path: root/mm/oom_kill.c
2014-01-30mm, oom: base root bonus on current usageDavid Rientjes
A 3% of system memory bonus is sometimes too excessive in comparison to other processes. With commit a63d83f427fb ("oom: badness heuristic rewrite"), the OOM killer tries to avoid killing privileged tasks by subtracting 3% of overall memory (system or cgroup) from their per-task consumption. But as a result, all root tasks that consume less than 3% of overall memory are considered equal, and so it only takes 33+ privileged tasks pushing the system out of memory for the OOM killer to do something stupid and kill dhclient or other root-owned processes. For example, on a 32G machine it can't tell the difference between the 1M agetty and the 10G fork bomb member. The changelog describes this 3% boost as the equivalent to the global overcommit limit being 3% higher for privileged tasks, but this is not the same as discounting 3% of overall memory from _every privileged task individually_ during OOM selection. Replace the 3% of system memory bonus with a 3% of current memory usage bonus. By giving root tasks a bonus that is proportional to their actual size, they remain comparable even when relatively small. In the example above, the OOM killer will discount the 1M agetty's 256 badness points down to 179, and the 10G fork bomb's 262144 points down to 183500 points and make the right choice, instead of discounting both to 0 and killing agetty because it's first in the task list. Signed-off-by: David Rientjes <rientjes@google.com> Reported-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23mm, oom: prefer thread group leaders for display purposesDavid Rientjes
When two threads have the same badness score, it's preferable to kill the thread group leader so that the actual process name is printed to the kernel log rather than the thread group name which may be shared amongst several processes. This was the behavior when select_bad_process() used to do for_each_process(), but it now iterates threads instead and leads to ambiguity. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Greg Thelen <gthelen@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21oom_kill: add rcu_read_lock() into find_lock_task_mm()Oleg Nesterov
find_lock_task_mm() expects it is called under rcu or tasklist lock, but it seems that at least oom_unkillable_task()->task_in_mem_cgroup() and mem_cgroup_out_of_memory()->oom_badness() can call it lockless. Perhaps we could fix the callers, but this patch simply adds rcu lock into find_lock_task_mm(). This also allows to simplify a bit one of its callers, oom_kill_process(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Sergey Dyasly <dserrg@gmail.com> Cc: Sameer Nanda <snanda@chromium.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mandeep Singh Baines <msb@chromium.org> Cc: "Ma, Xindong" <xindong.ma@intel.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: "Tu, Xiaobing" <xiaobing.tu@intel.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21oom_kill: has_intersects_mems_allowed() needs rcu_read_lock()Oleg Nesterov
At least out_of_memory() calls has_intersects_mems_allowed() without even rcu_read_lock(), this is obviously buggy. Add the necessary rcu_read_lock(). This means that we can not simply return from the loop, we need "bool ret" and "break". While at it, swap the names of task_struct's (the argument and the local). This cleans up the code a little bit and avoids the unnecessary initialization. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Sergey Dyasly <dserrg@gmail.com> Tested-by: Sergey Dyasly <dserrg@gmail.com> Reviewed-by: Sameer Nanda <snanda@chromium.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mandeep Singh Baines <msb@chromium.org> Cc: "Ma, Xindong" <xindong.ma@intel.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: "Tu, Xiaobing" <xiaobing.tu@intel.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21oom_kill: change oom_kill.c to use for_each_thread()Oleg Nesterov
Change oom_kill.c to use for_each_thread() rather than the racy while_each_thread() which can loop forever if we race with exit. Note also that most users were buggy even if while_each_thread() was fine, the task can exit even _before_ rcu_read_lock(). Fortunately the new for_each_thread() only requires the stable task_struct, so this change fixes both problems. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Sergey Dyasly <dserrg@gmail.com> Tested-by: Sergey Dyasly <dserrg@gmail.com> Reviewed-by: Sameer Nanda <snanda@chromium.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mandeep Singh Baines <msb@chromium.org> Cc: "Ma, Xindong" <xindong.ma@intel.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: "Tu, Xiaobing" <xiaobing.tu@intel.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-15mm: convert mm->nr_ptes to atomic_long_tKirill A. Shutemov
With split page table lock for PMD level we can't hold mm->page_table_lock while updating nr_ptes. Let's convert it to atomic_long_t to avoid races. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Tested-by: Alex Thorlton <athorlton@sgi.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: "Eric W . Biederman" <ebiederm@xmission.com> Cc: "Paul E . McKenney" <paulmck@linux.vnet.ibm.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andi Kleen <ak@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Dave Jones <davej@redhat.com> Cc: David Howells <dhowells@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Kees Cook <keescook@chromium.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Robin Holt <robinmholt@gmail.com> Cc: Sedat Dilek <sedat.dilek@gmail.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-16mm: memcg: handle non-error OOM situations more gracefullyJohannes Weiner
