When memory is hot-added, all the memory is in offline state. So clear
all zones' present_pages because they will be updated in online_pages()
and offline_pages(). Otherwise, /proc/zoneinfo will corrupt:
When the memory of node2 is offline:
# cat /proc/zoneinfo
Node 2, zone Movable
spanned 8388608
present 8388608
managed 0
When we online memory on node2:
spanned 8388608
present 16777216
managed 8388608
Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com>
Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: <stable@vger.kernel.org> [3.16+]
In free_area_init_core(), zone->managed_pages is set to an approximate
value for lowmem, and will be adjusted when the bootmem allocator frees
pages into the buddy system.
But free_area_init_core() is also called by hotadd_new_pgdat() when
hot-adding memory. As a result, zone->managed_pages of the newly added
node's pgdat is set to an approximate value in the very beginning.
Even if the memory on that node has node been onlined,
/sys/device/system/node/nodeXXX/meminfo has wrong value:
hot-add node2 (memory not onlined)
cat /sys/device/system/node/node2/meminfo
Node 2 MemTotal: 33554432 kB
Node 2 MemFree: 0 kB
Node 2 MemUsed: 33554432 kB
Node 2 Active: 0 kB
This patch fixes this problem by reset node managed pages to 0 after
hot-adding a new node.
1. Move reset_managed_pages_done from reset_node_managed_pages() to
reset_all_zones_managed_pages()
2. Make reset_node_managed_pages() non-static
3. Call reset_node_managed_pages() in hotadd_new_pgdat() after pgdat
is initialized
Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
When hot adding the same memory after hot removal, the following
messages are shown:
WARNING: CPU: 20 PID: 6 at mm/page_alloc.c:4968 free_area_init_node+0x3fe/0x426()
Call Trace:
dump_stack+0x46/0x58
warn_slowpath_common+0x81/0xa0
warn_slowpath_null+0x1a/0x20
hotadd_new_pgdat+0x90/0x110
add_memory+0xd4/0x200
acpi_memory_device_add+0x1aa/0x289
acpi_bus_attach+0xfd/0x204
acpi_bus_attach+0x178/0x204
acpi_bus_scan+0x6a/0x90
acpi_device_hotplug+0xe8/0x418
acpi_hotplug_work_fn+0x1f/0x2b
process_one_work+0x14e/0x3f0
worker_thread+0x11b/0x510
kthread+0xe1/0x100
ret_from_fork+0x7c/0xb0
The detaled explanation is as follows:
When hot removing memory, pgdat is set to 0 in try_offline_node(). But
if the pgdat is allocated by bootmem allocator, the clearing step is
skipped.
And when hot adding the same memory, the uninitialized pgdat is reused.
But free_area_init_node() checks wether pgdat is set to zero. As a
result, free_area_init_node() hits WARN_ON().
This patch clears pgdat which is allocated by bootmem allocator in
try_offline_node().
Cc: Zhang Zhen <zhenzhang.zhang@huawei.com>
Cc: Wang Nan <wangnan0@huawei.com>
Cc: Tang Chen <tangchen@cn.fujitsu.com>
Reviewed-by: Toshi Kani <toshi.kani@hp.com>
Currently memory-hotplug has two limits:
1. If the memory block is in ZONE_NORMAL, you can change it to
ZONE_MOVABLE, but this memory block must be adjacent to ZONE_MOVABLE.
2. If the memory block is in ZONE_MOVABLE, you can change it to
ZONE_NORMAL, but this memory block must be adjacent to ZONE_NORMAL.
With this patch, we can easy to know a memory block can be onlined to
which zone, and don't need to know the above two limits.
Updated the related Documentation.
[akpm@linux-foundation.org: use conventional comment layout]
[akpm@linux-foundation.org: fix build with CONFIG_MEMORY_HOTREMOVE=n]
[akpm@linux-foundation.org: remove unused local zone_prev]
Signed-off-by: Zhang Zhen <zhenzhang.zhang@huawei.com>
Cc: Toshi Kani <toshi.kani@hp.com>
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
This series of patches fixes a problem when adding memory in bad manner.
