path: root/mm/khugepaged.c
2016-11-30mm, thp: propagation of conditional compilation in khugepaged.cJérémy Lefaure
Commit b46e756f5e47 ("thp: extract khugepaged from mm/huge_memory.c") moved code from huge_memory.c to khugepaged.c. Some of this code should be compiled only when CONFIG_SYSFS is enabled but the condition around this code was not moved into khugepaged.c. The result is a compilation error when CONFIG_SYSFS is disabled: mm/built-in.o: In function `khugepaged_defrag_store': khugepaged.c:(.text+0x2d095): undefined reference to `single_hugepage_flag_store' mm/built-in.o: In function `khugepaged_defrag_show': khugepaged.c:(.text+0x2d0ab): undefined reference to `single_hugepage_flag_show' This commit adds the #ifdef CONFIG_SYSFS around the code related to sysfs. Link: http://lkml.kernel.org/r/20161114203448.24197-1-jeremy.lefaure@lse.epita.fr Signed-off-by: Jérémy Lefaure <jeremy.lefaure@lse.epita.fr> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-09-19mm, thp: fix leaking mapped pte in __collapse_huge_page_swapin()Ebru Akagunduz
Currently, khugepaged does not permit swapin if there are enough young pages in a THP. The problem is when a THP does not have enough young pages, khugepaged leaks mapped ptes. This patch prohibits leaking mapped ptes. Link: http://lkml.kernel.org/r/1472820276-7831-1-git-send-email-ebru.akagunduz@gmail.com Signed-off-by: Ebru Akagunduz <ebru.akagunduz@gmail.com> Suggested-by: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-09-19khugepaged: fix use-after-free in collapse_huge_page()Kirill A. Shutemov
hugepage_vma_revalidate() tries to re-check if we still should try to collapse small pages into huge one after the re-acquiring mmap_sem. The problem Dmitry Vyukov reported[1] is that the vma found by hugepage_vma_revalidate() can be suitable for huge pages, but not the same vma we had before dropping mmap_sem. And dereferencing original vma can lead to fun results.. Let's use vma hugepage_vma_revalidate() found instead of assuming it's the same as what we had before the lock was dropped. [1] http://lkml.kernel.org/r/CACT4Y+Z3gigBvhca9kRJFcjX0G70V_nRhbwKBU+yGoESBDKi9Q@mail.gmail.com Link: http://lkml.kernel.org/r/20160907122559.GA6542@black.fi.intel.com Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reported-by: Dmitry Vyukov <dvyukov@google.com> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Ebru Akagunduz <ebru.akagunduz@gmail.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Vegard Nossum <vegard.nossum@oracle.com> Cc: Sasha Levin <levinsasha928@gmail.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com> Cc: Greg Thelen <gthelen@google.com> Cc: Suleiman Souhlal <suleiman@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: David Rientjes <rientjes@google.com> Cc: syzkaller <syzkaller@googlegroups.com> Cc: Kostya Serebryany <kcc@google.com> Cc: Alexander Potapenko <glider@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm, thp: remove __GFP_NORETRY from khugepaged and madvised allocationsVlastimil Babka
After the previous patch, we can distinguish costly allocations that should be really lightweight, such as THP page faults, with __GFP_NORETRY. This means we don't need to recognize khugepaged allocations via PF_KTHREAD anymore. We can also change THP page faults in areas where madvise(MADV_HUGEPAGE) was used to try as hard as khugepaged, as the process has indicated that it benefits from THP's and is willing to pay some initial latency costs. We can also make the flags handling less cryptic by distinguishing GFP_TRANSHUGE_LIGHT (no reclaim at all, default mode in page fault) from GFP_TRANSHUGE (only direct reclaim, khugepaged default). Adding __GFP_NORETRY or __GFP_KSWAPD_RECLAIM is done where needed. The patch effectively changes the current GFP_TRANSHUGE users as follows: * get_huge_zero_page() - the zero page lifetime should be relatively long and it's shared by multiple users, so it's worth spending some effort on it. We use GFP_TRANSHUGE, and __GFP_NORETRY is not added. This also restores direct reclaim to this allocation, which was unintentionally removed by commit e4a49efe4e7e ("mm: thp: set THP defrag by default to madvise and add a stall-free defrag option") * alloc_hugepage_khugepaged_gfpmask() - this is khugepaged, so latency is not an issue. So if khugepaged "defrag" is enabled (the default), do reclaim via GFP_TRANSHUGE without __GFP_NORETRY. We can remove the PF_KTHREAD check from page alloc. As a side-effect, khugepaged will now