually end up being marked dirty. But there is a window
where they are clean and could be impacted by code such as drop_caches.
So, just dirty them all as they are added to the pagecache.
Link: http://lkml.kernel.org/r/b5be45b8-5afe-56cd-9482-28384699a049@oracle.com
Fixes: 6bda666a03f0 ("hugepages: fold find_or_alloc_pages into huge_no_page()")
Acked-by: Mihcla Hocko <mhocko@suse.com>
Reviewed-by: Khalid Aziz <khalid.aziz@oracle.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: "Aneesh Kumar K . V" <aneesh.kumar@linux.vnet.ibm.com>
commit 017b1660df89f5fb4bfe66c34e35f7d2031100c7 upstream.
The page migration code employs try_to_unmap() to try and unmap the source
page. This is accomplished by using rmap_walk to find all vmas where the
page is mapped. This search stops when page mapcount is zero. For shared
PMD huge pages, the page map count is always 1 no matter the number of
mappings. Shared mappings are tracked via the reference count of the PMD
page. Therefore, try_to_unmap stops prematurely and does not completely
unmap all mappings of the source page.
This problem can result is data corruption as writes to the original
source page can happen after contents of the page are copied to the target
page. Hence, data is lost.
This problem was originally seen as DB corruption of shared global areas
after a huge page was soft offlined due to ECC memory errors. DB
developers noticed they could reproduce the issue by (hotplug) offlining
memory used to back huge pages. A simple testcase can reproduce the
problem by creating a shared PMD mapping (note that this must be at least
PUD_SIZE in size and PUD_SIZE aligned (1GB on x86)), and using
migrate_pages() to migrate process pages between nodes while continually
writing to the huge pages being migrated.
To fix, have the try_to_unmap_one routine check for huge PMD sharing by
calling huge_pmd_unshare for hugetlbfs huge pages. If it is a shared
mapping it will be 'unshared' which removes the page table entry and drops
the reference on the PMD page. After this, flush caches and TLB.
mmu notifiers are called before locking page tables, but we can not be
sure of PMD sharing until page tables are locked. Therefore, check for
the possibility of PMD sharing before locking so that notifiers can
prepare for the worst possible case.
Link: http://lkml.kernel.org/r/20180823205917.16297-2-mike.kravetz@oracle.com
[mike.kravetz@oracle.com: make _range_in_vma() a static inline]
Link: http://lkml.kernel.org/r/6063f215-a5c8-2f0c-465a-2c515ddc952d@oracle.com
Fixes: 39dde65c9940 ("shared page table for hugetlb page")
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Jerome Glisse <jglisse@redhat.com>
commit 520495fe96d74e05db585fc748351e0504d8f40d upstream.
When booting with very large numbers of gigantic (i.e. 1G) pages, the
operations in the loop of gather_bootmem_prealloc, and specifically
prep_compound_gigantic_page, takes a very long time, and can cause a
softlockup if enough pages are requested at boot.
For example booting with 3844 1G pages requires prepping
(set_compound_head, init the count) over 1 billion 4K tail pages, which
takes considerable time.
Add a cond_resched() to the outer loop in gather_bootmem_prealloc() to
prevent this lockup.
Tested: Booted with softlockup_panic=1 hugepagesz=1G hugepages=3844 and
no softlockup is reported, and the hugepages are reported as
successfully setup.
Link: http://lkml.kernel.org/r/20180627214447.260804-1-cannonmatthews@google.com
Signed-off-by: Cannon Matthews <cannonmatthews@google.com>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Andres Lagar-Cavilla <andreslc@google.com>
Cc: Peter Feiner <pfeiner@google.com>
commit 63489f8e821144000e0bdca7e65a8d1cc23a7ee7 upstream.
A vma with vm_pgoff large enough to overflow a loff_t type when
converted to a byte offset can be passed via the remap_file_pages system
call. The hugetlbfs mmap routine uses the byte offset to calculate
reservations and file size.
A sequence such as:
mmap(0x20a00000, 0x600000, 0, 0x66033, -1, 0);
remap_file_pages(0x20a00000, 0x600000, 0, 0x20000000000000, 0);
will result in the following when task exits/file closed,
kernel BUG at mm/hugetlb.c:749!
Call Trace:
hugetlbfs_evict_inode+0x2f/0x40
evict+0xcb/0x190
__dentry_kill+0xcb/0x150
__fput+0x164/0x1e0
task_work_run+0x84/0xa0
exit_to_usermode_loop+0x7d/0x80
do_syscall_64+0x18b/0x190
entry_SYSCALL_64_after_hwframe+0x3d/0xa2
The overflowed pgoff value causes hugetlbfs to try to set up a mapping
with a negative range (end < start) that leaves invalid state which
causes the BUG.
The previous overflow fix to this code was incomplete and did not take
the remap_file_pages system call into account.
[mike.kravetz@oracle.com: v3]
Link: http://lkml.kernel.org/r/20180309002726.7248-1-mike.kravetz@oracle.com
[akpm@linux-foundation.org: include mmdebug.h]
[akpm@linux-foundation.org: fix -ve left shift count on sh]
Link: http://lkml.kernel.org/r/20180308210502.15952-1-mike.kravetz@oracle.com
Fixes: 045c7a3f53d9 ("hugetlbfs: fix offset overflow in hugetlbfs mmap")
Reported-by: Nic Losby <blurbdust@gmail.com>
Cc: Yisheng Xie <xieyisheng1@huawei.com>
commit f4f0a3d85b50a65a348e2b8635041d6b30f01deb upstream.
I made a mistake during converting hugetlb code to 5-level paging: in
huge_pte_alloc() we have to use p4d_alloc(), not p4d_offset().
Otherwise it leads to crash -- NULL-pointer dereference in pud_alloc()
if p4d table is not yet allocated.
It only can happen in 5-level paging mode. In 4-level paging mode
p4d_offset() always returns pgd, so we are fine.
Link: http://lkml.kernel.org/r/20171122121921.64822-1-kirill.shutemov@linux.intel.com
Fixes: c2febafc6773 ("mm: convert generic code to 5-level paging")
Acked-by: Vlastimil Babka <vbabka@suse.cz>
commit 31383c6865a578834dd953d9dbc88e6b19fe3997 upstream.
