commit 645d83c5db970a1c57225e155113b4aa2451e920 upstream.
Fix MAP_PRIVATE mmap() of files and devices where the data in the backing store
might be mapped directly. Use the BDI_CAP_MAP_DIRECT capability flag to govern
whether or not we should be trying to map a file directly. This can be used to
determine whether or not a region has been filled in at the point where we call
do_mmap_shared() or do_mmap_private().
The BDI_CAP_MAP_DIRECT capability flag is cleared by validate_mmap_request() if
there's any reason we can't use it. It's also cleared in do_mmap_pgoff() if
f_op->get_unmapped_area() fails.
Without this fix, attempting to run a program from a RomFS image on a
non-mappable MTD partition results in a BUG as the kernel attempts XIP, and
this can be caught in gdb:
Program received signal SIGABRT, Aborted.
0xc005dce8 in add_nommu_region (region=<value optimized out>) at mm/nommu.c:547
(gdb) bt
#0 0xc005dce8 in add_nommu_region (region=<value optimized out>) at mm/nommu.c:547
#1 0xc005f168 in do_mmap_pgoff (file=0xc31a6620, addr=<value optimized out>, len=3808, prot=3, flags=6146, pgoff=0) at mm/nommu.c:1373
#2 0xc00a96b8 in elf_fdpic_map_file (params=0xc33fbbec, file=0xc31a6620, mm=0xc31bef60, what=0xc0213144 "executable") at mm.h:1145
#3 0xc00aa8b4 in load_elf_fdpic_binary (bprm=0xc316cb00, regs=<value optimized out>) at fs/binfmt_elf_fdpic.c:343
#4 0xc006b588 in search_binary_handler (bprm=0x6, regs=0xc33fbce0) at fs/exec.c:1234
#5 0xc006c648 in do_execve (filename=<value optimized out>, argv=0xc3ad14cc, envp=0xc3ad1460, regs=0xc33fbce0) at fs/exec.c:1356
#6 0xc0008cf0 in sys_execve (name=<value optimized out>, argv=0xc3ad14cc, envp=0xc3ad1460) at arch/frv/kernel/process.c:263
#7 0xc00075dc in __syscall_call () at arch/frv/kernel/entry.S:897
Note that this fix does the following commit differently:
commit a190887b58c32d19c2eee007c5eb8faa970a69ba
Author: David Howells <dhowells@redhat.com>
Date: Sat Sep 5 11:17:07 2009 -0700
nommu: fix error handling in do_mmap_pgoff()
Reported-by: Graff Yang <graff.yang@gmail.com>
Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
Cc: Greg Ungerer <gerg@snapgear.com>
Fix the error handling in do_mmap_pgoff(). If do_mmap_shared_file() or
do_mmap_private() fail, we jump to the error_put_region label at which
point we cann __put_nommu_region() on the region - but we haven't yet
added the region to the tree, and so __put_nommu_region() may BUG
because the region tree is empty or it may corrupt the region tree.
To get around this, we can afford to add the region to the region tree
before calling do_mmap_shared_file() or do_mmap_private() as we keep
nommu_region_sem write-locked, so no-one can race with us by seeing a
transient region.
Acked-by: Paul Mundt <lethal@linux-sh.org>
Acked-by: Greg Ungerer <gerg@snapgear.com>
According to the POSIX (1003.1-2008), the file descriptor shall have been
opened with read permission, regardless of the protection options specified to
mmap(). The ltp test cases mmap06/07 need this.
Signed-off-by: Graff Yang <graff.yang@gmail.com>
Currently SELinux enforcement of controls on the ability to map low memory
is determined by the mmap_min_addr tunable. This patch causes SELinux to
ignore the tunable and instead use a seperate Kconfig option specific to how
much space the LSM should protect.
The tunable will now only control the need for CAP_SYS_RAWIO and SELinux
permissions will always protect the amount of low memory designated by
CONFIG_LSM_MMAP_MIN_ADDR.
This allows users who need to disable the mmap_min_addr controls (usual reason
being they run WINE as a non-root user) to do so and still have SELinux
controls preventing confined domains (like a web server) from being able to
map some area of low memory.
