commit e7701557bfdd81ff44cab13a80439319a735d8e2 upstream.
gcc-7 produces this warning:
mm/kasan/report.c: In function 'kasan_report':
mm/kasan/report.c:351:3: error: 'info.first_bad_addr' may be used uninitialized in this function [-Werror=maybe-uninitialized]
print_shadow_for_address(info->first_bad_addr);
mm/kasan/report.c:360:27: note: 'info.first_bad_addr' was declared here
The code seems fine as we only print info.first_bad_addr when there is a
shadow, and we always initialize it in that case, but this is relatively
hard for gcc to figure out after the latest rework.
Adding an intialization to the most likely value together with the other
struct members shuts up that warning.
Fixes: b235b9808664 ("kasan: unify report headers")
Link: https://patchwork.kernel.org/patch/9641417/
Link: http://lkml.kernel.org/r/20170725152739.4176967-1-arnd@arndb.de
Suggested-by: Alexander Potapenko <glider@google.com>
Suggested-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Signed-off-by: Andrey Konovalov <andreyknvl@google.com>
commit 5c6a84a3f4558a6115fef1b59343c7ae56b3abc3 upstream.
__pa_symbol is the correct API to find the physical address of symbols.
Switch to it to allow for debugging APIs to work correctly. Other
functions such as p*d_populate may call __pa internally. Ensure that the
address passed is in the linear region by calling lm_alias.
Reviewed-by: Mark Rutland <mark.rutland@arm.com>
Tested-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Laura Abbott <labbott@redhat.com>
commit b53f40db59b27b62bc294c30506b02a0cae47e0b upstream.
Resuming from a suspend operation is showing a KASAN false positive
warning:
BUG: KASAN: stack-out-of-bounds in unwind_get_return_address+0x11d/0x130 at addr ffff8803867d7878
Read of size 8 by task pm-suspend/7774
page:ffffea000e19f5c0 count:0 mapcount:0 mapping: (null) index:0x0
flags: 0x2ffff0000000000()
page dumped because: kasan: bad access detected
CPU: 0 PID: 7774 Comm: pm-suspend Tainted: G B 4.9.0-rc7+ #8
Hardware name: Gigabyte Technology Co., Ltd. Z170X-UD5/Z170X-UD5-CF, BIOS F5 03/07/2016
Call Trace:
dump_stack+0x63/0x82
kasan_report_error+0x4b4/0x4e0
? acpi_hw_read_port+0xd0/0x1ea
? kfree_const+0x22/0x30
? acpi_hw_validate_io_request+0x1a6/0x1a6
__asan_report_load8_noabort+0x61/0x70
? unwind_get_return_address+0x11d/0x130
? unwind_next_frame+0x97/0xf0
__save_stack_trace+0x92/0x100
save_stack_trace+0x1b/0x20
save_stack+0x46/0xd0
? save_stack_trace+0x1b/0x20
? save_stack+0x46/0xd0
? kasan_kmalloc+0xad/0xe0
? kasan_slab_alloc+0x12/0x20
? acpi_hw_read+0x2b6/0x3aa
? acpi_hw_validate_register+0x20b/0x20b
? acpi_hw_write_port+0x72/0xc7
? acpi_hw_write+0x11f/0x15f
? acpi_hw_read_multiple+0x19f/0x19f
? memcpy+0x45/0x50
? kasan_unpoison_shadow+0x36/0x50
kmem_cache_alloc_trace+0xbc/0x1e0
? acpi_get_sleep_type_data+0x9a/0x578
acpi_hw_legacy_wake_prep+0x88/0x22c
? acpi_hw_legacy_sleep+0x3c7/0x3c7
? acpi_write_bit_register+0x28d/0x2d3
? acpi_read_bit_register+0x19b/0x19b
acpi_hw_sleep_dispatch+0xb5/0xba
acpi_leave_sleep_state_prep+0x17/0x19
acpi_suspend_enter+0x154/0x1e0
? trace_suspend_resume+0xe8/0xe8
suspend_devices_and_enter+0xb09/0xdb0
? printk+0xa8/0xd8
? arch_suspend_enable_irqs+0x20/0x20
? try_to_freeze_tasks+0x295/0x600
pm_suspend+0x6c9/0x780
? finish_wait+0x1f0/0x1f0
? suspend_devices_and_enter+0xdb0/0xdb0
state_store+0xa2/0x120
? kobj_attr_show+0x60/0x60
kobj_attr_store+0x36/0x70
sysfs_kf_write+0x131/0x200
kernfs_fop_write+0x295/0x3f0
__vfs_write+0xef/0x760
? handle_mm_fault+0x1346/0x35e0
? do_iter_readv_writev+0x660/0x660
? __pmd_alloc+0x310/0x310
? do_lock_file_wait+0x1e0/0x1e0
? apparmor_file_permission+0x18/0x20
? security_file_permission+0x73/0x1c0
? rw_verify_area+0xbd/0x2b0
vfs_write+0x149/0x4a0
SyS_write+0xd9/0x1c0
? SyS_read+0x1c0/0x1c0
entry_SYSCALL_64_fastpath+0x1e/0xad
Memory state around the buggy address:
ffff8803867d7700: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ffff8803867d7780: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
>ffff8803867d7800: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 f4
ffff8803867d7880: f3 f3 f3 f3 00 00 00 00 00 00 00 00 00 00 00 00
ffff8803867d7900: 00 00 00 f1 f1 f1 f1 04 f4 f4 f4 f3 f3 f3 f3 00
KASAN instrumentation poisons the stack when entering a function and
unpoisons it when exiting the function. However, in the suspend path,
some functions never return, so their stack never gets unpoisoned,
resulting in stale KASAN shadow data which can cause later false
positive warnings like the one above.
