commit 80de7c3138ee9fd86a98696fd2cf7ad89b995d0a upstream.
Trivially triggerable, found by trinity:
kernel BUG at mm/mempolicy.c:2546!
Process trinity-child2 (pid: 23988, threadinfo ffff88010197e000, task ffff88007821a670)
Call Trace:
show_numa_map+0xd5/0x450
show_pid_numa_map+0x13/0x20
traverse+0xf2/0x230
seq_read+0x34b/0x3e0
vfs_read+0xac/0x180
sys_pread64+0xa2/0xc0
system_call_fastpath+0x1a/0x1f
RIP: mpol_to_str+0x156/0x360
Signed-off-by: Dave Jones <davej@redhat.com>
commit 05f144a0d5c2207a0349348127f996e104ad7404 upstream.
Dave Jones' system call fuzz testing tool "trinity" triggered the
following bug error with slab debugging enabled
BUG numa_policy (Not tainted): Poison overwritten
INFO: 0xffff880146498250-0xffff880146498250. First byte 0x6a instead of 0x6b
INFO: Allocated in mpol_new+0xa3/0x140 age=46310 cpu=6 pid=32154
__slab_alloc+0x3d3/0x445
kmem_cache_alloc+0x29d/0x2b0
mpol_new+0xa3/0x140
sys_mbind+0x142/0x620
system_call_fastpath+0x16/0x1b
INFO: Freed in __mpol_put+0x27/0x30 age=46268 cpu=6 pid=32154
__slab_free+0x2e/0x1de
kmem_cache_free+0x25a/0x260
remove_vma+0x68/0x90
exit_mmap+0x118/0x140
mmput+0x73/0x110
exit_mm+0x108/0x130
do_exit+0x162/0xb90
do_group_exit+0x4f/0xc0
sys_exit_group+0x17/0x20
INFO: Slab 0xffffea0005192600 objects=27 used=27 fp=0x (null) flags=0x20000000004080
INFO: Object 0xffff880146498250 @offset=592 fp=0xffff88014649b9d0
This implied a reference counting bug and the problem happened during
mbind().
mbind() applies a new memory policy to a range and uses mbind_range() to
merge existing VMAs or split them as necessary. In the event of splits,
mpol_dup() will allocate a new struct mempolicy and maintain existing
reference counts whose rules are documented in
Documentation/vm/numa_memory_policy.txt .
The problem occurs with shared memory policies. The vm_op->set_policy
increments the reference count if necessary and split_vma() and
vma_merge() have already handled the existing reference counts.
However, policy_vma() screws it up by replacing an existing
vma->vm_policy with one that potentially has the wrong reference count
leading to a premature free. This patch removes the damage caused by
policy_vma().
With this patch applied Dave's trinity tool runs an mbind test for 5
minutes without error. /proc/slabinfo reported that there are no
numa_policy or shared_policy_node objects allocated after the test
completed and the shared memory region was deleted.
Cc: Dave Jones <davej@redhat.com>
Cc: Stephen Wilson <wilsons@start.ca>
Cc: Christoph Lameter <cl@linux.com>
Commit 3268c63 ("mm: fix move/migrate_pages() race on task struct") has
added an odd construct where 'mm' is checked for being NULL, and if it is,
it would get dereferenced anyways by mput()ing it.
This would lead to the following NULL ptr deref and BUG() when calling
migrate_pages() with a pid that has no mm struct:
[25904.193704] BUG: unable to handle kernel NULL pointer dereference at 0000000000000050
[25904.194235] IP: [<ffffffff810b0de7>] mmput+0x27/0xf0
[25904.194235] PGD 773e6067 PUD 77da0067 PMD 0
[25904.194235] Oops: 0002 [#1] PREEMPT SMP
[25904.194235] CPU 2
[25904.194235] Pid: 31608, comm: trinity Tainted: G W 3.4.0-rc2-next-20120412-sasha #69
[25904.194235] RIP: 0010:[<ffffffff810b0de7>] [<ffffffff810b0de7>] mmput+0x27/0xf0
[25904.194235] RSP: 0018:ffff880077d49e08 EFLAGS: 00010202
[25904.194235] RAX: 0000000000000286 RBX: 0000000000000000 RCX: 0000000000000000
[25904.194235] RDX: ffff880075ef8000 RSI: 000000000000023d RDI: 0000000000000286
[25904.194235] RBP: ffff880077d49e18 R08: 0000000000000001 R09: 0000000000000001
[25904.194235] R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000
[25904.194235] R13: 00000000ffffffea R14: ffff880034287740 R15: ffff8800218d3010
[25904.194235] FS: 00007fc8b244c700(0000) GS:ffff880029800000(0000) knlGS:0000000000000000
[25904.194235] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[25904.194235] CR2: 0000000000000050 CR3: 00000000767c6000 CR4: 00000000000406e0
[25904.194235] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[25904.194235] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[25904.194235] Process trinity (pid: 31608, threadinfo ffff880077d48000, task ffff880075ef8000)
[25904.194235] Stack:
[25904.194235] ffff8800342876c0 0000000000000000 ffff880077d49f78 ffffffff811b8020
[25904.194235] ffffffff811b7d91 ffff880075ef8000 ffff88002256d200 0000000000000000
[25904.194235] 00000000000003ff 0000000000000000 0000000000000000 0000000000000000
[25904.194235] Call Trace:
[25904.194235] [<ffffffff811b8020>] sys_migrate_pages+0x340/0x3a0
[25904.194235] [<ffffffff811b7d91>] ? sys_migrate_pages+0xb1/0x3a0
[25904.194235] [<ffffffff8266cbb9>] system_call_fastpath+0x16/0x1b
[25904.194235] Code: c9 c3 66 90 55 31 d2 48 89 e5 be 3d 02 00 00 48 83 ec 10 48 89 1c 24 4c 89 64 24 08 48 89 fb 48 c7 c7 cf 0e e1 82 e8 69 18 03 00 <f0> ff 4b 50 0f 94 c0 84 c0 0f 84 aa 00 00 00 48 89 df e8 72 f1
[25904.194235] RIP [<ffffffff810b0de7>] mmput+0x27/0xf0
[25904.194235] RSP <ffff880077d49e08>
[25904.348999] ---[ end trace a307b3ed40206b4b ]---
Signed-off-by: Sasha Levin <levinsasha928@gmail.com>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Commit c0ff7453bb5c ("cpuset,mm: fix no node to alloc memory when
changing cpuset's mems") wins a super prize for the largest number of
memory barriers entered into fast paths for one commit.