Patch series "device-dax: fix unaligned munmap handling"
When device-dax is operating in huge-page mode we want it to behave like
hugetlbfs and fail attempts to split vmas into unaligned ranges. It
would be messy to teach the munmap path about device-dax alignment
constraints in the same (hstate) way that hugetlbfs communicates this
constraint. Instead, these patches introduce a new ->split() vm
operation.
This patch (of 2):
The device-dax interface has similar constraints as hugetlbfs in that it
requires the munmap path to unmap in huge page aligned units. Rather
than add more custom vma handling code in __split_vma() introduce a new
vm operation to perform this vma specific check.
Link: http://lkml.kernel.org/r/151130418135.4029.6783191281930729710.stgit@dwillia2-desk3.amr.corp.intel.com
Fixes: dee410792419 ("/dev/dax, core: file operations and dax-mmap")
Cc: Jeff Moyer <jmoyer@redhat.com>
This oops:
kernel BUG at fs/hugetlbfs/inode.c:484!
RIP: remove_inode_hugepages+0x3d0/0x410
Call Trace:
hugetlbfs_setattr+0xd9/0x130
notify_change+0x292/0x410
do_truncate+0x65/0xa0
do_sys_ftruncate.constprop.3+0x11a/0x180
SyS_ftruncate+0xe/0x10
tracesys+0xd9/0xde
was caused by the lack of i_size check in hugetlb_mcopy_atomic_pte.
mmap() can still succeed beyond the end of the i_size after vmtruncate
zapped vmas in those ranges, but the faults must not succeed, and that
includes UFFDIO_COPY.
We could differentiate the retval to userland to represent a SIGBUS like
a page fault would do (vs SIGSEGV), but it doesn't seem very useful and
we'd need to pick a random retval as there's no meaningful syscall
retval that would differentiate from SIGSEGV and SIGBUS, there's just
-EFAULT.
Link: http://lkml.kernel.org/r/20171016223914.2421-2-aarcange@redhat.com
Cc: Mike Rapoport <rppt@linux.vnet.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull powerpc updates from Michael Ellerman:
"Nothing really major this release, despite quite a lot of activity.
Just lots of things all over the place.
Some things of note include:
- Access via perf to a new type of PMU (IMC) on Power9, which can
count both core events as well as nest unit events (Memory
controller etc).
- Optimisations to the radix MMU TLB flushing, mostly to avoid
unnecessary Page Walk Cache (PWC) flushes when the structure of the
tree is not changing.
- Reworks/cleanups of do_page_fault() to modernise it and bring it
closer to other architectures where possible.
- Rework of our page table walking so that THP updates only need to
send IPIs to CPUs where the affected mm has run, rather than all
CPUs.
- The size of our vmalloc area is increased to 56T on 64-bit hash MMU
systems. This avoids problems with the percpu allocator on systems
with very sparse NUMA layouts.
- STRICT_KERNEL_RWX support on PPC32.
- A new sched domain topology for Power9, to capture the fact that
pairs of cores may share an L2 cache.
- Power9 support for VAS, which is a new mechanism for accessing
coprocessors, and initial support for using it with the NX
compression accelerator.
- Major work on the instruction emulation support, adding support for
many new instructions, and reworking it so it can be used to
implement the emulation needed to fixup alignment faults.
- Support for guests under PowerVM to use the Power9 XIVE interrupt
controller.
And probably that many things again that are almost as interesting,
but I had to keep the list short. Plus the usual fixes and cleanups as
always.
Thanks to: Alexey Kardashevskiy, Alistair Popple, Andreas Schwab,
Aneesh Kumar K.V, Anju T Sudhakar, Arvind Yadav, Balbir Singh,
Benjamin Herrenschmidt, Bhumika Goyal, Breno Leitao, Bryant G. Ly,
Christophe Leroy, Cédric Le Goater, Dan Carpenter, Dou Liyang,
Frederic Barrat, Gautham R. Shenoy, Geliang Tang, Geoff Levand, Hannes
Reinecke, Haren Myneni, Ivan Mikhaylov, John Allen, Julia Lawall,
LABBE Corentin, Laurentiu Tudor, Madhavan Srinivasan, Markus Elfring,
Masahiro Yamada, Matt Brown, Michael Neuling, Murilo Opsfelder Araujo,
Nathan Fontenot, Naveen N. Rao, Nicholas Piggin, Oliver O'Halloran,
Paul Mackerras, Rashmica Gupta, Rob Herring, Rui Teng, Sam Bobroff,
Santosh Sivaraj, Scott Wood, Shilpasri G Bhat, Sukadev Bhattiprolu,
Suraj Jitindar Singh, Tobin C. Harding, Victor Aoqui"
* tag 'powerpc-4.14-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (321 commits)
powerpc/xive: Fix section __init warning
powerpc: Fix kernel crash in emulation of vector loads and stores
powerpc/xive: improve debugging macros
powerpc/xive: add XIVE Exploitation Mode to CAS
powerpc/xive: introduce H_INT_ESB hcall
powerpc/xive: add the HW IRQ number under xive_irq_data
powerpc/xive: introduce xive_esb_write()
powerpc/xive: rename xive_poke_esb() in xive_esb_read()
powerpc/xive: guest exploitation of the XIVE interrupt controller
powerpc/xive: introduce a common routine xive_queue_page_alloc()
powerpc/sstep: Avoid used uninitialized error
axonram: Return directly after a failed kzalloc() in axon_ram_probe()
axonram: Improve a size determination in axon_ram_probe()
axonram: Delete an error message for a failed memory allocation in axon_ram_probe()
powerpc/powernv/npu: Move tlb flush before launching ATSD
powerpc/macintosh: constify wf_sensor_ops structures
powerpc/iommu: Use permission-specific DEVICE_ATTR variants
powerpc/eeh: Delete an error out of memory message at init time
powerpc/mm: Use seq_putc() in two functions
macintosh: Convert to using %pOF instead of full_name
alloc_gigantic_page doesn't consider movability of the gigantic hugetlb
when scanning eligible ranges for the allocation. As 1GB hugetlb pages
are not movable currently this can break the movable zone assumption
that all allocations are migrateable and as such break memory hotplug.
