commit 668f9abbd4334e6c29fa8acd71635c4f9101caa7 upstream.
Commit bf6bddf1924e ("mm: introduce compaction and migration for
ballooned pages") introduces page_count(page) into memory compaction
which dereferences page->first_page if PageTail(page).
This results in a very rare NULL pointer dereference on the
aforementioned page_count(page). Indeed, anything that does
compound_head(), including page_count() is susceptible to racing with
prep_compound_page() and seeing a NULL or dangling page->first_page
pointer.
This patch uses Andrea's implementation of compound_trans_head() that
deals with such a race and makes it the default compound_head()
implementation. This includes a read memory barrier that ensures that
if PageTail(head) is true that we return a head page that is neither
NULL nor dangling. The patch then adds a store memory barrier to
prep_compound_page() to ensure page->first_page is set.
This is the safest way to ensure we see the head page that we are
expecting, PageTail(page) is already in the unlikely() path and the
memory barriers are unfortunately required.
Hugetlbfs is the exception, we don't enforce a store memory barrier
during init since no race is possible.
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Holger Kiehl <Holger.Kiehl@dwd.de>
Cc: Christoph Lameter <cl@linux.com>
Cc: Rafael Aquini <aquini@redhat.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
The use of strict_strtoul() is not preferred, because strict_strtoul() is
obsolete. Thus, kstrtoul() should be used.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
A CONFIG_DISCONTIGMEM=y m68k config gave
mm/ksm.c: In function `get_kpfn_nid':
mm/ksm.c:492: error: implicit declaration of function `pfn_to_nid'
linux/mmzone.h declares it for CONFIG_SPARSEMEM and CONFIG_FLATMEM, but
expects the arch's asm/mmzone.h to declare it for CONFIG_DISCONTIGMEM
(see arch/mips/include/asm/mmzone.h for example).
Or perhaps it is only expected when CONFIG_NUMA=y: too much of a maze,
and m68k got away without it so far, so fix the build in mm/ksm.c.
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Cc: Petr Holasek <pholasek@redhat.com>
I'm not sure why, but the hlist for each entry iterators were conceived
list_for_each_entry(pos, head, member)
The hlist ones were greedy and wanted an extra parameter:
hlist_for_each_entry(tpos, pos, head, member)
Why did they need an extra pos parameter? I'm not quite sure. Not only
they don't really need it, it also prevents the iterator from looking
exactly like the list iterator, which is unfortunate.
Besides the semantic patch, there was some manual work required:
- Fix up the actual hlist iterators in linux/list.h
- Fix up the declaration of other iterators based on the hlist ones.
- A very small amount of places were using the 'node' parameter, this
was modified to use 'obj->member' instead.
- Coccinelle didn't handle the hlist_for_each_entry_safe iterator
properly, so those had to be fixed up manually.
The semantic patch which is mostly the work of Peter Senna Tschudin is here:
iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host;
type T;
expression a,c,d,e;
identifier b;
statement S;
-T b;
<+... when != b
hlist_for_each_entry(a,
- b,
c, d) S
hlist_for_each_entry_continue(a,
- b,
c) S
hlist_for_each_entry_from(a,
- b,
c) S
hlist_for_each_entry_rcu(a,
- b,
c, d) S
hlist_for_each_entry_rcu_bh(a,
- b,
c, d) S
hlist_for_each_entry_continue_rcu_bh(a,
- b,
c) S
for_each_busy_worker(a, c,
- b,
d) S
ax25_uid_for_each(a,
- b,
c) S
ax25_for_each(a,
- b,
c) S
inet_bind_bucket_for_each(a,
- b,
c) S
sctp_for_each_hentry(a,
- b,
c) S
sk_for_each(a,
- b,
c) S
sk_for_each_rcu(a,
- b,
c) S
sk_for_each_from
-(a, b)
+(a)
S
+ sk_for_each_from(a) S
sk_for_each_safe(a,
- b,
c, d) S
sk_for_each_bound(a,
- b,
c) S
hlist_for_each_entry_safe(a,
- b,
c, d, e) S
hlist_for_each_entry_continue_rcu(a,
- b,
c) S
nr_neigh_for_each(a,
- b,
c) S
nr_neigh_for_each_safe(a,
- b,
c, d) S
nr_node_for_each(a,
- b,
c) S
nr_node_for_each_safe(a,
- b,
c, d) S
- for_each_gfn_sp(a, c, d, b) S
+ for_each_gfn_sp(a, c, d) S
- for_each_gfn_indirect_valid_sp(a, c, d, b) S
+ for_each_gfn_indirect_valid_sp(a, c, d) S
for_each_host(a,
- b,
c) S
for_each_host_safe(a,
- b,
c, d) S
for_each_mesh_entry(a,
- b,
c, d) S
[akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c]
[akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c]
[akpm@linux-foundation.org: checkpatch fixes]
[akpm@linux-foundation.org: fix warnings]
[akpm@linux-foudnation.org: redo intrusive kvm changes]
Tested-by: Peter Senna Tschudin <peter.senna@gmail.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Gleb Natapov <gleb@redhat.com>
It is a pity to have MAX_NUMNODES+MAX_NUMNODES tree roots statically
allocated, particularly when very few users will ever actually tune
merge_across_nodes 0 to use more than 1+1 of those trees. Not a big
deal (only 16kB wasted on each machine with CONFIG_MAXSMP), but a pity.
Start off with 1+1 statically allocated, then if merge_across_nodes is
ever tuned, allocate for nr_node_ids+nr_node_ids. Do not attempt to
free up the extra if it's tuned back, that would be a waste of effort.
Cc: Izik Eidus <izik.eidus@ravellosystems.com>
In "ksm: remove old stable nodes more thoroughly" I said that I'd never
seen its WARN_ON_ONCE(page_mapped(page)). True at the time of writing,
but it soon appeared once I tried fuller tests on the whole series.
