path: root/mm/memory.c
2009-07-27mm: Pass virtual address to [__]p{te,ud,md}_free_tlb()Benjamin Herrenschmidt
mm: Pass virtual address to [__]p{te,ud,md}_free_tlb() Upcoming paches to support the new 64-bit "BookE" powerpc architecture will need to have the virtual address corresponding to PTE page when freeing it, due to the way the HW table walker works. Basically, the TLB can be loaded with "large" pages that cover the whole virtual space (well, sort-of, half of it actually) represented by a PTE page, and which contain an "indirect" bit indicating that this TLB entry RPN points to an array of PTEs from which the TLB can then create direct entries. Thus, in order to invalidate those when PTE pages are deleted, we need the virtual address to pass to tlbilx or tlbivax instructions. The old trick of sticking it somewhere in the PTE page struct page sucks too much, the address is almost readily available in all call sites and almost everybody implemets these as macros, so we may as well add the argument everywhere. I added it to the pmd and pud variants for consistency. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: David Howells <dhowells@redhat.com> [MN10300 & FRV] Acked-by: Nick Piggin <npiggin@suse.de> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-25clarify get_user_pages() prototypePeter Zijlstra
Currently the 4th parameter of get_user_pages() is called len, but its in pages, not bytes. Rename the thing to nr_pages to avoid future confusion. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-23mm: pass mm to grab_swap_tokenHugh Dickins
If a kthread happens to use get_user_pages() on an mm (as KSM does), there's a chance that it will end up trying to read in a swap page, then oops in grab_swap_token() because the kthread has no mm: GUP passes down the right mm, so grab_swap_token() ought to be using it. We have not identified a stronger case than KSM's daemon (not yet in mainline), but the issue must have come up before, since RHEL has included a fix for this for years (though a different fix, they just back out of grab_swap_token if current->mm is unset: which is what we first proposed, but using the right mm here seems more correct). Reported-by: Izik Eidus <ieidus@redhat.com> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-23mm: don't rely on flags coincidenceHugh Dickins
Indeed FOLL_WRITE matches FAULT_FLAG_WRITE, matches GUP_FLAGS_WRITE, and it's tempting to devise a set of Grand Unified Paging flags; but not today. So until then, let's rely upon the compiler to spot the coincidence, "rather than have that subtle dependency and a comment for it" - as you remarked in another context yesterday. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Acked-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-21Move FAULT_FLAG_xyz into handle_mm_fault() callersLinus Torvalds
This allows the callers to now pass down the full set of FAULT_FLAG_xyz flags to handle_mm_fault(). All callers have been (mechanically) converted to the new calling convention, there's almost certainly room for architectures to clean up their code and then add FAULT_FLAG_RETRY when that support is added. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-21Remove internal use of 'write_access' in mm/memory.cLinus Torvalds
The fault handling routines really want more fine-grained flags than a single "was it a write fault" boolean - the callers will want to set flags like "you can return a retry error" etc. And that's actually how the VM works internally, but right now the top-level fault handling functions in mm/memory.c all pass just the 'write_access' boolean around. This switches them over to pass around the FAULT_FLAG_xyzzy 'flags' variable instead. The 'write_access' calling convention still exists for the exported 'handle_mm_fault()' function, but that is next. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: introduce follow_pfn()Johannes Weiner
Analoguous to follow_phys(), add a helper that looks up the PFN at a user virtual address in an IO mapping or a raw PFN mapping. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Christoph Hellwig <hch@infradead.org> Acked-by: Magnus Damm <magnus.damm@gmail.com> Cc: Hans Verkuil <hverkuil@xs4all.nl> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: use generic follow_pte() in follow_phys()Johannes Weiner
2009-06-16mm: introduce follow_pte()Johannes Weiner
A generic readonly page table lookup helper to map an address space and an address from it to a pte. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Christoph Hellwig <hch@infradead.org> Acked-by: Magnus Damm <magnus.damm@gmail.com> Cc: Hans Verkuil <hverkuil@xs4all.nl> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: clean up get_user_pages_fast() documentationNick Piggin
