path: root/mm/nommu.c
2011-07-25mmap: fix and tidy up overcommit page arithmeticDmitry Fink
- shmem pages are not immediately available, but they are not potentially available either, even if we swap them out, they will just relocate from memory into swap, total amount of immediate and potentially available memory is not going to be affected, so we shouldn't count them as potentially free in the first place. - nr_free_pages() is not an expensive operation anymore, there is no need to split the decision making in two halves and repeat code. Signed-off-by: Dmitry Fink <dmitry.fink@palm.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-22Merge branch 'ptrace' of git://git.kernel.org/pub/scm/linux/kernel/git/oleg/miscLinus Torvalds
* 'ptrace' of git://git.kernel.org/pub/scm/linux/kernel/git/oleg/misc: (39 commits) ptrace: do_wait(traced_leader_killed_by_mt_exec) can block forever ptrace: fix ptrace_signal() && STOP_DEQUEUED interaction connector: add an event for monitoring process tracers ptrace: dont send SIGSTOP on auto-attach if PT_SEIZED ptrace: mv send-SIGSTOP from do_fork() to ptrace_init_task() ptrace_init_task: initialize child->jobctl explicitly has_stopped_jobs: s/task_is_stopped/SIGNAL_STOP_STOPPED/ ptrace: make former thread ID available via PTRACE_GETEVENTMSG after PTRACE_EVENT_EXEC stop ptrace: wait_consider_task: s/same_thread_group/ptrace_reparented/ ptrace: kill real_parent_is_ptracer() in in favor of ptrace_reparented() ptrace: ptrace_reparented() should check same_thread_group() redefine thread_group_leader() as exit_signal >= 0 do not change dead_task->exit_signal kill task_detached() reparent_leader: check EXIT_DEAD instead of task_detached() make do_notify_parent() __must_check, update the callers __ptrace_detach: avoid task_detached(), check do_notify_parent() kill tracehook_notify_death() make do_notify_parent() return bool ptrace: s/tracehook_tracer_task()/ptrace_parent()/ ...
2011-07-08mm/nommu.c: fix remap_pfn_range()Bob Liu
remap_pfn_range() means map physical address pfn<<PAGE_SHIFT to user addr. For nommu arch it's implemented by vma->vm_start = pfn << PAGE_SHIFT which is wrong acroding the original meaning of this function. And some driver developer using remap_pfn_range() with correct parameter will get unexpected result because vm_start is changed. It should be implementd like addr = pfn << PAGE_SHIFT but which is meanless on nommu arch, this patch just make it simply return. Parameter name and setting of vma->vm_flags also be fixed. Signed-off-by: Bob Liu <lliubbo@gmail.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: David Howells <dhowells@redhat.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Bob Liu <lliubbo@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-22ptrace: kill trivial tracehooksTejun Heo
At this point, tracehooks aren't useful to mainline kernel and mostly just add an extra layer of obfuscation. Although they have comments, without actual in-kernel users, it is difficult to tell what are their assumptions and they're actually trying to achieve. To mainline kernel, they just aren't worth keeping around. This patch kills the following trivial tracehooks. * Ones testing whether task is ptraced. Replace with ->ptrace test. tracehook_expect_breakpoints() tracehook_consider_ignored_signal() tracehook_consider_fatal_signal() * ptrace_event() wrappers. Call directly. tracehook_report_exec() tracehook_report_exit() tracehook_report_vfork_done() * ptrace_release_task() wrapper. Call directly. tracehook_finish_release_task() * noop tracehook_prepare_release_task() tracehook_report_death() This doesn't introduce any behavior change. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Christoph Hellwig <hch@infradead.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com>
2011-05-25nommu: add page alignment to mmapBob Liu
Currently on nommu arch mmap(),mremap() and munmap() doesn't do page_align() which isn't consist with mmu arch and cause some issues. First, some drivers' mmap() function depends on vma->vm_end - vma->start is page aligned which is true on mmu arch but not on nommu. eg: uvc camera driver. Second munmap() may return -EINVAL[split file] error in cases when end is not page aligned(passed into from userspace) but vma->vm_end is aligned dure to split or driver's mmap() ops. Add page alignment to fix those issues. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Bob Liu <lliubbo@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Greg Ungerer <gerg@snapgear.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: nommu: fix a compile warning in do_mmap_pgoff()Namhyung Kim
