path: root/mm/mmap.c
2014-10-29mm, thp: fix collapsing of hugepages on madviseDavid Rientjes
If an anonymous mapping is not allowed to fault thp memory and then madvise(MADV_HUGEPAGE) is used after fault, khugepaged will never collapse this memory into thp memory. This occurs because the madvise(2) handler for thp, hugepage_madvise(), clears VM_NOHUGEPAGE on the stack and it isn't stored in vma->vm_flags until the final action of madvise_behavior(). This causes the khugepaged_enter_vma_merge() to be a no-op in hugepage_madvise() when the vma had previously had VM_NOHUGEPAGE set. Fix this by passing the correct vma flags to the khugepaged mm slot handler. There's no chance khugepaged can run on this vma until after madvise_behavior() returns since we hold mm->mmap_sem. It would be possible to clear VM_NOHUGEPAGE directly from vma->vm_flags in hugepage_advise(), but I didn't want to introduce special case behavior into madvise_behavior(). I think it's best to just let it always set vma->vm_flags itself. Signed-off-by: David Rientjes <rientjes@google.com> Reported-by: Suleiman Souhlal <suleiman@google.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14mm: softdirty: enable write notifications on VMAs after VM_SOFTDIRTY clearedPeter Feiner
For VMAs that don't want write notifications, PTEs created for read faults have their write bit set. If the read fault happens after VM_SOFTDIRTY is cleared, then the PTE's softdirty bit will remain clear after subsequent writes. Here's a simple code snippet to demonstrate the bug: char* m = mmap(NULL, getpagesize(), PROT_READ | PROT_WRITE, MAP_ANONYMOUS | MAP_SHARED, -1, 0); system("echo 4 > /proc/$PPID/clear_refs"); /* clear VM_SOFTDIRTY */ assert(*m == '\0'); /* new PTE allows write access */ assert(!soft_dirty(x)); *m = 'x'; /* should dirty the page */ assert(soft_dirty(x)); /* fails */ With this patch, write notifications are enabled when VM_SOFTDIRTY is cleared. Furthermore, to avoid unnecessary faults, write notifications are disabled when VM_SOFTDIRTY is set. As a side effect of enabling and disabling write notifications with care, this patch fixes a bug in mprotect where vm_page_prot bits set by drivers were zapped on mprotect. An analogous bug was fixed in mmap by commit c9d0bf241451 ("mm: uncached vma support with writenotify"). Signed-off-by: Peter Feiner <pfeiner@google.com> Reported-by: Peter Feiner <pfeiner@google.com> Suggested-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Jamie Liu <jamieliu@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-10Merge branch 'for-3.18' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu Pull percpu updates from Tejun Heo: "A lot of activities on percpu front. Notable changes are... - percpu allocator now can take @gfp. If @gfp doesn't contain GFP_KERNEL, it tries to allocate from what's already available to the allocator and a work item tries to keep the reserve around certain level so that these atomic allocations usually succeed. This will replace the ad-hoc percpu memory pool used by blk-throttle and also be used by the planned blkcg support for writeback IOs. Please note that I noticed a bug in how @gfp is interpreted while preparing this pull request and applied the fix 6ae833c7fe0c ("percpu: fix how @gfp is interpreted by the percpu allocator") just now. - percpu_ref now uses longs for percpu and global counters instead of ints. It leads to more sparse packing of the percpu counters on 64bit machines but the overhead should be negligible and this allows using percpu_ref for refcnting pages and in-memory objects directly. - The switching between percpu and single counter modes of a percpu_ref is made independent of putting the base ref and a percpu_ref can now optionally be initialized in single or killed mode. This allows avoiding percpu shutdown latency for cases where the refcounted objects may be synchronously created and destroyed in rapid succession with only a fraction of them reaching fully operational status (SCSI probing does this when combined with blk-mq support). It's also planned to be used to implement forced single mode to detect underflow more timely for debugging. There's a separate branch percpu/for-3.18-consistent-ops which cleans up the duplicate percpu accessors. That branch causes a number of conflicts with s390 and other trees. I'll send a separate pull request w/ resolutions once other branches are merged" * 'for-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (33 commits) percpu: fix how @gfp is interpreted by the percpu allocator blk-mq, percpu_ref: start q->mq_usage_counter in atomic mode percpu_ref: make INIT_ATOMIC and switch_to_atomic() sticky percpu_ref: add PERCPU_REF_INIT_* flags percpu_ref: decouple switching to percpu mode and reinit percpu_ref: decouple switching to atomic mode and killing percpu_ref: add PCPU_REF_DEAD percpu_ref: rename things to prepare for decoupling percpu/atomic mode switch percpu_ref: replace pcpu_ prefix with percpu_ percpu_ref: minor code and comment updates percpu_ref: relocate percpu_ref_reinit() Revert "blk-mq, percpu_ref: implement a kludge for SCSI blk-mq stall during probe" Revert "percpu: free percpu allocation info for uniprocessor system" percpu-refcount: make percpu_ref based on longs instead of ints percpu-refcount: improve WARN messages percpu: fix locking regression in the failure path of pcpu_alloc() percpu-refcount: add @gfp to percpu_ref_init() proportions: add @gfp to init functions percpu_counter: add @gfp to percpu_counter_init() percpu_counter: make percpu_counters_lock irq-safe ...
