[ Upstream commit 8b09549c2bfd9f3f8f4cdad74107ef4f4ff9cdd7 ]
Commit fa5e084e43eb ("vmscan: do not unconditionally treat zones that
fail zone_reclaim() as full") changed the return value of
node_reclaim(). The original return value 0 means NODE_RECLAIM_SOME
after this commit.
While the return value of node_reclaim() when CONFIG_NUMA is n is not
changed. This will leads to call zone_watermark_ok() again.
This patch fixes the return value by adjusting to NODE_RECLAIM_NOSCAN.
Since node_reclaim() is only called in page_alloc.c, move it to
mm/internal.h.
Link: http://lkml.kernel.org/r/20181113080436.22078-1-richard.weiyang@gmail.com
Signed-off-by: Wei Yang <richard.weiyang@gmail.com>
Reviewed-by: Matthew Wilcox <willy@infradead.org>
Cc: Mel Gorman <mgorman@techsingularity.net>
For ages we have been relying on TIF_MEMDIE thread flag to mark OOM
victims and then, among other things, to give these threads full access
to memory reserves. There are few shortcomings of this implementation,
though.
First of all and the most serious one is that the full access to memory
reserves is quite dangerous because we leave no safety room for the
system to operate and potentially do last emergency steps to move on.
Secondly this flag is per task_struct while the OOM killer operates on
mm_struct granularity so all processes sharing the given mm are killed.
Giving the full access to all these task_structs could lead to a quick
memory reserves depletion. We have tried to reduce this risk by giving
TIF_MEMDIE only to the main thread and the currently allocating task but
that doesn't really solve this problem while it surely opens up a room
for corner cases - e.g. GFP_NO{FS,IO} requests might loop inside the
allocator without access to memory reserves because a particular thread
was not the group leader.
Now that we have the oom reaper and that all oom victims are reapable
after 1b51e65eab64 ("oom, oom_reaper: allow to reap mm shared by the
kthreads") we can be more conservative and grant only partial access to
memory reserves because there are reasonable chances of the parallel
memory freeing. We still want some access to reserves because we do not
want other consumers to eat up the victim's freed memory. oom victims
will still contend with __GFP_HIGH users but those shouldn't be so
aggressive to starve oom victims completely.
Introduce ALLOC_OOM flag and give all tsk_is_oom_victim tasks access to
the half of the reserves. This makes the access to reserves independent
on which task has passed through mark_oom_victim. Also drop any usage
of TIF_MEMDIE from the page allocator proper and replace it by
tsk_is_oom_victim as well which will make page_alloc.c completely
TIF_MEMDIE free finally.
CONFIG_MMU=n doesn't have oom reaper so let's stick to the original
ALLOC_NO_WATERMARKS approach.
There is a demand to make the oom killer memcg aware which will imply
many tasks killed at once. This change will allow such a usecase
without worrying about complete memory reserves depletion.
Link: http://lkml.kernel.org/r/20170810075019.28998-2-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Acked-by: Mel Gorman <mgorman@techsingularity.net>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: Roman Gushchin <guro@fb.com>
build_all_zonelists gets a zone parameter to initialize zone's pagesets.
There is only a single user which gives a non-NULL zone parameter and
that one doesn't really need the rest of the build_all_zonelists (see
commit 6dcd73d7011b ("memory-hotplug: allocate zone's pcp before
onlining pages")).
Therefore remove setup_zone_pageset from build_all_zonelists and call it
from its only user directly. This will also remove a pointless zonlists
rebuilding which is always good.
Link: http://lkml.kernel.org/r/20170721143915.14161-5-mhocko@kernel.org
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Joonsoo Kim <js1304@gmail.com>
Cc: Shaohua Li <shaohua.li@intel.com>
Cc: Toshi Kani <toshi.kani@hpe.com>
Cc: Wen Congyang <wency@cn.fujitsu.com>
leaving stale TLB entries
Nadav Amit identified a theoritical race between page reclaim and
mprotect due to TLB flushes being batched outside of the PTL being held.
He described the race as follows:
CPU0 CPU1
user accesses memory using RW PTE
[PTE now cached in TLB]
try_to_unmap_one()
==> ptep_get_and_clear()
==> set_tlb_ubc_flush_pending()
mprotect(addr, PROT_READ)
==> change_pte_range()
==> [ PTE non-present - no flush ]
user writes using cached RW PTE
try_to_unmap_flush()
The same type of race exists for reads when protecting for PROT_NONE and
also exists for operations that can leave an old TLB entry behind such
as munmap, mremap and madvise.
For some operations like mprotect, it's not necessarily a data integrity
issue but it is a correctness issue as there is a window where an
mprotect that limits access still allows access. For munmap, it's
potentially a data integrity issue although the race is massive as an
munmap, mmap and return to userspace must all complete between the
window when reclaim drops the PTL and flushes the TLB. However, it's
theoritically possible so handle this issue by flushing the mm if
reclaim is potentially currently batching TLB flushes.
Other instances where a flush is required for a present pte should be ok
as either the page lock is held preventing parallel reclaim or a page
reference count is elevated preventing a parallel free leading to
corruption. In the case of page_mkclean there isn't an obvious path
that userspace could take advantage of without using the operations that
are guarded by this patch. Other users such as gup as a race with
reclaim looks just at PTEs. huge page variants should be ok as they
don't race with reclaim. mincore only looks at PTEs. userfault also
should be ok as if a parallel reclaim takes place, it will either fault
the page back in or read some of the data before the flush occurs
triggering a fault.
Note that a variant of this patch was acked by Andy Lutomirski but this
was for the x86 parts on top of his PCID work which didn't make the 4.13
merge window as expected. His ack is dropped from this version and
there will be a follow-on patch on top of PCID that will include his
ack.
[akpm@linux-foundation.org: tweak comments]
[akpm@linux-foundation.org: fix spello]
Link: http://lkml.kernel.org/r/20170717155523.emckq2esjro6hf3z@suse.de
Reported-by: Nadav Amit <nadav.amit@gmail.com>
Cc: <stable@vger.kernel.org> [v4.4+]
semantic
__GFP_REPEAT was designed to allow retry-but-eventually-fail semantic to
the page allocator. This has been true but only for allocations
requests larger than PAGE_ALLOC_COSTLY_ORDER. It has been always
ignored for smaller sizes. This is a bit unfortunate because there is
no way to express the same semantic for those requests and they are
considered too important to fail so they might end up looping in the
page allocator for ever, similarly to GFP_NOFAIL requests.
Now that the whole tree has been cleaned up and accidental or misled
usage of __GFP_REPEAT flag has been removed for !costly requests we can
give the original flag a better name and more importantly a more useful
semantic. Let's rename it to __GFP_RETRY_MAYFAIL which tells the user
that the allocator would try really hard but there is no promise of a
success. This will work independent of the order and overrides the
default allocator behavior. Page allocator users have several levels of
guarantee vs. cost options (take GFP_KERNEL as an example)
- GFP_KERNEL & ~__GFP_RECLAIM - optimistic allocation without _any_
attempt to free memory at all. The most light weight mode which even
doesn't kick the background reclaim. Should be used carefully because
it might deplete the memory and the next user might hit the more
aggressive reclaim
- GFP_KERNEL & ~__GFP_DIRECT_RECLAIM (or GFP_NOWAIT)- optimistic
allocation without any attempt to free memory from the current
context but can wake kswapd to reclaim memory if the zone is below
the low watermark. Can be used from either atomic contexts or when
the request is a performance optimization and there is another
fallback for a slow path.
- (GFP_KERNEL|__GFP_HIGH) & ~__GFP_DIRECT_RECLAIM (aka GFP_ATOMIC) -
non sleeping allocation with an expensive fallback so it can access
some portion of memory reserves. Usually used from interrupt/bh
context with an expensive slow path fallback.
- GFP_KERNEL - both background and direct reclaim are allowed and the
_default_ page allocator behavior is used. That means that !costly
allocation requests are basically nofail but there is no guarantee of
that behavior so failures have to be checked properly by callers
(e.g. OOM killer victim is allowed to fail currently).
- GFP_KERNEL | __GFP_NORETRY - overrides the default allocator behavior
and all allocation requests fail early rather than cause disruptive
reclaim (one round of reclaim in this implementation). The OOM killer
is not invoked.
- GFP_KERNEL | __GFP_RETRY_MAYFAIL - overrides the default allocator
behavior and all allocation requests try really hard. The request
will fail if the reclaim cannot make any progress. The OOM killer
won't be triggered.
- GFP_KERNEL | __GFP_NOFAIL - overrides the default allocator behavior
and all allocation requests will loop endlessly until they succeed.
