path: root/mm/mmu_context.c
2010-01-15mm: export use_mm/unuse_mm to modulesMichael S. Tsirkin
vhost net module wants to do copy to/from user from a kernel thread, which needs use_mm. Export it to modules. Acked-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-22mm: reduce atomic use on use_mm fast pathMichael S. Tsirkin
When the mm being switched to matches the active mm, we don't need to increment and then drop the mm count. In a simple benchmark this happens in about 50% of time. Making that conditional reduces contention on that cacheline on SMP systems. Acked-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: move use_mm/unuse_mm from aio.c to mm/Michael S. Tsirkin
Anyone who wants to do copy to/from user from a kernel thread, needs use_mm (like what fs/aio has). Move that into mm/, to make reusing and exporting easier down the line, and make aio use it. Next intended user, besides aio, will be vhost-net. Acked-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
