commit 46612b751c4941c5c0472ddf04027e877ae5990f upstream.
When soft_offline_in_use_page() runs on a thp tail page after pmd is
split, we trigger the following VM_BUG_ON_PAGE():
Memory failure: 0x3755ff: non anonymous thp
__get_any_page: 0x3755ff: unknown zero refcount page type 2fffff80000000
Soft offlining pfn 0x34d805 at process virtual address 0x20fff000
page:ffffea000d360140 count:0 mapcount:0 mapping:0000000000000000 index:0x1
flags: 0x2fffff80000000()
raw: 002fffff80000000 ffffea000d360108 ffffea000d360188 0000000000000000
raw: 0000000000000001 0000000000000000 00000000ffffffff 0000000000000000
page dumped because: VM_BUG_ON_PAGE(page_ref_count(page) == 0)
kernel BUG at ./include/linux/mm.h:519!
soft_offline_in_use_page() passed refcount and page lock from tail page
to head page, which is not needed because we can pass any subpage to
split_huge_page().
Naoya had fixed a similar issue in c3901e722b29 ("mm: hwpoison: fix thp
split handling in memory_failure()"). But he missed fixing soft
offline.
Link: http://lkml.kernel.org/r/1551452476-24000-1-git-send-email-zhongjiang@huawei.com
Fixes: 61f5d698cc97 ("mm: re-enable THP")
Signed-off-by: zhongjiang <zhongjiang@huawei.com>
Acked-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Kirill A. Shutemov <kirill@shutemov.name>
Cc: <stable@vger.kernel.org> [4.5+]
commit 6376360ecbe525a9c17b3d081dfd88ba3e4ed65b upstream.
Currently memory_failure() is racy against process's exiting, which
results in kernel crash by null pointer dereference.
The root cause is that memory_failure() uses force_sig() to forcibly
kill asynchronous (meaning not in the current context) processes. As
discussed in thread https://lkml.org/lkml/2010/6/8/236 years ago for OOM
fixes, this is not a right thing to do. OOM solves this issue by using
do_send_sig_info() as done in commit d2d393099de2 ("signal:
oom_kill_task: use SEND_SIG_FORCED instead of force_sig()"), so this
patch is suggesting to do the same for hwpoison. do_send_sig_info()
properly accesses to siglock with lock_task_sighand(), so is free from
the reported race.
I confirmed that the reported bug reproduces with inserting some delay
in kill_procs(), and it never reproduces with this patch.
Note that memory_failure() can send another type of signal using
force_sig_mceerr(), and the reported race shouldn't happen on it because
force_sig_mceerr() is called only for synchronous processes (i.e.
BUS_MCEERR_AR happens only when some process accesses to the corrupted
memory.)
Link: http://lkml.kernel.org/r/20190116093046.GA29835@hori1.linux.bs1.fc.nec.co.jp
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Reported-by: Jane Chu <jane.chu@oracle.com>
Reviewed-by: Dan Williams <dan.j.williams@intel.com>
Reviewed-by: William Kucharski <william.kucharski@oracle.com>
[ Upstream commit 286c469a988fbaf68e3a97ddf1e6c245c1446968 ]
Memory error handler calls try_to_unmap() for error pages in various
states. If the error page is a mlocked page, error handling could fail
with "still referenced by 1 users" message. This is because the page is
linked to and stays in lru cache after the following call chain.
try_to_unmap_one
page_remove_rmap
clear_page_mlock
putback_lru_page
lru_cache_add
memory_failure() calls shake_page() to hanlde the similar issue, but
current code doesn't cover because shake_page() is called only before
try_to_unmap(). So this patches adds shake_page().
Fixes: 23a003bfd23ea9ea0b7756b920e51f64b284b468 ("mm/madvise: pass return code of memory_failure() to userspace")
Link: http://lkml.kernel.org/r/20170417055948.GM31394@yexl-desktop
Link: http://lkml.kernel.org/r/1493197841-23986-3-git-send-email-n-horiguchi@ah.jp.nec.com
Reported-by: kernel test robot <lkp@intel.com>
Cc: Xiaolong Ye <xiaolong.ye@intel.com>
Cc: Chen Gong <gong.chen@linux.intel.com>
commit 18365225f0440d09708ad9daade2ec11275c3df9 upstream.
Laurent Dufour has noticed that hwpoinsoned pages are kept charged. In
his particular case he has hit a bad_page("page still charged to
cgroup") when onlining a hwpoison page. While this looks like something
that shouldn't happen in the first place because onlining hwpages and
returning them to the page allocator makes only little sense it shows a
real problem.
hwpoison pages do not get freed usually so we do not uncharge them (at
least not since commit 0a31bc97c80c ("mm: memcontrol: rewrite uncharge
API")). Each charge pins memcg (since e8ea14cc6ead ("mm: memcontrol:
take a css reference for each charged page")) as well and so the
mem_cgroup and the associated state will never go away. Fix this leak
by forcibly uncharging a LRU hwpoisoned page in delete_from_lru_cache().
We also have to tweak uncharge_list because it cannot rely on zero ref
count for these pages.
