Originally by Nick Piggin <npiggin@suse.de>
Remove mlocked pages from the LRU using "unevictable infrastructure"
during mmap(), munmap(), mremap() and truncate(). Try to move back to
normal LRU lists on munmap() when last mlocked mapping removed. Remove
PageMlocked() status when page truncated from file.
[akpm@linux-foundation.org: cleanup]
[kamezawa.hiroyu@jp.fujitsu.com: fix double unlock_page()]
[kosaki.motohiro@jp.fujitsu.com: split LRU: munlock rework]
[lee.schermerhorn@hp.com: mlock: fix __mlock_vma_pages_range comment block]
[akpm@linux-foundation.org: remove bogus kerneldoc token]
Signed-off-by: Nick Piggin <npiggin@suse.de>
Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Signed-off-by: Rik van Riel <riel@redhat.com>
Signed-off-by: KAMEZAWA Hiroyuki <kamewzawa.hiroyu@jp.fujitsu.com>
Make sure that mlocked pages also live on the unevictable LRU, so kswapd
will not scan them over and over again.
This is achieved through various strategies:
1) add yet another page flag--PG_mlocked--to indicate that
the page is locked for efficient testing in vmscan and,
optionally, fault path. This allows early culling of
unevictable pages, preventing them from getting to
page_referenced()/try_to_unmap(). Also allows separate
accounting of mlock'd pages, as Nick's original patch
did.
Note: Nick's original mlock patch used a PG_mlocked
flag. I had removed this in favor of the PG_unevictable
flag + an mlock_count [new page struct member]. I
restored the PG_mlocked flag to eliminate the new
count field.
2) add the mlock/unevictable infrastructure to mm/mlock.c,
with internal APIs in mm/internal.h. This is a rework
of Nick's original patch to these files, taking into
account that mlocked pages are now kept on unevictable
LRU list.
3) update vmscan.c:page_evictable() to check PageMlocked()
and, if vma passed in, the vm_flags. Note that the vma
will only be passed in for new pages in the fault path;
and then only if the "cull unevictable pages in fault
path" patch is included.
4) add try_to_unlock() to rmap.c to walk a page's rmap and
ClearPageMlocked() if no other vmas have it mlocked.
Reuses as much of try_to_unmap() as possible. This
effectively replaces the use of one of the lru list links
as an mlock count. If this mechanism let's pages in mlocked
vmas leak through w/o PG_mlocked set [I don't know that it
does], we should catch them later in try_to_unmap(). One
hopes this will be rare, as it will be relatively expensive.
Original mm/internal.h, mm/rmap.c and mm/mlock.c changes:
splitlru: introduce __get_user_pages():
New munlock processing need to GUP_FLAGS_IGNORE_VMA_PERMISSIONS.
because current get_user_pages() can't grab PROT_NONE pages theresore it
cause PROT_NONE pages can't munlock.
[akpm@linux-foundation.org: fix this for pagemap-pass-mm-into-pagewalkers.patch]
[akpm@linux-foundation.org: untangle patch interdependencies]
[akpm@linux-foundation.org: fix things after out-of-order merging]
[hugh@veritas.com: fix page-flags mess]
[lee.schermerhorn@hp.com: fix munlock page table walk - now requires 'mm']
[kosaki.motohiro@jp.fujitsu.com: build fix]
[kosaki.motohiro@jp.fujitsu.com: fix truncate race and sevaral comments]
[kosaki.motohiro@jp.fujitsu.com: splitlru: introduce __get_user_pages()]
Cc: Nick Piggin <npiggin@suse.de>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Cc: Matt Mackall <mpm@selenic.com>
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Anonymous mappings should ignore offset but shared anonymous mapping
forgot to clear it and makes the following legit test program trigger
SIGBUS.
#include <sys/mman.h>
#include <stdio.h>
#include <errno.h>
#define PAGE_SIZE 4096
int main(void)
char *p;
int i;
p = mmap(NULL, 2 * PAGE_SIZE, PROT_READ|PROT_WRITE,
MAP_SHARED|MAP_ANONYMOUS, -1, PAGE_SIZE);
if (p == MAP_FAILED) {
perror("mmap");
return 1;
for (i = 0; i < 2; i++) {
printf("page %d\n", i);
p[i * 4096] = i;
return 0;
Fix it.
