Various drivers end up replicating the code to mmap() their memory
buffers into user space, and our core memory remapping function may be
very flexible but it is unnecessarily complicated for the common cases
to use.
Our internal VM uses pfn's ("page frame numbers") which simplifies
things for the VM, and allows us to pass physical addresses around in a
denser and more efficient format than passing a "phys_addr_t" around,
and having to shift it up and down by the page size. But it just means
that drivers end up doing that shifting instead at the interface level.
It also means that drivers end up mucking around with internal VM things
like the vma details (vm_pgoff, vm_start/end) way more than they really
need to.
So this just exports a function to map a certain physical memory range
into user space (using a phys_addr_t based interface that is much more
natural for a driver) and hides all the complexity from the driver.
Some drivers will still end up tweaking the vm_page_prot details for
things like prefetching or cacheability etc, but that's actually
relevant to the driver, rather than caring about what the page offset of
the mapping is into the particular IO memory region.
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
This patch attempts to fix:
https://bugzilla.kernel.org/show_bug.cgi?id=56461
The symptom is a crash and messages like this:
chrome: Corrupted page table at address 34a03000
*pdpt = 0000000000000000 *pde = 0000000000000000
Bad pagetable: 000f [#1] PREEMPT SMP
Ingo guesses this got introduced by commit 611ae8e3f520 ("x86/tlb:
enable tlb flush range support for x86") since that code started to free
unused pagetables.
On x86-32 PAE kernels, that new code has the potential to free an entire
PMD page and will clear one of the four page-directory-pointer-table
(aka pgd_t entries).
The hardware aggressively "caches" these top-level entries and invlpg
does not actually affect the CPU's copy. If we clear one we *HAVE* to
do a full TLB flush, otherwise we might continue using a freed pmd page.
(note, we do this properly on the population side in pud_populate()).
This patch tracks whenever we clear one of these entries in the 'struct
mmu_gather', and ensures that we follow up with a full tlb flush.
BTW, I disassembled and checked that:
if (tlb->fullmm == 0)
and
if (!tlb->fullmm && !tlb->need_flush_all)
generate essentially the same code, so there should be zero impact there
to the !PAE case.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Peter Anvin <hpa@zytor.com>
Cc: Artem S Tashkinov <t.artem@mailcity.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module update from Rusty Russell:
"The sweeping change is to make add_taint() explicitly indicate whether
to disable lockdep, but it's a mechanical change."
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
MODSIGN: Add option to not sign modules during modules_install
MODSIGN: Add -s <signature> option to sign-file
MODSIGN: Specify the hash algorithm on sign-file command line
MODSIGN: Simplify Makefile with a Kconfig helper
module: clean up load_module a little more.
modpost: Ignore ARC specific non-alloc sections
module: constify within_module_*
taint: add explicit flag to show whether lock dep is still OK.
module: printk message when module signature fail taints kernel.
I dislike the way in which "swapcache" gets used in do_swap_page():
there is always a page from swapcache there (even if maybe uncached by
the time we lock it), but tests are made according to "swapcache".
Rework that with "page != swapcache", as has been done in unuse_pte().
Cc: Petr Holasek <pholasek@redhat.com>
Cc: Izik Eidus <izik.eidus@ravellosystems.com>
In "ksm: remove old stable nodes more thoroughly" I said that I'd never
seen its WARN_ON_ONCE(page_mapped(page)). True at the time of writing,
but it soon appeared once I tried fuller tests on the whole series.
It turned out to be due to the KSM page migration itself: unmerge_and_
remove_all_rmap_items() failed to locate and replace all the KSM pages,
because of that hiatus in page migration when old pte has been replaced
by migration entry, but not yet by new pte. follow_page() finds no page
at that instant, but a KSM page reappears shortly after, without a
fault.
Add FOLL_MIGRATION flag, so follow_page() can do migration_entry_wait()
for KSM's break_cow(). I'd have preferred to avoid another flag, and do
it every time, in case someone else makes the same easy mistake; but did
not find another transgressor (the common get_user_pages() is of course
safe), and cannot be sure that every follow_page() caller is prepared to
sleep - ia64's xencomm_vtop()? Now, THP's wait_split_huge_page() can
already sleep there, since anon_vma locking was changed to mutex, but
maybe that's somehow excluded.
This change adds a follow_page_mask function which is equivalent to
follow_page, but with an extra page_mask argument.
follow_page_mask sets *page_mask to HPAGE_PMD_NR - 1 when it encounters
a THP page, and to 0 in other cases.
__get_user_pages() makes use of this in order to accelerate populating
THP ranges - that is, when both the pages and vmas arrays are NULL, we
don't need to iterate HPAGE_PMD_NR times to cover a single THP page (and
we also avoid taking mm->page_table_lock that many times).
Signed-off-by: Michel Lespinasse <walken@google.com>
Use long type for page counts in mm_populate() so as to avoid integer
overflow when running the following test code:
int main(void) {
void *p = mmap(NULL, 0x100000000000, PROT_READ,
MAP_PRIVATE | MAP_ANON, -1, 0);
printf("p: %p\n", p);
mlockall(MCL_CURRENT);
printf("done\n");
return 0;
Switching merge_across_nodes after running KSM is liable to oops on stale
nodes still left over from the previous stable tree. It's not something
that people will often want to do, but it would be lame to demand a reboot
when they're trying to determine which merge_across_nodes setting is best.
How can this happen? We only permit switching merge_across_nodes when
pages_shared is 0, and usually set run 2 to force that beforehand, which
ought to unmerge everything: yet oopses still occur when you then run 1.
Three causes:
1. The old stable tree (built according to the inverse
merge_across_nodes) has not been fully torn down. A stable node
lingers until get_ksm_page() notices that the page it references no
longer references it: but the page is not necessarily freed as soon as
expected, particularly when swapcache.
Fix this with a pass through the old stable tree, applying
get_ksm_page() to each of the remaining nodes (most found stale and
removed immediately), with forced removal of any left over. Unless the
page is still mapped: I've not seen that case, it shouldn't occur, but
better to WARN_ON_ONCE and EBUSY than BUG.
2. __ksm_enter() has a nice little optimization, to insert the new mm
just behind ksmd's cursor, so there's a full pass for it to stabilize
(or be removed) before ksmd addresses it. Nice when ksmd is running,
but not so nice when we're trying to unmerge all mms: we were missing
those mms forked and inserted behind the unmerge cursor. Easily fixed
by inserting at the end when KSM_RUN_UNMERGE.
3. It is possible for a KSM page to be faulted back from swapcache
into an mm, just after unmerge_and_remove_all_rmap_items() scanned past
it. Fix this by copying on fault when KSM_RUN_UNMERGE: but that is
private to ksm.c, so dissolve the distinction between
ksm_might_need_to_copy() and ksm_does_need_to_copy(), doing it all in
the one call into ksm.c.
