path: root/mm/madvise.c
2012-07-06mm: Hold a file reference in madvise_removeAndy Lutomirski
Otherwise the code races with munmap (causing a use-after-free of the vma) or with close (causing a use-after-free of the struct file). The bug was introduced by commit 90ed52ebe481 ("[PATCH] holepunch: fix mmap_sem i_mutex deadlock") Cc: Hugh Dickins <hugh@veritas.com> Cc: Miklos Szeredi <mszeredi@suse.cz> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Nick Piggin <npiggin@suse.de> Cc: stable@vger.kernel.org Signed-off-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm/fs: route MADV_REMOVE to FALLOC_FL_PUNCH_HOLEHugh Dickins
Now tmpfs supports hole-punching via fallocate(), switch madvise_remove() to use do_fallocate() instead of vmtruncate_range(): which extends madvise(,,MADV_REMOVE) support from tmpfs to ext4, ocfs2 and xfs. There is one more user of vmtruncate_range() in our tree, staging/android's ashmem_shrink(): convert it to use do_fallocate() too (but if its unpinned areas are already unmapped - I don't know - then it would do better to use shmem_truncate_range() directly). Based-on-patch-by: Cong Wang <amwang@redhat.com> Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Colin Cross <ccross@android.com> Cc: John Stultz <john.stultz@linaro.org> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Andreas Dilger <adilger@dilger.ca> Cc: Mark Fasheh <mfasheh@suse.de> Cc: Joel Becker <jlbec@evilplan.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Ben Myers <bpm@sgi.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23coredump: add VM_NODUMP, MADV_NODUMP, MADV_CLEAR_NODUMPJason Baron
Since we no longer need the VM_ALWAYSDUMP flag, let's use the freed bit for 'VM_NODUMP' flag. The idea is is to add a new madvise() flag: MADV_DONTDUMP, which can be set by applications to specifically request memory regions which should not dump core. The specific application I have in mind is qemu: we can add a flag there that wouldn't dump all of guest memory when qemu dumps core. This flag might also be useful for security sensitive apps that want to absolutely make sure that parts of memory are not dumped. To clear the flag use: MADV_DODUMP. [akpm@linux-foundation.org: s/MADV_NODUMP/MADV_DONTDUMP/, s/MADV_CLEAR_NODUMP/MADV_DODUMP/, per Roland] [akpm@linux-foundation.org: fix up the architectures which broke] Signed-off-by: Jason Baron <jbaron@redhat.com> Acked-by: Roland McGrath <roland@hack.frob.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Avi Kivity <avi@redhat.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-03HWPOISON: Clean up memory_failure() vs. __memory_failure()Tony Luck
There is only one caller of memory_failure(), all other users call __memory_failure() and pass in the flags argument explicitly. The lone user of memory_failure() will soon need to pass flags too. Add flags argument to the callsite in mce.c. Delete the old memory_failure() function, and then rename __memory_failure() without the leading "__". Provide clearer message when action optional memory errors are ignored. Acked-by: Borislav Petkov <bp@amd64.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-07-20fs: kill i_alloc_semChristoph Hellwig
i_alloc_sem is a rather special rw_semaphore. It's the last one that may be released by a non-owner, and it's write side is always mirrored by real exclusion. It's intended use it to wait for all pending direct I/O requests to finish before starting a truncate. Replace it with a hand-grown construct: - exclusion for truncates is already guaranteed by i_mutex, so it can simply fall way - the reader side is replaced by an i_dio_count member in struct inode that counts the number of pending direct I/O requests. Truncate can't proceed as long as it's non-zero - when i_dio_count reaches non-zero we wake up a pending truncate using wake_up_bit on a new bit in i_flags - new references to i_dio_count can't appear while we are waiting for it to read zero because the direct I/O count always needs i_mutex (or an equivalent like XFS's i_iolock) for starting a new operation. This scheme is much simpler, and saves the space of a spinlock_t and a struct list_head in struct inode (typically 160 bits on a non-debug 64-bit system). Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-13thp: khugepaged: make khugepaged aware about madviseAndrea Arcangeli
