path: root/mm/hugetlb.c
2005-08-05[PATCH] Fix hugepage crash on failing mmap()David Gibson
This patch fixes a crash in the hugepage code. unmap_hugepage_area() was assuming that (due to prefault) PTEs must exist for all the area in question. However, this may not be the case, if mmap() encounters an error before the prefault and calls unmap_region() to clean up any partial mapping. Depending on the hugepage configuration, this crash can be triggered by an unpriveleged user. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Cc: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] Hugepage consolidationDavid Gibson
A lot of the code in arch/*/mm/hugetlbpage.c is quite similar. This patch attempts to consolidate a lot of the code across the arch's, putting the combined version in mm/hugetlb.c. There are a couple of uglyish hacks in order to covert all the hugepage archs, but the result is a very large reduction in the total amount of code. It also means things like hugepage lazy allocation could be implemented in one place, instead of six. Tested, at least a little, on ppc64, i386 and x86_64. Notes: - this patch changes the meaning of set_huge_pte() to be more analagous to set_pte() - does SH4 need s special huge_ptep_get_and_clear()?? Acked-by: William Lee Irwin <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