It turned out to be due to the KSM page migration itself: unmerge_and_
remove_all_rmap_items() failed to locate and replace all the KSM pages,
because of that hiatus in page migration when old pte has been replaced
by migration entry, but not yet by new pte. follow_page() finds no page
at that instant, but a KSM page reappears shortly after, without a
fault.
Add FOLL_MIGRATION flag, so follow_page() can do migration_entry_wait()
for KSM's break_cow(). I'd have preferred to avoid another flag, and do
it every time, in case someone else makes the same easy mistake; but did
not find another transgressor (the common get_user_pages() is of course
safe), and cannot be sure that every follow_page() caller is prepared to
sleep - ia64's xencomm_vtop()? Now, THP's wait_split_huge_page() can
already sleep there, since anon_vma locking was changed to mutex, but
maybe that's somehow excluded.
Think of struct rmap_item as an extension of struct page (restricted to
MADV_MERGEABLE areas): there may be a lot of them, we need to keep them
small, especially on 32-bit architectures of limited lowmem.
Siting "int nid" after "unsigned int checksum" works nicely on 64-bit,
making no change to its 64-byte struct rmap_item; but bloats the 32-bit
struct rmap_item from (nicely cache-aligned) 32 bytes to 36 bytes, which
rounds up to 40 bytes once allocated from slab. We'd better avoid that.
Hey, I only just remembered that the anon_vma pointer in struct
rmap_item has no purpose until the rmap_item is hung from a stable tree
node (which has its own nid field); and rmap_item's nid field no purpose
than to say which tree root to tell rb_erase() when unlinking from an
unstable tree.
Double them up in a union. There's just one place where we set anon_vma
early (when we already hold mmap_sem): now we must remove tree_rmap_item
from its unstable tree there, before overwriting nid. No need to
spatter BUG()s around: we'd be seeing oopses if this were wrong.
An inconsistency emerged in reviewing the NUMA node changes to KSM: when
meeting a page from the wrong NUMA node in a stable tree, we say that
it's okay for comparisons, but not as a leaf for merging; whereas when
meeting a page from the wrong NUMA node in an unstable tree, we bail out
immediately.
Now, it might be that a wrong NUMA node in an unstable tree is more
likely to correlate with instablility (different content, with rbnode
now misplaced) than page migration; but even so, we are accustomed to
instablility in the unstable tree.
Without strong evidence for which strategy is generally better, I'd
rather be consistent with what's done in the stable tree: accept a page
from the wrong NUMA node for comparison, but not as a leaf for merging.
Added slightly more detail to the Documentation of merge_across_nodes, a
few comments in areas indicated by review, and renamed get_ksm_page()'s
argument from "locked" to "lock_it". No functional change.
Complaints are rare, but lockdep still does not understand the way
ksm_memory_callback(MEM_GOING_OFFLINE) takes ksm_thread_mutex, and holds
it until the ksm_memory_callback(MEM_OFFLINE): that appears to be a
problem because notifier callbacks are made under down_read of
blocking_notifier_head->rwsem (so first the mutex is taken while holding
the rwsem, then later the rwsem is taken while still holding the mutex);
but is not in fact a problem because mem_hotplug_mutex is held
throughout the dance.
There was an attempt to fix this with mutex_lock_nested(); but if that
happened to fool lockdep two years ago, apparently it does so no longer.
I had hoped to eradicate this issue in extending KSM page migration not
to need the ksm_thread_mutex. But then realized that although the page
migration itself is safe, we do still need to lock out ksmd and other
users of get_ksm_page() while offlining memory - at some point between
MEM_GOING_OFFLINE and MEM_OFFLINE, the struct pages themselves may
vanish, and get_ksm_page()'s accesses to them become a violation.
So, give up on holding ksm_thread_mutex itself from MEM_GOING_OFFLINE to
MEM_OFFLINE, and add a KSM_RUN_OFFLINE flag, and wait_while_offlining()
checks, to achieve the same lockout without being caught by lockdep.
This is less elegant for KSM, but it's more important to keep lockdep
useful to other users - and I apologize for how long it took to fix.
Reported-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Tested-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com>
The new KSM NUMA merge_across_nodes knob introduces a problem, when it's
set to non-default 0: if a KSM page is migrated to a different NUMA node,
how do we migrate its stable node to the right tree? And what if that
collides with an existing stable node?
ksm_migrate_page() can do no more than it's already doing, updating
stable_node->kpfn: the stable tree itself cannot be manipulated without
holding ksm_thread_mutex. So accept that a stable tree may temporarily
indicate a page belonging to the wrong NUMA node, leave updating until the
next pass of ksmd, just be careful not to merge other pages on to a
misplaced page. Note nid of holding tree in stable_node, and recognize
that it will not always match nid of kpfn.
A misplaced KSM page is discovered, either when ksm_do_scan() next comes
around to one of its rmap_items (we now have to go to cmp_and_merge_page
even on pages in a stable tree), or when stable_tree_search() arrives at a
matching node for another page, and this node page is found misplaced.
In each case, move the misplaced stable_node to a list of migrate_nodes
(and use the address of migrate_nodes as magic by which to identify them):
we don't need them in a tree. If stable_tree_search() finds no match for
a page, but it's currently exiled to this list, then slot its stable_node
right there into the tree, bringing all of its mappings with it; otherwise
they get migrated one by one to the original page of the colliding node.
stable_tree_search() is now modelled more like stable_tree_insert(), in
order to handle these insertions of migrated nodes.
remove_node_from_stable_tree(), remove_all_stable_nodes() and
ksm_check_stable_tree() have to handle the migrate_nodes list as well as
the stable tree itself. Less obviously, we do need to prune the list of
stale entries from time to time (scan_get_next_rmap_item() does it once
each full scan): whereas stale nodes in the stable tree get naturally
pruned as searches try to brush past them, these migrate_nodes may get
forgotten and accumulate.
Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com>
KSM page migration is already supported in the case of memory hotremove,
which takes the ksm_thread_mutex across all its migrations to keep life
simple.
But the new KSM NUMA merge_across_nodes knob introduces a problem, when
it's set to non-default 0: if a KSM page is migrated to a different NUMA
node, how do we migrate its stable node to the right tree? And what if
that collides with an existing stable node?
So far there's no provision for that, and this patch does not attempt to
deal with it either. But how will I test a solution, when I don't know
how to hotremove memory? The best answer is to enable KSM page migration
in all cases now, and test more common cases. With THP and compaction
added since KSM came in, page migration is now mainstream, and it's a
shame that a KSM page can frustrate freeing a page block.
Without worrying about merge_across_nodes 0 for now, this patch gets KSM
page migration working reliably for default merge_across_nodes 1 (but
leave the patch enabling it until near the end of the series).
It's much simpler than I'd originally imagined, and does not require an
additional tier of locking: page migration relies on the page lock, KSM
page reclaim relies on the page lock, the page lock is enough for KSM page
migration too.
Almost all the care has to be in get_ksm_page(): that's the function which
worries about when a stable node is stale and should be freed, now it also
has to worry about the KSM page being migrated.
The only new overhead is an additional put/get/lock/unlock_page when
stable_tree_search() arrives at a matching node: to make sure migration
respects the raised page count, and so does not migrate the page while
we're busy with it here. That's probably avoidable, either by changing
internal interfaces from using kpage to stable_node, or by moving the
ksm_migrate_page() callsite into a page_freeze_refs() section (even if not
swapcache); but this works well, I've no urge to pull it apart now.
(Descents of the stable tree may pass through nodes whose KSM pages are
under migration: being unlocked, the raised page count does not prevent
that, nor need it: it's safe to memcmp against either old or new page.)
You might worry about mremap, and whether page migration's rmap_walk to
remove migration entries will find all the KSM locations where it inserted
earlier: that should already be handled, by the satisfyingly heavy hammer
of move_vma()'s call to ksm_madvise(,,,MADV_UNMERGEABLE,).
Switching merge_across_nodes after running KSM is liable to oops on stale
nodes still left over from the previous stable tree. It's not something
that people will often want to do, but it would be lame to demand a reboot
when they're trying to determine which merge_across_nodes setting is best.
How can this happen? We only permit switching merge_across_nodes when
pages_shared is 0, and usually set run 2 to force that beforehand, which
ought to unmerge everything: yet oopses still occur when you then run 1.
Three causes:
1. The old stable tree (built according to the inverse
merge_across_nodes) has not been fully torn down. A stable node
lingers until get_ksm_page() notices that the page it references no
longer references it: but the page is not necessarily freed as soon as
expected, particularly when swapcache.
Fix this with a pass through the old stable tree, applying
get_ksm_page() to each of the remaining nodes (most found stale and
removed immediately), with forced removal of any left over. Unless the
page is still mapped: I've not seen that case, it shouldn't occur, but
better to WARN_ON_ONCE and EBUSY than BUG.
2. __ksm_enter() has a nice little optimization, to insert the new mm
just behind ksmd's cursor, so there's a full pass for it to stabilize
(or be removed) before ksmd addresses it. Nice when ksmd is running,
but not so nice when we're trying to unmerge all mms: we were missing
those mms forked and inserted behind the unmerge cursor. Easily fixed
by inserting at the end when KSM_RUN_UNMERGE.
3. It is possible for a KSM page to be faulted back from swapcache
into an mm, just after unmerge_and_remove_all_rmap_items() scanned past
it. Fix this by copying on fault when KSM_RUN_UNMERGE: but that is
private to ksm.c, so dissolve the distinction between
ksm_might_need_to_copy() and ksm_does_need_to_copy(), doing it all in
the one call into ksm.c.
A long outstanding, unrelated bugfix sneaks in with that third fix:
ksm_does_need_to_copy() would copy from a !PageUptodate page (implying I/O
error when read in from swap) to a page which it then marks Uptodate. Fix
this case by not copying, letting do_swap_page() discover the error.
In some places where get_ksm_page() is used, we need the page to be locked.
When KSM migration is fully enabled, we shall want that to make sure that
the page just acquired cannot be migrated beneath us (raised page count is
only effective when there is serialization to make sure migration
notices). Whereas when navigating through the stable tree, we certainly
do not want to lock each node (raised page count is enough to guarantee
the memcmps, even if page is migrated to another node).
Since we're about to add another use case, add the locked argument to
get_ksm_page() now.
Hmm, what's that rcu_read_lock() about? Complete misunderstanding, I
really got the wrong end of the stick on that! There's a configuration in
which page_cache_get_speculative() can do something cheaper than
get_page_unless_zero(), relying on its caller's rcu_read_lock() to have
disabled preemption for it. There's no need for rcu_read_lock() around
get_page_unless_zero() (and mapping checks) here. Cut out that silliness
before making this any harder to understand.
Memory hotremove's ksm_check_stable_tree() is pitifully inefficient
(restarting whenever it finds a stale node to remove), but rearrange so
that at least it does not needlessly restart from nid 0 each time. And
add a couple of comments: here is why we keep pfn instead of page.
Add NUMA() and DO_NUMA() macros to minimize blight of #ifdef
CONFIG_NUMAs (but indeed we don't want to expand struct rmap_item by nid
when not NUMA). Add comment, remove "unsigned" from rmap_item->nid, as
"int nid" elsewhere. Define ksm_merge_across_nodes 1U when #ifndef NUMA
to help optimizing out. Use ?: in get_kpfn_nid(). Adjust a few
comments noticed in ongoing work.
