path: root/mm/mempolicy.c
2008-10-20Unevictable LRU InfrastructureLee Schermerhorn
When the system contains lots of mlocked or otherwise unevictable pages, the pageout code (kswapd) can spend lots of time scanning over these pages. Worse still, the presence of lots of unevictable pages can confuse kswapd into thinking that more aggressive pageout modes are required, resulting in all kinds of bad behaviour. Infrastructure to manage pages excluded from reclaim--i.e., hidden from vmscan. Based on a patch by Larry Woodman of Red Hat. Reworked to maintain "unevictable" pages on a separate per-zone LRU list, to "hide" them from vmscan. Kosaki Motohiro added the support for the memory controller unevictable lru list. Pages on the unevictable list have both PG_unevictable and PG_lru set. Thus, PG_unevictable is analogous to and mutually exclusive with PG_active--it specifies which LRU list the page is on. The unevictable infrastructure is enabled by a new mm Kconfig option [CONFIG_]UNEVICTABLE_LRU. A new function 'page_evictable(page, vma)' in vmscan.c tests whether or not a page may be evictable. Subsequent patches will add the various !evictable tests. We'll want to keep these tests light-weight for use in shrink_active_list() and, possibly, the fault path. To avoid races between tasks putting pages [back] onto an LRU list and tasks that might be moving the page from non-evictable to evictable state, the new function 'putback_lru_page()' -- inverse to 'isolate_lru_page()' -- tests the "evictability" of a page after placing it on the LRU, before dropping the reference. If the page has become unevictable, putback_lru_page() will redo the 'putback', thus moving the page to the unevictable list. This way, we avoid "stranding" evictable pages on the unevictable list. [akpm@linux-foundation.org: fix fallout from out-of-order merge] [riel@redhat.com: fix UNEVICTABLE_LRU and !PROC_PAGE_MONITOR build] [nishimura@mxp.nes.nec.co.jp: remove redundant mapping check] [kosaki.motohiro@jp.fujitsu.com: unevictable-lru-infrastructure: putback_lru_page()/unevictable page handling rework] [kosaki.motohiro@jp.fujitsu.com: kill unnecessary lock_page() in vmscan.c] [kosaki.motohiro@jp.fujitsu.com: revert migration change of unevictable lru infrastructure] [kosaki.motohiro@jp.fujitsu.com: revert to unevictable-lru-infrastructure-kconfig-fix.patch] [kosaki.motohiro@jp.fujitsu.com: restore patch failure of vmstat-unevictable-and-mlocked-pages-vm-events.patch] Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Debugged-by: Benjamin Kidwell <benjkidwell@yahoo.com> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20vmscan: move isolate_lru_page() to vmscan.cNick Piggin
On large memory systems, the VM can spend way too much time scanning through pages that it cannot (or should not) evict from memory. Not only does it use up CPU time, but it also provokes lock contention and can leave large systems under memory presure in a catatonic state. This patch series improves VM scalability by: 1) putting filesystem backed, swap backed and unevictable pages onto their own LRUs, so the system only scans the pages that it can/should evict from memory 2) switching to two handed clock replacement for the anonymous LRUs, so the number of pages that need to be scanned when the system starts swapping is bound to a reasonable number 3) keeping unevictable pages off the LRU completely, so the VM does not waste CPU time scanning them. ramfs, ramdisk, SHM_LOCKED shared memory segments and mlock()ed VMA pages are keept on the unevictable list. This patch: isolate_lru_page logically belongs to be in vmscan.c than migrate.c. It is tough, because we don't need that function without memory migration so there is a valid argument to have it in migrate.c. However a subsequent patch needs to make use of it in the core mm, so we can happily move it to vmscan.c. Also, make the function a little more generic by not requiring that it adds an isolated page to a given list. Callers can do that. Note that we now have '__isolate_lru_page()', that does something quite different, visible outside of vmscan.c for use with memory controller. Methinks we need to rationalize these names/purposes. --lts [akpm@linux-foundation.org: fix mm/memory_hotplug.c build] Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12do_migrate_pages(): remove unused variableMinChan Kim
Signed-off-by: MinChan Kim <minchan.kim@gmail.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24hugetlb: modular state for hugetlb page sizeAndi Kleen
The goal of this patchset is to support multiple hugetlb page sizes. This is achieved by introducing a new struct hstate structure, which encapsulates the important hugetlb state and constants (eg. huge page size, number of huge pages currently allocated, etc). The hstate structure is then passed around the code which requires these fields, they will do the right thing regardless of the exact hstate they are operating on. This patch adds the hstate structure, with a single global instance of it (default_hstate), and does the basic work of converting hugetlb to use the hstate. Future patches will add more hstate structures to allow for different hugetlbfs mounts to have different page sizes. [akpm@linux-foundation.org: coding-style fixes] Acked-by: Adam Litke <agl@us.ibm.com> Acked-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-04mempolicy: mask off internal flags for userspace APIDavid Rientjes
Flags considered internal to the mempolicy kernel code are stored as part of the "flags" member of struct mempolicy. Before exposing a policy type to userspace via get_mempolicy(), these internal flags must be masked. Flags exposed to userspace, however, should still be returned to the user. Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: use struct mempolicy pointer in shmem_sb_infoLee Schermerhorn
This patch replaces the mempolicy mode, mode_flags, and nodemask in the shmem_sb_info struct with a struct mempolicy pointer, initialized to NULL. This removes dependency on the details of mempolicy from shmem.c and hugetlbfs inode.c and simplifies the interfaces. mpol_parse_str() in mempolicy.c is changed to return, via a pointer to a pointer arg, a struct mempolicy pointer on success. For MPOL_DEFAULT, the returned pointer is NULL. Further, mpol_parse_str() now takes a 'no_context' argument that causes the input nodemask to be stored in the w.user_nodemask of the created mempolicy for use when the mempolicy is installed in a tmpfs inode shared policy tree. At that time, any cpuset contextualization is applied to the original input nodemask. This preserves the previous behavior where the input nodemask was stored in the superblock. We can think of the returned mempolicy as "context free". Because mpol_parse_str() is now calling mpol_new(), we can remove from mpol_to_str() the semantic checks that mpol_new() already performs. Add 'no_context' parameter to mpol_to_str() to specify that it should format the nodemask in w.user_nodemask for 'bind' and 'interleave' policies. Change mpol_shared_policy_init() to take a pointer to a "context free" struct mempolicy and to create a new, "contextualized" mempolicy using the mode, mode_flags and user_nodemask from the input mempolicy. Note: we know that the mempolicy passed to mpol_to_str() or mpol_shared_policy_init() from a tmpfs superblock is "context free". This is currently the only instance thereof. However, if we found more uses for this concept, and introduced any ambiguity as to whether a mempolicy was context free or not, we could add another internal mode flag to identify context free mempolicies. Then, we could remove the 'no_context' argument from mpol_to_str(). Added shmem_get_sbmpol() to return a reference counted superblock mempolicy, if one exists, to pass to mpol_shared_policy_init(). We must add the reference under the sb stat_lock to prevent races with replacement of the mpol by remount. This reference is removed in mpol_shared_policy_init(). [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: another build fix] [akpm@linux-foundation.org: yet another build fix] Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: support mpol=local tmpfs mount optionLee Schermerhorn