MADV_HUGEPAGE and MADV_NOHUGEPAGE were fully effective only if run after mmap and before touching the memory. While this is enough for most usages, it's little effort to make madvise more dynamic at runtime on an existing mapping by making khugepaged aware about madvise. MADV_HUGEPAGE: register in khugepaged immediately without waiting a page fault (that may not ever happen if all pages are already mapped and the "enabled" knob was set to madvise during the initial page faults). MADV_NOHUGEPAGE: skip vmas marked VM_NOHUGEPAGE in khugepaged to stop collapsing pages where not needed. [akpm@linux-foundation.org: tweak comment] Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: madvise(MADV_NOHUGEPAGE)Andrea Arcangeli
Add madvise MADV_NOHUGEPAGE to mark regions that are not important to be hugepage backed. Return -EINVAL if the vma is not of an anonymous type, or the feature isn't built into the kernel. Never silently return success. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: madvise(MADV_HUGEPAGE)Andrea Arcangeli
Add madvise MADV_HUGEPAGE to mark regions that are important to be hugepage backed. Return -EINVAL if the vma is not of an anonymous type, or the feature isn't built into the kernel. Never silently return success. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16HWPOISON: Add a madvise() injector for soft page offliningAndi Kleen
Process based injection is much easier to handle for test programs, who can first bring a page into a specific state and then test. So add a new MADV_SOFT_OFFLINE to soft offline a page, similar to the existing hard offline injector. Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-12-16HWPOISON: Use get_user_page_fast in hwpoison madviseAndi Kleen
The previous version didn't take the mmap_sem before calling gup(), which is racy. Use get_user_pages_fast() instead which doesn't need any locks. This is also faster of course, but then it doesn't really matter because this is just a testing path. Based on report from Nick Piggin. Cc: npiggin@suse.de Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-12-16HWPOISON: Turn ref argument into flags argumentAndi Kleen
Now that "ref" is just a boolean turn it into a flags argument. First step is only a single flag that makes the code's intention more clear, but more may follow. Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-12-16HWPOISON: avoid grabbing the page count multiple times during madvise injectionWu Fengguang
If page is double referenced in madvise_hwpoison() and __memory_failure(), remove_mapping() will fail because it expects page_count=2. Fix it by not grabbing extra page count in __memory_failure(). Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-09-24Merge branch 'hwpoison' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6 * 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: (21 commits) HWPOISON: Enable error_remove_page on btrfs HWPOISON: Add simple debugfs interface to inject hwpoison on arbitary PFNs HWPOISON: Add madvise() based injector for hardware poisoned pages v4 HWPOISON: Enable error_remove_page for NFS HWPOISON: Enable .remove_error_page for migration aware file systems HWPOISON: The high level memory error handler in the VM v7 HWPOISON: Add PR_MCE_KILL prctl to control early kill behaviour per process HWPOISON: shmem: call set_page_dirty() with locked page HWPOISON: Define a new error_remove_page address space op for async truncation HWPOISON: Add invalidate_inode_page HWPOISON: Refactor truncate to allow direct truncating of page v2 HWPOISON: check and isolate corrupted free pages v2 HWPOISON: Handle hardware poisoned pages in try_to_unmap HWPOISON: Use bitmask/action code for try_to_unmap behaviour HWPOISON: x86: Add VM_FAULT_HWPOISON handling to x86 page fault handler v2 HWPOISON: Add poison check to page fault handling HWPOISON: Add basic support for poisoned pages in fault handler v3 HWPOISON: Add new SIGBUS error codes for hardware poison signals HWPOISON: Add support for poison swap entries v2 HWPOISON: Export some rmap vma locking to outside world ...