Move more documentation for get_user_pages_fast into the new kerneldoc comment. Add some comments for get_user_pages as well. Also, move get_user_pages_fast declaration up to get_user_pages. It wasn't there initially because it was once a static inline function. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Andy Grover <andy.grover@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-02mm: close page_mkwrite racesNick Piggin
Change page_mkwrite to allow implementations to return with the page locked, and also change it's callers (in page fault paths) to hold the lock until the page is marked dirty. This allows the filesystem to have full control of page dirtying events coming from the VM. Rather than simply hold the page locked over the page_mkwrite call, we call page_mkwrite with the page unlocked and allow callers to return with it locked, so filesystems can avoid LOR conditions with page lock. The problem with the current scheme is this: a filesystem that wants to associate some metadata with a page as long as the page is dirty, will perform this manipulation in its ->page_mkwrite. It currently then must return with the page unlocked and may not hold any other locks (according to existing page_mkwrite convention). In this window, the VM could write out the page, clearing page-dirty. The filesystem has no good way to detect that a dirty pte is about to be attached, so it will happily write out the page, at which point, the filesystem may manipulate the metadata to reflect that the page is no longer dirty. It is not always possible to perform the required metadata manipulation in ->set_page_dirty, because that function cannot block or fail. The filesystem may need to allocate some data structure, for example. And the VM cannot mark the pte dirty before page_mkwrite, because page_mkwrite is allowed to fail, so we must not allow any window where the page could be written to if page_mkwrite does fail. This solution of holding the page locked over the 3 critical operations (page_mkwrite, setting the pte dirty, and finally setting the page dirty) closes out races nicely, preventing page cleaning for writeout being initiated in that window. This provides the filesystem with a strong synchronisation against the VM here. - Sage needs this race closed for ceph filesystem. - Trond for NFS (http://bugzilla.kernel.org/show_bug.cgi?id=12913). - I need it for fsblock. - I suspect other filesystems may need it too (eg. btrfs). - I have converted buffer.c to the new locking. Even simple block allocation under dirty pages might be susceptible to i_size changing under partial page at the end of file (we also have a buffer.c-side problem here, but it cannot be fixed properly without this patch). - Other filesystems (eg. NFS, maybe btrfs) will need to change their page_mkwrite functions themselves. [ This also moves page_mkwrite another step closer to fault, which should eventually allow page_mkwrite to be moved into ->fault, and thus avoiding a filesystem calldown and page lock/unlock cycle in __do_fault. ] [akpm@linux-foundation.org: fix derefs of NULL ->mapping] Cc: Sage Weil <sage@newdream.net> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Valdis Kletnieks <Valdis.Kletnieks@vt.edu> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-02mm: fix pageref leak in do_swap_page()Johannes Weiner
By the time the memory cgroup code is notified about a swapin we already hold a reference on the fault page. If the cgroup callback fails make sure to unlock AND release the page reference which was taken by lookup_swap_cach(), or we leak the reference. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01mm: page_mkwrite change prototype to match faultNick Piggin
Change the page_mkwrite prototype to take a struct vm_fault, and return VM_FAULT_xxx flags. There should be no functional change. This makes it possible to return much more detailed error information to the VM (and also can provide more information eg. virtual_address to the driver, which might be important in some special cases). This is required for a subsequent fix. And will also make it easier to merge page_mkwrite() with fault() in future. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Chris Mason <chris.mason@oracle.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Miklos Szeredi <miklos@szeredi.hu> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <joel.becker@oracle.com> Cc: Artem Bityutskiy <dedekind@infradead.org> Cc: Felix Blyakher <felixb@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01mm: add comment why mark_page_accessed() would be better than pte_mkyoung() ↵KOSAKI Motohiro
in follow_page() At first look, mark_page_accessed() in follow_page() seems a bit strange. It seems pte_mkyoung() would be better consistent with other kernel code. However, it is intentional. The commit log said: ------------------------------------------------ commit 9e45f61d69be9024a2e6bef3831fb04d90fac7a8 Author: akpm <akpm> Date: Fri Aug 15 07:24:59 2003 +0000 [PATCH] Use mark_page_accessed() in follow_page() Touching a page via follow_page() counts as a reference so we should be either setting the referenced bit in the pte or running mark_page_accessed(). Altering the pte is tricky because we haven't implemented an atomic pte_mkyoung(). And mark_page_accessed() is better anyway because it has more aging state: it can move the page onto the active list. BKrev: 3f3c8acbplT8FbwBVGtth7QmnqWkIw ------------------------------------------------ The atomic issue is still true nowadays. adding comment help to understand code intention and it would be better. [akpm@linux-foundation.org: clarify text] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01mm: don't call mark_page_accessed() in do_swap_page()KOSAKI Motohiro