For example: for a x86_64 machine booted with "mem=400M" and with 2GiB
memory installed, following commands cause problem:
# echo 0x40000000 > /sys/devices/system/memory/probe
[ 28.613895] init_memory_mapping: [mem 0x40000000-0x47ffffff]
# echo 0x48000000 > /sys/devices/system/memory/probe
[ 28.693675] init_memory_mapping: [mem 0x48000000-0x4fffffff]
# echo online_movable > /sys/devices/system/memory/memory9/state
# echo 0x50000000 > /sys/devices/system/memory/probe
[ 29.084090] init_memory_mapping: [mem 0x50000000-0x57ffffff]
# echo 0x58000000 > /sys/devices/system/memory/probe
[ 29.151880] init_memory_mapping: [mem 0x58000000-0x5fffffff]
# echo online_movable > /sys/devices/system/memory/memory11/state
# echo online> /sys/devices/system/memory/memory8/state
# echo online> /sys/devices/system/memory/memory10/state
# echo offline> /sys/devices/system/memory/memory9/state
[ 30.558819] Offlined Pages 32768
# free
total used free shared buffers cached
Mem: 780588 18014398509432020 830552 0 0 51180
-/+ buffers/cache: 18014398509380840 881732
Swap: 0 0 0
This is because the above commands probe higher memory after online a
section with online_movable, which causes ZONE_HIGHMEM (or ZONE_NORMAL
for systems without ZONE_HIGHMEM) overlaps ZONE_MOVABLE.
After the second online_movable, the problem can be observed from
zoneinfo:
Node 0, zone Movable
pages free 65491
min 250
low 312
high 375
scanned 0
spanned 18446744073709518848
present 65536
managed 65536
This series of patches solve the problem by checking ZONE_MOVABLE when
choosing zone for new memory. If new memory is inside or higher than
ZONE_MOVABLE, makes it go there instead.
After applying this series of patches, following are free and zoneinfo
result (after offlining memory9):
bash-4.2# free
Mem: 780956 80112 700844 0 0 51180
-/+ buffers/cache: 28932 752024
Swap: 0 0 0
bash-4.2# cat /proc/zoneinfo
Node 0, zone DMA
pages free 3389
min 14
low 17
high 21
scanned 0
spanned 4095
present 3998
managed 3977
nr_free_pages 3389
start_pfn: 1
inactive_ratio: 1
Node 0, zone DMA32
pages free 73724
min 341
low 426
high 511
scanned 0
spanned 98304
present 98304
managed 92958
nr_free_pages 73724
start_pfn: 4096
inactive_ratio: 1
Node 0, zone Normal
pages free 32630
min 120
low 150
high 180
scanned 0
spanned 32768
present 32768
managed 32768
nr_free_pages 32630
start_pfn: 262144
inactive_ratio: 1
pages free 65476
min 241
low 301
high 361
scanned 0
spanned 98304
present 65536
managed 65536
nr_free_pages 65476
start_pfn: 294912
inactive_ratio: 1
This patch (of 7):
Introduce zone_for_memory() in arch independent code for
arch_add_memory() use.
Many arch_add_memory() function simply selects ZONE_HIGHMEM or
ZONE_NORMAL and add new memory into it. However, with the existance of
ZONE_MOVABLE, the selection method should be carefully considered: if
new, higher memory is added after ZONE_MOVABLE is setup, the default
zone and ZONE_MOVABLE may overlap each other.
should_add_memory_movable() checks the status of ZONE_MOVABLE. If it
has already contain memory, compare the address of new memory and
movable memory. If new memory is higher than movable, it should be
added into ZONE_MOVABLE instead of default zone.
Signed-off-by: Wang Nan <wangnan0@huawei.com>
Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: "Mel Gorman" <mgorman@suse.de>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
In store_mem_state(), we have:
334 else if (!strncmp(buf, "offline", min_t(int, count, 7)))
335 online_type = -1;
355 case -1:
356 ret = device_offline(&mem->dev);
357 break;
Here, "offline" is hard coded as -1.
This patch does the following renaming:
ONLINE_KEEP -> MMOP_ONLINE_KEEP
ONLINE_KERNEL -> MMOP_ONLINE_KERNEL
ONLINE_MOVABLE -> MMOP_ONLINE_MOVABLE
and introduces MMOP_OFFLINE = -1 to avoid hard coding.
Cc: Hu Tao <hutao@cn.fujitsu.com>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Gu Zheng <guz.fnst@cn.fujitsu.com>
grow_zone_span and grow_pgdat_span are only called by
__meminit __add_zone
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Acked-by: David Rientjes <rientjes@google.com>
Memory migration uses a callback defined by the caller to determine how to
allocate destination pages. When migration fails for a source page,
however, it frees the destination page back to the system.
This patch adds a memory migration callback defined by the caller to
determine how to free destination pages. If a caller, such as memory
compaction, builds its own freelist for migration targets, this can reuse
already freed memory instead of scanning additional memory.
If the caller provides a function to handle freeing of destination pages,
it is called when page migration fails. If the caller passes NULL then
freeing back to the system will be handled as usual. This patch
introduces no functional change.