A long outstanding, unrelated bugfix sneaks in with that third fix:
ksm_does_need_to_copy() would copy from a !PageUptodate page (implying I/O
error when read in from swap) to a page which it then marks Uptodate. Fix
this case by not copying, letting do_swap_page() discover the error.
Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com>
page->_last_nid fits into page->flags on 64-bit. The unlikely 32-bit
NUMA configuration with NUMA Balancing will still need an extra page
field. As Peter notes "Completely dropping 32bit support for
CONFIG_NUMA_BALANCING would simplify things, but it would also remove
the warning if we grow enough 64bit only page-flags to push the last-cpu
out."
[mgorman@suse.de: minor modifications]
Cc: Simon Jeons <simon.jeons@gmail.com>
Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com>
In find_extend_vma(), we don't need mlock_vma_pages_range() to verify
the vma type - we know we're working with a stack. So, we can call
directly into __mlock_vma_pages_range(), and remove the last
make_pages_present() call site.
Note that we don't use mm_populate() here, so we can't release the
mmap_sem while allocating new stack pages. This is deemed acceptable,
because the stack vmas grow by a bounded number of pages at a time, and
these are anon pages so we don't have to read from disk to populate
them.
Tested-by: Andy Lutomirski <luto@amacapital.net>
Cc: Greg Ungerer <gregungerer@westnet.com.au>
When ex-KSM pages are faulted from swap cache, the fault handler is not
capable of re-establishing anon_vma-spanning KSM pages. In this case, a
copy of the page is created instead, just like during a COW break.
These freshly made copies are known to be exclusive to the faulting VMA
and there is no reason to go look for this page in parent and sibling
processes during rmap operations.
Use page_add_new_anon_rmap() for these copies. This also puts them on
the proper LRU lists and marks them SwapBacked, so we can get rid of
doing this ad-hoc in the KSM copy code.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Cc: Satoru Moriya <satoru.moriya@hds.com>
Fix up all callers as they were before, with make one change: an
unsigned module taints the kernel, but doesn't turn off lockdep.
The check for a pmd being in the process of being split was dropped by
mistake by commit d10e63f29488 ("mm: numa: Create basic numa page
hinting infrastructure"). Put it back.
Reported-by: Dave Jones <davej@redhat.com>
Debugged-by: Hillf Danton <dhillf@gmail.com>
Acked-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Kirill Shutemov <kirill@shutemov.name>
Since commit e303297e6c3a ("mm: extended batches for generic
mmu_gather") we are batching pages to be freed until either
tlb_next_batch cannot allocate a new batch or we are done.
This works just fine most of the time but we can get in troubles with
non-preemptible kernel (CONFIG_PREEMPT_NONE or CONFIG_PREEMPT_VOLUNTARY)
on large machines where too aggressive batching might lead to soft
lockups during process exit path (exit_mmap) because there are no
scheduling points down the free_pages_and_swap_cache path and so the
freeing can take long enough to trigger the soft lockup.
The lockup is harmless except when the system is setup to panic on
softlockup which is not that unusual.
The simplest way to work around this issue is to limit the maximum
number of batches in a single mmu_gather. 10k of collected pages should
be safe to prevent from soft lockups (we would have 2ms for one) even if
they are all freed without an explicit scheduling point.
This patch doesn't add any new explicit scheduling points because it
relies on zap_pmd_range during page tables zapping which calls
cond_resched per PMD.
The following lockup has been reported for 3.0 kernel with a huge
process (in order of hundreds gigs but I do know any more details).
BUG: soft lockup - CPU#56 stuck for 22s! [kernel:31053]
Modules linked in: af_packet nfs lockd fscache auth_rpcgss nfs_acl sunrpc mptctl mptbase autofs4 binfmt_misc dm_round_robin dm_multipath bonding cpufreq_conservative cpufreq_userspace cpufreq_powersave pcc_cpufreq mperf microcode fuse loop osst sg sd_mod crc_t10dif st qla2xxx scsi_transport_fc scsi_tgt netxen_nic i7core_edac iTCO_wdt joydev e1000e serio_raw pcspkr edac_core iTCO_vendor_support acpi_power_meter rtc_cmos hpwdt hpilo button container usbhid hid dm_mirror dm_region_hash dm_log linear uhci_hcd ehci_hcd usbcore usb_common scsi_dh_emc scsi_dh_alua scsi_dh_hp_sw scsi_dh_rdac scsi_dh dm_snapshot pcnet32 mii edd dm_mod raid1 ext3 mbcache jbd fan thermal processor thermal_sys hwmon cciss scsi_mod
Supported: Yes
CPU 56
Pid: 31053, comm: kernel Not tainted 3.0.31-0.9-default #1 HP ProLiant DL580 G7
RIP: 0010: _raw_spin_unlock_irqrestore+0x8/0x10
RSP: 0018:ffff883ec1037af0 EFLAGS: 00000206
RAX: 0000000000000e00 RBX: ffffea01a0817e28 RCX: ffff88803ffd9e80
RDX: 0000000000000200 RSI: 0000000000000206 RDI: 0000000000000206
RBP: 0000000000000002 R08: 0000000000000001 R09: ffff887ec724a400
R10: 0000000000000000 R11: dead000000200200 R12: ffffffff8144c26e
R13: 0000000000000030 R14: 0000000000000297 R15: 000000000000000e
FS: 00007ed834282700(0000) GS:ffff88c03f200000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 000000000068b240 CR3: 0000003ec13c5000 CR4: 00000000000006e0
Process kernel (pid: 31053, threadinfo ffff883ec1036000, task ffff883ebd5d4100)
Call Trace:
release_pages+0xc5/0x260
free_pages_and_swap_cache+0x9d/0xc0
tlb_flush_mmu+0x5c/0x80
tlb_finish_mmu+0xe/0x50
exit_mmap+0xbd/0x120
mmput+0x49/0x120
exit_mm+0x122/0x160
do_exit+0x17a/0x430
do_group_exit+0x3d/0xb0
get_signal_to_deliver+0x247/0x480
do_signal+0x71/0x1b0
do_notify_resume+0x98/0xb0
int_signal+0x12/0x17
DWARF2 unwinder stuck at int_signal+0x12/0x17
Cc: <stable@vger.kernel.org> [3.0+]
gcc-4.4.4 screws this up.
mm/memory.c: In function 'do_pmd_numa_page':
mm/memory.c:3594: warning: no return statement in function returning non-void
git://git.kernel.org/pub/scm/linux/kernel/git/mel/linux-balancenuma
Pull Automatic NUMA Balancing bare-bones from Mel Gorman:
"There are three implementations for NUMA balancing, this tree
(balancenuma), numacore which has been developed in tip/master and
autonuma which is in aa.git.