For tmpfs/shmem shared policies, MPOL_DEFAULT is not necessarily equivalent to "local allocation". Because shared policies are at the same "scope" level [see Documentation/vm/numa_memory_policy.txt], as vma policies MPOL_DEFAULT means "fall back to current task policy". This patch extends the memory policy string parsing function to display "local" for MPOL_PREFERRED + MPOL_F_LOCAL. This allows one to specify local allocation as the default policy for shared memory areas via the tmpfs mpol mount option, regardless of the current task's policy. Also, "local" is now displayed for this policy. This patch allows us to accept the same input format as the display. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: rework shmem mpol parsing and displayLee Schermerhorn
mm/shmem.c currently contains functions to parse and display memory policy strings for the tmpfs 'mpol' mount option. Move this to mm/mempolicy.c with the rest of the mempolicy support. With subsequent patches, we'll be able to remove knowledge of the details [mode, flags, policy, ...] completely from shmem.c 1) replace shmem_parse_mpol() in mm/shmem.c with mpol_parse_str() in mm/mempolicy.c. Rework to use the policy_types[] array [used by mpol_to_str()] to look up mode by name. 2) use mpol_to_str() to format policy for shmem_show_mpol(). mpol_to_str() expects a pointer to a struct mempolicy, so temporarily construct one. This will be replaced with a reference to a struct mempolicy in the tmpfs superblock in a subsequent patch. NOTE 1: I changed mpol_to_str() to use a colon ':' rather than an equal sign '=' as the nodemask delimiter to match mpol_parse_str() and the tmpfs/shmem mpol mount option formatting that now uses mpol_to_str(). This is a user visible change to numa_maps, but then the addition of the mode flags already changed the display. It makes sense to me to have the mounts and numa_maps display the policy in the same format. However, if anyone objects strongly, I can pass the desired nodemask delimeter as an arg to mpol_to_str(). Note 2: Like show_numa_map(), I don't check the return code from mpol_to_str(). I do use a longer buffer than the one provided by show_numa_map(), which seems to have sufficed so far. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: clean-up mpol-to-str() mempolicy formattingLee Schermerhorn
mpol-to-str() formats memory policies into printable strings. Currently this is only used to display "numa_maps". A subsequent patch will use mpol_to_str() for formatting tmpfs [shmem] mpol mount options, allowing us to remove essentially duplicate code in mm/shmem.c. This patch cleans up mpol_to_str() generally and in preparation for that patch. 1) show_numa_maps() is not checking the return code from mpol_to_str(). There's not a lot we can do in this context if mpol_to_str() did return the error [insufficient space in buffer]. Proposed "solution": just check, under DEBUG_VM, that callers are providing sufficient buffer space for the policy, flags, and a few nodes. This way, we'll get some display. show_numa_maps() is providing a 50-byte buffer, so it won't trip this check. 50-bytes should be sufficient unless one has a large number of nodes in a very sparse nodemask. 2) The display of the new mode flags ["static" & "relative"] was set up to display multiple flags, separated by a "bar" '|'. However, this support is incomplete--e.g., need_bar was never incremented; and currently, these two flags are mutually exclusive. So remove the "bar" support, for now, and only display one flag. 3) Use snprint() to format flags, so as not to overflow the buffer. Not that it's ever happed, AFAIK. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: use MPOL_F_LOCAL to Indicate Preferred Local PolicyLee Schermerhorn
Now that we're using "preferred local" policy for system default, we need to make this as fast as possible. Because of the variable size of the mempolicy structure [based on size of nodemasks], the preferred_node may be in a different cacheline from the mode. This can result in accessing an extra cacheline in the normal case of system default policy. Suspect this is the cause of an observed 2-3% slowdown in page fault testing relative to kernel without this patch series. To alleviate this, use an internal mode flag, MPOL_F_LOCAL in the mempolicy flags member which is guaranteed [?] to be in the same cacheline as the mode itself. Verified that reworked mempolicy now performs slightly better on 25-rc8-mm1 for both anon and shmem segments with system default and vma [preferred local] policy. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: mPOL_PREFERRED cleanups for "local allocation"Lee Schermerhorn
Here are a couple of "cleanups" for MPOL_PREFERRED behavior when v.preferred_node < 0 -- i.e., "local allocation": 1) [do_]get_mempolicy() calls the now renamed get_policy_nodemask() to fetch the nodemask associated with a policy. Currently, get_policy_nodemask() returns the set of nodes with memory, when the policy 'mode' is 'PREFERRED, and the preferred_node is < 0. Change to return an empty nodemask, as this is what was specified to achieve "local allocation". 2) When a task is moved into a [new] cpuset, mpol_rebind_policy() is called to adjust any task and vma policy nodes to be valid in the new cpuset. However, when the policy is MPOL_PREFERRED, and the preferred_node is <0, no rebind is necessary. The "local allocation" indication is valid in any cpuset. Existing code will "do the right thing" because node_remap() will just return the argument node when it is outside of the valid range of node ids. However, I think it is clearer and cleaner to skip the remap explicitly in this case. 3) mpol_to_str() produces a printable, "human readable" string from a struct mempolicy. For MPOL_PREFERRED with preferred_node <0, show "local", as this indicates local allocation, as the task migrates among nodes. Note that this matches the usage of "local allocation" in libnuma() and numactl. Without this change, I believe that node_set() [via set_bit()] will set bit 31, resulting in a misleading display. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: use MPOL_PREFERRED for system-wide default policyLee Schermerhorn