commit bf3f3bc5e734706730c12a323f9b2068052aa1f0 (mm: don't mark_page_accessed in fault path) only remove the mark_page_accessed() in filemap_fault(). Therefore, swap-backed pages and file-backed pages have inconsistent behavior. mark_page_accessed() should be removed from do_swap_page(). Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-14VM, x86, PAT: add a new vm flag to track full pfnmap at mmapPallipadi, Venkatesh
Impact: cleanup Add a new vm flag VM_PFN_AT_MMAP to identify a PFNMAP that is fully mapped with remap_pfn_range. Patch removes the overloading of VM_INSERTPAGE from the earlier patch. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Acked-by: Nick Piggin <npiggin@suse.de> LKML-Reference: <20090313233543.GA19909@linux-os.sc.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-13VM, x86, PAT: Change is_linear_pfn_mapping to not use vm_pgoffPallipadi, Venkatesh
Impact: fix false positive PAT warnings - also fix VirtalBox hang Use of vma->vm_pgoff to identify the pfnmaps that are fully mapped at mmap time is broken. vm_pgoff is set by generic mmap code even for cases where drivers are setting up the mappings at the fault time. The problem was originally reported here: http://marc.info/?l=linux-kernel&m=123383810628583&w=2 Change is_linear_pfn_mapping logic to overload VM_INSERTPAGE flag along with VM_PFNMAP to mean full PFNMAP setup at mmap time. Problem also tracked at: http://bugzilla.kernel.org/show_bug.cgi?id=12800 Reported-by: Thomas Hellstrom <thellstrom@vmware.com> Tested-by: Frans Pop <elendil@planet.nl> Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha>@intel.com> Cc: Nick Piggin <npiggin@suse.de> Cc: "ebiederm@xmission.com" <ebiederm@xmission.com> Cc: <stable@kernel.org> # only for 2.6.29.1, not .28 LKML-Reference: <20090313004527.GA7176@linux-os.sc.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-05do_wp_page: fix regression with execute in placeCarsten Otte
Fix do_wp_page for VM_MIXEDMAP mappings. In the case where pfn_valid returns 0 for a pfn at the beginning of do_wp_page and the mapping is not shared writable, the code branches to label `gotten:' with old_page == NULL. In case the vma is locked (vma->vm_flags & VM_LOCKED), lock_page, clear_page_mlock, and unlock_page try to access the old_page. This patch checks whether old_page is valid before it is dereferenced. The regression was introduced by "mlock: mlocked pages are unevictable" (commit b291f000393f5a0b679012b39d79fbc85c018233). Signed-off-by: Carsten Otte <cotte@de.ibm.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: <stable@kernel.org> [2.6.28.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-13x86 PAT: change track_pfn_vma_new to take pgprot_t pointer paramvenkatesh.pallipadi@intel.com
Impact: cleanup Change the protection parameter for track_pfn_vma_new() into a pgprot_t pointer. Subsequent patch changes the x86 PAT handling to return a compatible memtype in pgprot_t, if what was requested cannot be allowed due to conflicts. No fuctionality change in this patch. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-13x86 PAT: remove PFNMAP type on track_pfn_vma_new() errorvenkatesh.pallipadi@intel.com
Impact: fix (harmless) double-free of memtype entries and avoid warning On track_pfn_vma_new() failure, reset the vm_flags so that there will be no second cleanup happening when upper level routines call unmap_vmas(). This patch fixes part of the bug reported here: http://marc.info/?l=linux-kernel&m=123108883716357&w=2 Specifically the error message: X:5010 freeing invalid memtype d0000000-d0101000 Is due to multiple frees on error path, will not happen with the patch below. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-12lockdep, mm: fix might_fault() annotationPeter Zijlstra
Some code (nfs/sunrpc) uses socket ops on kernel memory while holding the mmap_sem, this is safe because kernel memory doesn't get paged out, therefore we'll never actually fault, and the might_fault() annotations will generate false positives. Reported-by: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-08memcg: fix swap accounting leakKAMEZAWA Hiroyuki
