path: root/mm/madvise.c
2005-10-11[PATCH] madvise: Avoid returning error code -EBADF for anonymous mappingsSuzuki
Revert this recent correctness change: Douglas Crosher <dcrosher@scieneer.com> reported that it broke an existing application, and that madvise() works without error on anonymous mappings on Solaris. This means that madvise() will remain non-standards-compliant: we should return -EBADF for all requests against non-file-backed vma's, but Linux only does this for MADV_WILLNEED requests. Signed-off-by: Suzuki K P <suzuki@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mm: fix madvise vma mergingHugh Dickins
Better late than never, I've at last reviewed the madvise vma merging going into 2.6.13. Remove a pointless check and fix two little bugs - a simple test (with /proc/<pid>/maps hacked to show ReadHints) showed both mismerges in practice: though being madvise, neither was disastrous. 1. Correct placement of the success label in madvise_behavior: as in mprotect_fixup and mlock_fixup, it is necessary to update vm_flags when vma_merge succeeds (to handle the exceptional Case 8 noted in the comments above vma_merge itself). 2. Correct initial value of prev when starting part way into a vma: as in sys_mprotect and do_mlock, it needs to be set to vma in this case (vma_merge handles only that minimum of cases shown in its comments). 3. If find_vma_prev sets prev, then the vma it returns is prev->vm_next, so it's pointless to make that same assignment again in sys_madvise. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] madvise() does not always return -EBADF on non-file mapped areasuzuki
The madvise() system call returns -EBADF for areas which does not map to files, only for *behaviour* request MADV_WILLNEED. According to man pages, madvise returns : EBADF - the map exists, but the area maps something that isn't a file. Fixes bug 2995. Signed-off-by: Suzuki K P <suzuki@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] xip: madvice/fadvice: execute in placeCarsten Otte
Make sys_madvice/fadvice return sane with xip. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] remove redundant vm_flags clearing from madvise.cPekka Enberg
This patch removes redundant VM_ClearReadHint from mm/madvice.c which was left there by Prasanna's patch. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] madvise: merge the mapsPrasanna Meda
This attempts to merge back the split maps. This code is mostly copied from Chrisw's mlock merging from post 2.6.11 trees. The only difference is in munmapped_error handling. Also passed prev to willneed/dontneed, eventhogh they do not handle it now, since I felt it will be cleaner, instead of handling prev in madvise_vma in some cases and in subfunction in some cases. Signed-off-by: Prasanna Meda <pmeda@akamai.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] madvise: do not split the mapsPrasanna Meda
This attempts to avoid splittings when it is not needed, that is when vm_flags are same as new flags. The idea is from the <2.6.11 mlock_fixup and others. This will provide base for the next madvise merging patch. Signed-off-by: Prasanna Meda <pmeda@akamai.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