Reported-by: Scott Bauer <scott.bauer@intel.com>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Acked-by: Pavel Machek <pavel@ucw.cz>
[ Upstream commit 1e8e18f694a52d703665012ca486826f64bac29d ]
There is a special case that the size is "(N << KASAN_SHADOW_SCALE_SHIFT)
Pages plus X", the value of X is [1, KASAN_SHADOW_SCALE_SIZE-1]. The
operation "size >> KASAN_SHADOW_SCALE_SHIFT" will drop X, and the
roundup operation can not retrieve the missed one page. For example:
size=0x28006, PAGE_SIZE=0x1000, KASAN_SHADOW_SCALE_SHIFT=3, we will get
shadow_size=0x5000, but actually we need 6 pages.
shadow_size = round_up(size >> KASAN_SHADOW_SCALE_SHIFT, PAGE_SIZE);
This can lead to a kernel crash when kasan is enabled and the value of
mod->core_layout.size or mod->init_layout.size is like above. Because
the shadow memory of X has not been allocated and mapped.
move_module:
ptr = module_alloc(mod->core_layout.size);
memset(ptr, 0, mod->core_layout.size); //crashed
Unable to handle kernel paging request at virtual address ffff0fffff97b000
Call trace:
__asan_storeN+0x174/0x1a8
memset+0x24/0x48
layout_and_allocate+0xcd8/0x1800
load_module+0x190/0x23e8
SyS_finit_module+0x148/0x180
Link: http://lkml.kernel.org/r/1529659626-12660-1-git-send-email-thunder.leizhen@huawei.com
Signed-off-by: Zhen Lei <thunder.leizhen@huawei.com>
Reviewed-by: Dmitriy Vyukov <dvyukov@google.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: Hanjun Guo <guohanjun@huawei.com>
Cc: Libin <huawei.libin@huawei.com>
commit 3f1959721558a976aaf9c2024d5bc884e6411bf7 upstream.
Using module_init() is wrong. E.g. ACPI adds and onlines memory before
our memory notifier gets registered.
This makes sure that ACPI memory detected during boot up will not result
in a kernel crash.
Easily reproducible with QEMU, just specify a DIMM when starting up.
Link: http://lkml.kernel.org/r/20180522100756.18478-3-david@redhat.com
Fixes: 786a8959912e ("kasan: disable memory hotplug")
Signed-off-by: David Hildenbrand <david@redhat.com>
Cc: <stable@vger.kernel.org>
[ Upstream commit 4f40c6e5627ea73b4e7c615c59631f38cc880885 ]
After much waiting I finally reproduced a KASAN issue, only to find my
trace-buffer empty of useful information because it got spooled out :/
Make kasan_report honour the /proc/sys/kernel/traceoff_on_warning
interface.
Link: http://lkml.kernel.org/r/20170125164106.3514-1-aryabinin@virtuozzo.com
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Acked-by: Alexander Potapenko <glider@google.com>
Gcc revision 241896 implements use-after-scope detection. Will be
available in gcc 7. Support it in KASAN.
Gcc emits 2 new callbacks to poison/unpoison large stack objects when
they go in/out of scope. Implement the callbacks and add a test.
[dvyukov@google.com: v3]
Link: http://lkml.kernel.org/r/1479998292-144502-1-git-send-email-dvyukov@google.com
Link: http://lkml.kernel.org/r/1479226045-145148-1-git-send-email-dvyukov@google.com
Signed-off-by: Dmitry Vyukov <dvyukov@google.com>
Cc: <stable@vger.kernel.org> [4.0+]
kasan_global struct is part of compiler/runtime ABI. gcc revision
241983 has added a new field to kasan_global struct. Update kernel
definition of kasan_global struct to include the new field.
Without this patch KASAN is broken with gcc 7.
Link: http://lkml.kernel.org/r/1479219743-28682-1-git-send-email-dvyukov@google.com
I observed false KSAN positives in the sctp code, when
sctp uses jprobe_return() in jsctp_sf_eat_sack().