This might be really dangerous especially for larger orders.
Existing users of __GFP_REPEAT are changed to __GFP_RETRY_MAYFAIL
because they already had their semantic. No new users are added.
__alloc_pages_slowpath is changed to bail out for __GFP_RETRY_MAYFAIL if
there is no progress and we have already passed the OOM point.
This means that all the reclaim opportunities have been exhausted except
the most disruptive one (the OOM killer) and a user defined fallback
behavior is more sensible than keep retrying in the page allocator.
[akpm@linux-foundation.org: fix arch/sparc/kernel/mdesc.c]
[mhocko@suse.com: semantic fix]
Link: http://lkml.kernel.org/r/20170626123847.GM11534@dhcp22.suse.cz
[mhocko@kernel.org: address other thing spotted by Vlastimil]
Link: http://lkml.kernel.org/r/20170626124233.GN11534@dhcp22.suse.cz
Link: http://lkml.kernel.org/r/20170623085345.11304-3-mhocko@kernel.org
Cc: Alex Belits <alex.belits@cavium.com>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Darrick J. Wong <darrick.wong@oracle.com>
Cc: David Daney <david.daney@cavium.com>
Cc: NeilBrown <neilb@suse.com>
The main goal of direct compaction is to form a high-order page for
allocation, but it should also help against long-term fragmentation when
possible.
Most lower-than-pageblock-order compactions are for non-movable
allocations, which means that if we compact in a movable pageblock and
terminate as soon as we create the high-order page, it's unlikely that
the fallback heuristics will claim the whole block. Instead there might
be a single unmovable page in a pageblock full of movable pages, and the
next unmovable allocation might pick another pageblock and increase
long-term fragmentation.
To help against such scenarios, this patch changes the termination
criteria for compaction so that the current pageblock is finished even
though the high-order page already exists. Note that it might be
possible that the high-order page formed elsewhere in the zone due to
parallel activity, but this patch doesn't try to detect that.
This is only done with sync compaction, because async compaction is
limited to pageblock of the same migratetype, where it cannot result in
a migratetype fallback. (Async compaction also eagerly skips
order-aligned blocks where isolation fails, which is against the goal of
migrating away as much of the pageblock as possible.)
As a result of this patch, long-term memory fragmentation should be
reduced.
In testing based on 4.9 kernel with stress-highalloc from mmtests
configured for order-4 GFP_KERNEL allocations, this patch has reduced
the number of unmovable allocations falling back to movable pageblocks
by 20%. The number
Link: http://lkml.kernel.org/r/20170307131545.28577-9-vbabka@suse.cz
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Preparation patch. We are going to need migratetype at lower layers
than compact_zone() and compact_finished().
Link: http://lkml.kernel.org/r/20170307131545.28577-7-vbabka@suse.cz
Patch series "try to reduce fragmenting fallbacks", v3.
Last year, Johannes Weiner has reported a regression in page mobility
grouping [1] and while the exact cause was not found, I've come up with
some ways to improve it by reducing the number of allocations falling
back to different migratetype and causing permanent fragmentation.
The series was tested with mmtests stress-highalloc modified to do
GFP_KERNEL order-4 allocations, on 4.9 with "mm, vmscan: fix zone
balance check in prepare_kswapd_sleep" (without that, kcompactd indeed
wasn't woken up) on UMA machine with 4GB memory. There were 5 repeats
of each run, as the extfrag stats are quite volatile (note the stats
below are sums, not averages, as it was less perl hacking for me).
Success rate are the same, already high due to the low allocation order
used, so I'm not including them.
Compaction stats:
(the patches are stacked, and I haven't measured the non-functional-changes
patches separately)
patch 1 patch 2 patch 3 patch 4 patch 7 patch 8
Compaction stalls 22449 24680 24846 19765 22059 17480
Compaction success 12971 14836 14608 10475 11632 8757
Compaction failures 9477 9843 10238 9290 10426 8722
Page migrate success 3109022 3370438 3312164 1695105 1608435 2111379
Page migrate failure 911588 1149065 1028264 1112675 1077251 1026367
Compaction pages isolated 7242983 8015530 7782467 4629063 4402787 5377665
Compaction migrate scanned 980838938 987367943 957690188 917647238 947155598 1018922197
Compaction free scanned 557926893 598946443 602236894 594024490 541169699 763651731
Compaction cost 10243 10578 10304 8286 8398 9440
Compaction stats are mostly within noise until patch 4, which decreases
the number of compactions, and migrations. Part of that could be due to
more pageblocks marked as unmovable, and async compaction skipping
those. This changes a bit with patch 7, but not so much. Patch 8
increases free scanner stats and migrations, which comes from the
changed termination criteria. Interestingly number of compactions
decreases - probably the fully compacted pageblock satisfies multiple
subsequent allocations, so it amortizes.
Next comes the extfrag tracepoint, where "fragmenting" means that an
allocation had to fallback to a pageblock of another migratetype which
wasn't fully free (which is almost all of the fallbacks). I have
locally added another tracepoint for "Page steal" into
steal_suitable_fallback() which triggers in situations where we are
allowed to do move_freepages_block(). If we decide to also do
set_pageblock_migratetype(), it's "Pages steal with pageblock" with
break down for which allocation migratetype we are stealing and from
which fallback migratetype. The last part "due to counting" comes from
patch 4 and counts the events where the counting of movable pages
allowed us to change pageblock's migratetype, while the number of free
pages alone wouldn't be enough to cross the threshold.
Page alloc extfrag event 10155066 8522968 10164959 15622080 13727068 13140319
Extfrag fragmenting 10149231 8517025 10159040 15616925 13721391 13134792
Extfrag fragmenting for unmovable 159504 168500 184177 97835 70625 56948
Extfrag fragmenting unmovable placed with movable 153613 163549 172693 91740 64099 50917
Extfrag fragmenting unmovable placed with reclaim. 5891 4951 11484 6095 6526 6031
Extfrag fragmenting for reclaimable 4738 4829 6345 4822 5640 5378
Extfrag fragmenting reclaimable placed with movable 1836 1902 1851 1579 1739 1760
Extfrag fragmenting reclaimable placed with unmov. 2902 2927 4494 3243 3901 3618
Extfrag fragmenting for movable 9984989 8343696 9968518 15514268 13645126 13072466
Pages steal 179954 192291 210880 123254 94545 81486
Pages steal with pageblock 22153 18943 20154 33562 29969 33444
Pages steal with pageblock for unmovable 14350 12858 13256 20660 19003 20852
Pages steal with pageblock for unmovable from mov. 12812 11402 11683 19072 17467 19298
Pages steal with pageblock for unmovable from recl. 1538 1456 1573 1588 1536 1554
Pages steal with pageblock for movable 7114 5489 5965 11787 10012 11493
Pages steal with pageblock for movable from unmov. 6885 5291 5541 11179 9525 10885
Pages steal with pageblock for movable from recl. 229 198 424 608 487 608
Pages steal with pageblock for reclaimable 689 596 933 1115 954 1099
Pages steal with pageblock for reclaimable from unmov. 273 219 537 658 547 667
Pages steal with pageblock for reclaimable from mov. 416 377 396 457 407 432
Pages steal with pageblock due to counting 11834 10075 7530
... for unmovable 8993 7381 4616
... for movable 2792 2653 2851
... for reclaimable 49 41 63
What we can see is that "Extfrag fragmenting for unmovable" and "...
placed with movable" drops with almost each patch, which is good as we
are polluting less movable pageblocks with unmovable pages.
The most significant change is patch 4 with movable page counting. On
the other hand it increases "Extfrag fragmenting for movable" by 50%.
"Pages steal" drops though, so these movable allocation fallbacks find
only small free pages and are not allowed to steal whole pageblocks
back. "Pages steal with pageblock" raises, because the patch increases
the chances of pageblock migratetype changes to happen. This affects
all migratetypes.
The summary is that patch 4 is not a clear win wrt these stats, but I
believe that the tradeoff it makes is a good one. There's less
pollution of movable pageblocks by unmovable allocations. There's less
stealing between pageblock, and those that remain have higher chance of
changing migratetype also the pageblock itself, so it should more
faithfully reflect the migratetype of the pages within the pageblock.
The increase of movable allocations falling back to unmovable pageblock
might look dramatic, but those allocations can be migrated by compaction
when needed, and other patches in the series (7-9) improve that aspect.
Patches 7 and 8 continue the trend of reduced unmovable fallbacks and
also reduce the impact on movable fallbacks from patch 4.
[1] https://www.spinics.net/lists/linux-mm/msg114237.html
This patch (of 8):
While currently there are (mostly by accident) no holes in struct
compact_control (on x86_64), but we are going to add more bool flags, so
place them all together to the end of the structure. While at it, just
order all fields from largest to smallest.
