path: root/mm/nommu.c
2006-03-22[PATCH] mm: nommu use compound pagesNick Piggin
Now that compound page handling is properly fixed in the VM, move nommu over to using compound pages rather than rolling their own refcounting. nommu vm page refcounting is broken anyway, but there is no need to have divergent code in the core VM now, nor when it gets fixed. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: David Howells <dhowells@redhat.com> (Needs testing, please). Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-28[PATCH] nommu: implement vmalloc_node()Andrew Morton
Fix oprofile linkage. Pointed out by "Luke Yang" <luke.adi@gmail.com>. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-20[PATCH] Fix undefined symbols for nommu architectureLuke Yang
Signed-off-by: Luke Yang <luke.adi@gmail.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] NOMMU: Make SYSV IPC SHM use ramfs facilities on NOMMUDavid Howells
The attached patch makes the SYSV IPC shared memory facilities use the new ramfs facilities on a no-MMU kernel. The following changes are made: (1) There are now shmem_mmap() and shmem_get_unmapped_area() functions to allow the IPC SHM facilities to commune with the tiny-shmem and shmem code. (2) ramfs files now need resizing using do_truncate() rather than by modifying the inode size directly (see shmem_file_setup()). This causes ramfs to attempt to bind a block of pages of sufficient size to the inode. (3) CONFIG_SYSVIPC is no longer contingent on CONFIG_MMU. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-28mm: re-architect the VM_UNPAGED logicLinus Torvalds
This replaces the (in my opinion horrible) VM_UNMAPPED logic with very explicit support for a "remapped page range" aka VM_PFNMAP. It allows a VM area to contain an arbitrary range of page table entries that the VM never touches, and never considers to be normal pages. Any user of "remap_pfn_range()" automatically gets this new functionality, and doesn't even have to mark the pages reserved or indeed mark them any other way. It just works. As a side effect, doing mmap() on /dev/mem works for arbitrary ranges. Sparc update from David in the next commit. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] mm/{mmap,nommu}.c: several unexportsAdrian Bunk
I didn't find any possible modular usage in the kernel. This patch was already ACK'ed by Christoph Hellwig. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: follow_page with inner ptlockHugh Dickins
Final step in pushing down common core's page_table_lock. follow_page no longer wants caller to hold page_table_lock, uses pte_offset_map_lock itself; and so no page_table_lock is taken in get_user_pages itself. But get_user_pages (and get_futex_key) do then need follow_page to pin the page for them: take Daniel's suggestion of bitflags to follow_page. Need one for WRITE, another for TOUCH (it was the accessed flag before: vanished along with check_user_page_readable, but surely get_numa_maps is wrong to mark every page it finds as accessed), another for GET. And another, ANON to dispose of untouched_anonymous_page: it seems silly for that to descend a second time, let follow_page observe if there was no page table and return ZERO_PAGE if so. Fix minor bug in that: check VM_LOCKED - make_pages_present ought to make readonly anonymous present. Give get_numa_maps a cond_resched while we're there. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: update_hiwaters just in timeHugh Dickins
update_mem_hiwater has attracted various criticisms, in particular from those concerned with mm scalability. Originally it was called whenever rss or total_vm got raised. Then many of those callsites were replaced by a timer tick call from account_system_time. Now Frank van Maarseveen reports that to be found inadequate. How about this? Works for Frank. Replace update_mem_hiwater, a poor combination of two unrelated ops, by macros update_hiwater_rss and update_hiwater_vm. Don't attempt to keep mm->hiwater_rss up to date at timer tick, nor every time we raise rss (usually by 1): those are hot paths. Do the opposite, update only when about to lower rss (usually by many), or just before final accounting in do_exit. Handle mm->hiwater_vm in the same way, though it's much less of an issue. Demand that whoever collects these hiwater statistics do the work of taking the maximum with rss or total_vm. And there has been no collector of these hiwater statistics in the tree. The new convention needs an example, so match Frank's usage by adding a VmPeak line above VmSize to /proc/<pid>/status, and also a VmHWM line above VmRSS (High-Water-Mark or High-Water-Memory). There was a particular anomaly during mremap move, that hiwater_vm might be captured too high. A fleeting such anomaly remains, but it's quickly corrected now, whereas before it would stick. What locking? None: if the app is racy then these statistics will be racy, it's not worth any overhead to make them exact. But whenever it suits, hiwater_vm is updated under exclusive mmap_sem, and hiwater_rss under page_table_lock (for now) or with preemption disabled (later on): without going to any trouble, minimize the time between reading current values and updating, to minimize those occasions when a racing thread bumps a count up and back down in between. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: rss = file_rss + anon_rssHugh Dickins