Currently, when one specifies MPOL_DEFAULT via a NUMA memory policy API [set_mempolicy(), mbind() and internal versions], the kernel simply installs a NULL struct mempolicy pointer in the appropriate context: task policy, vma policy, or shared policy. This causes any use of that policy to "fall back" to the next most specific policy scope. The only use of MPOL_DEFAULT to mean "local allocation" is in the system default policy. This requires extra checks/cases for MPOL_DEFAULT in many mempolicy.c functions. There is another, "preferred" way to specify local allocation via the APIs. That is using the MPOL_PREFERRED policy mode with an empty nodemask. Internally, the empty nodemask gets converted to a preferred_node id of '-1'. All internal usage of MPOL_PREFERRED will convert the '-1' to the id of the node local to the cpu where the allocation occurs. System default policy, except during boot, is hard-coded to "local allocation". By using the MPOL_PREFERRED mode with a negative value of preferred node for system default policy, MPOL_DEFAULT will never occur in the 'policy' member of a struct mempolicy. Thus, we can remove all checks for MPOL_DEFAULT when converting policy to a node id/zonelist in the allocation paths. In slab_node() return local node id when policy pointer is NULL. No need to set a pol value to take the switch default. Replace switch default with BUG()--i.e., shouldn't happen. With this patch MPOL_DEFAULT is only used in the APIs, including internal calls to do_set_mempolicy() and in the display of policy in /proc/<pid>/numa_maps. It always means "fall back" to the the next most specific policy scope. This simplifies the description of memory policies quite a bit, with no visible change in behavior. get_mempolicy() continues to return MPOL_DEFAULT and an empty nodemask when the requested policy [task or vma/shared] is NULL. These are the values one would supply via set_mempolicy() or mbind() to achieve that condition--default behavior. This patch updates Documentation to reflect this change. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: rework mempolicy Reference Counting [yet again]Lee Schermerhorn
After further discussion with Christoph Lameter, it has become clear that my earlier attempts to clean up the mempolicy reference counting were a bit of overkill in some areas, resulting in superflous ref/unref in what are usually fast paths. In other areas, further inspection reveals that I botched the unref for interleave policies. A separate patch, suitable for upstream/stable trees, fixes up the known errors in the previous attempt to fix reference counting. This patch reworks the memory policy referencing counting and, one hopes, simplifies the code. Maybe I'll get it right this time. See the update to the numa_memory_policy.txt document for a discussion of memory policy reference counting that motivates this patch. Summary: Lookup of mempolicy, based on (vma, address) need only add a reference for shared policy, and we need only unref the policy when finished for shared policies. So, this patch backs out all of the unneeded extra reference counting added by my previous attempt. It then unrefs only shared policies when we're finished with them, using the mpol_cond_put() [conditional put] helper function introduced by this patch. Note that shmem_swapin() calls read_swap_cache_async() with a dummy vma containing just the policy. read_swap_cache_async() can call alloc_page_vma() multiple times, so we can't let alloc_page_vma() unref the shared policy in this case. To avoid this, we make a copy of any non-null shared policy and remove the MPOL_F_SHARED flag from the copy. This copy occurs before reading a page [or multiple pages] from swap, so the overhead should not be an issue here. I introduced a new static inline function "mpol_cond_copy()" to copy the shared policy to an on-stack policy and remove the flags that would require a conditional free. The current implementation of mpol_cond_copy() assumes that the struct mempolicy contains no pointers to dynamically allocated structures that must be duplicated or reference counted during copy. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: mark shared policies for unrefLee Schermerhorn
As part of yet another rework of mempolicy reference counting, we want to be able to identify shared policies efficiently, because they have an extra ref taken on lookup that needs to be removed when we're finished using the policy. Note: the extra ref is required because the policies are shared between tasks/processes and can be changed/freed by one task while another task is using them--e.g., for page allocation. Building on David Rientjes mempolicy "mode flags" enhancement, this patch indicates a "shared" policy by setting a new MPOL_F_SHARED flag in the flags member of the struct mempolicy added by David. MPOL_F_SHARED, and any future "internal mode flags" are reserved from bit zero up, as they will never be passed in the upper bits of the mode argument of a mempolicy API. I set the MPOL_F_SHARED flag when the policy is installed in the shared policy rb-tree. Don't need/want to clear the flag when removing from the tree as the mempolicy is freed [unref'd] internally to the sp_delete() function. However, a task could hold another reference on this mempolicy from a prior lookup. We need the MPOL_F_SHARED flag to stay put so that any tasks holding a ref will unref, eventually freeing, the mempolicy. A later patch in this series will introduce a function to conditionally unref [mpol_free] a policy. The MPOL_F_SHARED flag is one reason [currently the only reason] to unref/free a policy via the conditional free. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: rename struct mempolicy 'policy' member to 'mode'Lee Schermerhorn
The terms 'policy' and 'mode' are both used in various places to describe the semantics of the value stored in the 'policy' member of struct mempolicy. Furthermore, the term 'policy' is used to refer to that member, to the entire struct mempolicy and to the more abstract concept of the tuple consisting of a "mode" and an optional node or set of nodes. Recently, we have added "mode flags" that are passed in the upper bits of the 'mode' [or sometimes, 'policy'] member of the numa APIs. I'd like to resolve this confusion, which perhaps only exists in my mind, by renaming the 'policy' member to 'mode' throughout, and fixing up the Documentation. Man pages will be updated separately. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: fixup Fallback for Default Shmem PolicyLee Schermerhorn
get_vma_policy() is not handling fallback to task policy correctly when the get_policy() vm_op returns NULL. The NULL overwrites the 'pol' variable that was holding the fallback task mempolicy. So, it was falling back directly to system default policy. Fix get_vma_policy() to use only non-NULL policy returned from the vma get_policy op. shm_get_policy() was falling back to current task's mempolicy if the "backing file system" [tmpfs vs hugetlbfs] does not support the get_policy vm_op and the vma policy is null. This is incorrect for show_numa_maps() which is likely querying the numa_maps of some task other than current. Remove this fallback. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: write lock mmap_sem while changing task mempolicyLee Schermerhorn