Because 'ret' is declared as int, not unsigned long, no need to cast the error contants into unsigned long. If you compile this code on a 64-bit machine somehow, you'll see following warning: CC mm/nommu.o mm/nommu.c: In function `do_mmap_pgoff': mm/nommu.c:1411: warning: overflow in implicit constant conversion Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: David Howells <dhowells@redhat.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: nommu: fix a potential memory leak in do_mmap_private()Namhyung Kim
If f_op->read() fails and sysctl_nr_trim_pages > 1, there could be a memory leak between @region->vm_end and @region->vm_top. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: David Howells <dhowells@redhat.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: nommu: check the vma list when unmapping file-mapped vmaNamhyung Kim
Now we have the sorted vma list, use it in do_munmap() to check that we have an exact match. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: David Howells <dhowells@redhat.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: nommu: find vma using the sorted vma listNamhyung Kim
Now we have the sorted vma list, use it in the find_vma[_exact]() rather than doing linear search on the rb-tree. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: David Howells <dhowells@redhat.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: nommu: don't scan the vma list when deletingNamhyung Kim
Since commit 297c5eee3724 ("mm: make the vma list be doubly linked") made it a doubly linked list, we don't need to scan the list when deleting @vma. And the original code didn't update the prev pointer. Fix it too. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: David Howells <dhowells@redhat.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: nommu: sort mm->mmap list properlyNamhyung Kim
When I was reading nommu code, I found that it handles the vma list/tree in an unusual way. IIUC, because there can be more than one identical/overrapped vmas in the list/tree, it sorts the tree more strictly and does a linear search on the tree. But it doesn't applied to the list (i.e. the list could be constructed in a different order than the tree so that we can't use the list when finding the first vma in that order). Since inserting/sorting a vma in the tree and link is done at the same time, we can easily construct both of them in the same order. And linear searching on the tree could be more costly than doing it on the list, it can be converted to use the list. Also, after the commit 297c5eee3724 ("mm: make the vma list be doubly linked") made the list be doubly linked, there were a couple of code need to be fixed to construct the list properly. Patch 1/6 is a preparation. It maintains the list sorted same as the tree and construct doubly-linked list properly. Patch 2/6 is a simple optimization for the vma deletion. Patch 3/6 and 4/6 convert tree traversal to list traversal and the rest are simple fixes and cleanups. This patch: @vma added into @mm should be sorted by start addr, end addr and VMA struct addr in that order because we may get identical VMAs in the @mm. However this was true only for the rbtree, not for the list. This patch fixes this by remembering 'rb_prev' during the tree traversal like find_vma_prepare() does and linking the @vma via __vma_link_list(). After this patch, we can iterate the whole VMAs in correct order simply by using @mm->mmap list. [akpm@linux-foundation.org: avoid duplicating __vma_link_list()] Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: David Howells <dhowells@redhat.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25arch, mm: filter disallowed nodes from arch specific show_mem functionsDavid Rientjes
Architectures that implement their own show_mem() function did not pass the filter argument to show_free_areas() to appropriately avoid emitting the state of nodes that are disallowed in the current context. This patch now passes the filter argument to show_free_areas() so those nodes are now avoided. This patch also removes the show_free_areas() wrapper around __show_free_areas() and converts existing callers to pass an empty filter. ia64 emits additional information for each node, so skip_free_areas_zone() must be made global to filter disallowed nodes and it is converted to use a nid argument rather than a zone for this use case. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Helge Deller <deller@gmx.de> Cc: James Bottomley <jejb@parisc-linux.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-29NOMMU: implement access_remote_vmMike Frysinger