Signed-off-by: David Rientjes <rientjes@google.com>
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Replace ((x) >> PAGE_SHIFT) with the pfn macro.
kmem_cache_{create,destroy,shrink} need to get a stable value of
cpu/node online mask, because they init/destroy/access per-cpu/node
kmem_cache parts, which can be allocated or destroyed on cpu/mem
hotplug. To protect against cpu hotplug, these functions use
{get,put}_online_cpus. However, they do nothing to synchronize with
memory hotplug - taking the slab_mutex does not eliminate the
possibility of race as described in patch 2.
What we need there is something like get_online_cpus, but for memory.
We already have lock_memory_hotplug, which serves for the purpose, but
it's a bit of a hammer right now, because it's backed by a mutex. As a
result, it imposes some limitations to locking order, which are not
desirable, and can't be used just like get_online_cpus. That's why in
patch 1 I substitute it with get/put_online_mems, which work exactly
like get/put_online_cpus except they block not cpu, but memory hotplug.
[ v1 can be found at https://lkml.org/lkml/2014/4/6/68. I NAK'ed it by
myself, because it used an rw semaphore for get/put_online_mems,
making them dead lock prune. ]
This patch (of 2):
{un}lock_memory_hotplug, which is used to synchronize against memory
hotplug, is currently backed by a mutex, which makes it a bit of a
hammer - threads that only want to get a stable value of online nodes
mask won't be able to proceed concurrently. Also, it imposes some
strong locking ordering rules on it, which narrows down the set of its
usage scenarios.
This patch introduces get/put_online_mems, which are the same as
get/put_online_cpus, but for memory hotplug, i.e. executing a code
inside a get/put_online_mems section will guarantee a stable value of
online nodes, present pages, etc.
lock_memory_hotplug()/unlock_memory_hotplug() are removed altogether.
Signed-off-by: Vladimir Davydov <vdavydov@parallels.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Xishi Qiu <qiuxishi@huawei.com>
Cc: Jiang Liu <liuj97@gmail.com>
Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Cc: Wen Congyang <wency@cn.fujitsu.com>
lock_memory_hotplug
We don't need to do register_memory_resource() under
lock_memory_hotplug() since it has its own lock and doesn't make any
callbacks.
Also register_memory_resource return NULL on failure so we don't have
anything to cleanup at this point.
The reason for this rfc is I was doing some experiments with hotplugging
of memory on some of our larger systems. While it seems to work, it can
be quite slow. With some preliminary digging I found that
lock_memory_hotplug is clearly ripe for breakup.
It could be broken up per nid or something but it also covers the
online_page_callback. The online_page_callback shouldn't be very hard
to break out.
Also there is the issue of various structures(wmarks come to mind) that
are only updated under the lock_memory_hotplug that would need to be
dealt with.
Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: "Rafael J. Wysocki" <rafael.j.wysocki@intel.com>
Cc: Hedi <hedi@sgi.com>
Cc: Mike Travis <travis@sgi.com>
bad_page() is cool in that it prints out a bunch of data about the page.
But, I can never remember which page flags are good and which are bad,
or whether ->index or ->mapping is required to be NULL.
This patch allows bad/dump_page() callers to specify a string about why
they are dumping the page and adds explanation strings to a number of
places. It also adds a 'bad_flags' argument to bad_page(), which it
then dumps out separately from the flags which are actually set.
This way, the messages will show specifically why the page was bad,
*specifically* which flags it is complaining about, if it was a page
flag combination which was the problem.
[akpm@linux-foundation.org: switch to pr_alert]
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Reviewed-by: Christoph Lameter <cl@linux.com>
Correct ensure_zone_is_initialized() function description according to
the introduced memblock APIs for early memory allocations.
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Paul Walmsley <paul@pwsan.com>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Tejun Heo <tj@kernel.org>
Cc: Tony Lindgren <tony@atomide.com>
Clean-up to remove depedency with bootmem headers.
Reviewed-by: Tejun Heo <tj@kernel.org>
Linux kernel cannot migrate pages used by the kernel. As a result,
hotpluggable memory used by the kernel won't be able to be hot-removed.
To solve this problem, the basic idea is to prevent memblock from
allocating hotpluggable memory for the kernel at early time, and arrange
all hotpluggable memory in ACPI SRAT(System Resource Affinity Table) as
ZONE_MOVABLE when initializing zones.
In the previous patches, we have marked hotpluggable memory regions with
MEMBLOCK_HOTPLUG flag in memblock.memory.
In this patch, we make memblock skip these hotpluggable memory regions
in the default top-down allocation function if movable_node boot option
is specified.
Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
Cc: "Rafael J . Wysocki" <rjw@sisk.pl>
Cc: Chen Tang <imtangchen@gmail.com>
Cc: Gong Chen <gong.chen@linux.intel.com>
Cc: Jiang Liu <jiang.liu@huawei.com>
Cc: Larry Woodman <lwoodman@redhat.com>
Cc: Len Brown <lenb@kernel.org>
Cc: Liu Jiang <jiang.liu@huawei.com>
Cc: Michal Nazarewicz <mina86@mina86.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Taku Izumi <izumi.taku@jp.fujitsu.com>
Cc: Thomas Renninger <trenn@suse.de>
Cc: Vasilis Liaskovitis <vasilis.liaskovitis@profitbricks.com>
Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com>
The hot-Pluggable field in SRAT specifies which memory is hotpluggable.
As we mentioned before, if hotpluggable memory is used by the kernel, it
cannot be hot-removed. So memory hotplug users may want to set all
hotpluggable memory in ZONE_MOVABLE so that the kernel won't use it.
Memory hotplug users may also set a node as movable node, which has
ZONE_MOVABLE only, so that the whole node can be hot-removed.
But the kernel cannot use memory in ZONE_MOVABLE. By doing this, the
kernel cannot use memory in movable nodes. This will cause NUMA
performance down. And other users may be unhappy.
So we need a way to allow users to enable and disable this functionality.
In this patch, we introduce movable_node boot option to allow users to
choose to not to consume hotpluggable memory at early boot time and later
we can set it as ZONE_MOVABLE.
To achieve this, the movable_node boot option will control the memblock
allocation direction. That said, after memblock is ready, before SRAT is
parsed, we should allocate memory near the kernel image as we explained in
the previous patches. So if movable_node boot option is set, the kernel
does the following:
1. After memblock is ready, make memblock allocate memory bottom up.
2. After SRAT is parsed, make memblock behave as default, allocate memory
top down.
Users can specify "movable_node" in kernel commandline to enable this
functionality. For those who don't use memory hotplug or who don't want
to lose their NUMA performance, just don't specify anything. The kernel
will work as before.
Suggested-by: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Suggested-by: Ingo Molnar <mingo@kernel.org>
Acked-by: Tejun Heo <tj@kernel.org>
Acked-by: Toshi Kani <toshi.kani@hp.com>
For below functions,
- sparse_add_one_section()
- kmalloc_section_memmap()
- __kmalloc_section_memmap()
- __kfree_section_memmap()
they are always invoked to operate on one memory section, so it is
redundant to always pass a nr_pages parameter, which is the page numbers
in one section. So we can directly use predefined macro PAGES_PER_SECTION
instead of passing the parameter.
Cc: Yasunori Goto <y-goto@jp.fujitsu.com>
Cc: Andy Whitcroft <apw@shadowen.org>
cpu_up() has #ifdef CONFIG_MEMORY_HOTPLUG code blocks, which call
mem_online_node() to put its node online if offlined and then call
build_all_zonelists() to initialize the zone list.
These steps are specific to memory hotplug, and should be managed in
mm/memory_hotplug.c. lock_memory_hotplug() should also be held for the
whole steps.
For this reason, this patch replaces mem_online_node() with
try_online_node(), which performs the whole steps with
lock_memory_hotplug() held. try_online_node() is named after
try_offline_node() as they have similar purpose.
There is no functional change in this patch.
Signed-off-by: Toshi Kani <toshi.kani@hp.com>
Use "pfn_to_nid(pfn)" instead of "page_to_nid(pfn_to_page(pfn))".
Signed-off-by: Xishi Qiu <qiuxishi@huawei.com>
Acked-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
A is_memblock_offlined() return or 1 means memory block is offlined, but
is_memblock_offlined_cb() returning 1 means memory block is not offlined,
this will confuse somebody, so rename the function.
Use "pgdat_end_pfn()" instead of "pgdat->node_start_pfn +
pgdat->node_spanned_pages". Simplify the code, no functional change.
Pull ACPI and power management fixes from Rafael Wysocki:
"All of these commits are fixes that have emerged recently and some of
them fix bugs introduced during this merge window.
Specifics:
1) ACPI-based PCI hotplug (ACPIPHP) fixes related to spurious events
After the recent ACPIPHP changes we've seen some interesting
breakage on a system that triggers device check notifications
during boot for non-existing devices. Although those
notifications are really spurious, we should be able to deal with
them nevertheless and that shouldn't introduce too much overhead.
Four commits to make that work properly.
