commit 6b7339f4c31ad69c8e9c0b2859276e22cf72176d upstream.
Reading page fault handler code I've noticed that under right
circumstances kernel would map anonymous pages into file mappings: if
the VMA doesn't have vm_ops->fault() and the VMA wasn't fully populated
on ->mmap(), kernel would handle page fault to not populated pte with
do_anonymous_page().
Let's change page fault handler to use do_anonymous_page() only on
anonymous VMA (->vm_ops == NULL) and make sure that the VMA is not
shared.
For file mappings without vm_ops->fault() or shred VMA without vm_ops,
page fault on pte_none() entry would lead to SIGBUS.
Acked-by: Oleg Nesterov <oleg@redhat.com>
Cc: Willy Tarreau <w@1wt.eu>
This will allow FS that uses VM_PFNMAP | VM_MIXEDMAP (no page structs) to
get notified when access is a write to a read-only PFN.
This can happen if we mmap() a file then first mmap-read from it to
page-in a read-only PFN, than we mmap-write to the same page.
We need this functionality to fix a DAX bug, where in the scenario above
we fail to set ctime/mtime though we modified the file. An xfstest is
attached to this patchset that shows the failure and the fix. (A DAX
patch will follow)
This functionality is extra important for us, because upon dirtying of a
pmem page we also want to RDMA the page to a remote cluster node.
We define a new pfn_mkwrite and do not reuse page_mkwrite because
1 - The name ;-)
2 - But mainly because it would take a very long and tedious
audit of all page_mkwrite functions of VM_MIXEDMAP/VM_PFNMAP
users. To make sure they do not now CRASH. For example current
DAX code (which this is for) would crash.
If we would want to reuse page_mkwrite, We will need to first
patch all users, so to not-crash-on-no-page. Then enable this
patch. But even if I did that I would not sleep so well at night.
Adding a new vector is the safest thing to do, and is not that
expensive. an extra pointer at a static function vector per driver.
Also the new vector is better for performance, because else we
Will call all current Kernel vectors, so to:
check-ha-no-page-do-nothing and return.
No need to call it from do_shared_fault because do_wp_page is called to
change pte permissions anyway.
Signed-off-by: Yigal Korman <yigal@plexistor.com>
Signed-off-by: Boaz Harrosh <boaz@plexistor.com>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Matthew Wilcox <matthew.r.wilcox@intel.com>
Cc: Jan Kara <jack@suse.cz>
A lot of filesystems use generic_file_mmap() and filemap_fault(),
f_op->mmap and vm_ops->fault aren't enough to identify filesystem.
This prints file name, vm_ops->fault, f_op->mmap and a_ops->readpage
(which is almost always implemented and filesystem-specific).
Example:
[ 23.676410] BUG: Bad page map in process sh pte:1b7e6025 pmd:19bbd067
[ 23.676887] page:ffffea00006df980 count:4 mapcount:1 mapping:ffff8800196426c0 index:0x97
[ 23.677481] flags: 0x10000000000000c(referenced|uptodate)
[ 23.677896] page dumped because: bad pte
[ 23.678205] addr:00007f52fcb17000 vm_flags:00000075 anon_vma: (null) mapping:ffff8800196426c0 index:97
[ 23.678922] file:libc-2.19.so fault:filemap_fault mmap:generic_file_readonly_mmap readpage:v9fs_vfs_readpage
[akpm@linux-foundation.org: use pr_alert, per Kirill]
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Cc: Sasha Levin <sasha.levin@oracle.com>
Acked-by: Kirill A. Shutemov <kirill@shutemov.name>
We converted some of the usages of ACCESS_ONCE to READ_ONCE in the mm/
tree since it doesn't work reliably on non-scalar types.
This patch removes the rest of the usages of ACCESS_ONCE, and use the new
READ_ONCE API for the read accesses. This makes things cleaner, instead
of using separate/multiple sets of APIs.
Signed-off-by: Jason Low <jason.low2@hp.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
Acked-by: Davidlohr Bueso <dave@stgolabs.net>
Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com>
The do_wp_page function is extremely long. Extract the logic for
handling a page belonging to a shared vma into a function of its own.
This helps the readability of the code, without doing any functional
change in it.
Signed-off-by: Shachar Raindel <raindel@mellanox.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Acked-by: Andi Kleen <ak@linux.intel.com>
Acked-by: Haggai Eran <haggaie@mellanox.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Peter Feiner <pfeiner@google.com>
Cc: Michel Lespinasse <walken@google.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
In some cases, do_wp_page had to copy the page suffering a write fault
to a new location. If the function logic decided that to do this, it
was done by jumping with a "goto" operation to the relevant code block.
This made the code really hard to understand. It is also against the
kernel coding style guidelines.
This patch extracts the page copy and page table update logic to a
separate function. It also clean up the naming, from "gotten" to
"wp_page_copy", and adds few comments.
When do_wp_page is ending, in several cases it needs to unlock the pages
and ptls it was accessing.
Currently, this logic was "called" by using a goto jump. This makes
following the control flow of the function harder. Readability was
further hampered by the unlock case containing large amount of logic
needed only in one of the 3 cases.
Using goto for cleanup is generally allowed. However, moving the
trivial unlocking flows to the relevant call sites allow deeper
refactoring in the next patch.
Currently do_wp_page contains 265 code lines. It also contains 9 goto
statements, of which 5 are targeting labels which are not cleanup
related. This makes the function extremely difficult to understand.
The following patches are an attempt at breaking the function to its
basic components, and making it easier to understand.
The patches are straight forward function extractions from do_wp_page.
As we extract functions, we remove unneeded parameters and simplify the
code as much as possible. However, the functionality is supposed to
remain completely unchanged. The patches also attempt to document the
functionality of each extracted function. In patch 2, we split the
unlock logic to the contain logic relevant to specific needs of each use
case, instead of having huge number of conditional decisions in a single
unlock flow.
This patch (of 4):
When do_wp_page is ending, in several cases it needs to reuse the existing
page. This is achieved by making the page table writable, and possibly
updating the page-cache state.
following the control flow of the function harder. It is also against the
coding style guidelines for using goto.
As the code can easily be refactored into a specialized function, refactor
it out and simplify the code flow in do_wp_page.
Dave Chinner reported the following on https://lkml.org/lkml/2015/3/1/226
Across the board the 4.0-rc1 numbers are much slower, and the degradation
is far worse when using the large memory footprint configs. Perf points
straight at the cause - this is from 4.0-rc1 on the "-o bhash=101073" config:
- 56.07% 56.07% [kernel] [k] default_send_IPI_mask_sequence_phys
- default_send_IPI_mask_sequence_phys
- 99.99% physflat_send_IPI_mask
- 99.37% native_send_call_func_ipi
smp_call_function_many
- native_flush_tlb_others
- 99.85% flush_tlb_page
ptep_clear_flush
try_to_unmap_one
rmap_walk
try_to_unmap
migrate_pages
migrate_misplaced_page
- handle_mm_fault
- 99.73% __do_page_fault
trace_do_page_fault
do_async_page_fault
+ async_page_fault
0.63% native_send_call_func_single_ipi
generic_exec_single
smp_call_function_single
This is showing excessive migration activity even though excessive
migrations are meant to get throttled. Normally, the scan rate is tuned
on a per-task basis depending on the locality of faults. However, if
migrations fail for any reason then the PTE scanner may scan faster if
the faults continue to be remote. This means there is higher system CPU
overhead and fault trapping at exactly the time we know that migrations
cannot happen. This patch tracks when migration failures occur and
slows the PTE scanner.
