Pages isolated for migration are accounted with the vmstat counters
NR_ISOLATE_[ANON|FILE]. Callers of migrate_pages() are expected to
increment these counters when pages are isolated from the LRU. Once the
pages have been migrated, they are put back on the LRU or freed and the
isolated count is decremented.
Memory failure is not properly accounting for pages it isolates causing
the NR_ISOLATED counters to be negative. On SMP builds, this goes
unnoticed as negative counters are treated as 0 due to expected per-cpu
drift. On UP builds, the counter is treated by too_many_isolated() as a
large value causing processes to enter D state during page reclaim or
compaction. This patch accounts for pages isolated by memory failure
correctly.
[mel@csn.ul.ie: rewrote changelog]
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
Signed-off-by: Minchan Kim <minchan.kim@gmail.com>
Acked-by: Mel Gorman <mel@csn.ul.ie>
Cc: <stable@kernel.org>
Change each shrinker's API by consolidating the existing parameters into
shrink_control struct. This will simplify any further features added w/o
touching each file of shrinker.
[akpm@linux-foundation.org: fix build]
[akpm@linux-foundation.org: fix warning]
[kosaki.motohiro@jp.fujitsu.com: fix up new shrinker API]
[akpm@linux-foundation.org: fix xfs warning]
[akpm@linux-foundation.org: update gfs2]
Signed-off-by: Ying Han <yinghan@google.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
Acked-by: Pavel Emelyanov <xemul@openvz.org>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Consolidate the existing parameters to shrink_slab() into a new
shrink_control struct. This is needed later to pass the same struct to
shrinkers.
Drop first page reference only after calling isolate_lru_page() to keep
page stable reference while isolating.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
Straightforward conversion of i_mmap_lock to a mutex.
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Namhyung Kim <namhyung@gmail.com>
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits)
Documentation/iostats.txt: bit-size reference etc.
cfq-iosched: removing unnecessary think time checking
cfq-iosched: Don't clear queue stats when preempt.
blk-throttle: Reset group slice when limits are changed
blk-cgroup: Only give unaccounted_time under debug
cfq-iosched: Don't set active queue in preempt
block: fix non-atomic access to genhd inflight structures
block: attempt to merge with existing requests on plug flush
block: NULL dereference on error path in __blkdev_get()
cfq-iosched: Don't update group weights when on service tree
fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away
block: Require subsystems to explicitly allocate bio_set integrity mempool
jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
fs: make fsync_buffers_list() plug
mm: make generic_writepages() use plugging
blk-cgroup: Add unaccounted time to timeslice_used.
block: fixup plugging stubs for !CONFIG_BLOCK
block: remove obsolete comments for blkdev_issue_zeroout.
blktrace: Use rq->cmd_flags directly in blk_add_trace_rq.
Fix up conflicts in fs/{aio.c,super.c}
Now we renamed remove_from_page_cache with delete_from_page_cache. As
consistency of __remove_from_swap_cache and remove_from_swap_cache, we
change internal page cache handling function name, too.
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Reviewed-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Unused.
Signed-off-by: Huang Ying <ying.huang@intel.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Code has been converted over to the new explicit on-stack plugging,
and delay users have been converted to use the new API for that.
So lets kill off the old plugging along with aops->sync_page().
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
When a tail page of THP is poisoned, memory-failure will do nothing except
setting PG_hwpoison, while the expected behavior is that the process, who
is using the poisoned tail page, should be killed.
The above problem is caused by lru check of the poisoned tail page of THP.
Because PG_lru flag is only set on the head page of THP, the check always
consider the poisoned tail page as NON lru page.
So the lru check for the tail page of THP should be avoided, as like as
hugetlb.
This patch adds !PageTransCompound() before lru check for THP, because of
the check (!PageHuge() && !PageTransCompound()) the whole branch could be
optimized away at build time when both hugetlbfs and THP are set with "N"
(or in archs not supporting either of those).
[akpm@linux-foundation.org: fix unrelated typo in shake_page() comment]
Signed-off-by: Jin Dongming <jin.dongming@np.css.fujitsu.com>
Reviewed-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
When the tail page of THP is poisoned, the head page will be poisoned too.
And the wrong address, address of head page, will be sent with sigbus
always.
So when the poisoned page is used by Guest OS which is running on KVM,
after the address changing(hva->gpa) by qemu, the unexpected process on
Guest OS will be killed by sigbus.