Signed-off-by: Eric Paris <eparis@redhat.com>
Signed-off-by: James Morris <jmorris@namei.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6:
sh: LCDC dcache flush for deferred io
sh: Fix compiler error and include the definition of IS_ERR_VALUE
sh: re-add LCDC fbdev support to the Migo-R defconfig
sh: fix se7724 ceu names
sh: ms7724se: Enable sh_eth in defconfig.
arch/sh/boards/mach-se/7206/io.c: Remove unnecessary semicolons
sh: ms7724se: Add sh_eth support
nommu: provide follow_pfn().
sh: Kill off unused DEBUG_BOOTMEM symbol.
perf_counter tools: add cpu_relax()/rmb() definitions for sh.
sh64: Hook up page fault events for software perf counters.
sh: Hook up page fault events for software perf counters.
sh: make set_perf_counter_pending() static inline.
clocksource: sh_tmu: Make undefined TCOR behaviour less undefined.
With the introduction of follow_pfn() as an exported symbol, modules have
begun making use of it. Unfortunately this was not reflected on nommu at
the time, so the in-tree users have subsequently all blown up with link
errors there.
This provides a simple follow_pfn() that just returns addr >> PAGE_SHIFT,
which will do the right thing on nommu. There is no need to do range
checking within the vma, as the find_vma() case will already take care of
this.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Currently the 4th parameter of get_user_pages() is called len, but its
in pages, not bytes. Rename the thing to nr_pages to avoid future
confusion.
With the "security: use mmap_min_addr indepedently of security models"
change, mmap_min_addr is used in common areas, which susbsequently blows
up the nommu build. This stubs in the definition in the nommu case as
well.
mm/nommu.c | 3 +++
1 file changed, 3 insertions(+)
Don't check vm_region::vm_start is page aligned in add_nommu_region() because
the region may reflect some non-page-aligned mapped file, such as could be
obtained from RomFS XIP.
Acked-by: Greg Ungerer <gerg@uclinux.org>
NOMMU mmap() has an option controlled by a sysctl variable that determines
whether the allocations made by do_mmap_private() should have the excess
space trimmed off and returned to the allocator. Make the initial setting
of this variable a Kconfig configuration option.
The reason there can be excess space is that the allocator only allocates
in power-of-2 size chunks, but mmap()'s can be made in sizes that aren't a
power of 2.
There are two alternatives:
(1) Keep the excess as dead space. The dead space then remains unused for the
lifetime of the mapping. Mappings of shared objects such as libc, ld.so
or busybox's text segment may retain their dead space forever.
(2) Return the excess to the allocator. This means that the dead space is
limited to less than a page per mapping, but it means that for a transient
process, there's more chance of fragmentation as the excess space may be
reused fairly quickly.
During the boot process, a lot of transient processes are created, and
this can cause a lot of fragmentation as the pagecache and various slabs
grow greatly during this time.
By turning off the trimming of excess space during boot and disabling
batching of frees, Coldfire can manage to boot.
A better way of doing things might be to have /sbin/init turn this option
off. By that point libc, ld.so and init - which are all long-duration
processes - have all been loaded and trimmed.
Reported-by: Lanttor Guo <lanttor.guo@freescale.com>
Tested-by: Lanttor Guo <lanttor.guo@freescale.com>
The Committed_AS field can underflow in certain situations:
> # while true; do cat /proc/meminfo | grep _AS; sleep 1; done | uniq -c
> 1 Committed_AS: 18446744073709323392 kB
> 11 Committed_AS: 18446744073709455488 kB
> 6 Committed_AS: 35136 kB
> 5 Committed_AS: 18446744073709454400 kB
> 7 Committed_AS: 35904 kB
> 3 Committed_AS: 18446744073709453248 kB
> 2 Committed_AS: 34752 kB
> 9 Committed_AS: 18446744073709453248 kB
> 8 Committed_AS: 34752 kB
> 3 Committed_AS: 18446744073709320960 kB
> 7 Committed_AS: 18446744073709454080 kB
> 5 Committed_AS: 18446744073709454080 kB
> 6 Committed_AS: 18446744073709320960 kB
Because NR_CPUS can be greater than 1000 and meminfo_proc_show() does
not check for underflow.