Fix swapin charge operation of memcg. Now, memcg has hooks to swap-out operation and checks SwapCache is really unused or not. That check depends on contents of struct page. I.e. If PageAnon(page) && page_mapped(page), the page is recoginized as still-in-use. Now, reuse_swap_page() calles delete_from_swap_cache() before establishment of any rmap. Then, in followinig sequence (Page fault with WRITE) try_charge() (charge += PAGESIZE) commit_charge() (Check page_cgroup is used or not..) reuse_swap_page() -> delete_from_swapcache() -> mem_cgroup_uncharge_swapcache() (charge -= PAGESIZE) ...... New charge is uncharged soon.... To avoid this, move commit_charge() after page_mapcount() goes up to 1. By this, try_charge() (usage += PAGESIZE) reuse_swap_page() (may usage -= PAGESIZE if PCG_USED is set) commit_charge() (If page_cgroup is not marked as PCG_USED, add new charge.) Accounting will be correct. Changelog (v2) -> (v3) - fixed invalid charge to swp_entry==0. - updated documentation. Changelog (v1) -> (v2) - fixed comment. [nishimura@mxp.nes.nec.co.jp: swap accounting leak doc fix] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Tested-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: revert gfp mask fixKAMEZAWA Hiroyuki
My patch, memcg-fix-gfp_mask-of-callers-of-charge.patch changed gfp_mask of callers of charge to be GFP_HIGHUSER_MOVABLE for showing what will happen at memory reclaim. But in recent discussion, it's NACKed because it sounds ugly. This patch is for reverting it and add some clean up to gfp_mask of callers of charge. No behavior change but need review before generating HUNK in deep queue. This patch also adds explanation to meaning of gfp_mask passed to charge functions in memcontrol.h. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: mem+swap controller coreKAMEZAWA Hiroyuki
This patch implements per cgroup limit for usage of memory+swap. However there are SwapCache, double counting of swap-cache and swap-entry is avoided. Mem+Swap controller works as following. - memory usage is limited by memory.limit_in_bytes. - memory + swap usage is limited by memory.memsw_limit_in_bytes. This has following benefits. - A user can limit total resource usage of mem+swap. Without this, because memory resource controller doesn't take care of usage of swap, a process can exhaust all the swap (by memory leak.) We can avoid this case. And Swap is shared resource but it cannot be reclaimed (goes back to memory) until it's used. This characteristic can be trouble when the memory is divided into some parts by cpuset or memcg. Assume group A and group B. After some application executes, the system can be.. Group A -- very large free memory space but occupy 99% of swap. Group B -- under memory shortage but cannot use swap...it's nearly full. Ability to set appropriate swap limit for each group is required. Maybe someone wonder "why not swap but mem+swap ?" - The global LRU(kswapd) can swap out arbitrary pages. Swap-out means to move account from memory to swap...there is no change in usage of mem+swap. In other words, when we want to limit the usage of swap without affecting global LRU, mem+swap limit is better than just limiting swap. Accounting target information is stored in swap_cgroup which is per swap entry record. Charge is done as following. map - charge page and memsw. unmap - uncharge page/memsw if not SwapCache. swap-out (__delete_from_swap_cache) - uncharge page - record mem_cgroup information to swap_cgroup. swap-in (do_swap_page) - charged as page and memsw. record in swap_cgroup is cleared. memsw accounting is decremented. swap-free (swap_free()) - if swap entry is freed, memsw is uncharged by PAGE_SIZE. There are people work under never-swap environments and consider swap as something bad. For such people, this mem+swap controller extension is just an overhead. This overhead is avoided by config or boot option. (see Kconfig. detail is not in this patch.) TODO: - maybe more optimization can be don in swap-in path. (but not very safe.) But we just do simple accounting at this stage. [nishimura@mxp.nes.nec.co.jp: make resize limit hold mutex] [hugh@veritas.com: memswap controller core swapcache fixes] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: fix gfp_mask of callers of chargeKAMEZAWA Hiroyuki
Fix misuse of gfp_kernel. Now, most of callers of mem_cgroup_charge_xxx functions uses GFP_KERNEL. I think that this is from the fact that page_cgroup *was* dynamically allocated. But now, we allocate all page_cgroup at boot. And mem_cgroup_try_to_free_pages() reclaim memory from GFP_HIGHUSER_MOVABLE + specified GFP_RECLAIM_MASK. * This is because we just want to reduce memory usage. "Where we should reclaim from ?" is not a problem in memcg. This patch modifies gfp masks to be GFP_HIGUSER_MOVABLE if possible. Note: This patch is not for fixing behavior but for showing sane information in source code. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: introduce charge-commit-cancel style of functionsKAMEZAWA Hiroyuki