Commit 3812c8c8f395 ("mm: memcg: do not trap chargers with full callstack on OOM") assumed that only a few places that can trigger a memcg OOM situation do not return VM_FAULT_OOM, like optional page cache readahead. But there are many more and it's impractical to annotate them all. First of all, we don't want to invoke the OOM killer when the failed allocation is gracefully handled, so defer the actual kill to the end of the fault handling as well. This simplifies the code quite a bit for added bonus. Second, since a failed allocation might not be the abrupt end of the fault, the memcg OOM handler needs to be re-entrant until the fault finishes for subsequent allocation attempts. If an allocation is attempted after the task already OOMed, allow it to bypass the limit so that it can quickly finish the fault and invoke the OOM killer. Reported-by: azurIt <azurit@pobox.sk> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-12mm: memcg: do not trap chargers with full callstack on OOMJohannes Weiner
The memcg OOM handling is incredibly fragile and can deadlock. When a task fails to charge memory, it invokes the OOM killer and loops right there in the charge code until it succeeds. Comparably, any other task that enters the charge path at this point will go to a waitqueue right then and there and sleep until the OOM situation is resolved. The problem is that these tasks may hold filesystem locks and the mmap_sem; locks that the selected OOM victim may need to exit. For example, in one reported case, the task invoking the OOM killer was about to charge a page cache page during a write(), which holds the i_mutex. The OOM killer selected a task that was just entering truncate() and trying to acquire the i_mutex: OOM invoking task: mem_cgroup_handle_oom+0x241/0x3b0 mem_cgroup_cache_charge+0xbe/0xe0 add_to_page_cache_locked+0x4c/0x140 add_to_page_cache_lru+0x22/0x50 grab_cache_page_write_begin+0x8b/0xe0 ext3_write_begin+0x88/0x270 generic_file_buffered_write+0x116/0x290 __generic_file_aio_write+0x27c/0x480 generic_file_aio_write+0x76/0xf0 # takes ->i_mutex do_sync_write+0xea/0x130 vfs_write+0xf3/0x1f0 sys_write+0x51/0x90 system_call_fastpath+0x18/0x1d OOM kill victim: do_truncate+0x58/0xa0 # takes i_mutex do_last+0x250/0xa30 path_openat+0xd7/0x440 do_filp_open+0x49/0xa0 do_sys_open+0x106/0x240 sys_open+0x20/0x30 system_call_fastpath+0x18/0x1d The OOM handling task will retry the charge indefinitely while the OOM killed task is not releasing any resources. A similar scenario can happen when the kernel OOM killer for a memcg is disabled and a userspace task is in charge of resolving OOM situations. In this case, ALL tasks that enter the OOM path will be made to sleep on the OOM waitqueue and wait for userspace to free resources or increase the group's limit. But a userspace OOM handler is prone to deadlock itself on the locks held by the waiting tasks. For example one of the sleeping tasks may be stuck in a brk() call with the mmap_sem held for writing but the userspace handler, in order to pick an optimal victim, may need to read files from /proc/<pid>, which tries to acquire the same mmap_sem for reading and deadlocks. This patch changes the way tasks behave after detecting a memcg OOM and makes sure nobody loops or sleeps with locks held: 1. When OOMing in a user fault, invoke the OOM killer and restart the fault instead of looping on the charge attempt. This way, the OOM victim can not get stuck on locks the looping task may hold. 2. When OOMing in a user fault but somebody else is handling it (either the kernel OOM killer or a userspace handler), don't go to sleep in the charge context. Instead, remember the OOMing memcg in the task struct and then fully unwind the page fault stack with -ENOMEM. pagefault_out_of_memory() will then call back into the memcg code to check if the -ENOMEM came from the memcg, and then either put the task to sleep on the memcg's OOM waitqueue or just restart the fault. The OOM victim can no longer get stuck on any lock a sleeping task may hold. Debugged by Michal Hocko. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reported-by: azurIt <azurit@pobox.sk> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-15mm/oom_kill: remove weird use of ERR_PTR()/PTR_ERR().Rusty Russell
The normal expectation for ERR_PTR() is to put a negative errno into a pointer. oom_kill puts the magic -1 in the result (and has since pre-git), which is probably clearer with an explicit cast. Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-02-23memcg, oom: provide more precise dump info while memcg oom happeningSha Zhengju