What we expected is that the process using the poisoned tail page could be
killed on Guest OS, but not that the process using the healthy head page
is killed.
Since it is not good to poison the healthy page, avoid poisoning other
than the page which is really poisoned.
(While we poison all pages in a huge page in case of hugetlb,
we can do this for THP thanks to split_huge_page().)
Here we fix two parts:
1. Isolate the poisoned page only to make sure
the reported address is the address of poisoned page.
2. make the poisoned page work as the poisoned regular page.
[akpm@linux-foundation.org: fix spello in comment]
The poisoned THP is now split with split_huge_page() in
collect_procs_anon(). If kmalloc() is failed in collect_procs(),
split_huge_page() could not be called. And the work after
split_huge_page() for collecting the processes using poisoned page will
not be done, too. So the processes using the poisoned page could not be
killed.
The condition becomes worse when CONFIG_DEBUG_VM == "Y". Because the
poisoned THP could not be split, system panic will be caused by
VM_BUG_ON(PageTransHuge(page)) in try_to_unmap().
This patch does:
1. move split_huge_page() to the place before collect_procs().
This can be sure the failure of splitting THP is caused by itself.
2. when splitting THP is failed, stop the operations after it.
This can avoid unexpected system panic or non sense works.
If migrate_huge_page by memory-failure fails , it calls put_page in itself
to decrease page reference and caller of migrate_huge_page also calls
putback_lru_pages. It can do double free of page so it can make page
corruption on page holder.
In addtion, clean of pages on caller is consistent behavior with
migrate_pages by cf608ac19c ("mm: compaction: fix COMPACTPAGEFAILED
counting").
Cc: Christoph Lameter <cl@linux.com>
In some cases migrate_pages could return zero while still leaving a few
pages in the pagelist (and some caller wouldn't notice it has to call
putback_lru_pages after commit cf608ac19c9 ("mm: compaction: fix
COMPACTPAGEFAILED counting")).
Add one missing putback_lru_pages not added by commit cf608ac19c95 ("mm:
compaction: fix COMPACTPAGEFAILED counting").
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
Read compound_trans_order safe. Noop for CONFIG_TRANSPARENT_HUGEPAGE=n.
Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
hugetlbfs was changed to allow memory failure to migrate the hugetlbfs
pages and that broke THP as split_huge_page was then called on hugetlbfs
pages too.
compound_head/order was also run unsafe on THP pages that can be splitted
at any time.
All compound_head() invocations in memory-failure.c that are run on pages
that aren't pinned and that can be freed and reused from under us (while
compound_head is running) are buggy because compound_head can return a
dangling pointer, but I'm not fixing this as this is a generic
memory-failure bug not specific to THP but it applies to hugetlbfs too, so
I can fix it later after THP is merged upstream.
Paging logic that splits the page before it is unmapped and added to swap
to ensure backwards compatibility with the legacy swap code. Eventually
swap should natively pageout the hugepages to increase performance and
decrease seeking and fragmentation of swap space. swapoff can just skip
over huge pmd as they cannot be part of swap yet. In add_to_swap be
careful to split the page only if we got a valid swap entry so we don't
split hugepages with a full swap.
In theory we could split pages before isolating them during the lru scan,
but for khugepaged to be safe, I'm relying on either mmap_sem write mode,
or PG_lock taken, so split_huge_page has to run either with mmap_sem
read/write mode or PG_lock taken. Calling it from isolate_lru_page would
make locking more complicated, in addition to that split_huge_page would
deadlock if called by __isolate_lru_page because it has to take the lru
lock to add the tail pages.
synchronous compaction in the faster path
Migration synchronously waits for writeback if the initial passes fails.
Callers of memory compaction do not necessarily want this behaviour if the
caller is latency sensitive or expects that synchronous migration is not
going to have a significantly better success rate.
This patch adds a sync parameter to migrate_pages() allowing the caller to
indicate if wait_on_page_writeback() is allowed within migration or not.
For reclaim/compaction, try_to_compact_pages() is first called
asynchronously, direct reclaim runs and then try_to_compact_pages() is
called synchronously as there is a greater expectation that it'll succeed.
[akpm@linux-foundation.org: build/merge fix]
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Cc: Andy Whitcroft <apw@shadowen.org>
Presently hwpoison is using lock_system_sleep() to prevent a race with
memory hotplug. However lock_system_sleep() is a no-op if
CONFIG_HIBERNATION=n. Therefore we need a new lock.
Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Suggested-by: Hugh Dickins <hughd@google.com>
Presently update_nr_listpages() doesn't have a role. That's because lists
passed is always empty just after calling migrate_pages. The
migrate_pages cleans up page list which have failed to migrate before
returning by aaa994b3.
[PATCH] page migration: handle freeing of pages in migrate_pages()
Do not leave pages on the lists passed to migrate_pages(). Seems that we will
not need any postprocessing of pages. This will simplify the handling of
pages by the callers of migrate_pages().
At that time, we thought we don't need any postprocessing of pages. But
the situation is changed. The compaction need to know the number of
failed to migrate for COMPACTPAGEFAILED stat
This patch makes new rule for caller of migrate_pages to call
putback_lru_pages. So caller need to clean up the lists so it has a
chance to postprocess the pages. [suggested by Christoph Lameter]
Reviewed-by: Mel Gorman <mel@csn.ul.ie>
Reviewed-by: Wu Fengguang <fengguang.wu@intel.com>
Acked-by: Christoph Lameter <cl@linux.com>
mm/memory-failure.c
We don't reply in other temporary failure cases and there were no
reports of replies happening. I think the original reason it was
added was also just an early bug, not an observation of the race.
So remove the loop for now, but keep a warning message.
The addr_valid flag is the only flag in "to_kill" and it's slightly more
efficient to have it as char instead of a bitfield.
Now that only a few obscure messages are left as pr_debug disable
outputting of pr_debug in memory-failure.c by default.
Convert a lot of pr_debugs in memory-failure.c that are generally useful
to pr_info. It's reasonable to print at least one message why
offlining succeeded or failed by default.
Clean up and improve the overview comment in memory-failure.c
Tidy some grammar issues in other comments.
Currently unpoisoning hugepages doesn't work correctly because
clearing PG_HWPoison is done outside if (TestClearPageHWPoison).
This patch fixes it.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
This patch extends soft offlining framework to support hugepage.
When memory corrected errors occur repeatedly on a hugepage,
we can choose to stop using it by migrating data onto another hugepage
and disabling the original (maybe half-broken) one.
ChangeLog since v4:
- branch soft_offline_page() for hugepage
ChangeLog since v3:
- remove comment about "ToDo: hugepage soft-offline"
ChangeLog since v2:
- move refcount handling into isolate_lru_page()
ChangeLog since v1:
- add double check in isolating hwpoisoned hugepage
- define free/non-free checker for hugepage
- postpone calling put_page() for hugepage in soft_offline_page()
Currently error recovery for free hugepage works only for MF_COUNT_INCREASED.
This patch enables !MF_COUNT_INCREASED case.
Free hugepages can be handled directly by alloc_huge_page() and
dequeue_hwpoisoned_huge_page(), and both of them are protected
by hugetlb_lock, so there is no race between them.
Note that this patch defines the refcount of HWPoisoned hugepage
dequeued from freelist is 1, deviated from present 0, thereby we
can avoid race between unpoison and memory failure on free hugepage.
This is reasonable because unlikely to free buddy pages, free hugepage
is governed by hugetlbfs even after error handling finishes.
And it also makes unpoison code added in the later patch cleaner.
This check is necessary to avoid race between dequeue and allocation,
which can cause a free hugepage to be dequeued twice and get kernel unstable.
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Reviewed-by: Christoph Lameter <cl@linux.com>
When we call the slab shrinker to free a page we need to stop at
page count one because the caller always holds a single reference, not zero.
This avoids useless looping over slab shrinkers and freeing too much
memory.
The SIGBUS user space signalling is supposed to report the
address granuality of a corruption. Pass this information correctly
for huge pages by querying the hpage order.
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6
* 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6:
hugetlb: add missing unlock in avoidcopy path in hugetlb_cow()
hwpoison: rename CONFIG
HWPOISON, hugetlb: support hwpoison injection for hugepage
HWPOISON, hugetlb: detect hwpoison in hugetlb code
HWPOISON, hugetlb: isolate corrupted hugepage
HWPOISON, hugetlb: maintain mce_bad_pages in handling hugepage error
HWPOISON, hugetlb: set/clear PG_hwpoison bits on hugepage
HWPOISON, hugetlb: enable error handling path for hugepage
hugetlb, rmap: add reverse mapping for hugepage
hugetlb: move definition of is_vm_hugetlb_page() to hugepage_inline.h
Fix up trivial conflicts in mm/memory-failure.c
If error hugepage is not in-use, we can fully recovery from error
by dequeuing it from freelist, so return RECOVERY.