The stray 0xf4 in shadow memory are stack redzones:
[ ] BUG: KASAN: stack-out-of-bounds in memcmp+0xe9/0x150 at addr ffff88005e48f480
[ ] Read of size 1 by task syz-executor/18535
[ ] page:ffffea00017923c0 count:0 mapcount:0 mapping: (null) index:0x0
[ ] flags: 0x1fffc0000000000()
[ ] page dumped because: kasan: bad access detected
[ ] CPU: 1 PID: 18535 Comm: syz-executor Not tainted 4.8.0+ #28
[ ] Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
[ ] ffff88005e48f2d0 ffffffff82d2b849 ffffffff0bc91e90 fffffbfff10971e8
[ ] ffffed000bc91e90 ffffed000bc91e90 0000000000000001 0000000000000000
[ ] ffff88005e48f480 ffff88005e48f350 ffffffff817d3169 ffff88005e48f370
[ ] Call Trace:
[ ] [<ffffffff82d2b849>] dump_stack+0x12e/0x185
[ ] [<ffffffff817d3169>] kasan_report+0x489/0x4b0
[ ] [<ffffffff817d31a9>] __asan_report_load1_noabort+0x19/0x20
[ ] [<ffffffff82d49529>] memcmp+0xe9/0x150
[ ] [<ffffffff82df7486>] depot_save_stack+0x176/0x5c0
[ ] [<ffffffff817d2031>] save_stack+0xb1/0xd0
[ ] [<ffffffff817d27f2>] kasan_slab_free+0x72/0xc0
[ ] [<ffffffff817d05b8>] kfree+0xc8/0x2a0
[ ] [<ffffffff85b03f19>] skb_free_head+0x79/0xb0
[ ] [<ffffffff85b0900a>] skb_release_data+0x37a/0x420
[ ] [<ffffffff85b090ff>] skb_release_all+0x4f/0x60
[ ] [<ffffffff85b11348>] consume_skb+0x138/0x370
[ ] [<ffffffff8676ad7b>] sctp_chunk_put+0xcb/0x180
[ ] [<ffffffff8676ae88>] sctp_chunk_free+0x58/0x70
[ ] [<ffffffff8677fa5f>] sctp_inq_pop+0x68f/0xef0
[ ] [<ffffffff8675ee36>] sctp_assoc_bh_rcv+0xd6/0x4b0
[ ] [<ffffffff8677f2c1>] sctp_inq_push+0x131/0x190
[ ] [<ffffffff867bad69>] sctp_backlog_rcv+0xe9/0xa20
[ ] Memory state around the buggy address:
[ ] ffff88005e48f380: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ ] ffff88005e48f400: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ ] >ffff88005e48f480: f4 f4 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ ] ffff88005e48f500: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ ] ffff88005e48f580: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
KASAN stack instrumentation poisons stack redzones on function entry
and unpoisons them on function exit. If a function exits abnormally
(e.g. with a longjmp like jprobe_return()), stack redzones are left
poisoned. Later this leads to random KASAN false reports.
Unpoison stack redzones in the frames we are going to jump over
before doing actual longjmp in jprobe_return().
Acked-by: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com>
Cc: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Cc: Ananth N Mavinakayanahalli <ananth@linux.vnet.ibm.com>
Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
Cc: Masami Hiramatsu <mhiramat@kernel.org>
Cc: kasan-dev@googlegroups.com
Cc: surovegin@google.com
Cc: rostedt@goodmis.org
Link: http://lkml.kernel.org/r/1476454043-101898-1-git-send-email-dvyukov@google.com
It's quite unlikely that the user will so little memory that the per-CPU
quarantines won't fit into the given fraction of the available memory.
Even in that case he won't be able to do anything with the information
given in the warning.
Link: http://lkml.kernel.org/r/1470929182-101413-1-git-send-email-glider@google.com
Signed-off-by: Alexander Potapenko <glider@google.com>
Cc: Andrey Konovalov <adech.fo@gmail.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Kuthonuzo Luruo <kuthonuzo.luruo@hpe.com>
If the total amount of memory assigned to quarantine is less than the
amount of memory assigned to per-cpu quarantines, |new_quarantine_size|
may overflow. Instead, set it to zero.
[akpm@linux-foundation.org: cleanup: use WARN_ONCE return value]
Link: http://lkml.kernel.org/r/1470063563-96266-1-git-send-email-glider@google.com
Fixes: 55834c59098d ("mm: kasan: initial memory quarantine implementation")
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Currently we just dump stack in case of double free bug.
Let's dump all info about the object that we have.
[aryabinin@virtuozzo.com: change double free message per Alexander]
Link: http://lkml.kernel.org/r/1470153654-30160-1-git-send-email-aryabinin@virtuozzo.com
Link: http://lkml.kernel.org/r/1470062715-14077-6-git-send-email-aryabinin@virtuozzo.com
The state of object currently tracked in two places - shadow memory, and
the ->state field in struct kasan_alloc_meta. We can get rid of the
latter. The will save us a little bit of memory. Also, this allow us
to move free stack into struct kasan_alloc_meta, without increasing
memory consumption. So now we should always know when the last time the
object was freed. This may be useful for long delayed use-after-free
bugs.
As a side effect this fixes following UBSAN warning:
UBSAN: Undefined behaviour in mm/kasan/quarantine.c:102:13
member access within misaligned address ffff88000d1efebc for type 'struct qlist_node'
which requires 8 byte alignment
Link: http://lkml.kernel.org/r/1470062715-14077-5-git-send-email-aryabinin@virtuozzo.com
Reported-by: kernel test robot <xiaolong.ye@intel.com>
Cc: Pekka Enberg <penberg@kernel.org>
Size of slab object already stored in cache->object_size.
Note, that kmalloc() internally rounds up size of allocation, so
object_size may be not equal to alloc_size, but, usually we don't need
to know the exact size of allocated object. In case if we need that
information, we still can figure it out from the report. The dump of
shadow memory allows to identify the end of allocated memory, and
thereby the exact allocation size.
