path: root/mm/mempool.c
2007-10-20spelling fixes: mm/Simon Arlott
Spelling fixes in mm/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-07-17Slab allocators: Replace explicit zeroing with __GFP_ZEROChristoph Lameter
kmalloc_node() and kmem_cache_alloc_node() were not available in a zeroing variant in the past. But with __GFP_ZERO it is possible now to do zeroing while allocating. Use __GFP_ZERO to remove the explicit clearing of memory via memset whereever we can. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16permit mempool_free(NULL)Rusty Russell
Christian Borntraeger points out that mempool_free() doesn't noop when handed NULL. This is inconsistent with the other free-like functions in the kernel. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Numerous fixes to kernel-doc info in source files.Robert P. J. Day
A variety of (mostly) innocuous fixes to the embedded kernel-doc content in source files, including: * make multi-line initial descriptions single line * denote some function names, constants and structs as such * change erroneous opening '/*' to '/**' in a few places * reword some text for clarity Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-01[PATCH] dm: work around mempool_alloc, bio_alloc_bioset deadlocksPavel Mironchik
This patch works around a complex dm-related deadlock/livelock down in the mempool allocator. Alasdair said: Several dm targets suffer from this. Mempools are not yet used correctly everywhere in device-mapper: they can get shared when devices are stacked, and some targets share them across multiple instances. I made fixing this one of the prerequisites for this patch: md-dm-reduce-stack-usage-with-stacked-block-devices.patch which in some cases makes people more likely to hit the problem. There's been some progress on this recently with (unfinished) dm-crypt patches at: http://www.kernel.org/pub/linux/kernel/people/agk/patches/2.6/editing/ (dm-crypt-move-io-to-workqueue.patch plus dependencies) and: I've no problems with a temporary workaround like that, but Milan Broz (a new Redhat developer in the Czech Republic) has started reviewing all the mempool usage in device-mapper so I'm expecting we'll soon have a proper fix for this associated problems. [He's back from holiday at the start of next week.] For now, this sad-but-safe little patch will allow the machine to recover. [akpm@osdl.org: rewrote changelog] Cc: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: drivers/char/ftape/lowlevel/fdc-io.c: Correct a comment Kconfig help: MTD_JEDECPROBE already supports Intel Remove ugly debugging stuff do_mounts.c: Minor ROOT_DEV comment cleanup BUG_ON() Conversion in drivers/s390/block/dasd_devmap.c BUG_ON() Conversion in mm/mempool.c BUG_ON() Conversion in mm/memory.c BUG_ON() Conversion in kernel/fork.c BUG_ON() Conversion in ipc/sem.c BUG_ON() Conversion in fs/ext2/ BUG_ON() Conversion in fs/hfs/ BUG_ON() Conversion in fs/dcache.c BUG_ON() Conversion in fs/buffer.c BUG_ON() Conversion in input/serio/hp_sdc_mlc.c BUG_ON() Conversion in md/dm-table.c BUG_ON() Conversion in md/dm-path-selector.c BUG_ON() Conversion in drivers/isdn BUG_ON() Conversion in drivers/char BUG_ON() Conversion in drivers/mtd/
2006-03-26[PATCH] mempool: add kzalloc allocatorMatthew Dobson
Add another allocator to the common mempool code: a kzalloc/kfree allocator This will be used by the next patch in the series to replace a mempool-backed kzalloc allocator. It is also very likely that there will be more users in the future. Signed-off-by: Matthew Dobson <colpatch@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] mempool: add kmalloc allocatorMatthew Dobson
Add another allocator to the common mempool code: a kmalloc/kfree allocator This will be used by the next patch in the series to replace duplicate mempool-backed kmalloc allocators in several places in the kernel. It is also very likely that there will be more users in the future. Signed-off-by: Matthew Dobson <colpatch@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] mempool: add page allocatorMatthew Dobson
This will be used by the next patch in the series to replace duplicate mempool-backed page allocators in 2 places in the kernel. It is also likely that there will be more users in the future. Signed-off-by: Matthew Dobson <colpatch@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26BUG_ON() Conversion in mm/mempool.cEric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-22[PATCH] mm: kill kmem_cache_t usagePekka Enberg
We have struct kmem_cache now so use it instead of the old typedef. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] gfp_t: mm/* (easy parts)Al Viro
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] propagate __nocast annotationsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] mempool - only init waitqueue in slow pathBenjamin LaHaise
Here's a small patch to improve the performance of mempool_alloc by only initializing the wait queue when we're about to wait. Signed-off-by: Benjamin LaHaise <benjamin.c.lahaise@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] NUMA aware block device control structure allocationChristoph Lameter
Patch to allocate the control structures for for ide devices on the node of the device itself (for NUMA systems). The patch depends on the Slab API change patch by Manfred and me (in mm) and the pcidev_to_node patch that I posted today. Does some realignment too. Signed-off-by: Justin M. Forbes <jmforbes@linuxtx.org> Signed-off-by: Christoph Lameter <christoph@lameter.com> Signed-off-by: Pravin Shelar <pravin@calsoftinc.com> Signed-off-by: Shobhit Dayal <shobhit@calsoftinc.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] use smp_mb/wmb/rmb where possibleakpm@osdl.org
Replace a number of memory barriers with smp_ variants. This means we won't take the unnecessary hit on UP machines. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] mempool: simplify allocNick Piggin
Mempool is pretty clever. Looks too clever for its own good :) It shouldn't really know so much about page reclaim internals. - don't guess about what effective page reclaim might involve. - don't randomly flush out all dirty data if some unlikely thing happens (alloc returns NULL). page reclaim can (sort of :P) handle it. I think the main motivation is trying to avoid pool->lock at all costs. However the first allocation is attempted with __GFP_WAIT cleared, so it will be 'can_try_harder' if it hits the page allocator. So if allocation still fails, then we can probably afford to hit the pool->lock - and what's the alternative? Try page reclaim and hit zone->lru_lock? A nice upshot is that we don't need to do any fancy memory barriers or do (intentionally) racy access to pool-> fields outside the lock. Signed-off-by: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] mempool: NOMEMALLOC and NORETRYNick Piggin
Mempools have 2 problems. The first is that mempool_alloc can possibly get stuck in __alloc_pages when they should opt to fail, and take an element from their reserved pool. The second is that it will happily eat emergency PF_MEMALLOC reserves instead of going to their reserved pools. Fix the first by passing __GFP_NORETRY in the allocation calls in mempool_alloc. Fix the second by introducing a __GFP_MEMPOOL flag which directs the page allocator not to allocate from the reserve pool. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