Currently when a memcg oom is happening the oom dump messages is still global state and provides few useful info for users. This patch prints more pointed memcg page statistics for memcg-oom and take hierarchy into consideration: Based on Michal's advice, we take hierarchy into consideration: supppose we trigger an OOM on A's limit root_memcg | A (use_hierachy=1) / \ B C | D then the printed info will be: Memory cgroup stats for /A:... Memory cgroup stats for /A/B:... Memory cgroup stats for /A/C:... Memory cgroup stats for /A/B/D:... Following are samples of oom output: (1) Before change: mal-80 invoked oom-killer:gfp_mask=0xd0, order=0, oom_score_adj=0 mal-80 cpuset=/ mems_allowed=0 Pid: 2976, comm: mal-80 Not tainted 3.7.0+ #10 Call Trace: [<ffffffff8167fbfb>] dump_header+0x83/0x1ca ..... (call trace) [<ffffffff8168a818>] page_fault+0x28/0x30 <<<<<<<<<<<<<<<<<<<<< memcg specific information Task in /A/B/D killed as a result of limit of /A memory: usage 101376kB, limit 101376kB, failcnt 57 memory+swap: usage 101376kB, limit 101376kB, failcnt 0 kmem: usage 0kB, limit 9007199254740991kB, failcnt 0 <<<<<<<<<<<<<<<<<<<<< print per cpu pageset stat Mem-Info: Node 0 DMA per-cpu: CPU 0: hi: 0, btch: 1 usd: 0 ...... CPU 3: hi: 0, btch: 1 usd: 0 Node 0 DMA32 per-cpu: CPU 0: hi: 186, btch: 31 usd: 173 ...... CPU 3: hi: 186, btch: 31 usd: 130 <<<<<<<<<<<<<<<<<<<<< print global page state active_anon:92963 inactive_anon:40777 isolated_anon:0 active_file:33027 inactive_file:51718 isolated_file:0 unevictable:0 dirty:3 writeback:0 unstable:0 free:729995 slab_reclaimable:6897 slab_unreclaimable:6263 mapped:20278 shmem:35971 pagetables:5885 bounce:0 free_cma:0 <<<<<<<<<<<<<<<<<<<<< print per zone page state Node 0 DMA free:15836kB ... all_unreclaimable? no lowmem_reserve[]: 0 3175 3899 3899 Node 0 DMA32 free:2888564kB ... all_unrelaimable? no lowmem_reserve[]: 0 0 724 724 lowmem_reserve[]: 0 0 0 0 Node 0 DMA: 1*4kB (U) ... 3*4096kB (M) = 15836kB Node 0 DMA32: 41*4kB (UM) ... 702*4096kB (MR) = 2888316kB 120710 total pagecache pages 0 pages in swap cache <<<<<<<<<<<<<<<<<<<<< print global swap cache stat Swap cache stats: add 0, delete 0, find 0/0 Free swap = 499708kB Total swap = 499708kB 1040368 pages RAM 58678 pages reserved 169065 pages shared 173632 pages non-shared [ pid ] uid tgid total_vm rss nr_ptes swapents oom_score_adj name [ 2693] 0 2693 6005 1324 17 0 0 god [ 2754] 0 2754 6003 1320 16 0 0 god [ 2811] 0 2811 5992 1304 18 0 0 god [ 2874] 0 2874 6005 1323 18 0 0 god [ 2935] 0 2935 8720 7742 21 0 0 mal-30 [ 2976] 0 2976 21520 17577 42 0 0 mal-80 Memory cgroup out of memory: Kill process 2976 (mal-80) score 665 or sacrifice child Killed process 2976 (mal-80) total-vm:86080kB, anon-rss:69964kB, file-rss:344kB We can see that messages dumped by show_free_areas() are longsome and can provide so limited info for memcg that just happen oom. (2) After change mal-80 invoked oom-killer: gfp_mask=0xd0, order=0, oom_score_adj=0 mal-80 cpuset=/ mems_allowed=0 Pid: 2704, comm: mal-80 Not tainted 3.7.0+ #10 Call Trace: [<ffffffff8167fd0b>] dump_header+0x83/0x1d1 .......(call trace) [<ffffffff8168a918>] page_fault+0x28/0x30 Task in /A/B/D killed as a result of limit of /A <<<<<<<<<<<<<<<<<<<<< memcg specific information memory: usage 102400kB, limit 102400kB, failcnt 140 memory+swap: usage 102400kB, limit 102400kB, failcnt 0 kmem: usage 0kB, limit 9007199254740991kB, failcnt 0 Memory cgroup stats for /A: cache:32KB rss:30984KB mapped_file:0KB swap:0KB inactive_anon:6912KB active_anon:24072KB inactive_file:32KB active_file:0KB unevictable:0KB Memory cgroup stats for /A/B: cache:0KB rss:0KB mapped_file:0KB swap:0KB inactive_anon:0KB active_anon:0KB inactive_file:0KB active_file:0KB unevictable:0KB Memory cgroup stats for /A/C: cache:0KB rss:0KB mapped_file:0KB swap:0KB inactive_anon:0KB active_anon:0KB inactive_file:0KB active_file:0KB unevictable:0KB Memory cgroup stats for /A/B/D: cache:32KB rss:71352KB mapped_file:0KB swap:0KB inactive_anon:6656KB active_anon:64696KB inactive_file:16KB active_file:16KB unevictable:0KB [ pid ] uid tgid total_vm rss nr_ptes swapents oom_score_adj name [ 2260] 0 2260 6006 1325 18 0 0 god [ 2383] 0 2383 6003 1319 17 0 0 god [ 2503] 0 2503 6004 1321 18 0 0 god [ 2622] 0 2622 6004 1321 16 0 0 god [ 2695] 0 2695 8720 7741 22 0 0 mal-30 [ 2704] 0 2704 21520 17839 43 0 0 mal-80 Memory cgroup out of memory: Kill process 2704 (mal-80) score 669 or sacrifice child Killed process 2704 (mal-80) total-vm:86080kB, anon-rss:71016kB, file-rss:340kB This version provides more pointed info for memcg in "Memory cgroup stats for XXX" section. Signed-off-by: Sha Zhengju <handai.szj@taobao.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-12mm, oom: remove redundant sleep in pagefault oom handlerDavid Rientjes
out_of_memory() will already cause current to schedule if it has not been killed, so doing it again in pagefault_out_of_memory() is redundant. Remove it. Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-12mm, oom: cleanup pagefault oom handlerDavid Rientjes
To lock the entire system from parallel oom killing, it's possible to pass in a zonelist with all zones rather than using for_each_populated_zone() for the iteration. This obsoletes try_set_system_oom() and clear_system_oom() so that they can be removed. Signed-off-by: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-12oom: use N_MEMORY instead N_HIGH_MEMORYLai Jiangshan
N_HIGH_MEMORY stands for the nodes that has normal or high memory. N_MEMORY stands for the nodes that has any memory. The code here need to handle with the nodes which have memory, we should use N_MEMORY instead. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Hillf Danton <dhillf@gmail.com> Signed-off-by: Wen Congyang <wency@cn.fujitsu.com> Cc: Christoph Lameter <cl@linux.com> Cc: Lin Feng <linfeng@cn.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-11mm, oom: fix race when specifying a thread as the oom originDavid Rientjes