2014-10-09mm: use VM_BUG_ON_MM where possibleSasha Levin
Dump the contents of the relevant struct_mm when we hit the bug condition. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-09mm/mmap.c: clean up CONFIG_DEBUG_VM_RB checksAndrew Morton
- be consistent in printing the test which failed - one message was actually wrong (a<b != b>a) - don't print second bogus warning if browse_rb() failed Cc: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-09mm: convert a few VM_BUG_ON callers to VM_BUG_ON_VMASasha Levin
Trivially convert a few VM_BUG_ON calls to VM_BUG_ON_VMA to extract more information when they trigger. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Michal Hocko <mhocko@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Michel Lespinasse <walken@google.com> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-09mm: use may_adjust_brk helperCyrill Gorcunov
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Kees Cook <keescook@chromium.org> Cc: Tejun Heo <tj@kernel.org> Cc: Andrew Vagin <avagin@openvz.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: H. Peter Anvin <hpa@zytor.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Vasiliy Kulikov <segoon@openwall.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Julien Tinnes <jln@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-09mm/mmap.c: whitespace fixesvishnu.ps
Signed-off-by: vishnu.ps <vishnu.ps@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-09-24Merge branch 'for-linus' of ↵Tejun Heo
git://git.kernel.org/pub/scm/linux/kernel/git/axboe/linux-block into for-3.18 This is to receive 0a30288da1ae ("blk-mq, percpu_ref: implement a kludge for SCSI blk-mq stall during probe") which implements __percpu_ref_kill_expedited() to work around SCSI blk-mq stall. The commit reverted and patches to implement proper fix will be added. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Kent Overstreet <kmo@daterainc.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Christoph Hellwig <hch@lst.de>
2014-09-10mm/mmap.c: use pr_emerg when printing BUG related informationSasha Levin
Make sure we actually see the output of validate_mm() and browse_rb() before triggering a BUG(). pr_info isn't shown by default so the reason for the BUG() isn't obvious. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-09-08percpu_counter: add @gfp to percpu_counter_init()Tejun Heo
Percpu allocator now supports allocation mask. Add @gfp to percpu_counter_init() so that !GFP_KERNEL allocation masks can be used with percpu_counters too. We could have left percpu_counter_init() alone and added percpu_counter_init_gfp(); however, the number of users isn't that high and introducing _gfp variants to all percpu data structures would be quite ugly, so let's just do the conversion. This is the one with the most users. Other percpu data structures are a lot easier to convert. This patch doesn't make any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Jan Kara <jack@suse.cz> Acked-by: "David S. Miller" <davem@davemloft.net> Cc: x86@kernel.org Cc: Jens Axboe <axboe@kernel.dk> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org>
2014-08-08mm: allow drivers to prevent new writable mappingsDavid Herrmann
This patch (of 6): The i_mmap_writable field counts existing writable mappings of an address_space. To allow drivers to prevent new writable mappings, make this counter signed and prevent new writable mappings if it is negative. This is modelled after i_writecount and DENYWRITE. This will be required by the shmem-sealing infrastructure to prevent any new writable mappings after the WRITE seal has been set. In case there exists a writable mapping, this operation will fail with EBUSY. Note that we rely on the fact that iff you already own a writable mapping, you can increase the counter without using the helpers. This is the same that we do for i_writecount. Signed-off-by: David Herrmann <dh.herrmann@gmail.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Ryan Lortie <desrt@desrt.ca> Cc: Lennart Poettering <lennart@poettering.net> Cc: Daniel Mack <zonque@gmail.com> Cc: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-06mm: catch memory commitment underflowKonstantin Khlebnikov
Print a warning (if CONFIG_DEBUG_VM=y) when memory commitment becomes too negative. This shouldn't happen any more - the previous two patches fixed the committed_as underflow issues. [akpm@linux-foundation.org: use VM_WARN_ONCE, per Dave] Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06mm: convert some level-less printks to pr_*Mitchel Humpherys
printk is meant to be used with an associated log level. There are some instances of printk scattered around the mm code where the log level is missing. Add a log level and adhere to suggestions by scripts/checkpatch.pl by moving to the pr_* macros. Also add the typical pr_fmt definition so that print statements can be easily traced back to the modules where they occur, correlated one with another, etc. This will require the removal of some (now redundant) prefixes on a few print statements. Signed-off-by: Mitchel Humpherys <mitchelh@codeaurora.