Link: http://lkml.kernel.org/r/20170307131545.28577-2-vbabka@suse.cz
Introduce two helpers, is_migrate_highatomic() and is_migrate_highatomic_page().
Simplify the code, no functional changes.
[akpm@linux-foundation.org: use static inlines rather than macros, per mhocko]
Link: http://lkml.kernel.org/r/58B94F15.6060606@huawei.com
Signed-off-by: Xishi Qiu <qiuxishi@huawei.com>
Cc: Minchan Kim <minchan@kernel.org>
NR_PAGES_SCANNED counts number of pages scanned since the last page free
event in the allocator. This was used primarily to measure the
reclaimability of zones and nodes, and determine when reclaim should
give up on them. In that role, it has been replaced in the preceding
patches by a different mechanism.
Being implemented as an efficient vmstat counter, it was automatically
exported to userspace as well. It's however unlikely that anyone
outside the kernel is using this counter in any meaningful way.
Remove the counter and the unused pgdat_reclaimable().
Link: http://lkml.kernel.org/r/20170228214007.5621-8-hannes@cmpxchg.org
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com>
Cc: Jia He <hejianet@gmail.com>
Patch series "mm: kswapd spinning on unreclaimable nodes - fixes and
cleanups".
Jia reported a scenario in which the kswapd of a node indefinitely spins
at 100% CPU usage. We have seen similar cases at Facebook.
The kernel's current method of judging its ability to reclaim a node (or
whether to back off and sleep) is based on the amount of scanned pages
in proportion to the amount of reclaimable pages. In Jia's and our
scenarios, there are no reclaimable pages in the node, however, and the
condition for backing off is never met. Kswapd busyloops in an attempt
to restore the watermarks while having nothing to work with.
This series reworks the definition of an unreclaimable node based not on
scanning but on whether kswapd is able to actually reclaim pages in
MAX_RECLAIM_RETRIES (16) consecutive runs. This is the same criteria
the page allocator uses for giving up on direct reclaim and invoking the
OOM killer. If it cannot free any pages, kswapd will go to sleep and
leave further attempts to direct reclaim invocations, which will either
make progress and re-enable kswapd, or invoke the OOM killer.
Patch #1 fixes the immediate problem Jia reported, the remainder are
smaller fixlets, cleanups, and overall phasing out of the old method.
Patch #6 is the odd one out. It's a nice cleanup to get_scan_count(),
and directly related to #5, but in itself not relevant to the series.
If the whole series is too ambitious for 4.11, I would consider the
first three patches fixes, the rest cleanups.
This patch (of 9):
Jia He reports a problem with kswapd spinning at 100% CPU when
requesting more hugepages than memory available in the system:
$ echo 4000 >/proc/sys/vm/nr_hugepages
top - 13:42:59 up 3:37, 1 user, load average: 1.09, 1.03, 1.01
Tasks: 1 total, 1 running, 0 sleeping, 0 stopped, 0 zombie
%Cpu(s): 0.0 us, 12.5 sy, 0.0 ni, 85.5 id, 2.0 wa, 0.0 hi, 0.0 si, 0.0 st
KiB Mem: 31371520 total, 30915136 used, 456384 free, 320 buffers
KiB Swap: 6284224 total, 115712 used, 6168512 free. 48192 cached Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
76 root 20 0 0 0 0 R 100.0 0.000 217:17.29 kswapd3
At that time, there are no reclaimable pages left in the node, but as
kswapd fails to restore the high watermarks it refuses to go to sleep.
Kswapd needs to back away from nodes that fail to balance. Up until
commit 1d82de618ddd ("mm, vmscan: make kswapd reclaim in terms of
nodes") kswapd had such a mechanism. It considered zones whose
theoretically reclaimable pages it had reclaimed six times over as
unreclaimable and backed away from them. This guard was erroneously
removed as the patch changed the definition of a balanced node.
However, simply restoring this code wouldn't help in the case reported
here: there *are* no reclaimable pages that could be scanned until the
threshold is met. Kswapd would stay awake anyway.
Introduce a new and much simpler way of backing off. If kswapd runs
through MAX_RECLAIM_RETRIES (16) cycles without reclaiming a single
page, make it back off from the node. This is the same number of shots
direct reclaim takes before declaring OOM. Kswapd will go to sleep on
that node until a direct reclaimer manages to reclaim some pages, thus
proving the node reclaimable again.
[hannes@cmpxchg.org: check kswapd failure against the cumulative nr_reclaimed count]
Link: http://lkml.kernel.org/r/20170306162410.GB2090@cmpxchg.org
[shakeelb@google.com: fix condition for throttle_direct_reclaim]
Link: http://lkml.kernel.org/r/20170314183228.20152-1-shakeelb@google.com
Link: http://lkml.kernel.org/r/20170228214007.5621-2-hannes@cmpxchg.org
Signed-off-by: Shakeel Butt <shakeelb@google.com>
Reported-by: Jia He <hejianet@gmail.com>
Tested-by: Jia He <hejianet@gmail.com>
Acked-by: Minchan Kim <minchan@kernel.org>
We currently have 2 specific WQ_RECLAIM workqueues in the mm code.
vmstat_wq for updating pcp stats and lru_add_drain_wq dedicated to drain
per cpu lru caches. This seems more than necessary because both can run
on a single WQ. Both do not block on locks requiring a memory
allocation nor perform any allocations themselves. We will save one
rescuer thread this way.
On the other hand drain_all_pages() queues work on the system wq which
doesn't have rescuer and so this depend on memory allocation (when all
workers are stuck allocating and new ones cannot be created).
Initially we thought this would be more of a theoretical problem but
Hugh Dickins has reported:
: 4.11-rc has been giving me hangs after hours of swapping load. At
: first they looked like memory leaks ("fork: Cannot allocate memory");
: but for no good reason I happened to do "cat /proc/sys/vm/stat_refresh"
: before looking at /proc/meminfo one time, and the stat_refresh stuck
: in D state, waiting for completion of flush_work like many kworkers.
: kthreadd waiting for completion of flush_work in drain_all_pages().
This worker should be using WQ_RECLAIM as well in order to guarantee a
forward progress. We can reuse the same one as for lru draining and
vmstat.
Link: http://lkml.kernel.org/r/20170307131751.24936-1-mhocko@kernel.org
Suggested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Tested-by: Yang Li <pku.leo@gmail.com>
Tested-by: Hugh Dickins <hughd@google.com>
Current rmap code can miss a VMA that maps PTE-mapped THP if the first
suppage of the THP was unmapped from the VMA.
We need to walk rmap for the whole range of offsets that THP covers, not
only the first one.
vma_address() also need to be corrected to check the range instead of
the first subpage.
Link: http://lkml.kernel.org/r/20170129173858.45174-6-kirill.shutemov@linux.intel.com
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Cc: Vladimir Davydov <vdavydov.dev@gmail.com>
Logic on whether we can reap pages from the VMA should match what we
have in madvise_dontneed(). In particular, we should skip, VM_PFNMAP
VMAs, but we don't now.
Let's just extract condition on which we can shoot down pagesi from a
VMA with MADV_DONTNEED into separate function and use it in both places.
Link: http://lkml.kernel.org/r/20170118122429.43661-4-kirill.shutemov@linux.intel.com
A "compact_daemon_wake" vmstat exists that represents the number of
times kcompactd has woken up. This doesn't represent how much work it
actually did, though.
It's useful to understand how much compaction work is being done by
kcompactd versus other methods such as direct compaction and explicitly
triggered per-node (or system) compaction.
This adds two new vmstats: "compact_daemon_migrate_scanned" and
"compact_daemon_free_scanned" to represent the number of pages kcompactd
has scanned as part of its migration scanner and freeing scanner,
respectively.
These values are still accounted for in the general
"compact_migrate_scanned" and "compact_free_scanned" for compatibility.
It could be argued that explicitly triggered compaction could also be
tracked separately, and that could be added if others find it useful.
Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1612071749390.69852@chino.kir.corp.google.com
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Michal Hocko <mhocko@kernel.org>
In __free_one_page() we do the buddy merging arithmetics on "page/buddy
index", which is just the lower MAX_ORDER bits of pfn. The operations
we do that affect the higher bits are bitwise AND and subtraction (in
that order), where the final result will be the same with the higher
bits left unmasked, as long as these bits are equal for both buddies -
which must be true by the definition of a buddy.
We can therefore use pfn's directly instead of "index" and skip the
zeroing of >MAX_ORDER bits. This can help a bit by itself, although
compiler might be smart enough already. It also helps the next patch to
avoid page_to_pfn() for memory hole checks.
