path: root/mm/memcontrol.c
2011-09-14memcg: Revert "memcg: add memory.vmscan_stat"Johannes Weiner
Revert the post-3.0 commit 82f9d486e59f5 ("memcg: add memory.vmscan_stat"). The implementation of per-memcg reclaim statistics violates how memcg hierarchies usually behave: hierarchically. The reclaim statistics are accounted to child memcgs and the parent hitting the limit, but not to hierarchy levels in between. Usually, hierarchical statistics are perfectly recursive, with each level representing the sum of itself and all its children. Since this exports statistics to userspace, this may lead to confusion and problems with changing things after the release, so revert it now, we can try again later. Signed-off-by: Johannes Weiner <jweiner@redhat.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Michal Hocko <mhocko@suse.cz> Cc: Ying Han <yinghan@google.com> Cc: Balbir Singh <bsingharora@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-25memcg: fix hierarchical oom lockingJohannes Weiner
Commit 79dfdaccd1d5 ("memcg: make oom_lock 0 and 1 based rather than counter") tried to oom lock the hierarchy and roll back upon encountering an already locked memcg. The code is confused when it comes to detecting a locked memcg, though, so it would fail and rollback after locking one memcg and encountering an unlocked second one. The result is that oom-locking hierarchies fails unconditionally and that every oom killer invocation simply goes to sleep on the oom waitqueue forever. The tasks practically hang forever without anyone intervening, possibly holding locks that trip up unrelated tasks, too. Signed-off-by: Johannes Weiner <jweiner@redhat.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-25memcg: pin execution to current cpu while draining stockJohannes Weiner
Commit d1a05b6973c7 ("memcg do not try to drain per-cpu caches without pages") added a drain_local_stock() call to a preemptible section. The draining task looks up the cpu-local stock twice to set the draining-flag, then to drain the stock and clear the flag again. If the task is migrated to a different CPU in between, noone will clear the flag on the first stock and it will be forever undrainable. Its charge can not be recovered and the cgroup can not be deleted anymore. Properly pin the task to the executing CPU while draining stocks. Signed-off-by: Johannes Weiner <jweiner@redhat.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com Acked-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-09Revert "memcg: get rid of percpu_charge_mutex lock"Michal Hocko
This reverts commit 8521fc50d433507a7cdc96bec280f9e5888a54cc. The patch incorrectly assumes that using atomic FLUSHING_CACHED_CHARGE bit operations is sufficient but that is not true. Johannes Weiner has reported a crash during parallel memory cgroup removal: BUG: unable to handle kernel NULL pointer dereference at 0000000000000018 IP: [<ffffffff81083b70>] css_is_ancestor+0x20/0x70 Oops: 0000 [#1] PREEMPT SMP Pid: 19677, comm: rmdir Tainted: G W 3.0.0-mm1-00188-gf38d32b #35 ECS MCP61M-M3/MCP61M-M3 RIP: 0010:[<ffffffff81083b70>] css_is_ancestor+0x20/0x70 RSP: 0018:ffff880077b09c88 EFLAGS: 00010202 Process rmdir (pid: 19677, threadinfo ffff880077b08000, task ffff8800781bb310) Call Trace: [<ffffffff810feba3>] mem_cgroup_same_or_subtree+0x33/0x40 [<ffffffff810feccf>] drain_all_stock+0x11f/0x170 [<ffffffff81103211>] mem_cgroup_force_empty+0x231/0x6d0 [<ffffffff811036c4>] mem_cgroup_pre_destroy+0x14/0x20 [<ffffffff81080559>] cgroup_rmdir+0xb9/0x500 [<ffffffff81114d26>] vfs_rmdir+0x86/0xe0 [<ffffffff81114e7b>] do_rmdir+0xfb/0x110 [<ffffffff81114ea6>] sys_rmdir+0x16/0x20 [<ffffffff8154d76b>] system_call_fastpath+0x16/0x1b We are crashing because we try to dereference cached memcg when we are checking whether we should wait for draining on the cache. The cache is already cleaned up, though. There is also a theoretical chance that the cached memcg gets freed between we test for the FLUSHING_CACHED_CHARGE and dereference it in mem_cgroup_same_or_subtree: CPU0 CPU1 CPU2 mem=stock->cached stock->cached=NULL clear_bit test_and_set_bit test_bit() ... <preempted> mem_cgroup_destroy use after free The percpu_charge_mutex protected from this race because sync draining is exclusive. It is safer to revert now and come up with a more parallel implementation later. Signed-off-by: Michal Hocko <mhocko@suse.cz> Reported-by: Johannes Weiner <jweiner@redhat.com> Acked-by: Johannes Weiner <jweiner@redhat.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03tmpfs: convert mem_cgroup shmem to radix-swapHugh Dickins
Remove mem_cgroup_shmem_charge_fallback(): it was only required when we had to move swappage to filecache with GFP_NOWAIT. Remove the GFP_NOWAIT special case from mem_cgroup_cache_charge(), by moving its call out from shmem_add_to_page_cache() to two of thats three callers. But leave it doing mem_cgroup_uncharge_cache_page() on error: although asymmetrical, it's easier for all 3 callers to handle. These two changes would also be appropriate if anyone were to start using shmem_read_mapping_page_gfp() with GFP_NOWAIT. Remove mem_cgroup_get_shmem_target(): mc_handle_file_pte() can test radix_tree_exceptional_entry() to get what it needs for itself. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26memcg: get rid of percpu_charge_mutex lockMichal Hocko