There is a small race in do_swap_page(). When the page swapped-in is charged, the mapcount can be greater than 0. But, at the same time some process (shares it ) call unmap and make mapcount 1->0 and the page is uncharged. CPUA CPUB mapcount == 1. (1) charge if mapcount==0 zap_pte_range() (2) mapcount 1 => 0. (3) uncharge(). (success) (4) set page's rmap() mapcount 0=>1 Then, this swap page's account is leaked. For fixing this, I added a new interface. - charge account to res_counter by PAGE_SIZE and try to free pages if necessary. - commit register page_cgroup and add to LRU if necessary. - cancel uncharge PAGE_SIZE because of do_swap_page failure. CPUA (1) charge (always) (2) set page's rmap (mapcount > 0) (3) commit charge was necessary or not after set_pte(). This protocol uses PCG_USED bit on page_cgroup for avoiding over accounting. Usual mem_cgroup_charge_common() does charge -> commit at a time. And this patch also adds following function to clarify all charges. - mem_cgroup_newpage_charge() ....replacement for mem_cgroup_charge() called against newly allocated anon pages. - mem_cgroup_charge_migrate_fixup() called only from remove_migration_ptes(). we'll have to rewrite this later.(this patch just keeps old behavior) This function will be removed by additional patch to make migration clearer. Good for clarifying "what we do" Then, we have 4 following charge points. - newpage - swap-in - add-to-cache. - migration. [akpm@linux-foundation.org: add missing inline directives to stubs] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06mm: make get_user_pages() interruptibleYing Han
The initial implementation of checking TIF_MEMDIE covers the cases of OOM killing. If the process has been OOM killed, the TIF_MEMDIE is set and it return immediately. This patch includes: 1. add the case that the SIGKILL is sent by user processes. The process can try to get_user_pages() unlimited memory even if a user process has sent a SIGKILL to it(maybe a monitor find the process exceed its memory limit and try to kill it). In the old implementation, the SIGKILL won't be handled until the get_user_pages() returns. 2. change the return value to be ERESTARTSYS. It makes no sense to return ENOMEM if the get_user_pages returned by getting a SIGKILL signal. Considering the general convention for a system call interrupted by a signal is ERESTARTNOSYS, so the current return value is consistant to that. Lee: An unfortunate side effect of "make-get_user_pages-interruptible" is that it prevents a SIGKILL'd task from munlock-ing pages that it had mlocked, resulting in freeing of mlocked pages. Freeing of mlocked pages, in itself, is not so bad. We just count them now--altho' I had hoped to remove this stat and add PG_MLOCKED to the free pages flags check. However, consider pages in shared libraries mapped by more than one task that a task mlocked--e.g., via mlockall(). If the task that mlocked the pages exits via SIGKILL, these pages would be left mlocked and unevictable. Proposed fix: Add another GUP flag to ignore sigkill when calling get_user_pages from munlock()--similar to Kosaki Motohiro's 'IGNORE_VMA_PERMISSIONS flag for the same purpose. We are not actually allocating memory in this case, which "make-get_user_pages-interruptible" intends to avoid. We're just munlocking pages that are already resident and mapped, and we're reusing get_user_pages() to access those pages. ?? Maybe we should combine 'IGNORE_VMA_PERMISSIONS and '_IGNORE_SIGKILL into a single flag: GUP_FLAGS_MUNLOCK ??? [Lee.Schermerhorn@hp.com: ignore sigkill in get_user_pages during munlock] Signed-off-by: Paul Menage <menage@google.com> Signed-off-by: Ying Han <yinghan@google.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Hugh Dickins <hugh@veritas.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Rohit Seth <rohitseth@google.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06badpage: KERN_ALERT BUG instead of KERN_EMERGHugh Dickins
bad_page() and rmap Eeek messages have said KERN_EMERG for a few years, which I've followed in print_bad_pte(). These are serious system errors, on a par with BUGs, but they're not quite emergencies, and we do our best to carry on: say KERN_ALERT "BUG: " like the x86 oops does. And remove the "Trying to fix it up, but a reboot is needed" line: it's not untrue, but I hope the KERN_ALERT "BUG: " conveys as much. Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06badpage: ratelimit print_bad_pte and bad_pageHugh Dickins
print_bad_pte() and bad_page() might each need ratelimiting - especially for their dump_stacks, almost never of interest, yet not quite dispensible. Correlating corruption across neighbouring entries can be very helpful, so allow a burst of 60 reports before keeping quiet for the remainder of that minute (or allow a steady drip of one report per second). Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06badpage: remove vma from page_remove_rmapHugh Dickins
Remove page_remove_rmap()'s vma arg, which was only for the Eeek message. And remove the BUG_ON(page_mapcount(page) == 0) from CONFIG_DEBUG_VM's page_dup_rmap(): we're trying to be more resilient about that than BUGs. Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06badpage: zap print_bad_pte on swap and fileHugh Dickins