Reorganize the code and use the standard zonelist allocations scheme
that we use for standard hugetbl pages. htlb_alloc_mask will ensure
that only migratable hugetlb pages will ever see a movable zone.
Link: http://lkml.kernel.org/r/20170803083549.21407-1-mhocko@kernel.org
Fixes: 944d9fec8d7a ("hugetlb: add support for gigantic page allocation at runtime")
Signed-off-by: Michal Hocko <mhocko@suse.com>
Cc: Luiz Capitulino <lcapitulino@redhat.com>
attribute_group are not supposed to change at runtime. All functions
working with attribute_group provided by <linux/sysfs.h> work with const
attribute_group. So mark the non-const structs as const.
Link: http://lkml.kernel.org/r/1501157260-3922-1-git-send-email-arvind.yadav.cs@gmail.com
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
When walking the page tables to resolve an address that points to
!p*d_present() entry, huge_pte_offset() returns inconsistent values
depending on the level of page table (PUD or PMD).
It returns NULL in the case of a PUD entry while in the case of a PMD
entry, it returns a pointer to the page table entry.
A similar inconsitency exists when handling swap entries - returns NULL
for a PUD entry while a pointer to the pte_t is retured for the PMD
entry.
Update huge_pte_offset() to make the behaviour consistent - return a
pointer to the pte_t for hugepage or swap entries. Only return NULL in
instances where we have a p*d_none() entry and the size parameter
doesn't match the hugepage size at this level of the page table.
Document the behaviour to clarify the expected behaviour of this
function. This is to set clear semantics for architecture specific
implementations of huge_pte_offset().
Discussions on the arm64 implementation of huge_pte_offset()
(http://www.spinics.net/lists/linux-mm/msg133699.html) showed that there
is benefit from returning a pte_t* in the case of p*d_none().
The fault handling code in hugetlb_fault() can handle p*d_none() entries
and saves an extra round trip to huge_pte_alloc(). Other callers of
huge_pte_offset() should be ok as well.
[punit.agrawal@arm.com: v2]
Link: http://lkml.kernel.org/r/20170725154114.24131-2-punit.agrawal@arm.com
Signed-off-by: Punit Agrawal <punit.agrawal@arm.com>
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
Cc: Steve Capper <steve.capper@arm.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
When running in guest mode ppc64 supports a different mechanism for hugetlb
allocation/reservation. The LPAR management application called HMC can
be used to reserve a set of hugepages and we pass the details of
reserved pages via device tree to the guest. (more details in
htab_dt_scan_hugepage_blocks()) . We do the memblock_reserve of the range
and later in the boot sequence, we add the reserved range to huge_boot_pages.
But to enable 16G hugetlb on baremetal config (when we are not running as guest)
we want to do memblock reservation during boot. Generic code already does this
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
huge_add_to_page_cache->add_to_page_cache implicitly unlocks the page
before returning in case of errors.
The error returned was -EEXIST by running UFFDIO_COPY on a non-hole
offset of a VM_SHARED hugetlbfs mapping. It was an userland bug that
triggered it and the kernel must cope with it returning -EEXIST from
ioctl(UFFDIO_COPY) as expected.
page dumped because: VM_BUG_ON_PAGE(!PageLocked(page))
kernel BUG at mm/filemap.c:964!
invalid opcode: 0000 [#1] SMP
CPU: 1 PID: 22582 Comm: qemu-system-x86 Not tainted 4.11.11-300.fc26.x86_64 #1
RIP: unlock_page+0x4a/0x50
Call Trace:
hugetlb_mcopy_atomic_pte+0xc0/0x320
mcopy_atomic+0x96f/0xbe0
userfaultfd_ioctl+0x218/0xe90
do_vfs_ioctl+0xa5/0x600
SyS_ioctl+0x79/0x90
entry_SYSCALL_64_fastpath+0x1a/0xa9
Link: http://lkml.kernel.org/r/20170802165145.22628-2-aarcange@redhat.com
Tested-by: Maxime Coquelin <maxime.coquelin@redhat.com>
Cc: Alexey Perevalov <a.perevalov@samsung.com>
Commit 9a291a7c9428 ("mm/hugetlb: report -EHWPOISON not -EFAULT when
FOLL_HWPOISON is specified") causes __get_user_pages to ignore certain
errors from follow_hugetlb_page. After such error, __get_user_pages
subsequently calls faultin_page on the same VMA and start address that
follow_hugetlb_page failed on instead of returning the error immediately
as it should.
In follow_hugetlb_page, when hugetlb_fault returns a value covered under
VM_FAULT_ERROR, follow_hugetlb_page returns it without setting nr_pages
to 0 as __get_user_pages expects in this case, which causes the
following to happen in __get_user_pages: the "while (nr_pages)" check
succeeds, we skip the "if (!vma..." check because we got a VMA the last
time around, we find no page with follow_page_mask, and we call
faultin_page, which calls hugetlb_fault for the second time.
This issue also slightly changes how __get_user_pages works. Before, it
only returned error if it had made no progress (i = 0). But now,
follow_hugetlb_page can clobber "i" with an error code since its new
return path doesn't check for progress. So if "i" is nonzero before a
failing call to follow_hugetlb_page, that indication of progress is lost
and __get_user_pages can return error even if some pages were
successfully pinned.
To fix this, change follow_hugetlb_page so that it updates nr_pages,
allowing __get_user_pages to fail immediately and restoring the "error
only if no progress" behavior to __get_user_pages.
Tested that __get_user_pages returns when expected on error from
hugetlb_fault in follow_hugetlb_page.
Fixes: 9a291a7c9428 ("mm/hugetlb: report -EHWPOISON not -EFAULT when FOLL_HWPOISON is specified")
Link: http://lkml.kernel.org/r/1500406795-58462-1-git-send-email-daniel.m.jordan@oracle.com
Signed-off-by: Daniel Jordan <daniel.m.jordan@oracle.com>
Acked-by: Punit Agrawal <punit.agrawal@arm.com>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Cc: James Morse <james.morse@arm.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: zhong jiang <zhongjiang@huawei.com>
Cc: <stable@vger.kernel.org> [4.12.x]
semantic
__GFP_REPEAT was designed to allow retry-but-eventually-fail semantic to
the page allocator. This has been true but only for allocations
requests larger than PAGE_ALLOC_COSTLY_ORDER. It has been always
ignored for smaller sizes. This is a bit unfortunate because there is
no way to express the same semantic for those requests and they are
considered too important to fail so they might end up looping in the
page allocator for ever, similarly to GFP_NOFAIL requests.