Recent vm changes brought in a new function which the core procfs code utilizes. So implement it for nommu systems too to avoid link failures. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Simon Horman <horms@verge.net.au> Tested-by: Ithamar Adema <ithamar.adema@team-embedded.nl> Acked-by: Greg Ungerer <gerg@uclinux.org>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-23mm: arch: rename in_gate_area_no_task to in_gate_area_no_mmStephen Wilson
Now that gate vma's are referenced with respect to a particular mm and not a particular task it only makes sense to propagate the change to this predicate as well. Signed-off-by: Stephen Wilson <wilsons@start.ca> Reviewed-by: Michel Lespinasse <walken@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-13mlock: do not hold mmap_sem for extended periods of timeMichel Lespinasse
__get_user_pages gets a new 'nonblocking' parameter to signal that the caller is prepared to re-acquire mmap_sem and retry the operation if needed. This is used to split off long operations if they are going to block on a disk transfer, or when we detect contention on the mmap_sem. [akpm@linux-foundation.org: remove ref to rwsem_is_contended()] Signed-off-by: Michel Lespinasse <walken@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Nick Piggin <npiggin@kernel.dk> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-24nommu: Provide stubbed alloc/free_vm_area() implementation.Paul Mundt
Now that these have been introduced in to the vmalloc API, sync up the nommu side of things. At present we don't deal with VMAs as such, so for the time being these will simply BUG() out. In the future it should be possible to support this interface by layering on top of the vm_regions. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-12-24nommu: Fix up vmalloc_node() symbol export regression.Paul Mundt
Commit e1ca778 ("mm: add vzalloc() and vzalloc_node() helpers") ended up accidentally deleting the vmalloc_node() symbol export, resulting in: "vmalloc_node" [net/core/pktgen.ko] undefined! "vmalloc_node" [net/netfilter/x_tables.ko] undefined! regressions. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-25nommu: yield CPU while disposing VMSteven J. Magnani
Depending on processor speed, page size, and the amount of memory a process is allowed to amass, cleanup of a large VM may freeze the system for many seconds. This can result in a watchdog timeout. Make sure other tasks receive some service when cleaning up large VMs. Signed-off-by: Steven J. Magnani <steve@digidescorp.com> Cc: Greg Ungerer <gerg@snapgear.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-30audit mmapAl Viro
Normal syscall audit doesn't catch 5th argument of syscall. It also doesn't catch the contents of userland structures pointed to be syscall argument, so for both old and new mmap(2) ABI it doesn't record the descriptor we are mapping. For old one it also misses flags. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-26mm: add vzalloc() and vzalloc_node() helpersDave Young
Add vzalloc() and vzalloc_node() to encapsulate the vmalloc-then-memset-zero operation. Use __GFP_ZERO to zero fill the allocated memory. Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Cc: Christoph Lameter <cl@linux-foundation.org> Acked-by: Greg Ungerer <gerg@snapgear.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-21mm: make the vma list be doubly linkedLinus Torvalds
It's a really simple list, and several of the users want to go backwards in it to find the previous vma. So rather than have to look up the previous entry with 'find_vma_prev()' or something similar, just make it doubly linked instead. Tested-by: Ian Campbell <ijc@hellion.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-13NOMMU: Remove an extraneous no_printk()David Howells
Remove an extraneous no_printk() in mm/nommu.c that got missed when the function got generalised from several things that used it in commit 12fdff3fc248 ("Add a dummy printk function for the maintenance of unused printks"). Without this, the following error is observed: mm/nommu.c:41: error: conflicting types for 'no_printk' include/linux/kernel.h:314: error: previous definition of 'no_printk' was here Reported-by: Michal Simek <monstr@monstr.eu> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-26nommu: allow private mappings of read-only devicesBernd Schmidt
Slightly rearrange the logic that determines capabilities and vm_flags. Disable BDI_CAP_MAP_DIRECT in all cases if the device can't support the protections. Allow private readonly mappings of readonly backing devices. Signed-off-by: Bernd Schmidt <bernds_cb1@t-online.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: David McCullough <davidm@snapgear.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: David Howells <dhowells@redhat.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-25NOMMU: Fix __get_user_pages() to pin last page on offset buffersDavid Howells