Complete zap_pte_range()'s coverage of bad pagetable entries by calling print_bad_pte() on a pte_file in a linear vma and on a bad swap entry. That needs free_swap_and_cache() to tell it, which will also have shown one of those "swap_free" errors (but with much less information). Similar checks in fork's copy_one_pte()? No, that would be more noisy than helpful: we'll see them when parent and child exec or exit. Where do_nonlinear_fault() calls print_bad_pte(): omit !VM_CAN_NONLINEAR case, that could only be a bug in sys_remap_file_pages(), not a bad pte. VM_FAULT_OOM rather than VM_FAULT_SIGBUS? Well, okay, that is consistent with what happens if do_swap_page() operates a bad swap entry; but don't we have patches to be more careful about killing when VM_FAULT_OOM? Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06badpage: vm_normal_page use print_bad_pteHugh Dickins
print_bad_pte() is so far being called only when zap_pte_range() finds negative page_mapcount, or there's a fault on a pte_file where it does not belong. That's weak coverage when we suspect pagetable corruption. Originally, it was called when vm_normal_page() found an invalid pfn: but pfn_valid is expensive on some architectures and configurations, so 2.6.24 put that under CONFIG_DEBUG_VM (which doesn't help in the field), then 2.6.26 replaced it by a VM_BUG_ON (likewise). Reinstate the print_bad_pte() in vm_normal_page(), but use a cheaper test than pfn_valid(): memmap_init_zone() (used in bootup and hotplug) keep a __read_mostly note of the highest_memmap_pfn, vm_normal_page() then check pfn against that. We could call this pfn_plausible() or pfn_sane(), but I doubt we'll need it elsewhere: of course it's not reliable, but gives much stronger pagetable validation on many boxes. Also use print_bad_pte() when the pte_special bit is found outside a VM_PFNMAP or VM_MIXEDMAP area, instead of VM_BUG_ON. Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06badpage: replace page_remove_rmap Eeek and BUGHugh Dickins
Now that bad pages are kept out of circulation, there is no need for the infamous page_remove_rmap() BUG() - once that page is freed, its negative mapcount will issue a "Bad page state" message and the page won't be freed. Removing the BUG() allows more info, on subsequent pages, to be gathered. We do have more info about the page at this point than bad_page() can know - notably, what the pmd is, which might pinpoint something like low 64kB corruption - but page_remove_rmap() isn't given the address to find that. In practice, there is only one call to page_remove_rmap() which has ever reported anything, that from zap_pte_range() (usually on exit, sometimes on munmap). It has all the info, so remove page_remove_rmap()'s "Eeek" message and leave it all to zap_pte_range(). mm/memory.c already has a hardly used print_bad_pte() function, showing some of the appropriate info: extend it to show what we want for the rmap case: pte info, page info (when there is a page) and vma info to compare. zap_pte_range() already knows the pmd, but print_bad_pte() is easier to use if it works that out for itself. Some of this info is also shown in bad_page()'s "Bad page state" message. Keep them separate, but adjust them to match each other as far as possible. Say "Bad page map" in print_bad_pte(), and add a TAINT_BAD_PAGE there too. print_bad_pte() show current->comm unconditionally (though it should get repeated in the usually irrelevant stack trace): sorry, I misled Nick Piggin to make it conditional on vm_mm == current->mm, but current->mm is already NULL in the exit case. Usually current->comm is good, though exceptionally it may not be that of the mm (when "swapoff" for example). Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06mm: make maddr __iomemKOSAKI Motohiro
sparse output following warnings. mm/memory.c:2936:8: warning: incorrect type in assignment (different address spaces) mm/memory.c:2936:8: expected void *maddr mm/memory.c:2936:8: got void [noderef] <asn:2> cleanup here. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06mm: try_to_free_swap replaces remove_exclusive_swap_pageHugh Dickins
remove_exclusive_swap_page(): its problem is in living up to its name. It doesn't matter if someone else has a reference to the page (raised page_count); it doesn't matter if the page is mapped into userspace (raised page_mapcount - though that hints it may be worth keeping the swap): all that matters is that there be no more references to the swap (and no writeback in progress). swapoff (try_to_unuse) has been removing pages from swapcache for years, with no concern for page count or page mapcount, and we used to have a comment in lookup_swap_cache() recognizing that: if you go for a page of swapcache, you'll get the right page, but it could have been removed from swapcache by the time you get page lock. So, give up asking for exclusivity: get rid of remove_exclusive_swap_page(), and remove_exclusive_swap_page_ref() and remove_exclusive_swap_page_count() which were spawned for the recent LRU work: replace them by the simpler try_to_free_swap() which just checks page_swapcount(). Similarly, remove the page_count limitation from free_swap_and_count(), but assume that it's worth holding on to the swap if page is mapped and swap nowhere near full. Add a vm_swap_full() test in free_swap_cache()? It would be consistent, but I think we probably have enough for now. Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Rik van Riel <riel@redhat.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06mm: reuse_swap_page replaces can_share_swap_pageHugh Dickins