Reported-by: Dave Chinner <david@fromorbit.com>
Tested-by: Dave Chinner <david@fromorbit.com>
Cc: Aneesh Kumar <aneesh.kumar@linux.vnet.ibm.com>
Protecting a PTE to trap a NUMA hinting fault clears the writable bit
and further faults are needed after trapping a NUMA hinting fault to set
the writable bit again. This patch preserves the writable bit when
trapping NUMA hinting faults. The impact is obvious from the number of
minor faults trapped during the basis balancing benchmark and the system
CPU usage;
autonumabench
4.0.0-rc4 4.0.0-rc4
baseline preserve
Time System-NUMA01 107.13 ( 0.00%) 103.13 ( 3.73%)
Time System-NUMA01_THEADLOCAL 131.87 ( 0.00%) 83.30 ( 36.83%)
Time System-NUMA02 8.95 ( 0.00%) 10.72 (-19.78%)
Time System-NUMA02_SMT 4.57 ( 0.00%) 3.99 ( 12.69%)
Time Elapsed-NUMA01 515.78 ( 0.00%) 517.26 ( -0.29%)
Time Elapsed-NUMA01_THEADLOCAL 384.10 ( 0.00%) 384.31 ( -0.05%)
Time Elapsed-NUMA02 48.86 ( 0.00%) 48.78 ( 0.16%)
Time Elapsed-NUMA02_SMT 47.98 ( 0.00%) 48.12 ( -0.29%)
4.0.0-rc4 4.0.0-rc4
baseline preserve
User 44383.95 43971.89
System 252.61 201.24
Elapsed 998.68 1000.94
Minor Faults 2597249 1981230
Major Faults 365 364
There is a similar drop in system CPU usage using Dave Chinner's xfsrepair
workload
4.0.0-rc4 4.0.0-rc4
baseline preserve
Amean real-xfsrepair 454.14 ( 0.00%) 442.36 ( 2.60%)
Amean syst-xfsrepair 277.20 ( 0.00%) 204.68 ( 26.16%)
The patch looks hacky but the alternatives looked worse. The tidest was
to rewalk the page tables after a hinting fault but it was more complex
than this approach and the performance was worse. It's not generally
safe to just mark the page writable during the fault if it's a write
fault as it may have been read-only for COW so that approach was
discarded.
These are three follow-on patches based on the xfsrepair workload Dave
Chinner reported was problematic in 4.0-rc1 due to changes in page table
management -- https://lkml.org/lkml/2015/3/1/226.
Much of the problem was reduced by commit 53da3bc2ba9e ("mm: fix up numa
read-only thread grouping logic") and commit ba68bc0115eb ("mm: thp:
Return the correct value for change_huge_pmd"). It was known that the
performance in 3.19 was still better even if is far less safe. This
series aims to restore the performance without compromising on safety.
For the test of this mail, I'm comparing 3.19 against 4.0-rc4 and the
three patches applied on top
autonumabench
3.19.0 4.0.0-rc4 4.0.0-rc4 4.0.0-rc4 4.0.0-rc4
vanilla vanilla vmwrite-v5r8 preserve-v5r8 slowscan-v5r8
Time System-NUMA01 124.00 ( 0.00%) 161.86 (-30.53%) 107.13 ( 13.60%) 103.13 ( 16.83%) 145.01 (-16.94%)
Time System-NUMA01_THEADLOCAL 115.54 ( 0.00%) 107.64 ( 6.84%) 131.87 (-14.13%) 83.30 ( 27.90%) 92.35 ( 20.07%)
Time System-NUMA02 9.35 ( 0.00%) 10.44 (-11.66%) 8.95 ( 4.28%) 10.72 (-14.65%) 8.16 ( 12.73%)
Time System-NUMA02_SMT 3.87 ( 0.00%) 4.63 (-19.64%) 4.57 (-18.09%) 3.99 ( -3.10%) 3.36 ( 13.18%)
Time Elapsed-NUMA01 570.06 ( 0.00%) 567.82 ( 0.39%) 515.78 ( 9.52%) 517.26 ( 9.26%) 543.80 ( 4.61%)
Time Elapsed-NUMA01_THEADLOCAL 393.69 ( 0.00%) 384.83 ( 2.25%) 384.10 ( 2.44%) 384.31 ( 2.38%) 380.73 ( 3.29%)
Time Elapsed-NUMA02 49.09 ( 0.00%) 49.33 ( -0.49%) 48.86 ( 0.47%) 48.78 ( 0.63%) 50.94 ( -3.77%)
Time Elapsed-NUMA02_SMT 47.51 ( 0.00%) 47.15 ( 0.76%) 47.98 ( -0.99%) 48.12 ( -1.28%) 49.56 ( -4.31%)
vanilla vanillavmwrite-v5r8preserve-v5r8slowscan-v5r8
User 46334.60 46391.94 44383.95 43971.89 44372.12
System 252.84 284.66 252.61 201.24 249.00
Elapsed 1062.14 1050.96 998.68 1000.94 1026.78
Overall the system CPU usage is comparable and the test is naturally a
bit variable. The slowing of the scanner hurts numa01 but on this
machine it is an adverse workload and patches that dramatically help it
often hurt absolutely everything else.
Due to patch 2, the fault activity is interesting
Minor Faults 2097811 2656646 2597249 1981230 1636841
Major Faults 362 450 365 364 365
Note the impact preserving the write bit across protection updates and
fault reduces faults.
NUMA alloc hit 1229008 1217015 1191660 1178322 1199681
NUMA alloc miss 0 0 0 0 0
NUMA interleave hit 0 0 0 0 0
NUMA alloc local 1228514 1216317 1190871 1177448 1199021
NUMA base PTE updates 245706197 240041607 238195516 244704842 115012800
NUMA huge PMD updates 479530 468448 464868 477573 224487
NUMA page range updates 491225557 479886983 476207932 489222218 229950144
NUMA hint faults 659753 656503 641678 656926 294842
NUMA hint local faults 381604 373963 360478 337585 186249
NUMA hint local percent 57 56 56 51 63
NUMA pages migrated 5412140 6374899 6266530 5277468 5755096
AutoNUMA cost 5121% 5083% 4994% 5097% 2388%
Here the impact of slowing the PTE scanner on migratrion failures is
obvious as "NUMA base PTE updates" and "NUMA huge PMD updates" are
massively reduced even though the headline performance is very similar.