Link: http://lkml.kernel.org/r/1470062715-14077-4-git-send-email-aryabinin@virtuozzo.com
SLUB doesn't require disabled interrupts to call ___cache_free().
Link: http://lkml.kernel.org/r/1470062715-14077-3-git-send-email-aryabinin@virtuozzo.com
Currently we call quarantine_reduce() for ___GFP_KSWAPD_RECLAIM (implied
by __GFP_RECLAIM) allocation. So, basically we call it on almost every
allocation. quarantine_reduce() sometimes is heavy operation, and
calling it with disabled interrupts may trigger hard LOCKUP:
NMI watchdog: Watchdog detected hard LOCKUP on cpu 2irq event stamp: 1411258
Call Trace:
<NMI> dump_stack+0x68/0x96
watchdog_overflow_callback+0x15b/0x190
__perf_event_overflow+0x1b1/0x540
perf_event_overflow+0x14/0x20
intel_pmu_handle_irq+0x36a/0xad0
perf_event_nmi_handler+0x2c/0x50
nmi_handle+0x128/0x480
default_do_nmi+0xb2/0x210
do_nmi+0x1aa/0x220
end_repeat_nmi+0x1a/0x1e
<<EOE>> __kernel_text_address+0x86/0xb0
print_context_stack+0x7b/0x100
dump_trace+0x12b/0x350
save_stack_trace+0x2b/0x50
set_track+0x83/0x140
free_debug_processing+0x1aa/0x420
__slab_free+0x1d6/0x2e0
___cache_free+0xb6/0xd0
qlist_free_all+0x83/0x100
quarantine_reduce+0x177/0x1b0
kasan_kmalloc+0xf3/0x100
Reduce the quarantine_reduce iff direct reclaim is allowed.
Fixes: 55834c59098d("mm: kasan: initial memory quarantine implementation")
Link: http://lkml.kernel.org/r/1470062715-14077-2-git-send-email-aryabinin@virtuozzo.com
Reported-by: Dave Jones <davej@codemonkey.org.uk>
Once an object is put into quarantine, we no longer own it, i.e. object
could leave the quarantine and be reallocated. So having set_track()
call after the quarantine_put() may corrupt slab objects.
BUG kmalloc-4096 (Not tainted): Poison overwritten
Disabling lock debugging due to kernel taint
INFO: 0xffff8804540de850-0xffff8804540de857. First byte 0xb5 instead of 0x6b
INFO: Freed in qlist_free_all+0x42/0x100 age=75 cpu=3 pid=24492
kmem_cache_alloc+0x109/0x3e0
mmap_region+0x53e/0xe40
do_mmap+0x70f/0xa50
vm_mmap_pgoff+0x147/0x1b0
SyS_mmap_pgoff+0x2c7/0x5b0
SyS_mmap+0x1b/0x30
do_syscall_64+0x1a0/0x4e0
return_from_SYSCALL_64+0x0/0x7a
INFO: Slab 0xffffea0011503600 objects=7 used=7 fp=0x (null) flags=0x8000000000004080
INFO: Object 0xffff8804540de848 @offset=26696 fp=0xffff8804540dc588
Redzone ffff8804540de840: bb bb bb bb bb bb bb bb ........
Object ffff8804540de848: 6b 6b 6b 6b 6b 6b 6b 6b b5 52 00 00 f2 01 60 cc kkkkkkkk.R....`.
Similarly, poisoning after the quarantine_put() leads to false positive
use-after-free reports:
BUG: KASAN: use-after-free in anon_vma_interval_tree_insert+0x304/0x430 at addr ffff880405c540a0
Read of size 8 by task trinity-c0/3036
CPU: 0 PID: 3036 Comm: trinity-c0 Not tainted 4.7.0-think+ #9
Call Trace:
kasan_report_error+0x222/0x600
anon_vma_chain_link+0x91/0xd0
anon_vma_clone+0x136/0x3f0
anon_vma_fork+0x81/0x4c0
copy_process.part.47+0x2c43/0x5b20
_do_fork+0x16d/0xbd0
SyS_clone+0x19/0x20
entry_SYSCALL64_slow_path+0x25/0x25
Fix this by putting an object in the quarantine after all other
operations.
Fixes: 80a9201a5965 ("mm, kasan: switch SLUB to stackdepot, enable memory quarantine for SLUB")
Link: http://lkml.kernel.org/r/1470062715-14077-1-git-send-email-aryabinin@virtuozzo.com
Reported-by: Vegard Nossum <vegard.nossum@oracle.com>
Reported-by: Sasha Levin <alexander.levin@verizon.com>
For KASAN builds:
- switch SLUB allocator to using stackdepot instead of storing the
allocation/deallocation stacks in the objects;
- change the freelist hook so that parts of the freelist can be put
into the quarantine.
[aryabinin@virtuozzo.com: fixes]
Link: http://lkml.kernel.org/r/1468601423-28676-1-git-send-email-aryabinin@virtuozzo.com
Link: http://lkml.kernel.org/r/1468347165-41906-3-git-send-email-glider@google.com
Cc: Steven Rostedt (Red Hat) <rostedt@goodmis.org>
Cc: Kostya Serebryany <kcc@google.com>
There are two bugs on qlist_move_cache(). One is that qlist's tail
isn't set properly. curr->next can be NULL since it is singly linked
list and NULL value on tail is invalid if there is one item on qlist.