Leave stable_tree_insert()'s rb_linkage until after the node has been
set up, as unstable_tree_search_insert() does: ksm_thread_mutex and page
lock make either way safe, but we're going to copy and I prefer this
precedent.
Here's a KSM series, based on mmotm 2013-01-23-17-04: starting with
Petr's v7 "KSM: numa awareness sysfs knob"; then fixing the two issues
we had with that, fully enabling KSM page migration on the way.
(A different kind of KSM/NUMA issue which I've certainly not begun to
address here: when KSM pages are unmerged, there's usually no sense in
preferring to allocate the new pages local to the caller's node.)
This patch:
Introduces new sysfs boolean knob /sys/kernel/mm/ksm/merge_across_nodes
which control merging pages across different numa nodes. When it is set
to zero only pages from the same node are merged, otherwise pages from
all nodes can be merged together (default behavior).
Typical use-case could be a lot of KVM guests on NUMA machine and cpus
from more distant nodes would have significant increase of access
latency to the merged ksm page. Sysfs knob was choosen for higher
variability when some users still prefers higher amount of saved
physical memory regardless of access latency.
Every numa node has its own stable & unstable trees because of faster
searching and inserting. Changing of merge_across_nodes value is
possible only when there are not any ksm shared pages in system.
I've tested this patch on numa machines with 2, 4 and 8 nodes and
measured speed of memory access inside of KVM guests with memory pinned
to one of nodes with this benchmark:
http://pholasek.fedorapeople.org/alloc_pg.c
Population standard deviations of access times in percentage of average
were following:
merge_across_nodes=1
2 nodes 1.4%
4 nodes 1.6%
8 nodes 1.7%
merge_across_nodes=0
2 nodes 1%
4 nodes 0.32%
8 nodes 0.018%
RFC: https://lkml.org/lkml/2011/11/30/91
v1: https://lkml.org/lkml/2012/1/23/46
v2: https://lkml.org/lkml/2012/6/29/105
v3: https://lkml.org/lkml/2012/9/14/550
v4: https://lkml.org/lkml/2012/9/23/137
v5: https://lkml.org/lkml/2012/12/10/540
v6: https://lkml.org/lkml/2012/12/23/154
v7: https://lkml.org/lkml/2012/12/27/225
Hugh notes that this patch brings two problems, whose solution needs
further support in mm/ksm.c, which follows in subsequent patches:
1) switching merge_across_nodes after running KSM is liable to oops
on stale nodes still left over from the previous stable tree;
2) memory hotremove may migrate KSM pages, but there is no provision
here for !merge_across_nodes to migrate nodes to the proper tree.
Signed-off-by: Petr Holasek <pholasek@redhat.com>
Switch ksm to use the new hashtable implementation. This reduces the
amount of generic unrelated code in the ksm module.
Signed-off-by: Sasha Levin <levinsasha928@gmail.com>
Cc: Konstantin Khlebnikov <khlebnikov@openvz.org>
When ex-KSM pages are faulted from swap cache, the fault handler is not
capable of re-establishing anon_vma-spanning KSM pages. In this case, a
copy of the page is created instead, just like during a COW break.
These freshly made copies are known to be exclusive to the faulting VMA
and there is no reason to go look for this page in parent and sibling
processes during rmap operations.
Use page_add_new_anon_rmap() for these copies. This also puts them on
the proper LRU lists and marks them SwapBacked, so we can get rid of
doing this ad-hoc in the KSM copy code.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Cc: Simon Jeons <simon.jeons@gmail.com>
Cc: Satoru Moriya <satoru.moriya@hds.com>
The rmap walks in ksm.c are like those in rmap.c: they can safely be
done with anon_vma_lock_read().
git://git.kernel.org/pub/scm/linux/kernel/git/mel/linux-balancenuma
Pull Automatic NUMA Balancing bare-bones from Mel Gorman:
"There are three implementations for NUMA balancing, this tree
(balancenuma), numacore which has been developed in tip/master and
autonuma which is in aa.git.
In almost all respects balancenuma is the dumbest of the three because
its main impact is on the VM side with no attempt to be smart about
scheduling. In the interest of getting the ball rolling, it would be
desirable to see this much merged for 3.8 with the view to building
scheduler smarts on top and adapting the VM where required for 3.9.
The most recent set of comparisons available from different people are
mel: https://lkml.org/lkml/2012/12/9/108
mingo: https://lkml.org/lkml/2012/12/7/331
tglx: https://lkml.org/lkml/2012/12/10/437
srikar: https://lkml.org/lkml/2012/12/10/397
The results are a mixed bag. In my own tests, balancenuma does
reasonably well. It's dumb as rocks and does not regress against
mainline. On the other hand, Ingo's tests shows that balancenuma is
incapable of converging for this workloads driven by perf which is bad
but is potentially explained by the lack of scheduler smarts. Thomas'
results show balancenuma improves on mainline but falls far short of
numacore or autonuma. Srikar's results indicate we all suffer on a
large machine with imbalanced node sizes.
My own testing showed that recent numacore results have improved
dramatically, particularly in the last week but not universally.
We've butted heads heavily on system CPU usage and high levels of
migration even when it shows that overall performance is better.
There are also cases where it regresses. Of interest is that for
specjbb in some configurations it will regress for lower numbers of
warehouses and show gains for higher numbers which is not reported by
the tool by default and sometimes missed in treports. Recently I
reported for numacore that the JVM was crashing with
NullPointerExceptions but currently it's unclear what the source of
this problem is. Initially I thought it was in how numacore batch
handles PTEs but I'm no longer think this is the case. It's possible
numacore is just able to trigger it due to higher rates of migration.
These reports were quite late in the cycle so I/we would like to start
with this tree as it contains much of the code we can agree on and has
not changed significantly over the last 2-3 weeks."