Now that the whole tree has been cleaned up and accidental or misled
usage of __GFP_REPEAT flag has been removed for !costly requests we can
give the original flag a better name and more importantly a more useful
semantic. Let's rename it to __GFP_RETRY_MAYFAIL which tells the user
that the allocator would try really hard but there is no promise of a
success. This will work independent of the order and overrides the
default allocator behavior. Page allocator users have several levels of
guarantee vs. cost options (take GFP_KERNEL as an example)
- GFP_KERNEL & ~__GFP_RECLAIM - optimistic allocation without _any_
attempt to free memory at all. The most light weight mode which even
doesn't kick the background reclaim. Should be used carefully because
it might deplete the memory and the next user might hit the more
aggressive reclaim
- GFP_KERNEL & ~__GFP_DIRECT_RECLAIM (or GFP_NOWAIT)- optimistic
allocation without any attempt to free memory from the current
context but can wake kswapd to reclaim memory if the zone is below
the low watermark. Can be used from either atomic contexts or when
the request is a performance optimization and there is another
fallback for a slow path.
- (GFP_KERNEL|__GFP_HIGH) & ~__GFP_DIRECT_RECLAIM (aka GFP_ATOMIC) -
non sleeping allocation with an expensive fallback so it can access
some portion of memory reserves. Usually used from interrupt/bh
context with an expensive slow path fallback.
- GFP_KERNEL - both background and direct reclaim are allowed and the
_default_ page allocator behavior is used. That means that !costly
allocation requests are basically nofail but there is no guarantee of
that behavior so failures have to be checked properly by callers
(e.g. OOM killer victim is allowed to fail currently).
- GFP_KERNEL | __GFP_NORETRY - overrides the default allocator behavior
and all allocation requests fail early rather than cause disruptive
reclaim (one round of reclaim in this implementation). The OOM killer
is not invoked.
- GFP_KERNEL | __GFP_RETRY_MAYFAIL - overrides the default allocator
behavior and all allocation requests try really hard. The request
will fail if the reclaim cannot make any progress. The OOM killer
won't be triggered.
- GFP_KERNEL | __GFP_NOFAIL - overrides the default allocator behavior
and all allocation requests will loop endlessly until they succeed.
This might be really dangerous especially for larger orders.
Existing users of __GFP_REPEAT are changed to __GFP_RETRY_MAYFAIL
because they already had their semantic. No new users are added.
__alloc_pages_slowpath is changed to bail out for __GFP_RETRY_MAYFAIL if
there is no progress and we have already passed the OOM point.
This means that all the reclaim opportunities have been exhausted except
the most disruptive one (the OOM killer) and a user defined fallback
behavior is more sensible than keep retrying in the page allocator.
[akpm@linux-foundation.org: fix arch/sparc/kernel/mdesc.c]
[mhocko@suse.com: semantic fix]
Link: http://lkml.kernel.org/r/20170626123847.GM11534@dhcp22.suse.cz
[mhocko@kernel.org: address other thing spotted by Vlastimil]
Link: http://lkml.kernel.org/r/20170626124233.GN11534@dhcp22.suse.cz
Link: http://lkml.kernel.org/r/20170623085345.11304-3-mhocko@kernel.org
Cc: Alex Belits <alex.belits@cavium.com>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Darrick J. Wong <darrick.wong@oracle.com>
Cc: David Daney <david.daney@cavium.com>
Cc: NeilBrown <neilb@suse.com>
alloc_huge_page_nodemask tries to allocate from any numa node in the
allowed node mask starting from lower numa nodes. This might lead to
filling up those low NUMA nodes while others are not used. We can
reduce this risk by introducing a concept of the preferred node similar
to what we have in the regular page allocator. We will start allocating
from the preferred nid and then iterate over all allowed nodes in the
zonelist order until we try them all.
This is mimicing the page allocator logic except it operates on per-node
mempools. dequeue_huge_page_vma already does this so distill the
zonelist logic into a more generic dequeue_huge_page_nodemask and use it
in alloc_huge_page_nodemask.
This will allow us to use proper per numa distance fallback also for
alloc_huge_page_node which can use alloc_huge_page_nodemask now and we
can get rid of alloc_huge_page_node helper which doesn't have any user
anymore.
Link: http://lkml.kernel.org/r/20170622193034.28972-3-mhocko@kernel.org
Tested-by: Mike Kravetz <mike.kravetz@oracle.com>
Patch series "mm, hugetlb: allow proper node fallback dequeue".
While working on a hugetlb migration issue addressed in a separate
patchset[1] I have noticed that the hugetlb allocations from the
preallocated pool are quite subotimal.
[1] //lkml.kernel.org/r/20170608074553.22152-1-mhocko@kernel.org
There is no fallback mechanism implemented and no notion of preferred
node. I have tried to work around it but Vlastimil was right to push
back for a more robust solution. It seems that such a solution is to
reuse zonelist approach we use for the page alloctor.
This series has 3 patches. The first one tries to make hugetlb
allocation layers more clear. The second one implements the zonelist
hugetlb pool allocation and introduces a preferred node semantic which
is used by the migration callbacks. The last patch is a clean up.
This patch (of 3):
Hugetlb allocation path for fresh huge pages is unnecessarily complex
and it mixes different interfaces between layers.
__alloc_buddy_huge_page is the central place to perform a new
allocation. It checks for the hugetlb overcommit and then relies on
__hugetlb_alloc_buddy_huge_page to invoke the page allocator. This is
all good except that __alloc_buddy_huge_page pushes vma and address down
the callchain and so __hugetlb_alloc_buddy_huge_page has to deal with
two different allocation modes - one for memory policy and other node
specific (or to make it more obscure node non-specific) requests.
This just screams for a reorganization.