But NR_CPUS proportional isn't good calculation. In general,
possibility of lock contention is proportional to the number of online
cpus, not theorical maximum cpus (NR_CPUS).
The current kernel has generic percpu-counter stuff. using it is right
way. it makes code simplify and percpu_counter_read_positive() don't
make underflow issue.
Reported-by: Dave Hansen <dave@linux.vnet.ibm.com>
Cc: Eric B Munson <ebmunson@us.ibm.com>
Cc: <stable@kernel.org> [All kernel versions]
Fix a number of issues with the per-MM VMA patch:
(1) Make mmap_pages_allocated an atomic_long_t, just in case this is used on
a NOMMU system with more than 2G pages. Makes no difference on a 32-bit
system.
(2) Report vma->vm_pgoff * PAGE_SIZE as a 64-bit value, not a 32-bit value,
lest it overflow.
(3) Move the allocation of the vm_area_struct slab back for fork.c.
(4) Use KMEM_CACHE() for both vm_area_struct and vm_region slabs.
(5) Use BUG_ON() rather than if () BUG().
(6) Make the default validate_nommu_regions() a static inline rather than a
#define.
(7) Make free_page_series()'s objection to pages with a refcount != 1 more
informative.
(8) Adjust the __put_nommu_region() banner comment to indicate that the
semaphore must be held for writing.
(9) Limit the number of warnings about munmaps of non-mmapped regions.
Reported-by: Andrew Morton <akpm@linux-foundation.org>
This patch adds the name of the process to the bad allocation error
message on non-MMU systems.
Changed suggested by jsujjavanich@syntech-fuelmaster.com
Signed-off-by: Greg Ungerer <gerg@uclinux.org>
Presently we do not support these interfaces, so make them BUG() wrappers
as per the rest of the vmap interface on nommu. Fixes up the modular xfs
build.
Convert all system calls to return a long. This should be a NOP since all
converted types should have the same size anyway.
With the exception of sys_exit_group which returned void. But that doesn't
matter since the system call doesn't return.
Now that we no longer use compound pages for all large allocations,
kobjsize() actively breaks things like binfmt_flat by always handing
back PAGE_SIZE for mmap'ed regions. Fix this up by looking up the
VMA region for non-compounds.
Ideally binfmt_flat wants to get rid of kobjsize() completely, but
this is an incremental step.
Tested-by: Mike Frysinger <vapier.adi@gmail.com>
NOMMU mmap allocates a piece of memory for an mmap that's rounded up in size to
the nearest power-of-2 number of pages. Currently it then discards the excess
pages back to the page allocator, making that memory available for use by other
things. This can, however, cause greater amount of fragmentation.
To counter this, a sysctl is added in order to fine-tune the trimming
behaviour. The default behaviour remains to trim pages aggressively, while
this can either be disabled completely or set to a higher page-granular
watermark in order to have finer-grained control.
vm region vm_top bits taken from an earlier patch by David Howells.
Make VMAs per mm_struct as for MMU-mode linux. This solves two problems:
(1) In SYSV SHM where nattch for a segment does not reflect the number of
shmat's (and forks) done.
(2) In mmap() where the VMA's vm_mm is set to point to the parent mm by an
exec'ing process when VM_EXECUTABLE is specified, regardless of the fact
that a VMA might be shared and already have its vm_mm assigned to another
process or a dead process.
A new struct (vm_region) is introduced to track a mapped region and to remember
the circumstances under which it may be shared and the vm_list_struct structure
is discarded as it's no longer required.
This patch makes the following additional changes:
(1) Regions are now allocated with alloc_pages() rather than kmalloc() and
with no recourse to __GFP_COMP, so the pages are not composite. Instead,
each page has a reference on it held by the region. Anything else that is
interested in such a page will have to get a reference on it to retain it.
When the pages are released due to unmapping, each page is passed to
put_page() and will be freed when the page usage count reaches zero.
(2) Excess pages are trimmed after an allocation as the allocation must be
made as a power-of-2 quantity of pages.