Fixes: 0a31bc97c80c ("mm: memcontrol: rewrite uncharge API")
Link: http://lkml.kernel.org/r/20170502185507.GB19165@dhcp22.suse.cz
Signed-off-by: Michal Hocko <mhocko@suse.com>
Reported-by: Laurent Dufour <ldufour@linux.vnet.ibm.com>
Tested-by: Laurent Dufour <ldufour@linux.vnet.ibm.com>
Reviewed-by: Balbir Singh <bsingharora@gmail.com>
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
commit 7258ae5c5a2ce2f5969e8b18b881be40ab55433d upstream.
memory_failure() chooses a recovery action function based on the page
flags. For huge pages it uses the tail page flags which don't have
anything interesting set, resulting in:
> Memory failure: 0x9be3b4: Unknown page state
> Memory failure: 0x9be3b4: recovery action for unknown page: Failed
Instead, save a copy of the head page's flags if this is a huge page,
this means if there are no relevant flags for this tail page, we use the
head pages flags instead. This results in the me_huge_page() recovery
action being called:
> Memory failure: 0x9b7969: recovery action for huge page: Delayed
For hugepages that have not yet been allocated, this allows the hugepage
to be dequeued.
Fixes: 524fca1e7356 ("HWPOISON: fix misjudgement of page_action() for errors on mlocked pages")
Link: http://lkml.kernel.org/r/20170524130204.21845-1-james.morse@arm.com
Signed-off-by: James Morse <james.morse@arm.com>
Tested-by: Punit Agrawal <punit.agrawal@arm.com>
Acked-by: Punit Agrawal <punit.agrawal@arm.com>
commit 30809f559a0d348c2dfd7ab05e9a451e2384962e upstream.
On failing to migrate a page, soft_offline_huge_page() performs the
necessary update to the hugepage ref-count.
But when !hugepage_migration_supported() , unmap_and_move_hugepage()
also decrements the page ref-count for the hugepage. The combined
behaviour leaves the ref-count in an inconsistent state.
This leads to soft lockups when running the overcommitted hugepage test
from mce-tests suite.
Soft offlining pfn 0x83ed600 at process virtual address 0x400000000000
soft offline: 0x83ed600: migration failed 1, type 1fffc00000008008 (uptodate|head)
INFO: rcu_preempt detected stalls on CPUs/tasks:
Tasks blocked on level-0 rcu_node (CPUs 0-7): P2715
(detected by 7, t=5254 jiffies, g=963, c=962, q=321)
thugetlb_overco R running task 0 2715 2685 0x00000008
Call trace:
dump_backtrace+0x0/0x268
show_stack+0x24/0x30
sched_show_task+0x134/0x180
rcu_print_detail_task_stall_rnp+0x54/0x7c
rcu_check_callbacks+0xa74/0xb08
update_process_times+0x34/0x60
tick_sched_handle.isra.7+0x38/0x70
tick_sched_timer+0x4c/0x98
__hrtimer_run_queues+0xc0/0x300
hrtimer_interrupt+0xac/0x228
arch_timer_handler_phys+0x3c/0x50
handle_percpu_devid_irq+0x8c/0x290
generic_handle_irq+0x34/0x50
__handle_domain_irq+0x68/0xc0
gic_handle_irq+0x5c/0xb0
Address this by changing the putback_active_hugepage() in
soft_offline_huge_page() to putback_movable_pages().
This only triggers on systems that enable memory failure handling
(ARCH_SUPPORTS_MEMORY_FAILURE) but not hugepage migration
(!ARCH_ENABLE_HUGEPAGE_MIGRATION).
I imagine this wasn't triggered as there aren't many systems running
this configuration.
[akpm@linux-foundation.org: remove dead comment, per Naoya]
Link: http://lkml.kernel.org/r/20170525135146.32011-1-punit.agrawal@arm.com
Reported-by: Manoj Iyer <manoj.iyer@canonical.com>
Tested-by: Manoj Iyer <manoj.iyer@canonical.com>
Suggested-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Signed-off-by: Punit Agrawal <punit.agrawal@arm.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Wanpeng Li <wanpeng.li@hotmail.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
When memory_failure() runs on a thp tail page after pmd is split, we
page:ffffd7cd819b0040 count:0 mapcount:0 mapping: (null) index:0x1
flags: 0x1fffc000400000(hwpoison)
page dumped because: VM_BUG_ON_PAGE(!page_count(p))
kernel BUG at /src/linux-dev/mm/memory-failure.c:1132!
memory_failure() passed refcount and page lock from tail page to head
split_huge_page().
Link: http://lkml.kernel.org/r/1477961577-7183-1-git-send-email-n-horiguchi@ah.jp.nec.com
dequeue_hwpoisoned_huge_page() can be called without page lock hold, so
let's remove incorrect comment.
The reason why the page lock is not really needed is that
dequeue_hwpoisoned_huge_page() checks page_huge_active() inside
hugetlb_lock, which allows us to avoid trying to dequeue a hugepage that
are just allocated but not linked to active list yet, even without
taking page lock.
Link: http://lkml.kernel.org/r/20160720092901.GA15995@www9186uo.sakura.ne.jp
Reported-by: Zhan Chen <zhanc1@andrew.cmu.edu>
This moves the LRU lists from the zone to the node and related data such
as counters, tracing, congestion tracking and writeback tracking.
Unfortunately, due to reclaim and compaction retry logic, it is
necessary to account for the number of LRU pages on both zone and node
logic. Most reclaim logic is based on the node counters but the retry
logic uses the zone counters which do not distinguish inactive and
active sizes. It would be possible to leave the LRU counters on a
per-zone basis but it's a heavier calculation across multiple cache
lines that is much more frequent than the retry checks.
Other than the LRU counters, this is mostly a mechanical patch but note
that it introduces a number of anomalies. For example, the scans are
per-zone but using per-node counters. We also mark a node as congested
when a zone is congested. This causes weird problems that are fixed
later but is easier to review.