A read of /proc/<pid>/numa_maps holds the target task's mmap_sem for read while examining each vma's mempolicy. A vma's mempolicy can fall back to the task's policy. However, the task could be changing it's task policy and free the one that the show_numa_maps() is examining. To prevent this, grab the mmap_sem for write when updating task mempolicy. Pointed out to me by Christoph Lameter and extracted and reworked from Christoph's alternative mempol reference counting patch. This is analogous to the way that do_mbind() and do_get_mempolicy() prevent races between task's sharing an mm_struct [a.k.a. threads] setting and querying a mempolicy for a particular address. Note: this is necessary, but not sufficient, to allow us to stop taking an extra reference on "other task's mempolicy" in get_vma_policy. Subsequent patches will complete this update, allowing us to simplify the tests for whether we need to unref a mempolicy at various points in the code. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: rename mpol_copy to mpol_dupLee Schermerhorn
This patch renames mpol_copy() to mpol_dup() because, well, that's what it does. Like, e.g., strdup() for strings, mpol_dup() takes a pointer to an existing mempolicy, allocates a new one and copies the contents. In a later patch, I want to use the name mpol_copy() to copy the contents from one mempolicy to another like, e.g., strcpy() does for strings. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: rename mpol_free to mpol_putLee Schermerhorn
This is a change that was requested some time ago by Mel Gorman. Makes sense to me, so here it is. Note: I retain the name "mpol_free_shared_policy()" because it actually does free the shared_policy, which is NOT a reference counted object. However, ... The mempolicy object[s] referenced by the shared_policy are reference counted, so mpol_put() is used to release the reference held by the shared_policy. The mempolicy might not be freed at this time, because some task attached to the shared object associated with the shared policy may be in the process of allocating a page based on the mempolicy. In that case, the task performing the allocation will hold a reference on the mempolicy, obtained via mpol_shared_policy_lookup(). The mempolicy will be freed when all tasks holding such a reference have called mpol_put() for the mempolicy. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: disallow static or relative flags for local preferred modeDavid Rientjes
MPOL_F_STATIC_NODES and MPOL_F_RELATIVE_NODES don't mean anything for MPOL_PREFERRED policies that were created with an empty nodemask (for purely local allocations). They'll never be invalidated because the allowed mems of a task changes or need to be rebound relative to a cpuset's placement. Also fixes a bug identified by Lee Schermerhorn that disallowed empty nodemasks to be passed to MPOL_PREFERRED to specify local allocations. [A different, somewhat incomplete, patch already existed in 25-rc5-mm1.] Cc: Paul Jackson <pj@sgi.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Andi Kleen <ak@suse.de> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: create mempolicy_operations structureDavid Rientjes
Create a mempolicy_operations structure that currently points to two functions[*] for the various modes: int (*create)(struct mempolicy *, const nodemask_t *); void (*rebind)(struct mempolicy *, const nodemask_t *); This splits the implementation for the various modes out of two large functions, mpol_new() and mpol_rebind_policy(). Eventually it may be beneficial to add additional functions to accomodate the existing switch() statements in mm/mempolicy.c. [*] The ->create() function for MPOL_DEFAULT is currently NULL since no struct mempolicy is dynamically allocated. [Lee.Schermerhorn@hp.com: fix regression in the package mempolicy regression tests] Signed-off-by: David Rientjes <rientjes@google.com> Cc: Paul Jackson <pj@sgi.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Eric Whitney <eric.whitney@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: move rebind functionsDavid Rientjes
Move the mpol_rebind_{policy,task,mm}() functions after mpol_new() to avoid having to declare function prototypes. Cc: Paul Jackson <pj@sgi.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: add MPOL_F_RELATIVE_NODES flagDavid Rientjes
Adds another optional mode flag, MPOL_F_RELATIVE_NODES, that specifies nodemasks passed via set_mempolicy() or mbind() should be considered relative to the current task's mems_allowed. When the mempolicy is created, the passed nodemask is folded and mapped onto the current task's mems_allowed. For example, consider a task using set_mempolicy() to pass MPOL_INTERLEAVE | MPOL_F_RELATIVE_NODES with a nodemask of 1-3. If current's mems_allowed is 4-7, the effected nodemask is 5-7 (the second, third, and fourth node of mems_allowed). If the same task is attached to a cpuset, the mempolicy nodemask is rebound each time the mems are changed. Some possible rebinds and results are: mems result 1-3 1-3 1-7 2-4 1,5-6 1,5-6 1,5-7 5-7 Likewise, the zonelist built for MPOL_BIND acts on the set of zones assigned to the resultant nodemask from the relative remap. In the MPOL_PREFERRED case, the preferred node is remapped from the currently effected nodemask to the relative nodemask. This mempolicy mode flag was conceived of by Paul Jackson <pj@sgi.com>. Cc: Paul Jackson <pj@sgi.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: add MPOL_F_STATIC_NODES flagDavid Rientjes
Add an optional mempolicy mode flag, MPOL_F_STATIC_NODES, that suppresses the node remap when the policy is rebound. Adds another member to struct mempolicy, nodemask_t user_nodemask, as part of a union with cpuset_mems_allowed: struct mempolicy { ... union { nodemask_t cpuset_mems_allowed; nodemask_t user_nodemask; } w; } that stores the the nodemask that the user passed when he or she created the mempolicy via set_mempolicy() or mbind(). When using MPOL_F_STATIC_NODES, which is passed with any mempolicy mode, the user's passed nodemask intersected with the VMA or task's allowed nodes is always used when determining the preferred node, setting the MPOL_BIND zonelist, or creating the interleave nodemask. This happens whenever the policy is rebound, including when a task's cpuset assignment changes or the cpuset's mems are changed. This creates an interesting side-effect in that it allows the mempolicy "intent" to lie dormant and uneffected until it has access to the node(s) that it desires. For example, if you currently ask for an interleaved policy over a set of nodes that you do not have access to, the mempolicy is not created and the task continues to use the previous policy. With this change, however, it is possible to create the same mempolicy; it is only effected when access to nodes in the nodemask is acquired. It is also possible to mount tmpfs with the static nodemask behavior when specifying a node or nodemask. To do this, simply add "=static" immediately following the mempolicy mode at mount time: mount -o remount mpol=interleave=static:1-3 Also removes mpol_check_policy() and folds its logic into mpol_new() since it is now obsoleted. The unused vma_mpol_equal() is also removed. Cc: Paul Jackson <pj@sgi.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: support optional mode flagsDavid Rientjes