2) Memory hotplug and hibernation mutual exclusion rework
This was maent to be a cleanup, but it happens to fix a classical
ABBA deadlock between system suspend/hibernation and ACPI memory
hotplug which is possible if they are started roughly at the same
time. Three commits rework memory hotplug so that it doesn't
acquire pm_mutex and make hibernation use device_hotplug_lock
which prevents it from racing with memory hotplug.
3) ACPI Intel LPSS (Low-Power Subsystem) driver crash fix
The ACPI LPSS driver crashes during boot on Apple Macbook Air with
Haswell that has slightly unusual BIOS configuration in which one
of the LPSS device's _CRS method doesn't return all of the
information expected by the driver. Fix from Mika Westerberg, for
stable.
4) ACPICA fix related to Store->ArgX operation
AML interpreter fix for obscure breakage that causes AML to be
executed incorrectly on some machines (observed in practice).
From Bob Moore.
5) ACPI core fix for PCI ACPI device objects lookup
There still are cases in which there is more than one ACPI device
object matching a given PCI device and we don't choose the one
that the BIOS expects us to choose, so this makes the lookup take
more criteria into account in those cases.
6) Fix to prevent cpuidle from crashing in some rare cases
If the result of cpuidle_get_driver() is NULL, which can happen on
some systems, cpuidle_driver_ref() will crash trying to use that
pointer and the Daniel Fu's fix prevents that from happening.
7) cpufreq fixes related to CPU hotplug
Stephen Boyd reported a number of concurrency problems with
cpufreq related to CPU hotplug which are addressed by a series of
fixes from Srivatsa S Bhat and Viresh Kumar.
8) cpufreq fix for time conversion in time_in_state attribute
Time conversion carried out by cpufreq when user space attempts to
read /sys/devices/system/cpu/cpu*/cpufreq/stats/time_in_state
won't work correcty if cputime_t doesn't map directly to jiffies.
Fix from Andreas Schwab.
9) Revert of a troublesome cpufreq commit
Commit 7c30ed5 (cpufreq: make sure frequency transitions are
serialized) was intended to address some known concurrency
problems in cpufreq related to the ordering of transitions, but
unfortunately it introduced several problems of its own, so I
decided to revert it now and address the original problems later
in a more robust way.
10) Intel Haswell CPU models for intel_pstate from Nell Hardcastle.
11) cpufreq fixes related to system suspend/resume
The recent cpufreq changes that made it preserve CPU sysfs
attributes over suspend/resume cycles introduced a possible NULL
pointer dereference that caused it to crash during the second
attempt to suspend. Three commits from Srivatsa S Bhat fix that
problem and a couple of related issues.
12) cpufreq locking fix
cpufreq_policy_restore() should acquire the lock for reading, but
it acquires it for writing. Fix from Lan Tianyu"
* tag 'pm+acpi-fixes-3.12-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (25 commits)
cpufreq: Acquire the lock in cpufreq_policy_restore() for reading
cpufreq: Prevent problems in update_policy_cpu() if last_cpu == new_cpu
cpufreq: Restructure if/else block to avoid unintended behavior
cpufreq: Fix crash in cpufreq-stats during suspend/resume
intel_pstate: Add Haswell CPU models
Revert "cpufreq: make sure frequency transitions are serialized"
cpufreq: Use signed type for 'ret' variable, to store negative error values
cpufreq: Remove temporary fix for race between CPU hotplug and sysfs-writes
cpufreq: Synchronize the cpufreq store_*() routines with CPU hotplug
cpufreq: Invoke __cpufreq_remove_dev_finish() after releasing cpu_hotplug.lock
cpufreq: Split __cpufreq_remove_dev() into two parts
cpufreq: Fix wrong time unit conversion
cpufreq: serialize calls to __cpufreq_governor()
cpufreq: don't allow governor limits to be changed when it is disabled
ACPI / bind: Prefer device objects with _STA to those without it
ACPI / hotplug / PCI: Avoid parent bus rescans on spurious device checks
ACPI / hotplug / PCI: Use _OST to notify firmware about notify status
ACPI / hotplug / PCI: Avoid doing too much for spurious notifies
ACPICA: Fix for a Store->ArgX when ArgX contains a reference to a field.
ACPI / hotplug / PCI: Don't trim devices before scanning the namespace
Until now we can't offline memory blocks which contain hugepages because a
hugepage is considered as an unmovable page. But now with this patch
series, a hugepage has become movable, so by using hugepage migration we
can offline such memory blocks.
What's different from other users of hugepage migration is that we need to
decompose all the hugepages inside the target memory block into free buddy
pages after hugepage migration, because otherwise free hugepages remaining
in the memory block intervene the memory offlining. For this reason we
introduce new functions dissolve_free_huge_page() and
dissolve_free_huge_pages().