Another one is that if cache is matched, qlist_put() is called and it
will set curr->next to NULL. It would cause to stop the loop
prematurely.
These problems come from complicated implementation so I'd like to
re-implement it completely. Implementation in this patch is really
simple. Iterate all qlist_nodes and put them to appropriate list.
Unfortunately, I got this bug sometime ago and lose oops message. But,
the bug looks trivial and no need to attach oops.
Link: http://lkml.kernel.org/r/1467766348-22419-1-git-send-email-iamjoonsoo.kim@lge.com
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Reviewed-by: Dmitry Vyukov <dvyukov@google.com>
Cc: Kuthonuzo Luruo <poll.stdin@gmail.com>
Currently we may put reserved by mempool elements into quarantine via
kasan_kfree(). This is totally wrong since quarantine may really free
these objects. So when mempool will try to use such element,
use-after-free will happen. Or mempool may decide that it no longer
need that element and double-free it.
So don't put object into quarantine in kasan_kfree(), just poison it.
Rename kasan_kfree() to kasan_poison_kfree() to respect that.
Also, we shouldn't use kasan_slab_alloc()/kasan_krealloc() in
kasan_unpoison_element() because those functions may update allocation
stacktrace. This would be wrong for the most of the remove_element call
sites.
(The only call site where we may want to update alloc stacktrace is
in mempool_alloc(). Kmemleak solves this by calling
kmemleak_update_trace(), so we could make something like that too.
But this is out of scope of this patch).
Link: http://lkml.kernel.org/r/575977C3.1010905@virtuozzo.com
Reported-by: Kuthonuzo Luruo <kuthonuzo.luruo@hpe.com>
Cc: Dmitriy Vyukov <dvyukov@google.com>
Change the following memory hot-add error messages to info messages.
There is no need for these to be errors.
kasan: WARNING: KASAN doesn't support memory hot-add
kasan: Memory hot-add will be disabled
Link: http://lkml.kernel.org/r/1464794430-5486-1-git-send-email-shuahkh@osg.samsung.com
Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
Commit cd11016e5f52 ("mm, kasan: stackdepot implementation. Enable
stackdepot for SLAB") added 'reserved' field, but never used it.
Link: http://lkml.kernel.org/r/1464021054-2307-1-git-send-email-aryabinin@virtuozzo.com
Memory access coded in an assembly won't be seen by KASAN as a compiler
can instrument only C code. Add kasan_check_[read,write]() API which is
going to be used to check a certain memory range.
Link: http://lkml.kernel.org/r/1462538722-1574-3-git-send-email-aryabinin@virtuozzo.com
When bogus memory access happens in mem[set,cpy,move]() it's usually
caller's fault. So don't blame mem[set,cpy,move]() in bug report, blame
the caller instead.
Before:
BUG: KASAN: out-of-bounds access in memset+0x23/0x40 at <address>
After:
BUG: KASAN: out-of-bounds access in <memset_caller> at <address>
Link: http://lkml.kernel.org/r/1462538722-1574-2-git-send-email-aryabinin@virtuozzo.com
Quarantine isolates freed objects in a separate queue. The objects are
returned to the allocator later, which helps to detect use-after-free
errors.
When the object is freed, its state changes from KASAN_STATE_ALLOC to
KASAN_STATE_QUARANTINE. The object is poisoned and put into quarantine
instead of being returned to the allocator, therefore every subsequent
access to that object triggers a KASAN error, and the error handler is
able to say where the object has been allocated and deallocated.
When it's time for the object to leave quarantine, its state becomes
KASAN_STATE_FREE and it's returned to the allocator. From now on the
allocator may reuse it for another allocation. Before that happens,
it's still possible to detect a use-after free on that object (it
retains the allocation/deallocation stacks).
When the allocator reuses this object, the shadow is unpoisoned and old
allocation/deallocation stacks are wiped. Therefore a use of this
object, even an incorrect one, won't trigger ASan warning.
Without the quarantine, it's not guaranteed that the objects aren't
reused immediately, that's why the probability of catching a
use-after-free is lower than with quarantine in place.
errors.
Freed objects are first added to per-cpu quarantine queues. When a
cache is destroyed or memory shrinking is requested, the objects are
moved into the global quarantine queue. Whenever a kmalloc call allows
memory reclaiming, the oldest objects are popped out of the global queue
until the total size of objects in quarantine is less than 3/4 of the
maximum quarantine size (which is a fraction of installed physical
memory).
As long as an object remains in the quarantine, KASAN is able to report
accesses to it, so the chance of reporting a use-after-free is
increased. Once the object leaves quarantine, the allocator may reuse
it, in which case the object is unpoisoned and KASAN can't detect
incorrect accesses to it.
Right now quarantine support is only enabled in SLAB allocator.
Unification of KASAN features in SLAB and SLUB will be done later.
This patch is based on the "mm: kasan: quarantine" patch originally
prepared by Dmitry Chernenkov. A number of improvements have been
suggested by Andrey Ryabinin.