In the event that there is excessive overhead on 32-bit systems due to
the nodes being on LRU then there are two potential solutions
1. Long-term isolation of highmem pages when reclaim is lowmem
When pages are skipped, they are immediately added back onto the LRU
list. If lowmem reclaim persisted for long periods of time, the same
highmem pages get continually scanned. The idea would be that lowmem
keeps those pages on a separate list until a reclaim for highmem pages
arrives that splices the highmem pages back onto the LRU. It potentially
could be implemented similar to the UNEVICTABLE list.
That would reduce the skip rate with the potential corner case is that
highmem pages have to be scanned and reclaimed to free lowmem slab pages.
2. Linear scan lowmem pages if the initial LRU shrink fails
This will break LRU ordering but may be preferable and faster during
memory pressure than skipping LRU pages.
Link: http://lkml.kernel.org/r/1467970510-21195-4-git-send-email-mgorman@techsingularity.net
Signed-off-by: Mel Gorman <mgorman@techsingularity.net>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Hillf Danton <hillf.zj@alibaba-inc.com>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Rik van Riel <riel@surriel.com>
HWPoison was specific to some particular x86 platforms. And it is often
seen as high level machine check handler. And therefore, 'MCE' is used
for the format prefix of printk(). However, 'PowerNV' has also used
HWPoison for handling memory errors[1], so 'MCE' is no longer suitable
to memory_failure.c.
Additionally, 'MCE' and 'Memory failure' have different context. The
former belongs to exception context and the latter belongs to process
context. Furthermore, HWPoison can also be used for off-lining those
sub-health pages that do not trigger any machine check exception.
This patch aims to replace 'MCE' with a more appropriate prefix.
[1] commit 75eb3d9b60c2 ("powerpc/powernv: Get FSP memory errors
and plumb into memory poison infrastructure.")
Signed-off-by: Chen Yucong <slaoub@gmail.com>
get_hwpoison_page() must recheck relation between head and tail pages.
n-horiguchi said: without this recheck, the race causes kernel to pin an
irrelevant page, and finally makes kernel crash for refcount mismatch.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time
ago with promise that one day it will be possible to implement page
cache with bigger chunks than PAGE_SIZE.
This promise never materialized. And unlikely will.
We have many places where PAGE_CACHE_SIZE assumed to be equal to
PAGE_SIZE. And it's constant source of confusion on whether
PAGE_CACHE_* or PAGE_* constant should be used in a particular case,
especially on the border between fs and mm.
Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much
breakage to be doable.
Let's stop pretending that pages in page cache are special. They are
not.
The changes are pretty straight-forward:
- <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN};
- page_cache_get() -> get_page();
- page_cache_release() -> put_page();
This patch contains automated changes generated with coccinelle using
script below. For some reason, coccinelle doesn't patch header files.
I've called spatch for them manually.
The only adjustment after coccinelle is revert of changes to
PAGE_CAHCE_ALIGN definition: we are going to drop it later.
There are few places in the code where coccinelle didn't reach. I'll
fix them manually in a separate patch. Comments and documentation also
will be addressed with the separate patch.
virtual patch
expression E;
- E << (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
expression E;
- E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
- PAGE_CACHE_SHIFT
+ PAGE_SHIFT
- PAGE_CACHE_SIZE
+ PAGE_SIZE
- PAGE_CACHE_MASK
+ PAGE_MASK
expression E;
- PAGE_CACHE_ALIGN(E)
+ PAGE_ALIGN(E)
expression E;
- page_cache_get(E)
+ get_page(E)
expression E;
- page_cache_release(E)
+ put_page(E)
Most of the mm subsystem uses pr_<level> so make it consistent.
Miscellanea:
- Realign arguments
- Add missing newline to format
- kmemleak-test.c has a "kmemleak: " prefix added to the
"Kmemleak testing" logging message via pr_fmt
Acked-by: Tejun Heo <tj@kernel.org> [percpu]
Remove the useless #undef, since the corresponding #define has already
been removed.
Signed-off-by: Wang Xiaoqiang <wangxq10@lzu.edu.cn>
Currently memory_failure() doesn't handle non anonymous thp case,
because we can hardly expect the error handling to be successful, and it
can just hit some corner case which results in BUG_ON or something
severe like that. This is also the case for soft offline code, so let's
make it in the same way.
Orignal code has a MF_COUNT_INCREASED check before put_hwpoison_page(),
but it's unnecessary because get_any_page() is already called when
running on this code, which takes a refcount of the target page
regardress of the flag. So this patch also removes it.
[akpm@linux-foundation.org: fix build]
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
soft_offline_page() has some deeply indented code, that's the sign of
demand for cleanup. So let's do this. No functionality change.
Some mm-related BUG_ON()s could trigger from hwpoison code due to recent
changes in thp refcounting rule. This patch fixes them up.
In the new refcounting, we no longer use tail->_mapcount to keep tail's
refcount, and thereby we can simplify get/put_hwpoison_page().
And another change is that tail's refcount is not transferred to the raw
page during thp split (more precisely, in new rule we don't take
refcount on tail page any more.) So when we need thp split, we have to
transfer the refcount properly to the 4kB soft-offlined page before
migration.
thp split code goes into core code only when precheck
(total_mapcount(head) == page_count(head) - 1) passes to avoid useless
split, where we assume that one refcount is held by the caller of thp
split and the others are taken via mapping. To meet this assumption,
this patch moves thp split part in soft_offline_page() after
get_any_page().