Acked-by: Hugh Dickins <hugh@veritas.com>
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Lockdep spotted:
[ INFO: possible circular locking dependency detected ]
2.6.27-rc1 #270
qemu-kvm/2033 is trying to acquire lock:
(&inode->i_data.i_mmap_lock){----}, at: [<ffffffff802996cc>] mm_take_all_locks+0xc2/0xea
but task is already holding lock:
(&anon_vma->lock){----}, at: [<ffffffff8029967a>] mm_take_all_locks+0x70/0xea
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (&anon_vma->lock){----}:
[<ffffffff8025cd37>] __lock_acquire+0x11be/0x14d2
[<ffffffff8025d0a9>] lock_acquire+0x5e/0x7a
[<ffffffff804c655b>] _spin_lock+0x3b/0x47
[<ffffffff8029a2ef>] vma_adjust+0x200/0x444
[<ffffffff8029a662>] split_vma+0x12f/0x146
[<ffffffff8029bc60>] mprotect_fixup+0x13c/0x536
[<ffffffff8029c203>] sys_mprotect+0x1a9/0x21e
[<ffffffff8020c0db>] system_call_fastpath+0x16/0x1b
[<ffffffffffffffff>] 0xffffffffffffffff
-> #0 (&inode->i_data.i_mmap_lock){----}:
[<ffffffff8025ca54>] __lock_acquire+0xedb/0x14d2
[<ffffffff8025d397>] lock_release_non_nested+0x1c2/0x219
[<ffffffff8025d515>] lock_release+0x127/0x14a
[<ffffffff804c6403>] _spin_unlock+0x1e/0x50
[<ffffffff802995d9>] mm_drop_all_locks+0x7f/0xb0
[<ffffffff802a965d>] do_mmu_notifier_register+0xe2/0x112
[<ffffffff802a96a8>] mmu_notifier_register+0xe/0x10
[<ffffffffa0043b6b>] kvm_dev_ioctl+0x11e/0x287 [kvm]
[<ffffffff802bd0ca>] vfs_ioctl+0x2a/0x78
[<ffffffff802bd36f>] do_vfs_ioctl+0x257/0x274
[<ffffffff802bd3e1>] sys_ioctl+0x55/0x78
5 locks held by qemu-kvm/2033:
#0: (&mm->mmap_sem){----}, at: [<ffffffff802a95d0>] do_mmu_notifier_register+0x55/0x112
#1: (mm_all_locks_mutex){--..}, at: [<ffffffff8029963e>] mm_take_all_locks+0x34/0xea
#2: (&anon_vma->lock){----}, at: [<ffffffff8029967a>] mm_take_all_locks+0x70/0xea
#3: (&anon_vma->lock){----}, at: [<ffffffff8029967a>] mm_take_all_locks+0x70/0xea
#4: (&anon_vma->lock){----}, at: [<ffffffff8029967a>] mm_take_all_locks+0x70/0xea
stack backtrace:
Pid: 2033, comm: qemu-kvm Not tainted 2.6.27-rc1 #270
Call Trace:
[<ffffffff8025b7c7>] print_circular_bug_tail+0xb8/0xc3
[<ffffffff80259bb1>] ? add_lock_to_list+0x7e/0xad
[<ffffffff8029967a>] ? mm_take_all_locks+0x70/0xea
[<ffffffff802996cc>] ? mm_take_all_locks+0xc2/0xea
[<ffffffff8025b202>] ? trace_hardirqs_on_caller+0x4d/0x115
[<ffffffff802995d9>] ? mm_drop_all_locks+0x7f/0xb0
[<ffffffff8033f9f2>] ? file_has_perm+0x83/0x8e
Which the locking hierarchy in mm/rmap.c confirms as valid.
Fix this by first taking all the mapping->i_mmap_lock instances and then
take all anon_vma->lock instances.
The nesting is correct due to holding mmap_sem, use the new annotation
to annotate this.
gcc 4.3.0 correctly emits the following warnings.
When a vma covering addr is found, find_vma_prepare indeed returns without
setting pprev, rb_link, and rb_parent.
mm/mmap.c: In function `insert_vm_struct':
mm/mmap.c:2085: warning: `rb_parent' may be used uninitialized in this function
mm/mmap.c:2085: warning: `rb_link' may be used uninitialized in this function
mm/mmap.c:2084: warning: `prev' may be used uninitialized in this function
mm/mmap.c: In function `copy_vma':
mm/mmap.c:2124: warning: `rb_parent' may be used uninitialized in this function
mm/mmap.c:2124: warning: `rb_link' may be used uninitialized in this function
mm/mmap.c:2123: warning: `prev' may be used uninitialized in this function
mm/mmap.c: In function `do_brk':
mm/mmap.c:1951: warning: `rb_parent' may be used uninitialized in this function
mm/mmap.c:1951: warning: `rb_link' may be used uninitialized in this function
mm/mmap.c:1949: warning: `prev' may be used uninitialized in this function
mm/mmap.c: In function `mmap_region':
mm/mmap.c:1092: warning: `rb_parent' may be used uninitialized in this function
mm/mmap.c:1092: warning: `rb_link' may be used uninitialized in this function
mm/mmap.c:1089: warning: `prev' may be used uninitialized in this function
Hugh adds: in fact, none of find_vma_prepare's callers use those values
when a vma is found to be already covering addr, it's either an error or
an occasion to munmap and repeat. Okay, let's quieten the compiler (but I
would prefer it if pprev, rb_link and rb_parent were meaningful in that
case, rather than whatever's in them from descending the tree).
Signed-off-by: Benny Halevy <bhalevy@panasas.com>
Cc: "Ryan Hope" <rmh3093@gmail.com>
With KVM/GFP/XPMEM there isn't just the primary CPU MMU pointing to pages.