no longer check if the initial compaction was deferred or contended. This is OK, as khugepaged sleep times between collapsion attempts are long enough to prevent noticeable disruption, so we should allow it to spend some effort. * migrate_misplaced_transhuge_page() - already was masking out __GFP_RECLAIM, so just convert to GFP_TRANSHUGE_LIGHT which is equivalent. * alloc_hugepage_direct_gfpmask() - vma's with VM_HUGEPAGE (via madvise) are now allocating without __GFP_NORETRY. Other vma's keep using __GFP_NORETRY if direct reclaim/compaction is at all allowed (by default it's allowed only for madvised vma's). The rest is conversion to GFP_TRANSHUGE(_LIGHT). [mhocko@suse.com: suggested GFP_TRANSHUGE_LIGHT] Link: http://lkml.kernel.org/r/20160721073614.24395-7-vbabka@suse.cz Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Mel Gorman <mgorman@techsingularity.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm: convert zone_reclaim to node_reclaimMel Gorman
As reclaim is now per-node based, convert zone_reclaim to be node_reclaim. It is possible that a node will be reclaimed multiple times if it has multiple zones but this is unavoidable without caching all nodes traversed so far. The documentation and interface to userspace is the same from a configuration perspective and will will be similar in behaviour unless the node-local allocation requests were also limited to lower zones. Link: http://lkml.kernel.org/r/1467970510-21195-24-git-send-email-mgorman@techsingularity.net Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Hillf Danton <hillf.zj@alibaba-inc.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@surriel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm: move most file-based accounting to the nodeMel Gorman
There are now a number of accounting oddities such as mapped file pages being accounted for on the node while the total number of file pages are accounted on the zone. This can be coped with to some extent but it's confusing so this patch moves the relevant file-based accounted. Due to throttling logic in the page allocator for reliable OOM detection, it is still necessary to track dirty and writeback pages on a per-zone basis. [mgorman@techsingularity.net: fix NR_ZONE_WRITE_PENDING accounting] Link: http://lkml.kernel.org/r/1468404004-5085-5-git-send-email-mgorman@techsingularity.net Link: http://lkml.kernel.org/r/1467970510-21195-20-git-send-email-mgorman@techsingularity.net Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Hillf Danton <hillf.zj@alibaba-inc.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@surriel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm, vmscan: move LRU lists to nodeMel Gorman
This moves the LRU lists from the zone to the node and related data such as counters, tracing, congestion tracking and writeback tracking. Unfortunately, due to reclaim and compaction retry logic, it is necessary to account for the number of LRU pages on both zone and node logic. Most reclaim logic is based on the node counters but the retry logic uses the zone counters which do not distinguish inactive and active sizes. It would be possible to leave the LRU counters on a per-zone basis but it's a heavier calculation across multiple cache lines that is much more frequent than the retry checks. Other than the LRU counters, this is mostly a mechanical patch but note that it introduces a number of anomalies. For example, the scans are per-zone but using per-node counters. We also mark a node as congested when a zone is congested. This causes weird problems that are fixed later but is easier to review. In the event that there is excessive overhead on 32-bit systems due to the nodes being on LRU then there are two potential solutions 1. Long-term isolation of highmem pages when reclaim is lowmem When pages are skipped, they are immediately added back onto the LRU list. If lowmem reclaim persisted for long periods of time, the same highmem pages get continually scanned. The idea would be that lowmem keeps those pages on a separate list until a reclaim for highmem pages arrives that splices the highmem pages back onto the LRU. It potentially could be implemented similar to the UNEVICTABLE list. That would reduce the skip rate with the potential corner case is that highmem pages have to be scanned and reclaimed to free lowmem slab pages. 2. Linear scan lowmem pages if the initial LRU shrink fails This will break LRU ordering but may be preferable and faster during memory pressure than skipping LRU pages. Link: http://lkml.kernel.org/r/1467970510-21195-4-git-send-email-mgorman@techsingularity.net Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Hillf Danton <hillf.zj@alibaba-inc.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@surriel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26mm, thp: convert from optimistic swapin collapsing to conservativeEbru Akagunduz