test_set_oom_score_adj() and compare_swap_oom_score_adj() are used to specify that current should be killed first if an oom condition occurs in between the two calls. The usage is short oom_score_adj = test_set_oom_score_adj(OOM_SCORE_ADJ_MAX); ... compare_swap_oom_score_adj(OOM_SCORE_ADJ_MAX, oom_score_adj); to store the thread's oom_score_adj, temporarily change it to the maximum score possible, and then restore the old value if it is still the same. This happens to still be racy, however, if the user writes OOM_SCORE_ADJ_MAX to /proc/pid/oom_score_adj in between the two calls. The compare_swap_oom_score_adj() will then incorrectly reset the old value prior to the write of OOM_SCORE_ADJ_MAX. To fix this, introduce a new oom_flags_t member in struct signal_struct that will be used for per-thread oom killer flags. KSM and swapoff can now use a bit in this member to specify that threads should be killed first in oom conditions without playing around with oom_score_adj. This also allows the correct oom_score_adj to always be shown when reading /proc/pid/oom_score. Signed-off-by: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: Anton Vorontsov <anton.vorontsov@linaro.org> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-11mm, oom: change type of oom_score_adj to shortDavid Rientjes
The maximum oom_score_adj is 1000 and the minimum oom_score_adj is -1000, so this range can be represented by the signed short type with no functional change. The extra space this frees up in struct signal_struct will be used for per-thread oom kill flags in the next patch. Signed-off-by: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: Anton Vorontsov <anton.vorontsov@linaro.org> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-11mm, oom: allow exiting threads to have access to memory reservesDavid Rientjes
Exiting threads, those with PF_EXITING set, can pagefault and require memory before they can make forward progress. This happens, for instance, when a process must fault task->robust_list, a userspace structure, before detaching its memory. These threads also aren't guaranteed to get access to memory reserves unless oom killed or killed from userspace. The oom killer won't grant memory reserves if other threads are also exiting other than current and stalling at the same point. This prevents needlessly killing processes when others are already exiting. Instead of special casing all the possible situations between PF_EXITING getting set and a thread detaching its mm where it may allocate memory, which probably wouldn't get updated when a change is made to the exit path, the solution is to give all exiting threads access to memory reserves if they call the oom killer. This allows them to quickly allocate, detach its mm, and free the memory it represents. Summary of Luigi's bug report: : He had an oom condition where threads were faulting on task->robust_list : and repeatedly called the oom killer but it would defer killing a thread : because it saw other PF_EXITING threads. This can happen anytime we need : to allocate memory after setting PF_EXITING and before detaching our mm; : if there are other threads in the same state then the oom killer won't do : anything unless one of them happens to be killed from userspace. : : So instead of only deferring for PF_EXITING and !task->robust_list, it's : better to just give them access to memory reserves to prevent a potential : livelock so that any other faults that may be introduced in the future in : the exit path don't cause the same problem (and hopefully we don't allow : too many of those!). Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: Minchan Kim <minchan@kernel.org> Tested-by: Luigi Semenzato <semenzato@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09oom: remove deprecated oom_adjDavidlohr Bueso
The deprecated /proc/<pid>/oom_adj is scheduled for removal this month. Signed-off-by: Davidlohr Bueso <dave@gnu.org> Acked-by: David Rientjes <rientjes@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm, memcg: move all oom handling to memcontrol.cDavid Rientjes
By globally defining check_panic_on_oom(), the memcg oom handler can be moved entirely to mm/memcontrol.c. This removes the ugly #ifdef in the oom killer and cleans up the code. Signed-off-by: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Oleg Nesterov <oleg@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm, oom: reduce dependency on tasklist_lockDavid Rientjes
Since exiting tasks require write_lock_irq(&tasklist_lock) several times, try to reduce the amount of time the readside is held for oom kills. This makes the interface with the memcg oom handler more consistent since it now never needs to take tasklist_lock unnecessarily. The only time the oom killer now takes tasklist_lock is when iterating the children of the selected task, everything else is protected by rcu_read_lock(). This requires that a reference to the selected process, p, is grabbed before calling oom_kill_process(). It may release it and grab a reference on another one of p's threads if !p->mm, but it also guarantees that it will release the reference before returning. [hughd@google.com: fix duplicate put_task_struct()] Signed-off-by: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: Oleg Nesterov <oleg@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm, memcg: introduce own oom handler to iterate only over its own threadsDavid Rientjes