There are secondary MMUs (with secondary sptes and secondary tlbs) too.
sptes in the kvm case are shadow pagetables, but when I say spte in
mmu-notifier context, I mean "secondary pte". In GRU case there's no
actual secondary pte and there's only a secondary tlb because the GRU
secondary MMU has no knowledge about sptes and every secondary tlb miss
event in the MMU always generates a page fault that has to be resolved by
the CPU (this is not the case of KVM where the a secondary tlb miss will
walk sptes in hardware and it will refill the secondary tlb transparently
to software if the corresponding spte is present). The same way
zap_page_range has to invalidate the pte before freeing the page, the spte
(and secondary tlb) must also be invalidated before any page is freed and
reused.
Currently we take a page_count pin on every page mapped by sptes, but that
means the pages can't be swapped whenever they're mapped by any spte
because they're part of the guest working set. Furthermore a spte unmap
event can immediately lead to a page to be freed when the pin is released
(so requiring the same complex and relatively slow tlb_gather smp safe
logic we have in zap_page_range and that can be avoided completely if the
spte unmap event doesn't require an unpin of the page previously mapped in
the secondary MMU).
The mmu notifiers allow kvm/GRU/XPMEM to attach to the tsk->mm and know
when the VM is swapping or freeing or doing anything on the primary MMU so
that the secondary MMU code can drop sptes before the pages are freed,
avoiding all page pinning and allowing 100% reliable swapping of guest
physical address space. Furthermore it avoids the code that teardown the
mappings of the secondary MMU, to implement a logic like tlb_gather in
zap_page_range that would require many IPI to flush other cpu tlbs, for
each fixed number of spte unmapped.
To make an example: if what happens on the primary MMU is a protection
downgrade (from writeable to wrprotect) the secondary MMU mappings will be
invalidated, and the next secondary-mmu-page-fault will call
get_user_pages and trigger a do_wp_page through get_user_pages if it
called get_user_pages with write=1, and it'll re-establishing an updated
spte or secondary-tlb-mapping on the copied page. Or it will setup a
readonly spte or readonly tlb mapping if it's a guest-read, if it calls
get_user_pages with write=0. This is just an example.
This allows to map any page pointed by any pte (and in turn visible in the
primary CPU MMU), into a secondary MMU (be it a pure tlb like GRU, or an
full MMU with both sptes and secondary-tlb like the shadow-pagetable layer
with kvm), or a remote DMA in software like XPMEM (hence needing of
schedule in XPMEM code to send the invalidate to the remote node, while no
need to schedule in kvm/gru as it's an immediate event like invalidating
primary-mmu pte).
At least for KVM without this patch it's impossible to swap guests
reliably. And having this feature and removing the page pin allows
several other optimizations that simplify life considerably.
Dependencies:
1) mm_take_all_locks() to register the mmu notifier when the whole VM
isn't doing anything with "mm". This allows mmu notifier users to keep
track if the VM is in the middle of the invalidate_range_begin/end
critical section with an atomic counter incraese in range_begin and
decreased in range_end. No secondary MMU page fault is allowed to map
any spte or secondary tlb reference, while the VM is in the middle of
range_begin/end as any page returned by get_user_pages in that critical
section could later immediately be freed without any further
->invalidate_page notification (invalidate_range_begin/end works on
ranges and ->invalidate_page isn't called immediately before freeing
the page). To stop all page freeing and pagetable overwrites the
mmap_sem must be taken in write mode and all other anon_vma/i_mmap
locks must be taken too.
2) It'd be a waste to add branches in the VM if nobody could possibly
run KVM/GRU/XPMEM on the kernel, so mmu notifiers will only enabled if
CONFIG_KVM=m/y. In the current kernel kvm won't yet take advantage of
mmu notifiers, but this already allows to compile a KVM external module
against a kernel with mmu notifiers enabled and from the next pull from
kvm.git we'll start using them. And GRU/XPMEM will also be able to
continue the development by enabling KVM=m in their config, until they
submit all GRU/XPMEM GPLv2 code to the mainline kernel. Then they can
also enable MMU_NOTIFIERS in the same way KVM does it (even if KVM=n).
This guarantees nobody selects MMU_NOTIFIER=y if KVM and GRU and XPMEM
are all =n.
The mmu_notifier_register call can fail because mm_take_all_locks may be
interrupted by a signal and return -EINTR. Because mmu_notifier_reigster
is used when a driver startup, a failure can be gracefully handled. Here
an example of the change applied to kvm to register the mmu notifiers.
Usually when a driver startups other allocations are required anyway and
-ENOMEM failure paths exists already.
struct kvm *kvm_arch_create_vm(void)
struct kvm *kvm = kzalloc(sizeof(struct kvm), GFP_KERNEL);
+ int err;
if (!kvm)
return ERR_PTR(-ENOMEM);
INIT_LIST_HEAD(&kvm->arch.active_mmu_pages);
+ kvm->arch.mmu_notifier.ops = &kvm_mmu_notifier_ops;
+ err = mmu_notifier_register(&kvm->arch.mmu_notifier, current->mm);
+ if (err) {
+ kfree(kvm);
+ return ERR_PTR(err);
return kvm;
mmu_notifier_unregister returns void and it's reliable.
The patch also adds a few needed but missing includes that would prevent
kernel to compile after these changes on non-x86 archs (x86 didn't need
them by luck).