Other than that, what this patch does is straightforwardly to add hugepage
migration code, that is, adding hugepage code to the functions which scan
over pfn and collect hugepages to be migrated, and adding a hugepage
allocation function to alloc_migrate_target().
As for larger hugepages (1GB for x86_64), it's not easy to do hotremove
over them because it's larger than memory block. So we now simply leave
it to fail as it is.
[yongjun_wei@trendmicro.com.cn: remove duplicated include]
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Acked-by: Andi Kleen <ak@linux.intel.com>
Cc: Hillf Danton <dhillf@gmail.com>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
lock_device_hotplug() serializes hotplug & online/offline operations. The
lock is held in common sysfs online/offline interfaces and ACPI hotplug
code paths.
And here are the code paths:
- CPU & Mem online/offline via sysfs online
store_online()->lock_device_hotplug()
- Mem online via sysfs state:
store_mem_state()->lock_device_hotplug()
- ACPI CPU & Mem hot-add:
acpi_scan_bus_device_check()->lock_device_hotplug()
- ACPI CPU & Mem hot-delete:
acpi_scan_hot_remove()->lock_device_hotplug()
try_offline_node() off-lines a node if all memory sections and cpus are
removed on the node. It is called from acpi_processor_remove() and
acpi_memory_remove_memory()->remove_memory() paths, both of which are in
the ACPI hotplug code.
try_offline_node() calls stop_machine() to stop all cpus while checking
all cpu status with the assumption that the caller is not protected from
CPU hotplug or CPU online/offline operations. However, the caller is
always serialized with lock_device_hotplug(). Also, the code needs to be
properly serialized with a lock, not by stopping all cpus at a random
place with stop_machine().
This patch removes the use of stop_machine() in try_offline_node() and
adds comments to try_offline_node() and remove_memory() that
lock_device_hotplug() is required.
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
add_memory() and remove_memory() can only handle a memory range aligned
with section. There are problems when an unaligned range is added and
then deleted as follows:
- add_memory() with an unaligned range succeeds, but __add_pages()
called from add_memory() adds a whole section of pages even though
a given memory range is less than the section size.
- remove_memory() to the added unaligned range hits BUG_ON() in
__remove_pages().
This patch changes add_memory() and remove_memory() to check if a given
memory range is aligned with section at the beginning. As the result,
add_memory() fails with -EINVAL when a given range is unaligned, and does
not add such memory range. This prevents remove_memory() to be called
with an unaligned range as well. Note that remove_memory() has to use
BUG_ON() since this function cannot fail.
[akpm@linux-foundation.org: avoid printk warnings]
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Reviewed-by: Tang Chen <tangchen@cn.fujitsu.com>
Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com>
Use "zone_is_initialized()" instead of "if (zone->wait_table)".
Cc: Cody P Schafer <cody@linux.vnet.ibm.com>
Use "zone_is_empty()" instead of "if (zone->spanned_pages)".
Use "zone_end_pfn()" instead of "zone->zone_start_pfn + zone->spanned_pages".
[akpm@linux-foundation.org: fix build]
I think we can remove "BUG_ON(start_pfn >= end_pfn)" in __offline_pages(),
because in memory_block_action() "nr_pages = PAGES_PER_SECTION * sections_per_block"
is always greater than 0.
offline_pages()
__offline_pages()
In v2.6.32, If info->length==0, this way may hit this BUG_ON().
acpi_memory_disable_device()
remove_memory(info->start_addr, info->length)
offline_pages()
A later Fujitsu patch renamed this function and the BUG_ON() is
unnecessary.
Reviewed-by: Dave Hansen <dave.hansen@linux.intel.com>
Since all of the memory hotplug operations have to be carried out
under device_hotplug_lock, they won't need to acquire pm_mutex if
device_hotplug_lock is held around hibernation.
For this reason, make the hibernation code acquire
device_hotplug_lock after freezing user space processes and
release it before thawing them. At the same tim drop the
lock_system_sleep() and unlock_system_sleep() calls from
lock_memory_hotplug() and unlock_memory_hotplug(), respectively.
online_pages() is called from memory_block_action() when a user requests
to online a memory block via sysfs. This function needs to return a
proper error value in case of error.
Merge first patch-bomb from Andrew Morton:
- various misc bits
- I'm been patchmonkeying ocfs2 for a while, as Joel and Mark have been
distracted. There has been quite a bit of activity.