percpu_charge_mutex protects from multiple simultaneous per-cpu charge caches draining because we might end up having too many work items. At least this was the case until commit 26fe61684449 ("memcg: fix percpu cached charge draining frequency") when we introduced a more targeted draining for async mode. Now that also sync draining is targeted we can safely remove mutex because we will not send more work than the current number of CPUs. FLUSHING_CACHED_CHARGE protects from sending the same work multiple times and stock->nr_pages == 0 protects from pointless sending a work if there is obviously nothing to be done. This is of course racy but we can live with it as the race window is really small (we would have to see FLUSHING_CACHED_CHARGE cleared while nr_pages would be still non-zero). The only remaining place where we can race is synchronous mode when we rely on FLUSHING_CACHED_CHARGE test which might have been set by other drainer on the same group but we should wait in that case as well. Signed-off-by: Michal Hocko <mhocko@suse.cz> Cc: Balbir Singh <bsingharora@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26memcg: add mem_cgroup_same_or_subtree() helperMichal Hocko
We are checking whether a given two groups are same or at least in the same subtree of a hierarchy at several places. Let's make a helper for it to make code easier to read. Signed-off-by: Michal Hocko <mhocko@suse.cz> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <bsingharora@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26memcg: unify sync and async per-cpu charge cache drainingMichal Hocko
Currently we have two ways how to drain per-CPU caches for charges. drain_all_stock_sync will synchronously drain all caches while drain_all_stock_async will asynchronously drain only those that refer to a given memory cgroup or its subtree in hierarchy. Targeted async draining has been introduced by 26fe6168 (memcg: fix percpu cached charge draining frequency) to reduce the cpu workers number. sync draining is currently triggered only from mem_cgroup_force_empty which is triggered only by userspace (mem_cgroup_force_empty_write) or when a cgroup is removed (mem_cgroup_pre_destroy). Although these are not usually frequent operations it still makes some sense to do targeted draining as well, especially if the box has many CPUs. This patch unifies both methods to use the single code (drain_all_stock) which relies on the original async implementation and just adds flush_work to wait on all caches that are still under work for the sync mode. We are using FLUSHING_CACHED_CHARGE bit check to prevent from waiting on a work that we haven't triggered. Please note that both sync and async functions are currently protected by percpu_charge_mutex so we cannot race with other drainers. Signed-off-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <bsingharora@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26memcg: do not try to drain per-cpu caches without pagesMichal Hocko
drain_all_stock_async tries to optimize a work to be done on the work queue by excluding any work for the current CPU because it assumes that the context we are called from already tried to charge from that cache and it's failed so it must be empty already. While the assumption is correct we can optimize it even more by checking the current number of pages in the cache. This will also reduce a work on other CPUs with an empty stock. For the current CPU we can simply call drain_local_stock rather than deferring it to the work queue. [kamezawa.hiroyu@jp.fujitsu.com: use drain_local_stock for current CPU optimization] Signed-off-by: Michal Hocko <mhocko@suse.cz> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26memcg: add memory.vmscan_statKAMEZAWA Hiroyuki
The commit log of 0ae5e89c60c9 ("memcg: count the soft_limit reclaim in...") says it adds scanning stats to memory.stat file. But it doesn't because we considered we needed to make a concensus for such new APIs. This patch is a trial to add memory.scan_stat. This shows - the number of scanned pages(total, anon, file) - the number of rotated pages(total, anon, file) - the number of freed pages(total, anon, file) - the number of elaplsed time (including sleep/pause time) for both of direct/soft reclaim. The biggest difference with oringinal Ying's one is that this file can be reset by some write, as # echo 0 ...../memory.scan_stat Example of output is here. This is a result after make -j 6 kernel under 300M limit. [kamezawa@bluextal ~]$ cat /cgroup/memory/A/memory.scan_stat [kamezawa@bluextal ~]$ cat /cgroup/memory/A/memory.vmscan_stat scanned_pages_by_limit 9471864 scanned_anon_pages_by_limit 6640629 scanned_file_pages_by_limit 2831235 rotated_pages_by_limit 4243974 rotated_anon_pages_by_limit 3971968 rotated_file_pages_by_limit 272006 freed_pages_by_limit 2318492 freed_anon_pages_by_limit 962052 freed_file_pages_by_limit 1356440 elapsed_ns_by_limit 351386416101 scanned_pages_by_system 0 scanned_anon_pages_by_system 0 scanned_file_pages_by_system 0 rotated_pages_by_system 0 rotated_anon_pages_by_system 0 rotated_file_pages_by_system 0 freed_pages_by_system 0 freed_anon_pages_by_system 0 freed_file_pages_by_system 0 elapsed_ns_by_system 0 scanned_pages_by_limit_under_hierarchy 9471864 scanned_anon_pages_by_limit_under_hierarchy 6640629 