[get|put]_mems_allowed is incredibly heavy with pairs of full memory
barriers inserted into a number of hot paths. This was detected while
investigating at large page allocator slowdown introduced some time
after 2.6.32. The largest portion of this overhead was shown by
oprofile to be at an mfence introduced by this commit into the page
allocator hot path.
For extra style points, the commit introduced the use of yield() in an
implementation of what looks like a spinning mutex.
This patch replaces the full memory barriers on both read and write
sides with a sequence counter with just read barriers on the fast path
side. This is much cheaper on some architectures, including x86. The
main bulk of the patch is the retry logic if the nodemask changes in a
manner that can cause a false failure.
While updating the nodemask, a check is made to see if a false failure
is a risk. If it is, the sequence number gets bumped and parallel
allocators will briefly stall while the nodemask update takes place.
In a page fault test microbenchmark, oprofile samples from
__alloc_pages_nodemask went from 4.53% of all samples to 1.15%. The
actual results were
3.3.0-rc3 3.3.0-rc3
rc3-vanilla nobarrier-v2r1
Clients 1 UserTime 0.07 ( 0.00%) 0.08 (-14.19%)
Clients 2 UserTime 0.07 ( 0.00%) 0.07 ( 2.72%)
Clients 4 UserTime 0.08 ( 0.00%) 0.07 ( 3.29%)
Clients 1 SysTime 0.70 ( 0.00%) 0.65 ( 6.65%)
Clients 2 SysTime 0.85 ( 0.00%) 0.82 ( 3.65%)
Clients 4 SysTime 1.41 ( 0.00%) 1.41 ( 0.32%)
Clients 1 WallTime 0.77 ( 0.00%) 0.74 ( 4.19%)
Clients 2 WallTime 0.47 ( 0.00%) 0.45 ( 3.73%)
Clients 4 WallTime 0.38 ( 0.00%) 0.37 ( 1.58%)
Clients 1 Flt/sec/cpu 497620.28 ( 0.00%) 520294.53 ( 4.56%)
Clients 2 Flt/sec/cpu 414639.05 ( 0.00%) 429882.01 ( 3.68%)
Clients 4 Flt/sec/cpu 257959.16 ( 0.00%) 258761.48 ( 0.31%)
Clients 1 Flt/sec 495161.39 ( 0.00%) 517292.87 ( 4.47%)
Clients 2 Flt/sec 820325.95 ( 0.00%) 850289.77 ( 3.65%)
Clients 4 Flt/sec 1020068.93 ( 0.00%) 1022674.06 ( 0.26%)
MMTests Statistics: duration
Sys Time Running Test (seconds) 135.68 132.17
User+Sys Time Running Test (seconds) 164.2 160.13
Total Elapsed Time (seconds) 123.46 120.87
The overall improvement is small but the System CPU time is much
improved and roughly in correlation to what oprofile reported (these
performance figures are without profiling so skew is expected). The
actual number of page faults is noticeably improved.
For benchmarks like kernel builds, the overall benefit is marginal but
the system CPU time is slightly reduced.
To test the actual bug the commit fixed I opened two terminals. The
first ran within a cpuset and continually ran a small program that
faulted 100M of anonymous data. In a second window, the nodemask of the
cpuset was continually randomised in a loop.
Without the commit, the program would fail every so often (usually
within 10 seconds) and obviously with the commit everything worked fine.
With this patch applied, it also worked fine so the fix should be
functionally equivalent.
Cc: Miao Xie <miaox@cn.fujitsu.com>
Migration functions perform the rcu_read_unlock too early. As a result
the task pointed to may change from under us. This can result in an oops,
as reported by Dave Hansen in https://lkml.org/lkml/2012/2/23/302.
The following patch extend the period of the rcu_read_lock until after the
permissions checks are done. We also take a refcount so that the task
reference is stable when calling security check functions and performing
cpuset node validation (which takes a mutex).
The refcount is dropped before actual page migration occurs so there is no
change to the refcounts held during page migration.
Also move the determination of the mm of the task struct to immediately
before the do_migrate*() calls so that it is clear that we switch from
handling the task during permission checks to the mm for the actual
migration. Since the determination is only done once and we then no
longer use the task_struct we can be sure that we operate on a specific
address space that will not change from under us.