A good place to free up old swap is where do_wp_page(), or do_swap_page(), is about to redirty the page: the data on disk is then stale and won't be read again; and if we do decide to write the page out later, using the previous swap location makes an unnecessary disk seek very likely. So give can_share_swap_page() the side-effect of delete_from_swap_cache() when it safely can. And can_share_swap_page() was always a misleading name, the more so if it has a side-effect: rename it reuse_swap_page(). Irrelevant cleanup nearby: remove swap_token_default_timeout definition from swap.h: it's used nowhere. Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06mm: wp lock page before deciding cowHugh Dickins
An application may rely on get_user_pages() to give it pages writable from userspace and shared with a driver, GUP breaking COW if necessary. It may mprotect() the pages' writability, off and on, from time to time. Normally this works fine (so long as the app does not fork); but just occasionally, under memory pressure, a readonly pte in a newly writable area is COWed unnecessarily, breaking the link with the driver: because do_wp_page() does trylock_page, and falls back to COW whenever that fails. For reliable behaviour in the unshared case, when the trylock_page fails, now unlock pagetable, lock page and relock pagetable, before deciding whether Copy-On-Write is really necessary. Reported-by: Zhou Yingchao Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Rik van Riel <riel@redhat.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06mm: gup persist for write permissionHugh Dickins
do_wp_page()'s VM_FAULT_WRITE return value tells __get_user_pages() that COW has been done if necessary, though it may be leaving the pte without write permission - for the odd case of forced writing to a readonly vma for ptrace. At present GUP then retries the follow_page() without asking for write permission, to escape an endless loop when forced. But an application may be relying on GUP to guarantee a writable page which won't be COWed again when written from userspace, whereas a race here might leave a readonly pte in place? Change the VM_FAULT_WRITE handling to ask follow_page() for write permission again, except in that odd case of forced writing to a readonly vma. Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Rik van Riel <riel@redhat.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06mm: further cleanup page_add_new_anon_rmapHugh Dickins
Moving lru_cache_add_active_or_unevictable() into page_add_new_anon_rmap() was good but stupid: we can and should SetPageSwapBacked() there too; and we know for sure that this anonymous, swap-backed page is not file cache. Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06mm: add_active_or_unevictable into rmapHugh Dickins
lru_cache_add_active_or_unevictable() and page_add_new_anon_rmap() always appear together. Save some symbol table space and some jumping around by removing lru_cache_add_active_or_unevictable(), folding its code into page_add_new_anon_rmap(): like how we add file pages to lru just after adding them to page cache. Remove the nearby "TODO: is this safe?" comments (yes, it is safe), and change page_add_new_anon_rmap()'s address BUG_ON to VM_BUG_ON as originally intended. Signed-off-by: Hugh Dickins <hugh@veritas.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06mm/apply_to_range: call pte function with lazy updatesJeremy Fitzhardinge
Make the pte-level function in apply_to_range be called in lazy mmu mode, so that any pagetable modifications can be batched. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06mm: more likely reclaim MADV_SEQUENTIAL mappingsJohannes Weiner
File pages mapped only in sequentially read mappings are perfect reclaim canditates. This patch makes these mappings behave like weak references, their pages will be reclaimed unless they have a strong reference from a normal mapping as well. It changes the reclaim and the unmap path where they check if the page has been referenced. In both cases, accesses through sequentially read mappings will be ignored. Benchmark results from KOSAKI Motohiro: http://marc.info/?l=linux-mm&m=122485301925098&w=2 Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Signed-off-by: Rik van Riel <riel@redhat.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06mm: don't mark_page_accessed in fault pathNick Piggin