Otherwise whether or not we can recovery depends on user processes,
so return DELAYED.
Dependency:
"HWPOISON, hugetlb: enable error handling path for hugepage"
Acked-by: Fengguang Wu <fengguang.wu@intel.com>
For now all pages in the error hugepage are considered as hwpoisoned,
so count all of them in mce_bad_pages.
Dependency:
To avoid race condition between concurrent memory errors on identified
hugepage, we atomically test and set PG_hwpoison bit on the head page.
All pages in the error hugepage are considered as hwpoisoned
for now, so set and clear all PG_hwpoison bits in the hugepage
with page lock of the head page held.
Dependency:
This patch just enables handling path. Real containing and
recovering operation will be implemented in following patches.
Dependency:
"hugetlb, rmap: add reverse mapping for hugepage."
is_hwpoison_address accesses the page table, so the caller must hold
current->mm->mmap_sem in read mode. So fix its usage in hva_to_pfn of
kvm accordingly.
Comment is_hwpoison_address to remind other users.
Reported-by: Avi Kivity <avi@redhat.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
In common cases, guest SRAO MCE will cause corresponding poisoned page
be un-mapped and SIGBUS be sent to QEMU-KVM, then QEMU-KVM will relay
the MCE to guest OS.
But it is reported that if the poisoned page is accessed in guest
after unmapping and before MCE is relayed to guest OS, userspace will
be killed.
The reason is as follows. Because poisoned page has been un-mapped,
guest access will cause guest exit and kvm_mmu_page_fault will be
called. kvm_mmu_page_fault can not get the poisoned page for fault
address, so kernel and user space MMIO processing is tried in turn. In
user MMIO processing, poisoned page is accessed again, then userspace
is killed by force_sig_info.
To fix the bug, kvm_mmu_page_fault send HWPOISON signal to QEMU-KVM
and do not try kernel and user space MMIO processing for poisoned
page.
[xiao: fix warning introduced by avi]
Reported-by: Max Asbock <masbock@linux.vnet.ibm.com>
Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The old anon_vma code can lead to scalability issues with heavily forking
workloads. Specifically, each anon_vma will be shared between the parent
process and all its child processes.
In a workload with 1000 child processes and a VMA with 1000 anonymous
pages per process that get COWed, this leads to a system with a million
anonymous pages in the same anon_vma, each of which is mapped in just one
of the 1000 processes. However, the current rmap code needs to walk them
all, leading to O(N) scanning complexity for each page.
This can result in systems where one CPU is walking the page tables of
1000 processes in page_referenced_one, while all other CPUs are stuck on
the anon_vma lock. This leads to catastrophic failure for a benchmark
like AIM7, where the total number of processes can reach in the tens of
thousands. Real workloads are still a factor 10 less process intensive
than AIM7, but they are catching up.
This patch changes the way anon_vmas and VMAs are linked, which allows us
to associate multiple anon_vmas with a VMA. At fork time, each child
process gets its own anon_vmas, in which its COWed pages will be
instantiated. The parents' anon_vma is also linked to the VMA, because
non-COWed pages could be present in any of the children.
This reduces rmap scanning complexity to O(1) for the pages of the 1000
child processes, with O(N) complexity for at most 1/N pages in the system.
This reduces the average scanning cost in heavily forking workloads from
O(N) to 2.
The only real complexity in this patch stems from the fact that linking a
VMA to anon_vmas now involves memory allocations. This means vma_adjust
can fail, if it needs to attach a VMA to anon_vma structures. This in
turn means error handling needs to be added to the calling functions.
A second source of complexity is that, because there can be multiple
anon_vmas, the anon_vma linking in vma_adjust can no longer be done under
"the" anon_vma lock. To prevent the rmap code from walking up an
incomplete VMA, this patch introduces the VM_LOCK_RMAP VMA flag. This bit
flag uses the same slot as the NOMMU VM_MAPPED_COPY, with an ifdef in mm.h
to make sure it is impossible to compile a kernel that needs both symbolic
values for the same bitflag.
Some test results:
Without the anon_vma changes, when AIM7 hits around 9.7k users (on a test
box with 16GB RAM and not quite enough IO), the system ends up running
>99% in system time, with every CPU on the same anon_vma lock in the
pageout code.
With these changes, AIM7 hits the cross-over point around 29.7k users.