scanned_file_pages_by_limit_under_hierarchy 2831235 rotated_pages_by_limit_under_hierarchy 4243974 rotated_anon_pages_by_limit_under_hierarchy 3971968 rotated_file_pages_by_limit_under_hierarchy 272006 freed_pages_by_limit_under_hierarchy 2318492 freed_anon_pages_by_limit_under_hierarchy 962052 freed_file_pages_by_limit_under_hierarchy 1356440 elapsed_ns_by_limit_under_hierarchy 351386416101 scanned_pages_by_system_under_hierarchy 0 scanned_anon_pages_by_system_under_hierarchy 0 scanned_file_pages_by_system_under_hierarchy 0 rotated_pages_by_system_under_hierarchy 0 rotated_anon_pages_by_system_under_hierarchy 0 rotated_file_pages_by_system_under_hierarchy 0 freed_pages_by_system_under_hierarchy 0 freed_anon_pages_by_system_under_hierarchy 0 freed_file_pages_by_system_under_hierarchy 0 elapsed_ns_by_system_under_hierarchy 0 total_xxxx is for hierarchy management. This will be useful for further memcg developments and need to be developped before we do some complicated rework on LRU/softlimit management. This patch adds a new struct memcg_scanrecord into scan_control struct. sc->nr_scanned at el is not designed for exporting information. For example, nr_scanned is reset frequentrly and incremented +2 at scanning mapped pages. To avoid complexity, I added a new param in scan_control which is for exporting scanning score. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Michal Hocko <mhocko@suse.cz> Cc: Ying Han <yinghan@google.com> Cc: Andrew Bresticker <abrestic@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26memcg: fix behavior of mem_cgroup_resize_limit()Daisuke Nishimura
Commit 22a668d7c3ef ("memcg: fix behavior under memory.limit equals to memsw.limit") introduced "memsw_is_minimum" flag, which becomes true when mem_limit == memsw_limit. The flag is checked at the beginning of reclaim, and "noswap" is set if the flag is true, because using swap is meaningless in this case. This works well in most cases, but when we try to shrink mem_limit, which is the same as memsw_limit now, we might fail to shrink mem_limit because swap doesn't used. This patch fixes this behavior by: - check MEM_CGROUP_RECLAIM_SHRINK at the begining of reclaim - If it is set, don't set "noswap" flag even if memsw_is_minimum is true. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <bsingharora@gmail.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Ying Han <yinghan@google.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26memcg: change memcg_oom_mutex to spinlockMichal Hocko
memcg_oom_mutex is used to protect memcg OOM path and eventfd interface for oom_control. None of the critical sections which it protects sleep (eventfd_signal works from atomic context and the rest are simple linked list resp. oom_lock atomic operations). Mutex is also too heavyweight for those code paths because it triggers a lot of scheduling. It also makes makes convoying effects more visible when we have a big number of oom killing because we take the lock mutliple times during mem_cgroup_handle_oom so we have multiple places where many processes can sleep. Signed-off-by: Michal Hocko <mhocko@suse.cz> Cc: Balbir Singh <bsingharora@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26memcg: make oom_lock 0 and 1 based rather than counterMichal Hocko
Commit 867578cb ("memcg: fix oom kill behavior") introduced a oom_lock counter which is incremented by mem_cgroup_oom_lock when we are about to handle memcg OOM situation. mem_cgroup_handle_oom falls back to a sleep if oom_lock > 1 to prevent from multiple oom kills at the same time. The counter is then decremented by mem_cgroup_oom_unlock called from the same function. This works correctly but it can lead to serious starvations when we have many processes triggering OOM and many CPUs available for them (I have tested with 16 CPUs). Consider a process (call it A) which gets the oom_lock (the first one that got to mem_cgroup_handle_oom and grabbed memcg_oom_mutex) and other processes that are blocked on the mutex. While A releases the mutex and calls mem_cgroup_out_of_memory others will wake up (one after another) and increase the counter and fall into sleep (memcg_oom_waitq). Once A finishes mem_cgroup_out_of_memory it takes the mutex again and decreases oom_lock and wakes other tasks (if releasing memory by somebody else - e.g. killed process - hasn't done it yet). A testcase would look like: Assume malloc XXX is a program allocating XXX Megabytes of memory which touches all allocated pages in a tight loop # swapoff SWAP_DEVICE # cgcreate -g memory:A # cgset -r memory.oom_control=0 A # cgset -r memory.limit_in_bytes= 200M # for i in `seq 100` # do # cgexec -g memory:A malloc 10 & # done The main problem here is that all processes still race for the mutex and there is no guarantee that we will get counter back to 0 for those that got back to mem_cgroup_handle_oom. In the end the whole convoy in/decreases the counter but we do not get to 1 that would enable killing so nothing useful can be done. The time is basically unbounded because it highly depends on scheduling and ordering on mutex (I have seen this taking hours...). This patch replaces the counter by a simple {un}lock semantic. As mem_cgroup_oom_{un}lock works on the a subtree of a hierarchy we have to make sure that nobody else races with us which is guaranteed by the memcg_oom_mutex. We have to be