As xfsrepair was the reported workload here is the impact of the series
on it.
xfsrepair
Min real-fsmark 1183.29 ( 0.00%) 1165.73 ( 1.48%) 1152.78 ( 2.58%) 1153.64 ( 2.51%) 1177.62 ( 0.48%)
Min syst-fsmark 4107.85 ( 0.00%) 4027.75 ( 1.95%) 3986.74 ( 2.95%) 3979.16 ( 3.13%) 4048.76 ( 1.44%)
Min real-xfsrepair 441.51 ( 0.00%) 463.96 ( -5.08%) 449.50 ( -1.81%) 440.08 ( 0.32%) 439.87 ( 0.37%)
Min syst-xfsrepair 195.76 ( 0.00%) 278.47 (-42.25%) 262.34 (-34.01%) 203.70 ( -4.06%) 143.64 ( 26.62%)
Amean real-fsmark 1188.30 ( 0.00%) 1177.34 ( 0.92%) 1157.97 ( 2.55%) 1158.21 ( 2.53%) 1182.22 ( 0.51%)
Amean syst-fsmark 4111.37 ( 0.00%) 4055.70 ( 1.35%) 3987.19 ( 3.02%) 3998.72 ( 2.74%) 4061.69 ( 1.21%)
Amean real-xfsrepair 450.88 ( 0.00%) 468.32 ( -3.87%) 454.14 ( -0.72%) 442.36 ( 1.89%) 440.59 ( 2.28%)
Amean syst-xfsrepair 199.66 ( 0.00%) 290.60 (-45.55%) 277.20 (-38.84%) 204.68 ( -2.51%) 150.55 ( 24.60%)
Stddev real-fsmark 4.12 ( 0.00%) 10.82 (-162.29%) 4.14 ( -0.28%) 5.98 (-45.05%) 4.60 (-11.53%)
Stddev syst-fsmark 2.63 ( 0.00%) 20.32 (-671.82%) 0.37 ( 85.89%) 16.47 (-525.59%) 15.05 (-471.79%)
Stddev real-xfsrepair 6.87 ( 0.00%) 4.55 ( 33.75%) 3.46 ( 49.58%) 1.78 ( 74.12%) 0.52 ( 92.50%)
Stddev syst-xfsrepair 3.02 ( 0.00%) 10.30 (-241.37%) 13.17 (-336.37%) 0.71 ( 76.63%) 5.00 (-65.61%)
CoeffVar real-fsmark 0.35 ( 0.00%) 0.92 (-164.73%) 0.36 ( -2.91%) 0.52 (-48.82%) 0.39 (-12.10%)
CoeffVar syst-fsmark 0.06 ( 0.00%) 0.50 (-682.41%) 0.01 ( 85.45%) 0.41 (-543.22%) 0.37 (-478.78%)
CoeffVar real-xfsrepair 1.52 ( 0.00%) 0.97 ( 36.21%) 0.76 ( 49.94%) 0.40 ( 73.62%) 0.12 ( 92.33%)
CoeffVar syst-xfsrepair 1.51 ( 0.00%) 3.54 (-134.54%) 4.75 (-214.31%) 0.34 ( 77.20%) 3.32 (-119.63%)
Max real-fsmark 1193.39 ( 0.00%) 1191.77 ( 0.14%) 1162.90 ( 2.55%) 1166.66 ( 2.24%) 1188.50 ( 0.41%)
Max syst-fsmark 4114.18 ( 0.00%) 4075.45 ( 0.94%) 3987.65 ( 3.08%) 4019.45 ( 2.30%) 4082.80 ( 0.76%)
Max real-xfsrepair 457.80 ( 0.00%) 474.60 ( -3.67%) 457.82 ( -0.00%) 444.42 ( 2.92%) 441.03 ( 3.66%)
Max syst-xfsrepair 203.11 ( 0.00%) 303.65 (-49.50%) 294.35 (-44.92%) 205.33 ( -1.09%) 155.28 ( 23.55%)
The really relevant lines as syst-xfsrepair which is the system CPU
usage when running xfsrepair. Note that on my machine the overhead was
45% higher on 4.0-rc4 which may be part of what Dave is seeing. Once we
preserve the write bit across faults, it's only 2.51% higher on average.
With the full series applied, system CPU usage is 24.6% lower on
average.
Again, the impact of preserving the write bit on minor faults is obvious
and the impact of slowing scanning after migration failures is obvious
on the PTE updates. Note also that the number of pages migrated is much
reduced even though the headline performance is comparable.
Minor Faults 153466827 254507978 249163829 153501373 105737890
Major Faults 610 702 690 649 724
NUMA base PTE updates 217735049 210756527 217729596 216937111 144344993
NUMA huge PMD updates 129294 85044 106921 127246 79887
NUMA pages migrated 21938995 29705270 28594162 22687324 16258075
Mean sdb-avgqusz 13.47 2.54 2.55 2.47 2.49
Mean sdb-avgrqsz 202.32 140.22 139.50 139.02 138.12
Mean sdb-await 25.92 5.09 5.33 5.02 5.22
Mean sdb-r_await 4.71 0.19 0.83 0.51 0.11
Mean sdb-w_await 104.13 5.21 5.38 5.05 5.32
Mean sdb-svctm 0.59 0.13 0.14 0.13 0.14
Mean sdb-rrqm 0.16 0.00 0.00 0.00 0.00
Mean sdb-wrqm 3.59 1799.43 1826.84 1812.21 1785.67
Max sdb-avgqusz 111.06 12.13 14.05 11.66 15.60
Max sdb-avgrqsz 255.60 190.34 190.01 187.33 191.78
Max sdb-await 168.24 39.28 49.22 44.64 65.62
Max sdb-r_await 660.00 52.00 280.00 76.00 12.00
Max sdb-w_await 7804.00 39.28 49.22 44.64 65.62
Max sdb-svctm 4.00 2.82 2.86 1.98 2.84
Max sdb-rrqm 8.30 0.00 0.00 0.00 0.00
Max sdb-wrqm 34.20 5372.80 5278.60 5386.60 5546.15
FWIW, I also checked SPECjbb in different configurations but it's
similar observations -- minor faults lower, PTE update activity lower
and performance is roughly comparable against 3.19.
This patch (of 3):
Threads that share writable data within pages are grouped together as
related tasks. This decision is based on whether the PTE is marked
dirty which is subject to timing races between the PTE scanner update
and when the application writes the page. If the page is file-backed,
then background flushes and sync also affect placement. This is
unpredictable behaviour which is impossible to reason about so this
patch makes grouping decisions based on the VMA flags.
Dave Chinner reported that commit 4d9424669946 ("mm: convert
p[te|md]_mknonnuma and remaining page table manipulations") slowed down
his xfsrepair test enormously. In particular, it was using more system
time due to extra TLB flushing.
The ultimate reason turns out to be how the change to use the regular
page table accessor functions broke the NUMA grouping logic. The old
special mknuma/mknonnuma code accessed the page table present bit and
the magic NUMA bit directly, while the new code just changes the page
protections using PROT_NONE and the regular vma protections.