[akpm@linux-foundation.org: checkpatch fixes]
Signed-off-by: Christoph Lameter <cl@linux.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Reported-by: Dave Hansen <dave@linux.vnet.ibm.com>
In some cases it may happen that pmd_none_or_clear_bad() is called with
the mmap_sem hold in read mode. In those cases the huge page faults can
allocate hugepmds under pmd_none_or_clear_bad() and that can trigger a
false positive from pmd_bad() that will not like to see a pmd
materializing as trans huge.
It's not khugepaged causing the problem, khugepaged holds the mmap_sem
in write mode (and all those sites must hold the mmap_sem in read mode
to prevent pagetables to go away from under them, during code review it
seems vm86 mode on 32bit kernels requires that too unless it's
restricted to 1 thread per process or UP builds). The race is only with
the huge pagefaults that can convert a pmd_none() into a
pmd_trans_huge().
Effectively all these pmd_none_or_clear_bad() sites running with
mmap_sem in read mode are somewhat speculative with the page faults, and
the result is always undefined when they run simultaneously. This is
probably why it wasn't common to run into this. For example if the
madvise(MADV_DONTNEED) runs zap_page_range() shortly before the page
fault, the hugepage will not be zapped, if the page fault runs first it
will be zapped.
Altering pmd_bad() not to error out if it finds hugepmds won't be enough
to fix this, because zap_pmd_range would then proceed to call
zap_pte_range (which would be incorrect if the pmd become a
pmd_trans_huge()).
The simplest way to fix this is to read the pmd in the local stack
(regardless of what we read, no need of actual CPU barriers, only
compiler barrier needed), and be sure it is not changing under the code
that computes its value. Even if the real pmd is changing under the
value we hold on the stack, we don't care. If we actually end up in
zap_pte_range it means the pmd was not none already and it was not huge,
and it can't become huge from under us (khugepaged locking explained
above).
All we need is to enforce that there is no way anymore that in a code
path like below, pmd_trans_huge can be false, but pmd_none_or_clear_bad
can run into a hugepmd. The overhead of a barrier() is just a compiler
tweak and should not be measurable (I only added it for THP builds). I
don't exclude different compiler versions may have prevented the race
too by caching the value of *pmd on the stack (that hasn't been
verified, but it wouldn't be impossible considering
pmd_none_or_clear_bad, pmd_bad, pmd_trans_huge, pmd_none are all inlines
and there's no external function called in between pmd_trans_huge and
pmd_none_or_clear_bad).
if (pmd_trans_huge(*pmd)) {
if (next-addr != HPAGE_PMD_SIZE) {
VM_BUG_ON(!rwsem_is_locked(&tlb->mm->mmap_sem));
split_huge_page_pmd(vma->vm_mm, pmd);
} else if (zap_huge_pmd(tlb, vma, pmd, addr))
continue;
/* fall through */
if (pmd_none_or_clear_bad(pmd))
Because this race condition could be exercised without special
privileges this was reported in CVE-2012-1179.
The race was identified and fully explained by Ulrich who debugged it.
I'm quoting his accurate explanation below, for reference.
====== start quote =======
mapcount 0 page_mapcount 1
kernel BUG at mm/huge_memory.c:1384!
At some point prior to the panic, a "bad pmd ..." message similar to the
following is logged on the console:
mm/memory.c:145: bad pmd ffff8800376e1f98(80000000314000e7).
The "bad pmd ..." message is logged by pmd_clear_bad() before it clears
the page's PMD table entry.
143 void pmd_clear_bad(pmd_t *pmd)
144 {
-> 145 pmd_ERROR(*pmd);
146 pmd_clear(pmd);
147 }
After the PMD table entry has been cleared, there is an inconsistency
between the actual number of PMD table entries that are mapping the page
and the page's map count (_mapcount field in struct page). When the page
is subsequently reclaimed, __split_huge_page() detects this inconsistency.
1381 if (mapcount != page_mapcount(page))
1382 printk(KERN_ERR "mapcount %d page_mapcount %d\n",
1383 mapcount, page_mapcount(page));
-> 1384 BUG_ON(mapcount != page_mapcount(page));
The root cause of the problem is a race of two threads in a multithreaded
process. Thread B incurs a page fault on a virtual address that has never
been accessed (PMD entry is zero) while Thread A is executing an madvise()
system call on a virtual address within the same 2 MB (huge page) range.
virtual address space
| | |<-- B(fault)
2 MB | |/////////////////////|-.
huge < |/////////////////////| > A(range)
page | |/////////////////////|-'
- Thread A is executing an madvise(..., MADV_DONTNEED) system call
on the virtual address range "A(range)" shown in the picture.
sys_madvise
// Acquire the semaphore in shared mode.
down_read(¤t->mm->mmap_sem)
madvise_vma
switch (behavior)
case MADV_DONTNEED:
madvise_dontneed
zap_page_range
unmap_vmas
unmap_page_range
zap_pud_range
zap_pmd_range
// Assume that this huge page has never been accessed.
// I.e. content of the PMD entry is zero (not mapped).
// We don't get here due to the above assumption.
// Assume that Thread B incurred a page fault and
.---------> // sneaks in here as shown below.
| if (unlikely(pmd_bad(*pmd)))
| pmd_clear_bad
| pmd_ERROR
| // Log "bad pmd ..." message here.
| pmd_clear
| // Clear the page's PMD entry.
| // Thread B incremented the map count
| // in page_add_new_anon_rmap(), but
| // now the page is no longer mapped
| // by a PMD entry (-> inconsistency).
v
- Thread B is handling a page fault on virtual address "B(fault)" shown
in the picture.
do_page_fault
__do_page_fault
down_read_trylock(&mm->mmap_sem)
handle_mm_fault
if (pmd_none(*pmd) && transparent_hugepage_enabled(vma))
// We get here due to the above assumption (PMD entry is zero).
do_huge_pmd_anonymous_page
alloc_hugepage_vma
// Allocate a new transparent huge page here.