In almost all respects balancenuma is the dumbest of the three because
its main impact is on the VM side with no attempt to be smart about
scheduling. In the interest of getting the ball rolling, it would be
desirable to see this much merged for 3.8 with the view to building
scheduler smarts on top and adapting the VM where required for 3.9.
The most recent set of comparisons available from different people are
mel: https://lkml.org/lkml/2012/12/9/108
mingo: https://lkml.org/lkml/2012/12/7/331
tglx: https://lkml.org/lkml/2012/12/10/437
srikar: https://lkml.org/lkml/2012/12/10/397
The results are a mixed bag. In my own tests, balancenuma does
reasonably well. It's dumb as rocks and does not regress against
mainline. On the other hand, Ingo's tests shows that balancenuma is
incapable of converging for this workloads driven by perf which is bad
but is potentially explained by the lack of scheduler smarts. Thomas'
results show balancenuma improves on mainline but falls far short of
numacore or autonuma. Srikar's results indicate we all suffer on a
large machine with imbalanced node sizes.
My own testing showed that recent numacore results have improved
dramatically, particularly in the last week but not universally.
We've butted heads heavily on system CPU usage and high levels of
migration even when it shows that overall performance is better.
There are also cases where it regresses. Of interest is that for
specjbb in some configurations it will regress for lower numbers of
warehouses and show gains for higher numbers which is not reported by
the tool by default and sometimes missed in treports. Recently I
reported for numacore that the JVM was crashing with
NullPointerExceptions but currently it's unclear what the source of
this problem is. Initially I thought it was in how numacore batch
handles PTEs but I'm no longer think this is the case. It's possible
numacore is just able to trigger it due to higher rates of migration.
These reports were quite late in the cycle so I/we would like to start
with this tree as it contains much of the code we can agree on and has
not changed significantly over the last 2-3 weeks."
* tag 'balancenuma-v11' of git://git.kernel.org/pub/scm/linux/kernel/git/mel/linux-balancenuma: (50 commits)
mm/rmap, migration: Make rmap_walk_anon() and try_to_unmap_anon() more scalable
mm/rmap: Convert the struct anon_vma::mutex to an rwsem
mm: migrate: Account a transhuge page properly when rate limiting
mm: numa: Account for failed allocations and isolations as migration failures
mm: numa: Add THP migration for the NUMA working set scanning fault case build fix
mm: numa: Add THP migration for the NUMA working set scanning fault case.
mm: sched: numa: Delay PTE scanning until a task is scheduled on a new node
mm: sched: numa: Control enabling and disabling of NUMA balancing if !SCHED_DEBUG
mm: sched: Adapt the scanning rate if a NUMA hinting fault does not migrate
mm: numa: Use a two-stage filter to restrict pages being migrated for unlikely task<->node relationships
mm: numa: migrate: Set last_nid on newly allocated page
mm: numa: split_huge_page: Transfer last_nid on tail page
mm: numa: Introduce last_nid to the page frame
sched: numa: Slowly increase the scanning period as NUMA faults are handled
mm: numa: Rate limit setting of pte_numa if node is saturated
mm: numa: Rate limit the amount of memory that is migrated between nodes
mm: numa: Structures for Migrate On Fault per NUMA migration rate limiting
mm: numa: Migrate pages handled during a pmd_numa hinting fault
mm: numa: Migrate on reference policy
page_mkwrite is initalized with zero and only set once, from that point
exists no way to get to the oom or oom_free_new labels.
[akpm@linux-foundation.org: cleanup]
Signed-off-by: Dominik Dingel <dingel@linux.vnet.ibm.com>
We have two different implementation of is_zero_pfn() and my_zero_pfn()
helpers: for architectures with and without zero page coloring.
Let's consolidate them in <asm-generic/pgtable.h>.
Pass vma instead of mm and add address parameter.
In most cases we already have vma on the stack. We provides
split_huge_page_pmd_mm() for few cases when we have mm, but not vma.
This change is preparation to huge zero pmd splitting implementation.
Cc: "H. Peter Anvin" <hpa@linux.intel.com>
On write access to huge zero page we alloc a new huge page and clear it.
If ENOMEM, graceful fallback: we create a new pmd table and set pte around
fault address to newly allocated normal (4k) page. All other ptes in the
pmd set to normal zero page.
Acked-by: David Rientjes <rientjes@google.com>
On x86 memory accesses to pages without the ACCESSED flag set result in
the ACCESSED flag being set automatically. With the ARM architecture a
page access fault is raised instead (and it will continue to be raised
until the ACCESSED flag is set for the appropriate PTE/PMD).
For normal memory pages, handle_pte_fault will call pte_mkyoung
(effectively setting the ACCESSED flag). For transparent huge pages,
pmd_mkyoung will only be called for a write fault.
This patch ensures that faults on transparent hugepages which do not
result in a CoW update the access flags for the faulting pmd.
Cc: Chris Metcalf <cmetcalf@tilera.com>
Acked-by: Kirill A. Shutemov <kirill@shutemov.name>
Cc: Ni zhan Chen <nizhan.chen@gmail.com>
The PTE scanning rate and fault rates are two of the biggest sources of
system CPU overhead with automatic NUMA placement. Ideally a proper policy
would detect if a workload was properly placed, schedule and adjust the
PTE scanning rate accordingly. We do not track the necessary information
to do that but we at least know if we migrated or not.
This patch scans slower if a page was not migrated as the result of a
NUMA hinting fault up to sysctl_numa_balancing_scan_period_max which is
now higher than the previous default. Once every minute it will reset
the scanner in case of phase changes.
This is hilariously crude and the numbers are arbitrary. Workloads will
converge quite slowly in comparison to what a proper policy should be able
to do. On the plus side, we will chew up less CPU for workloads that have
no need for automatic balancing.
To say that the PMD handling code was incorrectly transferred from autonuma
is an understatement. The intention was to handle a PMDs worth of pages
in the same fault and effectively batch the taking of the PTL and page
migration. The copied version instead has the impact of clearing a number
of pte_numa PTE entries and whether any page migration takes place depends
on racing. This just happens to work in some cases.
This patch handles pte_numa faults in batch when a pmd_numa fault is
handled. The pages are migrated if they are currently misplaced.
Essentially this is making an assumption that NUMA locality is
on a PMD boundary but that could be addressed by only setting
pmd_numa if all the pages within that PMD are on the same node
if necessary.