[akpm@linux-foundation.org: remove unneeded #define, per Kirill]
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
I saw the following BUG_ON triggered in a testcase where a process calls
madvise(MADV_SOFT_OFFLINE) on thps, along with a background process that
calls migratepages command repeatedly (doing ping-pong among different
NUMA nodes) for the first process:
Soft offlining page 0x60000 at 0x700000600000
__get_any_page: 0x60000 free buddy page
page:ffffea0001800000 count:0 mapcount:-127 mapping: (null) index:0x1
flags: 0x1fffc0000000000()
page dumped because: VM_BUG_ON_PAGE(atomic_read(&page->_count) == 0)
kernel BUG at /src/linux-dev/include/linux/mm.h:342!
invalid opcode: 0000 [#1] SMP DEBUG_PAGEALLOC
Modules linked in: cfg80211 rfkill crc32c_intel serio_raw virtio_balloon i2c_piix4 virtio_blk virtio_net ata_generic pata_acpi
CPU: 3 PID: 3035 Comm: test_alloc_gene Tainted: G O 4.4.0-rc8-v4.4-rc8-160107-1501-00000-rc8+ #74
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
task: ffff88007c63d5c0 ti: ffff88007c210000 task.ti: ffff88007c210000
RIP: 0010:[<ffffffff8118998c>] [<ffffffff8118998c>] put_page+0x5c/0x60
RSP: 0018:ffff88007c213e00 EFLAGS: 00010246
Call Trace:
put_hwpoison_page+0x4e/0x80
soft_offline_page+0x501/0x520
SyS_madvise+0x6bc/0x6f0
entry_SYSCALL_64_fastpath+0x12/0x6a
Code: 8b fc ff ff 5b 5d c3 48 89 df e8 b0 fa ff ff 48 89 df 31 f6 e8 c6 7d ff ff 5b 5d c3 48 c7 c6 08 54 a2 81 48 89 df e8 a4 c5 01 00 <0f> 0b 66 90 66 66 66 66 90 55 48 89 e5 41 55 41 54 53 48 8b 47
RIP [<ffffffff8118998c>] put_page+0x5c/0x60
RSP <ffff88007c213e00>
The root cause resides in get_any_page() which retries to get a refcount
of the page to be soft-offlined. This function calls
put_hwpoison_page(), expecting that the target page is putback to LRU
list. But it can be also freed to buddy. So the second check need to
care about such case.
Fixes: af8fae7c0886 ("mm/memory-failure.c: clean up soft_offline_page()")
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Jerome Marchand <jmarchan@redhat.com>
Cc: Steve Capper <steve.capper@linaro.org>
Cc: <stable@vger.kernel.org> [3.9+]
We're going to use migration entries instead of compound_lock() to
stabilize page refcounts. Setup and remove migration entries require
page to be locked.
Some of split_huge_page() callers already have the page locked. Let's
require everybody to lock the page before calling split_huge_page().
Tested-by: Sasha Levin <sasha.levin@oracle.com>
Tested-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Acked-by: Jerome Marchand <jmarchan@redhat.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
lock_page() must operate on the whole compound page. It doesn't make
much sense to lock part of compound page. Change code to use head
page's PG_locked, if tail page is passed.
This patch also gets rid of custom helper functions --
__set_page_locked() and __clear_page_locked(). They are replaced with
helpers generated by __SETPAGEFLAG/__CLEARPAGEFLAG. Tail pages to these
helper would trigger VM_BUG_ON().
SLUB uses PG_locked as a bit spin locked. IIUC, tail pages should never
appear there. VM_BUG_ON() is added to make sure that this assumption is
correct.
[akpm@linux-foundation.org: fix fs/cifs/file.c]
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
Cc: Jérôme Glisse <jglisse@redhat.com>
Hugh has pointed that compound_head() call can be unsafe in some
context. There's one example:
CPU0 CPU1
isolate_migratepages_block()
page_count()
compound_head()
!!PageTail() == true
put_page()
tail->first_page = NULL
head = tail->first_page
alloc_pages(__GFP_COMP)
prep_compound_page()
tail->first_page = head
__SetPageTail(p);
<head == NULL dereferencing>
The race is pure theoretical. I don't it's possible to trigger it in
practice. But who knows.
We can fix the race by changing how encode PageTail() and compound_head()
within struct page to be able to update them in one shot.
The patch introduces page->compound_head into third double word block in
front of compound_dtor and compound_order. Bit 0 encodes PageTail() and
the rest bits are pointer to head page if bit zero is set.
The patch moves page->pmd_huge_pte out of word, just in case if an
architecture defines pgtable_t into something what can have the bit 0
set.
hugetlb_cgroup uses page->lru.next in the second tail page to store
pointer struct hugetlb_cgroup. The patch switch it to use page->private
in the second tail page instead. The space is free since ->first_page is
removed from the union.
The patch also opens possibility to remove HUGETLB_CGROUP_MIN_ORDER
limitation, since there's now space in first tail page to store struct
hugetlb_cgroup pointer. But that's out of scope of the patch.
That means page->compound_head shares storage space with:
- page->lru.next;
- page->next;
- page->rcu_head.next;
That's too long list to be absolutely sure, but looks like nobody uses
bit 0 of the word.
page->rcu_head.next guaranteed[1] to have bit 0 clean as long as we use
call_rcu(), call_rcu_bh(), call_rcu_sched(), or call_srcu(). But future
call_rcu_lazy() is not allowed as it makes use of the bit and we can
get false positive PageTail().
[1] http://lkml.kernel.org/g/20150827163634.GD4029@linux.vnet.ibm.com
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Currently kernel prints out results of every single unpoison event, which
i= s not necessary because unpoison is purely a testing feature and
testers can = get little or no information from lots of lines of unpoison
log storm. So this patch ratelimits printk in unpoison_memory().
This patch introduces a file local ratelimit_state, which adds 64 bytes to
memory-failure.o. If we apply pr_info_ratelimited() for 8 callsite below,
2= 56 bytes is added, so it's a win.
