path: root/mm/hugetlb_cgroup.c
2012-12-18mm/hugetlb: create hugetlb cgroup file in hugetlb_initJianguo Wu
Build kernel with CONFIG_HUGETLBFS=y,CONFIG_HUGETLB_PAGE=y and CONFIG_CGROUP_HUGETLB=y, then specify hugepagesz=xx boot option, system will fail to boot. This failure is caused by following code path: setup_hugepagesz hugetlb_add_hstate hugetlb_cgroup_file_init cgroup_add_cftypes kzalloc <--slab is *not available* yet For this path, slab is not available yet, so memory allocated will be failed, and cause WARN_ON() in hugetlb_cgroup_file_init(). So I move hugetlb_cgroup_file_init() into hugetlb_init(). [akpm@linux-foundation.org: tweak coding-style, remove pointless __init on inlined function] [akpm@linux-foundation.org: fix warning] Signed-off-by: Jianguo Wu <wujianguo@huawei.com> Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-19cgroup: rename ->create/post_create/pre_destroy/destroy() to ↵Tejun Heo
->css_alloc/online/offline/free() Rename cgroup_subsys css lifetime related callbacks to better describe what their roles are. Also, update documentation. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2012-11-05cgroup: make ->pre_destroy() return voidTejun Heo
All ->pre_destory() implementations return 0 now, which is the only allowed return value. Make it return void. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Michal Hocko <mhocko@suse.cz> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Li Zefan <lizefan@huawei.com> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Vivek Goyal <vgoyal@redhat.com>
2012-11-05hugetlb: do not fail in hugetlb_cgroup_pre_destroyMichal Hocko
Now that pre_destroy callbacks are called from the context where neither any task can attach the group nor any children group can be added there is no other way to fail from hugetlb_pre_destroy. Signed-off-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: Tejun Heo <tj@kernel.org> Reviewed-by: Glauber Costa <glommer@parallels.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2012-07-31hugetlb/cgroup: remove exclude and wakeup rmdir calls from migrateAneesh Kumar K.V
We already hold the hugetlb_lock. That should prevent a parallel cgroup rmdir from touching page's hugetlb cgroup. So remove the exclude and wakeup calls. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31hugetlb/cgroup: assign the page hugetlb cgroup when we move the page to ↵Aneesh Kumar K.V
active list. A page's hugetlb cgroup assignment and movement to the active list should occur with hugetlb_lock held. Otherwise when we remove the hugetlb cgroup we will iterate the active list and find pages with NULL hugetlb cgroup values. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31hugetlb/cgroup: migrate hugetlb cgroup info from oldpage to new page during ↵Aneesh Kumar K.V
migration With HugeTLB pages, hugetlb cgroup is uncharged in compound page destructor. Since we are holding a hugepage reference, we can be sure that old page won't get uncharged till the last put_page(). Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: David Rientjes <rientjes@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31hugetlb/cgroup: add hugetlb cgroup control filesAneesh Kumar K.V
Add the control files for hugetlb controller [akpm@linux-foundation.org: s/CONFIG_CGROUP_HUGETLB_RES_CTLR/CONFIG_MEMCG_HUGETLB/g] [akpm@linux-foundation.org: s/CONFIG_MEMCG_HUGETLB/CONFIG_CGROUP_HUGETLB/] Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: David Rientjes <rientjes@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hillf Danton <dhillf@gmail.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31hugetlb/cgroup: add support for cgroup removalAneesh Kumar K.V
Add support for cgroup removal. If we don't have parent cgroup, the charges are moved to root cgroup. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: David Rientjes <rientjes@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hillf Danton <dhillf@gmail.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31hugetlb/cgroup: add charge/uncharge routines for hugetlb cgroupAneesh Kumar K.V
Add the charge and uncharge routines for hugetlb cgroup. We do cgroup charging in page alloc and uncharge in compound page destructor. Assigning page's hugetlb cgroup is protected by hugetlb_lock. [liwp@linux.vnet.ibm.com: add huge_page_order check to avoid incorrect uncharge] Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: David Rientjes <rientjes@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Wanpeng Li <liwp.linux@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm/hugetlb: add new HugeTLB cgroupAneesh Kumar K.V
Implement a new controller that allows us to control HugeTLB allocations. The extension allows to limit the HugeTLB usage per control group and enforces the controller limit during page fault. Since HugeTLB doesn't support page reclaim, enforcing the limit at page fault time implies that, the application will get SIGBUS signal if it tries to access HugeTLB pages beyond its limit. This requires the application to know beforehand how much HugeTLB pages it would require for its use. The charge/uncharge calls will be added to HugeTLB code in later patch. Support for cgroup removal will be added in later patches. [akpm@linux-foundation.org: s/CONFIG_CGROUP_HUGETLB_RES_CTLR/CONFIG_MEMCG_HUGETLB/g] [akpm@linux-foundation.org: s/CONFIG_MEMCG_HUGETLB/CONFIG_CGROUP_HUGETLB/g] Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: David Rientjes <rientjes@google.com> Cc: Hillf Danton <dhillf@gmail.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