Doing a mark_page_accessed at fault-time, then doing SetPageReferenced at unmap-time if the pte is young has a number of problems. mark_page_accessed is supposed to be roughly the equivalent of a young pte for unmapped references. Unfortunately it doesn't come with any context: after being called, reclaim doesn't know who or why the page was touched. So calling mark_page_accessed not only adds extra lru or PG_referenced manipulations for pages that are already going to have pte_young ptes anyway, but it also adds these references which are difficult to work with from the context of vma specific references (eg. MADV_SEQUENTIAL pte_young may not wish to contribute to the page being referenced). Then, simply doing SetPageReferenced when zapping a pte and finding it is young, is not a really good solution either. SetPageReferenced does not correctly promote the page to the active list for example. So after removing mark_page_accessed from the fault path, several mmap()+touch+munmap() would have a very different result from several read(2) calls for example, which is not really desirable. Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Johannes Weiner <hannes@saeurebad.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-05inode->i_op is never NULLAl Viro
We used to have rather schizophrenic set of checks for NULL ->i_op even though it had been eliminated years ago. You'd need to go out of your way to set it to NULL explicitly _and_ a bunch of code would die on such inodes anyway. After killing two remaining places that still did that bogosity, all that crap can go away. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-12-30Merge branch 'core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (63 commits) stacktrace: provide save_stack_trace_tsk() weak alias rcu: provide RCU options on non-preempt architectures too printk: fix discarding message when recursion_bug futex: clean up futex_(un)lock_pi fault handling "Tree RCU": scalable classic RCU implementation futex: rename field in futex_q to clarify single waiter semantics x86/swiotlb: add default swiotlb_arch_range_needs_mapping x86/swiotlb: add default phys<->bus conversion x86: unify pci iommu setup and allow swiotlb to compile for 32 bit x86: add swiotlb allocation functions swiotlb: consolidate swiotlb info message printing swiotlb: support bouncing of HighMem pages swiotlb: factor out copy to/from device swiotlb: add arch hook to force mapping swiotlb: allow architectures to override phys<->bus<->phys conversions swiotlb: add comment where we handle the overflow of a dma mask on 32 bit rcu: fix rcutorture behavior during reboot resources: skip sanity check of busy resources swiotlb: move some definitions to header swiotlb: allow architectures to override swiotlb pool allocation ... Fix up trivial conflicts in arch/x86/kernel/Makefile arch/x86/mm/init_32.c include/linux/hardirq.h as per Ingo's suggestions.
2008-12-19x86: PAT: move track untrack pfnmap stubs to asm-genericvenkatesh.pallipadi@intel.com
Impact: Cleanup and branch hints only. Move the track and untrack pfn stub routines from memory.c to asm-generic. Also add unlikely to pfnmap related calls in fork and exit path. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-12-19x86: PAT: remove follow_pfnmap_pte in favor of follow_physvenkatesh.pallipadi@intel.com
Impact: Cleanup - removes a new function in favor of a recently modified older one. Replace follow_pfnmap_pte in pat code with follow_phys. follow_phys lso returns protection eliminating the need of pte_pgprot call. Using follow_phys also eliminates the need for pte_pa. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-12-19x86: PAT: modify follow_phys to return phys_addr prot and return valuevenkatesh.pallipadi@intel.com
Impact: Changes and globalizes an existing static interface. Follow_phys does similar things as follow_pfnmap_pte. Make a minor change to follow_phys so that it can be used in place of follow_pfnmap_pte. Physical address return value with 0 as error return does not work in follow_phys as the actual physical address 0 mapping may exist in pte. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-12-18x86: PAT: hooks in generic vm code to help archs to track pfnmap regions - v3venkatesh.pallipadi@intel.com
Impact: Introduces new hooks, which are currently null. Introduce generic hooks in remap_pfn_range and vm_insert_pfn and corresponding copy and free routines with reserve and free tracking. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-12-18x86: PAT: add follow_pfnmp_pte routine to help tracking pfnmap pages - v3venkatesh.pallipadi@intel.com
Impact: New currently unused interface. Add a generic interface to follow pfn in a pfnmap vma range. This is used by one of the subsequent x86 PAT related patch to keep track of memory types for vma regions across vma copy and free. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