The global oom killer is serialized by the per-zonelist try_set_zonelist_oom() which is used in the page allocator. Concurrent oom kills are thus a rare event and only occur in systems using mempolicies and with a large number of nodes. Memory controller oom kills, however, can frequently be concurrent since there is no serialization once the oom killer is called for oom conditions in several different memcgs in parallel. This creates a massive contention on tasklist_lock since the oom killer requires the readside for the tasklist iteration. If several memcgs are calling the oom killer, this lock can be held for a substantial amount of time, especially if threads continue to enter it as other threads are exiting. Since the exit path grabs the writeside of the lock with irqs disabled in a few different places, this can cause a soft lockup on cpus as a result of tasklist_lock starvation. The kernel lacks unfair writelocks, and successful calls to the oom killer usually result in at least one thread entering the exit path, so an alternative solution is needed. This patch introduces a seperate oom handler for memcgs so that they do not require tasklist_lock for as much time. Instead, it iterates only over the threads attached to the oom memcg and grabs a reference to the selected thread before calling oom_kill_process() to ensure it doesn't prematurely exit. This still requires tasklist_lock for the tasklist dump, iterating children of the selected process, and killing all other threads on the system sharing the same memory as the selected victim. So while this isn't a complete solution to tasklist_lock starvation, it significantly reduces the amount of time that it is held. Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Sha Zhengju <handai.szj@taobao.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm, oom: introduce helper function to process threads during scanDavid Rientjes
This patch introduces a helper function to process each thread during the iteration over the tasklist. A new return type, enum oom_scan_t, is defined to determine the future behavior of the iteration: - OOM_SCAN_OK: continue scanning the thread and find its badness, - OOM_SCAN_CONTINUE: do not consider this thread for oom kill, it's ineligible, - OOM_SCAN_ABORT: abort the iteration and return, or - OOM_SCAN_SELECT: always select this thread with the highest badness possible. There is no functional change with this patch. This new helper function will be used in the next patch in the memory controller. Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Sha Zhengju <handai.szj@taobao.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31memcg: rename config variablesAndrew Morton
Sanity: CONFIG_CGROUP_MEM_RES_CTLR -> CONFIG_MEMCG CONFIG_CGROUP_MEM_RES_CTLR_SWAP -> CONFIG_MEMCG_SWAP CONFIG_CGROUP_MEM_RES_CTLR_SWAP_ENABLED -> CONFIG_MEMCG_SWAP_ENABLED CONFIG_CGROUP_MEM_RES_CTLR_KMEM -> CONFIG_MEMCG_KMEM [mhocko@suse.cz: fix missed bits] Cc: Glauber Costa <glommer@parallels.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Cc: Tejun Heo <tj@kernel.org> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: David Rientjes <rientjes@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm, oom: replace some information in tasklist dumpDavid Rientjes
The number of ptes and swap entries are used in the oom killer's badness heuristic, so they should be shown in the tasklist dump. This patch adds those fields and replaces cpu and oom_adj values that are currently emitted. Cpu isn't interesting and oom_adj is deprecated and will be removed later this year, the same information is already displayed as oom_score_adj which is used internally. At the same time, make the documentation a little more clear to state this information is helpful to determine why the oom killer chose the task it did to kill. Signed-off-by: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm, oom: fix potential killing of thread that is disabled from oom killingDavid Rientjes
/proc/sys/vm/oom_kill_allocating_task will immediately kill current when the oom killer is called to avoid a potentially expensive tasklist scan for large systems. Currently, however, it is not checking current's oom_score_adj value which may be OOM_SCORE_ADJ_MIN, meaning that it has been disabled from oom killing. This patch avoids killing current in such a condition and simply falls back to the tasklist scan since memory still needs to be freed. Signed-off-by: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm, oom: do not schedule if current has been killedDavid Rientjes
The oom killer currently schedules away from current in an uninterruptible sleep if it does not have access to memory reserves. It's possible that current was killed because it shares memory with the oom killed thread or because it was killed by the user in the interim, however. This patch only schedules away from current if it does not have a pending kill, i.e. if it does not share memory with the oom killed thread. It's possible that it will immediately retry its memory allocation and fail, but it will immediately be given access to memory reserves if it calls the oom killer again. This prevents the delay of memory freeing when threads that share memory with the oom killed thread get unnecessarily scheduled. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-06-20mm: fix kernel-doc warningsWanpeng Li
Fix kernel-doc warnings such as Warning(../mm/page_cgroup.c:432): No description found for parameter 'id' Warning(../mm/page_cgroup.c:432): Excess function parameter 'mem' description in 'swap_cgroup_record' Signed-off-by: Wanpeng Li <liwp@linux.vnet.ibm.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-06-20mm, oom: fix and cleanup oom score calculationsDavid Rientjes