That sounds equivalent, and from a fault standpoint it really is, but a
subtle side effect is that the *other* protection bits of the page table
entries also change. And the code to decide how to group the NUMA
entries together used the writable bit to decide whether a particular
page was likely to be shared read-only or not.
And with the change to make the NUMA handling use the regular permission
setting functions, that writable bit was basically always cleared for
private mappings due to COW. So even if the page actually ends up being
written to in the end, the NUMA balancing would act as if it was always
shared RO.
This code is a heuristic anyway, so the fix - at least for now - is to
instead check whether the page is dirty rather than writable. The bit
doesn't change with protection changes.
NOTE! This also adds a FIXME comment to revisit this issue,
Not only should we probably re-visit the whole "is this a shared
read-only page" heuristic (we might want to take the vma permissions
into account and base this more on those than the per-page ones, and
also look at whether the particular access that triggers it is a write
or not), but the whole COW issue shows that we should think about the
NUMA fault handling some more.
For example, maybe we should do the early-COW thing that a regular fault
does. Or maybe we should accept that while using the same bits as
PROTNONE was a good thing (and got rid of the specual NUMA bit), we
might still want to just preseve the other protection bits across NUMA
faulting.
Those are bigger questions, left for later. This just fixes up the
heuristic so that it at least approximates working again. More analysis
and work needed.
Tested-by: Mel Gorman <mgorman@suse.de>
Cc: Ingo Molnar <mingo@kernel.org>,
Currently COW of an XIP file is done by first bringing in a read-only
mapping, then retrying the fault and copying the page. It is much more
efficient to tell the fault handler that a COW is being attempted (by
passing in the pre-allocated page in the vm_fault structure), and allow
the handler to perform the COW operation itself.
The handler cannot insert the page itself if there is already a read-only
mapping at that address, so allow the handler to return VM_FAULT_LOCKED
and set the fault_page to be NULL. This indicates to the MM code that the
i_mmap_lock is held instead of the page lock.
Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com>
Cc: Andreas Dilger <andreas.dilger@intel.com>
Cc: Boaz Harrosh <boaz@plexistor.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: Theodore Ts'o <tytso@mit.edu>
DAX is a replacement for the variation of XIP currently supported by the
ext2 filesystem. We have three different things in the tree called 'XIP',
and the new focus is on access to data rather than executables, so a name
change was in order. DAX stands for Direct Access. The X is for
eXciting.
The new focus on data access has resulted in more careful attention to
races that exist in the current XIP code, but are not hit by the use-case
that it was designed for. XIP's architecture worked fine for ext2, but
DAX is architected to work with modern filsystems such as ext4 and XFS.
DAX is not intended for use with btrfs; the value that btrfs adds relies
on manipulating data and writing data to different locations, while DAX's
value is for write-in-place and keeping the kernel from touching the data.
DAX was developed in order to support NV-DIMMs, but it's become clear that
its usefuless extends beyond NV-DIMMs and there are several potential
customers including the tracing machinery. Other people want to place the
kernel log in an area of memory, as long as they have a BIOS that does not
clear DRAM on reboot.
Patch 1 is a bug fix, probably worth including in 3.18.
Patches 2 & 3 are infrastructure for DAX.
Patches 4-8 replace the XIP code with its DAX equivalents, transforming
ext2 to use the DAX code as we go. Note that patch 10 is the
Documentation patch.
Patches 9-15 clean up after the XIP code, removing the infrastructure
that is no longer needed and renaming various XIP things to DAX.
Most of these patches were added after Jan found things he didn't
like in an earlier version of the ext4 patch ... that had been copied
from ext2. So ext2 i being transformed to do things the same way that
ext4 will later. The ability to mount ext2 filesystems with the 'xip'
option is retained, although the 'dax' option is now preferred.
Patch 16 adds some DAX infrastructure to support ext4.
Patch 17 adds DAX support to ext4. It is broadly similar to ext2's DAX
support, but it is more efficient than ext4's due to its support for
unwritten extents.
Patch 18 is another cleanup patch renaming XIP to DAX.
My thanks to Mathieu Desnoyers for his reviews of the v11 patchset. Most
of the changes below were based on his feedback.
This patch (of 18):
Pagecache faults recheck i_size after taking the page lock to ensure that
the fault didn't race against a truncate. We don't have a page to lock in
the XIP case, so use i_mmap_lock_read() instead. It is locked in the
truncate path in unmap_mapping_range() after updating i_size. So while we
hold it in the fault path, we are guaranteed that either i_size has
already been updated in the truncate path, or that the truncate will
subsequently call zap_page_range_single() and so remove the mapping we
have just inserted.
There is a window of time in which i_size has been reduced and the thread
has a mapping to a page which will be removed from the file, but this is
harmless as the page will not be allocated to a different purpose before
the thread's access to it is revoked.
[akpm@linux-foundation.org: switch to i_mmap_lock_read(), add comment in unmap_single_vma()]
Reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
For whatever reason, generic_access_phys() only remaps one page, but
actually allows to access arbitrary size. It's quite easy to trigger
large reads, like printing out large structure with gdb, which leads to a
crash. Fix it by remapping correct size.
Fixes: 28b2ee20c7cb ("access_process_vm device memory infrastructure")
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
Cc: <stable@vger.kernel.org>
pte_protnone_numa is only safe to use after VMA checks for PROT_NONE are
complete. Treating a real PROT_NONE PTE as a NUMA hinting fault is going
to result in strangeness so add a check for it. BUG_ON looks like
overkill but if this is hit then it's a serious bug that could result in
corruption so do not even try recovering. It would have been more
comprehensive to check VMA flags in pte_protnone_numa but it would have
made the API ugly just for a debugging check.
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com>
Faults on the huge zero page are pointless and there is a BUG_ON to catch
them during fault time. This patch reintroduces a check that avoids
marking the zero page PAGE_NONE.
With PROT_NONE, the traditional page table manipulation functions are
sufficient.
[andre.przywara@arm.com: fix compiler warning in pmdp_invalidate()]
[akpm@linux-foundation.org: fix build with STRICT_MM_TYPECHECKS]
Acked-by: Aneesh Kumar <aneesh.kumar@linux.vnet.ibm.com>
Tested-by: Sasha Levin <sasha.levin@oracle.com>
Convert existing users of pte_numa and friends to the new helper. Note
that the kernel is broken after this patch is applied until the other page
table modifiers are also altered. This patch layout is to make review
easier.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Dave noticed that unprivileged process can allocate significant amount of
memory -- >500 MiB on x86_64 -- and stay unnoticed by oom-killer and
memory cgroup. The trick is to allocate a lot of PMD page tables. Linux
kernel doesn't account PMD tables to the process, only PTE.
The use-cases below use few tricks to allocate a lot of PMD page tables
while keeping VmRSS and VmPTE low. oom_score for the process will be 0.