It is tricky to quantify the basic cost of automatic NUMA placement in a
meaningful manner. This patch adds some vmstats that can be used as part
of a basic costing model.
u = basic unit = sizeof(void *)
Ca = cost of struct page access = sizeof(struct page) / u
Cpte = Cost PTE access = Ca
Cupdate = Cost PTE update = (2 * Cpte) + (2 * Wlock)
where Cpte is incurred twice for a read and a write and Wlock
is a constant representing the cost of taking or releasing a
lock
Cnumahint = Cost of a minor page fault = some high constant e.g. 1000
Cpagerw = Cost to read or write a full page = Ca + PAGE_SIZE/u
Ci = Cost of page isolation = Ca + Wi
where Wi is a constant that should reflect the approximate cost
of the locking operation
Cpagecopy = Cpagerw + (Cpagerw * Wnuma) + Ci + (Ci * Wnuma)
where Wnuma is the approximate NUMA factor. 1 is local. 1.2
would imply that remote accesses are 20% more expensive
Balancing cost = Cpte * numa_pte_updates +
Cnumahint * numa_hint_faults +
Ci * numa_pages_migrated +
Cpagecopy * numa_pages_migrated
Note that numa_pages_migrated is used as a measure of how many pages
were isolated even though it would miss pages that failed to migrate. A
vmstat counter could have been added for it but the isolation cost is
pretty marginal in comparison to the overall cost so it seemed overkill.
The ideal way to measure automatic placement benefit would be to count
the number of remote accesses versus local accesses and do something like
benefit = (remote_accesses_before - remove_access_after) * Wnuma
but the information is not readily available. As a workload converges, the
expection would be that the number of remote numa hints would reduce to 0.
convergence = numa_hint_faults_local / numa_hint_faults
where this is measured for the last N number of
numa hints recorded. When the workload is fully
converged the value is 1.
This can measure if the placement policy is converging and how fast it is
doing it.
NOTE: This patch is based on "sched, numa, mm: Add fault driven
placement and migration policy" but as it throws away all the policy
to just leave a basic foundation I had to drop the signed-offs-by.
This patch creates a bare-bones method for setting PTEs pte_numa in the
context of the scheduler that when faulted later will be faulted onto the
node the CPU is running on. In itself this does nothing useful but any
placement policy will fundamentally depend on receiving hints on placement
from fault context and doing something intelligent about it.
Note: Based on "mm/mpol: Use special PROT_NONE to migrate pages" but
sufficiently different that the signed-off-bys were dropped
Combine our previous _PAGE_NUMA, mpol_misplaced and migrate_misplaced_page()
pieces into an effective migrate on fault scheme.
Note that (on x86) we rely on PROT_NONE pages being !present and avoid
the TLB flush from try_to_unmap(TTU_MIGRATION). This greatly improves the
page-migration performance.
Based-on-work-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Note: This patch started as "mm/mpol: Create special PROT_NONE
infrastructure" and preserves the basic idea but steals *very*
heavily from "autonuma: numa hinting page faults entry points" for
the actual fault handlers without the migration parts. The end
result is barely recognisable as either patch so all Signed-off
and Reviewed-bys are dropped. If Peter, Ingo and Andrea are ok with
this version, I will re-add the signed-offs-by to reflect the history.
In order to facilitate a lazy -- fault driven -- migration of pages, create
a special transient PAGE_NUMA variant, we can then use the 'spurious'
protection faults to drive our migrations from.
The meaning of PAGE_NUMA depends on the architecture but on x86 it is
effectively PROT_NONE. Actual PROT_NONE mappings will not generate these
NUMA faults for the reason that the page fault code checks the permission on
the VMA (and will throw a segmentation fault on actual PROT_NONE mappings),
before it ever calls handle_mm_fault.
[dhillf@gmail.com: Fix typo]
Introduce FOLL_NUMA to tell follow_page to check
pte/pmd_numa. get_user_pages must use FOLL_NUMA, and it's safe to do
so because it always invokes handle_mm_fault and retries the
follow_page later.
KVM secondary MMU page faults will trigger the NUMA hinting page
faults through gup_fast -> get_user_pages -> follow_page ->
handle_mm_fault.
Other follow_page callers like KSM should not use FOLL_NUMA, or they
would fail to get the pages if they use follow_page instead of
get_user_pages.
[ This patch was picked up from the AutoNUMA tree. ]
Originally-by: Andrea Arcangeli <aarcange@redhat.com>
[ ported to this tree. ]
With transparent hugepage support, handle_mm_fault() has to be careful
that a normal PMD has been established before handling a PTE fault. To
achieve this, it used __pte_alloc() directly instead of pte_alloc_map
as pte_alloc_map is unsafe to run against a huge PMD. pte_offset_map()
is called once it is known the PMD is safe.
pte_alloc_map() is smart enough to check if a PTE is already present
before calling __pte_alloc but this check was lost. As a consequence,
PTEs may be allocated unnecessarily and the page table lock taken.
Thi useless PTE does get cleaned up but it's a performance hit which
is visible in page_test from aim9.
This patch simply re-adds the check normally done by pte_alloc_map to
check if the PTE needs to be allocated before taking the page table
lock. The effect is noticable in page_test from aim9.
AIM9
2.6.38-vanilla 2.6.38-checkptenone
creat-clo 446.10 ( 0.00%) 424.47 (-5.10%)
page_test 38.10 ( 0.00%) 42.04 ( 9.37%)
brk_test 52.45 ( 0.00%) 51.57 (-1.71%)
exec_test 382.00 ( 0.00%) 456.90 (16.39%)
fork_test 60.11 ( 0.00%) 67.79 (11.34%)
MMTests Statistics: duration
Total Elapsed Time (seconds) 611.90 612.22
(While this affects 2.6.38, it is a performance rather than a
functional bug and normally outside the rules -stable. While the big
performance differences are to a microbench, the difference in fork
and exec performance may be significant enough that -stable wants to
consider the patch)
Reported-by: Raz Ben Yehuda <raziebe@gmail.com>
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
[ Picked this up from the AutoNUMA tree to help
it upstream and to allow apples-to-apples
performance comparisons. ]
do_wp_page() sets mmun_called if mmun_start and mmun_end were
initialized and, if so, may call mmu_notifier_invalidate_range_end()
with these values. This doesn't prevent gcc from emitting a build
warning though:
mm/memory.c: In function `do_wp_page':
mm/memory.c:2530: warning: `mmun_start' may be used uninitialized in this function
mm/memory.c:2531: warning: `mmun_end' may be used uninitialized in this function
It's much easier to initialize the variables to impossible values and do
a simple comparison to determine if they were initialized to remove the
bool entirely.
Signed-off-by: David Rientjes <rientjes@google.com>
When a transparent hugepage is mapped and it is included in an mlock()
range, follow_page() incorrectly avoids setting the page's mlock bit and
moving it to the unevictable lru.