* tag 'balancenuma-v11' of git://git.kernel.org/pub/scm/linux/kernel/git/mel/linux-balancenuma: (50 commits)
mm/rmap, migration: Make rmap_walk_anon() and try_to_unmap_anon() more scalable
mm/rmap: Convert the struct anon_vma::mutex to an rwsem
mm: migrate: Account a transhuge page properly when rate limiting
mm: numa: Account for failed allocations and isolations as migration failures
mm: numa: Add THP migration for the NUMA working set scanning fault case build fix
mm: numa: Add THP migration for the NUMA working set scanning fault case.
mm: sched: numa: Delay PTE scanning until a task is scheduled on a new node
mm: sched: numa: Control enabling and disabling of NUMA balancing if !SCHED_DEBUG
mm: sched: Adapt the scanning rate if a NUMA hinting fault does not migrate
mm: numa: Use a two-stage filter to restrict pages being migrated for unlikely task<->node relationships
mm: numa: migrate: Set last_nid on newly allocated page
mm: numa: split_huge_page: Transfer last_nid on tail page
mm: numa: Introduce last_nid to the page frame
sched: numa: Slowly increase the scanning period as NUMA faults are handled
mm: numa: Rate limit setting of pte_numa if node is saturated
mm: numa: Rate limit the amount of memory that is migrated between nodes
mm: numa: Structures for Migrate On Fault per NUMA migration rate limiting
mm: numa: Migrate pages handled during a pmd_numa hinting fault
mm: numa: Migrate on reference policy
test_set_oom_score_adj() and compare_swap_oom_score_adj() are used to
specify that current should be killed first if an oom condition occurs in
between the two calls.
The usage is
short oom_score_adj = test_set_oom_score_adj(OOM_SCORE_ADJ_MAX);
compare_swap_oom_score_adj(OOM_SCORE_ADJ_MAX, oom_score_adj);
to store the thread's oom_score_adj, temporarily change it to the maximum
score possible, and then restore the old value if it is still the same.
This happens to still be racy, however, if the user writes
OOM_SCORE_ADJ_MAX to /proc/pid/oom_score_adj in between the two calls.
The compare_swap_oom_score_adj() will then incorrectly reset the old value
prior to the write of OOM_SCORE_ADJ_MAX.
To fix this, introduce a new oom_flags_t member in struct signal_struct
that will be used for per-thread oom killer flags. KSM and swapoff can
now use a bit in this member to specify that threads should be killed
first in oom conditions without playing around with oom_score_adj.
This also allows the correct oom_score_adj to always be shown when reading
/proc/pid/oom_score.
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Cc: Anton Vorontsov <anton.vorontsov@linaro.org>
The maximum oom_score_adj is 1000 and the minimum oom_score_adj is -1000,
so this range can be represented by the signed short type with no
functional change. The extra space this frees up in struct signal_struct
will be used for per-thread oom kill flags in the next patch.
Several place need to find the pmd by(mm_struct, address), so introduce a
function to simplify it.
[akpm@linux-foundation.org: fix warning]
Signed-off-by: Bob Liu <lliubbo@gmail.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
Cc: Ni zhan Chen <nizhan.chen@gmail.com>
rmap_walk_anon() and try_to_unmap_anon() appears to be too
careful about locking the anon vma: while it needs protection
against anon vma list modifications, it does not need exclusive
access to the list itself.
Transforming this exclusive lock to a read-locked rwsem removes
a global lock from the hot path of page-migration intense
threaded workloads which can cause pathological performance like
this:
96.43% process 0 [kernel.kallsyms] [k] perf_trace_sched_switch
--- perf_trace_sched_switch
__schedule
schedule
schedule_preempt_disabled
__mutex_lock_common.isra.6
__mutex_lock_slowpath
mutex_lock
|--50.61%-- rmap_walk
| move_to_new_page
| migrate_pages
| migrate_misplaced_page
| __do_numa_page.isra.69
| handle_pte_fault
| handle_mm_fault
| __do_page_fault
| do_page_fault
| page_fault
| __memset_sse2
| --100.00%-- worker_thread
| --100.00%-- start_thread
--49.39%-- page_lock_anon_vma
try_to_unmap_anon
try_to_unmap
migrate_pages
handle_pte_fault
handle_mm_fault
__do_page_fault
do_page_fault
page_fault
__memset_sse2
start_thread
With this change applied the profile is now nicely flat
and there's no anon-vma related scheduling/blocking.
Rename anon_vma_[un]lock() => anon_vma_[un]lock_write(),
to make it clearer that it's an exclusive write-lock in
that case - suggested by Rik van Riel.
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Paul Turner <pjt@google.com>
invalidate_range_end
In order to allow sleeping during invalidate_page mmu notifier calls, we
need to avoid calling when holding the PT lock. In addition to its direct
calls, invalidate_page can also be called as a substitute for a change_pte
call, in case the notifier client hasn't implemented change_pte.
This patch drops the invalidate_page call from change_pte, and instead
wraps all calls to change_pte with invalidate_range_start and
invalidate_range_end calls.
Note that change_pte still cannot sleep after this patch, and that clients
implementing change_pte should not take action on it in case the number of
outstanding invalidate_range_start calls is larger than one, otherwise
they might miss a later invalidation.
Signed-off-by: Haggai Eran <haggaie@mellanox.com>
Cc: Andrea Arcangeli <andrea@qumranet.com>
Cc: Sagi Grimberg <sagig@mellanox.com>
Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
Cc: Or Gerlitz <ogerlitz@mellanox.com>
Cc: Haggai Eran <haggaie@mellanox.com>
Cc: Shachar Raindel <raindel@mellanox.com>
Cc: Liran Liss <liranl@mellanox.com>
Cc: Avi Kivity <avi@redhat.com>
page_evictable(page, vma) is an irritant: almost all its callers pass
NULL for vma. Remove the vma arg and use mlocked_vma_newpage(vma, page)
explicitly in the couple of places it's needed. But in those places we
don't even need page_evictable() itself! They're dealing with a freshly
allocated anonymous page, which has no "mapping" and cannot be mlocked yet.