Fix __get_user_pages() to make it pin the last page on a buffer that doesn't begin at the start of a page, but is a multiple of PAGE_SIZE in size. The problem is that __get_user_pages() advances the pointer too much when it iterates to the next page if the page it's currently looking at isn't used from the first byte. This can cause the end of a short VMA to be reached prematurely, resulting in the last page being lost. Signed-off-by: Steven J. Magnani <steve@digidescorp.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-25NOMMU: Revert 'nommu: get_user_pages(): pin last page on non-page-aligned start'David Howells
Revert the following patch: commit c08c6e1f54c85fc299cf9f88cf330d6dd28a9a1d Author: Steven J. Magnani <steve@digidescorp.com> Date: Fri Mar 5 13:42:24 2010 -0800 nommu: get_user_pages(): pin last page on non-page-aligned start As it assumes that the mappings begin at the start of pages - something that isn't necessarily true on NOMMU systems. On NOMMU systems, it is possible for a mapping to only occupy part of the page, and not necessarily touch either end of it; in fact it's also possible for multiple non-overlapping mappings to coexist on one page (consider direct mappings of ROMFS files, for example). Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steven J. Magnani <steve@digidescorp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-24nommu: fix an incorrect comment in the do_mmap_shared_file()David Howells
Fix an incorrect comment in the do_mmap_shared_file(). If a mapping is requested MAP_SHARED, then a private copy cannot be made and still provide correct semantics. Signed-off-by: David Howells <dhowells@redhat.com> Reported-by: Dave Hudson <uclinux@blueteddy.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12Add generic sys_old_mmap()Christoph Hellwig
Add a generic implementation of the old mmap() syscall, which expects its argument in a memory block and switch all architectures over to use it. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: James Morris <jmorris@namei.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Ungerer <gerg@uclinux.org> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06nommu: get_user_pages(): pin last page on non-page-aligned startSteven J. Magnani
The noMMU version of get_user_pages() fails to pin the last page when the start address isn't page-aligned. The patch fixes this in a way that makes find_extend_vma() congruent to its MMU cousin. Signed-off-by: Steven J. Magnani <steve@digidescorp.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm: change anon_vma linking to fix multi-process server scalability issueRik van Riel
The old anon_vma code can lead to scalability issues with heavily forking workloads. Specifically, each anon_vma will be shared between the parent process and all its child processes. In a workload with 1000 child processes and a VMA with 1000 anonymous pages per process that get COWed, this leads to a system with a million anonymous pages in the same anon_vma, each of which is mapped in just one of the 1000 processes. However, the current rmap code needs to walk them all, leading to O(N) scanning complexity for each page. This can result in systems where one CPU is walking the page tables of 1000 processes in page_referenced_one, while all other CPUs are stuck on the anon_vma lock. This leads to catastrophic failure for a benchmark like AIM7, where the total number of processes can reach in the tens of thousands. Real workloads are still a factor 10 less process intensive than AIM7, but they are catching up. This patch changes the way anon_vmas and VMAs are linked, which allows us to associate multiple anon_vmas with a VMA. At fork time, each child process gets its own anon_vmas, in which its COWed pages will be instantiated. The parents' anon_vma is also linked to the VMA, because non-COWed pages could be present in any of the children. This reduces rmap scanning complexity to O(1) for the pages of the 1000 child processes, with O(N) complexity for at most 1/N pages in the system. This reduces the average scanning cost in heavily forking workloads from O(N) to 2. The only real complexity in this patch stems from the fact that linking a VMA to anon_vmas now involves memory allocations. This means vma_adjust can fail, if it needs to attach a VMA to anon_vma structures. This in turn means error handling needs to be added to the calling functions. A second source of complexity is that, because there can be multiple anon_vmas, the anon_vma linking in vma_adjust can no longer be done under "the" anon_vma lock. To prevent the rmap code from walking up an incomplete VMA, this patch introduces the VM_LOCK_RMAP VMA flag. This bit flag uses the same slot as the NOMMU VM_MAPPED_COPY, with