Link: http://lkml.kernel.org/r/20161216120009.20064-1-vbabka@suse.cz
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Add a new page flag, PageWaiters, to indicate the page waitqueue has
tasks waiting. This can be tested rather than testing waitqueue_active
which requires another cacheline load.
This bit is always set when the page has tasks on page_waitqueue(page),
and is set and cleared under the waitqueue lock. It may be set when
there are no tasks on the waitqueue, which will cause a harmless extra
wakeup check that will clears the bit.
The generic bit-waitqueue infrastructure is no longer used for pages.
Instead, waitqueues are used directly with a custom key type. The
generic code was not flexible enough to have PageWaiters manipulation
under the waitqueue lock (which simplifies concurrency).
This improves the performance of page lock intensive microbenchmarks by
2-3%.
Putting two bits in the same word opens the opportunity to remove the
memory barrier between clearing the lock bit and testing the waiters
bit, after some work on the arch primitives (e.g., ensuring memory
operand widths match and cover both bits).
Signed-off-by: Nicholas Piggin <npiggin@gmail.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Bob Peterson <rpeterso@redhat.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Andrew Lutomirski <luto@kernel.org>
Cc: Andreas Gruenbacher <agruenba@redhat.com>
Add orig_pte field to vm_fault structure to allow ->page_mkwrite
handlers to fully handle the fault.
This also allows us to save some passing of extra arguments around.
Link: http://lkml.kernel.org/r/1479460644-25076-8-git-send-email-jack@suse.cz
Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Currently we have two different structures for passing fault information
around - struct vm_fault and struct fault_env. DAX will need more
information in struct vm_fault to handle its faults so the content of
that structure would become event closer to fault_env. Furthermore it
would need to generate struct fault_env to be able to call some of the
generic functions. So at this point I don't think there's much use in
keeping these two structures separate. Just embed into struct vm_fault
all that is needed to use it for both purposes.
Link: http://lkml.kernel.org/r/1479460644-25076-2-git-send-email-jack@suse.cz
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
Several people have reported premature OOMs for order-2 allocations
(stack) due to OOM rework in 4.7. In the scenario (parallel kernel
build and dd writing to two drives) many pageblocks get marked as
Unmovable and compaction free scanner struggles to isolate free pages.
Joonsoo Kim pointed out that the free scanner skips pageblocks that are
not movable to prevent filling them and forcing non-movable allocations
to fallback to other pageblocks. Such heuristic makes sense to help
prevent long-term fragmentation, but premature OOMs are relatively more
urgent problem. As a compromise, this patch disables the heuristic only
for the ultimate compaction priority.
Link: http://lkml.kernel.org/r/20160906135258.18335-5-vbabka@suse.cz
Reported-by: Ralf-Peter Rohbeck <Ralf-Peter.Rohbeck@quantum.com>
Reported-by: Arkadiusz Miskiewicz <a.miskiewicz@gmail.com>
Reported-by: Olaf Hering <olaf@aepfle.de>
Suggested-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
Patch series "make direct compaction more deterministic")
This is mostly a followup to Michal's oom detection rework, which
highlighted the need for direct compaction to provide better feedback in
reclaim/compaction loop, so that it can reliably recognize when
compaction cannot make further progress, and allocation should invoke
OOM killer or fail. We've discussed this at LSF/MM [1] where I proposed
expanding the async/sync migration mode used in compaction to more
general "priorities". This patchset adds one new priority that just
overrides all the heuristics and makes compaction fully scan all zones.
I don't currently think that we need more fine-grained priorities, but
we'll see. Other than that there's some smaller fixes and cleanups,
mainly related to the THP-specific hacks.
I've tested this with stress-highalloc in GFP_KERNEL order-4 and
THP-like order-9 scenarios. There's some improvement for compaction
stats for the order-4, which is likely due to the better watermarks
handling. In the previous version I reported mostly noise wrt
compaction stats, and decreased direct reclaim - now the reclaim is
without difference. I believe this is due to the less aggressive
compaction priority increase in patch 6.
"before" is a mmotm tree prior to 4.7 release plus the first part of the
series that was sent and merged separately
before after
order-4:
Compaction stalls 27216 30759
Compaction success 19598 25475
Compaction failures 7617 5283
Page migrate success 370510 464919
Page migrate failure 25712 27987
Compaction pages isolated 849601 1041581
Compaction migrate scanned 143146541 101084990
Compaction free scanned 208355124 144863510
Compaction cost 1403 1210
order-9:
Compaction stalls 7311 7401
Compaction success 1634 1683
Compaction failures 5677 5718
Page migrate success 194657 183988
Page migrate failure 4753 4170
Compaction pages isolated 498790 456130
Compaction migrate scanned 565371 524174
Compaction free scanned 4230296 4250744
Compaction cost 215 203
[1] https://lwn.net/Articles/684611/
This patch (of 11):
A recent patch has added whole_zone flag that compaction sets when
scanning starts from the zone boundary, in order to report that zone has
been fully scanned in one attempt. For allocations that want to try
really hard or cannot fail, we will want to introduce a mode where
scanning whole zone is guaranteed regardless of the cached positions.
This patch reuses the whole_zone flag in a way that if it's already
passed true to compaction, the cached scanner positions are ignored.
Employing this flag during reclaim/compaction loop will be done in the
next patch. This patch however converts compaction invoked from
userspace via procfs to use this flag. Before this patch, the cached
positions were first reset to zone boundaries and then read back from
struct zone, so there was a window where a parallel compaction could
replace the reset values, making the manual compaction less effective.
Using the flag instead of performing reset is more robust.
Link: http://lkml.kernel.org/r/20160810091226.6709-2-vbabka@suse.cz
Tested-by: Lorenzo Stoakes <lstoakes@gmail.com>
Async compaction detects contention either due to failing trylock on
zone->lock or lru_lock, or by need_resched(). Since 1f9efdef4f3f ("mm,
compaction: khugepaged should not give up due to need_resched()") the
code got quite complicated to distinguish these two up to the
__alloc_pages_slowpath() level, so different decisions could be taken
for khugepaged allocations.
After the recent changes, khugepaged allocations don't check for
contended compaction anymore, so we again don't need to distinguish lock
and sched contention, and simplify the current convoluted code a lot.
However, I believe it's also possible to simplify even more and
completely remove the check for contended compaction after the initial
async compaction for costly orders, which was originally aimed at THP
page fault allocations. There are several reasons why this can be done
now:
- with the new defaults, THP page faults no longer do reclaim/compaction at
all, unless the system admin has overridden the default, or application has
indicated via madvise that it can benefit from THP's. In both cases, it
means that the potential extra latency is expected and worth the benefits.
- even if reclaim/compaction proceeds after this patch where it previously
wouldn't, the second compaction attempt is still async and will detect the
contention and back off, if the contention persists
- there are still heuristics like deferred compaction and pageblock skip bits
in place that prevent excessive THP page fault latencies
Link: http://lkml.kernel.org/r/20160721073614.24395-9-vbabka@suse.cz
The fair zone allocation policy interleaves allocation requests between
zones to avoid an age inversion problem whereby new pages are reclaimed
to balance a zone. Reclaim is now node-based so this should no longer
be an issue and the fair zone allocation policy is not free. This patch
removes it.
Link: http://lkml.kernel.org/r/1467970510-21195-30-git-send-email-mgorman@techsingularity.net
Signed-off-by: Mel Gorman <mgorman@techsingularity.net>
Cc: Hillf Danton <hillf.zj@alibaba-inc.com>
Cc: Rik van Riel <riel@surriel.com>
As reclaim is now per-node based, convert zone_reclaim to be
node_reclaim. It is possible that a node will be reclaimed multiple
times if it has multiple zones but this is unavoidable without caching
all nodes traversed so far. The documentation and interface to
userspace is the same from a configuration perspective and will will be
similar in behaviour unless the node-local allocation requests were also
limited to lower zones.
Link: http://lkml.kernel.org/r/1467970510-21195-24-git-send-email-mgorman@techsingularity.net
This moves the LRU lists from the zone to the node and related data such
as counters, tracing, congestion tracking and writeback tracking.
Unfortunately, due to reclaim and compaction retry logic, it is
necessary to account for the number of LRU pages on both zone and node
logic. Most reclaim logic is based on the node counters but the retry
logic uses the zone counters which do not distinguish inactive and
active sizes. It would be possible to leave the LRU counters on a
per-zone basis but it's a heavier calculation across multiple cache
lines that is much more frequent than the retry checks.
Other than the LRU counters, this is mostly a mechanical patch but note
that it introduces a number of anomalies. For example, the scans are
per-zone but using per-node counters. We also mark a node as congested
when a zone is congested. This causes weird problems that are fixed
later but is easier to review.