This patch pulls out all the vma specific handling up to
__alloc_buddy_huge_page_with_mpol where it belongs.
__alloc_buddy_huge_page will get nodemask argument and
__hugetlb_alloc_buddy_huge_page will become a trivial wrapper over the
page allocator.
In short:
__alloc_buddy_huge_page_with_mpol - memory policy handling
__alloc_buddy_huge_page - overcommit handling and accounting
__hugetlb_alloc_buddy_huge_page - page allocator layer
Also note that __hugetlb_alloc_buddy_huge_page and its cpuset retry loop
is not really needed because the page allocator already handles the
cpusets update.
Finally __hugetlb_alloc_buddy_huge_page had a special case for node
specific allocations (when no policy is applied and there is a node
given). This has relied on __GFP_THISNODE to not fallback to a different
node. alloc_huge_page_node is the only caller which relies on this
behavior so move the __GFP_THISNODE there.
Not only does this remove quite some code it also should make those
layers easier to follow and clear wrt responsibilities.
Link: http://lkml.kernel.org/r/20170622193034.28972-2-mhocko@kernel.org
The hugetlb code has its own function to report human-readable sizes.
Convert it to use the shared string_get_size() function. This will lead
to a minor difference in user visible output (MiB/GiB instead of MB/GB),
but some would argue that's desirable anyway.
Link: http://lkml.kernel.org/r/20170606190350.GA20010@bombadil.infradead.org
Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com>
Cc: Liam R. Howlett <Liam.Howlett@Oracle.com>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
A few hugetlb allocators loop while calling the page allocator and can
potentially prevent rescheduling if the page allocator slowpath is not
utilized.
Conditionally schedule when large numbers of hugepages can be allocated.
Anshuman:
"Fixes a task which was getting hung while writing like 10000 hugepages
(16MB on POWER8) into /proc/sys/vm/nr_hugepages."
Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1706091535300.66176@chino.kir.corp.google.com
Signed-off-by: David Rientjes <rientjes@google.com>
Tested-by: Anshuman Khandual <khandual@linux.vnet.ibm.com>
new_node_page will try to use the origin's next NUMA node as the
migration destination for hugetlb pages. If such a node doesn't have
any preallocated pool it falls back to __alloc_buddy_huge_page_no_mpol
to allocate a surplus page instead. This is quite subotpimal for any
configuration when hugetlb pages are no distributed to all NUMA nodes
evenly. Say we have a hotplugable node 4 and spare hugetlb pages are
node 0
/sys/devices/system/node/node0/hugepages/hugepages-2048kB/nr_hugepages:10000
/sys/devices/system/node/node1/hugepages/hugepages-2048kB/nr_hugepages:0
/sys/devices/system/node/node2/hugepages/hugepages-2048kB/nr_hugepages:0
/sys/devices/system/node/node3/hugepages/hugepages-2048kB/nr_hugepages:0
/sys/devices/system/node/node4/hugepages/hugepages-2048kB/nr_hugepages:10000
/sys/devices/system/node/node5/hugepages/hugepages-2048kB/nr_hugepages:0
/sys/devices/system/node/node6/hugepages/hugepages-2048kB/nr_hugepages:0
/sys/devices/system/node/node7/hugepages/hugepages-2048kB/nr_hugepages:0
Now we consume the whole pool on node 4 and try to offline this node.
All the allocated pages should be moved to node0 which has enough
preallocated pages to hold them. With the current implementation
offlining very likely fails because hugetlb allocations during runtime
are much less reliable.
Fix this by reusing the nodemask which excludes migration source and try
to find a first node which has a page in the preallocated pool first and
fall back to __alloc_buddy_huge_page_no_mpol only when the whole pool is
consumed.
[akpm@linux-foundation.org: remove bogus arg from alloc_huge_page_nodemask() stub]
Link: http://lkml.kernel.org/r/20170608074553.22152-3-mhocko@kernel.org
Cc: Xishi Qiu <qiuxishi@huawei.com>
Cc: Joonsoo Kim <js1304@gmail.com>
When the user specifies too many hugepages or an invalid
default_hugepagesz the communication to the user is implicit in the
allocation message. This patch adds a warning when the desired page
count is not allocated and prints an error when the default_hugepagesz
is invalid on boot.
During boot hugepages will allocate until there is a fraction of the
hugepage size left. That is, we allocate until either the request is
satisfied or memory for the pages is exhausted. When memory for the
pages is exhausted, it will most likely lead to the system failing with
the OOM manager not finding enough (or anything) to kill (unless you're
using really big hugepages in the order of 100s of MB or in the GBs).
The user will most likely see the OOM messages much later in the boot
sequence than the implicitly stated message. Worse yet, you may even
get an OOM for each processor which causes many pages of OOMs on modern
systems. Although these messages will be printed earlier than the OOM
messages, at least giving the user errors and warnings will highlight
the configuration as an issue. I'm trying to point the user in the
right direction by providing a more robust statement of what is failing.
During the sysctl or echo command, the user can check the results much
easier than if the system hangs during boot and the scenario of having
nothing to OOM for kernel memory is highly unlikely.
Mike said:
"Before sending out this patch, I asked Liam off list why he was doing
it. Was it something he just thought would be useful? Or, was there
some type of user situation/need. He said that he had been called in
to assist on several occasions when a system OOMed during boot. In
almost all of these situations, the user had grossly misconfigured
huge pages.
DB users want to pre-allocate just the right amount of huge pages, but
sometimes they can be really off. In such situations, the huge page
init code just allocates as many huge pages as it can and reports the
number allocated. There is no indication that it quit allocating
because it ran out of memory. Of course, a user could compare the
number in the message to what they requested on the command line to
determine if they got all the huge pages they requested. The thought
was that it would be useful to at least flag this situation. That way,
the user might be able to better relate the huge page allocation
failure to the OOM.
I'm not sure if the e-mail discussion made it obvious that this is
something he has seen on several occasions.
I see Michal's point that this will only flag the situation where
someone configures huge pages very badly. And, a more extensive look
at the situation of misconfiguring huge pages might be in order. But,
this has happened on several occasions which led to the creation of
this patch"
[akpm@linux-foundation.org: reposition memfmt() to avoid forward declaration]
Link: http://lkml.kernel.org/r/20170603005413.10380-1-Liam.Howlett@Oracle.com
Signed-off-by: Liam R. Howlett <Liam.Howlett@Oracle.com>
Cc: zhongjiang <zhongjiang@huawei.com>
dequeue_hwpoisoned_huge_page() is no longer used, so let's remove it.