careful while locking subtrees because we can encounter a subtree which is already locked: hierarchy: A / \ B \ /\ \ C D E B - C - D tree might be already locked. While we want to enable locking E subtree because OOM situations cannot influence each other we definitely do not want to allow locking A. Therefore we have to refuse lock if any subtree is already locked and clear up the lock for all nodes that have been set up to the failure point. On the other hand we have to make sure that the rest of the world will recognize that a group is under OOM even though it doesn't have a lock. Therefore we have to introduce under_oom variable which is incremented and decremented for the whole subtree when we enter resp. leave mem_cgroup_handle_oom. under_oom, unlike oom_lock, doesn't need be updated under memcg_oom_mutex because its users only check a single group and they use atomic operations for that. This can be checked easily by the following test case: # cgcreate -g memory:A # cgset -r memory.use_hierarchy=1 A # cgset -r memory.oom_control=1 A # cgset -r memory.limit_in_bytes= 100M # cgset -r memory.memsw.limit_in_bytes= 100M # cgcreate -g memory:A/B # cgset -r memory.oom_control=1 A/B # cgset -r memory.limit_in_bytes=20M # cgset -r memory.memsw.limit_in_bytes=20M # cgexec -g memory:A/B malloc 30 & #->this will be blocked by OOM of group B # cgexec -g memory:A malloc 80 & #->this will be blocked by OOM of group A While B gets oom_lock A will not get it. Both of them go into sleep and wait for an external action. We can make the limit higher for A to enforce waking it up # cgset -r memory.memsw.limit_in_bytes=300M A # cgset -r memory.limit_in_bytes=300M A malloc in A has to wake up even though it doesn't have oom_lock. Finally, the unlock path is very easy because we always unlock only the subtree we have locked previously while we always decrement under_oom. Signed-off-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <bsingharora@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26memcg: consolidate memory cgroup lru stat functionsKAMEZAWA Hiroyuki
In mm/memcontrol.c, there are many lru stat functions as.. mem_cgroup_zone_nr_lru_pages mem_cgroup_node_nr_file_lru_pages mem_cgroup_nr_file_lru_pages mem_cgroup_node_nr_anon_lru_pages mem_cgroup_nr_anon_lru_pages mem_cgroup_node_nr_unevictable_lru_pages mem_cgroup_nr_unevictable_lru_pages mem_cgroup_node_nr_lru_pages mem_cgroup_nr_lru_pages mem_cgroup_get_local_zonestat Some of them are under #ifdef MAX_NUMNODES >1 and others are not. This seems bad. This patch consolidates all functions into mem_cgroup_zone_nr_lru_pages() mem_cgroup_node_nr_lru_pages() mem_cgroup_nr_lru_pages() For these functions, "which LRU?" information is passed by a mask. example: mem_cgroup_nr_lru_pages(mem, BIT(LRU_ACTIVE_ANON)) And I added some macro as ALL_LRU, ALL_LRU_FILE, ALL_LRU_ANON. example: mem_cgroup_nr_lru_pages(mem, ALL_LRU) BTW, considering layout of NUMA memory placement of counters, this patch seems to be better. Now, when we gather all LRU information, we scan in following orer for_each_lru -> for_each_node -> for_each_zone. This means we'll touch cache lines in different node in turn. After patch, we'll scan for_each_node -> for_each_zone -> for_each_lru(mask) Then, we'll gather information in the same cacheline at once. [akpm@linux-foundation.org: fix warnigns, build error] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26memcg: export memory cgroup's swappiness with mem_cgroup_swappiness()KAMEZAWA Hiroyuki
Each memory cgroup has a 'swappiness' value which can be accessed by get_swappiness(memcg). The major user is try_to_free_mem_cgroup_pages() and swappiness is passed by argument. It's propagated by scan_control. get_swappiness() is a static function but some planned updates will need to get swappiness from files other than memcontrol.c This patch exports get_swappiness() as mem_cgroup_swappiness(). With this, we can remove the argument of swapiness from try_to_free... and drop swappiness from scan_control. only memcg uses it. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Ying Han <yinghan@google.com> Cc: Shaohua Li <shaohua.li@intel.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-08memcg: fix numa scan information update to be triggered by memory eventKAMEZAWA Hiroyuki
commit 889976dbcb12 ("memcg: reclaim memory from nodes in round-robin order") adds an numa node round-robin for memcg. But the information is updated once per 10sec. This patch changes the update trigger from jiffies to memcg's event count. After this patch, numa scan information will be updated when we see 1024 events of pagein/pageout under a memcg. [akpm@linux-foundation.org: attempt to repair code layout] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Ying Han <yinghan@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-08memcg: fix reclaimable lru check in memcgKAMEZAWA Hiroyuki
Now, in mem_cgroup_hierarchical_reclaim(), mem_cgroup_local_usage() is used for checking whether the memcg contains reclaimable pages or not. If no pages in it, the routine skips it. But, mem_cgroup_local_usage() contains Unevictable pages and cannot handle "noswap" condition correctly. This doesn't work on a swapless system. This patch adds test_mem_cgroup_reclaimable() and replaces mem_cgroup_local_usage(). test_mem_cgroup_reclaimable() see LRU counter and returns correct answer to the caller. And this new function has "noswap" argument and can see only FILE LRU if necessary. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix kerneldoc layout] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Ying Han <yinghan@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27mm: move shmem prototypes to shmem_fs.hHugh Dickins