The divide in p->signal->oom_score_adj * totalpages / 1000 within oom_badness() was causing an overflow of the signed long data type. This adds both the root bias and p->signal->oom_score_adj before doing the normalization which fixes the issue and also cleans up the calculation. Tested-by: Dave Jones <davej@redhat.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-06-08mm, oom: fix badness score underflowDavid Rientjes
If the privileges given to root threads (3% of allowable memory) or a negative value of /proc/pid/oom_score_adj happen to exceed the amount of rss of a thread, its badness score overflows as a result of commit a7f638f999ff ("mm, oom: normalize oom scores to oom_score_adj scale only for userspace"). Fix this by making the type signed and return 1, meaning the thread is still eligible for kill, if the value is negative. Reported-by: Dave Jones <davej@redhat.com> Acked-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm, oom: normalize oom scores to oom_score_adj scale only for userspaceDavid Rientjes
The oom_score_adj scale ranges from -1000 to 1000 and represents the proportion of memory available to the process at allocation time. This means an oom_score_adj value of 300, for example, will bias a process as though it was using an extra 30.0% of available memory and a value of -350 will discount 35.0% of available memory from its usage. The oom killer badness heuristic also uses this scale to report the oom score for each eligible process in determining the "best" process to kill. Thus, it can only differentiate each process's memory usage by 0.1% of system RAM. On large systems, this can end up being a large amount of memory: 256MB on 256GB systems, for example. This can be fixed by having the badness heuristic to use the actual memory usage in scoring threads and then normalizing it to the oom_score_adj scale for userspace. This results in better comparison between eligible threads for kill and no change from the userspace perspective. Suggested-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Tested-by: Dave Jones <davej@redhat.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-03userns: Store uid and gid values in struct cred with kuid_t and kgid_t typesEric W. Biederman
cred.h and a few trivial users of struct cred are changed. The rest of the users of struct cred are left for other patches as there are too many changes to make in one go and leave the change reviewable. If the user namespace is disabled and CONFIG_UIDGID_STRICT_TYPE_CHECKS are disabled the code will contiue to compile and behave correctly. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-03-23signal: oom_kill_task: use SEND_SIG_FORCED instead of force_sig()Oleg Nesterov
Change oom_kill_task() to use do_send_sig_info(SEND_SIG_FORCED) instead of force_sig(SIGKILL). With the recent changes we do not need force_ to kill the CLONE_NEWPID tasks. And this is more correct. force_sig() can race with the exiting thread even if oom_kill_task() checks p->mm != NULL, while do_send_sig_info(group => true) kille the whole process. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Anton Vorontsov <anton.vorontsov@linaro.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21mm, memcg: pass charge order to oom killerDavid Rientjes
The oom killer typically displays the allocation order at the time of oom as a part of its diangostic messages (for global, cpuset, and mempolicy ooms). The memory controller may also pass the charge order to the oom killer so it can emit the same information. This is useful in determining how large the memory allocation is that triggered the oom killer. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Balbir Singh <bsingharora@gmail.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21mm, oom: force oom kill on sysrq+fDavid Rientjes
The oom killer chooses not to kill a thread if: - an eligible thread has already been oom killed and has yet to exit, and - an eligible thread is exiting but has yet to free all its memory and is not the thread attempting to currently allocate memory. SysRq+F manually invokes the global oom killer to kill a memory-hogging task. This is normally done as a last resort to free memory when no progress is being made or to test the oom killer itself. For both uses, we always want to kill a thread and never defer. This patch causes SysRq+F to always kill an eligible thread and can be used to force a kill even if another oom killed thread has failed to exit. Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Pekka Enberg <penberg@kernel.org> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21mm, oom: introduce independent oom killer ratelimit stateDavid Rientjes
printk_ratelimit() uses the global ratelimit state for all printks. The oom killer should not be subjected to this state just because another subsystem or driver may be flooding the kernel log. This patch introduces printk ratelimiting specifically for the oom killer. Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21mm, oom: do not emit oom killer warning if chosen thread is already exitingDavid Rientjes
If a thread is chosen for oom kill and is already PF_EXITING, then the oom killer simply sets TIF_MEMDIE and returns. This allows the thread to have access to memory reserves so that it may quickly exit. This logic is preceeded with a comment saying there's no need to alarm the sysadmin. This patch adds truth to that statement. There's no need to emit any warning about the oom condition if the thread is already exiting since it will not be killed. In this condition, just silently return the oom killer since its only giving access to memory reserves and is otherwise a no-op. Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21mm, oom: fold oom_kill_task() into oom_kill_process()David Rientjes