This is evident if you try to mlock(), munlock(), and then mlock() a
range again. Currently:
#define MAP_SIZE (4 << 30) /* 4GB */
void *ptr = mmap(NULL, MAP_SIZE, PROT_READ | PROT_WRITE,
MAP_PRIVATE | MAP_ANONYMOUS, 0, 0);
mlock(ptr, MAP_SIZE);
$ grep -E "Unevictable|Inactive\(anon" /proc/meminfo
Inactive(anon): 6304 kB
Unevictable: 4213924 kB
munlock(ptr, MAP_SIZE);
Inactive(anon): 4186252 kB
Unevictable: 19652 kB
Inactive(anon): 4198556 kB
Unevictable: 21684 kB
Notice that less than 2MB was added to the unevictable list; this is
because these pages in the range are not transparent hugepages since the
4GB range was allocated with mmap() and has no specific alignment. If
posix_memalign() were used instead, unevictable would not have grown at
all on the second mlock().
The fix is to call mlock_vma_page() so that the mlock bit is set and the
page is added to the unevictable list. With this patch:
Inactive(anon): 4056 kB
Unevictable: 4213940 kB
Inactive(anon): 4198268 kB
Unevictable: 19636 kB
Inactive(anon): 4008 kB
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Michel Lespinasse <walken@google.com>
In order to allow sleeping during invalidate_page mmu notifier calls, we
need to avoid calling when holding the PT lock. In addition to its direct
calls, invalidate_page can also be called as a substitute for a change_pte
call, in case the notifier client hasn't implemented change_pte.
This patch drops the invalidate_page call from change_pte, and instead
wraps all calls to change_pte with invalidate_range_start and
invalidate_range_end calls.
Note that change_pte still cannot sleep after this patch, and that clients
implementing change_pte should not take action on it in case the number of
outstanding invalidate_range_start calls is larger than one, otherwise
they might miss a later invalidation.
Signed-off-by: Haggai Eran <haggaie@mellanox.com>
Cc: Andrea Arcangeli <andrea@qumranet.com>
Cc: Sagi Grimberg <sagig@mellanox.com>
Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
Cc: Or Gerlitz <ogerlitz@mellanox.com>
Cc: Haggai Eran <haggaie@mellanox.com>
Cc: Shachar Raindel <raindel@mellanox.com>
Cc: Liran Liss <liranl@mellanox.com>
Cc: Avi Kivity <avi@redhat.com>
In order to allow sleeping during mmu notifier calls, we need to avoid
invoking them under the page table spinlock. This patch solves the
problem by calling invalidate_page notification after releasing the lock
(but before freeing the page itself), or by wrapping the page invalidation
with calls to invalidate_range_begin and invalidate_range_end.
To prevent accidental changes to the invalidate_range_end arguments after
the call to invalidate_range_begin, the patch introduces a convention of
saving the arguments in consistently named locals:
unsigned long mmun_start; /* For mmu_notifiers */
unsigned long mmun_end; /* For mmu_notifiers */
mmun_start = ...
mmun_end = ...
mmu_notifier_invalidate_range_start(mm, mmun_start, mmun_end);
mmu_notifier_invalidate_range_end(mm, mmun_start, mmun_end);
The patch changes code to use this convention for all calls to
mmu_notifier_invalidate_range_start/end, except those where the calls are
close enough so that anyone who glances at the code can see the values
aren't changing.
This patchset is a preliminary step towards on-demand paging design to be
added to the RDMA stack.
Why do we want on-demand paging for Infiniband?
Applications register memory with an RDMA adapter using system calls,
and subsequently post IO operations that refer to the corresponding
virtual addresses directly to HW. Until now, this was achieved by
pinning the memory during the registration calls. The goal of on demand
paging is to avoid pinning the pages of registered memory regions (MRs).
This will allow users the same flexibility they get when swapping any
other part of their processes address spaces. Instead of requiring the
entire MR to fit in physical memory, we can allow the MR to be larger,
and only fit the current working set in physical memory.
Why should anyone care? What problems are users currently experiencing?
This can make programming with RDMA much simpler. Today, developers
that are working with more data than their RAM can hold need either to
deregister and reregister memory regions throughout their process's
life, or keep a single memory region and copy the data to it. On demand
paging will allow these developers to register a single MR at the
beginning of their process's life, and let the operating system manage
which pages needs to be fetched at a given time. In the future, we
might be able to provide a single memory access key for each process
that would provide the entire process's address as one large memory
region, and the developers wouldn't need to register memory regions at
all.
Is there any prospect that any other subsystems will utilise these
infrastructural changes? If so, which and how, etc?
As for other subsystems, I understand that XPMEM wanted to sleep in
MMU notifiers, as Christoph Lameter wrote at
http://lkml.indiana.edu/hypermail/linux/kernel/0802.1/0460.html and
perhaps Andrea knows about other use cases.
Scheduling in mmu notifications is required since we need to sync the
hardware with the secondary page tables change. A TLB flush of an IO
device is inherently slower than a CPU TLB flush, so our design works by
sending the invalidation request to the device, and waiting for an
interrupt before exiting the mmu notifier handler.
Avi said:
kvm may be a buyer. kvm::mmu_lock, which serializes guest page
faults, also protects long operations such as destroying large ranges.
It would be good to convert it into a spinlock, but as it is used inside
mmu notifiers, this cannot be done.
(there are alternatives, such as keeping the spinlock and using a
generation counter to do the teardown in O(1), which is what the "may"
is doing up there).
[akpm@linux-foundation.orgpossible speed tweak in hugetlb_cow(), cleanups]
Signed-off-by: Andrea Arcangeli <andrea@qumranet.com>
Signed-off-by: Sagi Grimberg <sagig@mellanox.com>
We had thought that pages could no longer get freed while still marked as
mlocked; but Johannes Weiner posted this program to demonstrate that
truncating an mlocked private file mapping containing COWed pages is still
mishandled:
#include <sys/types.h>
#include <sys/mman.h>
#include <sys/stat.h>
#include <stdlib.h>
#include <unistd.h>
#include <fcntl.h>
#include <stdio.h>
int main(void)
char *map;
int fd;
system("grep mlockfreed /proc/vmstat");
fd = open("chigurh", O_CREAT|O_EXCL|O_RDWR);
unlink("chigurh");
ftruncate(fd, 4096);
map = mmap(NULL, 4096, PROT_WRITE, MAP_PRIVATE, fd, 0);
map[0] = 11;
mlock(map, sizeof(fd));
ftruncate(fd, 0);
close(fd);
munlock(map, sizeof(fd));
munmap(map, 4096);
return 0;
The anon COWed pages are not caught by truncation's clear_page_mlock() of
the pagecache pages; but unmap_mapping_range() unmaps them, so we ought to
look out for them there in page_remove_rmap(). Indeed, why should
truncation or invalidation be doing the clear_page_mlock() when removing
from pagecache? mlock is a property of mapping in userspace, not a
property of pagecache: an mlocked unmapped page is nonsensical.