2009-09-22ksm: the mm interface to ksmHugh Dickins
This patch presents the mm interface to a dummy version of ksm.c, for better scrutiny of that interface: the real ksm.c follows later. When CONFIG_KSM is not set, madvise(2) reject MADV_MERGEABLE and MADV_UNMERGEABLE with EINVAL, since that seems more helpful than pretending that they can be serviced. But when CONFIG_KSM=y, accept them even if KSM is not currently running, and even on areas which KSM will not touch (e.g. hugetlb or shared file or special driver mappings). Like other madvices, report ENOMEM despite success if any area in the range is unmapped, and use EAGAIN to report out of memory. Define vma flag VM_MERGEABLE to identify an area on which KSM may try merging pages: leave it to ksm_madvise() to decide whether to set it. Define mm flag MMF_VM_MERGEABLE to identify an mm which might contain VM_MERGEABLE areas, to minimize callouts when forking or exiting. Based upon earlier patches by Chris Wright and Izik Eidus. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Chris Wright <chrisw@redhat.com> Signed-off-by: Izik Eidus <ieidus@redhat.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Avi Kivity <avi@redhat.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22ksm: first tidy up madvise_vma()Hugh Dickins
madvise.c has several levels of switch statements, what to do in which? Move MADV_DOFORK code down from madvise_vma() to madvise_behavior(), so madvise_vma() can be a simple router, to madvise_behavior() by default. vma->vm_flags is an unsigned long so use the same type for new_flags. Add missing comment lines to describe MADV_DONTFORK and MADV_DOFORK. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Chris Wright <chrisw@redhat.com> Signed-off-by: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Avi Kivity <avi@redhat.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-16HWPOISON: Add madvise() based injector for hardware poisoned pages v4Andi Kleen
Impact: optional, useful for debugging Add a new madvice sub command to inject poison for some pages in a process' address space. This is useful for testing the poison page handling. This patch can allow root to tie up large amounts of memory. I got feedback from container developers and they didn't see any problem. v2: Use write flag for get_user_pages to make sure to always get a fresh page v3: Don't request write mapping (Fengguang Wu) v4: Move MADV_* number to avoid conflict with KSM (Hugh Dickins) Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-06-16mm: madvise(): correct return codeNick Piggin
The posix_madvise() function succeeds (and does nothing) when called with parameters (NULL, 0, -1); according to LSB tests, it should fail with EINVAL because -1 is not a valid flag. When called with a valid address and size, it correctly fails. So perform an initial check for valid flags first. Reported-by: Jiri Dluhos <jdluhos@novell.com> Signed-off-by: Nick Piggin <npiggin@suse.de> Reviewed-and-Tested-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16readahead: move max_sane_readahead() calls into force_page_cache_readahead()Wu Fengguang
Impact: code simplification. Cc: Nick Piggin <npiggin@suse.de> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-13Revert "Ignore madvise(MADV_WILLNEED) for hugetlbfs-backed regions"Linus Torvalds
This reverts commit a425a638c858fd10370b573bde81df3ba500e271. Now that the previous commit removed the "readpage" actor for hugetlb files, read-ahead will no longer mess up the mapping, and there's no longer any reason to treat hugetlbfs mappings specially. Tested-and-acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-05Ignore madvise(MADV_WILLNEED) for hugetlbfs-backed regionsMel Gorman
madvise(MADV_WILLNEED) forces page cache readahead on a range of memory backed by a file. The assumption is made that the page required is order-0 and "normal" page cache. On hugetlbfs, this assumption is not true and order-0 pages are allocated and inserted into the hugetlbfs page cache. This leaks hugetlbfs page reservations and can cause BUGs to trigger related to corrupted page tables. This patch causes MADV_WILLNEED to be ignored for hugetlbfs-backed regions. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-14[CVE-2009-0029] System call wrappers part 14Heiko Carstens
2008-07-30madvise: update function comment of madvise_dontneedFernando Luis Vazquez Cao
Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28xip: support non-struct page backed memoryNick Piggin
Convert XIP to support non-struct page backed memory, using VM_MIXEDMAP for the user mappings. This requires the get_xip_page API to be changed to an address based one. Improve the API layering a little bit too, while we're here. This is required in order to support XIP filesystems on memory that isn't backed with struct page (but memory with struct page is still supported too). Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Carsten Otte <cotte@de.ibm.com> Cc: Jared Hulbert <jaredeh@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16speed up madvise_need_mmap_write() usageJason Baron
In the new madvise_need_mmap_write() call we can avoid an extra case statement and function call as follows. Signed-off-by: Jason Baron <jbaron@redhat.com> Cc: Nishanth Aravamudan <nacc@us.ibm.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07mm: madvise avoid exclusive mmap_semNick Piggin
Avoid down_write of the mmap_sem in madvise when we can help it. Acked-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-29[PATCH] holepunch: fix mmap_sem i_mutex deadlockHugh Dickins