#include <errno.h>
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <sys/mman.h>
#include <sys/prctl.h>
#define PUD_SIZE (1UL << 30)
#define PMD_SIZE (1UL << 21)
#define NR_PUD 130000
int main(void)
char *addr = NULL;
unsigned long i;
prctl(PR_SET_THP_DISABLE);
for (i = 0; i < NR_PUD ; i++) {
addr = mmap(addr + PUD_SIZE, PUD_SIZE, PROT_WRITE|PROT_READ,
MAP_ANONYMOUS|MAP_PRIVATE, -1, 0);
if (addr == MAP_FAILED) {
perror("mmap");
break;
*addr = 'x';
munmap(addr, PMD_SIZE);
mmap(addr, PMD_SIZE, PROT_WRITE|PROT_READ,
MAP_ANONYMOUS|MAP_PRIVATE|MAP_FIXED, -1, 0);
perror("re-mmap"), exit(1);
printf("PID %d consumed %lu KiB in PMD page tables\n",
getpid(), i * 4096 >> 10);
return pause();
The patch addresses the issue by account PMD tables to the process the
same way we account PTE.
The main place where PMD tables is accounted is __pmd_alloc() and
free_pmd_range(). But there're few corner cases:
- HugeTLB can share PMD page tables. The patch handles by accounting
the table to all processes who share it.
- x86 PAE pre-allocates few PMD tables on fork.
- Architectures with FIRST_USER_ADDRESS > 0. We need to adjust sanity
check on exit(2).
Accounting only happens on configuration where PMD page table's level is
present (PMD is not folded). As with nr_ptes we use per-mm counter. The
counter value is used to calculate baseline for badness score by
oom-killer.
Reported-by: Dave Hansen <dave.hansen@linux.intel.com>
Reviewed-by: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Pavel Emelyanov <xemul@openvz.org>
Tested-by: Sedat Dilek <sedat.dilek@gmail.com>
Merge misc updates from Andrew Morton:
"Bite-sized chunks this time, to avoid the MTA ratelimiting woes.
- fs/notify updates
- ocfs2
- some of MM"
That laconic "some MM" is mainly the removal of remap_file_pages(),
which is a big simplification of the VM, and which gets rid of a *lot*
of random cruft and special cases because we no longer support the
non-linear mappings that it used.
From a user interface perspective, nothing has changed, because the
remap_file_pages() syscall still exists, it's just done by emulating the
old behavior by creating a lot of individual small mappings instead of
one non-linear one.
The emulation is slower than the old "native" non-linear mappings, but
nobody really uses or cares about remap_file_pages(), and simplifying
the VM is a big advantage.
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (78 commits)
memcg: zap memcg_slab_caches and memcg_slab_mutex
memcg: zap memcg_name argument of memcg_create_kmem_cache
memcg: zap __memcg_{charge,uncharge}_slab
mm/page_alloc.c: place zone_id check before VM_BUG_ON_PAGE check
mm: hugetlb: fix type of hugetlb_treat_as_movable variable
mm, hugetlb: remove unnecessary lower bound on sysctl handlers"?
mm: memory: merge shared-writable dirtying branches in do_wp_page()
mm: memory: remove ->vm_file check on shared writable vmas
xtensa: drop _PAGE_FILE and pte_file()-related helpers
x86: drop _PAGE_FILE and pte_file()-related helpers
unicore32: drop pte_file()-related helpers
um: drop _PAGE_FILE and pte_file()-related helpers
tile: drop pte_file()-related helpers
sparc: drop pte_file()-related helpers
sh: drop _PAGE_FILE and pte_file()-related helpers
score: drop _PAGE_FILE and pte_file()-related helpers
s390: drop pte_file()-related helpers
parisc: drop _PAGE_FILE and pte_file()-related helpers
openrisc: drop _PAGE_FILE and pte_file()-related helpers
nios2: drop _PAGE_FILE and pte_file()-related helpers
Whether there is a vm_ops->page_mkwrite or not, the page dirtying is
pretty much the same. Make sure the page references are the same in both
cases, then merge the two branches.
It's tempting to go even further and page-lock the !page_mkwrite case, to
get it in line with everybody else setting the page table and thus further
simplify the model. But that's not quite compelling enough to justify
dropping the pte lock, then relocking and verifying the entry for
filesystems without ->page_mkwrite, which notably includes tmpfs. Leave
it for now and lock the page late in the !page_mkwrite case.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Shared anonymous mmaps are implemented with shmem files, so all VMAs with
shared writable semantics also have an underlying backing file.
One bit in ->vm_flags is unused now!
Cc: Dan Carpenter <dan.carpenter@oracle.com>
We don't create non-linear mappings anymore. Let's drop code which
handles them on page fault.
We have remap_file_pages(2) emulation in -mm tree for few release cycles
and we plan to have it mainline in v3.20. This patchset removes rest of
VM_NONLINEAR infrastructure.
Patches 1-8 take care about generic code. They are pretty
straight-forward and can be applied without other of patches.
Rest patches removes pte_file()-related stuff from architecture-specific
code. It usually frees up one bit in non-present pte. I've tried to reuse
that bit for swap offset, where I was able to figure out how to do that.
For obvious reason I cannot test all that arch-specific code and would
like to see acks from maintainers.
In total, remap_file_pages(2) required about 1.4K lines of not-so-trivial
kernel code. That's too much for functionality nobody uses.
Tested-by: Felipe Balbi <balbi@ti.com>
This patch (of 38):
handles them on unmap/zap.
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull xen features and fixes from David Vrabel:
- Reworked handling for foreign (grant mapped) pages to simplify the
code, enable a number of additional use cases and fix a number of
long-standing bugs.
- Prefer the TSC over the Xen PV clock when dom0 (and the TSC is
stable).
- Assorted other cleanup and minor bug fixes.
* tag 'stable/for-linus-3.20-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: (25 commits)
xen/manage: Fix USB interaction issues when resuming
xenbus: Add proper handling of XS_ERROR from Xenbus for transactions.
xen/gntdev: provide find_special_page VMA operation
xen/gntdev: mark userspace PTEs as special on x86 PV guests
xen-blkback: safely unmap grants in case they are still in use
xen/gntdev: safely unmap grants in case they are still in use
xen/gntdev: convert priv->lock to a mutex
xen/grant-table: add a mechanism to safely unmap pages that are in use
xen-netback: use foreign page information from the pages themselves
xen: mark grant mapped pages as foreign
xen/grant-table: add helpers for allocating pages
x86/xen: require ballooned pages for grant maps
xen: remove scratch frames for ballooned pages and m2p override
xen/grant-table: pre-populate kernel unmap ops for xen_gnttab_unmap_refs()
mm: add 'foreign' alias for the 'pinned' page flag
mm: provide a find_special_page vma operation
x86/xen: cleanup arch/x86/xen/mmu.c
x86/xen: add some __init annotations in arch/x86/xen/mmu.c
x86/xen: add some __init and static annotations in arch/x86/xen/setup.c
x86/xen: use correct types for addresses in arch/x86/xen/setup.c
The stack guard page error case has long incorrectly caused a SIGBUS
rather than a SIGSEGV, but nobody actually noticed until commit
fee7e49d4514 ("mm: propagate error from stack expansion even for guard
page") because that error case was never actually triggered in any
normal situations.