__do_huge_pmd_anonymous_page
spin_lock(&mm->page_table_lock)
// Here we increment the page's map count (starts at -1).
atomic_set(&page->_mapcount, 0)
set_pmd_at
// Here we set the page's PMD entry which will be cleared
// when Thread A calls pmd_clear_bad().
spin_unlock(&mm->page_table_lock)
The mmap_sem does not prevent the race because both threads are acquiring
it in shared mode (down_read). Thread B holds the page_table_lock while
the page's map count and PMD table entry are updated. However, Thread A
does not synchronize on that lock.
====== end quote =======
Reported-by: Ulrich Obergfell <uobergfe@redhat.com>
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Acked-by: Larry Woodman <lwoodman@redhat.com>
Cc: <stable@vger.kernel.org> [2.6.38+]
Cc: Mark Salter <msalter@redhat.com>
Several users of "find_vma_prev()" were not in fact interested in the
previous vma if there was no primary vma to be found either. And in
those cases, we're much better off just using the regular "find_vma()",
and then "prev" can be looked up by just checking vma->vm_prev.
The find_vma_prev() semantics are fairly subtle (see Mikulas' recent
commit 83cd904d271b: "mm: fix find_vma_prev"), and the whole "return
prev by reference" means that it generates worse code too.
Thus this "let's avoid using this inconvenient and clearly too subtle
interface when we don't really have to" patch.
Cc: Mikulas Patocka <mpatocka@redhat.com>
This patch adds a lightweight sync migrate operation MIGRATE_SYNC_LIGHT
mode that avoids writing back pages to backing storage. Async compaction
maps to MIGRATE_ASYNC while sync compaction maps to MIGRATE_SYNC_LIGHT.
For other migrate_pages users such as memory hotplug, MIGRATE_SYNC is
used.
This avoids sync compaction stalling for an excessive length of time,
particularly when copying files to a USB stick where there might be a
large number of dirty pages backed by a filesystem that does not support
->writepages.
[aarcange@redhat.com: This patch is heavily based on Andrea's work]
[akpm@linux-foundation.org: fix fs/nfs/write.c build]
[akpm@linux-foundation.org: fix fs/btrfs/disk-io.c build]
Cc: Minchan Kim <minchan.kim@gmail.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Andy Isaacson <adi@hexapodia.org>
Cc: Nai Xia <nai.xia@gmail.com>
Cc: Johannes Weiner <jweiner@redhat.com>
mpol_equal() logically returns a boolean. Use a bool type to slightly
improve readability.
Acked-by: David Rientjes <rientjes@google.com>
commit 8aacc9f550 ("mm/mempolicy.c: fix pgoff in mbind vma merge") is the
slightly incorrect fix.
Why? Think following case.
1. map 4 pages of a file at offset 0
[0123]
2. map 2 pages just after the first mapping of the same file but with
page offset 2
[0123][23]
3. mbind() 2 pages from the first mapping at offset 2.
mbind_range() should treat new vma is,
[0123][23]
|23|
mbind vma
but it does
[0123][23]
|01|
mbind vma
Oops. then, it makes wrong vma merge and splitting ([01][0123] or similar).
This patch fixes it.
[testcase]
test result - before the patch
case4: 126: test failed. expect '2,4', actual '2,2,2'
case5: passed
case6: passed
case7: passed
case8: passed
case_n: 246: test failed. expect '4,2', actual '1,4'
kernel BUG at mm/filemap.c:135!