an ifdef in mm.h to make sure it is impossible to compile a kernel that needs both symbolic values for the same bitflag. Some test results: Without the anon_vma changes, when AIM7 hits around 9.7k users (on a test box with 16GB RAM and not quite enough IO), the system ends up running >99% in system time, with every CPU on the same anon_vma lock in the pageout code. With these changes, AIM7 hits the cross-over point around 29.7k users. This happens with ~99% IO wait time, there never seems to be any spike in system time. The anon_vma lock contention appears to be resolved. [akpm@linux-foundation.org: cleanups] Signed-off-by: Rik van Riel <riel@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-16nommu: fix shared mmap after truncate shrinkage problemsDavid Howells
Fix a problem in NOMMU mmap with ramfs whereby a shared mmap can happen over the end of a truncation. The problem is that ramfs_nommu_check_mappings() checks that the reduced file size against the VMA tree, but not the vm_region tree. The following sequence of events can cause the problem: fd = open("/tmp/x", O_RDWR|O_TRUNC|O_CREAT, 0600); ftruncate(fd, 32 * 1024); a = mmap(NULL, 32 * 1024, PROT_READ|PROT_WRITE, MAP_SHARED, fd, 0); b = mmap(NULL, 16 * 1024, PROT_READ|PROT_WRITE, MAP_SHARED, fd, 0); munmap(a, 32 * 1024); ftruncate(fd, 16 * 1024); c = mmap(NULL, 32 * 1024, PROT_READ|PROT_WRITE, MAP_SHARED, fd, 0); Mapping 'a' creates a vm_region covering 32KB of the file. Mapping 'b' sees that the vm_region from 'a' is covering the region it wants and so shares it, pinning it in memory. Mapping 'a' then goes away and the file is truncated to the end of VMA 'b'. However, the region allocated by 'a' is still in effect, and has _not_ been reduced. Mapping 'c' is then created, and because there's a vm_region covering the desired region, get_unmapped_area() is _not_ called to repeat the check, and the mapping is granted, even though the pages from the latter half of the mapping have been discarded. However: d = mmap(NULL, 16 * 1024, PROT_READ|PROT_WRITE, MAP_SHARED, fd, 0); Mapping 'd' should work, and should end up sharing the region allocated by 'a'. To deal with this, we shrink the vm_region struct during the truncation, lest do_mmap_pgoff() take it as licence to share the full region automatically without calling the get_unmapped_area() file op again. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-16nommu: don't need get_unmapped_area() for NOMMUDavid Howells
get_unmapped_area() is unnecessary for NOMMU as no-one calls it. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-16nommu: remove a superfluous check of vm_region::vm_usageDavid Howells
In split_vma(), there's no need to check if the VMA being split has a region that's in use by more than one VMA because: (1) The preceding test prohibits splitting of non-anonymous VMAs and regions (eg: file or chardev backed VMAs). (2) Anonymous regions can't be mapped multiple times because there's no handle by which to refer to the already existing region. (3) If a VMA has previously been split, then the region backing it has also been split into two regions, each of usage 1. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-16nommu: struct vm_region's vm_usage count need not be atomicDavid Howells
The vm_usage count field in struct vm_region does not need to be atomic as it's only even modified whilst nommu_region_sem is write locked. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-06NOMMU: Use copy_*_user_page() in access_process_vm()Jie Zhang
The MMU code uses the copy_*_user_page() variants in access_process_vm() rather than copy_*_user() as the former includes an icache flush. This is important when doing things like setting software breakpoints with gdb. So switch the NOMMU code over to do the same. This patch makes the reasonable assumption that copy_from_user_page() won't fail - which is probably fine, as we've checked the VMA from which we're copying is usable, and the copy is not allowed to cross VMAs. The one case where it might go wrong is if the VMA is a device rather than RAM, and that device returns an error which - in which case rubbish will be returned rather than EIO. Signed-off-by: Jie Zhang <jie.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: David McCullough <david_mccullough@mcafee.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-06NOMMU: Avoiding duplicate icache flushes of shared mapsMike Frysinger