In the event that there is excessive overhead on 32-bit systems due to
the nodes being on LRU then there are two potential solutions
1. Long-term isolation of highmem pages when reclaim is lowmem
When pages are skipped, they are immediately added back onto the LRU
list. If lowmem reclaim persisted for long periods of time, the same
highmem pages get continually scanned. The idea would be that lowmem
keeps those pages on a separate list until a reclaim for highmem pages
arrives that splices the highmem pages back onto the LRU. It potentially
could be implemented similar to the UNEVICTABLE list.
That would reduce the skip rate with the potential corner case is that
highmem pages have to be scanned and reclaimed to free lowmem slab pages.
2. Linear scan lowmem pages if the initial LRU shrink fails
This will break LRU ordering but may be preferable and faster during
memory pressure than skipping LRU pages.
Link: http://lkml.kernel.org/r/1467970510-21195-4-git-send-email-mgorman@techsingularity.net
The idea borrowed from Peter's patch from patchset on speculative page
faults[1]:
Instead of passing around the endless list of function arguments,
replace the lot with a single structure so we can change context without
endless function signature changes.
The changes are mostly mechanical with exception of faultaround code:
filemap_map_pages() got reworked a bit.
This patch is preparation for the next one.
[1] http://lkml.kernel.org/r/20141020222841.302891540@infradead.org
Link: http://lkml.kernel.org/r/1466021202-61880-9-git-send-email-kirill.shutemov@linux.intel.com
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
This patch makes swapin readahead to improve thp collapse rate. When
khugepaged scanned pages, there can be a few of the pages in swap area.
With the patch THP can collapse 4kB pages into a THP when there are up
to max_ptes_swap swap ptes in a 2MB range.
The patch was tested with a test program that allocates 400B of memory,
writes to it, and then sleeps. I force the system to swap out all.
Afterwards, the test program touches the area by writing, it skips a
page in each 20 pages of the area.
Without the patch, system did not swap in readahead. THP rate was %65
of the program of the memory, it did not change over time.
With this patch, after 10 minutes of waiting khugepaged had collapsed
%99 of the program's memory.
[kirill.shutemov@linux.intel.com: trivial cleanup of exit path of the function]
[kirill.shutemov@linux.intel.com: __collapse_huge_page_swapin(): drop unused 'pte' parameter]
[kirill.shutemov@linux.intel.com: do not hold anon_vma lock during swap in]
Signed-off-by: Ebru Akagunduz <ebru.akagunduz@gmail.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Xie XiuQi <xiexiuqi@huawei.com>
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
This patch is motivated from Hugh and Vlastimil's concern [1].
There are two ways to get freepage from the allocator. One is using
normal memory allocation API and the other is __isolate_free_page()
which is internally used for compaction and pageblock isolation. Later
usage is rather tricky since it doesn't do whole post allocation
processing done by normal API.
One problematic thing I already know is that poisoned page would not be
checked if it is allocated by __isolate_free_page(). Perhaps, there
would be more.
We could add more debug logic for allocated page in the future and this
separation would cause more problem. I'd like to fix this situation at
this time. Solution is simple. This patch commonize some logic for
newly allocated page and uses it on all sites. This will solve the
problem.
[1] http://marc.info/?i=alpine.LSU.2.11.1604270029350.7066%40eggly.anvils%3E
[iamjoonsoo.kim@lge.com: mm-page_alloc-introduce-post-allocation-processing-on-page-allocator-v3]
Link: http://lkml.kernel.org/r/1464230275-25791-7-git-send-email-iamjoonsoo.kim@lge.com
Link: http://lkml.kernel.org/r/1466150259-27727-9-git-send-email-iamjoonsoo.kim@lge.com
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Alexander Potapenko <glider@google.com>
Commit d0164adc89f6 ("mm, page_alloc: distinguish between being unable
to sleep, unwilling to sleep and avoiding waking kswapd") modified
__GFP_WAIT to explicitly identify the difference between atomic callers
and those that were unwilling to sleep. Later the definition was
removed entirely.
The GFP_RECLAIM_MASK is the set of flags that affect watermark checking
and reclaim behaviour but __GFP_ATOMIC was never added. Without it,
atomic users of the slab allocator strip the __GFP_ATOMIC flag and
cannot access the page allocator atomic reserves. This patch addresses
the problem.
The user-visible impact depends on the workload but potentially atomic
allocations unnecessarily fail without this path.
Link: http://lkml.kernel.org/r/20160610093832.GK2527@techsingularity.net
Reported-by: Marcin Wojtas <mw@semihalf.com>
Cc: <stable@vger.kernel.org> [4.4+]
All the callers of vm_mmap seem to check for the failure already and
bail out in one way or another on the error which means that we can
change it to use killable version of vm_mmap_pgoff and return -EINTR if
the current task gets killed while waiting for mmap_sem. This also
means that vm_mmap_pgoff can be killable by default and drop the
additional parameter.
This will help in the OOM conditions when the oom victim might be stuck
waiting for the mmap_sem for write which in turn can block oom_reaper
which relies on the mmap_sem for read to make a forward progress and
reclaim the address space of the victim.
Please note that load_elf_binary is ignoring vm_mmap error for
current->personality & MMAP_PAGE_ZERO case but that shouldn't be a
problem because the address is not used anywhere and we never return to
the userspace if we got killed.
This is a follow up work for oom_reaper [1]. As the async OOM killing
depends on oom_sem for read we would really appreciate if a holder for
write didn't stood in the way. This patchset is changing many of
down_write calls to be killable to help those cases when the writer is
blocked and waiting for readers to release the lock and so help
__oom_reap_task to process the oom victim.
Most of the patches are really trivial because the lock is help from a
shallow syscall paths where we can return EINTR trivially and allow the
current task to die (note that EINTR will never get to the userspace as
the task has fatal signal pending). Others seem to be easy as well as
the callers are already handling fatal errors and bail and return to
userspace which should be sufficient to handle the failure gracefully.
I am not familiar with all those code paths so a deeper review is really
appreciated.
As this work is touching more areas which are not directly connected I
have tried to keep the CC list as small as possible and people who I
believed would be familiar are CCed only to the specific patches (all
should have received the cover though).
This patchset is based on linux-next and it depends on
down_write_killable for rw_semaphores which got merged into tip
locking/rwsem branch and it is merged into this next tree. I guess it
would be easiest to route these patches via mmotm because of the
dependency on the tip tree but if respective maintainers prefer other
way I have no objections.
I haven't covered all the mmap_write(mm->mmap_sem) instances here
$ git grep "down_write(.*\<mmap_sem\>)" next/master | wc -l
98
$ git grep "down_write(.*\<mmap_sem\>)" | wc -l
62
I have tried to cover those which should be relatively easy to review in
this series because this alone should be a nice improvement. Other
places can be changed on top.
[0] http://lkml.kernel.org/r/1456752417-9626-1-git-send-email-mhocko@kernel.org
[1] http://lkml.kernel.org/r/1452094975-551-1-git-send-email-mhocko@kernel.org
[2] http://lkml.kernel.org/r/1456750705-7141-1-git-send-email-mhocko@kernel.org
This patch (of 18):
This is the first step in making mmap_sem write waiters killable. It
focuses on the trivial ones which are taking the lock early after
entering the syscall and they are not changing state before.
Therefore it is very easy to change them to use down_write_killable and
immediately return with -EINTR. This will allow the waiter to pass away
without blocking the mmap_sem which might be required to make a forward
progress. E.g. the oom reaper will need the lock for reading to
dismantle the OOM victim address space.
The only tricky function in this patch is vm_mmap_pgoff which has many
call sites via vm_mmap. To reduce the risk keep vm_mmap with the
original non-killable semantic for now.
vm_munmap callers do not bother checking the return value so open code
it into the munmap syscall path for now for simplicity.
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
COMPACT_COMPLETE now means that compaction and free scanner met. This
is not very useful information if somebody just wants to use this
feedback and make any decisions based on that. The current caller might
be a poor guy who just happened to scan tiny portion of the zone and
that could be the reason no suitable pages were compacted. Make sure we
distinguish the full and partial zone walks.
Consumers should treat COMPACT_PARTIAL_SKIPPED as a potential success
and be optimistic in retrying.
The existing users of COMPACT_COMPLETE are conservatively changed to use
COMPACT_PARTIAL_SKIPPED as well but some of them should be probably
reconsidered and only defer the compaction only for COMPACT_COMPLETE
with the new semantic.
This patch shouldn't introduce any functional changes.