Hwpoison allows to filter pages by memory cgroup ino. Currently, it
calls try_get_mem_cgroup_from_page to obtain the cgroup from a page and
then its ino using cgroup_ino, but now we have a helper method for
that, page_cgroup_ino, so use it instead.
This patch also loosens the hwpoison memcg filter dependency rules - it
makes it depend on CONFIG_MEMCG instead of CONFIG_MEMCG_SWAP, because
hwpoison memcg filter does not require anything (nor it used to) from
CONFIG_MEMCG_SWAP side.
Signed-off-by: Vladimir Davydov <vdavydov@parallels.com>
Reviewed-by: Andres Lagar-Cavilla <andreslc@google.com>
Cc: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Jonathan Corbet <corbet@lwn.net>
alloc_pages_exact_node() was introduced in commit 6484eb3e2a81 ("page
allocator: do not check NUMA node ID when the caller knows the node is
valid") as an optimized variant of alloc_pages_node(), that doesn't
fallback to current node for nid == NUMA_NO_NODE. Unfortunately the
name of the function can easily suggest that the allocation is
restricted to the given node and fails otherwise. In truth, the node is
only preferred, unless __GFP_THISNODE is passed among the gfp flags.
The misleading name has lead to mistakes in the past, see for example
commits 5265047ac301 ("mm, thp: really limit transparent hugepage
allocation to local node") and b360edb43f8e ("mm, mempolicy:
migrate_to_node should only migrate to node").
Another issue with the name is that there's a family of
alloc_pages_exact*() functions where 'exact' means exact size (instead
of page order), which leads to more confusion.
To prevent further mistakes, this patch effectively renames
alloc_pages_exact_node() to __alloc_pages_node() to better convey that
it's an optimized variant of alloc_pages_node() not intended for general
usage. Both functions get described in comments.
It has been also considered to really provide a convenience function for
allocations restricted to a node, but the major opinion seems to be that
__GFP_THISNODE already provides that functionality and we shouldn't
duplicate the API needlessly. The number of users would be small
anyway.
Existing callers of alloc_pages_exact_node() are simply converted to
call __alloc_pages_node(), with the exception of sba_alloc_coherent()
which open-codes the check for NUMA_NO_NODE, so it is converted to use
alloc_pages_node() instead. This means it no longer performs some
VM_BUG_ON checks, and since the current check for nid in
alloc_pages_node() uses a 'nid < 0' comparison (which includes
NUMA_NO_NODE), it may hide wrong values which would be previously
exposed.
Both differences will be rectified by the next patch.
To sum up, this patch makes no functional changes, except temporarily
hiding potentially buggy callers. Restricting the checks in
alloc_pages_node() is left for the next patch which can in turn expose
more existing buggy callers.
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Acked-by: Robin Holt <robinmholt@gmail.com>
Acked-by: Christoph Lameter <cl@linux.com>
Acked-by: Michael Ellerman <mpe@ellerman.id.au>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Gleb Natapov <gleb@kernel.org>
Cc: Cliff Whickman <cpw@sgi.com>
memory_failure() can be called at any page at any time, which means that
we can't eliminate the possibility of containment failure. In such case
the best option is to leak the page intentionally (and never touch it
later.)
We have an unpoison function for testing, and it cannot handle such
containment-failed pages, which results in kernel panic (visible with
various calltraces.) So this patch suggests that we limit the
unpoisonable pages to properly contained pages and ignore any other
ones.
Testers are recommended to keep in mind that there're un-unpoisonable
pages when writing test programs.
Tested-by: Wanpeng Li <wanpeng.li@hotmail.com>
Wanpeng Li reported a race between soft_offline_page() and
unpoison_memory(), which causes the following kernel panic:
BUG: Bad page state in process bash pfn:97000
page:ffffea00025c0000 count:0 mapcount:1 mapping: (null) index:0x7f4fdbe00
flags: 0x1fffff80080048(uptodate|active|swapbacked)
page dumped because: PAGE_FLAGS_CHECK_AT_FREE flag(s) set
bad because of flags:
flags: 0x40(active)
Modules linked in: snd_hda_codec_hdmi i915 rpcsec_gss_krb5 nfsv4 dns_resolver bnep rfcomm nfsd bluetooth auth_rpcgss nfs_acl nfs rfkill lockd grace sunrpc i2c_algo_bit drm_kms_helper snd_hda_codec_realtek snd_hda_codec_generic drm snd_hda_intel fscache snd_hda_codec x86_pkg_temp_thermal coretemp kvm_intel snd_hda_core snd_hwdep kvm snd_pcm snd_seq_dummy snd_seq_oss crct10dif_pclmul snd_seq_midi crc32_pclmul snd_seq_midi_event ghash_clmulni_intel snd_rawmidi aesni_intel lrw gf128mul snd_seq glue_helper ablk_helper snd_seq_device cryptd fuse snd_timer dcdbas serio_raw mei_me parport_pc snd mei ppdev i2c_core video lp soundcore parport lpc_ich shpchp mfd_core ext4 mbcache jbd2 sd_mod e1000e ahci ptp libahci crc32c_intel libata pps_core
CPU: 3 PID: 2211 Comm: bash Not tainted 4.2.0-rc5-mm1+ #45
Hardware name: Dell Inc. OptiPlex 7020/0F5C5X, BIOS A03 01/08/2015
Call Trace:
dump_stack+0x48/0x5c
bad_page+0xe6/0x140
free_pages_prepare+0x2f9/0x320
? uncharge_list+0xdd/0x100
free_hot_cold_page+0x40/0x170
__put_single_page+0x20/0x30
put_page+0x25/0x40
unmap_and_move+0x1a6/0x1f0
migrate_pages+0x100/0x1d0
? kill_procs+0x100/0x100
? unlock_page+0x6f/0x90
__soft_offline_page+0x127/0x2a0
soft_offline_page+0xa6/0x200
This race is explained like below:
CPU0 CPU1
soft_offline_page
__soft_offline_page
TestSetPageHWPoison
unpoison_memory
PageHWPoison check (true)
TestClearPageHWPoison
put_page -> release refcount held by get_hwpoison_page in unpoison_memory
put_page -> release refcount held by isolate_lru_page in __soft_offline_page
migrate_pages
The second put_page() releases refcount held by isolate_lru_page() which
will lead to unmap_and_move() releases the last refcount of page and w/
mapcount still 1 since try_to_unmap() is not called if there is only one
user map the page. Anyway, the page refcount and mapcount will still
mess if the page is mapped by multiple users.