With the evolution of mempolicies, it is necessary to support mempolicy mode flags that specify how the policy shall behave in certain circumstances. The most immediate need for mode flag support is to suppress remapping the nodemask of a policy at the time of rebind. Both the mempolicy mode and flags are passed by the user in the 'int policy' formal of either the set_mempolicy() or mbind() syscall. A new constant, MPOL_MODE_FLAGS, represents the union of legal optional flags that may be passed as part of this int. Mempolicies that include illegal flags as part of their policy are rejected as invalid. An additional member to struct mempolicy is added to support the mode flags: struct mempolicy { ... unsigned short policy; unsigned short flags; } The splitting of the 'int' actual passed by the user is done in sys_set_mempolicy() and sys_mbind() for their respective syscalls. This is done by intersecting the actual with MPOL_MODE_FLAGS, rejecting the syscall of there are additional flags, and storing it in the new 'flags' member of struct mempolicy. The intersection of the actual with ~MPOL_MODE_FLAGS is stored in the 'policy' member of the struct and all current users of pol->policy remain unchanged. The union of the policy mode and optional mode flags is passed back to the user in get_mempolicy(). This combination of mode and flags within the same actual does not break userspace code that relies on get_mempolicy(&policy, ...) and either switch (policy) { case MPOL_BIND: ... case MPOL_INTERLEAVE: ... }; statements or if (policy == MPOL_INTERLEAVE) { ... } statements. Such applications would need to use optional mode flags when calling set_mempolicy() or mbind() for these previously implemented statements to stop working. If an application does start using optional mode flags, it will need to mask the optional flags off the policy in switch and conditional statements that only test mode. An additional member is also added to struct shmem_sb_info to store the optional mode flags. [hugh@veritas.com: shmem mpol: fix build warning] Cc: Paul Jackson <pj@sgi.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: convert MPOL constants to enumDavid Rientjes
The mempolicy mode constants, MPOL_DEFAULT, MPOL_PREFERRED, MPOL_BIND, and MPOL_INTERLEAVE, are better declared as part of an enum since they are sequentially numbered and cannot be combined. The policy member of struct mempolicy is also converted from type short to type unsigned short. A negative policy does not have any legitimate meaning, so it is possible to change its type in preparation for adding optional mode flags later. The equivalent member of struct shmem_sb_info is also changed from int to unsigned short. For compatibility, the policy formal to get_mempolicy() remains as a pointer to an int: int get_mempolicy(int *policy, unsigned long *nmask, unsigned long maxnode, unsigned long addr, unsigned long flags); although the only possible values is the range of type unsigned short. Cc: Paul Jackson <pj@sgi.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: filter based on a nodemask as well as a gfp_maskMel Gorman
The MPOL_BIND policy creates a zonelist that is used for allocations controlled by that mempolicy. As the per-node zonelist is already being filtered based on a zone id, this patch adds a version of __alloc_pages() that takes a nodemask for further filtering. This eliminates the need for MPOL_BIND to create a custom zonelist. A positive benefit of this is that allocations using MPOL_BIND now use the local node's distance-ordered zonelist instead of a custom node-id-ordered zonelist. I.e., pages will be allocated from the closest allowed node with available memory. [Lee.Schermerhorn@hp.com: Mempolicy: update stale documentation and comments] [Lee.Schermerhorn@hp.com: Mempolicy: make dequeue_huge_page_vma() obey MPOL_BIND nodemask] [Lee.Schermerhorn@hp.com: Mempolicy: make dequeue_huge_page_vma() obey MPOL_BIND nodemask rework] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: have zonelist contains structs with both a zone pointer and zone_idxMel Gorman
Filtering zonelists requires very frequent use of zone_idx(). This is costly as it involves a lookup of another structure and a substraction operation. As the zone_idx is often required, it should be quickly accessible. The node idx could also be stored here if it was found that accessing zone->node is significant which may be the case on workloads where nodemasks are heavily used. This patch introduces a struct zoneref to store a zone pointer and a zone index. The zonelist then consists of an array of these struct zonerefs which are looked up as necessary. Helpers are given for accessing the zone index as well as the node index. [kamezawa.hiroyu@jp.fujitsu.com: Suggested struct zoneref instead of embedding information in pointers] [hugh@veritas.com: mm-have-zonelist: fix memcg ooms] [hugh@veritas.com: just return do_try_to_free_pages] [hugh@veritas.com: do_try_to_free_pages gfp_mask redundant] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Christoph Lameter <clameter@sgi.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <clameter@sgi.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: introduce node_zonelist() for accessing the zonelist for a GFP maskMel Gorman
Introduce a node_zonelist() helper function. It is used to lookup the appropriate zonelist given a node and a GFP mask. The patch on its own is a cleanup but it helps clarify parts of the two-zonelist-per-node patchset. If necessary, it can be merged with the next patch in this set without problems. Reviewed-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <clameter@sgi.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-10mempolicy: fix reference counting bugsLee Schermerhorn