Cc: Vladimir Davydov <vdavydov@virtuozzo.com>
The classzone_idx can be inferred from preferred_zoneref so remove the
unnecessary field and save stack space.
Cc: Jesper Dangaard Brouer <brouer@redhat.com>
The allocator fast path looks up the first usable zone in a zonelist and
then get_page_from_freelist does the same job in the zonelist iterator.
This patch preserves the necessary information.
4.6.0-rc2 4.6.0-rc2
fastmark-v1r20 initonce-v1r20
Min alloc-odr0-1 364.00 ( 0.00%) 359.00 ( 1.37%)
Min alloc-odr0-2 262.00 ( 0.00%) 260.00 ( 0.76%)
Min alloc-odr0-4 214.00 ( 0.00%) 214.00 ( 0.00%)
Min alloc-odr0-8 186.00 ( 0.00%) 186.00 ( 0.00%)
Min alloc-odr0-16 173.00 ( 0.00%) 173.00 ( 0.00%)
Min alloc-odr0-32 165.00 ( 0.00%) 165.00 ( 0.00%)
Min alloc-odr0-64 161.00 ( 0.00%) 162.00 ( -0.62%)
Min alloc-odr0-128 159.00 ( 0.00%) 161.00 ( -1.26%)
Min alloc-odr0-256 168.00 ( 0.00%) 170.00 ( -1.19%)
Min alloc-odr0-512 180.00 ( 0.00%) 181.00 ( -0.56%)
Min alloc-odr0-1024 190.00 ( 0.00%) 190.00 ( 0.00%)
Min alloc-odr0-2048 196.00 ( 0.00%) 196.00 ( 0.00%)
Min alloc-odr0-4096 202.00 ( 0.00%) 202.00 ( 0.00%)
Min alloc-odr0-8192 206.00 ( 0.00%) 205.00 ( 0.49%)
Min alloc-odr0-16384 206.00 ( 0.00%) 205.00 ( 0.49%)
The benefit is negligible and the results are within the noise but each
cycle counts.
alloc_flags is a bitmask of flags but it is signed which does not
necessarily generate the best code depending on the compiler. Even
without an impact, it makes more sense that this be unsigned.
Many developers already know that field for reference count of the
struct page is _count and atomic type. They would try to handle it
directly and this could break the purpose of page reference count
tracepoint. To prevent direct _count modification, this patch rename it
to _refcount and add warning message on the code. After that, developer
who need to handle reference count will find that field should not be
accessed directly.
[akpm@linux-foundation.org: fix comments, per Vlastimil]
[akpm@linux-foundation.org: Documentation/vm/transhuge.txt too]
[sfr@canb.auug.org.au: sync ethernet driver changes]
Cc: Johannes Berg <johannes@sipsolutions.net>
Cc: Sunil Goutham <sgoutham@cavium.com>
Cc: Chris Metcalf <cmetcalf@mellanox.com>
Cc: Manish Chopra <manish.chopra@qlogic.com>
Cc: Yuval Mintz <yuval.mintz@qlogic.com>
Cc: Tariq Toukan <tariqt@mellanox.com>
Cc: Saeed Mahameed <saeedm@mellanox.com>
This patch (of 5):
This is based on the idea from Mel Gorman discussed during LSFMM 2015
and independently brought up by Oleg Nesterov.
The OOM killer currently allows to kill only a single task in a good
hope that the task will terminate in a reasonable time and frees up its
memory. Such a task (oom victim) will get an access to memory reserves
via mark_oom_victim to allow a forward progress should there be a need
for additional memory during exit path.
It has been shown (e.g. by Tetsuo Handa) that it is not that hard to
construct workloads which break the core assumption mentioned above and
the OOM victim might take unbounded amount of time to exit because it
might be blocked in the uninterruptible state waiting for an event (e.g.
lock) which is blocked by another task looping in the page allocator.
This patch reduces the probability of such a lockup by introducing a
specialized kernel thread (oom_reaper) which tries to reclaim additional
memory by preemptively reaping the anonymous or swapped out memory owned
by the oom victim under an assumption that such a memory won't be needed
when its owner is killed and kicked from the userspace anyway. There is
one notable exception to this, though, if the OOM victim was in the
process of coredumping the result would be incomplete. This is
considered a reasonable constrain because the overall system health is
more important than debugability of a particular application.
A kernel thread has been chosen because we need a reliable way of
invocation so workqueue context is not appropriate because all the
workers might be busy (e.g. allocating memory). Kswapd which sounds
like another good fit is not appropriate as well because it might get
blocked on locks during reclaim as well.
oom_reaper has to take mmap_sem on the target task for reading so the
solution is not 100% because the semaphore might be held or blocked for
write but the probability is reduced considerably wrt. basically any
lock blocking forward progress as described above. In order to prevent
from blocking on the lock without any forward progress we are using only
a trylock and retry 10 times with a short sleep in between. Users of
mmap_sem which need it for write should be carefully reviewed to use
_killable waiting as much as possible and reduce allocations requests
done with the lock held to absolute minimum to reduce the risk even
further.
The API between oom killer and oom reaper is quite trivial.
wake_oom_reaper updates mm_to_reap with cmpxchg to guarantee only
NULL->mm transition and oom_reaper clear this atomically once it is done
with the work. This means that only a single mm_struct can be reaped at
the time. As the operation is potentially disruptive we are trying to
limit it to the ncessary minimum and the reaper blocks any updates while
it operates on an mm. mm_struct is pinned by mm_count to allow parallel
exit_mmap and a race is detected by atomic_inc_not_zero(mm_users).
Suggested-by: Oleg Nesterov <oleg@redhat.com>
Suggested-by: Mel Gorman <mgorman@suse.de>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Andrea Argangeli <andrea@kernel.org>
Most of the mm subsystem uses pr_<level> so make it consistent.
Miscellanea:
- Realign arguments
- Add missing newline to format
- kmemleak-test.c has a "kmemleak: " prefix added to the
"Kmemleak testing" logging message via pr_fmt
Acked-by: Tejun Heo <tj@kernel.org> [percpu]
The success of CMA allocation largely depends on the success of
migration and key factor of it is page reference count. Until now, page
reference is manipulated by direct calling atomic functions so we cannot
follow up who and where manipulate it. Then, it is hard to find actual
reason of CMA allocation failure. CMA allocation should be guaranteed
to succeed so finding offending place is really important.
In this patch, call sites where page reference is manipulated are
converted to introduced wrapper function. This is preparation step to
add tracepoint to each page reference manipulation function. With this
facility, we can easily find reason of CMA allocation failure. There is
no functional change in this patch.
In addition, this patch also converts reference read sites. It will
help a second step that renames page._count to something else and
prevents later attempt to direct access to it (Suggested by Andrew).
Acked-by: Michal Nazarewicz <mina86@mina86.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com>
Similarly to direct reclaim/compaction, kswapd attempts to combine
reclaim and compaction to attempt making memory allocation of given
order available.
The details differ from direct reclaim e.g. in having high watermark as
a goal. The code involved in kswapd's reclaim/compaction decisions has
evolved to be quite complex.
Testing reveals that it doesn't actually work in at least one scenario,
and closer inspection suggests that it could be greatly simplified
without compromising on the goal (make high-order page available) or
efficiency (don't reclaim too much). The simplification relieas of
doing all compaction in kcompactd, which is simply woken up when high
watermarks are reached by kswapd's reclaim.
The scenario where kswapd compaction doesn't work was found with mmtests
test stress-highalloc configured to attempt order-9 allocations without
direct reclaim, just waking up kswapd. There was no compaction attempt
from kswapd during the whole test. Some added instrumentation shows
what happens:
- balance_pgdat() sets end_zone to Normal, as it's not balanced
- reclaim is attempted on DMA zone, which sets nr_attempted to 99, but
it cannot reclaim anything, so sc.nr_reclaimed is 0
- for zones DMA32 and Normal, kswapd_shrink_zone uses testorder=0, so
it merely checks if high watermarks were reached for base pages.
This is true, so no reclaim is attempted. For DMA, testorder=0
wasn't used, as compaction_suitable() returned COMPACT_SKIPPED
- even though the pgdat_needs_compaction flag wasn't set to false, no
compaction happens due to the condition sc.nr_reclaimed >
nr_attempted being false (as 0 < 99)
- priority-- due to nr_reclaimed being 0, repeat until priority reaches
0 pgdat_balanced() is false as only the small zone DMA appears
balanced (curiously in that check, watermark appears OK and
compaction_suitable() returns COMPACT_PARTIAL, because a lower
classzone_idx is used there)
Now, even if it was decided that reclaim shouldn't be attempted on the
DMA zone, the scenario would be the same, as (sc.nr_reclaimed=0 >
nr_attempted=0) is also false. The condition really should use >= as
the comment suggests. Then there is a mismatch in the check for setting
pgdat_needs_compaction to false using low watermark, while the rest uses
high watermark, and who knows what other subtlety. Hopefully this
demonstrates that this is unsustainable.