This race was introduced by commit 4491f71260 ("mm/memory-failure: set
PageHWPoison before migrate_pages()"), which focuses on preventing the
reuse of successfully migrated page. Before this commit we prevent the
reuse by changing the migratetype to MIGRATE_ISOLATE during soft
offlining, which has the following problems, so simply reverting the
commit is not a best option:
1) it doesn't eliminate the reuse completely, because
set_migratetype_isolate() can fail to set MIGRATE_ISOLATE to the
target page if the pageblock of the page contains one or more
unmovable pages (i.e. has_unmovable_pages() returns true).
2) the original code changes migratetype to MIGRATE_ISOLATE
forcibly, and sets it to MIGRATE_MOVABLE forcibly after soft offline,
regardless of the original migratetype state, which could impact
other subsystems like memory hotplug or compaction.
This patch moves PageSetHWPoison just after put_page() in
unmap_and_move(), which closes up the reported race window and minimizes
another race window b/w SetPageHWPoison and reallocation (which causes
the reuse of soft-offlined page.) The latter race window still exists
but it's acceptable, because it's rare and effectively the same as
ordinary "containment failure" case even if it happens, so keep the
window open is acceptable.
Fixes: 4491f71260 ("mm/memory-failure: set PageHWPoison before migrate_pages()")
Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com>
Reported-by: Wanpeng Li <wanpeng.li@hotmail.com>
num_poisoned_pages counter will be changed outside mm/memory-failure.c
by a subsequent patch, so this patch prepares wrappers to manipulate it.
put_hwpoison_page
Replace most instances of put_page() in memory error handling with
handling
Introduce put_hwpoison_page to put refcount for memory error handling.
There is a race between madvise_hwpoison path and memory_failure:
CPU0 CPU1
madvise_hwpoison
get_user_pages_fast
PageHWPoison check (false)
memory_failure
TestSetPageHWPoison
soft_offline_page
return -EBUSY (without put_page)
THP pages will get a refcount in madvise_hwpoison() w/
MF_COUNT_INCREASED flag, however, the refcount is still held when fail
to split THP pages.
Fix it by reducing the refcount of THP pages when fail to split THP.
mem_cgroup structure is defined in mm/memcontrol.c currently which means
that the code outside of this file has to use external API even for
trivial access stuff.
This patch exports mm_struct with its dependencies and makes some of the
exported functions inlines. This even helps to reduce the code size a bit
(make defconfig + CONFIG_MEMCG=y)
12355346 1823792 1089536 15268674 e8fb42 vmlinux.before
12354970 1823792 1089536 15268298 e8f9ca vmlinux.after
This is not much (370B) but better than nothing.
We also save a function call in some hot paths like callers of
mem_cgroup_count_vm_event which is used for accounting.
The patch doesn't introduce any functional changes.
[vdavykov@parallels.com: inline memcg_kmem_is_active]
[vdavykov@parallels.com: do not expose type outside of CONFIG_MEMCG]
[akpm@linux-foundation.org: memcontrol.h needs eventfd.h for eventfd_ctx]
[akpm@linux-foundation.org: export mem_cgroup_from_task() to modules]
Reviewed-by: Vladimir Davydov <vdavydov@parallels.com>
Suggested-by: Johannes Weiner <hannes@cmpxchg.org>
Cc: Tejun Heo <tj@kernel.org>
Bug:
kernel BUG at mm/huge_memory.c:1957!
Modules linked in: snd_hda_codec_hdmi i915 rpcsec_gss_krb5 snd_hda_codec_realtek snd_hda_codec_generic nfsv4 dns_re
CPU: 2 PID: 2576 Comm: test_huge Not tainted 4.2.0-rc5-mm1+ #27
task: ffff880204e3d600 ti: ffff8800db16c000 task.ti: ffff8800db16c000
RIP: split_huge_page_to_list+0xdb/0x120
Call Trace:
memory_failure+0x32e/0x7c0
madvise_hwpoison+0x8b/0x160
SyS_madvise+0x40/0x240
? do_page_fault+0x37/0x90
entry_SYSCALL_64_fastpath+0x12/0x71
Code: ff f0 41 ff 4c 24 30 74 0d 31 c0 48 83 c4 08 5b 41 5c 41 5d c9 c3 4c 89 e7 e8 e2 58 fd ff 48 83 c4 08 31 c0
RIP split_huge_page_to_list+0xdb/0x120
RSP <ffff8800db16fde8>
---[ end trace aee7ce0df8e44076 ]---
Testcase:
#define _GNU_SOURCE
#include <stdlib.h>
#include <stdio.h>
#include <sys/mman.h>
#include <unistd.h>
#include <fcntl.h>
#include <sys/types.h>
#include <errno.h>
#include <string.h>
#define MB 1024*1024
int main(void)
char *mem;
posix_memalign((void **)&mem, 2 * MB, 200 * MB);
madvise(mem, 200 * MB, MADV_HWPOISON);
free(mem);
return 0;
Huge zero page is allocated if page fault w/o FAULT_FLAG_WRITE flag.