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-05Merge branch 'x86/vdso' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next Pull x86 cdso updates from Peter Anvin: "Vdso cleanups and improvements largely from Andy Lutomirski. This makes the vdso a lot less ''special''" * 'x86/vdso' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/vdso, build: Make LE access macros clearer, host-safe x86/vdso, build: Fix cross-compilation from big-endian architectures x86/vdso, build: When vdso2c fails, unlink the output x86, vdso: Fix an OOPS accessing the HPET mapping w/o an HPET x86, mm: Replace arch_vma_name with vm_ops->name for vsyscalls x86, mm: Improve _install_special_mapping and fix x86 vdso naming mm, fs: Add vm_ops->name as an alternative to arch_vma_name x86, vdso: Fix an OOPS accessing the HPET mapping w/o an HPET x86, vdso: Remove vestiges of VDSO_PRELINK and some outdated comments x86, vdso: Move the vvar and hpet mappings next to the 64-bit vDSO x86, vdso: Move the 32-bit vdso special pages after the text x86, vdso: Reimplement vdso.so preparation in build-time C x86, vdso: Move syscall and sysenter setup into kernel/cpu/common.c x86, vdso: Clean up 32-bit vs 64-bit vdso params x86, mm: Ensure correct alignment of the fixmap
2014-06-04mm/mmap.c: remove the first mapping checkHuang Shijie
Remove the first mapping check for vma_link. Move the mutex_lock into the braces when vma->vm_file is true. Signed-off-by: Huang Shijie <b32955@freescale.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04mm/mmap.c: replace IS_ERR and PTR_ERR with PTR_ERR_OR_ZERODuan Jiong
Fix a coccinelle error regarding usage of IS_ERR and PTR_ERR instead of PTR_ERR_OR_ZERO. Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-20x86, mm: Improve _install_special_mapping and fix x86 vdso namingAndy Lutomirski
Using arch_vma_name to give special mappings a name is awkward. x86 currently implements it by comparing the start address of the vma to the expected address of the vdso. This requires tracking the start address of special mappings and is probably buggy if a special vma is split or moved. Improve _install_special_mapping to just name the vma directly. Use it to give the x86 vvar area a name, which should make CRIU's life easier. As a side effect, the vvar area will show up in core dumps. This could be considered weird and is fixable. [hpa: I say we accept this as-is but be prepared to deal with knocking out the vvars from core dumps if this becomes a problem.] Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: Andy Lutomirski <luto@amacapital.net> Link: http://lkml.kernel.org/r/276b39b6b645fb11e345457b503f17b83c2c6fd0.1400538962.git.luto@amacapital.net Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-04-07mm: per-thread vma cachingDavidlohr Bueso
This patch is a continuation of efforts trying to optimize find_vma(), avoiding potentially expensive rbtree walks to locate a vma upon faults. The original approach (https://lkml.org/lkml/2013/11/1/410), where the largest vma was also cached, ended up being too specific and random, thus further comparison with other approaches were needed. There are two things to consider when dealing with this, the cache hit rate and the latency of find_vma(). Improving the hit-rate does not necessarily translate in finding the vma any faster, as the overhead of any fancy caching schemes can be too high to consider. We currently cache the last used vma for the whole address space, which provides a nice optimization, reducing the total cycles in find_vma() by up to 250%, for workloads with good locality. On the other hand, this simple scheme is pretty much useless for workloads with poor locality. Analyzing ebizzy runs shows that, no matter how many threads are running, the mmap_cache hit rate is less than 2%, and in many situations below 1%. The proposed approach is to replace this scheme with a small per-thread cache, maximizing hit rates at a very low maintenance cost. Invalidations are performed by simply bumping up a 32-bit sequence number. The only expensive operation is in the rare case of a seq number overflow, where all caches that share the same address space are flushed. Upon a miss, the proposed replacement policy is based on the page number that contains the virtual address in question. Concretely, the following results are seen on an 80 core, 8 socket x86-64 box: 1) System bootup: Most programs are single threaded, so the per-thread scheme does improve ~50% hit rate by just adding a few more slots to the cache. +----------------+----------+------------------+ | caching scheme | hit-rate | cycles (billion) | +----------------+----------+------------------+ | baseline | 50.61% | 19.90 | | patched | 73.45% | 13.58 | +----------------+----------+------------------+ 2) Kernel build: This one is already pretty good with the current approach as we're dealing with good locality. +----------------+----------+------------------+ | caching scheme | hit-rate | cycles (billion) | +----------------+----------+------------------+ | baseline | 75.28% | 11.03 | | patched | 88.09% | 9.31 | +----------------+----------+------------------+ 3) Oracle 11g Data Mining (4k pages): Similar to the kernel build workload. +----------------+----------+------------------+ | caching scheme | hit-rate | cycles (billion) | +----------------+----------+------------------+ | baseline | 70.66% | 17.14 | | patched | 91.15% | 12.57 | +----------------+----------+------------------+ 4) Ebizzy: There's a fair amount of variation from run to run, but this approach always shows nearly perfect hit rates, while baseline is just about non-existent. The amounts of cycles can fluctuate between anywhere from ~60 to ~116 for the baseline scheme, but this approach reduces it considerably. For instance, with 80 threads: +----------------+----------+------------------+ | caching scheme | hit-rate | cycles (billion) | +----------------+----------+------------------+ | baseline | 1.06% | 91.54 | | patched | 99.97% | 14.18 | +----------------+----------+------------------+ [akpm@linux-foundation.org: fix nommu build, per Davidlohr] [akpm@linux-foundation.org: document vmacache_valid() logic] [akpm@linux-foundation.org: attempt to untangle header files] [akpm@linux-foundation.org: add vmacache_find() BUG_ON] [hughd@google.com: add vmacache_valid_mm() (from Oleg)] [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: adjust and enhance comments] Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Reviewed-by: Michel Lespinasse <walken@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Tested-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-04Merge branch 'locks-3.15' of git://git.samba.org/jlayton/linuxLinus Torvalds
Pull file locking updates from Jeff Layton: "Highlights: - maintainership change for fs/locks.c. Willy's not interested in maintaining it these days, and is OK with Bruce and I taking it. - fix for open vs setlease race that Al ID'ed - cleanup and consolidation of file locking code - eliminate unneeded BUG() call - merge of file-private lock implementation" * 'locks-3.15' of git://git.samba.org/jlayton/linux: locks: make locks_mandatory_area check for file-private locks locks: fix locks_mandatory_locked to respect file-private locks locks: require that flock->l_pid be set to 0 for file-private locks locks: add new fcntl cmd values for handling file private locks locks: skip deadlock detection on FL_FILE_PVT locks locks: pass the cmd value to fcntl_getlk/getlk64 locks: report l_pid as -1 for FL_FILE_PVT locks locks: make /proc/locks show IS_FILE_PVT locks as type "FLPVT" locks: rename locks_remove_flock to locks_remove_file locks: consolidate checks for compatible filp->f_mode values in setlk handlers locks: fix posix lock range overflow handling locks: eliminate BUG() call when there's an unexpected lock on file close locks: add __acquires and __releases annotations to locks_start and locks_stop locks: remove "inline" qualifier from fl_link manipulation functions locks: clean up comment typo locks: close potential race between setlease and open MAINTAINERS: update entry for fs/locks.c
2014-04-03mm/mmap.c: mark function as staticRashika Kheria
Mark function as static in mmap.c because they are not used outside this file. This eliminates the following warning in mm/mmap.c: mm/mmap.c:407:6: warning: no previous prototype for `validate_mm' [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-31locks: fix locks_mandatory_locked to respect file-private locksJeff Layton
As Trond pointed out, you can currently deadlock yourself by setting a file-private lock on a file that requires mandatory locking and then trying to do I/O on it. Avoid this problem by plumbing some knowledge of file-private locks into the mandatory locking code. In order to do this, we must pass down information about the struct file that's being used to locks_verify_locked. Reported-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: J. Bruce Fields <bfields@redhat.com>
2014-03-18mm: Add new func _install_special_mapping() to mmap.cStefani Seibold
The _install_special_mapping() is the new base function for install_special_mapping(). This function will return a pointer of the created VMA or a error code in an ERR_PTR() This new function will be needed by the for the vdso 32 bit support to map the additonal vvar and hpet pages into the 32 bit address space. This will be done with io_remap_pfn_range() and remap_pfn_range, which requieres a vm_area_struct. Reviewed-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Stefani Seibold <stefani@seibold.net> Link: http://lkml.kernel.org/r/1395094933-14252-3-git-send-email-stefani@seibold.net Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-01-23mm: ignore VM_SOFTDIRTY on VMA mergingCyrill Gorcunov
The VM_SOFTDIRTY bit affects vma merge routine: if two VMAs has all bits in vm_flags matched except dirty bit the kernel can't longer merge them and this forces the kernel to generate new VMAs instead. It finally may lead to the situation when userspace application reaches vm.max_map_count limit and get crashed in worse case | (gimp:11768): GLib-ERROR **: gmem.c:110: failed to allocate 4096 bytes | | (file-tiff-load:12038): LibGimpBase-WARNING **: file-tiff-load: gimp_wire_read(): error | xinit: connection to X server lost | | waiting for X server to shut down | /usr/lib64/gimp/2.0/plug-ins/file-tiff-load terminated: Hangup | /usr/lib64/gimp/2.0/plug-ins/script-fu terminated: Hangup | /usr/lib64/gimp/2.0/plug-ins/script-fu terminated: Hangup https://bugzilla.kernel.org/show_bug.cgi?id=67651 https://bugzilla.gnome.org/show_bug.cgi?id=719619#c0 Initial problem came from missed VM_SOFTDIRTY in do_brk() routine but even if we would set up VM_SOFTDIRTY here, there is still a way to prevent VMAs from merging: one can call | echo 4 > /proc/$PID/clear_refs and clear all VM_SOFTDIRTY over all VMAs presented in memory map, then new do_brk() will try to extend old VMA and finds that dirty bit doesn't match thus new VMA will be generated. As discussed with Pavel, the right approach should be to ignore VM_SOFTDIRTY bit when we're trying to merge VMAs and if merge successed we mark extended VMA with dirty bit where needed. Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Reported-by: Bastian Hougaard <gnome@rvzt.net> Reported-by: Mel Gorman <mgorman@suse.de> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23mm: audit/fix non-modular users of module_init in core codePaul Gortmaker