- About half the MM queue
- Some backlight bits
- Various lib/ updates
- checkpatch updates
- zillions more little rtc patches
- ptrace
- signals
- exec
- procfs
- rapidio
- nbd
- aoe
- pps
- memstick
- tools/testing/selftests updates
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (445 commits)
tools/testing/selftests: don't assume the x bit is set on scripts
selftests: add .gitignore for kcmp
selftests: fix clean target in kcmp Makefile
selftests: add .gitignore for vm
selftests: add hugetlbfstest
self-test: fix make clean
selftests: exit 1 on failure
kernel/resource.c: remove the unneeded assignment in function __find_resource
aio: fix wrong comment in aio_complete()
drivers/w1/slaves/w1_ds2408.c: add magic sequence to disable P0 test mode
drivers/memstick/host/r592.c: convert to module_pci_driver
drivers/memstick/host/jmb38x_ms: convert to module_pci_driver
pps-gpio: add device-tree binding and support
drivers/pps/clients/pps-gpio.c: convert to module_platform_driver
drivers/pps/clients/pps-gpio.c: convert to devm_* helpers
drivers/parport/share.c: use kzalloc
Documentation/accounting/getdelays.c: avoid strncpy in accounting tool
aoe: update internal version number to v83
aoe: update copyright date
aoe: perform I/O completions in parallel
Prepare for removing num_physpages.
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Enhance adjust_managed_page_count() to adjust totalhigh_pages for
highmem pages. And change code which directly adjusts totalram_pages to
use adjust_managed_page_count() because it adjusts totalram_pages,
totalhigh_pages and zone->managed_pages altogether in a safe way.
Remove inc_totalhigh_pages() and dec_totalhigh_pages() from xen/balloon
driver bacause adjust_managed_page_count() has already adjusted
totalhigh_pages.
This patch also fixes two bugs:
1) enhances virtio_balloon driver to adjust totalhigh_pages when
reserve/unreserve pages.
2) enhance memory_hotplug.c to adjust totalhigh_pages when hot-removing
memory.
We still need to deal with modifications of totalram_pages in file
arch/powerpc/platforms/pseries/cmm.c, but need help from PPC experts.
[akpm@linux-foundation.org: remove ifdef, per Wanpeng Li, virtio_balloon.c cleanup, per Sergei]
[akpm@linux-foundation.org: export adjust_managed_page_count() to modules, for drivers/virtio/virtio_balloon.c]
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Cc: <sworddragon2@aol.com>
Cc: Jianguo Wu <wujianguo@huawei.com>
Cc: Joonsoo Kim <js1304@gmail.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
In order to simpilify management of totalram_pages and
zone->managed_pages, make __free_pages_bootmem() only available at boot
time. With this change applied, __free_pages_bootmem() will only be
used by bootmem.c and nobootmem.c at boot time, so mark it as __init.
Other callers of __free_pages_bootmem() have been converted to use
free_reserved_page(), which handles totalram_pages and
zone->managed_pages in a safer way.
This patch also fix a bug in free_pagetable() for x86_64, which should
increase zone->managed_pages instead of zone->present_pages when freeing
reserved pages.
And now we have managed_pages_count_lock to protect totalram_pages and
zone->managed_pages, so remove the redundant ppb_lock lock in
put_page_bootmem(). This greatly simplifies the locking rules.
Fix some trivial typos in comments.
During early boot-up, iomem_resource is set up from the boot descriptor
table, such as EFI Memory Table and e820. Later,
acpi_memory_device_add() calls add_memory() for each ACPI memory device
object as it enumerates ACPI namespace. This add_memory() call is
expected to fail in register_memory_resource() at boot since
iomem_resource has been set up from EFI/e820. As a result, add_memory()
returns -EEXIST, which acpi_memory_device_add() handles as the normal
case.
This scheme works fine, but the following error message is logged for
every ACPI memory device object during boot-up.
"System RAM resource %pR cannot be added\n"
This patch changes register_memory_resource() to use pr_debug() for the
message as it shows up under the normal case.
mmzone.h documents node_size_lock (which pgdat_resize_lock() locks) as
follows:
* Must be held any time you expect node_start_pfn, node_present_pages
* or node_spanned_pages stay constant. [...]
So actually hold it when we update node_present_pages in __offline_pages().
Signed-off-by: Cody P Schafer <cody@linux.vnet.ibm.com>
follows:
So actually hold it when we update node_present_pages in online_pages().