invalid opcode: 0000 [#4] SMP DEBUG_PAGEALLOC
(snip long bug on messages)
test result - after the patch
case4: passed
case5: passed
case6: passed
case7: passed
case8: passed
case_n: passed
source: mbind_vma_test.c
#include <numaif.h>
#include <numa.h>
#include <sys/mman.h>
#include <stdio.h>
#include <unistd.h>
#include <stdlib.h>
#include <string.h>
static unsigned long pagesize;
void* mmap_addr;
struct bitmask *nmask;
char buf[1024];
FILE *file;
char retbuf[10240] = "";
int mapped_fd;
char *rubysrc = "ruby -e '\
pid = %d; \
vstart = 0x%llx; \
vend = 0x%llx; \
s = `pmap -q #{pid}`; \
rary = []; \
s.each_line {|line|; \
ary=line.split(\" \"); \
addr = ary[0].to_i(16); \
if(vstart <= addr && addr < vend) then \
rary.push(ary[1].to_i()/4); \
end; \
print rary.join(\",\"); \
void init(void)
void* addr;
char buf[128];
nmask = numa_allocate_nodemask();
numa_bitmask_setbit(nmask, 0);
pagesize = getpagesize();
sprintf(buf, "%s", "mbind_vma_XXXXXX");
mapped_fd = mkstemp(buf);
if (mapped_fd == -1)
perror("mkstemp "), exit(1);
unlink(buf);
if (lseek(mapped_fd, pagesize*8, SEEK_SET) < 0)
perror("lseek "), exit(1);
if (write(mapped_fd, "\0", 1) < 0)
perror("write "), exit(1);
addr = mmap(NULL, pagesize*8, PROT_NONE,
MAP_SHARED, mapped_fd, 0);
if (addr == MAP_FAILED)
perror("mmap "), exit(1);
if (mprotect(addr+pagesize, pagesize*6, PROT_READ|PROT_WRITE) < 0)
perror("mprotect "), exit(1);
mmap_addr = addr + pagesize;
/* make page populate */
memset(mmap_addr, 0, pagesize*6);
void fin(void)
void* addr = mmap_addr - pagesize;
munmap(addr, pagesize*8);
memset(buf, 0, sizeof(buf));
memset(retbuf, 0, sizeof(retbuf));
void mem_bind(int index, int len)
int err;
err = mbind(mmap_addr+pagesize*index, pagesize*len,
MPOL_BIND, nmask->maskp, nmask->size, 0);
if (err)
perror("mbind "), exit(err);
void mem_interleave(int index, int len)
int err;
MPOL_INTERLEAVE, nmask->maskp, nmask->size, 0);
if (err)
void mem_unbind(int index, int len)
int err;
MPOL_DEFAULT, NULL, 0, 0);
if (err)
void Assert(char *expected, char *value, char *name, int line)
if (strcmp(expected, value) == 0) {
fprintf(stderr, "%s: passed\n", name);
return;
else {
fprintf(stderr, "%s: %d: test failed. expect '%s', actual '%s'\n",
name, line,
expected, value);
// exit(1);
AAAA
PPPPPPNNNNNN
might become
PPNNNNNNNNNN
case 4 below
void case4(void)
init();
sprintf(buf, rubysrc, getpid(), mmap_addr, mmap_addr+pagesize*6);
mem_bind(0, 4);
mem_unbind(2, 2);
file = popen(buf, "r");
fread(retbuf, sizeof(retbuf), 1, file);
Assert("2,4", retbuf, "case4", __LINE__);
fin();
AAAA
PPPPPPNNNNNN
might become
PPPPPPPPPPNN
case 5 below
void case5(void)
init();
mem_bind(0, 2);
mem_bind(2, 2);
Assert("4,2", retbuf, "case5", __LINE__);
fin();
AAAA
PPPPNNNNXXXX
might become
PPPPPPPPPPPP 6
void case6(void)
init();
mem_bind(0, 2);
mem_bind(4, 2);
mem_bind(2, 2);
Assert("6", retbuf, "case6", __LINE__);
fin();
AAAA
PPPPNNNNXXXX
might become
PPPPPPPPXXXX 7
void case7(void)
init();
mem_bind(0, 2);
mem_interleave(4, 2);
mem_bind(2, 2);
Assert("4,2", retbuf, "case7", __LINE__);
fin();
AAAA
PPPPNNNNXXXX
might become
PPPPNNNNNNNN 8
void case8(void)
init();
mem_bind(0, 2);
mem_interleave(2, 2);
Assert("2,4", retbuf, "case8", __LINE__);
fin();
void case_n(void)
init();
/* make redundunt mappings [0][1234][34][7] */
mmap(mmap_addr + pagesize*4, pagesize*2, PROT_READ|PROT_WRITE,
MAP_FIXED|MAP_SHARED, mapped_fd, pagesize*3);
/* Expect to do nothing. */
mem_unbind(2, 2);
Assert("4,2", retbuf, "case_n", __LINE__);
fin();
int main(int argc, char** argv)
case4();
case5();
case6();
case7();
case8();
case_n();
return 0;
Cc: Caspar Zhang <caspar@casparzhang.com>
Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: <stable@vger.kernel.org> [3.1.x]
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
Quiet the spares noise:
warning: symbol 'default_policy' was not declared. Should it be static?
The files changed within are only using the EXPORT_SYMBOL
macro variants. They are not using core modular infrastructure
and hence don't need module.h but only the export.h header.
When compiling mm/mempolicy.c with struct user copy checks the following
warning is shown:
In file included from arch/x86/include/asm/uaccess.h:572,
from include/linux/uaccess.h:5,
from include/linux/highmem.h:7,
from include/linux/pagemap.h:10,
from include/linux/mempolicy.h:70,
from mm/mempolicy.c:68:
In function `copy_from_user',
inlined from `compat_sys_get_mempolicy' at mm/mempolicy.c:1415:
arch/x86/include/asm/uaccess_64.h:64: warning: call to `copy_from_user_overflow' declared with attribute warning: copy_from_user() buffer size is not provably correct
LD mm/built-in.o
Fix this by passing correct buffer size value.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
commit 9d8cebd4bcd7 ("mm: fix mbind vma merge problem") didn't really
fix the mbind vma merge problem due to wrong pgoff value passing to
vma_merge(), which made vma_merge() always return NULL.
Before the patch applied, we are getting a result like:
addr = 0x7fa58f00c000
[snip]
7fa58f00c000-7fa58f00d000 rw-p 00000000 00:00 0
7fa58f00d000-7fa58f00e000 rw-p 00000000 00:00 0
7fa58f00e000-7fa58f00f000 rw-p 00000000 00:00 0
here 7fa58f00c000->7fa58f00f000 we get 3 VMAs which are expected to be
merged described as described in commit 9d8cebd.