Luckily we can simplify this a lot. The reclaim/compaction decisions
make sense for direct reclaim scenario, but in kswapd, our primary goal
is to reach high watermark in order-0 pages. Afterwards we can attempt
compaction just once. Unlike direct reclaim, we don't reclaim extra
pages (over the high watermark), the current code already disallows it
for good reasons.
After this patch, we simply wake up kcompactd to process the pgdat,
after we have either succeeded or failed to reach the high watermarks in
kswapd, which goes to sleep. We pass kswapd's order and classzone_idx,
so kcompactd can apply the same criteria to determine which zones are
worth compacting. Note that we use the classzone_idx from
wakeup_kswapd(), not balanced_classzone_idx which can include higher
zones that kswapd tried to balance too, but didn't consider them in
pgdat_balanced().
Since kswapd now cannot create high-order pages itself, we need to
adjust how it determines the zones to be balanced. The key element here
is adding a "highorder" parameter to zone_balanced, which, when set to
false, makes it consider only order-0 watermark instead of the desired
higher order (this was done previously by kswapd_shrink_zone(), but not
elsewhere). This false is passed for example in pgdat_balanced().
Importantly, wakeup_kswapd() uses true to make sure kswapd and thus
kcompactd are woken up for a high-order allocation failure.
The last thing is to decide what to do with pageblock_skip bitmap
handling. Compaction maintains a pageblock_skip bitmap to record
pageblocks where isolation recently failed. This bitmap can be reset by
three ways:
1) direct compaction is restarting after going through the full deferred cycle
2) kswapd goes to sleep, and some other direct compaction has previously
finished scanning the whole zone and set zone->compact_blockskip_flush.
Note that a successful direct compaction clears this flag.
3) compaction was invoked manually via trigger in /proc
The case 2) is somewhat fuzzy to begin with, but after introducing
kcompactd we should update it. The check for direct compaction in 1),
and to set the flush flag in 2) use current_is_kswapd(), which doesn't
work for kcompactd. Thus, this patch adds bool direct_compaction to
compact_control to use in 2). For the case 1) we remove the check
completely - unlike the former kswapd compaction, kcompactd does use the
deferred compaction functionality, so flushing tied to restarting from
deferred compaction makes sense here.
Note that when kswapd goes to sleep, kcompactd is woken up, so it will
see the flushed pageblock_skip bits. This is different from when the
former kswapd compaction observed the bits and I believe it makes more
sense. Kcompactd can afford to be more thorough than a direct
compaction trying to limit allocation latency, or kswapd whose primary
goal is to reclaim.
For testing, I used stress-highalloc configured to do order-9
allocations with GFP_NOWAIT|__GFP_HIGH|__GFP_COMP, so they relied just
on kswapd/kcompactd reclaim/compaction (the interfering kernel builds in
phases 1 and 2 work as usual):
stress-highalloc
4.5-rc1+before 4.5-rc1+after
-nodirect -nodirect
Success 1 Min 1.00 ( 0.00%) 5.00 (-66.67%)
Success 1 Mean 1.40 ( 0.00%) 6.20 (-55.00%)
Success 1 Max 2.00 ( 0.00%) 7.00 (-16.67%)
Success 2 Min 1.00 ( 0.00%) 5.00 (-66.67%)
Success 2 Mean 1.80 ( 0.00%) 6.40 (-52.38%)
Success 2 Max 3.00 ( 0.00%) 7.00 (-16.67%)
Success 3 Min 34.00 ( 0.00%) 62.00 ( 1.59%)
Success 3 Mean 41.80 ( 0.00%) 63.80 ( 1.24%)
Success 3 Max 53.00 ( 0.00%) 65.00 ( 2.99%)
User 3166.67 3181.09
System 1153.37 1158.25
Elapsed 1768.53 1799.37
-nodirect -nodirect
Direct pages scanned 32938 32797
Kswapd pages scanned 2183166 2202613
Kswapd pages reclaimed 2152359 2143524
Direct pages reclaimed 32735 32545
Percentage direct scans 1% 1%
THP fault alloc 579 612
THP collapse alloc 304 316
THP splits 0 0
THP fault fallback 793 778
THP collapse fail 11 16
Compaction stalls 1013 1007
Compaction success 92 67
Compaction failures 920 939
Page migrate success 238457 721374
Page migrate failure 23021 23469
Compaction pages isolated 504695 1479924
Compaction migrate scanned 661390 8812554
Compaction free scanned 13476658 84327916
Compaction cost 262 838
After this patch we see improvements in allocation success rate
(especially for phase 3) along with increased compaction activity. The
compaction stalls (direct compaction) in the interfering kernel builds
(probably THP's) also decreased somewhat thanks to kcompactd activity,
yet THP alloc successes improved a bit.
Note that elapsed and user time isn't so useful for this benchmark,
because of the background interference being unpredictable. It's just
to quickly spot some major unexpected differences. System time is
somewhat more useful and that didn't increase.
Also (after adjusting mmtests' ftrace monitor):
Time kswapd awake 2547781 2269241
Time kcompactd awake 0 119253
Time direct compacting 939937 557649
Time kswapd compacting 0 0
Time kcompactd compacting 0 119099
The decrease of overal time spent compacting appears to not match the
increased compaction stats. I suspect the tasks get rescheduled and
since the ftrace monitor doesn't see that, the reported time is wall
time, not CPU time. But arguably direct compactors care about overall
latency anyway, whether busy compacting or waiting for CPU doesn't
matter. And that latency seems to almost halved.
It's also interesting how much time kswapd spent awake just going
through all the priorities and failing to even try compacting, over and
over.
We can also configure stress-highalloc to perform both direct
reclaim/compaction and wakeup kswapd/kcompactd, by using
GFP_KERNEL|__GFP_HIGH|__GFP_COMP:
stress-highalloc
-direct -direct
Success 1 Min 4.00 ( 0.00%) 9.00 (-50.00%)
Success 1 Mean 8.00 ( 0.00%) 10.00 (-19.05%)
Success 1 Max 12.00 ( 0.00%) 11.00 ( 15.38%)
Success 2 Min 4.00 ( 0.00%) 9.00 (-50.00%)
Success 2 Mean 8.20 ( 0.00%) 10.00 (-16.28%)
Success 2 Max 13.00 ( 0.00%) 11.00 ( 8.33%)
Success 3 Min 75.00 ( 0.00%) 74.00 ( 1.33%)
Success 3 Mean 75.60 ( 0.00%) 75.20 ( 0.53%)
Success 3 Max 77.00 ( 0.00%) 76.00 ( 0.00%)
User 3344.73 3246.04
System 1194.24 1172.29
Elapsed 1838.04 1836.76
-direct -direct
Direct pages scanned 125146 120966
Kswapd pages scanned 2119757 2135012
Kswapd pages reclaimed 2073183 2108388
Direct pages reclaimed 124909 120577
Percentage direct scans 5% 5%
THP fault alloc 599 652
THP collapse alloc 323 354
THP splits 0 0
THP fault fallback 806 793
THP collapse fail 17 16
Compaction stalls 2457 2025
Compaction success 906 518
Compaction failures 1551 1507
Page migrate success 2031423 2360608
Page migrate failure 32845 40852
Compaction pages isolated 4129761 4802025
Compaction migrate scanned 11996712 21750613
Compaction free scanned 214970969 344372001
Compaction cost 2271 2694
In this scenario, this patch doesn't change the overall success rate as
direct compaction already tries all it can. There's however significant
reduction in direct compaction stalls (that is, the number of
allocations that went into direct compaction). The number of successes
(i.e. direct compaction stalls that ended up with successful
allocation) is reduced by the same number. This means the offload to
kcompactd is working as expected, and direct compaction is reduced
either due to detecting contention, or compaction deferred by kcompactd.
In the previous version of this patchset there was some apparent
reduction of success rate, but the changes in this version (such as
using sync compaction only), new baseline kernel, and/or averaging
results from 5 executions (my bet), made this go away.
Ftrace-based stats seem to roughly agree:
Time kswapd awake 2532984 2326824
Time kcompactd awake 0 257916
Time direct compacting 864839 735130
Time kcompactd compacting 0 257585
Cc: Mel Gorman <mgorman@techsingularity.net>
Cc: Michal Hocko <mhocko@suse.com>
Currently /proc/kpageflags returns nothing for "tail" buddy pages, which
is inconvenient when grasping how free pages are distributed. This
patch sets KPF_BUDDY for such pages.