oom_kill_task() has a single caller, so fold it into its parent function, oom_kill_process(). Slightly reduces the number of lines in the oom killer. Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21mm, oom: avoid looping when chosen thread detaches its mmDavid Rientjes
oom_kill_task() returns non-zero iff the chosen process does not have any threads with an attached ->mm. In such a case, it's better to just return to the page allocator and retry the allocation because memory could have been freed in the interim and the oom condition may no longer exist. It's unnecessary to loop in the oom killer and find another thread to kill. This allows both oom_kill_task() and oom_kill_process() to be converted to void functions. If the oom condition persists, the oom killer will be recalled. Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12mm: unify remaining mem_cont, mem, etc. variable names to memcgJohannes Weiner
Signed-off-by: Johannes Weiner <jweiner@redhat.com> Acked-by: David Rientjes <rientjes@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12mm: oom_kill: remove memcg argument from oom_kill_task()Johannes Weiner
The memcg argument of oom_kill_task() hasn't been used since 341aea2 'oom-kill: remove boost_dying_task_prio()'. Kill it. Signed-off-by: Johannes Weiner <jweiner@redhat.com> Acked-by: David Rientjes <rientjes@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10tracepoint: add tracepoints for debugging oom_score_adjKAMEZAWA Hiroyuki
oom_score_adj is used for guarding processes from OOM-Killer. One of problem is that it's inherited at fork(). When a daemon set oom_score_adj and make children, it's hard to know where the value is set. This patch adds some tracepoints useful for debugging. This patch adds 3 trace points. - creating new task - renaming a task (exec) - set oom_score_adj To debug, users need to enable some trace pointer. Maybe filtering is useful as # EVENT=/sys/kernel/debug/tracing/events/task/ # echo "oom_score_adj != 0" > $EVENT/task_newtask/filter # echo "oom_score_adj != 0" > $EVENT/task_rename/filter # echo 1 > $EVENT/enable # EVENT=/sys/kernel/debug/tracing/events/oom/ # echo 1 > $EVENT/enable output will be like this. # grep oom /sys/kernel/debug/tracing/trace bash-7699 [007] d..3 5140.744510: oom_score_adj_update: pid=7699 comm=bash oom_score_adj=-1000 bash-7699 [007] ...1 5151.818022: task_newtask: pid=7729 comm=bash clone_flags=1200011 oom_score_adj=-1000 ls-7729 [003] ...2 5151.818504: task_rename: pid=7729 oldcomm=bash newcomm=ls oom_score_adj=-1000 bash-7699 [002] ...1 5175.701468: task_newtask: pid=7730 comm=bash clone_flags=1200011 oom_score_adj=-1000 grep-7730 [007] ...2 5175.701993: task_rename: pid=7730 oldcomm=bash newcomm=grep oom_score_adj=-1000 Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-12-21Merge branch 'master' into pm-sleepRafael J. Wysocki
* master: (848 commits) SELinux: Fix RCU deref check warning in sel_netport_insert() binary_sysctl(): fix memory leak mm/vmalloc.c: remove static declaration of va from __get_vm_area_node ipmi_watchdog: restore settings when BMC reset oom: fix integer overflow of points in oom_badness memcg: keep root group unchanged if creation fails nilfs2: potential integer overflow in nilfs_ioctl_clean_segments() nilfs2: unbreak compat ioctl cpusets: stall when updating mems_allowed for mempolicy or disjoint nodemask evm: prevent racing during tfm allocation evm: key must be set once during initialization mmc: vub300: fix type of firmware_rom_wait_states module parameter Revert "mmc: enable runtime PM by default" mmc: sdhci: remove "state" argument from sdhci_suspend_host x86, dumpstack: Fix code bytes breakage due to missing KERN_CONT IB/qib: Correct sense on freectxts increment and decrement RDMA/cma: Verify private data length cgroups: fix a css_set not found bug in cgroup_attach_proc oprofile: Fix uninitialized memory access when writing to writing to oprofilefs Revert "xen/pv-on-hvm kexec: add xs_reset_watches to shutdown watches from old kernel" ... Conflicts: kernel/cgroup_freezer.c
2011-12-20oom: fix integer overflow of points in oom_badnessFrantisek Hrbata
An integer overflow will happen on 64bit archs if task's sum of rss, swapents and nr_ptes exceeds (2^31)/1000 value. This was introduced by commit f755a04 oom: use pte pages in OOM score where the oom score computation was divided into several steps and it's no longer computed as one expression in unsigned long(rss, swapents, nr_pte are unsigned long), where the result value assigned to points(int) is in range(1..1000). So there could be an int overflow while computing 176 points *= 1000; and points may have negative value. Meaning the oom score for a mem hog task will be one. 196 if (points <= 0) 197 return 1; For example: [ 3366] 0 3366 35390480 24303939 5 0 0 oom01 Out of memory: Kill process 3366 (oom01) score 1 or sacrifice child Here the oom1 process consumes more than 24303939(rss)*4096~=92GB physical memory, but it's oom score is one. In this situation the mem hog task is skipped and oom killer kills another and most probably innocent task with oom score greater than one. The points variable should be of type long instead of int to prevent the int overflow. Signed-off-by: Frantisek Hrbata <fhrbata@redhat.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Oleg Nesterov <oleg@redhat.com> Acked-by: David Rientjes <rientjes@google.com> Cc: <stable@vger.kernel.org> [2.6.36+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-21freezer: rename thaw_process() to __thaw_task() and simplify the implementationTejun Heo