(3) VMAs are added to the parent MM's R/B tree and mmap lists. As an MM may
end up with overlapping VMAs within the tree, the VMA struct address is
appended to the sort key.
(4) Non-anonymous VMAs are now added to the backing inode's prio list.
(5) Holes may be punched in anonymous VMAs with munmap(), releasing parts of
the backing region. The VMA and region structs will be split if
necessary.
(6) sys_shmdt() only releases one attachment to a SYSV IPC shared memory
segment instead of all the attachments at that addresss. Multiple
shmat()'s return the same address under NOMMU-mode instead of different
virtual addresses as under MMU-mode.
(7) Core dumping for ELF-FDPIC requires fewer exceptions for NOMMU-mode.
(8) /proc/maps is now the global list of mapped regions, and may list bits
that aren't actually mapped anywhere.
(9) /proc/meminfo gains a line (tagged "MmapCopy") that indicates the amount
of RAM currently allocated by mmap to hold mappable regions that can't be
mapped directly. These are copies of the backing device or file if not
anonymous.
These changes make NOMMU mode more similar to MMU mode. The downside is that
NOMMU mode requires some extra memory to track things over NOMMU without this
patch (VMAs are no longer shared, and there are now region structs).
Delete the askedalloc and realalloc variables as nothing actually uses the
value calculated.
We used to have rather schizophrenic set of checks for NULL ->i_op even
though it had been eliminated years ago. You'd need to go out of your
way to set it to NULL explicitly _and_ a bunch of code would die on
such inodes anyway. After killing two remaining places that still
did that bogosity, all that crap can go away.
Junjiro R. Okajima reported a problem where knfsd crashes if you are
using it to export shmemfs objects and run strict overcommit. In this
situation the current->mm based modifier to the overcommit goes through a
NULL pointer.
We could simply check for NULL and skip the modifier but we've caught
other real bugs in the past from mm being NULL here - cases where we did
need a valid mm set up (eg the exec bug about a year ago).
To preserve the checks and get the logic we want shuffle the checking
around and add a new helper to the vm_ security wrappers
Also fix a current->mm reference in nommu that should use the passed mm
[akpm@linux-foundation.org: fix build]
Reported-by: Junjiro R. Okajima <hooanon05@yahoo.co.jp>
Acked-by: James Morris <jmorris@namei.org>
Signed-off-by: Alan Cox <alan@redhat.com>
Make sure that mlocked pages also live on the unevictable LRU, so kswapd
will not scan them over and over again.
This is achieved through various strategies:
1) add yet another page flag--PG_mlocked--to indicate that
the page is locked for efficient testing in vmscan and,
optionally, fault path. This allows early culling of
unevictable pages, preventing them from getting to
page_referenced()/try_to_unmap(). Also allows separate
accounting of mlock'd pages, as Nick's original patch
did.
Note: Nick's original mlock patch used a PG_mlocked
flag. I had removed this in favor of the PG_unevictable
flag + an mlock_count [new page struct member]. I
restored the PG_mlocked flag to eliminate the new
count field.
2) add the mlock/unevictable infrastructure to mm/mlock.c,
with internal APIs in mm/internal.h. This is a rework
of Nick's original patch to these files, taking into
account that mlocked pages are now kept on unevictable
LRU list.
3) update vmscan.c:page_evictable() to check PageMlocked()
and, if vma passed in, the vm_flags. Note that the vma
will only be passed in for new pages in the fault path;
and then only if the "cull unevictable pages in fault
path" patch is included.
4) add try_to_unlock() to rmap.c to walk a page's rmap and
ClearPageMlocked() if no other vmas have it mlocked.
Reuses as much of try_to_unmap() as possible. This
effectively replaces the use of one of the lru list links
as an mlock count. If this mechanism let's pages in mlocked
vmas leak through w/o PG_mlocked set [I don't know that it
does], we should catch them later in try_to_unmap(). One
hopes this will be rare, as it will be relatively expensive.