Code that is obj-y (always built-in) or dependent on a bool Kconfig (built-in or absent) can never be modular. So using module_init as an alias for __initcall can be somewhat misleading. Fix these up now, so that we can relocate module_init from init.h into module.h in the future. If we don't do this, we'd have to add module.h to obviously non-modular code, and that would be a worse thing. The audit targets the following module_init users for change: mm/ksm.c bool KSM mm/mmap.c bool MMU mm/huge_memory.c bool TRANSPARENT_HUGEPAGE mm/mmu_notifier.c bool MMU_NOTIFIER Note that direct use of __initcall is discouraged, vs. one of the priority categorized subgroups. As __initcall gets mapped onto device_initcall, our use of subsys_initcall (which makes sense for these files) will thus change this registration from level 6-device to level 4-subsys (i.e. slightly earlier). However no observable impact of that difference has been observed during testing. One might think that core_initcall (l2) or postcore_initcall (l3) would be more appropriate for anything in mm/ but if we look at some actual init functions themselves, we see things like: mm/huge_memory.c --> hugepage_init --> hugepage_init_sysfs mm/mmap.c --> init_user_reserve --> sysctl_user_reserve_kbytes mm/ksm.c --> ksm_init --> sysfs_create_group and hence the choice of subsys_initcall (l4) seems reasonable, and at the same time minimizes the risk of changing the priority too drastically all at once. We can adjust further in the future. Also, several instances of missing ";" at EOL are fixed. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21mm/mmap.c: add mlock_future_check() helperDavidlohr Bueso
Both do_brk and do_mmap_pgoff verify that we are actually capable of locking future pages if the corresponding VM_LOCKED flags are used. Encapsulate this logic into a single mlock_future_check() helper function. Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Cc: Rik van Riel <riel@redhat.com> Reviewed-by: Michel Lespinasse <walken@google.com> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21mm: add overcommit_kbytes sysctl variableJerome Marchand
Some applications that run on HPC clusters are designed around the availability of RAM and the overcommit ratio is fine tuned to get the maximum usage of memory without swapping. With growing memory, the 1%-of-all-RAM grain provided by overcommit_ratio has become too coarse for these workload (on a 2TB machine it represents no less than 20GB). This patch adds the new overcommit_kbytes sysctl variable that allow a much finer grain. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix nommu build] Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-15mm: convert mm->nr_ptes to atomic_long_tKirill A. Shutemov
With split page table lock for PMD level we can't hold mm->page_table_lock while updating nr_ptes. Let's convert it to atomic_long_t to avoid races. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Tested-by: Alex Thorlton <athorlton@sgi.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: "Eric W . Biederman" <ebiederm@xmission.com> Cc: "Paul E . McKenney" <paulmck@linux.vnet.ibm.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andi Kleen <ak@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Dave Jones <davej@redhat.com> Cc: David Howells <dhowells@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Kees Cook <keescook@chromium.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Robin Holt <robinmholt@gmail.com> Cc: Sedat Dilek <sedat.dilek@gmail.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-13Merge branch 'akpm' (patches from Andrew Morton)Linus Torvalds
Merge first patch-bomb from Andrew Morton: "Quite a lot of other stuff is banked up awaiting further next->mainline merging, but this batch contains: - Lots of random misc patches - OCFS2 - Most of MM - backlight updates - lib/ updates - printk updates - checkpatch updates - epoll tweaking - rtc updates - hfs - hfsplus - documentation - procfs - update gcov to gcc-4.7 format - IPC" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (269 commits) ipc, msg: fix message length check for negative values ipc/util.c: remove unnecessary work pending test devpts: plug the memory leak in kill_sb ./Makefile: export initial ramdisk compression config option init/Kconfig: add option to disable kernel compression drivers: w1: make w1_slave::flags long to avoid memory corruption drivers/w1/masters/ds1wm.cuse dev_get_platdata() drivers/memstick/core/ms_block.c: fix unreachable state in h_msb_read_page() drivers/memstick/core/mspro_block.c: fix attributes array allocation drivers/pps/clients/pps-gpio.c: remove redundant of_match_ptr kernel/panic.c: reduce 1 byte usage for print tainted buffer gcov: reuse kbasename helper kernel/gcov/fs.c: use pr_warn() kernel/module.c: use pr_foo() gcov: compile specific gcov implementation based on gcc version gcov: add support for gcc 4.7 gcov format gcov: move gcov structs definitions to a gcc version specific file kernel/taskstats.c: return -ENOMEM when alloc memory fails in add_del_listener() kernel/taskstats.c: add nla_nest_cancel() for failure processing between nla_nest_start() and nla_nest_end() kernel/sysctl_binary.c: use scnprintf() instead of snprintf() ...