[glider@google.com: v9]
Link: http://lkml.kernel.org/r/1462987130-144092-1-git-send-email-glider@google.com
Cc: Konstantin Serebryany <kcc@google.com>
Cc: Dmitry Chernenkov <dmitryc@google.com>
Add the missing argument to set_track().
Fixes: cd11016e5f52 ("mm, kasan: stackdepot implementation. Enable stackdepot for SLAB")
Implement the stack depot and provide CONFIG_STACKDEPOT. Stack depot
will allow KASAN store allocation/deallocation stack traces for memory
chunks. The stack traces are stored in a hash table and referenced by
handles which reside in the kasan_alloc_meta and kasan_free_meta
structures in the allocated memory chunks.
IRQ stack traces are cut below the IRQ entry point to avoid unnecessary
duplication.
Right now stackdepot support is only enabled in SLAB allocator. Once
KASAN features in SLAB are on par with those in SLUB we can switch SLUB
to stackdepot as well, thus removing the dependency on SLUB stack
bookkeeping, which wastes a lot of memory.
This patch is based on the "mm: kasan: stack depots" patch originally
Joonsoo has said that he plans to reuse the stackdepot code for the
mm/page_owner.c debugging facility.
[akpm@linux-foundation.org: s/depot_stack_handle/depot_stack_handle_t]
[aryabinin@virtuozzo.com: comment style fixes]
Add GFP flags to KASAN hooks for future patches to use.
This patch is based on the "mm: kasan: unified support for SLUB and SLAB
allocators" patch originally prepared by Dmitry Chernenkov.
Add KASAN hooks to SLAB allocator.
kcov provides code coverage collection for coverage-guided fuzzing
(randomized testing). Coverage-guided fuzzing is a testing technique
that uses coverage feedback to determine new interesting inputs to a
system. A notable user-space example is AFL
(http://lcamtuf.coredump.cx/afl/). However, this technique is not
widely used for kernel testing due to missing compiler and kernel
support.
kcov does not aim to collect as much coverage as possible. It aims to
collect more or less stable coverage that is function of syscall inputs.
To achieve this goal it does not collect coverage in soft/hard
interrupts and instrumentation of some inherently non-deterministic or
non-interesting parts of kernel is disbled (e.g. scheduler, locking).
Currently there is a single coverage collection mode (tracing), but the
API anticipates additional collection modes. Initially I also
implemented a second mode which exposes coverage in a fixed-size hash
table of counters (what Quentin used in his original patch). I've
dropped the second mode for simplicity.
This patch adds the necessary support on kernel side. The complimentary
compiler support was added in gcc revision 231296.
We've used this support to build syzkaller system call fuzzer, which has
found 90 kernel bugs in just 2 months:
https://github.com/google/syzkaller/wiki/Found-Bugs
We've also found 30+ bugs in our internal systems with syzkaller.
Another (yet unexplored) direction where kcov coverage would greatly
help is more traditional "blob mutation". For example, mounting a
random blob as a filesystem, or receiving a random blob over wire.
Why not gcov. Typical fuzzing loop looks as follows: (1) reset
coverage, (2) execute a bit of code, (3) collect coverage, repeat. A
typical coverage can be just a dozen of basic blocks (e.g. an invalid
input). In such context gcov becomes prohibitively expensive as
reset/collect coverage steps depend on total number of basic
blocks/edges in program (in case of kernel it is about 2M). Cost of
kcov depends only on number of executed basic blocks/edges. On top of
that, kernel requires per-thread coverage because there are always
background threads and unrelated processes that also produce coverage.
With inlined gcov instrumentation per-thread coverage is not possible.
kcov exposes kernel PCs and control flow to user-space which is
insecure. But debugfs should not be mapped as user accessible.
Based on a patch by Quentin Casasnovas.
[akpm@linux-foundation.org: make task_struct.kcov_mode have type `enum kcov_mode']
[akpm@linux-foundation.org: unbreak allmodconfig]
[akpm@linux-foundation.org: follow x86 Makefile layout standards]
Cc: syzkaller <syzkaller@googlegroups.com>
Cc: Vegard Nossum <vegard.nossum@oracle.com>
Cc: Tavis Ormandy <taviso@google.com>
Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com>
Cc: Eric Dumazet <edumazet@google.com>
Cc: Kees Cook <keescook@google.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: David Drysdale <drysdale@google.com>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Kirill A. Shutemov <kirill@shutemov.name>
Cc: Jiri Slaby <jslaby@suse.cz>
Kernel style prefers a single string over split strings when the string is
'user-visible'.
Miscellanea:
- Add a missing newline
- Realign arguments
Acked-by: Tejun Heo <tj@kernel.org> [percpu]
Functions which the compiler has instrumented for ASAN place poison on
the stack shadow upon entry and remove this poison prior to returning.
In some cases (e.g. hotplug and idle), CPUs may exit the kernel a
number of levels deep in C code. If there are any instrumented
functions on this critical path, these will leave portions of the idle
thread stack shadow poisoned.
If a CPU returns to the kernel via a different path (e.g. a cold
entry), then depending on stack frame layout subsequent calls to
instrumented functions may use regions of the stack with stale poison,
resulting in (spurious) KASAN splats to the console.