To detect whether khugepaged swapin is worthwhile, this patch checks the amount of young pages. There should be at least half of HPAGE_PMD_NR to swapin. Link: http://lkml.kernel.org/r/1468109451-1615-1-git-send-email-ebru.akagunduz@gmail.com Signed-off-by: Ebru Akagunduz <ebru.akagunduz@gmail.com> Suggested-by: Minchan Kim <minchan@kernel.org> Acked-by: Rik van Riel <riel@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Mel Gorman <mgorman@suse.de> Cc: David Rientjes <rientjes@google.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Boaz Harrosh <boaz@plexistor.com> Cc: Hillf Danton <hillf.zj@alibaba-inc.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26mm, thp: fix comment inconsistency for swapin readahead functionsEbru Akagunduz
After fixing swapin issues, comment lines stayed as in old version. This patch updates the comments. Link: http://lkml.kernel.org/r/1468109345-32258-1-git-send-email-ebru.akagunduz@gmail.com Signed-off-by: Ebru Akagunduz <ebru.akagunduz@gmail.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Mel Gorman <mgorman@suse.de> Cc: David Rientjes <rientjes@google.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Boaz Harrosh <boaz@plexistor.com> Cc: Hillf Danton <hillf.zj@alibaba-inc.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26thp: introduce CONFIG_TRANSPARENT_HUGE_PAGECACHEKirill A. Shutemov
For file mappings, we don't deposit page tables on THP allocation because it's not strictly required to implement split_huge_pmd(): we can just clear pmd and let following page faults to reconstruct the page table. But Power makes use of deposited page table to address MMU quirk. Let's hide THP page cache, including huge tmpfs, under separate config option, so it can be forbidden on Power. We can revert the patch later once solution for Power found. Link: http://lkml.kernel.org/r/1466021202-61880-36-git-send-email-kirill.shutemov@linux.intel.com Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26khugepaged: add support of collapse for tmpfs/shmem pagesKirill A. Shutemov
This patch extends khugepaged to support collapse of tmpfs/shmem pages. We share fair amount of infrastructure with anon-THP collapse. Few design points: - First we are looking for VMA which can be suitable for mapping huge page; - If the VMA maps shmem file, the rest scan/collapse operations operates on page cache, not on page tables as in anon VMA case. - khugepaged_scan_shmem() finds a range which is suitable for huge page. The scan is lockless and shouldn't disturb system too much. - once the candidate for collapse is found, collapse_shmem() attempts to create a huge page: + scan over radix tree, making the range point to new huge page; + new huge page is not-uptodate, locked and freezed (refcount is 0), so nobody can touch them until we say so. + we swap in pages during the scan. khugepaged_scan_shmem() filters out ranges with more than khugepaged_max_ptes_swap swapped out pages. It's HPAGE_PMD_NR/8 by default. + old pages are isolated, unmapped and put to local list in case to be restored back if collapse failed. - if collapse succeed, we retract pte page tables from VMAs where huge pages mapping is possible. The huge page will be mapped as PMD on next minor fault into the range. Link: http://lkml.kernel.org/r/1466021202-61880-35-git-send-email-kirill.shutemov@linux.intel.com Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26khugepaged: move up_read(mmap_sem) out of khugepaged_alloc_page()Kirill A. Shutemov
Both variants of khugepaged_alloc_page() do up_read(&mm->mmap_sem) first: no point keep it inside the function. Link: http://lkml.kernel.org/r/1466021202-61880-33-git-send-email-kirill.shutemov@linux.intel.com Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26thp: extract khugepaged from mm/huge_memory.cKirill A. Shutemov
khugepaged implementation grew to the point when it deserve separate file in source. Let's move it to mm/khugepaged.c. Link: http://lkml.kernel.org/r/1466021202-61880-32-git-send-email-kirill.shutemov@linux.intel.com Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