thaw_process() now has only internal users - system and cgroup freezers. Remove the unnecessary return value, rename, unexport and collapse __thaw_process() into it. This will help further updates to the freezer code. -v3: oom_kill grew a use of thaw_process() while this patch was pending. Convert it to use __thaw_task() for now. In the longer term, this should be handled by allowing tasks to die if killed even if it's frozen. -v2: minor style update as suggested by Matt. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Paul Menage <menage@google.com> Cc: Matt Helsley <matthltc@us.ibm.com>
2011-11-15oom: do not kill tasks with oom_score_adj OOM_SCORE_ADJ_MINMichal Hocko
Commit c9f01245 ("oom: remove oom_disable_count") has removed the oom_disable_count counter which has been used for early break out from oom_badness so we could never select a task with oom_score_adj set to OOM_SCORE_ADJ_MIN (oom disabled). Now that the counter is gone we are always going through heuristics calculation and we always return a non zero positive value. This means that we can end up killing a task with OOM disabled because it is indistinguishable from regular tasks with 1% resp. CAP_SYS_ADMIN tasks with 3% usage of memory or tasks with oom_score_adj set but OOM enabled. Let's break out early if the task should have OOM disabled. Signed-off-by: Michal Hocko <mhocko@suse.cz> Acked-by: David Rientjes <rientjes@google.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-10-31oom: fix race while temporarily setting current's oom_score_adjDavid Rientjes
test_set_oom_score_adj() was introduced in 72788c385604 ("oom: replace PF_OOM_ORIGIN with toggling oom_score_adj") to temporarily elevate current's oom_score_adj for ksm and swapoff without requiring an additional per-process flag. Using that function to both set oom_score_adj to OOM_SCORE_ADJ_MAX and then reinstate the previous value is racy since it's possible that userspace can set the value to something else itself before the old value is reinstated. That results in userspace setting current's oom_score_adj to a different value and then the kernel immediately setting it back to its previous value without notification. To fix this, a new compare_swap_oom_score_adj() function is introduced with the same semantics as the compare and swap CAS instruction, or CMPXCHG on x86. It is used to reinstate the previous value of oom_score_adj if and only if the present value is the same as the old value. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Ying Han <yinghan@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31oom: remove oom_disable_countDavid Rientjes
This removes mm->oom_disable_count entirely since it's unnecessary and currently buggy. The counter was intended to be per-process but it's currently decremented in the exit path for each thread that exits, causing it to underflow. The count was originally intended to prevent oom killing threads that share memory with threads that cannot be killed since it doesn't lead to future memory freeing. The counter could be fixed to represent all threads sharing the same mm, but it's better to remove the count since: - it is possible that the OOM_DISABLE thread sharing memory with the victim is waiting on that thread to exit and will actually cause future memory freeing, and - there is no guarantee that a thread is disabled from oom killing just because another thread sharing its mm is oom disabled. Signed-off-by: David Rientjes <rientjes@google.com> Reported-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Cc: Ying Han <yinghan@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31oom: avoid killing kthreads if they assume the oom killed thread's mmDavid Rientjes
After selecting a task to kill, the oom killer iterates all processes and kills all other threads that share the same mm_struct in different thread groups. It would not otherwise be helpful to kill a thread if its memory would not be subsequently freed. A kernel thread, however, may assume a user thread's mm by using use_mm(). This is only temporary and should not result in sending a SIGKILL to that kthread. This patch ensures that only user threads and not kthreads are sent a SIGKILL if they share the same mm_struct as the oom killed task. Signed-off-by: David Rientjes <rientjes@google.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31oom: thaw threads if oom killed thread is frozen before deferringDavid Rientjes
If a thread has been oom killed and is frozen, thaw it before returning to the page allocator. Otherwise, it can stay frozen indefinitely and no memory will be freed. Signed-off-by: David Rientjes <rientjes@google.com> Reported-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Acked-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31mm: Map most files to use export.h instead of module.hPaul Gortmaker
The files changed within are only using the EXPORT_SYMBOL macro variants. They are not using core modular infrastructure and hence don't need module.h but only the export.h header. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