Address 3 known bugs in the current memory policy reference counting method. I have a series of patches to rework the reference counting to reduce overhead in the allocation path. However, that series will require testing in -mm once I repost it. 1) alloc_page_vma() does not release the extra reference taken for vma/shared mempolicy when the mode == MPOL_INTERLEAVE. This can result in leaking mempolicy structures. This is probably occurring, but not being noticed. Fix: add the conditional release of the reference. 2) hugezonelist unconditionally releases a reference on the mempolicy when mode == MPOL_INTERLEAVE. This can result in decrementing the reference count for system default policy [should have no ill effect] or premature freeing of task policy. If this occurred, the next allocation using task mempolicy would use the freed structure and probably BUG out. Fix: add the necessary check to the release. 3) The current reference counting method assumes that vma 'get_policy()' methods automatically add an extra reference a non-NULL returned mempolicy. This is true for shmem_get_policy() used by tmpfs mappings, including regular page shm segments. However, SHM_HUGETLB shm's, backed by hugetlbfs, just use the vma policy without the extra reference. This results in freeing of the vma policy on the first allocation, with reuse of the freed mempolicy structure on subsequent allocations. Fix: Rather than add another condition to the conditional reference release, which occur in the allocation path, just add a reference when returning the vma policy in shm_get_policy() to match the assumptions. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Greg KH <greg@kroah.com> Cc: Andi Kleen <ak@suse.de> Cc: Christoph Lameter <clameter@sgi.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: David Rientjes <rientjes@google.com> Cc: <eric.whitney@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14d_path: Make seq_path() use a struct path argumentJan Blunck
seq_path() is always called with a dentry and a vfsmount from a struct path. Make seq_path() take it directly as an argument. Signed-off-by: Jan Blunck <jblunck@suse.de> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-11mempolicy: silently restrict nodemask to allowed nodesKOSAKI Motohiro
Kosaki Motohito noted that "numactl --interleave=all ..." failed in the presence of memoryless nodes. This patch attempts to fix that problem. Some background: numactl --interleave=all calls set_mempolicy(2) with a fully populated [out to MAXNUMNODES] nodemask. set_mempolicy() [in do_set_mempolicy()] calls contextualize_policy() which requires that the nodemask be a subset of the current task's mems_allowed; else EINVAL will be returned. A task's mems_allowed will always be a subset of node_states[N_HIGH_MEMORY] i.e., nodes with memory. So, a fully populated nodemask will be declared invalid if it includes memoryless nodes. NOTE: the same thing will occur when running in a cpuset with restricted mem_allowed--for the same reason: node mask contains dis-allowed nodes. mbind(2), on the other hand, just masks off any nodes in the nodemask that are not included in the caller's mems_allowed. In each case [mbind() and set_mempolicy()], mpol_check_policy() will complain [again, resulting in EINVAL] if the nodemask contains any memoryless nodes. This is somewhat redundant as mpol_new() will remove memoryless nodes for interleave policy, as will bind_zonelist()--called by mpol_new() for BIND policy. Proposed fix: 1) modify contextualize_policy logic to: a) remember whether the incoming node mask is empty. b) if not, restrict the nodemask to allowed nodes, as is currently done in-line for mbind(). This guarantees that the resulting mask includes only nodes with memory. NOTE: this is a [benign, IMO] change in behavior for set_mempolicy(). Dis-allowed nodes will be silently ignored, rather than returning an error. c) fold this code into mpol_check_policy(), replace 2 calls to contextualize_policy() to call mpol_check_policy() directly and remove contextualize_policy(). 2) In existing mpol_check_policy() logic, after "contextualization": a) MPOL_DEFAULT: require that in coming mask "was_empty" b) MPOL_{BIND|INTERLEAVE}: require that contextualized nodemask contains at least one node. c) add a case for MPOL_PREFERRED: if in coming was not empty and resulting mask IS empty, user specified invalid nodes. Return EINVAL. c) remove the now redundant check for memoryless nodes 3) remove the now redundant masking of policy nodes for interleave policy from mpol_new(). 4) Now that mpol_check_policy() contextualizes the nodemask, remove the in-line nodes_and() from sys_mbind(). I believe that this restores mbind() to the behavior before the memoryless-nodes patch series. E.g., we'll no longer treat an invalid nodemask with MPOL_PREFERRED as local allocation. [ Patch history: v1 -> v2: - Communicate whether or not incoming node mask was empty to mpol_check_policy() for better error checking. - As suggested by David Rientjes, remove the now unused cpuset_nodes_subset_current_mems_allowed() from cpuset.h v2 -> v3: - As suggested by Kosaki Motohito, fold the "contextualization" of policy nodemask into mpol_check_policy(). Looks a little cleaner. ] Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Tested-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-14Migration: find correct vma in new_vma_page()Lee Schermerhorn
We hit the BUG_ON() in mm/rmap.c:vma_address() when trying to migrate via mbind(MPOL_MF_MOVE) a non-anon region that spans multiple vmas. For anon-regions, we just fail to migrate any pages beyond the 1st vma in the range. This occurs because do_mbind() collects a list of pages to migrate by calling check_range(). check_range() walks the task's mm, spanning vmas as necessary, to collect the migratable pages into a list. Then, do_mbind() calls migrate_pages() passing the list of pages, a function to allocate new pages based on vma policy [new_vma_page()], and a pointer to the first vma of the range. For each page in the list, new_vma_page() calls page_address_in_vma() passing the page and the vma [first in range] to obtain the address to get for alloc_page_vma(). The page address is needed to get interleaving policy correct. If the pages in the list come from multiple vmas, eventually, new_page_address() will pass that page to page_address_in_vma() with the incorrect vma. For !PageAnon pages, this will result in a bug check in rmap.c:vma_address(). For anon pages, vma_address() will just return EFAULT and fail the migration. This patch modifies new_vma_page() to check the return value from page_address_in_vma(). If the return value is EFAULT, new_vma_page() searchs forward via vm_next for the vma that maps the page--i.e., that does not return EFAULT. This assumes that the pages in the list handed to migrate_pages() is in address order. This is currently case. The patch documents this assumption in a new comment block for new_vma_page(). If new_vma_page() cannot locate the vma mapping the page in a forward search in the mm, it will pass a NULL vma to alloc_page_vma(). This will result in the allocation using the task policy, if any, else system default policy. This situation is unlikely, but the patch documents this behavior with a comment. Note, this patch results in restarting from the first vma in a multi-vma range each time new_vma_page() is called. If this is not acceptable, we can make the vma argument a pointer, both in new_vma_page() and it's caller unmap_and_move() so that the value held by the loop in migrate_pages() always passes down the last vma in which a page was found. This will require changes to all new_page_t functions passed to migrate_pages(). Is this necessary? For this patch to work, we can't bug check in vma_address() for pages outside the argument vma. This patch removes the BUG_ON(). All other callers [besides new_vma_page()] already check the return status. Tested on x86_64, 4 node NUMA platform. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Uninline find_task_by_xxx set of functionsPavel Emelyanov