Original mm/internal.h, mm/rmap.c and mm/mlock.c changes:
Signed-off-by: Nick Piggin <npiggin@suse.de>
splitlru: introduce __get_user_pages():
New munlock processing need to GUP_FLAGS_IGNORE_VMA_PERMISSIONS.
because current get_user_pages() can't grab PROT_NONE pages theresore it
cause PROT_NONE pages can't munlock.
[akpm@linux-foundation.org: fix this for pagemap-pass-mm-into-pagewalkers.patch]
[akpm@linux-foundation.org: untangle patch interdependencies]
[akpm@linux-foundation.org: fix things after out-of-order merging]
[hugh@veritas.com: fix page-flags mess]
[lee.schermerhorn@hp.com: fix munlock page table walk - now requires 'mm']
[kosaki.motohiro@jp.fujitsu.com: build fix]
[kosaki.motohiro@jp.fujitsu.com: fix truncate race and sevaral comments]
[kosaki.motohiro@jp.fujitsu.com: splitlru: introduce __get_user_pages()]
Signed-off-by: Rik van Riel <riel@redhat.com>
Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Nick Piggin <npiggin@suse.de>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Cc: Matt Mackall <mpm@selenic.com>
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Now that SH has switched to vmalloc_exec() for PAGE_KERNEL_EXEC usage,
it's apparent that nommu has no vmalloc_exec() definition of its own.
Stub in the one from mm/vmalloc.c.
This adds tracehook_expect_breakpoints() as a formal hook for the nommu
code to use for its, "Is text-poking likely?" check at mmap time. This
names the actual semantics the code means to test, and documents it.
Signed-off-by: Roland McGrath <roland@redhat.com>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Reviewed-by: Ingo Molnar <mingo@elte.hu>
This implements a few changes on top of the recent kobjsize() refactoring
introduced by commit 6cfd53fc03670c7a544a56d441eb1a6cc800d72b.
As Christoph points out:
virt_to_head_page cannot return NULL. virt_to_page also
does not return NULL. pfn_valid() needs to be used to
figure out if a page is valid. Otherwise the page struct
reference that was returned may have PageReserved() set
to indicate that it is not a valid page.
As discussed further in the thread, virt_addr_valid() is the preferable
way to validate the object pointer in this case. In addition to fixing
up the reserved page case, it also has the benefit of encapsulating the
hack introduced by commit 4016a1390d07f15b267eecb20e76a48fd5c524ef on
the impacted platforms, allowing us to get rid of the extra checking in
kobjsize() for the platforms that don't perform this type of bizarre
memory_end abuse (every nommu platform that isn't blackfin). If blackfin
decides to get in line with every other platform and use PageReserved
for the DMA pages in question, kobjsize() will also continue to work
fine.
It also turns out that compound_order() will give us back 0-order for
non-head pages, so we can get rid of the PageCompound check and just
use compound_order() directly. Clean that up while we're at it.
Reviewed-by: Christoph Lameter <clameter@sgi.com>
kobjsize() has been abusing page->index as a method for sorting out
compound order, which blows up both for page cache pages, and SLOB's
reuse of the index in struct slob_page.
Presently we are not able to accurately size arbitrary pointers that
don't come from kmalloc(), so the best we can do is sort out the
compound order from the head page if it's a compound page, or default
to 0-order if it's impossible to ksize() the object.
Obviously this leaves quite a bit to be desired in terms of object
sizing accuracy, but the behaviour is unchanged over the existing
implementation, while fixing the page->index oopses originally reported
here:
http://marc.info/?l=linux-mm&m=121127773325245&w=2
Accuracy could also be improved by having SLUB and SLOB both set PG_slab
on ksizeable pages, rather than just handling the __GFP_COMP cases
irregardless of the PG_slab setting, as made possibly with Pekka's
patches:
http://marc.info/?l=linux-kernel&m=121139439900534&w=2
http://marc.info/?l=linux-kernel&m=121139440000537&w=2
http://marc.info/?l=linux-kernel&m=121139440000540&w=2
This is primarily a bugfix for nommu systems for 2.6.26, with the aim
being to gradually kill off kobjsize() and its particular brand of
object abuse entirely.
Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi>
The atomic_t type is 32bit but a 64bit system can have more than 2^32
pages of virtual address space available. Without this we overflow on
ludicrously large mappings
The kernel implements readlink of /proc/pid/exe by getting the file from
the first executable VMA. Then the path to the file is reconstructed and
reported as the result.
Because of the VMA walk the code is slightly different on nommu systems.
This patch avoids separate /proc/pid/exe code on nommu systems. Instead of
walking the VMAs to find the first executable file-backed VMA we store a
reference to the exec'd file in the mm_struct.
That reference would prevent the filesystem holding the executable file
from being unmounted even after unmapping the VMAs. So we track the number
of VM_EXECUTABLE VMAs and drop the new reference when the last one is
unmapped. This avoids pinning the mounted filesystem.
[akpm@linux-foundation.org: improve comments]
[yamamoto@valinux.co.jp: fix dup_mmap]
Signed-off-by: Matt Helsley <matthltc@us.ibm.com>
Cc:"Eric W. Biederman" <ebiederm@xmission.com>
Cc: Hugh Dickins <hugh@veritas.com>
Signed-off-by: YAMAMOTO Takashi <yamamoto@valinux.co.jp>
Don't perform kobjsize operations on objects the kernel doesn't manage.
On Blackfin, drivers can get dma coherent memory by calling a function
dma_alloc_coherent(). We do this in nommu by configuring a chunk of uncached
memory at the top of memory.
Since we don't want the kernel to use the uncached memory, we lie to the
kernel, and tell it that it's max memory is between 0, and the start of the
uncached dma coherent section.
this all works well, until this memory gets exposed into userspace (with a
frame buffer), when you look at the process's maps, it shows the framebuf:
root:/proc> cat maps
[snip]
03f0ef00-03f34700 rw-p 00000000 1f:00 192 /dev/fb0
root:/proc>
This is outside the "normal" range for the kernel. When the kernel tries to
find the size of this object (when you run ps), it dies in nommu.c in
kobjsize.
BUG_ON(page->index >= MAX_ORDER);
since the page we are referring to is outside what the kernel thinks is it's
max valid memory.
root:~> while [ 1 ]; ps > /dev/null; done
kernel BUG at mm/nommu.c:119!
Kernel panic - not syncing: BUG!
We fixed this by adding a check to reject out of range object pointers as it
already does that for NULL pointers.
Signed-off-by: Michael Hennerich <Michael.Hennerich@analog.com>
Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org>
This builds on top of the earlier vmalloc_32_user() work introduced by
b50731732f926d6c49fd0724616a7344c31cd5cf, as we now have places in the nommu
allmodconfig that hit up against these missing APIs.
As vmalloc_32_user() is already implemented, this is moved over to
vmalloc_user() and simply made a wrapper. As all current nommu platforms are
32-bit addressable, there's no special casing we have to do for ZONE_DMA and
things of that nature as per GFP_VMALLOC32.
remap_vmalloc_range() needs to check VM_USERMAP in order to figure out whether
we permit the remap or not, which means that we also have to rework the
vmalloc_user() code to grovel for the VMA and set the flag.
Acked-by: David McCullough <david_mccullough@securecomputing.com>
Make vmalloc functions work the same way as kfree() and friends that
take a const void * argument.
[akpm@linux-foundation.org: fix consts, coding-style]
Signed-off-by: Christoph Lameter <clameter@sgi.com>
If mmap_min_addr is set and a process attempts to mmap (not fixed) with a
non-null hint address less than mmap_min_addr the mapping will fail the
security checks. Since this is just a hint address this patch will round
such a hint address above mmap_min_addr.
gcj was found to try to be very frugal with vm usage and give hint addresses
in the 8k-32k range. Without this patch all such programs failed and with
the patch they happily get a higher address.
This patch is wrappad in CONFIG_SECURITY since mmap_min_addr doesn't exist
without it and there would be no security check possible no matter what. So
we should not bother compiling in this rounding if it is just a waste of
time.
mm/nommu.c needs to #include linux/module.h for it to understand EXPORT_*()
macros.
Fix the wishy-washy comment to clearly explain why kmalloc() can't
use the __GFP_HIGHMEM zone modifier.