Now that we actually report the error, people noticed the wrong signal
that resulted. So far, only the test suite of libsigsegv seems to have
actually cared, but there are real applications that use libsigsegv, so
let's not wait for any of those to break.
Reported-and-tested-by: Takashi Iwai <tiwai@suse.de>
Tested-by: Jan Engelhardt <jengelh@inai.de>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots"
Cc: stable@vger.kernel.org
The optional find_special_page VMA operation is used to lookup the
pages backing a VMA. This is useful in cases where the normal
mechanisms for finding the page don't work. This is only called if
the PTE is special.
One use case is a Xen PV guest mapping foreign pages into userspace.
In a Xen PV guest, the PTEs contain MFNs so get_user_pages() (for
example) must do an MFN to PFN (M2P) lookup before it can get the
page. For foreign pages (those owned by another guest) the M2P lookup
returns the PFN as seen by the foreign guest (which would be
completely the wrong page for the local guest).
This cannot be fixed up improving the M2P lookup since one MFN may be
mapped onto two or more pages so getting the right page is impossible
given just the MFN.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
When batching up address ranges for TLB invalidation, we check tlb->end
!= 0 to indicate that some pages have actually been unmapped.
As of commit f045bbb9fa1b ("mmu_gather: fix over-eager
tlb_flush_mmu_free() calling"), we use the same check for freeing these
pages in order to avoid a performance regression where we call
free_pages_and_swap_cache even when no pages are actually queued up.
Unfortunately, the range could have been reset (tlb->end = 0) by
tlb_end_vma, which has been shown to cause memory leaks on arm64.
Furthermore, investigation into these leaks revealed that the fullmm
case on task exit no longer invalidates the TLB, by virtue of tlb->end
== 0 (in 3.18, need_flush would have been set).
This patch resolves the problem by reverting commit f045bbb9fa1b, using
instead tlb->local.nr as the predicate for page freeing in
tlb_flush_mmu_free and ensuring that tlb->end is initialised to a
non-zero value in the fullmm case.
Tested-by: Mark Langsdorf <mlangsdo@redhat.com>
Tested-by: Dave Hansen <dave@sr71.net>
Tejun, while reviewing the code, spotted the following race condition
between the dirtying and truncation of a page:
__set_page_dirty_nobuffers() __delete_from_page_cache()
if (TestSetPageDirty(page))
page->mapping = NULL
if (PageDirty())
dec_zone_page_state(page, NR_FILE_DIRTY);
dec_bdi_stat(mapping->backing_dev_info, BDI_RECLAIMABLE);
if (page->mapping)
account_page_dirtied(page)
__inc_zone_page_state(page, NR_FILE_DIRTY);
__inc_bdi_stat(mapping->backing_dev_info, BDI_RECLAIMABLE);
which results in an imbalance of NR_FILE_DIRTY and BDI_RECLAIMABLE.
Dirtiers usually lock out truncation, either by holding the page lock
directly, or in case of zap_pte_range(), by pinning the mapcount with
the page table lock held. The notable exception to this rule, though,
is do_wp_page(), for which this race exists. However, do_wp_page()
already waits for a locked page to unlock before setting the dirty bit,
in order to prevent a race where clear_page_dirty() misses the page bit
in the presence of dirty ptes. Upgrade that wait to a fully locked
set_page_dirty() to also cover the situation explained above.
Afterwards, the code in set_page_dirty() dealing with a truncation race
is no longer needed. Remove it.
Reported-by: Tejun Heo <tj@kernel.org>
Jay Foad reports that the address sanitizer test (asan) sometimes gets
confused by a stack pointer that ends up being outside the stack vma
that is reported by /proc/maps.
This happens due to an interaction between RLIMIT_STACK and the guard
page: when we do the guard page check, we ignore the potential error
from the stack expansion, which effectively results in a missing guard
page, since the expected stack expansion won't have been done.
And since /proc/maps explicitly ignores the guard page (commit
d7824370e263: "mm: fix up some user-visible effects of the stack guard
page"), the stack pointer ends up being outside the reported stack area.
This is the minimal patch: it just propagates the error. It also
effectively makes the guard page part of the stack limit, which in turn
measn that the actual real stack is one page less than the stack limit.
Let's see if anybody notices. We could teach acct_stack_growth() to
allow an extra page for a grow-up/grow-down stack in the rlimit test,
but I don't want to add more complexity if it isn't needed.
Reported-and-tested-by: Jay Foad <jay.foad@gmail.com>
This reverts commit c8475d144abb1e62958cc5ec281d2a9e161c1946.
There are several[1][2] of bug reports which points to this commit as potential
cause[3].
Let's revert it until we figure out what's going on.
[1] https://lkml.org/lkml/2014/11/14/342
[2] https://lkml.org/lkml/2014/12/22/213
[3] https://lkml.org/lkml/2014/12/9/741
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Cc: Peter Zijlstra (Intel) <peterz@infradead.org>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/borntraeger/linux
Pull ACCESS_ONCE cleanup preparation from Christian Borntraeger:
"kernel: Provide READ_ONCE and ASSIGN_ONCE
As discussed on LKML http://marc.info/?i=54611D86.4040306%40de.ibm.com
ACCESS_ONCE might fail with specific compilers for non-scalar
accesses.
Here is a set of patches to tackle that problem.
The first patch introduce READ_ONCE and ASSIGN_ONCE. If the data
structure is larger than the machine word size memcpy is used and a
warning is emitted. The next patches fix up several in-tree users of
ACCESS_ONCE on non-scalar types.
This does not yet contain a patch that forces ACCESS_ONCE to work only
on scalar types. This is targetted for the next merge window as Linux
next already contains new offenders regarding ACCESS_ONCE vs.
non-scalar types"
* tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/borntraeger/linux:
s390/kvm: REPLACE barrier fixup with READ_ONCE
arm/spinlock: Replace ACCESS_ONCE with READ_ONCE
arm64/spinlock: Replace ACCESS_ONCE READ_ONCE
mips/gup: Replace ACCESS_ONCE with READ_ONCE
x86/gup: Replace ACCESS_ONCE with READ_ONCE
x86/spinlock: Replace ACCESS_ONCE with READ_ONCE
mm: replace ACCESS_ONCE with READ_ONCE or barriers
Belatedly document the changes in commit f0c6d4d295e4 ("mm: introduce
do_shared_fault() and drop do_fault()").
Cc: Bob Liu <lliubbo@gmail.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
ACCESS_ONCE does not work reliably on non-scalar types. For
example gcc 4.6 and 4.7 might remove the volatile tag for such
accesses during the SRA (scalar replacement of aggregates) step
(https://gcc.gnu.org/bugzilla/show_bug.cgi?id=58145)
Let's change the code to access the page table elements with
READ_ONCE that does implicit scalar accesses for the gup code.
mm_find_pmd is tricky, because m68k and sparc(32bit) define pmd_t
as array of longs. This code requires just that the pmd_present
and pmd_trans_huge check are done on the same value, so a barrier
is sufficent.