Link: http://lkml.kernel.org/r/1496305019-5493-9-git-send-email-n-horiguchi@ah.jp.nec.com
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Currently hugepage migrated by soft-offline (i.e. due to correctable
memory errors) is contained as a hugepage, which means many non-error
pages in it are unreusable, i.e. wasted.
This patch solves this issue by dissolving source hugepages into buddy.
As done in previous patch, PageHWPoison is set only on a head page of
the error hugepage. Then in dissoliving we move the PageHWPoison flag
to the raw error page so that all healthy subpages return back to buddy.
[arnd@arndb.de: fix warnings: replace some macros with inline functions]
Link: http://lkml.kernel.org/r/20170609102544.2947326-1-arnd@arndb.de
Link: http://lkml.kernel.org/r/1496305019-5493-5-git-send-email-n-horiguchi@ah.jp.nec.com
Signed-off-by: Anshuman Khandual <khandual@linux.vnet.ibm.com>
Patch series "mm: hwpoison: fixlet for hugetlb migration".
This patchset updates the hwpoison/hugetlb code to address 2 reported
issues.
One is madvise(MADV_HWPOISON) failure reported by Intel's lkp robot (see
http://lkml.kernel.org/r/20170417055948.GM31394@yexl-desktop.) First
half was already fixed in mainline, and another half about hugetlb cases
are solved in this series.
Another issue is "narrow-down error affected region into a single 4kB
page instead of a whole hugetlb page" issue, which was tried by Anshuman
(http://lkml.kernel.org/r/20170420110627.12307-1-khandual@linux.vnet.ibm.com)
and I updated it to apply it more widely.
This patch (of 9):
We no longer use MIGRATE_ISOLATE to prevent reuse of hwpoison hugepages
as we did before. So current dequeue_huge_page_node() doesn't work as
intended because it still uses is_migrate_isolate_page() for this check.
This patch fixes it with PageHWPoison flag.
Link: http://lkml.kernel.org/r/1496305019-5493-2-git-send-email-n-horiguchi@ah.jp.nec.com
Cc: Anshuman Khandual <khandual@linux.vnet.ibm.com>
The main allocator function __alloc_pages_nodemask() takes a zonelist
pointer as one of its parameters. All of its callers directly or
indirectly obtain the zonelist via node_zonelist() using a preferred
node id and gfp_mask. We can make the code a bit simpler by doing the
zonelist lookup in __alloc_pages_nodemask(), passing it a preferred node
id instead (gfp_mask is already another parameter).
There are some code size benefits thanks to removal of inlined
node_zonelist():
bloat-o-meter add/remove: 2/2 grow/shrink: 4/36 up/down: 399/-1351 (-952)
This will also make things simpler if we proceed with converting cpusets
to zonelists.
Link: http://lkml.kernel.org/r/20170517081140.30654-4-vbabka@suse.cz
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Reviewed-by: Christoph Lameter <cl@linux.com>
Cc: Dimitri Sivanich <sivanich@sgi.com>
Cc: Li Zefan <lizefan@huawei.com>
set_huge_pte_at(), an architecture callback to populate hugepage ptes,
does not provide the range of virtual memory that is targeted. This
leads to ambiguity when dealing with swap entries on architectures that
support hugepages consisting of contiguous ptes.
Fix the problem by introducing an overridable helper that is called when
populating the page tables with swap entries. The size of the targeted
region is provided to the helper to help determine the number of entries
to be updated.
Provide a default implementation that maintains the current behaviour.
[punit.agrawal@arm.com: v4]
Link: http://lkml.kernel.org/r/20170524115409.31309-8-punit.agrawal@arm.com
[punit.agrawal@arm.com: add an empty definition for set_huge_swap_pte_at()]
Link: http://lkml.kernel.org/r/20170525171331.31469-1-punit.agrawal@arm.com
Link: http://lkml.kernel.org/r/20170522133604.11392-6-punit.agrawal@arm.com
Acked-by: Steve Capper <steve.capper@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Hillf Danton <hillf.zj@alibaba-inc.com>
When unmapping a hugepage range, huge_pte_clear() is used to clear the
page table entries that are marked as not present. huge_pte_clear()
internally just ends up calling pte_clear() which does not correctly
deal with hugepages consisting of contiguous page table entries.
Add a size argument to address this issue and allow architectures to
override huge_pte_clear() by wrapping it in a #ifndef block.
Update s390 implementation with the size parameter as well.
Note that the change only affects huge_pte_clear() - the other generic
hugetlb functions don't need any change.
Link: http://lkml.kernel.org/r/20170522162555.4313-1-punit.agrawal@arm.com
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390 bits]
A poisoned or migrated hugepage is stored as a swap entry in the page
tables. On architectures that support hugepages consisting of
contiguous page table entries (such as on arm64) this leads to ambiguity
in determining the page table entry to return in huge_pte_offset() when
a poisoned entry is encountered.
Let's remove the ambiguity by adding a size parameter to convey
additional information about the requested address. Also fixup the
definition/usage of huge_pte_offset() throughout the tree.
Link: http://lkml.kernel.org/r/20170522133604.11392-4-punit.agrawal@arm.com
Cc: James Hogan <james.hogan@imgtec.com> (odd fixer:METAG ARCHITECTURE)
Cc: Ralf Baechle <ralf@linux-mips.org> (supporter:MIPS)
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Helge Deller <deller@gmx.de>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Rich Felker <dalias@libc.org>
Cc: Chris Metcalf <cmetcalf@mellanox.com>
This moves the #ifdef in C code to a Kconfig dependency. Also we move
the gigantic_page_supported() function to be arch specific.
This allows architectures to conditionally enable runtime allocation of
gigantic huge page. Architectures like ppc64 supports different
gigantic huge page size (16G and 1G) based on the translation mode
selected. This provides an opportunity for ppc64 to enable runtime
allocation only w.r.t 1G hugepage.
No functional change in this patch.