Re-testing the patched kernel with the reproducer provided in commit
9d8cebd, we get the correct result:
addr = 0x7ffa5aaa2000
[snip]
7ffa5aaa2000-7ffa5aaa6000 rw-p 00000000 00:00 0
7fffd556f000-7fffd5584000 rw-p 00000000 00:00 0 [stack]
Signed-off-by: Caspar Zhang <caspar@casparzhang.com>
[ This patch has already been accepted as commit 0ac0c0d0f837 but later
reverted (commit 35926ff5fba8) because it itroduced arch specific
__node_random which was defined only for x86 code so it broke other
archs. This is a followup without any arch specific code. Other than
that there are no functional changes.]
Some workloads that create a large number of small files tend to assign
too many pages to node 0 (multi-node systems). Part of the reason is
that the rotor (in cpuset_mem_spread_node()) used to assign nodes starts
at node 0 for newly created tasks.
This patch changes the rotor to be initialized to a random node number
of the cpuset.
[akpm@linux-foundation.org: fix layout]
[Lee.Schermerhorn@hp.com: Define stub numa_random() for !NUMA configuration]
[mhocko@suse.cz: Make it arch independent]
[akpm@linux-foundation.org: fix CONFIG_NUMA=y, MAX_NUMNODES>1 build]
Signed-off-by: Jack Steiner <steiner@sgi.com>
Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Cc: Paul Menage <menage@google.com>
Cc: Jack Steiner <steiner@sgi.com>
Cc: Robin Holt <holt@sgi.com>
Moving show_numa_map() from mempolicy.c to task_mmu.c solves several
issues.
- Having the show() operation "miles away" from the corresponding
seq_file iteration operations is a maintenance burden.
- The need to export ad hoc info like struct proc_maps_private is
eliminated.
- The implementation of show_numa_map() can be improved in a simple
manner by cooperating with the other seq_file operations (start,
stop, etc) -- something that would be messy to do without this
change.
Signed-off-by: Stephen Wilson <wilsons@start.ca>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
This function has been superseded by gather_hugetbl_stats() and is no
longer needed.
Improve the prototype of gather_stats() to take a struct numa_maps as
argument instead of a generic void *. Update all callers to make the
required type explicit.
Since gather_stats() is not needed before its definition and is scheduled
to be moved out of mempolicy.c the declaration is removed as well.
Mapping statistics in a NUMA environment is now computed using the generic
walk_page_range() logic. Remove the old/equivalent functionality.
Converting show_numa_map() to use the generic routine decouples the
function from mempolicy.c, allowing it to be moved out of the mm subsystem
and into fs/proc.
Also, include KSM pages in /proc/pid/numa_maps statistics. The pagewalk
logic implemented by check_pte_range() failed to account for such pages as
they were not applicable to the page migration case.
In commit 48fce3429d ("mempolicies: unexport get_vma_policy()")
get_vma_policy() was marked static as all clients were local to
mempolicy.c.
However, the decision to generate /proc/pid/numa_maps in the numa memory
policy code and outside the procfs subsystem introduces an artificial
interdependency between the two systems. Exporting get_vma_policy() once
again is the first step to clean up this interdependency.
The 'flags' field is already checked, no need to do it again.
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Cc: Bob Liu <lliubbo@gmail.com>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits)
doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore
Update cpuset info & webiste for cgroups
dcdbas: force SMI to happen when expected
arch/arm/Kconfig: remove one to many l's in the word.
asm-generic/user.h: Fix spelling in comment
drm: fix printk typo 'sracth'
Remove one to many n's in a word
Documentation/filesystems/romfs.txt: fixing link to genromfs
drivers:scsi Change printk typo initate -> initiate
serial, pch uart: Remove duplicate inclusion of linux/pci.h header
fs/eventpoll.c: fix spelling
mm: Fix out-of-date comments which refers non-existent functions
drm: Fix printk typo 'failled'
coh901318.c: Change initate to initiate.
mbox-db5500.c Change initate to initiate.
edac: correct i82975x error-info reported
edac: correct i82975x mci initialisation
edac: correct commented info
fs: update comments to point correct document
target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c
Trivial conflict in fs/eventpoll.c (spelling vs addition)
Pass down the correct node for a transparent hugepage allocation. Most
callers continue to use the current node, however the hugepaged daemon
now uses the previous node of the first to be collapsed page instead.
This ensures that khugepaged does not mess up local memory for an
existing process which uses local policy.
The choice of node is somewhat primitive currently: it just uses the
node of the first page in the pmd range. An alternative would be to
look at multiple pages and use the most popular node. I used the
simplest variant for now which should work well enough for the case of
all pages being on the same node.
Acked-by: Andrea Arcangeli <aarcange@redhat.com>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Currently alloc_pages_vma() always uses the local node as policy node for
the LOCAL policy. Pass this node down as an argument instead.
No behaviour change from this patch, but will be needed for followons.
The THP code didn't pass the correct interleaving shift to the memory
policy code. Fix this here by adjusting for the order.
Reviewed-by: Christoph Lameter <cl@linux.com>
It's mostly a matter of replacing alloc_pages with alloc_pages_vma after
introducing alloc_pages_vma. khugepaged needs special handling as the
allocation has to happen inside collapse_huge_page where the vma is known
and an error has to be returned to the outer loop to sleep
alloc_sleep_millisecs in case of failure. But it retains the more
efficient logic of handling allocation failures in khugepaged in case of
CONFIG_NUMA=n.
split_huge_page_pmd compat code. Each one of those would need to be
expanded to hundred of lines of complex code without a fully reliable
split_huge_page_pmd design.