A similar case is in handle_pte_fault. On ppc44x the word size is
32 bit, but a pte is 64 bit. A barrier is ok as well.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: linux-mm@kvack.org
Dave Hansen reports that commit fb7332a9fedf ("mmu_gather: move minimal
range calculations into generic code") caused a performance problem:
"tlb_finish_mmu() goes up about 9x in the profiles (~0.4%->3.6%) and
tlb_flush_mmu_free() takes about 3.1% of CPU time with the patch
applied, but does not show up at all on the commit before"
and the reason is that Will moved the test for whether we need to flush
from tlb_flush_mmu() into tlb_flush_mmu_tlbonly(). But that meant that
tlb_flush_mmu_free() basically lost that check.
Move it back into tlb_flush_mmu() where it belongs, so that it covers
both tlb_flush_mmu_tlbonly() _and_ tlb_flush_mmu_free().
Reported-and-tested-by: Dave Hansen <dave@sr71.net>
Acked-by: Will Deacon <will.deacon@arm.com>
Pull drm updates from Dave Airlie:
"Highlights:
- AMD KFD driver merge
This is the AMD HSA interface for exposing a lowlevel interface for
GPGPU use. They have an open source userspace built on top of this
interface, and the code looks as good as it was going to get out of
tree.
- Initial atomic modesetting work
The need for an atomic modesetting interface to allow userspace to
try and send a complete set of modesetting state to the driver has
arisen, and been suffering from neglect this past year. No more,
the start of the common code and changes for msm driver to use it
are in this tree. Ongoing work to get the userspace ioctl finished
and the code clean will probably wait until next kernel.
- DisplayID 1.3 and tiled monitor exposed to userspace.
Tiled monitor property is now exposed for userspace to make use of.
- Rockchip drm driver merged.
- imx gpu driver moved out of staging
Other stuff:
- core:
panel - MIPI DSI + new panels.
expose suggested x/y properties for virtual GPUs
- i915:
Initial Skylake (SKL) support
gen3/4 reset work
start of dri1/ums removal
infoframe tracking
fixes for lots of things.
- nouveau:
tegra k1 voltage support
GM204 modesetting support
GT21x memory reclocking work
- radeon:
CI dpm fixes
GPUVM improvements
Initial DPM fan control
- rcar-du:
HDMI support added
removed some support for old boards
slave encoder driver for Analog Devices adv7511
- exynos:
Exynos4415 SoC support
- msm:
a4xx gpu support
atomic helper conversion
- tegra:
iommu support
universal plane support
ganged-mode DSI support
- sti:
HDMI i2c improvements
- vmwgfx:
some late fixes.
- qxl:
use suggested x/y properties"
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (969 commits)
drm: sti: fix module compilation issue
drm/i915: save/restore GMBUS freq across suspend/resume on gen4
drm: sti: correctly cleanup CRTC and planes
drm: sti: add HQVDP plane
drm: sti: add cursor plane
drm: sti: enable auxiliary CRTC
drm: sti: fix delay in VTG programming
drm: sti: prepare sti_tvout to support auxiliary crtc
drm: sti: use drm_crtc_vblank_{on/off} instead of drm_vblank_{on/off}
drm: sti: fix hdmi avi infoframe
drm: sti: remove event lock while disabling vblank
drm: sti: simplify gdp code
drm: sti: clear all mixer control
drm: sti: remove gpio for HDMI hot plug detection
drm: sti: allow to change hdmi ddc i2c adapter
drm/doc: Document drm_add_modes_noedid() usage
drm/i915: Remove '& 0xffff' from the mask given to WA_REG()
drm/i915: Invert the mask and val arguments in wa_add() and WA_REG()
drm: Zero out DRM object memory upon cleanup
drm/i915/bdw: Fix the write setting up the WIZ hashing mode
This lets drivers like the AMD IOMMUv2 driver handle faults a bit more
simply, rather than doing tricks with page refs and get_user_pages().
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: Oded Gabbay <oded.gabbay@amd.com>
Cc: Joerg Roedel <jroedel@suse.de>
The unmap_mapping_range family of functions do the unmapping of user pages
(ultimately via zap_page_range_single) without touching the actual
interval tree, thus share the lock.
Signed-off-by: Davidlohr Bueso <dbueso@suse.de>
Convert all open coded mutex_lock/unlock calls to the
i_mmap_[lock/unlock]_write() helpers.
Acked-by: "Kirill A. Shutemov" <kirill@shutemov.name>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 updates from Martin Schwidefsky:
"The most notable change for this pull request is the ftrace rework
from Heiko. It brings a small performance improvement and the ground
work to support a new gcc option to replace the mcount blocks with a
single nop.
Two new s390 specific system calls are added to emulate user space
mmio for PCI, an artifact of the how PCI memory is accessed.
Two patches for the memory management with changes to common code.
For KVM mm_forbids_zeropage is added which disables the empty zero
page for an mm that is used by a KVM process. And an optimization,
pmdp_get_and_clear_full is added analog to ptep_get_and_clear_full.
Some micro optimization for the cmpxchg and the spinlock code.
And as usual bug fixes and cleanups"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (46 commits)
s390/cputime: fix 31-bit compile
s390/scm_block: make the number of reqs per HW req configurable
s390/scm_block: handle multiple requests in one HW request
s390/scm_block: allocate aidaw pages only when necessary
s390/scm_block: use mempool to manage aidaw requests
s390/eadm: change timeout value
s390/mm: fix memory leak of ptlock in pmd_free_tlb
s390: use local symbol names in entry[64].S
s390/ptrace: always include vector registers in core files
s390/simd: clear vector register pointer on fork/clone
s390: translate cputime magic constants to macros
s390/idle: convert open coded idle time seqcount
s390/idle: add missing irq off lockdep annotation
s390/debug: avoid function call for debug_sprintf_*
s390/kprobes: fix instruction copy for out of line execution
s390: remove diag 44 calls from cpu_relax()
s390/dasd: retry partition detection
s390/dasd: fix list corruption for sleep_on requests
s390/dasd: fix infinite term I/O loop
s390/dasd: remove unused code
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 updates from Will Deacon:
"Here's the usual mixed bag of arm64 updates, also including some
related EFI changes (Acked by Matt) and the MMU gather range cleanup
(Acked by you).