With this patch:
$ grep MemFree /proc/meminfo ; tools/vm/page-types -b buddy
MemFree: 3134992 kB
flags page-count MB symbolic-flags long-symbolic-flags
0x0000000000000400 779272 3044 __________B_______________________________ buddy
0x0000000000000c00 4385 17 __________BM______________________________ buddy,mmap
total 783657 3061
783657 pages is 3134628 kB (roughly consistent with the global counter,)
so it's OK.
[akpm@linux-foundation.org: update comment, per Naoya]
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Reviewed-by: Vladimir Davydov <vdavydov@virtuozzo.com>>
There is a performance drop report due to hugepage allocation and in
there half of cpu time are spent on pageblock_pfn_to_page() in
compaction [1].
In that workload, compaction is triggered to make hugepage but most of
pageblocks are un-available for compaction due to pageblock type and
skip bit so compaction usually fails. Most costly operations in this
case is to find valid pageblock while scanning whole zone range. To
check if pageblock is valid to compact, valid pfn within pageblock is
required and we can obtain it by calling pageblock_pfn_to_page(). This
function checks whether pageblock is in a single zone and return valid
pfn if possible. Problem is that we need to check it every time before
scanning pageblock even if we re-visit it and this turns out to be very
expensive in this workload.
Although we have no way to skip this pageblock check in the system where
hole exists at arbitrary position, we can use cached value for zone
continuity and just do pfn_to_page() in the system where hole doesn't
exist. This optimization considerably speeds up in above workload.
Before vs After
Max: 1096 MB/s vs 1325 MB/s
Min: 635 MB/s 1015 MB/s
Avg: 899 MB/s 1194 MB/s
Avg is improved by roughly 30% [2].
[1]: http://www.spinics.net/lists/linux-mm/msg97378.html
[2]: https://lkml.org/lkml/2015/12/9/23
[akpm@linux-foundation.org: don't forget to restore zone->contiguous on error path, per Vlastimil]
Reported-by: Aaron Lu <aaron.lu@intel.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Tested-by: Aaron Lu <aaron.lu@intel.com>
In mm we use several kinds of flags bitfields that are sometimes printed
for debugging purposes, or exported to userspace via sysfs. To make
them easier to interpret independently on kernel version and config, we
want to dump also the symbolic flag names. So far this has been done
with repeated calls to pr_cont(), which is unreliable on SMP, and not
usable for e.g. sysfs export.
To get a more reliable and universal solution, this patch extends
printk() format string for pointers to handle the page flags (%pGp),
gfp_flags (%pGg) and vma flags (%pGv). Existing users of
dump_flag_names() are converted and simplified.
It would be possible to pass flags by value instead of pointer, but the
%p format string for pointers already has extensions for various kernel
structures, so it's a good fit, and the extra indirection in a
non-critical path is negligible.
[linux@rasmusvillemoes.dk: lots of good implementation suggestions]
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Cc: Sasha Levin <sasha.levin@oracle.com>
* add VM_STACK as alias for VM_GROWSUP/DOWN depending on architecture
* always account VMAs with flag VM_STACK as stack (as it was before)
* cleanup classifying helpers
* update comments and documentation
Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com>
Tested-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
Cc: Cyrill Gorcunov <gorcunov@gmail.com>
This patch provides a way of working around a slight regression
introduced by commit 84638335900f ("mm: rework virtual memory
accounting").
Before that commit RLIMIT_DATA have control only over size of the brk
region. But that change have caused problems with all existing versions
of valgrind, because it set RLIMIT_DATA to zero.
This patch fixes rlimit check (limit actually in bytes, not pages) and
by default turns it into warning which prints at first VmData misuse:
"mmap: top (795): VmData 516096 exceed data ulimit 512000. Will be forbidden soon."
Behavior is controlled by boot param ignore_rlimit_data=y/n and by sysfs
/sys/module/kernel/parameters/ignore_rlimit_data. For now it set to "y".
[akpm@linux-foundation.org: tweak kernel-parameters.txt text[
Link: http://lkml.kernel.org/r/20151228211015.GL2194@uranus
Reported-by: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Vegard Nossum <vegard.nossum@oracle.com>
Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com>
Cc: Kees Cook <keescook@google.com>
Cc: Willy Tarreau <w@1wt.eu>
Cc: Pavel Emelyanov <xemul@virtuozzo.com>
This patch adds implementation of split_huge_page() for new
refcountings.
Unlike previous implementation, new split_huge_page() can fail if
somebody holds GUP pin on the page. It also means that pin on page
would prevent it from bening split under you. It makes situation in
many places much cleaner.
The basic scheme of split_huge_page():
- Check that sum of mapcounts of all subpage is equal to page_count()
plus one (caller pin). Foll off with -EBUSY. This way we can avoid
useless PMD-splits.
- Freeze the page counters by splitting all PMD and setup migration
PTEs.
- Re-check sum of mapcounts against page_count(). Page's counts are
stable now. -EBUSY if page is pinned.
- Split compound page.
- Unfreeze the page by removing migration entries.
Tested-by: Sasha Levin <sasha.levin@oracle.com>
Tested-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Acked-by: Jerome Marchand <jmarchan@redhat.com>
Cc: Steve Capper <steve.capper@linaro.org>
Cc: Christoph Lameter <cl@linux.com>
Tail page refcounting is utterly complicated and painful to support.
It uses ->_mapcount on tail pages to store how many times this page is
pinned. get_page() bumps ->_mapcount on tail page in addition to
->_count on head. This information is required by split_huge_page() to
be able to distribute pins from head of compound page to tails during
the split.
We will need ->_mapcount to account PTE mappings of subpages of the
compound page. We eliminate need in current meaning of ->_mapcount in
tail pages by forbidding split entirely if the page is pinned.
The only user of tail page refcounting is THP which is marked BROKEN for
now.
Let's drop all this mess. It makes get_page() and put_page() much
simpler.
Let's try to be consistent about data type of page order.
[sfr@canb.auug.org.au: fix build (type of pageblock_order)]
[hughd@google.com: some configs end up with MAX_ORDER and pageblock_order having different types]
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Hugh has pointed that compound_head() call can be unsafe in some
context. There's one example:
CPU0 CPU1
isolate_migratepages_block()
page_count()
compound_head()
!!PageTail() == true
put_page()
tail->first_page = NULL
head = tail->first_page
alloc_pages(__GFP_COMP)
prep_compound_page()
tail->first_page = head
__SetPageTail(p);
<head == NULL dereferencing>
The race is pure theoretical. I don't it's possible to trigger it in
practice. But who knows.
We can fix the race by changing how encode PageTail() and compound_head()
within struct page to be able to update them in one shot.
The patch introduces page->compound_head into third double word block in
front of compound_dtor and compound_order. Bit 0 encodes PageTail() and
the rest bits are pointer to head page if bit zero is set.
The patch moves page->pmd_huge_pte out of word, just in case if an
architecture defines pgtable_t into something what can have the bit 0
set.
hugetlb_cgroup uses page->lru.next in the second tail page to store
pointer struct hugetlb_cgroup. The patch switch it to use page->private
in the second tail page instead. The space is free since ->first_page is
removed from the union.
The patch also opens possibility to remove HUGETLB_CGROUP_MIN_ORDER
limitation, since there's now space in first tail page to store struct
hugetlb_cgroup pointer. But that's out of scope of the patch.
That means page->compound_head shares storage space with:
- page->lru.next;
- page->next;
- page->rcu_head.next;
That's too long list to be absolutely sure, but looks like nobody uses
bit 0 of the word.
page->rcu_head.next guaranteed[1] to have bit 0 clean as long as we use
call_rcu(), call_rcu_bh(), call_rcu_sched(), or call_srcu(). But future
call_rcu_lazy() is not allowed as it makes use of the bit and we can
get false positive PageTail().
[1] http://lkml.kernel.org/g/20150827163634.GD4029@linux.vnet.ibm.com
combinations
Andrew stated the following
We have quite a history of remote parts of the kernel using
weird/wrong/inexplicable combinations of __GFP_ flags. I tend
to think that this is because we didn't adequately explain the
interface.
And I don't think that gfp.h really improved much in this area as
a result of this patchset. Could you go through it some time and
decide if we've adequately documented all this stuff?
This patches first moves some GFP flag combinations that are part of the MM
internals to mm/internal.h. The rest of the patch documents the __GFP_FOO
bits under various headings and then documents the flag combinations. It
will not help callers that are brain damaged but the clarity might motivate
some fixes and avoid future mistakes.
Cc: Vitaly Wool <vitalywool@gmail.com>