[akpm@linux-foundation.org: fix mm/filemap_xip.c build]
[akpm@linux-foundation.org: fix mm/mmu_notifier.c build]
Signed-off-by: Andrea Arcangeli <andrea@qumranet.com>
Signed-off-by: Christoph Lameter <cl@linux-foundation.org>
Cc: Jack Steiner <steiner@sgi.com>
Cc: Robin Holt <holt@sgi.com>
Cc: Kanoj Sarcar <kanojsarcar@yahoo.com>
Cc: Roland Dreier <rdreier@cisco.com>
Cc: Steve Wise <swise@opengridcomputing.com>
Cc: Avi Kivity <avi@qumranet.com>
Cc: Hugh Dickins <hugh@veritas.com>
Cc: Anthony Liguori <aliguori@us.ibm.com>
Cc: Chris Wright <chrisw@redhat.com>
Cc: Marcelo Tosatti <marcelo@kvack.org>
Cc: Eric Dumazet <dada1@cosmosbay.com>
Cc: "Paul E. McKenney" <paulmck@us.ibm.com>
Cc: Izik Eidus <izike@qumranet.com>
mm_take_all_locks holds off reclaim from an entire mm_struct. This allows
mmu notifiers to register into the mm at any time with the guarantee that
no mmu operation is in progress on the mm.
This operation locks against the VM for all pte/vma/mm related operations
that could ever happen on a certain mm. This includes vmtruncate,
try_to_unmap, and all page faults.
The caller must take the mmap_sem in write mode before calling
mm_take_all_locks(). The caller isn't allowed to release the mmap_sem
until mm_drop_all_locks() returns.
mmap_sem in write mode is required in order to block all operations that
could modify pagetables and free pages without need of altering the vma
layout (for example populate_range() with nonlinear vmas). It's also
needed in write mode to avoid new anon_vmas to be associated with existing
vmas.
A single task can't take more than one mm_take_all_locks() in a row or it
would deadlock.
mm_take_all_locks() and mm_drop_all_locks are expensive operations that
may have to take thousand of locks.
mm_take_all_locks() can fail if it's interrupted by signals.
When mmu_notifier_register returns, we must be sure that the driver is
notified if some task is in the middle of a vmtruncate for the 'mm' where
the mmu notifier was registered (mmu_notifier_invalidate_range_start/end
is run around the vmtruncation but mmu_notifier_register can run after
mmu_notifier_invalidate_range_start and before
mmu_notifier_invalidate_range_end). Same problem for rmap paths. And
we've to remove page pinning to avoid replicating the tlb_gather logic
inside KVM (and GRU doesn't work well with page pinning regardless of
needing tlb_gather), so without mm_take_all_locks when vmtruncate frees
the page, kvm would have no way to notice that it mapped into sptes a page
that is going into the freelist without a chance of any further
mmu_notifier notification.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
The goal of this patchset is to support multiple hugetlb page sizes. This
is achieved by introducing a new struct hstate structure, which
encapsulates the important hugetlb state and constants (eg. huge page
size, number of huge pages currently allocated, etc).
The hstate structure is then passed around the code which requires these
fields, they will do the right thing regardless of the exact hstate they
are operating on.
This patch adds the hstate structure, with a single global instance of it
(default_hstate), and does the basic work of converting hugetlb to use the
hstate.
Future patches will add more hstate structures to allow for different
hugetlbfs mounts to have different page sizes.
Acked-by: Adam Litke <agl@us.ibm.com>
Acked-by: Nishanth Aravamudan <nacc@us.ibm.com>
Signed-off-by: Andi Kleen <ak@suse.de>
With Mel's hugetlb private reservation support patches applied, strict
overcommit semantics are applied to both shared and private huge page
mappings. This can be a problem if an application relied on unlimited
overcommit semantics for private mappings. An example of this would be an
application which maps a huge area with the intention of using it very
sparsely. These application would benefit from being able to opt-out of
the strict overcommit. It should be noted that prior to hugetlb
supporting demand faulting all mappings were fully populated and so
applications of this type should be rare.
This patch stack implements the MAP_NORESERVE mmap() flag for huge page
mappings. This flag has the same meaning as for small page mappings,
suppressing reservations for that mapping.
Thanks to Mel Gorman for reviewing a number of early versions of these
patches.
This patch:
When a small page mapping is created with mmap() reservations are created
by default for any memory pages required. When the region is read/write
the reservation is increased for every page, no reservation is needed for
read-only regions (as they implicitly share the zero page). Reservations
are tracked via the VM_ACCOUNT vma flag which is present when the region
has reservation backing it. When we convert a region from read-only to
read-write new reservations are aquired and VM_ACCOUNT is set. However,
when a read-only map is created with MAP_NORESERVE it is indistinguishable
from a normal mapping. When we then convert that to read/write we are
forced to incorrectly create reservations for it as we have no record of
the original MAP_NORESERVE.
This patch introduces a new vma flag VM_NORESERVE which records the
presence of the original MAP_NORESERVE flag. This allows us to
distinguish these two circumstances and correctly account the reserve.