2013-11-13mm: factor commit limit calculationJerome Marchand
The same calculation is currently done in three differents places. Factor that code so future changes has to be made at only one place. [akpm@linux-foundation.org: uninline vm_commit_limit()] Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-13mm: ensure get_unmapped_area() returns higher address than mmap_min_addrAkira Takeuchi
This patch fixes the problem that get_unmapped_area() can return illegal address and result in failing mmap(2) etc. In case that the address higher than PAGE_SIZE is set to /proc/sys/vm/mmap_min_addr, the address lower than mmap_min_addr can be returned by get_unmapped_area(), even if you do not pass any virtual address hint (i.e. the second argument). This is because the current get_unmapped_area() code does not take into account mmap_min_addr. This leads to two actual problems as follows: 1. mmap(2) can fail with EPERM on the process without CAP_SYS_RAWIO, although any illegal parameter is not passed. 2. The bottom-up search path after the top-down search might not work in arch_get_unmapped_area_topdown(). Note: The first and third chunk of my patch, which changes "len" check, are for more precise check using mmap_min_addr, and not for solving the above problem. [How to reproduce] --- test.c ------------------------------------------------- #include <stdio.h> #include <unistd.h> #include <sys/mman.h> #include <sys/errno.h> int main(int argc, char *argv[]) { void *ret = NULL, *last_map; size_t pagesize = sysconf(_SC_PAGESIZE); do { last_map = ret; ret = mmap(0, pagesize, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0); // printf("ret=%p\n", ret); } while (ret != MAP_FAILED); if (errno != ENOMEM) { printf("ERR: unexpected errno: %d (last map=%p)\n", errno, last_map); } return 0; } --------------------------------------------------------------- $ gcc -m32 -o test test.c $ sudo sysctl -w vm.mmap_min_addr=65536 vm.mmap_min_addr = 65536 $ ./test (run as non-priviledge user) ERR: unexpected errno: 1 (last map=0x10000) Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-13mmap: arch_get_unmapped_area(): use proper mmap base for bottom up directionHeiko Carstens
This is more or less the generic variant of commit 41aacc1eea64 ("x86 get_unmapped_area: Access mmap_legacy_base through mm_struct member"). So effectively architectures which use an own arch_pick_mmap_layout() implementation but call the generic arch_get_unmapped_area() now can also randomize their mmap_base. All architectures which have an own arch_pick_mmap_layout() and call the generic arch_get_unmapped_area() (arm64, s390, tile) currently set mmap_base to TASK_UNMAPPED_BASE. This is also true for the generic arch_pick_mmap_layout() function. So this change is a no-op currently. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Radu Caragea <sinaelgl@gmail.com> Cc: Michel Lespinasse <walken@google.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-24file->f_op is never NULL...Al Viro
2013-09-11mm/mmap: remove unnecessary assignmentYanchuan Nian
pgoff is not used after the statement "pgoff = vma->vm_pgoff;", so the assignment is redundant. Signed-off-by: Yanchuan Nian <ycnian@gmail.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11mm: track vma changes with VM_SOFTDIRTY bitCyrill Gorcunov
Pavel reported that in case if vma area get unmapped and then mapped (or expanded) in-place, the soft dirty tracker won't be able to recognize this situation since it works on pte level and ptes are get zapped on unmap, loosing soft dirty bit of course. So to resolve this situation we need to track actions on vma level, there VM_SOFTDIRTY flag comes in. When new vma area created (or old expanded) we set this bit, and keep it here until application calls for clearing soft dirty bit. Thus when user space application track memory changes now it can detect if vma area is renewed. Reported-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Matt Mackall <mpm@selenic.com> Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Peter Zijlstra <peterz@infradead.org> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Rob Landley <rob@landley.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11mm: mmap_region: kill correct_wcount/inode, use allow_write_access()Oleg Nesterov
correct_wcount and inode in mmap_region() just complicate the code. This boolean was needed previously, when deny_write_access() was called before vma_merge(), now we can simply check VM_DENYWRITE and do allow_write_access() if it is set. allow_write_access() checks file != NULL, so this is safe even if it was possible to use VM_DENYWRITE && !file. Just we need to ensure we use the same file which was deny_write_access()'ed, so the patch also moves "file = vma->vm_file" down after allow_write_access(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Colin Cross <ccross@android.com> Cc: David Rientjes <rientjes@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11mm: do_mmap_pgoff: cleanup the usage of file_inode()Oleg Nesterov
Simple cleanup. Move "struct inode *inode" variable into "if (file)" block to simplify the code and avoid the unnecessary check. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Colin Cross <ccross@android.com> Cc: David Rientjes <rientjes@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11mm: shift VM_GROWS* check from mmap_region() to do_mmap_pgoff()Oleg Nesterov