Link: http://lkml.kernel.org/r/1494995292-4443-1-git-send-email-aneesh.kumar@linux.vnet.ibm.com
Cc: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Architectures like ppc64 supports hugepage size that is not mapped to
any of of the page table levels. Instead they add an alternate page
table entry format called hugepage directory (hugepd). hugepd indicates
that the page table entry maps to a set of hugetlb pages. Add support
for this in generic follow_page_mask code. We already support this
format in the generic gup code.
The default implementation prints warning and returns NULL. We will add
ppc64 support in later patches
Link: http://lkml.kernel.org/r/1494926612-23928-7-git-send-email-aneesh.kumar@linux.vnet.ibm.com
Cc: Mike Kravetz <kravetz@us.ibm.com>
ppc64 supports pgd hugetlb entries. Add code to handle hugetlb pgd
entries to follow_page_mask so that ppc64 can switch to it to handle
hugetlbe entries.
Link: http://lkml.kernel.org/r/1494926612-23928-5-git-send-email-aneesh.kumar@linux.vnet.ibm.com
We will be using this later from the ppc64 code. Change the return type
to bool.
Link: http://lkml.kernel.org/r/1494926612-23928-4-git-send-email-aneesh.kumar@linux.vnet.ibm.com
Though migrating gigantic HugeTLB pages does not sound much like real
world use case, they can be affected by memory errors. Hence migration
at the PGD level HugeTLB pages should be supported just to enable soft
and hard offline use cases.
While allocating the new gigantic HugeTLB page, it should not matter
whether new page comes from the same node or not. There would be very
few gigantic pages on the system afterall, we should not be bothered
about node locality when trying to save a big page from crashing.
This change renames dequeu_huge_page_node() function as dequeue_huge
_page_node_exact() preserving it's original functionality. Now the new
dequeue_huge_page_node() function scans through all available online nodes
to allocate a huge page for the NUMA_NO_NODE case and just falls back
calling dequeu_huge_page_node_exact() for all other cases.
[arnd@arndb.de: make hstate_is_gigantic() inline]
Link: http://lkml.kernel.org/r/20170522124748.3911296-1-arnd@arndb.de
Link: http://lkml.kernel.org/r/20170516100509.20122-1-khandual@linux.vnet.ibm.com
KVM uses get_user_pages() to resolve its stage2 faults. KVM sets the
FOLL_HWPOISON flag causing faultin_page() to return -EHWPOISON when it
finds a VM_FAULT_HWPOISON. KVM handles these hwpoison pages as a
special case. (check_user_page_hwpoison())
When huge pages are involved, this doesn't work so well.
get_user_pages() calls follow_hugetlb_page(), which stops early if it
receives VM_FAULT_HWPOISON from hugetlb_fault(), eventually returning
-EFAULT to the caller. The step to map this to -EHWPOISON based on the
FOLL_ flags is missing. The hwpoison special case is skipped, and
-EFAULT is returned to user-space, causing Qemu or kvmtool to exit.
Instead, move this VM_FAULT_ to errno mapping code into a header file
and use it from faultin_page() and follow_hugetlb_page().
With this, KVM works as expected.
This isn't a problem for arm64 today as we haven't enabled
MEMORY_FAILURE, but I can't see any reason this doesn't happen on x86
too, so I think this should be a fix. This doesn't apply earlier than
stable's v4.11.1 due to all sorts of cleanup.
[james.morse@arm.com: add vm_fault_to_errno() call to faultin_page()]
suggested.
Link: http://lkml.kernel.org/r/20170525171035.16359-1-james.morse@arm.com
Link: http://lkml.kernel.org/r/20170524160900.28786-1-james.morse@arm.com
Signed-off-by: James Morse <james.morse@arm.com>
Acked-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: <stable@vger.kernel.org> [4.11.1+]
Changes to hugetlbfs reservation maps is a two step process. The first
step is a call to region_chg to determine what needs to be changed, and
prepare that change. This should be followed by a call to call to
region_add to commit the change, or region_abort to abort the change.
The error path in hugetlb_reserve_pages called region_abort after a
failed call to region_chg. As a result, the adds_in_progress counter in
the reservation map is off by 1. This is caught by a VM_BUG_ON in
resv_map_release when the reservation map is freed.
syzkaller fuzzer (when using an injected kmalloc failure) found this
bug, that resulted in the following:
kernel BUG at mm/hugetlb.c:742!
Call Trace:
hugetlbfs_evict_inode+0x7b/0xa0 fs/hugetlbfs/inode.c:493
evict+0x481/0x920 fs/inode.c:553
iput_final fs/inode.c:1515 [inline]
iput+0x62b/0xa20 fs/inode.c:1542
hugetlb_file_setup+0x593/0x9f0 fs/hugetlbfs/inode.c:1306
newseg+0x422/0xd30 ipc/shm.c:575
ipcget_new ipc/util.c:285 [inline]
ipcget+0x21e/0x580 ipc/util.c:639
SYSC_shmget ipc/shm.c:673 [inline]
SyS_shmget+0x158/0x230 ipc/shm.c:657
entry_SYSCALL_64_fastpath+0x1f/0xc2
RIP: resv_map_release+0x265/0x330 mm/hugetlb.c:742
Link: http://lkml.kernel.org/r/1490821682-23228-1-git-send-email-mike.kravetz@oracle.com
Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com>
I found the race condition which triggers the following bug when
move_pages() and soft offline are called on a single hugetlb page
concurrently.