The find_task_by_something is a set of macros are used to find task by pid depending on what kind of pid is proposed - global or virtual one. All of them are wrappers above the most generic one - find_task_by_pid_type_ns() - and just substitute some args for it. It turned out, that dereferencing the current->nsproxy->pid_ns construction and pushing one more argument on the stack inline cause kernel text size to grow. This patch moves all this stuff out-of-line into kernel/pid.c. Together with the next patch it saves a bit less than 400 bytes from the .text section. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: changes to show virtual ids to userPavel Emelyanov
This is the largest patch in the set. Make all (I hope) the places where the pid is shown to or get from user operate on the virtual pids. The idea is: - all in-kernel data structures must store either struct pid itself or the pid's global nr, obtained with pid_nr() call; - when seeking the task from kernel code with the stored id one should use find_task_by_pid() call that works with global pids; - when showing pid's numerical value to the user the virtual one should be used, but however when one shows task's pid outside this task's namespace the global one is to be used; - when getting the pid from userspace one need to consider this as the virtual one and use appropriate task/pid-searching functions. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: nuther build fix] [akpm@linux-foundation.org: yet nuther build fix] [akpm@linux-foundation.org: remove unneeded casts] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Task Control Groups: make cpusets a client of cgroupsPaul Menage
Remove the filesystem support logic from the cpusets system and makes cpusets a cgroup subsystem The "cpuset" filesystem becomes a dummy filesystem; attempts to mount it get passed through to the cgroup filesystem with the appropriate options to emulate the old cpuset filesystem behaviour. Signed-off-by: Paul Menage <menage@google.com> Cc: Serge E. Hallyn <serue@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Paul Jackson <pj@sgi.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16mm/mempolicy.c: cleanupsAdrian Bunk
This patch contains the following cleanups: - every file should include the headers containing the prototypes for its global functions - make the follosing needlessly global functions static: - migrate_to_node() - do_mbind() - sp_alloc() - mpol_rebind_policy() [akpm@linux-foundation.org: fix uninitialised var warning] Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16memoryless nodes: fixup uses of node_online_map in generic codeLee Schermerhorn
Here's a cut at fixing up uses of the online node map in generic code. mm/shmem.c:shmem_parse_mpol() Ensure nodelist is subset of nodes with memory. Use node_states[N_HIGH_MEMORY] as default for missing nodelist for interleave policy. mm/shmem.c:shmem_fill_super() initialize policy_nodes to node_states[N_HIGH_MEMORY] mm/page-writeback.c:highmem_dirtyable_memory() sum over nodes with memory mm/page_alloc.c:zlc_setup() allowednodes - use nodes with memory. mm/page_alloc.c:default_zonelist_order() average over nodes with memory. mm/page_alloc.c:find_next_best_node() skip nodes w/o memory. N_HIGH_MEMORY state mask may not be initialized at this time, unless we want to depend on early_calculate_totalpages() [see below]. Will ZONE_MOVABLE ever be configurable? mm/page_alloc.c:find_zone_movable_pfns_for_nodes() spread kernelcore over nodes with memory. This required calling early_calculate_totalpages() unconditionally, and populating N_HIGH_MEMORY node state therein from nodes in the early_node_map[]. If we can depend on this, we can eliminate the population of N_HIGH_MEMORY mask from __build_all_zonelists() and use the N_HIGH_MEMORY mask in find_next_best_node(). mm/mempolicy.c:mpol_check_policy() Ensure nodes specified for policy are subset of nodes with memory. [akpm@linux-foundation.org: fix warnings] Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Acked-by: Christoph Lameter <clameter@sgi.com> Cc: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Memoryless nodes: Update memory policy and page migrationChristoph Lameter
Online nodes now may have no memory. The checks and initialization must therefore be changed to no longer use the online functions. This will correctly initialize the interleave on bootup to only target nodes with memory and will make sys_move_pages return an error when a page is to be moved to a memoryless node. Similarly we will get an error if MPOL_BIND and MPOL_INTERLEAVE is used on a memoryless node. These are somewhat new semantics. So far one could specify memoryless nodes and we would maybe do the right thing and just ignore the node (or we'd do something strange like with MPOL_INTERLEAVE). If we want to allow the specification of memoryless nodes via memory policies then we need to keep checking for online nodes. Signed-off-by: Christoph Lameter <clameter@sgi.com> Acked-by: Nishanth Aravamudan <nacc@us.ibm.com> Tested-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Acked-by: Bob Picco <bob.picco@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@skynet.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Memoryless nodes: Fix interleave behavior for memoryless nodesChristoph Lameter
MPOL_INTERLEAVE currently simply loops over all nodes. Allocations on memoryless nodes will be redirected to nodes with memory. This results in an imbalance because the neighboring nodes to memoryless nodes will get significantly more interleave hits that the rest of the nodes on the system. We can avoid this imbalance by clearing the nodes in the interleave node set that have no memory. If we use the node map of the memory nodes instead of the online nodes then we have only the nodes we want. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Tested-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Acked-by: Bob Picco <bob.picco@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@skynet.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Mem Policy: add MPOL_F_MEMS_ALLOWED get_mempolicy() flagLee Schermerhorn
Allow an application to query the memories allowed by its context. Updated numa_memory_policy.txt to mention that applications can use this to obtain allowed memories for constructing valid policies. TODO: update out-of-tree libnuma wrapper[s], or maybe add a new wrapper--e.g., numa_get_mems_allowed() ? Also, update numa syscall man pages. Tested with memtoy V>=0.13. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Acked-by: Christoph Lameter <clameter@sgi.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Clean up duplicate includes in mm/Jesper Juhl
This patch cleans up duplicate includes in mm/ Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-19Fix NUMA Memory Policy Reference CountingLee Schermerhorn