Before adding any more global entry points into shmem.c, gather such prototypes into shmem_fs.h. Remove mm's own declarations from swap.h, but for now leave the ones in mm.h: because shmem_file_setup() and shmem_zero_setup() are called from various places, and we should not force other subsystems to update immediately. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15memcg: avoid percpu cached charge draining at softlimitKAMEZAWA Hiroyuki
Based on Michal Hocko's comment. We are not draining per cpu cached charges during soft limit reclaim because background reclaim doesn't care about charges. It tries to free some memory and charges will not give any. Cached charges might influence only selection of the biggest soft limit offender but as the call is done only after the selection has been already done it makes no change. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Reviewed-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15memcg: fix percpu cached charge draining frequencyKAMEZAWA Hiroyuki
For performance, memory cgroup caches some "charge" from res_counter into per cpu cache. This works well but because it's cache, it needs to be flushed in some cases. Typical cases are 1. when someone hit limit. 2. when rmdir() is called and need to charges to be 0. But "1" has problem. Recently, with large SMP machines, we see many kworker runs because of flushing memcg's cache. Bad things in implementation are that even if a cpu contains a cache for memcg not related to a memcg which hits limit, drain code is called. This patch does A) check percpu cache contains a useful data or not. B) check other asynchronous percpu draining doesn't run. C) don't call local cpu callback. (*)This patch avoid changing the calling condition with hard-limit. When I run "cat 1Gfile > /dev/null" under 300M limit memcg, [Before] 13767 kamezawa 20 0 98.6m 424 416 D 10.0 0.0 0:00.61 cat 58 root 20 0 0 0 0 S 0.6 0.0 0:00.09 kworker/2:1 60 root 20 0 0 0 0 S 0.6 0.0 0:00.08 kworker/4:1 4 root 20 0 0 0 0 S 0.3 0.0 0:00.02 kworker/0:0 57 root 20 0 0 0 0 S 0.3 0.0 0:00.05 kworker/1:1 61 root 20 0 0 0 0 S 0.3 0.0 0:00.05 kworker/5:1 62 root 20 0 0 0 0 S 0.3 0.0 0:00.05 kworker/6:1 63 root 20 0 0 0 0 S 0.3 0.0 0:00.05 kworker/7:1 [After] 2676 root 20 0 98.6m 416 416 D 9.3 0.0 0:00.87 cat 2626 kamezawa 20 0 15192 1312 920 R 0.3 0.0 0:00.28 top 1 root 20 0 19384 1496 1204 S 0.0 0.0 0:00.66 init 2 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kthreadd 3 root 20 0 0 0 0 S 0.0 0.0 0:00.00 ksoftirqd/0 4 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kworker/0:0 [akpm@linux-foundation.org: make percpu_charge_mutex static, tweak comments] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Reviewed-by: Michal Hocko <mhocko@suse.cz> Tested-by: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15memcg: fix wrong check of noswap with softlimitKAMEZAWA Hiroyuki
Hierarchical reclaim doesn't swap out if memsw and resource limits are thye same (memsw_is_minimum == true) because we would hit mem+swap limit anyway (during hard limit reclaim). If it comes to the soft limit we shouldn't consider memsw_is_minimum at all because it doesn't make much sense. Either the soft limit is bellow the hard limit and then we cannot hit mem+swap limit or the direct reclaim takes a precedence. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15mm: memory.numa_stat: fix file permissionKAMEZAWA Hiroyuki
Commit 406eb0c9ba76 ("memcg: add memory.numastat api for numa statistics") adds memory.numa_stat file for memory cgroup. But the file permissions are wrong. [kamezawa@bluextal linux-2.6]$ ls -l /cgroup/memory/A/memory.numa_stat ---------- 1 root root 0 Jun 9 18:36 /cgroup/memory/A/memory.numa_stat This patch fixes the permission as [root@bluextal kamezawa]# ls -l /cgroup/memory/A/memory.numa_stat -r--r--r-- 1 root root 0 Jun 10 16:49 /cgroup/memory/A/memory.numa_stat Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15vmscan,memcg: memcg aware swap tokenKOSAKI Motohiro
Currently, memcg reclaim can disable swap token even if the swap token mm doesn't belong in its memory cgroup. It's slightly risky. If an admin creates very small mem-cgroup and silly guy runs contentious heavy memory pressure workload, every tasks are going to lose swap token and then system may become unresponsive. That's bad. This patch adds 'memcg' parameter into disable_swap_token(). and if the parameter doesn't match swap token, VM doesn't disable it. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Rik van Riel<riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26memcg: add the pagefault count into memcg statsYing Han