Reported-by: Johannes Weiner <hannes@cmpxchg.org>
Cc: Ying Han <yinghan@google.com>
Implement an interval tree as a replacement for the VMA prio_tree. The
algorithms are similar to lib/interval_tree.c; however that code can't be
directly reused as the interval endpoints are not explicitly stored in the
VMA. So instead, the common algorithm is moved into a template and the
details (node type, how to get interval endpoints from the node, etc) are
filled in using the C preprocessor.
Once the interval tree functions are available, using them as a
replacement to the VMA prio tree is a relatively simple, mechanical job.
Cc: Hillf Danton <dhillf@gmail.com>
A long time ago, in v2.4, VM_RESERVED kept swapout process off VMA,
currently it lost original meaning but still has some effects:
| effect | alternative flags
1| account as reserved_vm | VM_IO
2| skip in core dump | VM_IO, VM_DONTDUMP
3| do not merge or expand | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP
4| do not mlock | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP
This patch removes reserved_vm counter from mm_struct. Seems like nobody
cares about it, it does not exported into userspace directly, it only
reduces total_vm showed in proc.
Thus VM_RESERVED can be replaced with VM_IO or pair VM_DONTEXPAND | VM_DONTDUMP.
remap_pfn_range() and io_remap_pfn_range() set VM_IO|VM_DONTEXPAND|VM_DONTDUMP.
remap_vmalloc_range() set VM_DONTEXPAND | VM_DONTDUMP.
[akpm@linux-foundation.org: drivers/vfio/pci/vfio_pci.c fixup]
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Cc: Carsten Otte <cotte@de.ibm.com>
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Eric Paris <eparis@redhat.com>
Cc: James Morris <james.l.morris@oracle.com>
Cc: Jason Baron <jbaron@redhat.com>
Cc: Kentaro Takeda <takedakn@nttdata.co.jp>
Cc: Matt Helsley <matthltc@us.ibm.com>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Robert Richter <robert.richter@amd.com>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: Venkatesh Pallipadi <venki@google.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Merge VM_INSERTPAGE into VM_MIXEDMAP. VM_MIXEDMAP VMA can mix pure-pfn
ptes, special ptes and normal ptes.
Now copy_page_range() always copies VM_MIXEDMAP VMA on fork like
VM_PFNMAP. If driver populates whole VMA at mmap() it probably not
expects page-faults.
This patch removes special check from vma_wants_writenotify() which
disables pages write tracking for VMA populated via vm_instert_page().
BDI below mapped file should not use dirty-accounting, moreover
do_wp_page() can handle this.
vm_insert_page() still marks vma after first usage. Usually it is called
from f_op->mmap() handler under mm->mmap_sem write-lock, so it able to
change vma->vm_flags. Caller must set VM_MIXEDMAP at mmap time if it
wants to call this function from other places, for example from page-fault
handler.
Replace the generic vma-flag VM_PFN_AT_MMAP with x86-only VM_PAT.
We can toss mapping address from remap_pfn_range() into
track_pfn_vma_new(), and collect all PAT-related logic together in
arch/x86/.
This patch also restores orignal frustration-free is_cow_mapping() check
in remap_pfn_range(), as it was before commit v2.6.28-rc8-88-g3c8bb73
("x86: PAT: store vm_pgoff for all linear_over_vma_region mappings - v3")
is_linear_pfn_mapping() checks can be removed from mm/huge_memory.c,
because it already handled by VM_PFNMAP in VM_NO_THP bit-mask.
[suresh.b.siddha@intel.com: Reset the VM_PAT flag as part of untrack_pfn_vma()]
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
vm_insert_pfn
With PAT enabled, vm_insert_pfn() looks up the existing pfn memory
attribute and uses it. Expectation is that the driver reserves the
memory attributes for the pfn before calling vm_insert_pfn().
remap_pfn_range() (when called for the whole vma) will setup a new
attribute (based on the prot argument) for the specified pfn range.
This addresses the legacy usage which typically calls remap_pfn_range()
with a desired memory attribute. For ranges smaller than the vma size
(which is typically not the case), remap_pfn_range() will use the
existing memory attribute for the pfn range.
Expose two different API's for these different behaviors.
track_pfn_insert() for tracking the pfn attribute set by vm_insert_pfn()
and track_pfn_remap() for the remap_pfn_range().
This cleanup also prepares the ground for the track/untrack pfn vma
routines to take over the ownership of setting PAT specific vm_flag in
the 'vma'.
[khlebnikov@openvz.org: Clear checks in track_pfn_remap()]
[akpm@linux-foundation.org: tweak a few comments]
Cc: Konstantin Khlebnikov <khlebnikov@openvz.org>
Pull second vfs pile from Al Viro:
"The stuff in there: fsfreeze deadlock fixes by Jan (essentially, the
deadlock reproduced by xfstests 068), symlink and hardlink restriction
patches, plus assorted cleanups and fixes.
Note that another fsfreeze deadlock (emergency thaw one) is *not*
dealt with - the series by Fernando conflicts a lot with Jan's, breaks
userland ABI (FIFREEZE semantics gets changed) and trades the deadlock
for massive vfsmount leak; this is going to be handled next cycle.
There probably will be another pull request, but that stuff won't be
in it."
Fix up trivial conflicts due to unrelated changes next to each other in
drivers/{staging/gdm72xx/usb_boot.c, usb/gadget/storage_common.c}
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (54 commits)
delousing target_core_file a bit
Documentation: Correct s_umount state for freeze_fs/unfreeze_fs
fs: Remove old freezing mechanism
ext2: Implement freezing
btrfs: Convert to new freezing mechanism
nilfs2: Convert to new freezing mechanism
ntfs: Convert to new freezing mechanism
fuse: Convert to new freezing mechanism
gfs2: Convert to new freezing mechanism
ocfs2: Convert to new freezing mechanism
xfs: Convert to new freezing code
ext4: Convert to new freezing mechanism
fs: Protect write paths by sb_start_write - sb_end_write
fs: Skip atime update on frozen filesystem
fs: Add freezing handling to mnt_want_write() / mnt_drop_write()
fs: Improve filesystem freezing handling
switch the protection of percpu_counter list to spinlock
nfsd: Push mnt_want_write() outside of i_mutex
btrfs: Push mnt_want_write() outside of i_mutex
fat: Push mnt_want_write() outside of i_mutex
If a process creates a large hugetlbfs mapping that is eligible for page
table sharing and forks heavily with children some of whom fault and
others which destroy the mapping then it is possible for page tables to
get corrupted. Some teardowns of the mapping encounter a "bad pmd" and
output a message to the kernel log. The final teardown will trigger a
BUG_ON in mm/filemap.c.
This was reproduced in 3.4 but is known to have existed for a long time
and goes back at least as far as 2.6.37. It was probably was introduced
in 2.6.20 by [39dde65c: shared page table for hugetlb page]. The messages
look like this;
[ ..........] Lots of bad pmd messages followed by this
[ 127.164256] mm/memory.c:391: bad pmd ffff880412e04fe8(80000003de4000e7).