* acpi-hotplug:
ACPI: Do not use CONFIG_ACPI_HOTPLUG_MEMORY_MODULE
ACPI / cpufreq: Add ACPI processor device IDs to acpi-cpufreq
Memory hotplug: Move alternative function definitions to header
ACPI / processor: Fix potential NULL pointer dereference in acpi_processor_add()
Memory hotplug / ACPI: Simplify memory removal
ACPI / scan: Add second pass of companion offlining to hot-remove code
Driver core / MM: Drop offline_memory_block()
ACPI / processor: Pass processor object handle to acpi_bind_one()
ACPI: Drop removal_type field from struct acpi_device
Driver core / memory: Simplify __memory_block_change_state()
ACPI / processor: Initialize per_cpu(processors, pr->id) properly
CPU: Fix sysfs cpu/online of offlined CPUs
Driver core: Introduce offline/online callbacks for memory blocks
ACPI / memhotplug: Bind removable memory blocks to ACPI device nodes
ACPI / processor: Use common hotplug infrastructure
ACPI / hotplug: Use device offline/online for graceful hot-removal
Driver core: Use generic offline/online for CPU offline/online
Driver core: Add offline/online device operations
Move the definitions of offline_pages() and remove_memory()
for CONFIG_MEMORY_HOTREMOVE to memory_hotplug.h, where they belong,
and make them static inline.
Now that the memory offlining should be taken care of by the
companion device offlining code in acpi_scan_hot_remove(), the
ACPI memory hotplug driver doesn't need to offline it in
remove_memory() any more. Moreover, since the return value of
remove_memory() is not used, it's better to make it be a void
function and trigger a BUG() if the memory scheduled for removal is
not offline.
Change the code in accordance with the above observations.
Since offline_memory_block(mem) is functionally equivalent to
device_offline(&mem->dev), make the only caller of the former use
the latter instead and drop offline_memory_block() entirely.
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Fix printk format warnings in mm/memory_hotplug.c by using "%pa":
mm/memory_hotplug.c: warning: format '%llx' expects argument of type 'long long unsigned int', but argument 2 has type 'resource_size_t' [-Wformat]
mm/memory_hotplug.c: warning: format '%llx' expects argument of type 'long long unsigned int', but argument 3 has type 'resource_size_t' [-Wformat]
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
During ACPI memory hotplug configuration bind memory blocks residing
in modules removable through the standard ACPI mechanism to struct
acpi_device objects associated with ACPI namespace objects
representing those modules. Accordingly, unbind those memory blocks
from the struct acpi_device objects when the memory modules in
question are being removed.
When "offline" operation for devices representing memory blocks is
introduced, this will allow the ACPI core's device hot-remove code to
use it to carry out remove_memory() for those memory blocks and check
the results of that before it actually removes the modules holding
them from the system.
Since walk_memory_range() is used for accessing all memory blocks
corresponding to a given ACPI namespace object, it is exported from
memory_hotplug.c so that the code in acpi_memhotplug.c can use it.
Tested-by: Vasilis Liaskovitis <vasilis.liaskovitis@profitbricks.com>
PFN_PHYS() is a phys_addr_t, which can be u32 or u64.
Fix the build warning when phys_addr_t is u32.
mm/memory_hotplug.c: warning: format '%llx' expects argument of type 'long long unsigned int', but argument 2 has type 'unsigned int' [-Wformat]: => 1685:3
mm/memory_hotplug.c: warning: format '%llx' expects argument of type 'long long unsigned int', but argument 3 has type 'unsigned int' [-Wformat]: => 1685:3
__remove_pages() is only necessary for CONFIG_MEMORY_HOTREMOVE. PowerPC
pseries will return -EOPNOTSUPP if unsupported.
Adding an #ifdef causes several other functions it depends on to also
become unnecessary, which saves in .text when disabled (it's disabled in
most defconfigs besides powerpc, including x86). remove_memory_block()
becomes static since it is not referenced outside of
drivers/base/memory.c.
Build tested on x86 and powerpc with CONFIG_MEMORY_HOTREMOVE both enabled
and disabled.
Change __remove_pages() to call release_mem_region_adjustable(). This
allows a requested memory range to be released from the iomem_resource
table even if it does not match exactly to an resource entry but still
fits into. The resource entries initialized at bootup usually cover the
whole contiguous memory ranges and may not necessarily match with the
size of memory hot-delete requests.
If release_mem_region_adjustable() failed, __remove_pages() emits a
warning message and continues to proceed as it was the case with
release_mem_region(). release_mem_region(), which is defined to
__release_region(), emits a warning message and returns no error since a
void function.
Reviewed-by : Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: Ram Pai <linuxram@us.ibm.com>
Cc: T Makphaibulchoke <tmac@hp.com>
Fix a typo "end_pft" in the comment of walk_memory_range().