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
This patch contains the following cleanups that are now possible:
- remove the unused security_operations->inode_xattr_getsuffix
- remove the no longer used security_operations->unregister_security
- remove some no longer required exit code
- remove a bunch of no longer used exports
Cc: Chris Wright <chrisw@sous-sol.org>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Cc: Serge Hallyn <serue@us.ibm.com>
The new exec code inserts an accounted vma into an mm struct which is not
current->mm. The existing memory check code has a hard coded assumption
that this does not happen as does the security code.
As the correct mm is known we pass the mm to the security method and the
helper function. A new security test is added for the case where we need
to pass the mm and the existing one is modified to pass current->mm to
avoid the need to change large amounts of code.
(Thanks to Tobias for fixing rejects and testing)
Cc: WU Fengguang <wfg@mail.ustc.edu.cn>
Cc: James Morris <jmorris@redhat.com>
Cc: Tobias Diedrich <ranma+kernel@tdiedrich.de>
Trying to survive an allmodconfig on a nommu platform results in many
screen lengths of module unhappiness. Many of the mmap related things that
binfmt_flat hooks in to are never exported despite being global, and there
are also missing definitions for vmalloc_32_user() and vm_insert_page().
I've implemented vmalloc_32_user() trying to stick as close to the
mm/vmalloc.c implementation as possible, though we don't have any need for
VM_USERMAP, so groveling for the VMA can be skipped. vm_insert_page() has
been stubbed for now in order to keep the build happy.
Change ->fault prototype. We now return an int, which contains
VM_FAULT_xxx code in the low byte, and FAULT_RET_xxx code in the next byte.
FAULT_RET_ code tells the VM whether a page was found, whether it has been
locked, and potentially other things. This is not quite the way he wanted
it yet, but that's changed in the next patch (which requires changes to
arch code).
This means we no longer set VM_CAN_INVALIDATE in the vma in order to say
that a page is locked which requires filemap_nopage to go away (because we
can no longer remain backward compatible without that flag), but we were
going to do that anyway.
struct fault_data is renamed to struct vm_fault as Linus asked. address
is now a void __user * that we should firmly encourage drivers not to use
without really good reason.
The page is now returned via a page pointer in the vm_fault struct.
Nonlinear mappings are (AFAIKS) simply a virtual memory concept that encodes
the virtual address -> file offset differently from linear mappings.
->populate is a layering violation because the filesystem/pagecache code
should need to know anything about the virtual memory mapping. The hitch here
is that the ->nopage handler didn't pass down enough information (ie. pgoff).
But it is more logical to pass pgoff rather than have the ->nopage function
calculate it itself anyway (because that's a similar layering violation).
Having the populate handler install the pte itself is likewise a nasty thing
to be doing.
This patch introduces a new fault handler that replaces ->nopage and
->populate and (later) ->nopfn. Most of the old mechanism is still in place
so there is a lot of duplication and nice cleanups that can be removed if
everyone switches over.
The rationale for doing this in the first place is that nonlinear mappings are
subject to the pagefault vs invalidate/truncate race too, and it seemed stupid
to duplicate the synchronisation logic rather than just consolidate the two.
After this patch, MAP_NONBLOCK no longer sets up ptes for pages present in
pagecache. Seems like a fringe functionality anyway.
NOPAGE_REFAULT is removed. This should be implemented with ->fault, and no
users have hit mainline yet.
[akpm@linux-foundation.org: cleanup]
[randy.dunlap@oracle.com: doc. fixes for readahead]
[akpm@linux-foundation.org: build fix]
Cc: Mark Fasheh <mark.fasheh@oracle.com>
Be consistent with VM mmap, implement expand_stack(). We can't actually do
anything other than return an error in the no MMU case though.
Add a new security check on mmap operations to see if the user is attempting
to mmap to low area of the address space. The amount of space protected is
indicated by the new proc tunable /proc/sys/vm/mmap_min_addr and defaults to
0, preserving existing behavior.