The get_user_pages_fast() which called in madvise_hwpoison() will get
huge zero page if the page is not allocated before. Huge zero page is a
tranparent huge page, however, it is not an anonymous page.
memory_failure will split the huge zero page and trigger
BUG_ON(is_huge_zero_page(page));
After commit 98ed2b0052e6 ("mm/memory-failure: give up error handling
for non-tail-refcounted thp"), memory_failure will not catch non anon
thp from madvise_hwpoison path and this bug occur.
Fix it by catching non anon thp in memory_failure in order to not split
huge zero page in madvise_hwpoison path.
After this patch:
Injecting memory failure for page 0x202800 at 0x7fd8ae800000
MCE: 0x202800: non anonymous thp
[akpm@linux-foundation.org: remove second split, per Wanpeng]
Hugetlbfs pages will get a refcount in get_any_page() or
madvise_hwpoison() if soft offlining through madvise. The refcount which
is held by the soft offline path should be released if we fail to isolate
hugetlbfs pages.
Fix it by reducing the refcount for both isolation success and failure.
After trying to drain pages from pagevec/pageset, we try to get reference
count of the page again, however, the reference count of the page is not
reduced if the page is still not on LRU list.
Fix it by adding the put_page() to drop the page reference which is from
__get_any_page().
Now page freeing code doesn't consider PageHWPoison as a bad page, so by
setting it before completing the page containment, we can prevent the
error page from being reused just after successful page migration.
I added TTU_IGNORE_HWPOISON for try_to_unmap() to make sure that the
page table entry is transformed into migration entry, not to hwpoison
entry.
Cc: Dean Nelson <dnelson@redhat.com>
"non anonymous thp" case is still racy with freeing thp, which causes
panic due to put_page() for refcount-0 page. It seems that closing up
this race might be hard (and/or not worth doing,) so let's give up the
error handling for this case.
When memory_failure() is called on a page which are just freed after
page migration from soft offlining, the counter num_poisoned_pages is
raised twi= ce. So let's fix it with using TestSetPageHWPoison.
Recently I addressed a few of hwpoison race problems and the patches are
merged on v4.2-rc1. It made progress, but unfortunately some problems
still remain due to less coverage of my testing. So I'm trying to fix
or avoid them in this series.
One point I'm expecting to discuss is that patch 4/5 changes the page
flag set to be checked on free time. In current behavior, __PG_HWPOISON
is not supposed to be set when the page is freed. I think that there is
no strong reason for this behavior, and it causes a problem hard to fix
only in error handler side (because __PG_HWPOISON could be set at
arbitrary timing.) So I suggest to change it.
With this patchset, hwpoison stress testing in official mce-test
testsuite (which previously failed) passes.
This patch (of 5):
In "just unpoisoned" path, we do put_page and then unlock_page, which is
a wrong order and causes "freeing locked page" bug. So let's fix it.
Acked-by: David Rientjes <rientjes@google.com>
RAS user space tools like rasdaemon which base on trace event, could
receive mce error event, but no memory recovery result event. So, I want
to add this event to make this scenario complete.
This patch add a event at ras group for memory-failure.
The output like below:
# tracer: nop
# entries-in-buffer/entries-written: 2/2 #P:24
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
mce-inject-13150 [001] .... 277.019359: memory_failure_event: pfn 0x19869: recovery action for free buddy page: Delayed
[xiexiuqi@huawei.com: fix build error]
Signed-off-by: Xie XiuQi <xiexiuqi@huawei.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Jim Davis <jim.epost@gmail.com>
Change type of action_result's param 3 to enum for type consistency,
and rename mf_outcome to mf_result for clearly.
Export 'outcome' and 'action_page_type' to mm.h, so we could use
this emnus outside.
This patch is preparation for adding trace events for memory-failure
recovery action.
memory_failure() is supposed not to handle thp itself, but to split it.
But if something were wrong and page_action() were called on thp,
me_huge_page() (action routine for hugepages) should be better to take
no action, rather than to take wrong action prepared for hugetlb (which
triggers BUG_ON().)
This change is for potential problems, but makes sense to me because thp
is an actively developing feature and this code path can be open in the
future.
Stress testing showed that soft offline events for a process iterating
"mmap-pagefault-munmap" loop can trigger
VM_BUG_ON(PAGE_FLAGS_CHECK_AT_PREP) in __free_one_page():
Soft offlining page 0x70fe1 at 0x70100008d000
Soft offlining page 0x705fb at 0x70300008d000
page:ffffea0001c3f840 count:0 mapcount:0 mapping: (null) index:0x2
flags: 0x1fffff80800000(hwpoison)
page dumped because: VM_BUG_ON_PAGE(page->flags & ((1 << 25) - 1))
kernel BUG at /src/linux-dev/mm/page_alloc.c:585!