Acked-by: Mel Gorman <mel@csn.ul.ie>
Cc: Michel Lespinasse <walken@google.com>
Cc: Ying Han <yinghan@google.com>
When a large VMA (anon or private file mapping) is first touched, which
will populate its anon_vma field, and then split into many regions through
the use of mprotect(), the original anon_vma ends up linking all of the
vmas on a linked list. This can cause rmap to become inefficient, as we
have to walk potentially thousands of irrelevent vmas before finding the
one a given anon page might fall into.
By replacing the same_anon_vma linked list with an interval tree (where
each avc's interval is determined by its vma's start and last pgoffs), we
can make rmap efficient for this use case again.
While the change is large, all of its pieces are fairly simple.
Most places that were walking the same_anon_vma list were looking for a
known pgoff, so they can just use the anon_vma_interval_tree_foreach()
interval tree iterator instead. The exception here is ksm, where the
page's index is not known. It would probably be possible to rework ksm so
that the index would be known, but for now I have decided to keep things
simple and just walk the entirety of the interval tree there.
When updating vma's that already have an anon_vma assigned, we must take
care to re-index the corresponding avc's on their interval tree. This is
done through the use of anon_vma_interval_tree_pre_update_vma() and
anon_vma_interval_tree_post_update_vma(), which remove the avc's from
their interval tree before the update and re-insert them after the update.
The anon_vma stays locked during the update, so there is no chance that
rmap would miss the vmas that are being updated.
Signed-off-by: Michel Lespinasse <walken@google.com>
Cc: Daniel Santos <daniel.santos@pobox.com>
A long time ago, in v2.4, VM_RESERVED kept swapout process off VMA,
currently it lost original meaning but still has some effects:
| effect | alternative flags
1| account as reserved_vm | VM_IO
2| skip in core dump | VM_IO, VM_DONTDUMP
3| do not merge or expand | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP
4| do not mlock | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP
This patch removes reserved_vm counter from mm_struct. Seems like nobody
cares about it, it does not exported into userspace directly, it only
reduces total_vm showed in proc.
Thus VM_RESERVED can be replaced with VM_IO or pair VM_DONTEXPAND | VM_DONTDUMP.
remap_pfn_range() and io_remap_pfn_range() set VM_IO|VM_DONTEXPAND|VM_DONTDUMP.
remap_vmalloc_range() set VM_DONTEXPAND | VM_DONTDUMP.
[akpm@linux-foundation.org: drivers/vfio/pci/vfio_pci.c fixup]
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Cc: Carsten Otte <cotte@de.ibm.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Eric Paris <eparis@redhat.com>
Cc: James Morris <james.l.morris@oracle.com>
Cc: Jason Baron <jbaron@redhat.com>
Cc: Kentaro Takeda <takedakn@nttdata.co.jp>
Cc: Matt Helsley <matthltc@us.ibm.com>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Robert Richter <robert.richter@amd.com>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: Venkatesh Pallipadi <venki@google.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Merge VM_INSERTPAGE into VM_MIXEDMAP. VM_MIXEDMAP VMA can mix pure-pfn
ptes, special ptes and normal ptes.
Now copy_page_range() always copies VM_MIXEDMAP VMA on fork like
VM_PFNMAP. If driver populates whole VMA at mmap() it probably not
expects page-faults.
This patch removes special check from vma_wants_writenotify() which
disables pages write tracking for VMA populated via vm_instert_page().
BDI below mapped file should not use dirty-accounting, moreover
do_wp_page() can handle this.
vm_insert_page() still marks vma after first usage. Usually it is called
from f_op->mmap() handler under mm->mmap_sem write-lock, so it able to
change vma->vm_flags. Caller must set VM_MIXEDMAP at mmap time if it
wants to call this function from other places, for example from page-fault
handler.
Combine several arch-specific vma flags into one.
before patch:
0x00000200 0x01000000 0x20000000 0x40000000
x86 VM_NOHUGEPAGE VM_HUGEPAGE - VM_PAT
powerpc - - VM_SAO -
parisc VM_GROWSUP - - -
ia64 VM_GROWSUP - - -
nommu - VM_MAPPED_COPY - -
others - - - -
after patch:
x86 - VM_PAT VM_HUGEPAGE VM_NOHUGEPAGE
powerpc - VM_SAO - -
parisc - VM_GROWSUP - -
ia64 - VM_GROWSUP - -
others - VM_ARCH_1 - -
And voila! One completely free bit.
There are multiple places which perform the same check. Add a new
find_mergeable_vma() to handle this.
Signed-off-by: Cong Wang <amwang@redhat.com>
When moving tasks from old memcg (with move_charge_at_immigrate on new
memcg), followed by removal of old memcg, hit General Protection Fault in
mem_cgroup_lru_del_list() (called from release_pages called from
free_pages_and_swap_cache from tlb_flush_mmu from tlb_finish_mmu from
exit_mmap from mmput from exit_mm from do_exit).
Somewhat reproducible, takes a few hours: the old struct mem_cgroup has
been freed and poisoned by SLAB_DEBUG, but mem_cgroup_lru_del_list() is
still trying to update its stats, and take page off lru before freeing.
A task, or a charge, or a page on lru: each secures a memcg against
removal. In this case, the last task has been moved out of the old memcg,
and it is exiting: anonymous pages are uncharged one by one from the
memcg, as they are zapped from its pagetables, so the charge gets down to
0; but the pages themselves are queued in an mmu_gather for freeing.