As well as fixing this FIXME in the code, this makes it much easier to
introduce MAP_NORESERVE support for huge pages as this flag is available
consistantly for the life of the mapping. VM_ACCOUNT on the other hand is
heavily used at the generic level in association with small pages.
Signed-off-by: Andy Whitcroft <apw@shadowen.org>
Cc: Adam Litke <agl@us.ibm.com>
Cc: Johannes Weiner <hannes@saeurebad.de>
Cc: Andy Whitcroft <apw@shadowen.org>
Cc: William Lee Irwin III <wli@holomorphy.com>
Cc: Michael Kerrisk <mtk.manpages@googlemail.com>
The double indirection here is not needed anywhere and hence (at least)
confusing.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Acked-by: Jeremy Fitzhardinge <jeremy@goop.org>
This patch allows architectures to define functions to deal with
additional protections bits for mmap() and mprotect().
arch_calc_vm_prot_bits() maps additonal protection bits to vm_flags
arch_vm_get_page_prot() maps additional vm_flags to the vma's vm_page_prot
arch_validate_prot() checks for valid values of the protection bits
Note: vm_get_page_prot() is now pretty ugly, but the generated code
should be identical for architectures that don't define additional
protection bits.
Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
Fix a regression introduced by
commit 4cc6028d4040f95cdb590a87db478b42b8be0508
Author: Jiri Kosina <jkosina@suse.cz>
Date: Wed Feb 6 22:39:44 2008 +0100
brk: check the lower bound properly
The check in sys_brk() on minimum value the brk might have must take
CONFIG_COMPAT_BRK setting into account. When this option is turned on
(i.e. we support ancient legacy binaries, e.g. libc5-linked stuff), the
lower bound on brk value is mm->end_code, otherwise the brk start is
allowed to be arbitrarily shifted.
Tested-by: Geert Uytterhoeven <geert@linux-m68k.org>
Cc: <stable@kernel.org>
The atomic_t type is 32bit but a 64bit system can have more than 2^32
pages of virtual address space available. Without this we overflow on
ludicrously large mappings
Signed-off-by: Alan Cox <alan@redhat.com>
The kernel implements readlink of /proc/pid/exe by getting the file from
the first executable VMA. Then the path to the file is reconstructed and
reported as the result.
Because of the VMA walk the code is slightly different on nommu systems.
This patch avoids separate /proc/pid/exe code on nommu systems. Instead of
walking the VMAs to find the first executable file-backed VMA we store a
reference to the exec'd file in the mm_struct.
That reference would prevent the filesystem holding the executable file
from being unmounted even after unmapping the VMAs. So we track the number
of VM_EXECUTABLE VMAs and drop the new reference when the last one is
unmapped. This avoids pinning the mounted filesystem.
[akpm@linux-foundation.org: improve comments]
[yamamoto@valinux.co.jp: fix dup_mmap]
Signed-off-by: Matt Helsley <matthltc@us.ibm.com>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Cc:"Eric W. Biederman" <ebiederm@xmission.com>
Signed-off-by: YAMAMOTO Takashi <yamamoto@valinux.co.jp>
This patch renames mpol_copy() to mpol_dup() because, well, that's what it
does. Like, e.g., strdup() for strings, mpol_dup() takes a pointer to an
existing mempolicy, allocates a new one and copies the contents.
In a later patch, I want to use the name mpol_copy() to copy the contents from
one mempolicy to another like, e.g., strcpy() does for strings.
Cc: Christoph Lameter <clameter@sgi.com>
Cc: Andi Kleen <ak@suse.de>
This is a change that was requested some time ago by Mel Gorman. Makes sense
to me, so here it is.
Note: I retain the name "mpol_free_shared_policy()" because it actually does
free the shared_policy, which is NOT a reference counted object. However, ...
The mempolicy object[s] referenced by the shared_policy are reference counted,
so mpol_put() is used to release the reference held by the shared_policy. The
mempolicy might not be freed at this time, because some task attached to the
shared object associated with the shared policy may be in the process of
allocating a page based on the mempolicy. In that case, the task performing
the allocation will hold a reference on the mempolicy, obtained via
mpol_shared_policy_lookup(). The mempolicy will be freed when all tasks
holding such a reference have called mpol_put() for the mempolicy.
It is not easy to actually understand the "if (!file || !vma_merge())"
code, turn it into "if (file && vma_merge())". This makes immediately
obvious that the subsequent "if (file)" is superfluous.
As Hugh Dickins pointed out, we can also factor out the ->i_writecount
corrections, and add a small comment about that.
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Miklos Szeredi <miklos@szeredi.hu>
Convert special mapping install from nopage to fault.
Because the "vm_file" is NULL for the special mapping, the generic VM
code has messed up "vm_pgoff" thinking that it's an anonymous mapping
and the offset does't matter. For that reason, we need to undo the
vm_pgoff offset that got added into vmf->pgoff.
[ We _really_ should clean that up - either by making this whole special
mapping code just use a real file entry rather than that ugly array of
"struct page" pointers, or by just making the VM code realize that
even if vm_file is NULL it may not be a regular anonymous mmap.