Modules linked in: cfg80211 rfkill crc32c_intel microcode ppdev parport_pc pcspkr serio_raw virtio_balloon parport i2c_piix4 virtio_blk virtio_net ata_generic pata_acpi floppy
CPU: 3 PID: 1779 Comm: test_base_madv_ Not tainted 4.0.0-v4.0-150511-1451-00009-g82360a3730e6 #139
RIP: free_pcppages_bulk+0x52a/0x6f0
Call Trace:
drain_pages_zone+0x3d/0x50
drain_local_pages+0x1d/0x30
on_each_cpu_mask+0x46/0x80
drain_all_pages+0x14b/0x1e0
soft_offline_page+0x432/0x6e0
SyS_madvise+0x73c/0x780
system_call_fastpath+0x12/0x17
Code: ff 89 45 b4 48 8b 45 c0 48 83 b8 a8 00 00 00 00 0f 85 e3 fb ff ff 0f 1f 00 0f 0b 48 8b 7d 90 48 c7 c6 e8 95 a6 81 e8 e6 32 02 00 <0f> 0b 8b 45 cc 49 89 47 30 41 8b 47 18 83 f8 ff 0f 85 10 ff ff
RIP [<ffffffff811a806a>] free_pcppages_bulk+0x52a/0x6f0
RSP <ffff88007a117d28>
---[ end trace 53926436e76d1f35 ]---
When soft offline successfully migrates page, the source page is supposed
to be freed. But there is a race condition where a source page looks
isolated (i.e. the refcount is 0 and the PageHWPoison is set) but
somewhat linked to pcplist. Then another soft offline event calls
drain_all_pages() and tries to free such hwpoisoned page, which is
forbidden.
This odd page state seems to happen due to the race between put_page() in
putback_lru_page() and __pagevec_lru_add_fn(). But I don't want to play
with tweaking drain code as done in commit 9ab3b598d2df "mm: hwpoison:
drop lru_add_drain_all() in __soft_offline_page()", or to change page
freeing code for this soft offline's purpose.
Instead, let's think about the difference between hard offline and soft
offline. There is an interesting difference in how to isolate the in-use
page between these, that is, hard offline marks PageHWPoison of the target
page at first, and doesn't free it by keeping its refcount 1. OTOH, soft
offline tries to free the target page then marks PageHWPoison. This
difference might be the source of complexity and result in bugs like the
above. So making soft offline isolate with keeping refcount can be a
solution for this problem.
We can pass to page migration code the "reason" which shows the caller, so
let's use this more to avoid calling putback_lru_page() when called from
soft offline, which effectively does the isolation for soft offline. With
this change, target pages of soft offline never be reused without changing
migratetype, so this patch also removes the related code.
handling
memory_failure() can run in 2 different mode (specified by
MF_COUNT_INCREASED) in page refcount perspective. When
MF_COUNT_INCREASED is set, memory_failure() assumes that the caller
takes a refcount of the target page. And if cleared, memory_failure()
takes it in it's own.
In current code, however, refcounting is done differently in each caller.
For example, madvise_hwpoison() uses get_user_pages_fast() and
hwpoison_inject() uses get_page_unless_zero(). So this inconsistent
refcounting causes refcount failure especially for thp tail pages.
Typical user visible effects are like memory leak or
VM_BUG_ON_PAGE(!page_count(page)) in isolate_lru_page().
To fix this refcounting issue, this patch introduces get_hwpoison_page()
to handle thp tail pages in the same manner for each caller of hwpoison
code.
memory_failure() might fail to split thp and in such case it returns
without completing page isolation. This is not good because PageHWPoison
on the thp is still set and there's no easy way to unpoison such thps. So
this patch try to roll back any action to the thp in "non anonymous thp"
case and "thp split failed" case, expecting an MCE(SRAR) generated by
later access afterward will properly free such thps.
[akpm@linux-foundation.org: fix CONFIG_HWPOISON_INJECT=m]
memory_failure() doesn't handle thp itself at this time and need to split
it before doing isolation. Currently thp is split in the middle of
hwpoison_user_mappings(), but there're corner cases where memory_failure()
wrongly tries to handle thp without splitting.
1) "non anonymous" thp, which is not a normal operating mode of thp,
but a memory error could hit a thp before anon_vma is initialized. In
such case, split_huge_page() fails and me_huge_page() (intended for
hugetlb) is called for thp, which triggers BUG_ON in page_hstate().
2) !PageLRU case, where hwpoison_user_mappings() returns with
SWAP_SUCCESS and the result is the same as case 1.
memory_failure() can't avoid splitting, so let's split it more earlier,
which also reduces code which are prepared for both of normal page and
thp.
All the items mentioned here have been either addressed, or were not
really needed. So just remove the comment.
Here's another comment fix for hwpoison.
It describes the "guiding principle" on when to add new
memory error recovery code.
If multiple soft offline events hit one free page/hugepage concurrently,
soft_offline_page() can handle the free page/hugepage multiple times,
which makes num_poisoned_pages counter increased more than once. This
patch fixes this wrong counting by checking TestSetPageHWPoison for normal
papes and by checking the return value of dequeue_hwpoisoned_huge_page()
for hugepages.
Acked-by: Dean Nelson <dnelson@redhat.com>
Cc: <stable@vger.kernel.org> [3.14+]
Currently memory_failure() calls shake_page() to sweep pages out from
pcplists only when the victim page is 4kB LRU page or thp head page.
But we should do this for a thp tail page too.
Consider that a memory error hits a thp tail page whose head page is on
a pcplist when memory_failure() runs. Then, the current kernel skips
shake_pages() part, so hwpoison_user_mappings() returns without calling
split_huge_page() nor try_to_unmap() because PageLRU of the thp head is
still cleared due to the skip of shake_page().
As a result, me_huge_page() runs for the thp, which is broken behavior.
One effect is a leak of the thp. And another is to fail to isolate the
memory error, so later access to the error address causes another MCE,
which kills the processes which used the thp.
This patch fixes this problem by calling shake_page() for thp tail case.
Fixes: 385de35722c9 ("thp: allow a hwpoisoned head page to be put back to LRU")
Reviewed-by: Andi Kleen <ak@linux.intel.com>
Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Cc: Jin Dongming <jin.dongming@np.css.fujitsu.com>
Cc: <stable@vger.kernel.org> [3.4+]