Two new stats in per-memcg memory.stat which tracks the number of page faults and number of major page faults. "pgfault" "pgmajfault" They are different from "pgpgin"/"pgpgout" stat which count number of pages charged/discharged to the cgroup and have no meaning of reading/ writing page to disk. It is valuable to track the two stats for both measuring application's performance as well as the efficiency of the kernel page reclaim path. Counting pagefaults per process is useful, but we also need the aggregated value since processes are monitored and controlled in cgroup basis in memcg. Functional test: check the total number of pgfault/pgmajfault of all memcgs and compare with global vmstat value: $ cat /proc/vmstat | grep fault pgfault 1070751 pgmajfault 553 $ cat /dev/cgroup/memory.stat | grep fault pgfault 1071138 pgmajfault 553 total_pgfault 1071142 total_pgmajfault 553 $ cat /dev/cgroup/A/memory.stat | grep fault pgfault 199 pgmajfault 0 total_pgfault 199 total_pgmajfault 0 Performance test: run page fault test(pft) wit 16 thread on faulting in 15G anon pages in 16G container. There is no regression noticed on the "flt/cpu/s" Sample output from pft: TAG pft:anon-sys-default: Gb Thr CLine User System Wall flt/cpu/s fault/wsec 15 16 1 0.67s 233.41s 14.76s 16798.546 266356.260 +-------------------------------------------------------------------------+ N Min Max Median Avg Stddev x 10 16682.962 17344.027 16913.524 16928.812 166.5362 + 10 16695.568 16923.896 16820.604 16824.652 84.816568 No difference proven at 95.0% confidence [akpm@linux-foundation.org: fix build] [hughd@google.com: shmem fix] Signed-off-by: Ying Han <yinghan@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26memcg: add memory.numastat api for numa statisticsYing Han
The new API exports numa_maps per-memcg basis. This is a piece of useful information where it exports per-memcg page distribution across real numa nodes. One of the usecases is evaluating application performance by combining this information w/ the cpu allocation to the application. The output of the memory.numastat tries to follow w/ simiar format of numa_maps like: total=<total pages> N0=<node 0 pages> N1=<node 1 pages> ... file=<total file pages> N0=<node 0 pages> N1=<node 1 pages> ... anon=<total anon pages> N0=<node 0 pages> N1=<node 1 pages> ... unevictable=<total anon pages> N0=<node 0 pages> N1=<node 1 pages> ... And we have per-node: total = file + anon + unevictable $ cat /dev/cgroup/memory/memory.numa_stat total=250020 N0=87620 N1=52367 N2=45298 N3=64735 file=225232 N0=83402 N1=46160 N2=40522 N3=55148 anon=21053 N0=3424 N1=6207 N2=4776 N3=6646 unevictable=3735 N0=794 N1=0 N2=0 N3=2941 Signed-off-by: Ying Han <yinghan@google.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26memcg: rename mem_cgroup_zone_nr_pages() to mem_cgroup_zone_nr_lru_pages()Ying Han
The caller of the function has been renamed to zone_nr_lru_pages(), and this is just fixing up in the memcg code. The current name is easily to be mis-read as zone's total number of pages. Signed-off-by: Ying Han <yinghan@google.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26memcg: remove unused retry signal from reclaimJohannes Weiner
If the memcg reclaim code detects the target memcg below its limit it exits and returns a guaranteed non-zero value so that the charge is retried. Nowadays, the charge side checks the memcg limit itself and does not rely on this non-zero return value trick. This patch removes it. The reclaim code will now always return the true number of pages it reclaimed on its own. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Rik van Riel<riel@redhat.com> Acked-by: Ying Han<yinghan@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26memcg: reclaim memory from nodes in round-robin orderYing Han
Presently, memory cgroup's direct reclaim frees memory from the current node. But this has some troubles. Usually when a set of threads works in a cooperative way, they tend to operate on the same node. So if they hit limits under memcg they will reclaim memory from themselves, damaging the active working set. For example, assume 2 node system which has Node 0 and Node 1 and a memcg which has 1G limit. After some work, file cache remains and the usages are Node 0: 1M Node 1: 998M. and run an application on Node 0, it will eat its foot before freeing unnecessary file caches. This patch adds round-robin for NUMA and adds equal pressure to each node. When using cpuset's spread memory feature, this will work very well. But yes, a better algorithm is needed. [akpm@linux-foundation.org: comment editing] [kamezawa.hiroyu@jp.fujitsu.com: fix time comparisons] Signed-off-by: Ying Han <yinghan@google.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26memcg: remove pointless next_mz nullification in mem_cgroup_soft_limit_reclaim()Michal Hocko
next_mz is assigned to NULL if __mem_cgroup_largest_soft_limit_node selects the same mz. This doesn't make much sense as we assign to the variable right in the next loop. Compiler will probably optimize this out but it is little bit confusing for the code reading. Signed-off-by: Michal Hocko <mhocko@suse.cz> Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26memcg: count the soft_limit reclaim in global background reclaimYing Han