- Linus ]
Cc: linux-mm@kvack.org
There is a check in sys_brk(), that tries to make sure that we do not
underflow the area that is dedicated to brk heap.
The check is however wrong, as it assumes that brk area starts immediately
after the end of the code (+bss), which is wrong for example in
environments with randomized brk start. The proper way is to check whether
the address is not below the start_brk address.
In order to change the layout of the page tables after an mmap has crossed the
adress space limit of the current page table layout a architecture hook in
get_unmapped_area is needed. The arguments are the address of the new mapping
and the length of it.
Cc: <linux-arch@vger.kernel.org>
Drivers that register a ->fault handler, but do not range-check the
offset argument, must set VM_DONTEXPAND in the vm_flags in order to
prevent an expanding mremap from overflowing the resource.
I've audited the tree and attempted to fix these problems (usually by
adding VM_DONTEXPAND where it is not obvious).
Randomize the location of the heap (brk) for i386 and x86_64. The range is
randomized in the range starting at current brk location up to 0x02000000
offset for both architectures. This, together with
pie-executable-randomization.patch and
pie-executable-randomization-fix.patch, should make the address space
randomization on i386 and x86_64 complete.
Arjan says:
This is known to break older versions of some emacs variants, whose dumper
code assumed that the last variable declared in the program is equal to the
start of the dynamically allocated memory region.
(The dumper is the code where emacs effectively dumps core at the end of it's
compilation stage; this coredump is then loaded as the main program during
normal use)
iirc this was 5 years or so; we found this way back when I was at RH and we
first did the security stuff there (including this brk randomization). It
wasn't all variants of emacs, and it got fixed as a result (I vaguely remember
that emacs already had code to deal with it for other archs/oses, just
ifdeffed wrongly).
It's a rare and wrong assumption as a general thing, just on x86 it mostly
happened to be true (but to be honest, it'll break too if gcc does
something fancy or if the linker does a non-standard order). Still its
something we should at least document.
Note 2: afaik it only broke the emacs *build*. I'm not 100% sure about that
(it IS 5 years ago) though.
[ akpm@linux-foundation.org: deuglification ]
Cc: Arjan van de Ven <arjan@infradead.org>
Cc: Roland McGrath <roland@redhat.com>
Cc: Jakub Jelinek <jakub@redhat.com>
Fixing:
CHECK mm/mmap.c
mm/mmap.c:1623:29: warning: Using plain integer as NULL pointer
mm/mmap.c:1944:29: warning: Using plain integer as NULL pointer
Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se>
Signed-off-by: James Morris <jmorris@namei.org>
Given a specifically crafted binary do_brk() can be used to get low
pages available in userspace virtually memory and can thus be used to
circumvent the mmap_min_addr low memory protection. Add security checks
in do_brk().
Signed-off-by: Eric Paris <eparis@redhat.com>
Acked-by: Alan Cox <alan@redhat.com>
If mmap_min_addr is set and a process attempts to mmap (not fixed) with a
non-null hint address less than mmap_min_addr the mapping will fail the
security checks. Since this is just a hint address this patch will round
such a hint address above mmap_min_addr.
gcj was found to try to be very frugal with vm usage and give hint addresses
in the 8k-32k range. Without this patch all such programs failed and with
the patch they happily get a higher address.
This patch is wrappad in CONFIG_SECURITY since mmap_min_addr doesn't exist
without it and there would be no security check possible no matter what. So
we should not bother compiling in this rounding if it is just a waste of
time.
Add security checks to make sure we are not attempting to expand the
stack into memory protected by mmap_min_addr
Fix mprotect bug in recent commit 3ed75eb8f1cd89565966599c4f77d2edb086d5b0
(setup vma->vm_page_prot by vm_get_page_prot()): the vma_wants_writenotify
case was setting the same prot as when not.
Nothing wrong with the use of protection_map[] in mmap_region(),
but use vm_get_page_prot() there too in the same ~VM_SHARED way.
Cc: Coly Li <coyli@suse.de>
This patch uses vm_get_page_prot() to setup vma->vm_page_prot.
Though inside vm_get_page_prot() the protection flags is AND with
(VM_READ|VM_WRITE|VM_EXEC|VM_SHARED), it does not hurt correct code.
Signed-off-by: Coly Li <coyli@suse.de>
This patch contains the following cleanups that are now possible:
- remove the unused security_operations->inode_xattr_getsuffix
- remove the no longer used security_operations->unregister_security
- remove some no longer required exit code
- remove a bunch of no longer used exports
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Acked-by: James Morris <jmorris@namei.org>
Cc: Chris Wright <chrisw@sous-sol.org>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Cc: Serge Hallyn <serue@us.ibm.com>
mm.h doesn't use directly anything from mutex.h and backing-dev.h, so
remove them and add them back to files which need them.
Cross-compile tested on many configs and archs.
The new exec code inserts an accounted vma into an mm struct which is not
current->mm. The existing memory check code has a hard coded assumption
that this does not happen as does the security code.
As the correct mm is known we pass the mm to the security method and the
helper function. A new security test is added for the case where we need
to pass the mm and the existing one is modified to pass current->mm to
avoid the need to change large amounts of code.