Acked-by: Mel Gorman <mel@csn.ul.ie>
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Today, tasklist_lock in migrate_pages doesn't protect anything.
rcu_read_lock() provide enough protection from pid hash walk.
Reported-by: Peter Zijlstra <peterz@infradead.org>
sync
With the introduction of the boolean sync parameter, the API looks a
little inconsistent as offlining is still an int. Convert offlining to a
bool for the sake of being tidy.
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Cc: Andy Whitcroft <apw@shadowen.org>
synchronous compaction in the faster path
Migration synchronously waits for writeback if the initial passes fails.
Callers of memory compaction do not necessarily want this behaviour if the
caller is latency sensitive or expects that synchronous migration is not
going to have a significantly better success rate.
This patch adds a sync parameter to migrate_pages() allowing the caller to
indicate if wait_on_page_writeback() is allowed within migration or not.
For reclaim/compaction, try_to_compact_pages() is first called
asynchronously, direct reclaim runs and then try_to_compact_pages() is
called synchronously as there is a greater expectation that it'll succeed.
[akpm@linux-foundation.org: build/merge fix]
find_task_by_vpid() should be protected by rcu_read_lock(), to prevent
free_pid() reclaiming pid.
Signed-off-by: Zeng Zhaoming <zengzm.kernel@gmail.com>
Cc: "Paul E. McKenney" <paulmck@us.ibm.com>
When a node contains only HighMem memory, slab_node(MPOL_BIND)
dereferences a NULL pointer.
[ This code seems to go back all the way to commit 19770b32609b: "mm:
filter based on a nodemask as well as a gfp_mask". Which was back in
April 2008, and it got merged into 2.6.26. - Linus ]
Cc: stable@kernel.org
Function check_range may return ERR_PTR(...). Check for it.
Signed-off-by: Vasiliy Kulikov <segooon@gmail.com>
Presently update_nr_listpages() doesn't have a role. That's because lists
passed is always empty just after calling migrate_pages. The
migrate_pages cleans up page list which have failed to migrate before
returning by aaa994b3.
[PATCH] page migration: handle freeing of pages in migrate_pages()
Do not leave pages on the lists passed to migrate_pages(). Seems that we will
not need any postprocessing of pages. This will simplify the handling of
pages by the callers of migrate_pages().
At that time, we thought we don't need any postprocessing of pages. But
the situation is changed. The compaction need to know the number of
failed to migrate for COMPACTPAGEFAILED stat
This patch makes new rule for caller of migrate_pages to call
putback_lru_pages. So caller need to clean up the lists so it has a
chance to postprocess the pages. [suggested by Christoph Lameter]
Signed-off-by: Minchan Kim <minchan.kim@gmail.com>
Reviewed-by: Mel Gorman <mel@csn.ul.ie>
Reviewed-by: Wu Fengguang <fengguang.wu@intel.com>
Acked-by: Christoph Lameter <cl@linux.com>
migrate_pages() is using >500 bytes stack. Reduce it.
mm/mempolicy.c: In function 'sys_migrate_pages':
mm/mempolicy.c:1344: warning: the frame size of 528 bytes is larger than 512 bytes
[akpm@linux-foundation.org: don't play with a might-be-NULL pointer]
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
The oom killer presently kills current whenever there is no more memory
free or reclaimable on its mempolicy's nodes. There is no guarantee that
current is a memory-hogging task or that killing it will free any
substantial amount of memory, however.
In such situations, it is better to scan the tasklist for nodes that are
allowed to allocate on current's set of nodes and kill the task with the
highest badness() score. This ensures that the most memory-hogging task,
or the one configured by the user with /proc/pid/oom_adj, is always
selected in such scenarios.
Signed-off-by: David Rientjes <rientjes@google.com>
My patch to "Factor out duplicate put/frees in mpol_shared_policy_init()
to a common return path"; and Dan Carpenter's fix thereto both left a
dangling reference to the incoming tmpfs superblock mempolicy structure.
A similar leak was introduced earlier when the nodemask was moved offstack
to the scratch area despite the note in the comment block regarding the
incoming ref.
Move the remaining 'put of the incoming "mpol" to the common exit path to
drop the reference.
Acked-by: Dan Carpenter <error27@gmail.com>
The original code called mpol_put(new) while "new" was an ERR_PTR.
Use mm->task_size instead of TASK_SIZE to ensure that the entire user
address space is migrated. mm->task_size is independent of the calling
task context. TASK SIZE may be dependant on the address space size of the
calling process. Usage of TASK_SIZE can lead to partial address space
migration if the calling process was 32 bit and the migrating process was
64 bit.
Here is the test script used on 64 system with a 32 bit echo process:
mount -t cgroup none /cgroup -o cpuset
cd /cgroup
mkdir 0
echo 1 > 0/cpuset.cpus
echo 0 > 0/cpuset.mems
echo 1 > 0/cpuset.memory_migrate
mkdir 1
echo 1 > 1/cpuset.cpus
echo 1 > 1/cpuset.mems
echo 1 > 1/cpuset.memory_migrate
echo $$ > 0/tasks
64_bit_process &
pid=$!
echo $pid > 1/tasks # This does not migrate all process pages without
# this patch. If 64 bit echo is used or this patch is
# applied, then the full address space of $pid is
# migrated.
To check memory migration, I watched:
grep MemUsed /sys/devices/system/node/node*/meminfo
Signed-off-by: Greg Thelen <gthelen@google.com>
Acked-by: Christoph Lameter <cl@linux-foundation.org>
Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Cc: Balbir Singh <balbir@in.ibm.com>
Before applying this patch, cpuset updates task->mems_allowed and
mempolicy by setting all new bits in the nodemask first, and clearing all
old unallowed bits later. But in the way, the allocator may find that
there is no node to alloc memory.