sys_madvise has down_write of mmap_sem, then madvise_remove calls vmtruncate_range which takes i_mutex and i_alloc_sem: no, we can easily devise deadlocks from that ordering. madvise_remove drop mmap_sem while calling vmtruncate_range: luckily, since madvise_remove doesn't split or merge vmas, it's easy to handle this case with a NULL prev, without restructuring sys_madvise. (Though sad to retake mmap_sem when it's unlikely to be needed, and certainly down_read is sufficient for MADV_REMOVE, unlike the other madvices.) Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Miklos Szeredi <mszeredi@suse.cz> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-16[PATCH] mm: fix madvise infinine loopNick Piggin
madvise(MADV_REMOVE) can go into an infinite loop or cause an oops if the call covers a region from the start of a vma, and extending past that vma. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Badari Pulavarty <pbadari@us.ibm.com> Acked-by: Hugh Dickins <hugh@veritas.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-04-17[PATCH] Fix MADV_REMOVE protection checkingHugh Dickins
madvise_remove needs to respect file and mmap protections. Signed-off-by: Hugh Dickins <hugh@veritas.com> [ Will the real CVE-2006-1524 stand up, please.. ] Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-14[PATCH] madvise MADV_DONTFORK/MADV_DOFORKMichael S. Tsirkin
Currently, copy-on-write may change the physical address of a page even if the user requested that the page is pinned in memory (either by mlock or by get_user_pages). This happens if the process forks meanwhile, and the parent writes to that page. As a result, the page is orphaned: in case of get_user_pages, the application will never see any data hardware DMA's into this page after the COW. In case of mlock'd memory, the parent is not getting the realtime/security benefits of mlock. In particular, this affects the Infiniband modules which do DMA from and into user pages all the time. This patch adds madvise options to control whether memory range is inherited across fork. Useful e.g. for when hardware is doing DMA from/into these pages. Could also be useful to an application wanting to speed up its forks by cutting large areas out of consideration. Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Acked-by: Hugh Dickins <hugh@veritas.com> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] madvise(MADV_REMOVE): remove pages from tmpfs shm backing storeBadari Pulavarty
Here is the patch to implement madvise(MADV_REMOVE) - which frees up a given range of pages & its associated backing store. Current implementation supports only shmfs/tmpfs and other filesystems return -ENOSYS. "Some app allocates large tmpfs files, then when some task quits and some client disconnect, some memory can be released. However the only way to release tmpfs-swap is to MADV_REMOVE". - Andrea Arcangeli Databases want to use this feature to drop a section of their bufferpool (shared memory segments) - without writing back to disk/swap space. This feature is also useful for supporting hot-plug memory on UML. Concerns raised by Andrew Morton: - "We have no plan for holepunching! If we _do_ have such a plan (or might in the future) then what would the API look like? I think sys_holepunch(fd, start, len), so we should start out with that." - Using madvise is very weird, because people will ask "why do I need to mmap my file before I can stick a hole in it?" - None of the other madvise operations call into the filesystem in this manner. A broad question is: is this capability an MM operation or a filesytem operation? truncate, for example, is a filesystem operation which sometimes has MM side-effects. madvise is an mm operation and with this patch, it gains FS side-effects, only they're really, really significant ones." Comments: - Andrea suggested the fs operation too but then it's more efficient to have it as a mm operation with fs side effects, because they don't immediatly know fd and physical offset of the range. It's possible to fixup in userland and to use the fs operation but it's more expensive, the vmas are already in the kernel and we can use them. Short term plan & Future Direction: - We seem to need this interface only for shmfs/tmpfs files in the short term. We have to add hooks into the filesystem for correctness and completeness. This is what this patch does. - In the future, plan is to support both fs and mmap apis also. This also involves (other) filesystem specific functions to be implemented. - Current patch doesn't support VM_NONLINEAR - which can be addressed in the future. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Andrea Arcangeli <andrea@suse.de> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Cc: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-28mm: re-architect the VM_UNPAGED logicLinus Torvalds
This replaces the (in my opinion horrible) VM_UNMAPPED logic with very explicit support for a "remapped page range" aka VM_PFNMAP. It allows a VM area to contain an arbitrary range of page table entries that the VM never touches, and never considers to be normal pages. Any user of "remap_pfn_range()" automatically gets this new functionality, and doesn't even have to mark the pages reserved or indeed mark them any other way. It just works. As a side effect, doing mmap() on /dev/mem works for arbitrary ranges. Sparc update from David in the next commit. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-22[PATCH] unpaged: VM_UNPAGEDHugh Dickins