(Thanks to Tobias for fixing rejects and testing)
Cc: WU Fengguang <wfg@mail.ustc.edu.cn>
Cc: James Morris <jmorris@redhat.com>
Cc: Tobias Diedrich <ranma+kernel@tdiedrich.de>
Remove fs.h from mm.h. For this,
1) Uninline vma_wants_writenotify(). It's pretty huge anyway.
2) Add back fs.h or less bloated headers (err.h) to files that need it.
As result, on x86_64 allyesconfig, fs.h dependencies cut down from 3929 files
rebuilt down to 3444 (-12.3%).
Cross-compile tested without regressions on my two usual configs and (sigh):
alpha arm-mx1ads mips-bigsur powerpc-ebony
alpha-allnoconfig arm-neponset mips-capcella powerpc-g5
alpha-defconfig arm-netwinder mips-cobalt powerpc-holly
alpha-up arm-netx mips-db1000 powerpc-iseries
arm arm-ns9xxx mips-db1100 powerpc-linkstation
arm-assabet arm-omap_h2_1610 mips-db1200 powerpc-lite5200
arm-at91rm9200dk arm-onearm mips-db1500 powerpc-maple
arm-at91rm9200ek arm-picotux200 mips-db1550 powerpc-mpc7448_hpc2
arm-at91sam9260ek arm-pleb mips-ddb5477 powerpc-mpc8272_ads
arm-at91sam9261ek arm-pnx4008 mips-decstation powerpc-mpc8313_rdb
arm-at91sam9263ek arm-pxa255-idp mips-e55 powerpc-mpc832x_mds
arm-at91sam9rlek arm-realview mips-emma2rh powerpc-mpc832x_rdb
arm-ateb9200 arm-realview-smp mips-excite powerpc-mpc834x_itx
arm-badge4 arm-rpc mips-fulong powerpc-mpc834x_itxgp
arm-carmeva arm-s3c2410 mips-ip22 powerpc-mpc834x_mds
arm-cerfcube arm-shannon mips-ip27 powerpc-mpc836x_mds
arm-clps7500 arm-shark mips-ip32 powerpc-mpc8540_ads
arm-collie arm-simpad mips-jazz powerpc-mpc8544_ds
arm-corgi arm-spitz mips-jmr3927 powerpc-mpc8560_ads
arm-csb337 arm-trizeps4 mips-malta powerpc-mpc8568mds
arm-csb637 arm-versatile mips-mipssim powerpc-mpc85xx_cds
arm-ebsa110 i386 mips-mpc30x powerpc-mpc8641_hpcn
arm-edb7211 i386-allnoconfig mips-msp71xx powerpc-mpc866_ads
arm-em_x270 i386-defconfig mips-ocelot powerpc-mpc885_ads
arm-ep93xx i386-up mips-pb1100 powerpc-pasemi
arm-footbridge ia64 mips-pb1500 powerpc-pmac32
arm-fortunet ia64-allnoconfig mips-pb1550 powerpc-ppc64
arm-h3600 ia64-bigsur mips-pnx8550-jbs powerpc-prpmc2800
arm-h7201 ia64-defconfig mips-pnx8550-stb810 powerpc-ps3
arm-h7202 ia64-gensparse mips-qemu powerpc-pseries
arm-hackkit ia64-sim mips-rbhma4200 powerpc-up
arm-integrator ia64-sn2 mips-rbhma4500 s390
arm-iop13xx ia64-tiger mips-rm200 s390-allnoconfig
arm-iop32x ia64-up mips-sb1250-swarm s390-defconfig
arm-iop33x ia64-zx1 mips-sead s390-up
arm-ixp2000 m68k mips-tb0219 sparc
arm-ixp23xx m68k-amiga mips-tb0226 sparc-allnoconfig
arm-ixp4xx m68k-apollo mips-tb0287 sparc-defconfig
arm-jornada720 m68k-atari mips-workpad sparc-up
arm-kafa m68k-bvme6000 mips-wrppmc sparc64
arm-kb9202 m68k-hp300 mips-yosemite sparc64-allnoconfig
arm-ks8695 m68k-mac parisc sparc64-defconfig
arm-lart m68k-mvme147 parisc-allnoconfig sparc64-up
arm-lpd270 m68k-mvme16x parisc-defconfig um-x86_64
arm-lpd7a400 m68k-q40 parisc-up x86_64
arm-lpd7a404 m68k-sun3 powerpc x86_64-allnoconfig
arm-lubbock m68k-sun3x powerpc-cell x86_64-defconfig
arm-lusl7200 mips powerpc-celleb x86_64-up
arm-mainstone mips-atlas powerpc-chrp32
Remove the arg+env limit of MAX_ARG_PAGES by copying the strings directly from
the old mm into the new mm.
We create the new mm before the binfmt code runs, and place the new stack at
the very top of the address space. Once the binfmt code runs and figures out
where the stack should be, we move it downwards.
It is a bit peculiar in that we have one task with two mm's, one of which is
inactive.