The reason is that cpuset rebinds the task's mempolicy, it cleans the
nodes which the allocater can alloc pages on, for example:
(mpol: mempolicy)
task1 task1's mpol task2
alloc page 1
alloc on node0? NO 1
1 change mems from 1 to 0
1 rebind task1's mpol
0-1 set new bits
0 clear disallowed bits
alloc on node1? NO 0
can't alloc page
goto oom
This patch fixes this problem by expanding the nodes range first(set newly
allowed bits) and shrink it lazily(clear newly disallowed bits). So we
use a variable to tell the write-side task that read-side task is reading
nodemask, and the write-side task clears newly disallowed nodes after
read-side task ends the current memory allocation.
[akpm@linux-foundation.org: fix spello]
Signed-off-by: Miao Xie <miaox@cn.fujitsu.com>
Cc: Nick Piggin <npiggin@suse.de>
Cc: Ravikiran Thirumalai <kiran@scalex86.org>
Nick Piggin reported that the allocator may see an empty nodemask when
changing cpuset's mems[1]. It happens only on the kernel that do not do
atomic nodemask_t stores. (MAX_NUMNODES > BITS_PER_LONG)
But I found that there is also a problem on the kernel that can do atomic
nodemask_t stores. The problem is that the allocator can't find a node to
alloc page when changing cpuset's mems though there is a lot of free
memory. The reason is like this:
(mpol: mempolicy)
alloc page 1
0-1 set new bits
can't alloc page
goto oom
I can use the attached program reproduce it by the following step:
# mkdir /dev/cpuset
# mount -t cpuset cpuset /dev/cpuset
# mkdir /dev/cpuset/1
# echo `cat /dev/cpuset/cpus` > /dev/cpuset/1/cpus
# echo `cat /dev/cpuset/mems` > /dev/cpuset/1/mems
# echo $$ > /dev/cpuset/1/tasks
# numactl --membind=`cat /dev/cpuset/mems` ./cpuset_mem_hog <nr_tasks> &
<nr_tasks> = max(nr_cpus - 1, 1)
# killall -s SIGUSR1 cpuset_mem_hog
# ./change_mems.sh
several hours later, oom will happen though there is a lot of free memory.
This patchset fixes this problem by expanding the nodes range first(set
newly allowed bits) and shrink it lazily(clear newly disallowed bits). So
we use a variable to tell the write-side task that read-side task is
reading nodemask, and the write-side task clears newly disallowed nodes
after read-side task ends the current memory allocation.
This patch:
In order to fix no node to alloc memory, when we want to update mempolicy
and mems_allowed, we expand the set of nodes first (set all the newly
nodes) and shrink the set of nodes lazily(clean disallowed nodes), But the
mempolicy's rebind functions may breaks the expanding.
So we restructure the mempolicy's rebind functions and split the rebind
work to two steps, just like the update of cpuset's mems: The 1st step:
expand the set of the mempolicy's nodes. The 2nd step: shrink the set of
the mempolicy's nodes. It is used when there is no real lock to protect
the mempolicy in the read-side. Otherwise we can do rebind work at once.
In order to implement it, we define
enum mpol_rebind_step {
MPOL_REBIND_ONCE,
MPOL_REBIND_STEP1,
MPOL_REBIND_STEP2,
MPOL_REBIND_NSTEP,
If the mempolicy needn't be updated by two steps, we can pass
MPOL_REBIND_ONCE to the rebind functions. Or we can pass
MPOL_REBIND_STEP1 to do the first step of the rebind work and pass
MPOL_REBIND_STEP2 to do the second step work.
Besides that, it maybe long time between these two step and we have to
release the lock that protects mempolicy and mems_allowed. If we hold the
lock once again, we must check whether the current mempolicy is under the
rebinding (the first step has been done) or not, because the task may
alloc a new mempolicy when we don't hold the lock. So we defined the
following flag to identify it:
#define MPOL_F_REBINDING (1 << 2)
The new functions will be used in the next patch.
Factor out duplicate put/frees in mpol_shared_policy_init() to a common
return path.
Rename 'policy_types[]' to 'policy_modes[]' to better match the array
contents.
Use designated intializer syntax for policy_modes[].
We don't really need the extra variable 'i' in mpol_parse_str(). The only
use is as the the loop variable. Then, it's assigned to 'mode'. Just use
mode, and loose the 'uninitialized_var()' macro.
No need to call mpol_set_nodemask() when we have no context for the
mempolicy. This can occur when we're parsing a tmpfs 'mpol' mount option.
Just save the raw nodemask in the mempolicy's w.user_nodemask member for
use when a tmpfs/shmem file is created. mpol_shared_policy_init() will
"contextualize" the policy for the new file based on the creating task's
context.
Lee's patch "mempolicy: use MPOL_PREFERRED for system-wide default policy"
has made the MPOL_DEFAULT only used in the memory policy APIs. So, no
need to check in __mpol_equal also. Also get rid of mpol_match_intent()
and move its logic directly into __mpol_equal().
Signed-off-by: Bob Liu <lliubbo@gmail.com>
In policy_zonelist() mode MPOL_INTERLEAVE shouldn't happen, so fall
through to BUG() instead of break to return. I also fixed the comment.