[ 127.164257] mm/memory.c:391: bad pmd ffff880412e04ff0(80000003de6000e7).
[ 127.164258] mm/memory.c:391: bad pmd ffff880412e04ff8(80000003de0000e7).
[ 127.186778] ------------[ cut here ]------------
[ 127.186781] kernel BUG at mm/filemap.c:134!
[ 127.186782] invalid opcode: 0000 [#1] SMP
[ 127.186783] CPU 7
[ 127.186784] Modules linked in: af_packet cpufreq_conservative cpufreq_userspace cpufreq_powersave acpi_cpufreq mperf ext3 jbd dm_mod coretemp crc32c_intel usb_storage ghash_clmulni_intel aesni_intel i2c_i801 r8169 mii uas sr_mod cdrom sg iTCO_wdt iTCO_vendor_support shpchp serio_raw cryptd aes_x86_64 e1000e pci_hotplug dcdbas aes_generic container microcode ext4 mbcache jbd2 crc16 sd_mod crc_t10dif i915 drm_kms_helper drm i2c_algo_bit ehci_hcd ahci libahci usbcore rtc_cmos usb_common button i2c_core intel_agp video intel_gtt fan processor thermal thermal_sys hwmon ata_generic pata_atiixp libata scsi_mod
[ 127.186801]
[ 127.186802] Pid: 9017, comm: hugetlbfs-test Not tainted 3.4.0-autobuild #53 Dell Inc. OptiPlex 990/06D7TR
[ 127.186804] RIP: 0010:[<ffffffff810ed6ce>] [<ffffffff810ed6ce>] __delete_from_page_cache+0x15e/0x160
[ 127.186809] RSP: 0000:ffff8804144b5c08 EFLAGS: 00010002
[ 127.186810] RAX: 0000000000000001 RBX: ffffea000a5c9000 RCX: 00000000ffffffc0
[ 127.186811] RDX: 0000000000000000 RSI: 0000000000000009 RDI: ffff88042dfdad00
[ 127.186812] RBP: ffff8804144b5c18 R08: 0000000000000009 R09: 0000000000000003
[ 127.186813] R10: 0000000000000000 R11: 000000000000002d R12: ffff880412ff83d8
[ 127.186814] R13: ffff880412ff83d8 R14: 0000000000000000 R15: ffff880412ff83d8
[ 127.186815] FS: 00007fe18ed2c700(0000) GS:ffff88042dce0000(0000) knlGS:0000000000000000
[ 127.186816] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 127.186817] CR2: 00007fe340000503 CR3: 0000000417a14000 CR4: 00000000000407e0
[ 127.186818] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 127.186819] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 127.186820] Process hugetlbfs-test (pid: 9017, threadinfo ffff8804144b4000, task ffff880417f803c0)
[ 127.186821] Stack:
[ 127.186822] ffffea000a5c9000 0000000000000000 ffff8804144b5c48 ffffffff810ed83b
[ 127.186824] ffff8804144b5c48 000000000000138a 0000000000001387 ffff8804144b5c98
[ 127.186825] ffff8804144b5d48 ffffffff811bc925 ffff8804144b5cb8 0000000000000000
[ 127.186827] Call Trace:
[ 127.186829] [<ffffffff810ed83b>] delete_from_page_cache+0x3b/0x80
[ 127.186832] [<ffffffff811bc925>] truncate_hugepages+0x115/0x220
[ 127.186834] [<ffffffff811bca43>] hugetlbfs_evict_inode+0x13/0x30
[ 127.186837] [<ffffffff811655c7>] evict+0xa7/0x1b0
[ 127.186839] [<ffffffff811657a3>] iput_final+0xd3/0x1f0
[ 127.186840] [<ffffffff811658f9>] iput+0x39/0x50
[ 127.186842] [<ffffffff81162708>] d_kill+0xf8/0x130
[ 127.186843] [<ffffffff81162812>] dput+0xd2/0x1a0
[ 127.186845] [<ffffffff8114e2d0>] __fput+0x170/0x230
[ 127.186848] [<ffffffff81236e0e>] ? rb_erase+0xce/0x150
[ 127.186849] [<ffffffff8114e3ad>] fput+0x1d/0x30
[ 127.186851] [<ffffffff81117db7>] remove_vma+0x37/0x80
[ 127.186853] [<ffffffff81119182>] do_munmap+0x2d2/0x360
[ 127.186855] [<ffffffff811cc639>] sys_shmdt+0xc9/0x170
[ 127.186857] [<ffffffff81410a39>] system_call_fastpath+0x16/0x1b
[ 127.186858] Code: 0f 1f 44 00 00 48 8b 43 08 48 8b 00 48 8b 40 28 8b b0 40 03 00 00 85 f6 0f 88 df fe ff ff 48 89 df e8 e7 cb 05 00 e9 d2 fe ff ff <0f> 0b 55 83 e2 fd 48 89 e5 48 83 ec 30 48 89 5d d8 4c 89 65 e0
[ 127.186868] RIP [<ffffffff810ed6ce>] __delete_from_page_cache+0x15e/0x160
[ 127.186870] RSP <ffff8804144b5c08>
[ 127.186871] ---[ end trace 7cbac5d1db69f426 ]---
The bug is a race and not always easy to reproduce. To reproduce it I was
doing the following on a single socket I7-based machine with 16G of RAM.
$ hugeadm --pool-pages-max DEFAULT:13G
$ echo $((18*1048576*1024)) > /proc/sys/kernel/shmmax
$ echo $((18*1048576*1024)) > /proc/sys/kernel/shmall
$ for i in `seq 1 9000`; do ./hugetlbfs-test; done
On my particular machine, it usually triggers within 10 minutes but
enabling debug options can change the timing such that it never hits.
Once the bug is triggered, the machine is in trouble and needs to be
rebooted. The machine will respond but processes accessing proc like "ps
aux" will hang due to the BUG_ON. shutdown will also hang and needs a
hard reset or a sysrq-b.
The basic problem is a race between page table sharing and teardown. For
the most part page table sharing depends on i_mmap_mutex. In some cases,
it is also taking the mm->page_table_lock for the PTE updates but with
shared page tables, it is the i_mmap_mutex that is more important.
Unfortunately it appears to be also insufficient. Consider the following
situation
Process A Process B
hugetlb_fault shmdt
LockWrite(mmap_sem)
do_munmap
unmap_region
unmap_vmas
unmap_single_vma
unmap_hugepage_range
Lock(i_mmap_mutex)
Lock(mm->page_table_lock)
huge_pmd_unshare/unmap tables <--- (1)
Unlock(mm->page_table_lock)
Unlock(i_mmap_mutex)
huge_pte_alloc ...