mmap() doesn't allow the non-anonymous mappings with VM_GROWS* bit set. In particular this means that mmap_region()->vma_merge(file, vm_flags) must always fail if "vm_flags & VM_GROWS" is set incorrectly. So it does not make sense to check VM_GROWS* after we already allocated the new vma, the only caller, do_mmap_pgoff(), which can pass this flag can do the check itself. And this looks a bit more correct, mmap_region() already unmapped the old mapping at this stage. But if mmap() is going to fail, it should avoid do_munmap() if possible. Note: we check VM_GROWS at the end to ensure that do_mmap_pgoff() won't return EINVAL in the case when it currently returns another error code. Many thanks to Hugh who nacked the buggy v1. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11mm: mempolicy: turn vma_set_policy() into vma_dup_policy()Oleg Nesterov
Simple cleanup. Every user of vma_set_policy() does the same work, this looks a bit annoying imho. And the new trivial helper which does mpol_dup() + vma_set_policy() to simplify the callers. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-16Fix TLB gather virtual address range invalidation corner casesLinus Torvalds
Ben Tebulin reported: "Since v3.7.2 on two independent machines a very specific Git repository fails in 9/10 cases on git-fsck due to an SHA1/memory failures. This only occurs on a very specific repository and can be reproduced stably on two independent laptops. Git mailing list ran out of ideas and for me this looks like some very exotic kernel issue" and bisected the failure to the backport of commit 53a59fc67f97 ("mm: limit mmu_gather batching to fix soft lockups on !CONFIG_PREEMPT"). That commit itself is not actually buggy, but what it does is to make it much more likely to hit the partial TLB invalidation case, since it introduces a new case in tlb_next_batch() that previously only ever happened when running out of memory. The real bug is that the TLB gather virtual memory range setup is subtly buggered. It was introduced in commit 597e1c3580b7 ("mm/mmu_gather: enable tlb flush range in generic mmu_gather"), and the range handling was already fixed at least once in commit e6c495a96ce0 ("mm: fix the TLB range flushed when __tlb_remove_page() runs out of slots"), but that fix was not complete. The problem with the TLB gather virtual address range is that it isn't set up by the initial tlb_gather_mmu() initialization (which didn't get the TLB range information), but it is set up ad-hoc later by the functions that actually flush the TLB. And so any such case that forgot to update the TLB range entries would potentially miss TLB invalidates. Rather than try to figure out exactly which particular ad-hoc range setup was missing (I personally suspect it's the hugetlb case in zap_huge_pmd(), which didn't have the same logic as zap_pte_range() did), this patch just gets rid of the problem at the source: make the TLB range information available to tlb_gather_mmu(), and initialize it when initializing all the other tlb gather fields. This makes the patch larger, but conceptually much simpler. And the end result is much more understandable; even if you want to play games with partial ranges when invalidating the TLB contents in chunks, now the range information is always there, and anybody who doesn't want to bother with it won't introduce subtle bugs. Ben verified that this fixes his problem. Reported-bisected-and-tested-by: Ben Tebulin <tebulin@googlemail.com> Build-testing-by: Stephen Rothwell <sfr@canb.auug.org.au> Build-testing-by: Richard Weinberger <richard.weinberger@gmail.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-31mm: mempolicy: fix mbind_range() && vma_adjust() interactionOleg Nesterov
vma_adjust() does vma_set_policy(vma, vma_policy(next)) and this is doubly wrong: 1. This leaks vma->vm_policy if it is not NULL and not equal to next->vm_policy. This can happen if vma_merge() expands "area", not prev (case 8). 2. This sets the wrong policy if vma_merge() joins prev and area, area is the vma the caller needs to update and it still has the old policy. Revert commit 1444f92c8498 ("mm: merging memory blocks resets mempolicy") which introduced these problems. Change mbind_range() to recheck mpol_equal() after vma_merge() to fix the problem that commit tried to address. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Steven T Hampson <steven.t.hampson@intel.com> Cc: Mel Gorman <mgorman@suse.de> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-10mm: remove free_area_cacheMichel Lespinasse
Since all architectures have been converted to use vm_unmapped_area(), there is no remaining use for the free_area_cache. Signed-off-by: Michel Lespinasse <walken@google.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: Helge Deller <deller@gmx.de> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09ipc/shmc.c: eliminate ugly 80-col tricksAndrew Morton
2013-07-09mmap: allow MAP_HUGETLB for hugetlbfs files v2Jörn Engel
It is counterintuitive at best that mmap'ing a hugetlbfs file with MAP_HUGETLB fails, while mmap'ing it without will a) succeed and b) return huge pages. v2: use is_file_hugepages(), as suggested by Jianguo Signed-off-by: Joern Engel <joern@logfs.org> Cc: Jianguo Wu <wujianguo@huawei.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm: use vma_pages() to replace (vm_end - vm_start) >> PAGE_SHIFTLibin