Soft offlining page 0x119400 at 0x700000000000
BUG: unable to handle kernel paging request at ffffea0011943820
IP: follow_huge_pmd+0x143/0x190
PGD 7ffd2067
PUD 7ffd1067
PMD 0
[61163.582052] Oops: 0000 [#1] SMP
Modules linked in: binfmt_misc ppdev virtio_balloon parport_pc pcspkr i2c_piix4 parport i2c_core acpi_cpufreq ip_tables xfs libcrc32c ata_generic pata_acpi virtio_blk 8139too crc32c_intel ata_piix serio_raw libata virtio_pci 8139cp virtio_ring virtio mii floppy dm_mirror dm_region_hash dm_log dm_mod [last unloaded: cap_check]
CPU: 0 PID: 22573 Comm: iterate_numa_mo Tainted: P OE 4.11.0-rc2-mm1+ #2
Hardware name: Red Hat KVM, BIOS 0.5.1 01/01/2011
RIP: 0010:follow_huge_pmd+0x143/0x190
RSP: 0018:ffffc90004bdbcd0 EFLAGS: 00010202
RAX: 0000000465003e80 RBX: ffffea0004e34d30 RCX: 00003ffffffff000
RDX: 0000000011943800 RSI: 0000000000080001 RDI: 0000000465003e80
RBP: ffffc90004bdbd18 R08: 0000000000000000 R09: ffff880138d34000
R10: ffffea0004650000 R11: 0000000000c363b0 R12: ffffea0011943800
R13: ffff8801b8d34000 R14: ffffea0000000000 R15: 000077ff80000000
FS: 00007fc977710740(0000) GS:ffff88007dc00000(0000) knlGS:0000000000000000
CR2: ffffea0011943820 CR3: 000000007a746000 CR4: 00000000001406f0
Call Trace:
follow_page_mask+0x270/0x550
SYSC_move_pages+0x4ea/0x8f0
SyS_move_pages+0xe/0x10
do_syscall_64+0x67/0x180
entry_SYSCALL64_slow_path+0x25/0x25
RIP: 0033:0x7fc976e03949
RSP: 002b:00007ffe72221d88 EFLAGS: 00000246 ORIG_RAX: 0000000000000117
RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007fc976e03949
RDX: 0000000000c22390 RSI: 0000000000001400 RDI: 0000000000005827
RBP: 00007ffe72221e00 R08: 0000000000c2c3a0 R09: 0000000000000004
R10: 0000000000c363b0 R11: 0000000000000246 R12: 0000000000400650
R13: 00007ffe72221ee0 R14: 0000000000000000 R15: 0000000000000000
Code: 81 e4 ff ff 1f 00 48 21 c2 49 c1 ec 0c 48 c1 ea 0c 4c 01 e2 49 bc 00 00 00 00 00 ea ff ff 48 c1 e2 06 49 01 d4 f6 45 bc 04 74 90 <49> 8b 7c 24 20 40 f6 c7 01 75 2b 4c 89 e7 8b 47 1c 85 c0 7e 2a
RIP: follow_huge_pmd+0x143/0x190 RSP: ffffc90004bdbcd0
---[ end trace e4f81353a2d23232 ]---
Kernel panic - not syncing: Fatal exception
Kernel Offset: disabled
This bug is triggered when pmd_present() returns true for non-present
hugetlb, so fixing the present check in follow_huge_pmd() prevents it.
Using pmd_present() to determine present/non-present for hugetlb is not
correct, because pmd_present() checks multiple bits (not only
_PAGE_PRESENT) for historical reason and it can misjudge hugetlb state.
Fixes: e66f17ff7177 ("mm/hugetlb: take page table lock in follow_huge_pmd()")
Link: http://lkml.kernel.org/r/1490149898-20231-1-git-send-email-n-horiguchi@ah.jp.nec.com
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: <stable@vger.kernel.org> [4.0+]
Convert all non-architecture-specific code to 5-level paging.
It's mostly mechanical adding handling one more page table level in
places where we deal with pud_t.
<linux/sched.h> into <linux/sched/signal.h>
Fix up affected files that include this signal functionality via sched.h.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Currently alloc_contig_range assumes that the compaction should be done
with the default GFP_KERNEL flags. This is probably right for all
current uses of this interface, but may change as CMA is used in more
use-cases (including being the default DMA memory allocator on some
platforms).
Change the function prototype, to allow for passing through the GFP mask
set by upper layers.
Also respect global restrictions by applying memalloc_noio_flags to the
passed in flags.
Link: http://lkml.kernel.org/r/20170127172328.18574-1-l.stach@pengutronix.de
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
Cc: Radim Krcmar <rkrcmar@redhat.com>
Cc: Chris Zankel <chris@zankel.net>
Cc: Alexander Graf <agraf@suse.com>
->fault(), ->page_mkwrite(), and ->pfn_mkwrite() calls do not need to
take a vma and vmf parameter when the vma already resides in vmf.
Remove the vma parameter to simplify things.
[arnd@arndb.de: fix ARM build]
Link: http://lkml.kernel.org/r/20170125223558.1451224-1-arnd@arndb.de
Link: http://lkml.kernel.org/r/148521301778.19116.10840599906674778980.stgit@djiang5-desk3.ch.intel.com
Signed-off-by: Dave Jiang <dave.jiang@intel.com>
Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Matthew Wilcox <mawilcox@microsoft.com>
Cc: Jan Kara <jack@suse.com>
Cc: Dan Williams <dan.j.williams@intel.com>
When userfaultfd hugetlbfs support was originally added, it followed the
pattern of anon mappings and did not support any vmas marked VM_SHARED.
As such, support was only added for private mappings.
Remove this limitation and support shared mappings. The primary
functional change required is adding pages to the page cache. More subtle
changes are required for huge page reservation handling in error paths. A
lengthy comment in the code describes the reservation handling.
[mike.kravetz@oracle.com: update]
Link: http://lkml.kernel.org/r/c9c8cafe-baa7-05b4-34ea-1dfa5523a85f@oracle.com
Link: http://lkml.kernel.org/r/1487195210-12839-1-git-send-email-mike.kravetz@oracle.com
Signed-off-by: Mike Kravetz <mike.kravetz@oracle.com>
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Add support for VM_FAULT_RETRY to follow_hugetlb_page() so that
get_user_pages_unlocked/locked and "nonblocking/FOLL_NOWAIT" features
will work on hugetlbfs.
This is required for fully functional userfaultfd non-present support on
hugetlbfs.
Link: http://lkml.kernel.org/r/20161216144821.5183-25-aarcange@redhat.com
Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com>
Cc: Michael Rapoport <RAPOPORT@il.ibm.com>
When processing a hugetlb fault for no page present, check the vma to
determine if faults are to be handled via userfaultfd. If so, drop the
hugetlb_fault_mutex and call handle_userfault().
Link: http://lkml.kernel.org/r/20161216144821.5183-21-aarcange@redhat.com