Although we tend to associate VM_RESERVED with remap_pfn_range, quite a few drivers set VM_RESERVED on areas which are then populated by nopage. The PageReserved removal in 2.6.15-rc1 changed VM_RESERVED not to free pages in zap_pte_range, without changing those drivers not to set it: so their pages just leak away. Let's not change miscellaneous drivers now: introduce VM_UNPAGED at the core, to flag the special areas where the ptes may have no struct page, or if they have then it's not to be touched. Replace most instances of VM_RESERVED in core mm by VM_UNPAGED. Force it on in remap_pfn_range, and the sparc and sparc64 io_remap_pfn_range. Revert addition of VM_RESERVED to powerpc vdso, it's not needed there. Is it needed anywhere? It still governs the mm->reserved_vm statistic, and special vmas not to be merged, and areas not to be core dumped; but could probably be eliminated later (the drivers are probably specifying it because in 2.4 it kept swapout off the vma, but in 2.6 we work from the LRU, which these pages don't get on). Use the VM_SHM slot for VM_UNPAGED, and define VM_SHM to 0: it serves no purpose whatsoever, and should be removed from drivers when we clean up. Signed-off-by: Hugh Dickins <hugh@veritas.com> Acked-by: William Irwin <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] core remove PageReservedNick Piggin
Remove PageReserved() calls from core code by tightening VM_RESERVED handling in mm/ to cover PageReserved functionality. PageReserved special casing is removed from get_page and put_page. All setting and clearing of PageReserved is retained, and it is now flagged in the page_alloc checks to help ensure we don't introduce any refcount based freeing of Reserved pages. MAP_PRIVATE, PROT_WRITE of VM_RESERVED regions is tentatively being deprecated. We never completely handled it correctly anyway, and is be reintroduced in future if required (Hugh has a proof of concept). Once PageReserved() calls are removed from kernel/power/swsusp.c, and all arch/ and driver code, the Set and Clear calls, and the PG_reserved bit can be trivially removed. Last real user of PageReserved is swsusp, which uses PageReserved to determine whether a struct page points to valid memory or not. This still needs to be addressed (a generic page_is_ram() should work). A last caveat: the ZERO_PAGE is now refcounted and managed with rmap (and thus mapcounted and count towards shared rss). These writes to the struct page could cause excessive cacheline bouncing on big systems. There are a number of ways this could be addressed if it is an issue. Signed-off-by: Nick Piggin <npiggin@suse.de> Refcount bug fix for filemap_xip.c Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-11[PATCH] madvise: Avoid returning error code -EBADF for anonymous mappingsSuzuki
Revert this recent correctness change: Douglas Crosher <dcrosher@scieneer.com> reported that it broke an existing application, and that madvise() works without error on anonymous mappings on Solaris. This means that madvise() will remain non-standards-compliant: we should return -EBADF for all requests against non-file-backed vma's, but Linux only does this for MADV_WILLNEED requests. Signed-off-by: Suzuki K P <suzuki@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mm: fix madvise vma mergingHugh Dickins
Better late than never, I've at last reviewed the madvise vma merging going into 2.6.13. Remove a pointless check and fix two little bugs - a simple test (with /proc/<pid>/maps hacked to show ReadHints) showed both mismerges in practice: though being madvise, neither was disastrous. 1. Correct placement of the success label in madvise_behavior: as in mprotect_fixup and mlock_fixup, it is necessary to update vm_flags when vma_merge succeeds (to handle the exceptional Case 8 noted in the comments above vma_merge itself). 2. Correct initial value of prev when starting part way into a vma: as in sys_mprotect and do_mlock, it needs to be set to vma in this case (vma_merge handles only that minimum of cases shown in its comments). 3. If find_vma_prev sets prev, then the vma it returns is prev->vm_next, so it's pointless to make that same assignment again in sys_madvise. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] madvise() does not always return -EBADF on non-file mapped areasuzuki
The madvise() system call returns -EBADF for areas which does not map to files, only for *behaviour* request MADV_WILLNEED. According to man pages, madvise returns : EBADF - the map exists, but the area maps something that isn't a file. Fixes bug 2995. Signed-off-by: Suzuki K P <suzuki@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] xip: madvice/fadvice: execute in placeCarsten Otte
Make sys_madvice/fadvice return sane with xip. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] remove redundant vm_flags clearing from madvise.cPekka Enberg
This patch removes redundant VM_ClearReadHint from mm/madvice.c which was left there by Prasanna's patch. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] madvise: merge the mapsPrasanna Meda
This attempts to merge back the split maps. This code is mostly copied from Chrisw's mlock merging from post 2.6.11 trees. The only difference is in munmapped_error handling. Also passed prev to willneed/dontneed, eventhogh they do not handle it now, since I felt it will be cleaner, instead of handling prev in madvise_vma in some cases and in subfunction in some cases. Signed-off-by: Prasanna Meda <pmeda@akamai.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] madvise: do not split the mapsPrasanna Meda
This attempts to avoid splittings when it is not needed, that is when vm_flags are same as new flags. The idea is from the <2.6.11 mlock_fixup and others. This will provide base for the next madvise merging patch. Signed-off-by: Prasanna Meda <pmeda@akamai.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