When working with FDPIC, there are many shared mappings of read-only code regions between applications (the C library, applet packages like busybox, etc.), but the current do_mmap_pgoff() function will issue an icache flush whenever a VMA is added to an MM instead of only doing it when the map is initially created. The flush can instead be done when a region is first mmapped PROT_EXEC. Note that we may not rely on the first mapping of a region being executable - it's possible for it to be PROT_READ only, so we have to remember whether we've flushed the region or not, and then flush the entire region when a bit of it is made executable. However, this also affects the brk area. That will no longer be executable. We can mprotect() it to PROT_EXEC on MPU-mode kernels, but for NOMMU mode kernels, when it increases the brk allocation, making sys_brk() flush the extra from the icache should suffice. The brk area probably isn't used by NOMMU programs since the brk area can only use up the leavings from the stack allocation, where the stack allocation is larger than requested. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-30mm: move sys_mmap_pgoff from util.cHugh Dickins
Move sys_mmap_pgoff() from mm/util.c to mm/mmap.c and mm/nommu.c, where we'd expect to find such code: especially now that it contains the MAP_HUGETLB handling. Revert mm/util.c to how it was in 2.6.32. This patch just ignores MAP_HUGETLB in the nommu case, as in 2.6.32, whereas 2.6.33-rc2 reported -ENOSYS. Perhaps validate_mmap_request() should reject it with -EINVAL? Add that later if necessary. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15nommu: fix malloc performance by adding uninitialized flagJie Zhang
The NOMMU code currently clears all anonymous mmapped memory. While this is what we want in the default case, all memory allocation from userspace under NOMMU has to go through this interface, including malloc() which is allowed to return uninitialized memory. This can easily be a significant performance penalty. So for constrained embedded systems were security is irrelevant, allow people to avoid clearing memory unnecessarily. This also alters the ELF-FDPIC binfmt such that it obtains uninitialised memory for the brk and stack region. Signed-off-by: Jie Zhang <jie.zhang@analog.com> Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-31NOMMU: Don't pass NULL pointers to fput() in do_mmap_pgoff()David Howells
Don't pass NULL pointers to fput() in the error handling paths of the NOMMU do_mmap_pgoff() as it can't handle it. The following can be used as a test program: int main() { static long long a[1024 * 1024 * 20] = { 0 }; return a;} Without the patch, the code oopses in atomic_long_dec_and_test() as called by fput() after the kernel complains that it can't allocate that big a chunk of memory. With the patch, the kernel just complains about the allocation size and then the program segfaults during execve() as execve() can't complete the allocation of all the new ELF program segments. Reported-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Robin Getz <rgetz@blackfin.uclinux.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-27const: mark struct vm_struct_operationsAlexey Dobriyan
* mark struct vm_area_struct::vm_ops as const * mark vm_ops in AGP code But leave TTM code alone, something is fishy there with global vm_ops being used. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24NOMMU: Ignore mmap() address param as it is a hintDavid Howells
Ignore the address parameter given to NOMMU mmap() as it is a hint, rather than giving an error if it's non-zero. MAP_FIXED still gets an error. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24NOMMU: Fix MAP_PRIVATE mmap() of objects where the data can be mapped directlyDavid Howells
Fix MAP_PRIVATE mmap() of files and devices where the data in the backing store might be mapped directly. Use the BDI_CAP_MAP_DIRECT capability flag to govern whether or not we should be trying to map a file directly. This can be used to determine whether or not a region has been filled in at the point where we call do_mmap_shared() or do_mmap_private(). The BDI_CAP_MAP_DIRECT capability flag is cleared by validate_mmap_request() if there's any reason we can't use it. It's also cleared in do_mmap_pgoff() if f_op->get_unmapped_area() fails. Without this fix, attempting to run a program from a RomFS image on a non-mappable MTD partition results in a BUG as the kernel attempts XIP, and this can be caught in gdb: Program received signal SIGABRT, Aborted. 