The global kswapd scans per-zone LRU and reclaims pages regardless of the cgroup. It breaks memory isolation since one cgroup can end up reclaiming pages from another cgroup. Instead we should rely on memcg-aware target reclaim including per-memcg kswapd and soft_limit hierarchical reclaim under memory pressure. In the global background reclaim, we do soft reclaim before scanning the per-zone LRU. However, the return value is ignored. This patch is the first step to skip shrink_zone() if soft_limit reclaim does enough work. This is part of the effort which tries to reduce reclaiming pages in global LRU in memcg. The per-memcg background reclaim patchset further enhances the per-cgroup targetting reclaim, which I should have V4 posted shortly. Try running multiple memory intensive workloads within seperate memcgs. Watch the counters of soft_steal in memory.stat. $ cat /dev/cgroup/A/memory.stat | grep 'soft' soft_steal 240000 soft_scan 240000 total_soft_steal 240000 total_soft_scan 240000 This patch: In the global background reclaim, we do soft reclaim before scanning the per-zone LRU. However, the return value is ignored. We would like to skip shrink_zone() if soft_limit reclaim does enough work. Also, we need to make the memory pressure balanced across per-memcg zones, like the logic vm-core. This patch is the first step where we start with counting the nr_scanned and nr_reclaimed from soft_limit reclaim into the global scan_control. Signed-off-by: Ying Han <yinghan@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26cgroups: add per-thread subsystem callbacksBen Blum
Add cgroup subsystem callbacks for per-thread attachment in atomic contexts Add can_attach_task(), pre_attach(), and attach_task() as new callbacks for cgroups's subsystem interface. Unlike can_attach and attach, these are for per-thread operations, to be called potentially many times when attaching an entire threadgroup. Also, the old "bool threadgroup" interface is removed, as replaced by this. All subsystems are modified for the new interface - of note is cpuset, which requires from/to nodemasks for attach to be globally scoped (though per-cpuset would work too) to persist from its pre_attach to attach_task and attach. This is a pre-patch for cgroup-procs-writable.patch. Signed-off-by: Ben Blum <bblum@andrew.cmu.edu> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Reviewed-by: Paul Menage <menage@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: David Rientjes <rientjes@google.com> Cc: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25memsw: remove noswapaccount kernel parameterMichal Hocko
The noswapaccount parameter has been deprecated since 2.6.38 without any complaints from users so we can remove it. swapaccount=0|1 can be used instead. As we are removing the parameter we can also clean up swapaccount because it doesn't have to accept an empty string anymore (to match noswapaccount) and so we can push = into __setup macro rather than checking "=1" resp. "=0" strings Signed-off-by: Michal Hocko <mhocko@suse.cz> Cc: Hiroyuki Kamezawa <kamezawa.hiroyuki@gmail.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23memcg: fix leak on wrong LRU with FUSEKAMEZAWA Hiroyuki
fs/fuse/dev.c::fuse_try_move_page() does (1) remove a page by ->steal() (2) re-add the page to page cache (3) link the page to LRU if it was not on LRU at (1) This implies the page is _on_ LRU when it's added to radix-tree. So, the page is added to memory cgroup while it's on LRU. because LRU is lazy and no one flushs it. This is the same behavior as SwapCache and needs special care as - remove page from LRU before overwrite pc->mem_cgroup. - add page to LRU after overwrite pc->mem_cgroup. And we need to taking care of pagevec. If PageLRU(page) is set before we add PCG_USED bit, the page will not be added to memcg's LRU (in short period). So, regardlress of PageLRU(page) value before commit_charge(), we need to check PageLRU(page) after commit_charge(). Addresses https://bugzilla.kernel.org/show_bug.cgi?id=30432 Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Miklos Szeredi <miklos@szeredi.hu> Cc: Balbir Singh <balbir@in.ibm.com> Reported-by: Daniel Poelzleithner <poelzi@poelzi.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23mm/memcontrol.c: suppress uninitialized-var warning with older gcc'sAndrew Morton
mm/memcontrol.c: In function 'mem_cgroup_force_empty': mm/memcontrol.c:2280: warning: 'flags' may be used uninitialized in this function It's a false positive. Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Greg Thelen <gthelen@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23memcg: use native word page statistics countersJohannes Weiner
The statistic counters are in units of pages, there is no reason to make them 64-bit wide on 32-bit machines. Make them native words. Since they are signed, this leaves 31 bit on 32-bit machines, which can represent roughly 8TB assuming a page size of 4k. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Greg Thelen <gthelen@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23memcg: break out event counters from other statsJohannes Weiner
For increasing and decreasing per-cpu cgroup usage counters it makes sense to use signed types, as single per-cpu values might go negative during updates. But this is not the case for only-ever-increasing event counters. All the counters have been signed 64-bit so far, which was enough to count events even with the sign bit wasted. This patch: - divides s64 counters into signed usage counters and unsigned monotonically increasing event counters. - converts unsigned event counters into 'unsigned long' rather than 'u64'. This matches the type used by the /proc/vmstat event counters. The next patch narrows the signed usage counters type (on 32-bit CPUs, that is). Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Greg Thelen <gthelen@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23memcg: unify charge/uncharge quantities to units of pagesJohannes Weiner