Contemporary GCCs always add stack shadow poisoning when ASAN is
enabled, even when asked to not instrument a function [1], so we can't
simply annotate functions on the critical path to avoid poisoning.
Instead, this series explicitly removes any stale poison before it can
be hit. In the common hotplug case we clear the entire stack shadow in
common code, before a CPU is brought online.
On architectures which perform a cold return as part of cpu idle may
retain an architecture-specific amount of stack contents. To retain the
poison for this retained context, the arch code must call the core KASAN
code, passing a "watermark" stack pointer value beyond which shadow will
be cleared. Architectures which don't perform a cold return as part of
idle do not need any additional code.
This patch (of 3):
Functions which the compiler has instrumented for KASAN place poison on
the stack shadow upon entry and remove this poision prior to returning.
In some cases (e.g. hotplug and idle), CPUs may exit the kernel a number
of levels deep in C code. If there are any instrumented functions on this
critical path, these will leave portions of the stack shadow poisoned.
If a CPU returns to the kernel via a different path (e.g. a cold entry),
then depending on stack frame layout subsequent calls to instrumented
functions may use regions of the stack with stale poison, resulting in
To avoid this, we must clear stale poison from the stack prior to
instrumented functions being called. This patch adds functions to the
KASAN core for removing poison from (portions of) a task's stack. These
will be used by subsequent patches to avoid problems with hotplug and
idle.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Reviewed-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
UBSAN uses compile-time instrumentation to catch undefined behavior
(UB). Compiler inserts code that perform certain kinds of checks before
operations that could cause UB. If check fails (i.e. UB detected)
__ubsan_handle_* function called to print error message.
So the most of the work is done by compiler. This patch just implements
ubsan handlers printing errors.
GCC has this capability since 4.9.x [1] (see -fsanitize=undefined
option and its suboptions).
However GCC 5.x has more checkers implemented [2].
Article [3] has a bit more details about UBSAN in the GCC.
[1] - https://gcc.gnu.org/onlinedocs/gcc-4.9.0/gcc/Debugging-Options.html
[2] - https://gcc.gnu.org/onlinedocs/gcc/Debugging-Options.html
[3] - http://developerblog.redhat.com/2014/10/16/gcc-undefined-behavior-sanitizer-ubsan/
Issues which UBSAN has found thus far are:
Found bugs:
* out-of-bounds access - 97840cb67ff5 ("netfilter: nfnetlink: fix
insufficient validation in nfnetlink_bind")
undefined shifts:
* d48458d4a768 ("jbd2: use a better hash function for the revoke
table")
* 10632008b9e1 ("clockevents: Prevent shift out of bounds")
* 'x << -1' shift in ext4 -
http://lkml.kernel.org/r/<5444EF21.8020501@samsung.com>
* undefined rol32(0) -
http://lkml.kernel.org/r/<1449198241-20654-1-git-send-email-sasha.levin@oracle.com>
* undefined dirty_ratelimit calculation -
http://lkml.kernel.org/r/<566594E2.3050306@odin.com>
* undefined roundown_pow_of_two(0) -
http://lkml.kernel.org/r/<1449156616-11474-1-git-send-email-sasha.levin@oracle.com>
* [WONTFIX] undefined shift in __bpf_prog_run -
http://lkml.kernel.org/r/<CACT4Y+ZxoR3UjLgcNdUm4fECLMx2VdtfrENMtRRCdgHB2n0bJA@mail.gmail.com>
WONTFIX here because it should be fixed in bpf program, not in kernel.
signed overflows:
* 32a8df4e0b33f ("sched: Fix odd values in effective_load()
calculations")
* mul overflow in ntp -
http://lkml.kernel.org/r/<1449175608-1146-1-git-send-email-sasha.levin@oracle.com>
* incorrect conversion into rtc_time in rtc_time64_to_tm() -
http://lkml.kernel.org/r/<1449187944-11730-1-git-send-email-sasha.levin@oracle.com>
* unvalidated timespec in io_getevents() -
http://lkml.kernel.org/r/<CACT4Y+bBxVYLQ6LtOKrKtnLthqLHcw-BMp3aqP3mjdAvr9FULQ@mail.gmail.com>
* [NOTABUG] signed overflow in ktime_add_safe() -
http://lkml.kernel.org/r/<CACT4Y+aJ4muRnWxsUe1CMnA6P8nooO33kwG-c8YZg=0Xc8rJqw@mail.gmail.com>
[akpm@linux-foundation.org: fix unused local warning]
[akpm@linux-foundation.org: fix __int128 build woes]
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Michal Marek <mmarek@suse.cz>
Cc: Yury Gribov <y.gribov@samsung.com>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Johannes Berg <johannes@sipsolutions.net>
Kmemleak reports the following leak:
unreferenced object 0xfffffbfff41ea000 (size 20480):
comm "modprobe", pid 65199, jiffies 4298875551 (age 542.568s)
hex dump (first 32 bytes):
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<ffffffff82354f5e>] kmemleak_alloc+0x4e/0xc0
[<ffffffff8152e718>] __vmalloc_node_range+0x4b8/0x740
[<ffffffff81574072>] kasan_module_alloc+0x72/0xc0
[<ffffffff810efe68>] module_alloc+0x78/0xb0
[<ffffffff812f6a24>] module_alloc_update_bounds+0x14/0x70
[<ffffffff812f8184>] layout_and_allocate+0x16f4/0x3c90
[<ffffffff812faa1f>] load_module+0x2ff/0x6690
[<ffffffff813010b6>] SyS_finit_module+0x136/0x170
[<ffffffff8239bbc9>] system_call_fastpath+0x16/0x1b
[<ffffffffffffffff>] 0xffffffffffffffff
kasan_module_alloc() allocates shadow memory for module and frees it on
module unloading. It doesn't store the pointer to allocated shadow memory
because it could be calculated from the shadowed address, i.e.
kasan_mem_to_shadow(addr).