Most of those pages will be on lru (and force_empty is careful to
lru_add_drain_all, to add pages from pagevec to lru first), but not
necessarily all: perhaps some have been isolated for page reclaim, perhaps
some isolated for other reasons. So, force_empty may find no task, no
charge and no page on lru, and let the removal proceed.
There would still be no problem if these pages were immediately freed; but
typically (and the put_page_testzero protocol demands it) they have to be
added back to lru before they are found freeable, then removed from lru
and freed. We don't see the issue when adding, because the
mem_cgroup_iter() loops keep their own reference to the memcg being
scanned; but when it comes to mem_cgroup_lru_del_list().
I believe this was not an issue in v3.2: there, PageCgroupAcctLRU and
PageCgroupUsed flags were used (like a trick with mirrors) to deflect view
of pc->mem_cgroup to the stable root_mem_cgroup when neither set.
38c5d72f3ebe ("memcg: simplify LRU handling by new rule") mercifully
removed those convolutions, but left this General Protection Fault.
But it's surprisingly easy to restore the old behaviour: just check
PageCgroupUsed in mem_cgroup_lru_add_list() (which decides on which lruvec
to add), and reset pc to root_mem_cgroup if page is uncharged. A risky
change? just going back to how it worked before; testing, and an audit of
uses of pc->mem_cgroup, show no problem.
And there's a nice bonus: with mem_cgroup_lru_add_list() itself making
sure that an uncharged page goes to root lru, mem_cgroup_reset_owner() no
longer has any purpose, and we can safely revert 4e5f01c2b9b9 ("memcg:
clear pc->mem_cgroup if necessary").
Calling update_page_reclaim_stat() after add_page_to_lru_list() in swap.c
is not strictly necessary: the lru_lock there, with RCU before memcg
structures are freed, makes mem_cgroup_get_reclaim_stat_from_page safe
without that; but it seems cleaner to rely on one dependency less.
This is a preparation before removing a flag PCG_ACCT_LRU in page_cgroup
and reducing atomic ops/complexity in memcg LRU handling.
In some cases, pages are added to lru before charge to memcg and pages
are not classfied to memory cgroup at lru addtion. Now, the lru where
the page should be added is determined a bit in page_cgroup->flags and
pc->mem_cgroup. I'd like to remove the check of flag.
To handle the case pc->mem_cgroup may contain stale pointers if pages
are added to LRU before classification. This patch resets
pc->mem_cgroup to root_mem_cgroup before lru additions.
[akpm@linux-foundation.org: fix CONFIG_CGROUP_MEM_CONT=n build]
[hughd@google.com: fix CONFIG_CGROUP_MEM_RES_CTLR=y CONFIG_CGROUP_MEM_RES_CTLR_SWAP=n build]
[akpm@linux-foundation.org: ksm.c needs memcontrol.h, per Michal]
[hughd@google.com: stop oops in mem_cgroup_reset_owner()]
[hughd@google.com: fix page migration to reset_owner]
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Miklos Szeredi <mszeredi@suse.cz>
Acked-by: Michal Hocko <mhocko@suse.cz>
test_set_oom_score_adj() was introduced in 72788c385604 ("oom: replace
PF_OOM_ORIGIN with toggling oom_score_adj") to temporarily elevate
current's oom_score_adj for ksm and swapoff without requiring an
additional per-process flag.
Using that function to both set oom_score_adj to OOM_SCORE_ADJ_MAX and
then reinstate the previous value is racy since it's possible that
userspace can set the value to something else itself before the old value
is reinstated. That results in userspace setting current's oom_score_adj
to a different value and then the kernel immediately setting it back to
its previous value without notification.
To fix this, a new compare_swap_oom_score_adj() function is introduced
with the same semantics as the compare and swap CAS instruction, or
CMPXCHG on x86. It is used to reinstate the previous value of
oom_score_adj if and only if the present value is the same as the old
value.
Andrea Righi reported a case where an exiting task can race against
ksmd::scan_get_next_rmap_item (http://lkml.org/lkml/2011/6/1/742) easily
triggering a NULL pointer dereference in ksmd.
ksm_scan.mm_slot == &ksm_mm_head with only one registered mm
CPU 1 (__ksm_exit) CPU 2 (scan_get_next_rmap_item)
list_empty() is false
lock slot == &ksm_mm_head
list_del(slot->mm_list)
(list now empty)
unlock
lock
slot = list_entry(slot->mm_list.next)
(list is empty, so slot is still ksm_mm_head)
unlock
slot->mm == NULL ... Oops
Close this race by revalidating that the new slot is not simply the list
head again.
Andrea's test case:
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <sys/mman.h>
#define BUFSIZE getpagesize()
int main(int argc, char **argv)
void *ptr;
if (posix_memalign(&ptr, getpagesize(), BUFSIZE) < 0) {
perror("posix_memalign");
exit(1);
if (madvise(ptr, BUFSIZE, MADV_MERGEABLE) < 0) {
perror("madvise");
exit(1);
*(char *)NULL = 0;
return 0;
Reported-by: Andrea Righi <andrea@betterlinux.com>
Tested-by: Andrea Righi <andrea@betterlinux.com>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Cc: <stable@kernel.org>
There's a kernel-wide shortage of per-process flags, so it's always
helpful to trim one when possible without incurring a significant penalty.
It's even more important when you're planning on adding a per- process
flag yourself, which I plan to do shortly for transparent hugepages.
PF_OOM_ORIGIN is used by ksm and swapoff to prefer current since it has a
tendency to allocate large amounts of memory and should be preferred for
killing over other tasks. We'd rather immediately kill the task making
the errant syscall rather than penalizing an innocent task.
This patch removes PF_OOM_ORIGIN since its behavior is equivalent to
setting the process's oom_score_adj to OOM_SCORE_ADJ_MAX.
