path: root/mm/mmu_context.c
2013-05-07mm: remove old aio use_mm() commentZach Brown
Bunch of performance improvements and cleanups Zach Brown and I have been working on. The code should be pretty solid at this point, though it could of course use more review and testing. The results in my testing are pretty impressive, particularly when an ioctx is being shared between multiple threads. In my crappy synthetic benchmark, with 4 threads submitting and one thread reaping completions, I saw overhead in the aio code go from ~50% (mostly ioctx lock contention) to low single digits. Performance with ioctx per thread improved too, but I'd have to rerun those benchmarks. The reason I've been focused on performance when the ioctx is shared is that for a fair number of real world completions, userspace needs the completions aggregated somehow - in practice people just end up implementing this aggregation in userspace today, but if it's done right we can do it much more efficiently in the kernel. Performance wise, the end result of this patch series is that submitting a kiocb writes to _no_ shared cachelines - the penalty for sharing an ioctx is gone there. There's still going to be some cacheline contention when we deliver the completions to the aio ringbuffer (at least if you have interrupts being delivered on multiple cores, which for high end stuff you do) but I have a couple more patches not in this series that implement coalescing for that (by taking advantage of interrupt coalescing). With that, there's basically no bottlenecks or performance issues to speak of in the aio code. This patch: use_mm() is used in more places than just aio. There's no need to mention callers when describing the function. Signed-off-by: Zach Brown <zab@redhat.com> Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Acked-by: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21mm, counters: remove task argument to sync_mm_rss() and __sync_task_rss_stat()David Rientjes
sync_mm_rss() can only be used for current to avoid race conditions in iterating and clearing its per-task counters. Remove the task argument for it and its helper function, __sync_task_rss_stat(), to avoid thinking it can be used safely for anything other than current. Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31mm: Map most files to use export.h instead of module.hPaul Gortmaker
The files changed within are only using the EXPORT_SYMBOL macro variants. They are not using core modular infrastructure and hence don't need module.h but only the export.h header. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2010-03-24exit: fix oops in sync_mm_rssMichael S. Tsirkin
In 2.6.34-rc1, removing vhost_net module causes an oops in sync_mm_rss (called from do_exit) when workqueue is destroyed. This does not happen on net-next, or with vhost on top of to 2.6.33. The issue seems to be introduced by 34e55232e59f7b19050267a05ff1226e5cd122a5 ("mm: avoid false sharing of mm_counter) which added sync_mm_rss() that is passed task->mm, and dereferences it without checking. If task is a kernel thread, mm might be NULL. I think this might also happen e.g. with aio. This patch fixes the oops by calling sync_mm_rss when task->mm is set to NULL. I also added BUG_ON to detect any other cases where counters get incremented while mm is NULL. The oops I observed looks like this: BUG: unable to handle kernel NULL pointer dereference at 00000000000002a8 IP: [<ffffffff810b436d>] sync_mm_rss+0x33/0x6f PGD 0 Oops: 0002 [#1] SMP last sysfs file: /sys/devices/system/cpu/cpu7/cache/index2/shared_cpu_map CPU 2 Modules linked in: vhost_net(-) tun bridge stp sunrpc ipv6 cpufreq_ondemand acpi_cpufreq freq_table kvm_intel kvm i5000_edac edac_core rtc_cmos bnx2 button i2c_i801 i2c_core rtc_core e1000e sg joydev ide_cd_mod serio_raw pcspkr rtc_lib cdrom virtio_net virtio_blk virtio_pci virtio_ring virtio af_packet e1000 shpchp aacraid uhci_hcd ohci_hcd ehci_hcd [last unloaded: microcode] Pid: 2046, comm: vhost Not tainted 2.6.34-rc1-vhost #25 System Planar/IBM System x3550 -[7978B3G]- RIP: 0010:[<ffffffff810b436d>] [<ffffffff810b436d>] sync_mm_rss+0x33/0x6f RSP: 0018:ffff8802379b7e60 EFLAGS: 00010202 RAX: 0000000000000008 RBX: ffff88023f2390c0 RCX: 0000000000000000 RDX: ffff88023f2396b0 RSI: 0000000000000000 RDI: ffff88023f2390c0 RBP: ffff8802379b7e60 R08: 0000000000000000 R09: 0000000000000000 R10: ffff88023aecfbc0 R11: 0000000000013240 R12: 0000000000000000 R13: ffffffff81051a6c R14: ffffe8ffffc0f540 R15: 0000000000000000 FS: 0000000000000000(0000) GS:ffff880001e80000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 00000000000002a8 CR3: 000000023af23000 CR4: 00000000000406e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process vhost (pid: 2046, threadinfo ffff8802379b6000, task ffff88023f2390c0) Stack: ffff8802379b7ee0 ffffffff81040687 ffffe8ffffc0f558 ffffffffa00a3e2d <0> 0000000000000000 ffff88023f2390c0 ffffffff81055817 ffff8802379b7e98 <0> ffff8802379b7e98 0000000100000286 ffff8802379b7ee0 ffff88023ad47d78 Call Trace: [<ffffffff81040687>] do_exit+0x147/0x6c4 [<ffffffffa00a3e2d>] ? handle_rx_net+0x0/0x17 [vhost_net] [<ffffffff81055817>] ? autoremove_wake_function+0x0/0x39 [<ffffffff81051a6c>] ? worker_thread+0x0/0x229 [<ffffffff810553c9>] kthreadd+0x0/0xf2 [<ffffffff810038d4>] kernel_thread_helper+0x4/0x10 [<ffffffff81055342>] ? kthread+0x0/0x87 [<ffffffff810038d0>] ? kernel_thread_helper+0x0/0x10 Code: 00 8b 87 6c 02 00 00 85 c0 74 14 48 98 f0 48 01 86 a0 02 00 00 c7 87 6c 02 00 00 00 00 00 00 8b 87 70 02 00 00 85 c0 74 14 48 98 <f0> 48 01 86 a8 02 00 00 c7 87 70 02 00 00 00 00 00 00 8b 87 74 RIP [<ffffffff810b436d>] sync_mm_rss+0x33/0x6f RSP <ffff8802379b7e60> CR2: 00000000000002a8 ---[ end trace 41603ba922beddd2 ]--- Fixing recursive fault but reboot is needed! (note: handle_rx_net is a work item using workqueue in question). sync_mm_rss+0x33/0x6f gave me a hint. I also tried reverting 34e55232e59f7b19050267a05ff1226e5cd122a5 and the oops goes away. The module in question calls use_mm and later unuse_mm from a kernel thread. It is when this kernel thread is destroyed that the crash happens. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-15mm: export use_mm/unuse_mm to modulesMichael S. Tsirkin
vhost net module wants to do copy to/from user from a kernel thread, which needs use_mm. Export it to modules. Acked-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-22mm: reduce atomic use on use_mm fast pathMichael S. Tsirkin
When the mm being switched to matches the active mm, we don't need to increment and then drop the mm count. In a simple benchmark this happens in about 50% of time. Making that conditional reduces contention on that cacheline on SMP systems. Acked-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: move use_mm/unuse_mm from aio.c to mm/Michael S. Tsirkin
Anyone who wants to do copy to/from user from a kernel thread, needs use_mm (like what fs/aio has). Move that into mm/, to make reusing and exporting easier down the line, and make aio use it. Next intended user, besides aio, will be vhost-net. Acked-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