Since kmemleak cannot find pointer to allocated shadow, it thinks that
memory leaked.
Use kmemleak_ignore() to tell kmemleak that this is not a leak and shadow
memory doesn't contain any pointers.
Currently we already taint the kernel in some cases. E.g. if we hit some
bug in slub memory we call object_err() which will taint the kernel with
TAINT_BAD_PAGE flag. But for other kind of bugs kernel left untainted.
Always taint with TAINT_BAD_PAGE if kasan found some bug. This is useful
for automated testing.
Use IS_ALIGNED() to determine whether the shadow span two bytes. It
generates less code and more readable. Also add some comments in shadow
check functions.
Signed-off-by: Xishi Qiu <qiuxishi@huawei.com>
The current KASAN code can not find the following out-of-bounds bugs:
char *ptr;
ptr = kmalloc(8, GFP_KERNEL);
memset(ptr+7, 0, 2);
the cause of the problem is the type conversion error in
*memory_is_poisoned_n* function. So this patch fix that.
Signed-off-by: Wang Long <long.wanglong@huawei.com>
Cc: Vladimir Murzin <vladimir.murzin@arm.com>
Update the reference to the kasan prototype repository on github, since it
was renamed.
We decided to use KASAN as the short name of the tool and
KernelAddressSanitizer as the full one. Update log messages according to
that.
Makes KASAN accurately determine the type of the bad access. If the shadow
byte value is in the [0, KASAN_SHADOW_SCALE_SIZE) range we can look at
the next shadow byte to determine the type of the access.
Update the names of the bad access types to better reflect the type of
the access that happended and make these error types "literals" that can
be used for classification and deduplication in scripts.
Each access with address lower than
kasan_shadow_to_mem(KASAN_SHADOW_START) is reported as user-memory-access.
This is not always true, the accessed address might not be in user space.
Fix this by reporting such accesses as null-ptr-derefs or
wild-memory-accesses.
There's another reason for this change. For userspace ASan we have a
bunch of systems that analyze error types for the purpose of
classification and deduplication. Sooner of later we will write them to
KASAN as well. Then clearly and explicitly stated error types will bring
value.
When we end up calling kasan_report in real mode, our shadow mapping for
the spinlock variable will show poisoned. This will result in us calling
kasan_report_error with lock_report spin lock held. To prevent this
disable kasan reporting when we are priting error w.r.t kasan.
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Reviewed-by: Andrey Ryabinin <ryabinin.a.a@gmail.com>
We can't use generic functions like print_hex_dump to access kasan shadow
region. This require us to setup another kasan shadow region for the
address passed (kasan shadow address). Some architectures won't be able
to do that. Hence make a copy of the shadow region row and pass that to
generic functions.
Use is_module_address instead
The function only disable/enable reporting. In the later patch we will be
adding a kasan early enable/disable. Rename kasan_enabled to properly
reflect its function.
The shadow which correspond 16 bytes memory may span 2 or 3 bytes. If
the memory is aligned on 8, then the shadow takes only 2 bytes. So we
check "shadow_first_bytes" is enough, and need not to call
"memory_is_poisoned_1(addr + 15);". But the code "if
(likely(!last_byte))" is wrong judgement.
e.g. addr=0, so last_byte = 15 & KASAN_SHADOW_MASK = 7, then the code
will continue to call "memory_is_poisoned_1(addr + 15);"
Cc: <zhongjiang@huawei.com>
Introduce generic kasan_populate_zero_shadow(shadow_start,
shadow_end). This function maps kasan_zero_page to the
[shadow_start, shadow_end] addresses.
This replaces x86_64 specific populate_zero_shadow() and will
be used for ARM64 in follow on patches.
The main changes from original version are:
* Use p?d_populate*() instead of set_p?d()
* Use memblock allocator directly instead of vmemmap_alloc_block()
* __pa() instead of __pa_nodebug(). __pa() causes troubles
iff we use it before kasan_early_init(). kasan_populate_zero_shadow()
will be used later, so we ok with __pa() here.
Signed-off-by: Andrey Ryabinin <ryabinin.a.a@gmail.com>
Cc: Alexey Klimov <klimov.linux@gmail.com>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: David Keitel <dkeitel@codeaurora.org>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Yury <yury.norov@gmail.com>
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/1439444244-26057-3-git-send-email-ryabinin.a.a@gmail.com
Update my email address.
Remove duplicate definition of the macro KASAN_FREE_PAGE in
mm/kasan/kasan.h
Acked-by: Andrey Ryabinin <a.ryabinin@samsung.com>