The process's old oom_score_adj is stored and then set to
OOM_SCORE_ADJ_MAX during the time it used to have PF_OOM_ORIGIN. The old
value is then reinstated when the process should no longer be considered a
high priority for oom killing.
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
Cc: Izik Eidus <ieidus@redhat.com>
The normal code pattern used in the kernel is: get/put.
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
It was hard to explain the page counts which were causing new LTP tests
of KSM to fail: we need to drain the per-cpu pagevecs to LRU occasionally.
Reported-by: CAI Qian <caiqian@redhat.com>
Cc:Andrea Arcangeli <aarcange@redhat.com>
Cleanup some code with common compound_trans_head helper.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Johannes Weiner <jweiner@redhat.com>
This makes KSM full operational with THP pages. Subpages are scanned
while the hugepage is still in place and delivering max cpu performance,
and only if there's a match and we're going to deduplicate memory, the
single hugepages with the subpage match is split.
There will be no false sharing between ksmd and khugepaged. khugepaged
won't collapse 2m virtual regions with KSM pages inside. ksmd also should
only split pages when the checksum matches and we're likely to split an
hugepage for some long living ksm page (usual ksm heuristic to avoid
sharing pages that get de-cowed).
It's unclear why schedule friendly kernel threads can't be taken away by
the CPU through the scheduler itself. It's safer to stop them as they can
trigger memory allocation, if kswapd also freezes itself to avoid
generating I/O they have too.
Skip transhuge pages in ksm for now.
When a swapcache page is replaced by a ksm page, it's best to free that
swap immediately.
Reported-by: Andrea Arcangeli <aarcange@redhat.com>
commit 62b61f611e ("ksm: memory hotremove migration only") caused the
following new lockdep warning.
[ INFO: possible circular locking dependency detected ]
bash/1621 is trying to acquire lock:
((memory_chain).rwsem){.+.+.+}, at: [<ffffffff81079339>]
__blocking_notifier_call_chain+0x69/0xc0
but task is already holding lock:
(ksm_thread_mutex){+.+.+.}, at: [<ffffffff8113a3aa>]
ksm_memory_callback+0x3a/0xc0
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (ksm_thread_mutex){+.+.+.}:
[<ffffffff8108b70a>] lock_acquire+0xaa/0x140
[<ffffffff81505d74>] __mutex_lock_common+0x44/0x3f0
[<ffffffff81506228>] mutex_lock_nested+0x48/0x60
[<ffffffff8113a3aa>] ksm_memory_callback+0x3a/0xc0
[<ffffffff8150c21c>] notifier_call_chain+0x8c/0xe0
[<ffffffff8107934e>] __blocking_notifier_call_chain+0x7e/0xc0
[<ffffffff810793a6>] blocking_notifier_call_chain+0x16/0x20
[<ffffffff813afbfb>] memory_notify+0x1b/0x20
[<ffffffff81141b7c>] remove_memory+0x1cc/0x5f0
[<ffffffff813af53d>] memory_block_change_state+0xfd/0x1a0
[<ffffffff813afd62>] store_mem_state+0xe2/0xf0
[<ffffffff813a0bb0>] sysdev_store+0x20/0x30
[<ffffffff811bc116>] sysfs_write_file+0xe6/0x170
[<ffffffff8114f398>] vfs_write+0xc8/0x190
[<ffffffff8114fc14>] sys_write+0x54/0x90
[<ffffffff810028b2>] system_call_fastpath+0x16/0x1b
-> #0 ((memory_chain).rwsem){.+.+.+}:
[<ffffffff8108b5ba>] __lock_acquire+0x155a/0x1600
[<ffffffff81506601>] down_read+0x51/0xa0
[<ffffffff81079339>] __blocking_notifier_call_chain+0x69/0xc0
[<ffffffff81141f1e>] remove_memory+0x56e/0x5f0
But it's a false positive. Both memory_chain.rwsem and ksm_thread_mutex
have an outer lock (mem_hotplug_mutex). So they cannot deadlock.
Thus, This patch annotate ksm_thread_mutex is not deadlock source.
[akpm@linux-foundation.org: update comment, from Hugh]
Building under memory pressure, with KSM on 2.6.36-rc5, collapsed with
an internal compiler error: typically indicating an error in swapping.
Perhaps there's a timing issue which makes it now more likely, perhaps
it's just a long time since I tried for so long: this bug goes back to
KSM swapping in 2.6.33.
Notice how reuse_swap_page() allows an exclusive page to be reused, but
only does SetPageDirty if it can delete it from swap cache right then -
if it's currently under Writeback, it has to be left in cache and we
don't SetPageDirty, but the page can be reused. Fine, the dirty bit
will get set in the pte; but notice how zap_pte_range() does not bother
to transfer pte_dirty to page_dirty when unmapping a PageAnon.
If KSM chooses to share such a page, it will look like a clean copy of
swapcache, and not be written out to swap when its memory is needed;
then stale data read back from swap when it's needed again.
We could fix this in reuse_swap_page() (or even refuse to reuse a
page under writeback), but it's more honest to fix my oversight in
KSM's write_protect_page(). Several days of testing on three machines
confirms that this fixes the issue they showed.
Cc: stable@kernel.org
The pte_same check is reliable only if the swap entry remains pinned (by
the page lock on swapcache). We've also to ensure the swapcache isn't
removed before we take the lock as try_to_free_swap won't care about the
page pin.
One of the possible impacts of this patch is that a KSM-shared page can
point to the anon_vma of another process, which could exit before the page
is freed.
This can leave a page with a pointer to a recycled anon_vma object, or
worse, a pointer to something that is no longer an anon_vma.
[riel@redhat.com: changelog help]
Use compile-allocated memory instead of dynamic allocated memory for
mm_slots_hash.
Use hash_ptr() instead divisions for bucket calculation.
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Signed-off-by: Izik Eidus <ieidus@redhat.com>