This patch proposes fixes to the reference counting of memory policy in the page allocation paths and in show_numa_map(). Extracted from my "Memory Policy Cleanups and Enhancements" series as stand-alone. Shared policy lookup [shmem] has always added a reference to the policy, but this was never unrefed after page allocation or after formatting the numa map data. Default system policy should not require additional ref counting, nor should the current task's task policy. However, show_numa_map() calls get_vma_policy() to examine what may be [likely is] another task's policy. The latter case needs protection against freeing of the policy. This patch adds a reference count to a mempolicy returned by get_vma_policy() when the policy is a vma policy or another task's mempolicy. Again, shared policy is already reference counted on lookup. A matching "unref" [__mpol_free()] is performed in alloc_page_vma() for shared and vma policies, and in show_numa_map() for shared and another task's mempolicy. We can call __mpol_free() directly, saving an admittedly inexpensive inline NULL test, because we know we have a non-NULL policy. Handling policy ref counts for hugepages is a bit trickier. huge_zonelist() returns a zone list that might come from a shared or vma 'BIND policy. In this case, we should hold the reference until after the huge page allocation in dequeue_hugepage(). The patch modifies huge_zonelist() to return a pointer to the mempolicy if it needs to be unref'd after allocation. Kernel Build [16cpu, 32GB, ia64] - average of 10 runs: w/o patch w/ refcount patch Avg Std Devn Avg Std Devn Real: 100.59 0.38 100.63 0.43 User: 1209.60 0.37 1209.91 0.31 System: 81.52 0.42 81.64 0.34 Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Acked-by: Andi Kleen <ak@suse.de> Cc: Christoph Lameter <clameter@sgi.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-31Page migration: Do not accept invalid nodes in the target nodesetChristoph Lameter
Page migration currently does not check if the target of the move contains nodes that that are invalid (if root attempts to migrate pages) and may try to allocate from invalid nodes if these are specified leading to oopses. Return -EINVAL if an offline node is specified. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Shaohua Li <shaohua.li@intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-22Apply memory policies to top two highest zones when highest zone is ZONE_MOVABLEMel Gorman
The NUMA layer only supports NUMA policies for the highest zone. When ZONE_MOVABLE is configured with kernelcore=, the the highest zone becomes ZONE_MOVABLE. The result is that policies are only applied to allocations like anonymous pages and page cache allocated from ZONE_MOVABLE when the zone is used. This patch applies policies to the two highest zones when the highest zone is ZONE_MOVABLE. As ZONE_MOVABLE consists of pages from the highest "real" zone, it's always functionally equivalent. The patch has been tested on a variety of machines both NUMA and non-NUMA covering x86, x86_64 and ppc64. No abnormal results were seen in kernbench, tbench, dbench or hackbench. It passes regression tests from the numactl package with and without kernelcore= once numactl tests are patched to wait for vmstat counters to update. akpm: this is the nasty hack to fix NUMA mempolicies in the presence of ZONE_MOVABLE and kernelcore= in 2.6.23. Christoph says "For .24 either merge the mobility or get the other solution that Mel is working on. That solution would only use a single zonelist per node and filter on the fly. That may help performance and also help to make memory policies work better." Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Tested-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Acked-by: Christoph Lameter <clameter@sgi.com> Cc: Andi Kleen <ak@suse.de> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Allow huge page allocations to use GFP_HIGH_MOVABLEMel Gorman
Huge pages are not movable so are not allocated from ZONE_MOVABLE. However, as ZONE_MOVABLE will always have pages that can be migrated or reclaimed, it can be used to satisfy hugepage allocations even when the system has been running a long time. This allows an administrator to resize the hugepage pool at runtime depending on the size of ZONE_MOVABLE. This patch adds a new sysctl called hugepages_treat_as_movable. When a non-zero value is written to it, future allocations for the huge page pool will use ZONE_MOVABLE. Despite huge pages being non-movable, we do not introduce additional external fragmentation of note as huge pages are always the largest contiguous block we care about. [akpm@linux-foundation.org: various fixes] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Add __GFP_MOVABLE for callers to flag allocations from high memory that may ↵Mel Gorman
be migrated It is often known at allocation time whether a page may be migrated or not. This patch adds a flag called __GFP_MOVABLE and a new mask called GFP_HIGH_MOVABLE. Allocations using the __GFP_MOVABLE can be either migrated using the page migration mechanism or reclaimed by syncing with backing storage and discarding. An API function very similar to alloc_zeroed_user_highpage() is added for __GFP_MOVABLE allocations called alloc_zeroed_user_highpage_movable(). The flags used by alloc_zeroed_user_highpage() are not changed because it would change the semantics of an existing API. After this patch is applied there are no in-kernel users of alloc_zeroed_user_highpage() so it probably should be marked deprecated if this patch is merged. Note that this patch includes a minor cleanup to the use of __GFP_ZERO in shmem.c to keep all flag modifications to inode->mapping in the shmem_dir_alloc() helper function. This clean-up suggestion is courtesy of Hugh Dickens. Additional credit goes to Christoph Lameter and Linus Torvalds for shaping the concept. Credit to Hugh Dickens for catching issues with shmem swap vector and ramfs allocations. [akpm@linux-foundation.org: build fix] [hugh@veritas.com: __GFP_ZERO cleanup] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16numa: mempolicy: trivial debug fixes.Paul Mundt
Enabling debugging fails to build due to the nodemask variable in do_mbind() having changed names, and then oopses on boot due to the assumption that the nodemask can be dereferenced -- which doesn't work out so well when the policy is changed to MPOL_DEFAULT with a NULL nodemask by numa_default_policy(). This fixes it up, and switches from PDprintk() to pr_debug() while we're at it. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16numa: mempolicy: dynamic interleave map for system initPaul Mundt
This converts the default system init memory policy to use a dynamically created node map instead of defaulting to all online nodes. Nodes of a certain size (>= 16MB) are judged to be suitable for interleave, and are added to the map. If all nodes are smaller in size, the largest one is automatically selected. Without this, tiny nodes find themselves out of memory before we even make it to userspace. Systems with large nodes will notice no change. Only the system init policy is effected by this change, the regular MPOL_DEFAULT policy is still switched to later on in the boot process as normal. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Cc: Andi Kleen <ak@suse.de> Cc: Christoph Lameter <clameter@sgi.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