Lock(i_mmap_mutex) ...
vma_prio_walk, find svma, spte ...
Lock(mm->page_table_lock) ...
share spte ...
Unlock(mm->page_table_lock) ...
Unlock(i_mmap_mutex) ...
hugetlb_no_page <--- (2)
free_pgtables
unlink_file_vma
hugetlb_free_pgd_range
remove_vma_list
In this scenario, it is possible for Process A to share page tables with
Process B that is trying to tear them down. The i_mmap_mutex on its own
does not prevent Process A walking Process B's page tables. At (1) above,
the page tables are not shared yet so it unmaps the PMDs. Process A sets
up page table sharing and at (2) faults a new entry. Process B then trips
up on it in free_pgtables.
This patch fixes the problem by adding a new function
__unmap_hugepage_range_final that is only called when the VMA is about to
be destroyed. This function clears VM_MAYSHARE during
unmap_hugepage_range() under the i_mmap_mutex. This makes the VMA
ineligible for sharing and avoids the race. Superficially this looks like
it would then be vunerable to truncate and madvise issues but hugetlbfs
has its own truncate handlers so does not use unmap_mapping_range() and
does not support madvise(DONTNEED).
This should be treated as a -stable candidate if it is merged.
Test program is as follows. The test case was mostly written by Michal
Hocko with a few minor changes to reproduce this bug.
==== CUT HERE ====
static size_t huge_page_size = (2UL << 20);
static size_t nr_huge_page_A = 512;
static size_t nr_huge_page_B = 5632;
unsigned int get_random(unsigned int max)
struct timeval tv;
gettimeofday(&tv, NULL);
srandom(tv.tv_usec);
return random() % max;
static void play(void *addr, size_t size)
unsigned char *start = addr,
*end = start + size,
*a;
start += get_random(size/2);
/* we could itterate on huge pages but let's give it more time. */
for (a = start; a < end; a += 4096)
*a = 0;
int main(int argc, char **argv)
key_t key = IPC_PRIVATE;
size_t sizeA = nr_huge_page_A * huge_page_size;
size_t sizeB = nr_huge_page_B * huge_page_size;
int shmidA, shmidB;
void *addrA = NULL, *addrB = NULL;
int nr_children = 300, n = 0;
if ((shmidA = shmget(key, sizeA, IPC_CREAT|SHM_HUGETLB|0660)) == -1) {
perror("shmget:");
return 1;
if ((addrA = shmat(shmidA, addrA, SHM_R|SHM_W)) == (void *)-1UL) {
perror("shmat");
return 1;
if ((shmidB = shmget(key, sizeB, IPC_CREAT|SHM_HUGETLB|0660)) == -1) {
perror("shmget:");
return 1;
if ((addrB = shmat(shmidB, addrB, SHM_R|SHM_W)) == (void *)-1UL) {
perror("shmat");
return 1;
fork_child:
switch(fork()) {
case 0:
switch (n%3) {
case 0:
play(addrA, sizeA);
break;
case 1:
play(addrB, sizeB);
break;
case 2:
break;
break;
case -1:
perror("fork:");
break;
default:
if (++n < nr_children)
goto fork_child;
play(addrA, sizeA);
break;
shmdt(addrA);
shmdt(addrB);
do {
wait(NULL);
} while (--n > 0);
shmctl(shmidA, IPC_RMID, NULL);
shmctl(shmidB, IPC_RMID, NULL);
return 0;
[akpm@linux-foundation.org: name the declaration's args, fix CONFIG_HUGETLBFS=n build]
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Call up_read(&mm->mmap_sem) directly since we have already got mm via
current->mm at the beginning of print_vma_addr().
Signed-off-by: Jie Liu <jeff.liu@oracle.com>
pages
Use a mmu_gather instead of a temporary linked list for accumulating pages
when we unmap a hugepage range
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Filesystems wanting to properly support freezing need to have control
when file_update_time() is called. After pushing file_update_time()
to all relevant .page_mkwrite implementations we can just stop calling
file_update_time() when filesystem implements .page_mkwrite.
Tested-by: Kamal Mostafa <kamal@canonical.com>
Tested-by: Peter M. Petrakis <peter.petrakis@canonical.com>
Tested-by: Dann Frazier <dann.frazier@canonical.com>
Tested-by: Massimo Morana <massimo.morana@canonical.com>
Pull x86/mm changes from Peter Anvin:
"The big change here is the patchset by Alex Shi to use INVLPG to flush
only the affected pages when we only need to flush a small page range.
It also removes the special INVALIDATE_TLB_VECTOR interrupts (32
vectors!) and replace it with an ordinary IPI function call."
Fix up trivial conflicts in arch/x86/include/asm/apic.h (added code next
to changed line)
* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/tlb: Fix build warning and crash when building for !SMP
x86/tlb: do flush_tlb_kernel_range by 'invlpg'
x86/tlb: replace INVALIDATE_TLB_VECTOR by CALL_FUNCTION_VECTOR
x86/tlb: enable tlb flush range support for x86
mm/mmu_gather: enable tlb flush range in generic mmu_gather
x86/tlb: add tlb_flushall_shift knob into debugfs
x86/tlb: add tlb_flushall_shift for specific CPU
x86/tlb: fall back to flush all when meet a THP large page
x86/flush_tlb: try flush_tlb_single one by one in flush_tlb_range
x86/tlb_info: get last level TLB entry number of CPU
x86: Add read_mostly declaration/definition to variables from smp.h
x86: Define early read-mostly per-cpu macros
This patch enabled the tlb flush range support in generic mmu layer.
Most of arch has self tlb flush range support, like ARM/IA64 etc.
X86 arch has no this support in hardware yet. But another instruction
'invlpg' can implement this function in some degree. So, enable this
feather in generic layer for x86 now. and maybe useful for other archs
in further.
Generic mmu_gather struct is protected by micro
HAVE_GENERIC_MMU_GATHER. Other archs that has flush range supported
own self mmu_gather struct. So, now this change is safe for them.
In future we may unify this struct and related functions on multiple
archs.
Thanks for Peter Zijlstra time and time reminder for multiple
architecture code safe!
Signed-off-by: Alex Shi <alex.shi@intel.com>
Link: http://lkml.kernel.org/r/1340845344-27557-7-git-send-email-alex.shi@intel.com
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Fix kernel-doc warnings in mm/memory.c:
Warning(mm/memory.c:1377): No description found for parameter 'start'
Warning(mm/memory.c:1377): Excess function parameter 'address' description in 'zap_page_range'
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Andrea asked for addr, end, vma->vm_start, and vma->vm_end to be emitted
when !rwsem_is_locked(&tlb->mm->mmap_sem). Otherwise, debugging the
underlying issue is more difficult.
Suggested-by: Andrea Arcangeli <aarcange@redhat.com>