This happens with ~99% IO wait time, there never seems to be any spike in
system time. The anon_vma lock contention appears to be resolved.
[akpm@linux-foundation.org: cleanups]
Signed-off-by: Rik van Riel <riel@redhat.com>
Cc: Larry Woodman <lwoodman@redhat.com>
Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk>
The injector filter requires stable_page_flags() which is supplied
by procfs. So make it dependent on that.
Also add ifdefs around the filter code in memory-failure.c so that
when the filter is disabled due to missing dependencies the whole
code still builds.
Reported-by: Ingo Molnar
Better to have complete sentences.
This is a simpler, gentler variant of memory_failure() for soft page
offlining controlled from user space. It doesn't kill anything, just
tries to invalidate and if that doesn't work migrate the
page away.
This is useful for predictive failure analysis, where a page has
a high rate of corrected errors, but hasn't gone bad yet. Instead
it can be offlined early and avoided.
The offlining is controlled from sysfs, including a new generic
entry point for hard page offlining for symmetry too.
We use the page isolate facility to prevent re-allocation
race. Normally this is only used by memory hotplug. To avoid
races with memory allocation I am using lock_system_sleep().
This avoids the situation where memory hotplug is about
to isolate a page range and then hwpoison undoes that work.
This is a big hammer currently, but the simplest solution
currently.
When the page is not free or LRU we try to free pages
from slab and other caches. The slab freeing is currently
quite dumb and does not try to focus on the specific slab
cache which might own the page. This could be potentially
improved later.
Thanks to Fengguang Wu and Haicheng Li for some fixes.
[Added fix from Andrew Morton to adapt to new migrate_pages prototype]
shake_page handles more types of page caches than
the much simpler lru_add_drain_all:
- slab (quite inefficiently for now)
- any other caches with a shrinker callback
- per cpu page allocator pages
- per CPU LRU
Use this call to try to turn pages into free or LRU pages.
Then handle the case of the page becoming free after drain everything.
In some use cases, user doesn't need extra filtering. E.g. user program
can inject errors through madvise syscall to its own pages, however it
might not know what the page state exactly is or which inode the page
belongs to.
So introduce an one-off interface "corrupt-filter-enable".
Echo 0 to switch off page filters, and echo 1 to switch on the filters.
[AK: changed default to 0]
Signed-off-by: Haicheng Li <haicheng.li@linux.intel.com>
The hwpoison test suite need to inject hwpoison to a collection of
selected task pages, and must not touch pages not owned by them and
thus kill important system processes such as init. (But it's OK to
mis-hwpoison free/unowned pages as well as shared clean pages.
Mis-hwpoison of shared dirty pages will kill all tasks, so the test
suite will target all or non of such tasks in the first place.)
The memory cgroup serves this purpose well. We can put the target
processes under the control of a memory cgroup, and tell the hwpoison
injection code to only kill pages associated with some active memory
cgroup.
The prerequisite for doing hwpoison stress tests with mem_cgroup is,
the mem_cgroup code tracks task pages _accurately_ (unless page is
locked). Which we believe is/should be true.
The benefits are simplification of hwpoison injector code. Also the
mem_cgroup code will automatically be tested by hwpoison test cases.
The alternative interfaces pin-pfn/unpin-pfn can also delegate the
(process and page flags) filtering functions reliably to user space.
However prototype implementation shows that this scheme adds more
complexity than we wanted.
Example test case:
mkdir /cgroup/hwpoison
usemem -m 100 -s 1000 &
echo `jobs -p` > /cgroup/hwpoison/tasks
memcg_ino=$(ls -id /cgroup/hwpoison | cut -f1 -d' ')
echo $memcg_ino > /debug/hwpoison/corrupt-filter-memcg
page-types -p `pidof init` --hwpoison # shall do nothing
page-types -p `pidof usemem` --hwpoison # poison its pages
[AK: Fix documentation]
[Add fix for problem noticed by Li Zefan <lizf@cn.fujitsu.com>;
dentry in the css could be NULL]
CC: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
CC: Hugh Dickins <hugh.dickins@tiscali.co.uk>
CC: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
CC: Balbir Singh <balbir@linux.vnet.ibm.com>
CC: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
CC: Li Zefan <lizf@cn.fujitsu.com>
CC: Paul Menage <menage@google.com>
CC: Nick Piggin <npiggin@suse.de>
CC: Andi Kleen <andi@firstfloor.org>