0xc005dce8 in add_nommu_region (region=<value optimized out>) at mm/nommu.c:547 (gdb) bt #0 0xc005dce8 in add_nommu_region (region=<value optimized out>) at mm/nommu.c:547 #1 0xc005f168 in do_mmap_pgoff (file=0xc31a6620, addr=<value optimized out>, len=3808, prot=3, flags=6146, pgoff=0) at mm/nommu.c:1373 #2 0xc00a96b8 in elf_fdpic_map_file (params=0xc33fbbec, file=0xc31a6620, mm=0xc31bef60, what=0xc0213144 "executable") at mm.h:1145 #3 0xc00aa8b4 in load_elf_fdpic_binary (bprm=0xc316cb00, regs=<value optimized out>) at fs/binfmt_elf_fdpic.c:343 #4 0xc006b588 in search_binary_handler (bprm=0x6, regs=0xc33fbce0) at fs/exec.c:1234 #5 0xc006c648 in do_execve (filename=<value optimized out>, argv=0xc3ad14cc, envp=0xc3ad1460, regs=0xc33fbce0) at fs/exec.c:1356 #6 0xc0008cf0 in sys_execve (name=<value optimized out>, argv=0xc3ad14cc, envp=0xc3ad1460) at arch/frv/kernel/process.c:263 #7 0xc00075dc in __syscall_call () at arch/frv/kernel/entry.S:897 Note that this fix does the following commit differently: commit a190887b58c32d19c2eee007c5eb8faa970a69ba Author: David Howells <dhowells@redhat.com> Date: Sat Sep 5 11:17:07 2009 -0700 nommu: fix error handling in do_mmap_pgoff() Reported-by: Graff Yang <graff.yang@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24truncate: new helpersnpiggin@suse.de
Introduce new truncate helpers truncate_pagecache and inode_newsize_ok. vmtruncate is also consolidated from mm/memory.c and mm/nommu.c and into mm/truncate.c. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-09-23nommu: fix two build breakagesHugh Dickins
My 58fa879e1e640a1856f736b418984ebeccee1c95 "mm: FOLL flags for GUP flags" broke CONFIG_NOMMU build by forgetting to update nommu.c foll_flags type: mm/nommu.c:171: error: conflicting types for `__get_user_pages' mm/internal.h:254: error: previous declaration of `__get_user_pages' was here make[1]: *** [mm/nommu.o] Error 1 My 03f6462a3ae78f36eb1f0ee8b4d5ae2f7859c1d5 "mm: move highest_memmap_pfn" broke CONFIG_NOMMU build by forgetting to add a nommu.c highest_memmap_pfn: mm/built-in.o: In function `memmap_init_zone': (.meminit.text+0x326): undefined reference to `highest_memmap_pfn' mm/built-in.o: In function `memmap_init_zone': (.meminit.text+0x32d): undefined reference to `highest_memmap_pfn' Fix both breakages, and give myself 30 lashes (ouch!) Reported-by: Michal Simek <michal.simek@petalogix.com> Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22nommu: add support for Memory Protection Units (MPU)Bernd Schmidt
Some architectures (like the Blackfin arch) implement some of the "simpler" features that one would expect out of a MMU such as memory protection. In our case, we actually get read/write/exec protection down to the page boundary so processes can't stomp on each other let alone the kernel. There is a performance decrease (which depends greatly on the workload) however as the hardware/software interaction was not optimized at design time. Signed-off-by: Bernd Schmidt <bernds_cb1@t-online.de> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: FOLL flags for GUP flagsHugh Dickins
__get_user_pages() has been taking its own GUP flags, then processing them into FOLL flags for follow_page(). Though oddly named, the FOLL flags are more widely used, so pass them to __get_user_pages() now. Sorry, VM flags, VM_FAULT flags and FAULT_FLAGs are still distinct. (The patch to __get_user_pages() looks peculiar, with both gup_flags and foll_flags: the gup_flags remain constant; but as before there's an exceptional case, out of scope of the patch, in which foll_flags per page have FOLL_WRITE masked off.) Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Rik van Riel <riel@redhat.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: remove unused GUP flagsHugh Dickins
GUP_FLAGS_IGNORE_VMA_PERMISSIONS and GUP_FLAGS_IGNORE_SIGKILL were flags added solely to prevent __get_user_pages() from doing some of what it usually does, in the munlock case: we can now remove them. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Acked-by: Rik van Riel <riel@redhat.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: includecheck fix for mm/nommu.cJaswinder Singh Rajput
Fix the following 'make includecheck' warning: mm/nommu.c: internal.h is included more than once. Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Cc: David Howells <dhowells@redhat.com> Acked-by: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-05nommu: fix error handling in do_mmap_pgoff()David Howells
Fix the error handling in do_mmap_pgoff(). If do_mmap_shared_file() or do_mmap_private() fail, we jump to the error_put_region label at which point we cann __put_nommu_region() on the region - but we haven't yet added the region to the tree, and so __put_nommu_region() may BUG because the region tree is empty or it may corrupt the region tree. To get around this, we can afford to add the region to the region tree before calling do_mmap_shared_file() or do_mmap_private() as we keep nommu_region_sem write-locked, so no-one can race with us by seeing a transient region. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Mel Gorman <mel@csn.ul.ie> Acked-by: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