[a.p.zijlstra@chello.nl: limit stack size]
Signed-off-by: Ollie Wild <aaw@google.com>
[bunk@stusta.de: unexport bprm_mm_init]
Nonlinear mappings are (AFAIKS) simply a virtual memory concept that encodes
the virtual address -> file offset differently from linear mappings.
->populate is a layering violation because the filesystem/pagecache code
should need to know anything about the virtual memory mapping. The hitch here
is that the ->nopage handler didn't pass down enough information (ie. pgoff).
But it is more logical to pass pgoff rather than have the ->nopage function
calculate it itself anyway (because that's a similar layering violation).
Having the populate handler install the pte itself is likewise a nasty thing
to be doing.
This patch introduces a new fault handler that replaces ->nopage and
->populate and (later) ->nopfn. Most of the old mechanism is still in place
so there is a lot of duplication and nice cleanups that can be removed if
everyone switches over.
The rationale for doing this in the first place is that nonlinear mappings are
subject to the pagefault vs invalidate/truncate race too, and it seemed stupid
to duplicate the synchronisation logic rather than just consolidate the two.
After this patch, MAP_NONBLOCK no longer sets up ptes for pages present in
pagecache. Seems like a fringe functionality anyway.
NOPAGE_REFAULT is removed. This should be implemented with ->fault, and no
users have hit mainline yet.
[randy.dunlap@oracle.com: doc. fixes for readahead]
[akpm@linux-foundation.org: build fix]
Cc: Mark Fasheh <mark.fasheh@oracle.com>
This is a straightforward split of do_mmap_pgoff() into two functions:
- do_mmap_pgoff() checks the parameters, and calculates the vma
flags. Then it calls
- mmap_region(), which does the actual mapping
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Add a new security check on mmap operations to see if the user is attempting
to mmap to low area of the address space. The amount of space protected is
indicated by the new proc tunable /proc/sys/vm/mmap_min_addr and defaults to
0, preserving existing behavior.
This patch uses a new SELinux security class "memprotect." Policy already
contains a number of allow rules like a_t self:process * (unconfined_t being
one of them) which mean that putting this check in the process class (its
best current fit) would make it useless as all user processes, which we also
want to protect against, would be allowed. By taking the memprotect name of
the new class it will also make it possible for us to move some of the other
memory protect permissions out of 'process' and into the new class next time
we bump the policy version number (which I also think is a good future idea)
Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
Acked-by: Chris Wright <chrisw@sous-sol.org>
Function expand_upwards() did not guarded against wrapping
around to address 0. This fixes the adjtimex02 testcase from
the Linux Test Project on a 32bit PARISC kernel.
[expand_upwards is only used on parisc and ia64; it looks like it does
the right thing on both. --kyle]
Signed-off-by: Helge Deller <deller@gmx.de>
Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
Signed-off-by: Michael Opdenacker <michael@free-electrons.com>
Signed-off-by: Roland McGrath <roland@redhat.com>
Remove the hugetlbfs specific hacks in toplevel get_unmapped_area() now that
all archs and hugetlbfs itself do the right thing for both cases.
Acked-by: William Irwin <bill.irwin@oracle.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Grant Grundler <grundler@parisc-linux.org>
Cc: Matthew Wilcox <willy@debian.org>
Cc: David Gibson <david@gibson.dropbear.id.au>
generic arch_get_unmapped_area() now handles MAP_FIXED. Now that all
implementations have been fixed, change the toplevel get_unmapped_area() to
call into arch or drivers for the MAP_FIXED case.
Cc: William Irwin <bill.irwin@oracle.com>
Add hooks to allow a paravirt implementation to track the lifetime of
an mm. Paravirtualization requires three hooks, but only two are
needed in common code. They are:
arch_dup_mmap, which is called when a new mmap is created at fork
arch_exit_mmap, which is called when the last process reference to an
mm is dropped, which typically happens on exit and exec.
The third hook is activate_mm, which is called from the arch-specific
activate_mm() macro/function, and so doesn't need stub versions for
other architectures. It's called when an mm is first used.
Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com>
Cc: James Bottomley <James.Bottomley@SteelEye.com>
The code is seemingly trying to make sure that rb_next() brings us to
successive increasing vma entries.
But the two variables, prev and pend, used to perform these checks, are
never advanced.
Cc: Andrea Arcangeli <andrea@novell.com>
This patch adds a utility function install_special_mapping, for creating a
special vma using a fixed set of preallocated pages as backing, such as for a
vDSO. This consolidates some nearly identical code used for vDSO mapping
reimplemented for different architectures.
When expanding the stack, we don't currently check if the VMA will cross
into an area of the address space that is reserved for hugetlb pages.
Subsequent faults on the expanded portion of such a VMA will confuse the
low-level MMU code, resulting in an OOPS. Check for this.
Signed-off-by: Adam Litke <agl@us.ibm.com>
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in linux/mm/.
Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu>
SLAB_KERNEL is an alias of GFP_KERNEL.
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Commit cb07c9a1864a8eac9f3123e428100d5b2a16e65a causes the wrong return
value. is_hugepage_only_range() is a boolean, so we should return
-EINVAL rather than 1.
Also - we can use "mm" instead of looking up "current->mm" again.