Changes include:
- support for alternative instruction patching from Andre
- seccomp from Akashi
- some AArch32 instruction emulation, required by the Android folks
- optimisations for exception entry/exit code, cmpxchg, pcpu atomics
- mmu_gather range calculations moved into core code
- EFI updates from Ard, including long-awaited SMBIOS support
- /proc/cpuinfo fixes to align with the format used by arch/arm/
- a few non-critical fixes across the architecture"
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (70 commits)
arm64: remove the unnecessary arm64_swiotlb_init()
arm64: add module support for alternatives fixups
arm64: perf: Prevent wraparound during overflow
arm64/include/asm: Fixed a warning about 'struct pt_regs'
arm64: Provide a namespace to NCAPS
arm64: bpf: lift restriction on last instruction
arm64: Implement support for read-mostly sections
arm64: compat: align cacheflush syscall with arch/arm
arm64: add seccomp support
arm64: add SIGSYS siginfo for compat task
arm64: add seccomp syscall for compat task
asm-generic: add generic seccomp.h for secure computing mode 1
arm64: ptrace: allow tracer to skip a system call
arm64: ptrace: add NT_ARM_SYSTEM_CALL regset
arm64: Move some head.text functions to executable section
arm64: jump labels: NOP out NOP -> NOP replacement
arm64: add support to dump the kernel page tables
arm64: Add FIX_HOLE to permanent fixed addresses
arm64: alternatives: fix pr_fmt string for consistency
arm64: vmlinux.lds.S: don't discard .exit.* sections at link-time
Linux 3.18
Backmerge Linus tree into -next as we had conflicts in i915/radeon/nouveau,
and everyone was solving them individually.
* tag 'v3.18': (57 commits)
Linux 3.18
watchdog: s3c2410_wdt: Fix the mask bit offset for Exynos7
uapi: fix to export linux/vm_sockets.h
i2c: cadence: Set the hardware time-out register to maximum value
i2c: davinci: generate STP always when NACK is received
ahci: disable MSI on SAMSUNG 0xa800 SSD
context_tracking: Restore previous state in schedule_user
slab: fix nodeid bounds check for non-contiguous node IDs
lib/genalloc.c: export devm_gen_pool_create() for modules
mm: fix anon_vma_clone() error treatment
mm: fix swapoff hang after page migration and fork
fat: fix oops on corrupted vfat fs
ipc/sem.c: fully initialize sem_array before making it visible
drivers/input/evdev.c: don't kfree() a vmalloc address
cxgb4: Fill in supported link mode for SFP modules
xen-netfront: Remove BUGs on paged skb data which crosses a page boundary
mm/vmpressure.c: fix race in vmpressure_work_fn()
mm: frontswap: invalidate expired data on a dup-store failure
mm: do not overwrite reserved pages counter at show_mem()
drm/radeon: kernel panic in drm_calc_vbltimestamp_from_scanoutpos with 3.18.0-rc6
drivers/gpu/drm/i915/intel_display.c
drivers/gpu/drm/nouveau/nouveau_drm.c
drivers/gpu/drm/radeon/radeon_cs.c
I've been seeing swapoff hangs in recent testing: it's cycling around
trying unsuccessfully to find an mm for some remaining pages of swap.
I have been exercising swap and page migration more heavily recently,
and now notice a long-standing error in copy_one_pte(): it's trying to
add dst_mm to swapoff's mmlist when it finds a swap entry, but is doing
so even when it's a migration entry or an hwpoison entry.
Which wouldn't matter much, except it adds dst_mm next to src_mm,
assuming src_mm is already on the mmlist: which may not be so. Then if
pages are later swapped out from dst_mm, swapoff won't be able to find
where to replace them.
There's already a !non_swap_entry() test for stats: move that up before
the swap_duplicate() and the addition to mmlist.
Cc: Kelley Nielsen <kelleynnn@gmail.com>
Cc: <stable@vger.kernel.org> [2.6.18+]
On architectures with hardware broadcasting of TLB invalidation messages
, it makes sense to reduce the range of the mmu_gather structure when
unmapping page ranges based on the dirty address information passed to
tlb_remove_tlb_entry.
arm64 already does this by directly manipulating the start/end fields
of the gather structure, but this confuses the generic code which
does not expect these fields to change and can end up calculating
invalid, negative ranges when forcing a flush in zap_pte_range.
This patch moves the minimal range calculation out of the arm64 code
and into the generic implementation, simplifying zap_pte_range in the
process (which no longer needs to care about start/end, since they will
point to the appropriate ranges already). With the range being tracked
by core code, the need_flush flag is dropped in favour of checking that
the end of the range has actually been set.
Cc: Russell King - ARM Linux <linux@arm.linux.org.uk>
When unmapping a range of pages in zap_pte_range, the page being
unmapped is added to an mmu_gather_batch structure for asynchronous
freeing. If we run out of space in the batch structure before the range
has been completely unmapped, then we break out of the loop, force a
TLB flush and free the pages that we have batched so far. If there are
further pages to unmap, then we resume the loop where we left off.
Unfortunately, we forget to update addr when we break out of the loop,
which causes us to truncate the range being invalidated as the end
address is exclusive. When we re-enter the loop at the same address, the
page has already been freed and the pte_present test will fail, meaning
that we do not reconsider the address for invalidation.
This patch fixes the problem by incrementing addr by the PAGE_SIZE
before breaking out of the loop on batch failure.
Add a new function stub to allow architectures to disable for
an mm_structthe backing of non-present, anonymous pages with
read-only empty zero pages.
Signed-off-by: Dominik Dingel <dingel@linux.vnet.ibm.com>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
For VMAs that don't want write notifications, PTEs created for read faults
have their write bit set. If the read fault happens after VM_SOFTDIRTY is
cleared, then the PTE's softdirty bit will remain clear after subsequent
writes.
Here's a simple code snippet to demonstrate the bug:
char* m = mmap(NULL, getpagesize(), PROT_READ | PROT_WRITE,
MAP_ANONYMOUS | MAP_SHARED, -1, 0);
system("echo 4 > /proc/$PPID/clear_refs"); /* clear VM_SOFTDIRTY */
assert(*m == '\0'); /* new PTE allows write access */
assert(!soft_dirty(x));
*m = 'x'; /* should dirty the page */
assert(soft_dirty(x)); /* fails */
With this patch, write notifications are enabled when VM_SOFTDIRTY is
cleared. Furthermore, to avoid unnecessary faults, write notifications
are disabled when VM_SOFTDIRTY is set.
As a side effect of enabling and disabling write notifications with
care, this patch fixes a bug in mprotect where vm_page_prot bits set by
drivers were zapped on mprotect. An analogous bug was fixed in mmap by
commit c9d0bf241451 ("mm: uncached vma support with writenotify").
Signed-off-by: Peter Feiner <pfeiner@google.com>
Reported-by: Peter Feiner <pfeiner@google.com>
Suggested-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Jamie Liu <jamieliu@google.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
This fixes the same bug as b43790eedd31 ("mm: softdirty: don't forget to
save file map softdiry bit on unmap") and 9aed8614af5a ("mm/memory.c:
don't forget to set softdirty on file mapped fault") where the return
value of pte_*mksoft_dirty was being ignored.
To be sure that no other pte/pmd "mk" function return values were being
ignored, I annotated the functions in arch/x86/include/asm/pgtable.h
with __must_check and rebuilt.
The userspace effect of this bug is that the softdirty mark might be
lost if a file mapped pte get zapped.
Acked-by: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: <stable@vger.kernel.org> [3.12+]