(*->vm_end - *->vm_start) >> PAGE_SHIFT operation is implemented as a inline funcion vma_pages() in linux/mm.h, so using it. Signed-off-by: Libin <huawei.libin@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-09shm: fix null pointer deref when userspace specifies invalid hugepage sizeLi Zefan
Dave reported an oops triggered by trinity: BUG: unable to handle kernel NULL pointer dereference at 0000000000000008 IP: newseg+0x10d/0x390 PGD cf8c1067 PUD cf8c2067 PMD 0 Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC CPU: 2 PID: 7636 Comm: trinity-child2 Not tainted 3.9.0+#67 ... Call Trace: ipcget+0x182/0x380 SyS_shmget+0x5a/0x60 tracesys+0xdd/0xe2 This bug was introduced by commit af73e4d9506d ("hugetlbfs: fix mmap failure in unaligned size request"). Reported-by: Dave Jones <davej@redhat.com> Cc: <stable@vger.kernel.org> Signed-off-by: Li Zefan <lizfan@huawei.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07hugetlbfs: fix mmap failure in unaligned size requestNaoya Horiguchi
The current kernel returns -EINVAL unless a given mmap length is "almost" hugepage aligned. This is because in sys_mmap_pgoff() the given length is passed to vm_mmap_pgoff() as it is without being aligned with hugepage boundary. This is a regression introduced in commit 40716e29243d ("hugetlbfs: fix alignment of huge page requests"), where alignment code is pushed into hugetlb_file_setup() and the variable len in caller side is not changed. To fix this, this patch partially reverts that commit, and adds alignment code in caller side. And it also introduces hstate_sizelog() in order to get proper hstate to specified hugepage size. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=56881 [akpm@linux-foundation.org: fix warning when CONFIG_HUGETLB_PAGE=n] Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reported-by: <iceman_dvd@yahoo.com> Cc: Steven Truelove <steven.truelove@utoronto.ca> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Hugh Dickins <hughd@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29mm/mmap: check for RLIMIT_AS before unmappingCyril Hrubis
Fix a corner case for MAP_FIXED when requested mapping length is larger than rlimit for virtual memory. In such case any overlapping mappings are unmapped before we check for the limit and return ENOMEM. The check is moved before the loop that unmaps overlapping parts of existing mappings. When we are about to hit the limit (currently mapped pages + len > limit) we scan for overlapping pages and check again accounting for them. This fixes situation when userspace program expects that the previous mappings are preserved after the mmap() syscall has returned with error. (POSIX clearly states that successfull mapping shall replace any previous mappings.) This corner case was found and can be tested with LTP testcase: testcases/open_posix_testsuite/conformance/interfaces/mmap/24-2.c In this case the mmap, which is clearly over current limit, unmaps dynamic libraries and the testcase segfaults right after returning into userspace. I've also looked at the second instance of the unmapping loop in the do_brk(). The do_brk() is called from brk() syscall and from vm_brk(). The brk() syscall checks for overlapping mappings and bails out when there are any (so it can't be triggered from the brk syscall). The vm_brk() is called only from binmft handlers so it shouldn't be triggered unless binmft handler created overlapping mappings. Signed-off-by: Cyril Hrubis <chrubis@suse.cz> Reviewed-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29mm: reinititalise user and admin reserves if memory is added or removedAndrew Shewmaker
Alter the admin and user reserves of the previous patches in this series when memory is added or removed. If memory is added and the reserves have been eliminated or increased above the default max, then we'll trust the admin. If memory is removed and there isn't enough free memory, then we need to reset the reserves. Otherwise keep the reserve set by the admin. The reserve reset code is the same as the reserve initialization code. I tested hot addition and removal by triggering it via sysfs. The reserves shrunk when they were set high and memory was removed. They were reset higher when memory was added again. [akpm@linux-foundation.org: use register_hotmemory_notifier()] [akpm@linux-foundation.org: init_user_reserve() and init_admin_reserve can no longer be __meminit] [fengguang.wu@intel.com: make init_reserve_notifier() static] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Andrew Shewmaker <agshew@gmail.com> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29mm: replace hardcoded 3% with admin_reserve_pages knobAndrew Shewmaker
Add an admin_reserve_kbytes knob to allow admins to change the hardcoded memory reserve to something other than 3%, which may be multiple gigabytes on large memory systems. Only about 8MB is necessary to enable recovery in the default mode, and only a few hundred MB are required even when overcommit is disabled. This affects OVERCOMMIT_GUESS and OVERCOMMIT_NEVER. admin_reserve_kbytes is initialized to min(3% free pages, 8MB) I arrived at 8MB by summing the RSS of sshd or login, bash, and top. Please see first patch in this series for full background, motivation, testing, and full changelog. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: make init_admin_reserve() static] Signed-off-by: Andrew Shewmaker <agshew@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