I was lazy when we added anon_rss, and chose to change as few places as possible. So currently each anonymous page has to be counted twice, in rss and in anon_rss. Which won't be so good if those are atomic counts in some configurations. Change that around: keep file_rss and anon_rss separately, and add them together (with get_mm_rss macro) when the total is needed - reading two atomics is much cheaper than updating two atomics. And update anon_rss upfront, typically in memory.c, not tucked away in page_add_anon_rmap. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-11[PATCH] uclinux: add NULL check, 0 end valid check and some more exports to ↵Greg Ungerer
nommu.c Move call to get_mm_counter() in update_mem_hiwater() to be inside the check for tsk->mm being null. Otherwise you can be following a null pointer here. This patch submitted by Javier Herrero <jherrero@hvsistemas.es>. Modify the end check for munmap regions to allow for the legacy behavior of 0 being valid. Pretty much all current uClinux system libc malloc's pass in 0 as the end point. A hard check will fail on these, so change the check so that if it is non-zero it must be valid otherwise it fails. A passed in value will always succeed (as it used too). Also export a few more mm system functions - to be consistent with the VM code exports. Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-04[PATCH] __vm_enough_memory() signedness fixSimon Derr
We have found what seems to be a small bug in __vm_enough_memory() when sysctl_overcommit_memory is set to OVERCOMMIT_NEVER. When this bug occurs the systems fails to boot, with /sbin/init whining about fork() returning ENOMEM. We hunted down the problem to this: The deferred update mecanism used in vm_acct_memory(), on a SMP system, allows the vm_committed_space counter to have a negative value. This should not be a problem since this counter is known to be inaccurate. But in __vm_enough_memory() this counter is compared to the `allowed' variable, which is an unsigned long. This comparison is broken since it will consider the negative values of vm_committed_space to be huge positive values, resulting in a memory allocation failure. Signed-off-by: <Jean-Marc.Saffroy@ext.bull.net> Signed-off-by: <Simon.Derr@bull.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] Avoiding mmap fragmentationWolfgang Wander
Ingo recently introduced a great speedup for allocating new mmaps using the free_area_cache pointer which boosts the specweb SSL benchmark by 4-5% and causes huge performance increases in thread creation. The downside of this patch is that it does lead to fragmentation in the mmap-ed areas (visible via /proc/self/maps), such that some applications that work fine under 2.4 kernels quickly run out of memory on any 2.6 kernel. The problem is twofold: 1) the free_area_cache is used to continue a search for memory where the last search ended. Before the change new areas were always searched from the base address on. So now new small areas are cluttering holes of all sizes throughout the whole mmap-able region whereas before small holes tended to close holes near the base leaving holes far from the base large and available for larger requests. 2) the free_area_cache also is set to the location of the last munmap-ed area so in scenarios where we allocate e.g. five regions of 1K each, then free regions 4 2 3 in this order the next request for 1K will be placed in the position of the old region 3, whereas before we appended it to the still active region 1, placing it at the location of the old region 2. Before we had 1 free region of 2K, now we only get two free regions of 1K -> fragmentation. The patch addresses thes issues by introducing yet another cache descriptor cached_hole_size that contains the largest known hole size below the current free_area_cache. If a new request comes in the size is compared against the cached_hole_size and if the request can be filled with a hole below free_area_cache the search is started from the base instead. The results look promising: Whereas 2.6.12-rc4 fragments quickly and my (earlier posted) leakme.c test program terminates after 50000+ iterations with 96 distinct and fragmented maps in /proc/self/maps it performs nicely (as expected) with thread creation, Ingo's test_str02 with 20000 threads requires 0.7s system time. Taking out Ingo's patch (un-patch available per request) by basically deleting all mentions of free_area_cache from the kernel and starting the search for new memory always at the respective bases we observe: leakme terminates successfully with 11 distinctive hardly fragmented areas in /proc/self/maps but thread creating is gringdingly slow: 30+s(!) system time for Ingo's test_str02 with 20000 threads. Now - drumroll ;-) the appended patch works fine with leakme: it ends with only 7 distinct areas in /proc/self/maps and also thread creation seems sufficiently fast with 0.71s for 20000 threads. Signed-off-by: Wolfgang Wander <wwc@rentec.com> Credit-to: "Richard Purdie" <rpurdie@rpsys.net> Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Acked-by: Ingo Molnar <mingo@elte.hu> (partly) Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] mm/nommu.c: try to fix __vmallocAdrian Bunk
Linus changed the second argument of __vmalloc from int to unsigned int breaking the compilation for CONFIG_MMU=n configurations (since he only changed vmalloc.c but not nommu.c). Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