There is no clear pattern when we pass a page count and when we pass a byte count that is a multiple of PAGE_SIZE. We never charge or uncharge subpage quantities, so convert it all to page counts. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23memcg: convert uncharge batching from bytes to page granularityJohannes Weiner
We never uncharge subpage quantities. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23memcg: convert per-cpu stock from bytes to page granularityJohannes Weiner
We never keep subpage quantities in the per-cpu stock. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23memcg: keep only one charge cancelling functionJohannes Weiner
We have two charge cancelling functions: one takes a page count, the other a page size. The second one just divides the parameter by PAGE_SIZE and then calls the first one. This is trivial, no need for an extra function. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23memcg: remove memcg->reclaim_param_lockJohannes Weiner
The reclaim_param_lock is only taken around single reads and writes to integer variables and is thus superfluous. Drop it. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23memcg: charged pages always have valid per-memcg zone infoJohannes Weiner
page_cgroup_zoneinfo() will never return NULL for a charged page, remove the check for it in mem_cgroup_get_reclaim_stat_from_page(). Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23memcg: remove direct page_cgroup-to-page pointerJohannes Weiner
In struct page_cgroup, we have a full word for flags but only a few are reserved. Use the remaining upper bits to encode, depending on configuration, the node or the section, to enable page_cgroup-to-page lookups without a direct pointer. This saves a full word for every page in a system with memory cgroups enabled. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23memcg: condense page_cgroup-to-page lookup pointsJohannes Weiner
The per-cgroup LRU lists string up 'struct page_cgroup's. To get from those structures to the page they represent, a lookup is required. Currently, the lookup is done through a direct pointer in struct page_cgroup, so a lot of functions down the callchain do this lookup by themselves instead of receiving the page pointer from their callers. The next patch removes this pointer, however, and the lookup is no longer that straight-forward. In preparation for that, this patch only leaves the non-optional lookups when coming directly from the LRU list and passes the page down the stack. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23memcg: fold __mem_cgroup_move_account into callerJohannes Weiner
It is one logical function, no need to have it split up. Also, get rid of some checks from the inner function that ensured the sanity of the outer function. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23memcg: change page_cgroup_zoneinfo signatureJohannes Weiner
Instead of passing a whole struct page_cgroup to this function, let it take only what it really needs from it: the struct mem_cgroup and the page. This has the advantage that reading pc->mem_cgroup is now done at the same place where the ordering rules for this pointer are enforced and explained. It is also in preparation for removing the pc->page backpointer. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23memcg: no uncharged pages reach page_cgroup_zoneinfoJohannes Weiner
This patch series removes the direct page pointer from struct page_cgroup, which saves 20% of per-page memcg memory overhead (Fedora and Ubuntu enable memcg per default, openSUSE apparently too). The node id or section number is encoded in the remaining free bits of pc->flags which allows calculating the corresponding page without the extra pointer. I ran, what I think is, a worst-case microbenchmark that just cats a large sparse file to /dev/null, because it means that walking the LRU list on behalf of per-cgroup reclaim and looking up pages from page_cgroups is happening constantly and at a high rate. But it made no measurable difference. A profile reported a 0.11% share of the new lookup_cgroup_page() function in this benchmark. This patch: All callsites check PCG_USED before passing pc->mem_cgroup, so the latter is never NULL. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23memcg: add memcg sanity checks at allocating and freeing pagesDaisuke Nishimura
Add checks at allocating or freeing a page whether the page is used (iow, charged) from the view point of memcg. This check may be useful in debugging a problem and we did similar checks before the commit 52d4b9ac(memcg: allocate all page_cgroup at boot). This patch adds some overheads at allocating or freeing memory, so it's enabled only when CONFIG_DEBUG_VM is enabled. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23memcg: remove NULL check from lookup_page_cgroup() resultJohannes Weiner
The page_cgroup array is set up before even fork is initialized. I seriously doubt that this code executes before the array is alloc'd. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