This patch uses a new SELinux security class "memprotect." Policy already
contains a number of allow rules like a_t self:process * (unconfined_t being
one of them) which mean that putting this check in the process class (its
best current fit) would make it useless as all user processes, which we also
want to protect against, would be allowed. By taking the memprotect name of
the new class it will also make it possible for us to move some of the other
memory protect permissions out of 'process' and into the new class next time
we bump the policy version number (which I also think is a good future idea)
Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
Acked-by: Chris Wright <chrisw@sous-sol.org>
This patch moves the die notifier handling to common code. Previous
various architectures had exactly the same code for it. Note that the new
code is compiled unconditionally, this should be understood as an appel to
the other architecture maintainer to implement support for it aswell (aka
sprinkling a notify_die or two in the proper place)
arm had a notifiy_die that did something totally different, I renamed it to
arm_notify_die as part of the patch and made it static to the file it's
declared and used at. avr32 used to pass slightly less information through
this interface and I brought it into line with the other architectures.
[akpm@linux-foundation.org: fix vmalloc_sync_all bustage]
[bryan.wu@analog.com: fix vmalloc_sync_all in nommu]
Cc: <linux-arch@vger.kernel.org>
Signed-off-by: Bryan Wu <bryan.wu@analog.com>
num_physpages is not exported out in mm/nommu.c, so the ip_conntrack module
link will fail.
Acked-By: David Howells <dhowells@redhat.com>
Make the SYSV SHM nattch counter work correctly by forcing multiple VMAs to
be produced to represent MAP_SHARED segments, even if they overlap exactly.
Using this test program:
http://people.redhat.com/~dhowells/doshm.c
Run as:
doshm sysv
I can see nattch going from one before the patch:
# /doshm sysv
Command: sysv
shmid: 65536
memory: 0xc3700000
c0b00000-c0b04000 rw-p 00000000 00:00 0
c0bb0000-c0bba788 r-xs 00000000 00:0b 14582157 /lib/ld-uClibc-0.9.28.so
c3180000-c31dede4 r-xs 00000000 00:0b 14582179 /lib/libuClibc-0.9.28.so
c3520000-c352278c rw-p 00000000 00:0b 13763417 /doshm
c3584000-c35865e8 r-xs 00000000 00:0b 13763417 /doshm
c3588000-c358aa00 rw-p 00008000 00:0b 14582157 /lib/ld-uClibc-0.9.28.so
c3590000-c359b6c0 rw-p 00000000 00:00 0
c3620000-c3640000 rwxp 00000000 00:00 0
c3700000-c37fa000 rw-S 00000000 00:06 1411 /SYSV00000000 (deleted)
nattch 1
To two after the patch:
# /doshm sysv
Command: sysv
shmid: 0
memory: 0xc3700000
c3320000-c3340000 rwxp 00000000 00:00 0
c3530000-c35325e8 r-xs 00000000 00:0b 13763417 /doshm
c3534000-c353678c rw-p 00000000 00:0b 13763417 /doshm
c3538000-c353aa00 rw-p 00008000 00:0b 14582157 /lib/ld-uClibc-0.9.28.so
c35a4000-c35a8000 rw-p 00000000 00:00 0
c3700000-c37fa000 rw-S 00000000 00:06 1369 /SYSV00000000 (deleted)
nattch 2
That's +1 to nattch for each shmat() made.
Supply a get_unmapped_area() to fix NOMMU SYSV SHM support.
Acked-by: Adam Litke <agl@us.ibm.com>
Signed-off-by: Josef Sipek <jsipek@fsl.cs.sunysb.edu>
I was playing with blackfin when i hit a neat bug ... doing an open() on a
directory and then passing that fd to mmap() would cause the kernel to hang
after poking into the code a bit more, i found that
mm/nommu.c:validate_mmap_request() checks the length and if it is 0, just
returns the address ... this is in stark contrast to mmu's
mm/mmap.c:do_mmap_pgoff() where it returns -EINVAL for 0 length requests ...
i then noticed that some other parts of the logic is out of date between the
two funcs, so perhaps that's the easy fix ?
This patch against fixes a spelling mistake ("control" instead of "cotrol").
Signed-off-by: Michael Opdenacker <michael@free-electrons.com>
Acked-by: Alan Cox <alan@redhat.com>
